[GRASS-SVN] r52973 - in grass/trunk: scripts/d.vect.thematic scripts/v.db.addcolumn scripts/v.db.addtable scripts/v.db.dropcolumn scripts/v.db.droprow scripts/v.db.droptable scripts/v.db.join scripts/v.db.reconnect.all scripts/v.db.renamecolumn scripts/v.db.univar scripts/v.db.update temporal/t.vect.db.select vector/v.db.connect vector/v.db.select visualization/nviz/src
Wed Aug 29 05:29:23 PDT 2012
Author: neteler
Date: 2012-08-29 05:29:23 -0700 (Wed, 29 Aug 2012)
New Revision: 52973
   grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
   grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
   grass/trunk/scripts/v.db.addtable/v.db.addtable.py
   grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
   grass/trunk/scripts/v.db.droprow/v.db.droprow.py
   grass/trunk/scripts/v.db.droptable/v.db.droptable.py
   grass/trunk/scripts/v.db.join/v.db.join.py
   grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
   grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
   grass/trunk/scripts/v.db.univar/v.db.univar.py
   grass/trunk/scripts/v.db.update/v.db.update.py
   grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
   grass/trunk/vector/v.db.connect/main.c
   grass/trunk/vector/v.db.select/main.c
   grass/trunk/visualization/nviz/src/nvizMain.c
homogenize keywords
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -19,6 +19,7 @@
 #%module
 #% description: Displays thematic vector map
 #% keywords: display
+#% keywords: cartography
 #% keywords: vector
 #% keywords: thematic
 #% keywords: legend
Modified: grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -19,8 +19,8 @@
 #%module
 #% description: Adds one or more columns to the attribute table connected to a given vector map.
 #% keywords: vector
+#% keywords: attribute table
 #% keywords: database
-#% keywords: attribute table
 #%end
 #%option G_OPT_V_MAP
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -18,8 +18,8 @@
 #%module
 #% description: Creates and connects a new attribute table to a given layer of an existing vector map.
 #% keywords: vector
 #%end
 #%end
Modified: grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
--- grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -21,8 +21,8 @@
 #%module
 #% description: Drops a column from the attribute table connected to a given vector map.
 #% keywords: vector
 #%end
Modified: grass/trunk/scripts/v.db.droprow/v.db.droprow.py
--- grass/trunk/scripts/v.db.droprow/v.db.droprow.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.droprow/v.db.droprow.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -18,8 +18,8 @@
 #%module
 #% description: Removes a vector feature from a vector map through attribute selection.
 #% keywords: vector
 #%end
 #%option G_OPT_V_INPUT
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -16,14 +16,14 @@
 #%Module
-#%  description: Removes existing attribute table of a vector map.
-#%  keywords: vector
-#%  keywords: database
+#% description: Removes existing attribute table of a vector map.
+#% keywords: vector
+#% keywords: database
 #%End
 #%flag
-#%  key: f
-#%  description: Force removal (required for actual deletion of table)
+#% key: f
+#% description: Force removal (required for actual deletion of table)
 #%end
 #%end
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.join/v.db.join.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -17,8 +17,8 @@
 #%module
 #% description: Allows to join a table to a vector map table.
 #% keywords: vector
 #%end
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -16,8 +16,8 @@
 #%module
 #% description: Reconnects vectors to a new database.
 #% keywords: vector
 #%end
 #%option G_OPT_DB_DATABASE
 #% key: old_database
Modified: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
--- grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -23,8 +23,8 @@
 #%module
 #% description: Renames a column in the attribute table connected to a given vector map.
 #% keywords: vector
 #%end
 #%end
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -20,6 +20,7 @@
 #% description: Calculates univariate statistics on selected table column for a GRASS vector map.
 #% keywords: vector
 #% keywords: statistics
 #%end
 #%flag
 #% key: e
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/scripts/v.db.update/v.db.update.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -18,8 +18,8 @@
 #%module
 #% description: Allows to update a column in the attribute table connected to a vector map.
 #% keywords: vector
 #%end
 #%end
Modified: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
--- grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py	2012-08-29 12:29:23 UTC (rev 52973)
@@ -17,9 +17,9 @@
 #%module
 #% description: Prints attributes of vector maps registered in a space time vector dataset.
 #% keywords: temporal
 #% keywords: vector
 #% keywords: select
 #%end
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/vector/v.db.connect/main.c	2012-08-29 12:29:23 UTC (rev 52973)
@@ -49,8 +49,8 @@
     module = G_define_module();
     G_add_keyword(_("vector"));
+    G_add_keyword(_("attribute table"));
     G_add_keyword(_("database"));
-    G_add_keyword(_("attribute table"));
     module->description =
 	_("Prints/sets DB connection for a vector map to attribute table.");
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/vector/v.db.select/main.c	2012-08-29 12:29:23 UTC (rev 52973)
@@ -50,8 +50,8 @@
     module->description = _("Prints vector map attributes.");
     map_opt = G_define_standard_option(G_OPT_V_MAP);
Modified: grass/trunk/visualization/nviz/src/nvizMain.c
--- grass/trunk/visualization/nviz/src/nvizMain.c	2012-08-29 11:58:20 UTC (rev 52972)
+++ grass/trunk/visualization/nviz/src/nvizMain.c	2012-08-29 12:29:23 UTC (rev 52973)
@@ -69,6 +69,7 @@
     G_add_keyword(_("visualization"));
+    G_add_keyword(_("graphics"));
     G_add_keyword(_("raster"));
     G_add_keyword(_("raster3d"));
