[GRASS-SVN] r52956 - in grass/trunk: lib/gis tools/g.html2man
svn_grass at osgeo.org
Tue Aug 28 11:00:56 PDT 2012
Author: glynn
Date: 2012-08-28 11:00:56 -0700 (Tue, 28 Aug 2012)
New Revision: 52956
Added:
grass/trunk/tools/g.html2man/rest.py
grass/trunk/lib/gis/parser_html.c
Make --html-description output easier to parse
Add ReST generator
Modified: grass/trunk/lib/gis/parser_html.c
--- grass/trunk/lib/gis/parser_html.c 2012-08-28 15:50:22 UTC (rev 52955)
+++ grass/trunk/lib/gis/parser_html.c 2012-08-28 18:00:56 UTC (rev 52956)
@@ -69,10 +69,10 @@
fprintf(stdout, "\n");
fprintf(stdout, "<h2>%s</h2>\n", _("SYNOPSIS"));
- fprintf(stdout, "<b>%s</b><br>\n", st->pgm_name);
+ fprintf(stdout, "<div id=\"name\"><b>%s</b><br></div>\n", st->pgm_name);
fprintf(stdout, "<b>%s help</b><br>\n", st->pgm_name);
- fprintf(stdout, "<b>%s</b>", st->pgm_name);
+ fprintf(stdout, "<div id=\"synopsis\"><b>%s</b>", st->pgm_name);
@@ -129,11 +129,12 @@
fprintf(stdout, " [--<b>verbose</b>] ");
fprintf(stdout, " [--<b>quiet</b>] ");
- fprintf(stdout, "\n");
+ fprintf(stdout, "\n</div>\n");
/* now long version */
+ fprintf(stdout, "<div id=\"flags\">\n");
if (st->n_flags || new_prompt) {
flag = &st->first_flag;
fprintf(stdout, "<h3>%s:</h3>\n", _("Flags"));
@@ -170,8 +171,10 @@
fprintf(stdout, "</dl>\n");
+ fprintf(stdout, "</div>\n");
+ fprintf(stdout, "<div id=\"parameters\">\n");
if (st->n_opts) {
opt = &st->first_option;
fprintf(stdout, "<h3>%s:</h3>\n", _("Parameters"));
@@ -249,6 +252,7 @@
fprintf(stdout, "</body>\n</html>\n");
Added: grass/trunk/tools/g.html2man/rest.py
--- grass/trunk/tools/g.html2man/rest.py (rev 0)
+++ grass/trunk/tools/g.html2man/rest.py 2012-08-28 18:00:56 UTC (rev 52956)
@@ -0,0 +1,126 @@
+import sys
+def match(node, tag, attr=None, val=None):
+ if not isinstance(node, tuple):
+ return False
+ if node[0] != tag:
+ return False
+ if attr is not None:
+ attrs = dict(node[1])
+ if attr not in attrs:
+ return False
+ if attrs[attr] != val:
+ return False
+ return True
+def find(node, tag, attr=None, val=None):
+ if isinstance(node, tuple):
+ node = node[2]
+ if not isinstance(node, list):
+ raise ValueError('child not found')
+ for child in node:
+ if match(child, tag, attr, val):
+ return child
+def children(node):
+ return node[2]
+def text(node):
+ return children(node)[0]
+def _(s):
+ return s # TODO
+def rest(root, f = sys.stdout):
+ def write(text):
+ f.write(text)
+ def show(item, italic=False, bold=False):
+ if isinstance(item, str):
+ spc = '' # if item[-1] == '\n' else ' '
+ fmt = '**' if bold else ('*' if italic else '')
+ write('%s%s%s%s' % (fmt, item, fmt, spc))
+ elif match(item, 'b'):
+ for i in children(item):
+ show(i, italic, True)
+ elif match(item, 'i') or match(item, 'em'):
+ show(i, True, bold)
+ html = find(root, 'html')
+ title = text(find(find(html, 'head'), 'title'))
+ rule = '=' * len(title)
+ write('%s\n' % rule)
+ write('%s\n' % title)
+ write('\n')
+ write(".. figure:: grass_logo.png\n")
+ write(" :align: center\n")
+ write(" :alt: GRASS logo\n")
+ write('\n')
+ body = find(html, 'body')
+ section = None
+ for child in children(body):
+ if match(child, 'h2'):
+ section = text(child)
+ rule = '-' * len(section)
+ write("%s\n%s\n" % (section, rule))
+ elif section == _('NAME'):
+ if match(child, 'em'):
+ name = text(find(child, 'b'))
+ write("**%s**" % name)
+ section = 'desc'
+ elif section == 'desc' and isinstance(child, str) and child[:4] == ' - ':
+ write(' - ')
+ write(child[4:])
+ if child[-1] != '\n':
+ write('\n')
+ write('\n')
+ section = None
+ elif section == _('KEYWORDS'):
+ write(child.strip())
+ write('\n\n')
+ section = None
+ elif section == _('SYNOPSIS'):
+ if match(child, 'div', 'id', 'name'):
+ write("**%s**\n\n" % name)
+ write("**%s** help\n\n" % name)
+ elif match(child, 'div', 'id', 'synopsis'):
+ for item in children(child):
+ show(item)
+ write('\n')
+ elif match(child, 'div', 'id', 'flags'):
+ header = text(find(child, 'h3'))
+ rule = '=' * len(header)
+ write('%s\n%s\n' % (header, rule))
+ flags = find(child, 'dl')
+ for flag in children(flags):
+ if match(flag, 'dt'):
+ item = text(find(flag, 'b'))
+ write('**%s**\n' % item)
+ elif match(flag, 'dd'):
+ write(' %s\n' % text(flag))
+ write('\n\n')
+ elif match(child, 'div', 'id', 'parameters'):
+ params = find(child, 'dl')
+ for param in children(params):
+ if match(param, 'dt'):
+ name = text(children(param)[0])
+ write('**%s** = ' % name)
+ for item in children(param)[2:]:
+ show(item)
+ write('\n\n')
+ elif match(param, 'dd'):
+ write('\t')
+ for item in children(param):
+ show(item)
+ write('\n\n')
+ write('\n')
+ return
