[GRASS-SVN] r52966 - in grass/trunk: imagery/i.emissivity raster/r.gwflow raster3d/r3.gwflow scripts/i.image.mosaic scripts/i.landsat.rgb scripts/i.oif temporal/t.rast.list temporal/t.rast.out.vtk temporal/t.rast3d.list temporal/t.unregister vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment vector/v.lrs/v.lrs.where
Wed Aug 29 00:53:03 PDT 2012
Author: neteler
Date: 2012-08-29 00:53:02 -0700 (Wed, 29 Aug 2012)
New Revision: 52966
   grass/trunk/imagery/i.emissivity/main.c
   grass/trunk/raster/r.gwflow/main.c
   grass/trunk/raster3d/r3.gwflow/main.c
   grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
   grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
   grass/trunk/scripts/i.oif/i.oif.py
   grass/trunk/temporal/t.rast.list/t.rast.list.py
   grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
   grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
   grass/trunk/temporal/t.unregister/t.unregister.py
   grass/trunk/vector/v.lrs/v.lrs.create/main.c
   grass/trunk/vector/v.lrs/v.lrs.label/main.c
   grass/trunk/vector/v.lrs/v.lrs.segment/main.c
   grass/trunk/vector/v.lrs/v.lrs.where/main.c
homogenize keywords
Modified: grass/trunk/imagery/i.emissivity/main.c
--- grass/trunk/imagery/i.emissivity/main.c	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/imagery/i.emissivity/main.c	2012-08-29 07:53:02 UTC (rev 52966)
@@ -41,11 +41,12 @@
     G_gisinit(argv[0]);
     module = G_define_module();
+    G_add_keyword(_("imagery"));
     G_add_keyword(_("emissivity"));
     G_add_keyword(_("land flux"));
     G_add_keyword(_("energy balance"));
     module->description =
-	_("Computes emissivity from NDVI, generic method for spares land.");
+	_("Computes emissivity from NDVI, generic method for sparse land.");
     /* Define the different options */
     input = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/raster/r.gwflow/main.c
--- grass/trunk/raster/r.gwflow/main.c	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/raster/r.gwflow/main.c	2012-08-29 07:53:02 UTC (rev 52966)
@@ -204,6 +204,7 @@
     G_add_keyword(_("raster"));
     G_add_keyword(_("groundwater flow"));
+    G_add_keyword(_("hydrology"));
 	_("Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions.");
Modified: grass/trunk/raster3d/r3.gwflow/main.c
--- grass/trunk/raster3d/r3.gwflow/main.c	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/raster3d/r3.gwflow/main.c	2012-08-29 07:53:02 UTC (rev 52966)
@@ -157,12 +157,10 @@
     G_add_keyword(_("raster3d"));
+    G_add_keyword(_("groundwater flow"));
     G_add_keyword(_("voxel"));
-    G_add_keyword(_("groundwater"));
-    G_add_keyword(_("numeric"));
-    G_add_keyword(_("simulation"));
-    module->description = _("Numerical calculation program for transient, confined groundwater flow in three dimensions");
+    module->description = _("Numerical calculation program for transient, confined groundwater flow in three dimensions.");
     /* Get parameters from user */
     set_params();
Modified: grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
--- grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py	2012-08-29 07:53:02 UTC (rev 52966)
@@ -24,8 +24,8 @@
 #%module
 #% description: Mosaics several images and extends colormap.
-#% keywords: raster
 #% keywords: imagery
+#% keywords: geometry
 #% keywords: mosaicking
 #%end
 #%option G_OPT_R_INPUTS
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py	2012-08-29 07:53:02 UTC (rev 52966)
@@ -22,8 +22,8 @@
 #%module
 #% description: Performs auto-balancing of colors for LANDSAT images.
+#% keywords: landsat
 #% keywords: colors
 #%end
Modified: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/scripts/i.oif/i.oif.py	2012-08-29 07:53:02 UTC (rev 52966)
@@ -24,10 +24,10 @@
 #% Module
-#%  description: Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7
-#%  keywords: imagery
-#%  keywords: statistics
+#% description: Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7
+#% keywords: imagery
+#% keywords: statistics
 #% End
 #% option G_OPT_R_INPUT
 #% key: image1
Modified: grass/trunk/temporal/t.rast.list/t.rast.list.py
--- grass/trunk/temporal/t.rast.list/t.rast.list.py	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/temporal/t.rast.list/t.rast.list.py	2012-08-29 07:53:02 UTC (rev 52966)
@@ -17,6 +17,7 @@
 #%module
 #% description: Lists registered maps of a space time raster dataset.
 #% keywords: temporal
+#% keywords: map management
 #% keywords: raster
 #% keywords: list
 #%end
Modified: grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
--- grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py	2012-08-29 07:53:02 UTC (rev 52966)
@@ -16,10 +16,9 @@
 #%module
 #% description: Exports space time raster dataset as VTK time series.
-#% keywords: dataset
-#% keywords: spacetime
+#% keywords: temporal
 #% keywords: export
+#% keywords: raster
 #% keywords: VTK
 #%end
Modified: grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
--- grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py	2012-08-29 07:53:02 UTC (rev 52966)
@@ -16,8 +16,8 @@
 #%module
 #% description: Lists registered maps of a space time raster3d dataset.
 #% keywords: raster3d
 #% keywords: list
 #%end
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/temporal/t.unregister/t.unregister.py	2012-08-29 07:53:02 UTC (rev 52966)
@@ -17,6 +17,7 @@
 #%module
 #% description: Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset.
 #% keywords: unregister
 #%end
Modified: grass/trunk/vector/v.lrs/v.lrs.create/main.c
--- grass/trunk/vector/v.lrs/v.lrs.create/main.c	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/vector/v.lrs/v.lrs.create/main.c	2012-08-29 07:53:02 UTC (rev 52966)
@@ -119,9 +119,9 @@
     G_add_keyword(_("vector"));
-    G_add_keyword(_("LRS"));
+    G_add_keyword(_("Linear Reference System"));
     G_add_keyword(_("networking"));
-    module->description = _("Create Linear Reference System");
+    module->description = _("Creates a linear reference system.");
     in_lines_opt = G_define_standard_option(G_OPT_V_INPUT);
     in_lines_opt->key = "in_lines";
Modified: grass/trunk/vector/v.lrs/v.lrs.label/main.c
--- grass/trunk/vector/v.lrs/v.lrs.label/main.c	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/vector/v.lrs/v.lrs.label/main.c	2012-08-29 07:53:02 UTC (rev 52966)
@@ -100,10 +100,10 @@
-    module->description = _("Create stationing from input lines, "
-			    "and linear reference system");
+    module->description = _("Creates stationing from input lines, "
+			    "and linear reference system.");
     in_opt = G_define_standard_option(G_OPT_V_INPUT);
     in_opt->description = _("Input vector map containing lines");
Modified: grass/trunk/vector/v.lrs/v.lrs.segment/main.c
--- grass/trunk/vector/v.lrs/v.lrs.segment/main.c	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/vector/v.lrs/v.lrs.segment/main.c	2012-08-29 07:53:02 UTC (rev 52966)
@@ -68,7 +68,7 @@
 	_("Creates points/segments from input lines, linear reference "
Modified: grass/trunk/vector/v.lrs/v.lrs.where/main.c
--- grass/trunk/vector/v.lrs/v.lrs.where/main.c	2012-08-29 07:50:44 UTC (rev 52965)
+++ grass/trunk/vector/v.lrs/v.lrs.where/main.c	2012-08-29 07:53:02 UTC (rev 52966)
@@ -55,7 +55,7 @@
 	_("Finds line id and real km+offset for given points in vector map "
