[GRASS-SVN] r54175 - grass/trunk
Tue Dec 4 00:11:18 PST 2012
Author: neteler
Date: 2012-12-04 00:11:17 -0800 (Tue, 04 Dec 2012)
New Revision: 54175
   grass/trunk/aclocal.m4
   grass/trunk/configure
fix/workaround for r54167
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4	2012-12-04 00:02:32 UTC (rev 54174)
+++ grass/trunk/aclocal.m4	2012-12-04 08:11:17 UTC (rev 54175)
@@ -506,6 +506,12 @@
 	    LD_LIBRARY_PATH_VAR="PATH"
         *-pc-mingw32)
+            SHLIB_LD_LIBS='${LIBS}'
+            SHLIB_SUFFIX=".dll"
+            SHLIB_LD="${CC} -shared"
+            LDFLAGS="-Wl,--export-dynamic,--enable-runtime-pseudo-reloc"
+            LD_LIBRARY_PATH_VAR="PATH"
         *-pc-msys)
             SHLIB_SUFFIX=".dll"
Modified: grass/trunk/configure
--- grass/trunk/configure	2012-12-04 00:02:32 UTC (rev 54174)
+++ grass/trunk/configure	2012-12-04 08:11:17 UTC (rev 54175)
@@ -1504,6 +1504,12 @@
         *-pc-mingw32)
         *-pc-msys)
             SHLIB_SUFFIX=".dll"
@@ -2231,7 +2237,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2235: checking for additional include dirs" >&5
+echo "configure:2241: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2254,7 +2260,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2258: checking for additional library dirs" >&5
+echo "configure:2264: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2288,7 +2294,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2292: checking for a BSD compatible install" >&5
+echo "configure:2298: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -2341,7 +2347,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:2345: checking for $ac_word" >&5
+echo "configure:2351: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2372,13 +2378,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2376: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2382: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-l$ac_lib  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 2382 "configure"
+#line 2388 "configure"
 #include "confdefs.h"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -2389,7 +2395,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:2393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -2414,7 +2420,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:2418: checking for $ac_word" >&5
+echo "configure:2424: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -2454,7 +2460,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:2458: checking for $ac_word" >&5
+echo "configure:2464: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2485,7 +2491,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:2489: checking for $ac_word" >&5
+echo "configure:2495: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -2523,7 +2529,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:2527: checking for $ac_word" >&5
+echo "configure:2533: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2552,7 +2558,7 @@
-echo "configure:2556: checking for $ac_word" >&5
+echo "configure:2562: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2583,7 +2589,7 @@
-echo "configure:2587: checking for $ac_word" >&5
+echo "configure:2593: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2612,7 +2618,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:2616: checking for $ac_word" >&5
+echo "configure:2622: checking for $ac_word" >&5
 case "$PERL" in
@@ -2643,7 +2649,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2647: checking how to run the C preprocessor" >&5
+echo "configure:2653: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -2656,13 +2662,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 2660 "configure"
+#line 2666 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -2673,13 +2679,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 2677 "configure"
+#line 2683 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2683: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2690,13 +2696,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 2694 "configure"
+#line 2700 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2700: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2706: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2720,10 +2726,10 @@
 echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2724: checking for ANSI C header files" >&5
+echo "configure:2730: checking for ANSI C header files" >&5
-#line 2727 "configure"
+#line 2733 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -2731,7 +2737,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:2735: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2748,7 +2754,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2752 "configure"
+#line 2758 "configure"
 #include <string.h>
 EOF
@@ -2766,7 +2772,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2770 "configure"
+#line 2776 "configure"
 #include <stdlib.h>
 EOF
@@ -2787,7 +2793,7 @@
 else
-#line 2791 "configure"
+#line 2797 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2798,7 +2804,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:2802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -2825,15 +2831,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2829: checking for $ac_hdr" >&5
+echo "configure:2835: checking for $ac_hdr" >&5
-#line 2832 "configure"
+#line 2838 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2862,15 +2868,15 @@
 do
-echo "configure:2866: checking for $ac_hdr" >&5
+echo "configure:2872: checking for $ac_hdr" >&5
-#line 2869 "configure"
+#line 2875 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2880: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2899,15 +2905,15 @@
 do
-echo "configure:2903: checking for $ac_hdr" >&5
+echo "configure:2909: checking for $ac_hdr" >&5
-#line 2906 "configure"
+#line 2912 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2911: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2917: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2936,15 +2942,15 @@
 do
-echo "configure:2940: checking for $ac_hdr" >&5
+echo "configure:2946: checking for $ac_hdr" >&5
-#line 2943 "configure"
+#line 2949 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2948: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2954: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2973,15 +2979,15 @@
 do
-echo "configure:2977: checking for $ac_hdr" >&5
+echo "configure:2983: checking for $ac_hdr" >&5
-#line 2980 "configure"
+#line 2986 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2985: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2991: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3007,10 +3013,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3011: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3017: checking whether time.h and sys/time.h may both be included" >&5
-#line 3014 "configure"
+#line 3020 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -3019,7 +3025,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:3023: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3029: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -3039,10 +3045,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3043: checking for off_t" >&5
+echo "configure:3049: checking for off_t" >&5
-#line 3046 "configure"
+#line 3052 "configure"
 #if STDC_HEADERS
@@ -3069,10 +3075,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3073: checking for uid_t in sys/types.h" >&5
+echo "configure:3079: checking for uid_t in sys/types.h" >&5
-#line 3076 "configure"
+#line 3082 "configure"
 EOF
@@ -3100,10 +3106,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3104: checking return type of signal handlers" >&5
+echo "configure:3110: checking return type of signal handlers" >&5
-#line 3107 "configure"
+#line 3113 "configure"
 #include <signal.h>
@@ -3120,7 +3126,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:3124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3130: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -3138,10 +3144,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3142: checking for Cygwin environment" >&5
+echo "configure:3148: checking for Cygwin environment" >&5
-#line 3145 "configure"
+#line 3151 "configure"
 int main() {
@@ -3152,7 +3158,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:3156: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3162: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -3170,10 +3176,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3174: checking for $ac_func" >&5
+echo "configure:3180: checking for $ac_func" >&5
-#line 3177 "configure"
+#line 3183 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -3196,7 +3202,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -3222,10 +3228,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:3226: checking for $ac_func" >&5
+echo "configure:3232: checking for $ac_func" >&5
-#line 3229 "configure"
+#line 3235 "configure"
@@ -3248,7 +3254,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3274,10 +3280,10 @@
 for ac_func in drand48
 do
-echo "configure:3278: checking for $ac_func" >&5
+echo "configure:3284: checking for $ac_func" >&5
-#line 3281 "configure"
+#line 3287 "configure"
@@ -3300,7 +3306,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3326,10 +3332,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:3330: checking for $ac_func" >&5
+echo "configure:3336: checking for $ac_func" >&5
-#line 3333 "configure"
+#line 3339 "configure"
@@ -3352,7 +3358,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3378,10 +3384,10 @@
 for ac_func in nanosleep
 do
-echo "configure:3382: checking for $ac_func" >&5
+echo "configure:3388: checking for $ac_func" >&5
-#line 3385 "configure"
+#line 3391 "configure"
@@ -3404,7 +3410,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3429,13 +3435,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3433: checking whether setpgrp takes no argument" >&5
+echo "configure:3439: checking whether setpgrp takes no argument" >&5
 if test "$cross_compiling" = yes; then
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 3439 "configure"
+#line 3445 "configure"
 #ifdef HAVE_UNISTD_H
@@ -3455,7 +3461,7 @@
 EOF
-if { (eval echo configure:3459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -3483,16 +3489,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3487: checking for long long int" >&5
+echo "configure:3493: checking for long long int" >&5
-#line 3489 "configure"
+#line 3495 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:3496: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3502: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 echo "$ac_t""yes" 1>&6
@@ -3512,7 +3518,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3516: checking for W11" >&5
+echo "configure:3522: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3540,7 +3546,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3544: checking for X" >&5
+echo "configure:3550: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3600,12 +3606,12 @@
   # First, try using that file with no special directory specified.
-#line 3604 "configure"
+#line 3610 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:3609: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3615: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3674,14 +3680,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3678 "configure"
+#line 3684 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -3786,17 +3792,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3790: checking whether -R must be followed by a space" >&5
+echo "configure:3796: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3793 "configure"
+#line 3799 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3812,14 +3818,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3816 "configure"
+#line 3822 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -3851,13 +3857,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3855: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3861: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 3861 "configure"
+#line 3867 "configure"
@@ -3868,7 +3874,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3889,13 +3895,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3893: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3899: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 3899 "configure"
+#line 3905 "configure"
@@ -3906,7 +3912,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3934,10 +3940,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3938: checking for gethostbyname" >&5
+echo "configure:3944: checking for gethostbyname" >&5
-#line 3941 "configure"
+#line 3947 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -3960,7 +3966,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -3980,13 +3986,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:3984: checking for gethostbyname in -lnsl" >&5
+echo "configure:3990: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 3990 "configure"
+#line 3996 "configure"
@@ -3997,7 +4003,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4026,10 +4032,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4030: checking for connect" >&5
+echo "configure:4036: checking for connect" >&5
-#line 4033 "configure"
+#line 4039 "configure"
     which can conflict with char connect(); below.  */
@@ -4052,7 +4058,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4072,13 +4078,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4076: checking for connect in -lsocket" >&5
+echo "configure:4082: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4082 "configure"
+#line 4088 "configure"
@@ -4089,7 +4095,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4112,10 +4118,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4116: checking for remove" >&5
+echo "configure:4122: checking for remove" >&5
-#line 4119 "configure"
+#line 4125 "configure"
     which can conflict with char remove(); below.  */
@@ -4138,7 +4144,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4158,13 +4164,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4162: checking for remove in -lposix" >&5
+echo "configure:4168: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4168 "configure"
+#line 4174 "configure"
@@ -4175,7 +4181,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4198,10 +4204,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4202: checking for shmat" >&5
+echo "configure:4208: checking for shmat" >&5
-#line 4205 "configure"
+#line 4211 "configure"
     which can conflict with char shmat(); below.  */
@@ -4224,7 +4230,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4244,13 +4250,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4248: checking for shmat in -lipc" >&5
+echo "configure:4254: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4254 "configure"
+#line 4260 "configure"
@@ -4261,7 +4267,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4293,13 +4299,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4297: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4303: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4303 "configure"
+#line 4309 "configure"
@@ -4310,7 +4316,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4350,12 +4356,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4354: checking for library containing cuserid" >&5
+echo "configure:4360: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4359 "configure"
+#line 4365 "configure"
@@ -4366,7 +4372,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4377,7 +4383,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4381 "configure"
+#line 4387 "configure"
@@ -4388,7 +4394,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4414,10 +4420,10 @@
 for ac_func in asprintf
 do
-echo "configure:4418: checking for $ac_func" >&5
+echo "configure:4424: checking for $ac_func" >&5
-#line 4421 "configure"
+#line 4427 "configure"
@@ -4440,7 +4446,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4467,10 +4473,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4471: checking for atan" >&5
+echo "configure:4477: checking for atan" >&5
-#line 4474 "configure"
+#line 4480 "configure"
     which can conflict with char atan(); below.  */
@@ -4493,7 +4499,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4511,13 +4517,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4515: checking for atan in -lm" >&5
+echo "configure:4521: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4521 "configure"
+#line 4527 "configure"
@@ -4528,7 +4534,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4555,10 +4561,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4559: checking for dlsym" >&5
+echo "configure:4565: checking for dlsym" >&5
-#line 4562 "configure"
+#line 4568 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4581,7 +4587,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4599,13 +4605,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4603: checking for dlsym in -ldl" >&5
+echo "configure:4609: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4609 "configure"
+#line 4615 "configure"
@@ -4616,7 +4622,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4643,10 +4649,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4647: checking for iconv" >&5
+echo "configure:4653: checking for iconv" >&5
-#line 4650 "configure"
+#line 4656 "configure"
     which can conflict with char iconv(); below.  */
@@ -4669,7 +4675,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4687,13 +4693,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4691: checking for iconv in -liconv" >&5
+echo "configure:4697: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4697 "configure"
+#line 4703 "configure"
@@ -4704,7 +4710,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4723,13 +4729,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4727: checking for iconv in -lgiconv" >&5
+echo "configure:4733: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4733 "configure"
+#line 4739 "configure"
@@ -4740,7 +4746,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4759,10 +4765,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4763: checking for libiconv" >&5
+echo "configure:4769: checking for libiconv" >&5
-#line 4766 "configure"
+#line 4772 "configure"
     which can conflict with char libiconv(); below.  */
@@ -4785,7 +4791,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -4803,13 +4809,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4807: checking for libiconv in -liconv" >&5
+echo "configure:4813: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4813 "configure"
+#line 4819 "configure"
@@ -4820,7 +4826,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4839,13 +4845,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4843: checking for libiconv in -lgiconv" >&5
+echo "configure:4849: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4849 "configure"
+#line 4855 "configure"
@@ -4856,7 +4862,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4893,10 +4899,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4897: checking for socket" >&5
+echo "configure:4903: checking for socket" >&5
-#line 4900 "configure"
+#line 4906 "configure"
     which can conflict with char socket(); below.  */
@@ -4919,7 +4925,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -4937,13 +4943,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:4941: checking for socket in -lsocket" >&5
+echo "configure:4947: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 4947 "configure"
+#line 4953 "configure"
@@ -4954,7 +4960,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:4958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5002,7 +5008,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5006: checking for location of zlib includes" >&5
+echo "configure:5012: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5028,15 +5034,15 @@
 do
-echo "configure:5032: checking for $ac_hdr" >&5
+echo "configure:5038: checking for $ac_hdr" >&5
-#line 5035 "configure"
+#line 5041 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5040: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5070,7 +5076,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5074: checking for location of zlib library" >&5
+echo "configure:5080: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5095,13 +5101,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5099: checking for deflate in -lz" >&5
+echo "configure:5105: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5105 "configure"
+#line 5111 "configure"
@@ -5112,7 +5118,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5160,7 +5166,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5164: checking for location of External PROJ.4 includes" >&5
+echo "configure:5170: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5186,15 +5192,15 @@
 do
-echo "configure:5190: checking for $ac_hdr" >&5
+echo "configure:5196: checking for $ac_hdr" >&5
-#line 5193 "configure"
+#line 5199 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5198: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5204: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5231,7 +5237,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5235: checking External PROJ.4 version" >&5
+echo "configure:5241: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5239,7 +5245,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 5243 "configure"
+#line 5249 "configure"
 #include <stdio.h>
@@ -5251,7 +5257,7 @@
 EOF
-if { (eval echo configure:5255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5276,7 +5282,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5280: checking for location of External PROJ.4 library" >&5
+echo "configure:5286: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5301,13 +5307,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5305: checking for pj_get_def in -lproj" >&5
+echo "configure:5311: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5311 "configure"
+#line 5317 "configure"
@@ -5318,7 +5324,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5352,7 +5358,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5356: checking for location of External PROJ.4 data files" >&5
+echo "configure:5362: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5376,14 +5382,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5380: checking for epsg" >&5
+echo "configure:5386: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5387: checking for $PROJSHARE/epsg" >&5
+echo "configure:5393: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5415,7 +5421,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:5419: checking for $ac_word" >&5
+echo "configure:5425: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5455,7 +5461,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5459: checking whether to use regex" >&5
+echo "configure:5465: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5475,7 +5481,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5479: checking for location of regex includes" >&5
+echo "configure:5485: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5501,15 +5507,15 @@
 do
-echo "configure:5505: checking for $ac_hdr" >&5
+echo "configure:5511: checking for $ac_hdr" >&5
-#line 5508 "configure"
+#line 5514 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5519: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5543,7 +5549,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5547: checking for location of regex library" >&5
+echo "configure:5553: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5568,10 +5574,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5572: checking for regcomp" >&5
+echo "configure:5578: checking for regcomp" >&5
-#line 5575 "configure"
+#line 5581 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5594,7 +5600,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5621,13 +5627,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5625: checking for regcomp in -lregex" >&5
+echo "configure:5631: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5631 "configure"
+#line 5637 "configure"
@@ -5638,7 +5644,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5688,7 +5694,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5692: checking whether to use Readline" >&5
+echo "configure:5698: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5709,7 +5715,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5713: checking for location of Readline includes" >&5
+echo "configure:5719: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5735,15 +5741,15 @@
 do
-echo "configure:5739: checking for $ac_hdr" >&5
+echo "configure:5745: checking for $ac_hdr" >&5
-#line 5742 "configure"
+#line 5748 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5747: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5753: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5779,15 +5785,15 @@
 do
-echo "configure:5783: checking for $ac_hdr" >&5
+echo "configure:5789: checking for $ac_hdr" >&5
-#line 5786 "configure"
+#line 5792 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5791: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5797: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5821,7 +5827,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5825: checking for location of Readline library" >&5
+echo "configure:5831: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5846,13 +5852,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5850: checking for readline in -lreadline" >&5
+echo "configure:5856: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 5856 "configure"
+#line 5862 "configure"
@@ -5863,7 +5869,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5898,13 +5904,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:5902: checking for add_history in -lhistory" >&5
+echo "configure:5908: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 5908 "configure"
+#line 5914 "configure"
@@ -5915,7 +5921,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:5919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5957,7 +5963,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:5961: checking whether to use GDAL" >&5
+echo "configure:5967: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -5975,7 +5981,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:5979: checking for $ac_word" >&5
+echo "configure:5985: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6030,14 +6036,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6034 "configure"
+#line 6040 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -6046,14 +6052,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6050 "configure"
+#line 6056 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6085,7 +6091,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6089: checking whether to use libLAS" >&5
+echo "configure:6095: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6102,7 +6108,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6106: checking for $ac_word" >&5
+echo "configure:6112: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6150,14 +6156,14 @@
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6154 "configure"
+#line 6160 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6165,14 +6171,14 @@
   rm -rf conftest*
-#line 6169 "configure"
+#line 6175 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6204,7 +6210,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6208: checking whether to use NetCDF" >&5
+echo "configure:6214: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6221,7 +6227,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:6225: checking for $ac_word" >&5
+echo "configure:6231: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6268,14 +6274,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6272 "configure"
+#line 6278 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6283,14 +6289,14 @@
   rm -rf conftest*
-#line 6287 "configure"
+#line 6293 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -6321,7 +6327,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6325: checking whether to use GEOS" >&5
+echo "configure:6331: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -6339,7 +6345,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6343: checking for $ac_word" >&5
+echo "configure:6349: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6387,15 +6393,15 @@
 do
-echo "configure:6391: checking for $ac_hdr" >&5
+echo "configure:6397: checking for $ac_hdr" >&5
-#line 6394 "configure"
+#line 6400 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6399: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6405: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6431,13 +6437,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6435: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6441: checking for initGEOS in -lgeos_c_i" >&5
 ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c_i  $LIBS"
-#line 6441 "configure"
+#line 6447 "configure"
@@ -6448,7 +6454,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6484,13 +6490,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6488: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6494: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6494 "configure"
+#line 6500 "configure"
@@ -6501,7 +6507,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6545,7 +6551,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6549: checking whether to use TIFF" >&5
+echo "configure:6555: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6565,7 +6571,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6569: checking for location of TIFF includes" >&5
+echo "configure:6575: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6591,15 +6597,15 @@
 do
-echo "configure:6595: checking for $ac_hdr" >&5
+echo "configure:6601: checking for $ac_hdr" >&5
-#line 6598 "configure"
+#line 6604 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6603: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6609: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6633,7 +6639,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6637: checking for location of TIFF library" >&5
+echo "configure:6643: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6664,13 +6670,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6668: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6674: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6674 "configure"
+#line 6680 "configure"
@@ -6681,7 +6687,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6700,13 +6706,13 @@
-echo "configure:6704: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6710: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6710 "configure"
+#line 6716 "configure"
@@ -6717,7 +6723,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6736,13 +6742,13 @@
-echo "configure:6740: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6746: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 6746 "configure"
+#line 6752 "configure"
@@ -6753,7 +6759,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6772,13 +6778,13 @@
-echo "configure:6776: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6782: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6782 "configure"
+#line 6788 "configure"
@@ -6789,7 +6795,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6808,13 +6814,13 @@
-echo "configure:6812: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6818: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 6818 "configure"
+#line 6824 "configure"
@@ -6825,7 +6831,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6844,13 +6850,13 @@
-echo "configure:6848: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6854: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6854 "configure"
+#line 6860 "configure"
@@ -6861,7 +6867,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6880,13 +6886,13 @@
-echo "configure:6884: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6890: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6890 "configure"
+#line 6896 "configure"
@@ -6897,7 +6903,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6916,13 +6922,13 @@
-echo "configure:6920: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6926: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6926 "configure"
+#line 6932 "configure"
@@ -6933,7 +6939,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7031,7 +7037,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7035: checking whether to use PNG" >&5
+echo "configure:7041: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7050,7 +7056,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7054: checking for location of PNG includes" >&5
+echo "configure:7060: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7076,15 +7082,15 @@
 do
-echo "configure:7080: checking for $ac_hdr" >&5
+echo "configure:7086: checking for $ac_hdr" >&5
-#line 7083 "configure"
+#line 7089 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7118,7 +7124,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7122: checking for location of PNG library" >&5
+echo "configure:7128: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7143,13 +7149,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7147: checking for png_read_image in -lpng" >&5
+echo "configure:7153: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7153 "configure"
+#line 7159 "configure"
@@ -7160,7 +7166,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7202,7 +7208,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7206: checking whether to use PostgreSQL" >&5
+echo "configure:7212: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7229,7 +7235,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7233: checking for location of PostgreSQL includes" >&5
+echo "configure:7239: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7255,15 +7261,15 @@
 do
-echo "configure:7259: checking for $ac_hdr" >&5
+echo "configure:7265: checking for $ac_hdr" >&5
-#line 7262 "configure"
+#line 7268 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7267: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7273: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7301,7 +7307,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7305: checking for location of PostgreSQL library" >&5
+echo "configure:7311: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7330,13 +7336,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7334: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7340: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7340 "configure"
+#line 7346 "configure"
@@ -7347,7 +7353,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7366,13 +7372,13 @@
-echo "configure:7370: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7376: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7376 "configure"
+#line 7382 "configure"
@@ -7383,7 +7389,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7402,13 +7408,13 @@
-echo "configure:7406: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7412: checking for PQsetdbLogin in -lpq" >&5
 ac_save_LIBS="$LIBS"
 LIBS="-lpq -lcrypt $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7412 "configure"
+#line 7418 "configure"
 #include "confdefs.h"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7419,7 +7425,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7438,13 +7444,13 @@
-echo "configure:7442: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7448: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7448 "configure"
+#line 7454 "configure"
@@ -7455,7 +7461,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7512,13 +7518,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7516: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7522: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7522 "configure"
+#line 7528 "configure"
@@ -7529,7 +7535,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7551,13 +7557,13 @@
-echo "configure:7555: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7561: checking for PQcmdTuples in -lpq" >&5
-#line 7561 "configure"
+#line 7567 "configure"
@@ -7568,7 +7574,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7611,7 +7617,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7615: checking whether to use MySQL" >&5
+echo "configure:7621: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7631,7 +7637,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7635: checking for location of MySQL includes" >&5
+echo "configure:7641: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7657,15 +7663,15 @@
 do
-echo "configure:7661: checking for $ac_hdr" >&5
+echo "configure:7667: checking for $ac_hdr" >&5
-#line 7664 "configure"
+#line 7670 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7675: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7702,7 +7708,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7706: checking for location of MySQL library" >&5
+echo "configure:7712: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7733,13 +7739,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7737: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7743: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7743 "configure"
+#line 7749 "configure"
@@ -7750,7 +7756,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7769,13 +7775,13 @@
-echo "configure:7773: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7779: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7779 "configure"
+#line 7785 "configure"
@@ -7786,7 +7792,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7805,13 +7811,13 @@
-echo "configure:7809: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7815: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7815 "configure"
+#line 7821 "configure"
@@ -7822,7 +7828,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7841,13 +7847,13 @@
-echo "configure:7845: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7851: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7851 "configure"
+#line 7857 "configure"
@@ -7858,7 +7864,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7877,13 +7883,13 @@
-echo "configure:7881: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7887: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7887 "configure"
+#line 7893 "configure"
@@ -7894,7 +7900,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7913,13 +7919,13 @@
-echo "configure:7917: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7923: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7923 "configure"
+#line 7929 "configure"
@@ -7930,7 +7936,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7949,13 +7955,13 @@
-echo "configure:7953: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7959: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 7959 "configure"
+#line 7965 "configure"
@@ -7966,7 +7972,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7985,13 +7991,13 @@
-echo "configure:7989: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7995: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 7995 "configure"
+#line 8001 "configure"
@@ -8002,7 +8008,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8092,7 +8098,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8096: checking for $ac_word" >&5
+echo "configure:8102: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8141,10 +8147,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8145: checking for mysql_server_init" >&5
+echo "configure:8151: checking for mysql_server_init" >&5
-#line 8148 "configure"
+#line 8154 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -8170,7 +8176,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8222,7 +8228,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8226: checking whether to use SQLite" >&5
+echo "configure:8232: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8242,7 +8248,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8246: checking for location of SQLite includes" >&5
+echo "configure:8252: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8268,15 +8274,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8272: checking for $ac_hdr" >&5
+echo "configure:8278: checking for $ac_hdr" >&5
-#line 8275 "configure"
+#line 8281 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8280: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8286: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8319,7 +8325,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8323: checking for location of SQLite library" >&5
+echo "configure:8329: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8348,13 +8354,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8352: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8358: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8358 "configure"
+#line 8364 "configure"
@@ -8365,7 +8371,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8384,13 +8390,13 @@
-echo "configure:8388: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8394: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8394 "configure"
+#line 8400 "configure"
@@ -8401,7 +8407,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8420,13 +8426,13 @@
-echo "configure:8424: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8430: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8430 "configure"
+#line 8436 "configure"
@@ -8437,7 +8443,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8456,13 +8462,13 @@
-echo "configure:8460: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8466: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8466 "configure"
+#line 8472 "configure"
@@ -8473,7 +8479,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8542,7 +8548,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8546: checking whether to use FFMPEG" >&5
+echo "configure:8552: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -8562,7 +8568,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8566: checking for location of FFMPEG includes" >&5
+echo "configure:8572: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8588,15 +8594,15 @@
 do
-echo "configure:8592: checking for $ac_hdr" >&5
+echo "configure:8598: checking for $ac_hdr" >&5
-#line 8595 "configure"
+#line 8601 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8600: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8606: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8632,15 +8638,15 @@
 do
-echo "configure:8636: checking for $ac_hdr" >&5
+echo "configure:8642: checking for $ac_hdr" >&5
-#line 8639 "configure"
+#line 8645 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8644: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8650: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8676,15 +8682,15 @@
 do
-echo "configure:8680: checking for $ac_hdr" >&5
+echo "configure:8686: checking for $ac_hdr" >&5
-#line 8683 "configure"
+#line 8689 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8727,7 +8733,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8731: checking for location of FFMPEG library" >&5
+echo "configure:8737: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8754,13 +8760,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8758: checking for av_free in -lavutil" >&5
+echo "configure:8764: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 8764 "configure"
+#line 8770 "configure"
@@ -8771,7 +8777,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8790,13 +8796,13 @@
-echo "configure:8794: checking for av_free in -lavutil" >&5
+echo "configure:8800: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 8800 "configure"
+#line 8806 "configure"
@@ -8807,7 +8813,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8852,13 +8858,13 @@
 echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8856: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8862: checking for avcodec_register in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 8862 "configure"
+#line 8868 "configure"
@@ -8869,7 +8875,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:8873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8888,13 +8894,13 @@
-echo "configure:8892: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8898: checking for avcodec_register in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8898 "configure"
+#line 8904 "configure"
@@ -8905,7 +8911,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:8909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8950,13 +8956,13 @@
 echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:8954: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8960: checking for avformat_alloc_context in -lavformat" >&5
 ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 8960 "configure"
+#line 8966 "configure"
@@ -8967,7 +8973,7 @@
 avformat_alloc_context()
 ; return 0; }
 EOF
-if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8986,13 +8992,13 @@
-echo "configure:8990: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8996: checking for avformat_alloc_context in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 8996 "configure"
+#line 9002 "configure"
@@ -9003,7 +9009,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9062,7 +9068,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9066: checking whether to use OpenGL" >&5
+echo "configure:9072: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9096,7 +9102,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9100: checking for location of OpenGL includes" >&5
+echo "configure:9106: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9122,15 +9128,15 @@
 do
-echo "configure:9126: checking for $ac_hdr" >&5
+echo "configure:9132: checking for $ac_hdr" >&5
-#line 9129 "configure"
+#line 9135 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9134: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9140: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9164,7 +9170,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9168: checking for location of OpenGL library" >&5
+echo "configure:9174: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9193,13 +9199,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9197: checking for glBegin in -lGL" >&5
+echo "configure:9203: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9203 "configure"
+#line 9209 "configure"
@@ -9210,7 +9216,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9229,13 +9235,13 @@
-echo "configure:9233: checking for glBegin in -lGL" >&5
+echo "configure:9239: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9239 "configure"
+#line 9245 "configure"
@@ -9246,7 +9252,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9265,13 +9271,13 @@
-echo "configure:9269: checking for glBegin in -lGL" >&5
+echo "configure:9275: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9275 "configure"
+#line 9281 "configure"
@@ -9282,7 +9288,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9301,13 +9307,13 @@
-echo "configure:9305: checking for glBegin in -lGL" >&5
+echo "configure:9311: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9311 "configure"
+#line 9317 "configure"
@@ -9318,7 +9324,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9380,13 +9386,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9384: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9390: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9390 "configure"
+#line 9396 "configure"
@@ -9397,7 +9403,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9416,13 +9422,13 @@
-echo "configure:9420: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9426: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9426 "configure"
+#line 9432 "configure"
@@ -9433,7 +9439,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9480,10 +9486,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9484: checking for glXCreatePbuffer" >&5
+echo "configure:9490: checking for glXCreatePbuffer" >&5
-#line 9487 "configure"
+#line 9493 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9506,7 +9512,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9543,10 +9549,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9547: checking for glXCreateGLXPixmap" >&5
+echo "configure:9553: checking for glXCreateGLXPixmap" >&5
-#line 9550 "configure"
+#line 9556 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9569,7 +9575,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9612,7 +9618,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9616: checking for location of OpenGL framework" >&5
+echo "configure:9622: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9636,15 +9642,15 @@
 do
-echo "configure:9640: checking for $ac_hdr" >&5
+echo "configure:9646: checking for $ac_hdr" >&5
-#line 9643 "configure"
+#line 9649 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9648: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9654: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9680,10 +9686,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9684: checking for glBegin" >&5
+echo "configure:9690: checking for glBegin" >&5
-#line 9687 "configure"
+#line 9693 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9706,7 +9712,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9743,10 +9749,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9747: checking for gluBeginCurve" >&5
+echo "configure:9753: checking for gluBeginCurve" >&5
-#line 9750 "configure"
+#line 9756 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9769,7 +9775,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9817,7 +9823,7 @@
-echo "configure:9821: checking for location of OpenGL includes" >&5
+echo "configure:9827: checking for location of OpenGL includes" >&5
@@ -9843,15 +9849,15 @@
 do
-echo "configure:9847: checking for $ac_hdr" >&5
+echo "configure:9853: checking for $ac_hdr" >&5
-#line 9850 "configure"
+#line 9856 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9861: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9885,7 +9891,7 @@
-echo "configure:9889: checking for location of OpenGL library" >&5
+echo "configure:9895: checking for location of OpenGL library" >&5
@@ -9910,18 +9916,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9914: checking for OpenGL library" >&5
+echo "configure:9920: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 9918 "configure"
+#line 9924 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:9925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -9945,18 +9951,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9949: checking for GLU library" >&5
+echo "configure:9955: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 9953 "configure"
+#line 9959 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:9960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10005,7 +10011,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10009: checking whether to use ODBC" >&5
+echo "configure:10015: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -10024,7 +10030,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10028: checking for location of ODBC includes" >&5
+echo "configure:10034: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10050,15 +10056,15 @@
 do
-echo "configure:10054: checking for $ac_hdr" >&5
+echo "configure:10060: checking for $ac_hdr" >&5
-#line 10057 "configure"
+#line 10063 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10068: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10092,7 +10098,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10096: checking for location of ODBC library" >&5
+echo "configure:10102: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10117,13 +10123,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10121: checking for SQLConnect in -lodbc" >&5
+echo "configure:10127: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 10127 "configure"
+#line 10133 "configure"
@@ -10134,7 +10140,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10159,13 +10165,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10163: checking for SQLConnect in -liodbc" >&5
+echo "configure:10169: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 10169 "configure"
+#line 10175 "configure"
@@ -10176,7 +10182,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10201,11 +10207,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10205: checking for ODBC library" >&5
+echo "configure:10211: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 10209 "configure"
+#line 10215 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -10213,7 +10219,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:10217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10262,7 +10268,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10266: checking whether to use FFTW" >&5
+echo "configure:10272: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -10281,7 +10287,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10285: checking for location of FFTW includes" >&5
+echo "configure:10291: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10307,15 +10313,15 @@
 do
-echo "configure:10311: checking for $ac_hdr" >&5
+echo "configure:10317: checking for $ac_hdr" >&5
-#line 10314 "configure"
+#line 10320 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10319: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10343,15 +10349,15 @@
 do
-echo "configure:10347: checking for $ac_hdr" >&5
+echo "configure:10353: checking for $ac_hdr" >&5
-#line 10350 "configure"
+#line 10356 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10361: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10379,15 +10385,15 @@
 do
-echo "configure:10383: checking for $ac_hdr" >&5
+echo "configure:10389: checking for $ac_hdr" >&5
-#line 10386 "configure"
+#line 10392 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10397: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10433,7 +10439,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10437: checking for location of FFTW library" >&5
+echo "configure:10443: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10458,13 +10464,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10462: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10468: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10468 "configure"
+#line 10474 "configure"
@@ -10475,7 +10481,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:10479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10500,13 +10506,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10504: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10510: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10510 "configure"
+#line 10516 "configure"
@@ -10517,7 +10523,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10542,13 +10548,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10546: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10552: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10552 "configure"
+#line 10558 "configure"
@@ -10559,7 +10565,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10616,7 +10622,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10620: checking whether to use BLAS" >&5
+echo "configure:10626: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -10637,7 +10643,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10641: checking for location of BLAS includes" >&5
+echo "configure:10647: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10657,7 +10663,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10661: checking for location of BLAS library" >&5
+echo "configure:10667: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10683,15 +10689,15 @@
 do
-echo "configure:10687: checking for $ac_hdr" >&5
+echo "configure:10693: checking for $ac_hdr" >&5
-#line 10690 "configure"
+#line 10696 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10695: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10701: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10726,13 +10732,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10730: checking for dnrm2_ in -lblas" >&5
+echo "configure:10736: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 10736 "configure"
+#line 10742 "configure"
@@ -10743,7 +10749,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10762,13 +10768,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10766: checking for dnrm2_ in -lblas" >&5
+echo "configure:10772: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10772 "configure"
+#line 10778 "configure"
@@ -10779,7 +10785,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10823,13 +10829,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10827: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10833: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 10833 "configure"
+#line 10839 "configure"
@@ -10840,7 +10846,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:10844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10855,13 +10861,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10859: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10865: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 10865 "configure"
+#line 10871 "configure"
@@ -10872,7 +10878,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10887,13 +10893,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10891: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10897: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10897 "configure"
+#line 10903 "configure"
@@ -10904,7 +10910,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:10908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10950,16 +10956,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10954: checking for sgemm in $vlib_flags" >&5
+echo "configure:10960: checking for sgemm in $vlib_flags" >&5
-#line 10956 "configure"
+#line 10962 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:10963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -10977,13 +10983,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10981: checking for sgemm_ in -lblas" >&5
+echo "configure:10987: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 10987 "configure"
+#line 10993 "configure"
@@ -10994,7 +11000,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11009,13 +11015,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11013: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11019: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 11019 "configure"
+#line 11025 "configure"
@@ -11026,7 +11032,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11041,13 +11047,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11045: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11051: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 11051 "configure"
+#line 11057 "configure"
@@ -11058,7 +11064,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11092,13 +11098,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11096: checking for acosp in -lsunmath" >&5
+echo "configure:11102: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 11102 "configure"
+#line 11108 "configure"
@@ -11109,7 +11115,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:11113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11124,13 +11130,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11128: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11134: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 11134 "configure"
+#line 11140 "configure"
@@ -11141,7 +11147,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11171,13 +11177,13 @@
 # Generic BLAS library
-echo "configure:11175: checking for sgemm_ in -lblas" >&5
+echo "configure:11181: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 11181 "configure"
+#line 11187 "configure"
@@ -11188,7 +11194,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11227,7 +11233,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11231: checking whether to use LAPACK" >&5
+echo "configure:11237: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -11252,7 +11258,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11256: checking for location of LAPACK includes" >&5
+echo "configure:11262: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11272,7 +11278,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11276: checking for location of LAPACK library" >&5
+echo "configure:11282: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11298,15 +11304,15 @@
 do
-echo "configure:11302: checking for $ac_hdr" >&5
+echo "configure:11308: checking for $ac_hdr" >&5
-#line 11305 "configure"
+#line 11311 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11310: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11338,10 +11344,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11342: checking for dsegv_" >&5
+echo "configure:11348: checking for dsegv_" >&5
-#line 11345 "configure"
+#line 11351 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -11364,7 +11370,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -11391,13 +11397,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11395: checking for desgv_ in -llapack" >&5
+echo "configure:11401: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 11401 "configure"
+#line 11407 "configure"
@@ -11408,7 +11414,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11440,13 +11446,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11444: checking for dgesv_ in -llapack" >&5
+echo "configure:11450: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 11450 "configure"
+#line 11456 "configure"
@@ -11457,7 +11463,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11476,13 +11482,13 @@
-echo "configure:11480: checking for dgesv_ in -llapack" >&5
+echo "configure:11486: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11486 "configure"
+#line 11492 "configure"
@@ -11493,7 +11499,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11549,7 +11555,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11553: checking whether to use Cairo" >&5
+echo "configure:11559: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11581,7 +11587,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11585: checking for location of cairo includes" >&5
+echo "configure:11591: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11607,15 +11613,15 @@
 do
-echo "configure:11611: checking for $ac_hdr" >&5
+echo "configure:11617: checking for $ac_hdr" >&5
-#line 11614 "configure"
+#line 11620 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11625: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11651,7 +11657,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11655: checking for location of cairo library" >&5
+echo "configure:11661: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11671,7 +11677,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11675: checking for cairo linking flags" >&5
+echo "configure:11681: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11687,10 +11693,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11691: checking for cairo_create" >&5
+echo "configure:11697: checking for cairo_create" >&5
-#line 11694 "configure"
+#line 11700 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -11713,7 +11719,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -11747,10 +11753,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11751: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11757: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11754 "configure"
+#line 11760 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -11773,7 +11779,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -11806,10 +11812,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11810: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11816: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11813 "configure"
+#line 11819 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -11832,7 +11838,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -11874,7 +11880,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11878: checking whether to use FreeType" >&5
+echo "configure:11884: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -11893,7 +11899,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11897: checking for location of FreeType includes" >&5
+echo "configure:11903: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11919,15 +11925,15 @@
 do
-echo "configure:11923: checking for $ac_hdr" >&5
+echo "configure:11929: checking for $ac_hdr" >&5
-#line 11926 "configure"
+#line 11932 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11931: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11961,7 +11967,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11965: checking for location of FreeType library" >&5
+echo "configure:11971: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11986,13 +11992,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11990: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11996: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 11996 "configure"
+#line 12002 "configure"
@@ -12003,7 +12009,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:12007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12044,7 +12050,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12048: checking whether to use NLS" >&5
+echo "configure:12054: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -12064,10 +12070,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12068: checking for gettext" >&5
+echo "configure:12074: checking for gettext" >&5
-#line 12071 "configure"
+#line 12077 "configure"
     which can conflict with char gettext(); below.  */
@@ -12090,7 +12096,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -12108,13 +12114,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12112: checking for gettext in -lintl" >&5
+echo "configure:12118: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 12118 "configure"
+#line 12124 "configure"
@@ -12125,7 +12131,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:12129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12135: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12160,7 +12166,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12164: checking whether to use C++" >&5
+echo "configure:12170: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -12176,7 +12182,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:12180: checking for $ac_word" >&5
+echo "configure:12186: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12205,7 +12211,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12209: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12215: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12216,12 +12222,12 @@
 cat > conftest.$ac_ext << EOF
-#line 12220 "configure"
+#line 12226 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:12225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -12247,19 +12253,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12251: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12257: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12256: checking whether we are using GNU C++" >&5
+echo "configure:12262: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12263: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12269: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -12277,7 +12283,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12281: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12287: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12315,7 +12321,7 @@
    'void exit (int);'
 do
   cat > conftest.$ac_ext <<EOF
-#line 12319 "configure"
+#line 12325 "configure"
 #include "confdefs.h"
 #include <stdlib.h>
 $ac_declaration
@@ -12323,7 +12329,7 @@
 exit (42);
 ; return 0; }
 EOF
-if { (eval echo configure:12327: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12333: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -12333,14 +12339,14 @@
 fi
 rm -f conftest*
-#line 12337 "configure"
+#line 12343 "configure"
 $ac_declaration
 int main() {
 exit (42);
 ; return 0; }
 EOF
-if { (eval echo configure:12344: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12350: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   break
 else
@@ -12369,7 +12375,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12373: checking whether to use openDWG" >&5
+echo "configure:12379: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12389,7 +12395,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12393: checking for location of openDGW includes" >&5
+echo "configure:12399: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12415,15 +12421,15 @@
 do
-echo "configure:12419: checking for $ac_hdr" >&5
+echo "configure:12425: checking for $ac_hdr" >&5
-#line 12422 "configure"
+#line 12428 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12433: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12457,7 +12463,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12461: checking for location of openDWG library" >&5
+echo "configure:12467: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12498,7 +12504,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12502: checking whether to use POSIX threads" >&5
+echo "configure:12508: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12518,7 +12524,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12522: checking for location of POSIX threads includes" >&5
+echo "configure:12528: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12544,15 +12550,15 @@
 do
-echo "configure:12548: checking for $ac_hdr" >&5
+echo "configure:12554: checking for $ac_hdr" >&5
-#line 12551 "configure"
+#line 12557 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12562: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12586,7 +12592,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12590: checking for location of POSIX threads library" >&5
+echo "configure:12596: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12611,10 +12617,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12615: checking for pthread_create" >&5
+echo "configure:12621: checking for pthread_create" >&5
-#line 12618 "configure"
+#line 12624 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12637,7 +12643,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12664,13 +12670,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12668: checking for pthread_create in -lpthread" >&5
+echo "configure:12674: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpthread  $LIBS"
-#line 12674 "configure"
+#line 12680 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12681,7 +12687,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12731,7 +12737,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12735: checking whether to use OpenMP" >&5
+echo "configure:12741: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12752,7 +12758,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12756: checking for location of OpenMP includes" >&5
+echo "configure:12762: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12778,15 +12784,15 @@
 do
-echo "configure:12782: checking for $ac_hdr" >&5
+echo "configure:12788: checking for $ac_hdr" >&5
-#line 12785 "configure"
+#line 12791 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12790: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12796: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12824,7 +12830,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12828: checking for location of OpenMP library" >&5
+echo "configure:12834: checking for location of OpenMP library" >&5
 case "$with_gomp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -12849,10 +12855,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12853: checking for GOMP_parallel_start" >&5
+echo "configure:12859: checking for GOMP_parallel_start" >&5
-#line 12856 "configure"
+#line 12862 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12875,7 +12881,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12902,13 +12908,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12906: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12912: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12912 "configure"
+#line 12918 "configure"
@@ -12919,7 +12925,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12998,7 +13004,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13002: checking for special C compiler options needed for large files" >&5
+echo "configure:13008: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13006,7 +13012,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13010 "configure"
+#line 13016 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13022,7 +13028,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13026: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13032: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13031,7 +13037,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13035 "configure"
+#line 13041 "configure"
@@ -13047,7 +13053,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13051: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13057: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13067,11 +13073,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13071: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13077: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13075 "configure"
+#line 13081 "configure"
@@ -13087,14 +13093,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13091: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13097: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 13098 "configure"
+#line 13104 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13112,7 +13118,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13116: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13122: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13131,11 +13137,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13135: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13141: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13139 "configure"
+#line 13145 "configure"
@@ -13151,14 +13157,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13155: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13161: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13162 "configure"
+#line 13168 "configure"
 #define _LARGE_FILES 1
@@ -13176,7 +13182,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13180: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13186: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13195,25 +13201,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13199: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13205: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13203 "configure"
+#line 13209 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13210: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13216: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13217 "configure"
+#line 13223 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13222,7 +13228,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13226: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13232: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13243,25 +13249,25 @@
    fi
-echo "configure:13247: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13253: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13251 "configure"
+#line 13257 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13258: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13264: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13265 "configure"
+#line 13271 "configure"
 #include <stdio.h>
@@ -13270,7 +13276,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13274: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13280: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13293,18 +13299,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13297: checking for fseeko" >&5
+echo "configure:13303: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13301 "configure"
+#line 13307 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13321,10 +13327,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13325: checking if system supports Large Files at all" >&5
+echo "configure:13331: checking if system supports Large Files at all" >&5
-#line 13328 "configure"
+#line 13334 "configure"
 #include <stdio.h>
@@ -13356,7 +13362,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13360: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13366: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13385,7 +13391,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13389: checking whether to use wxWidgets" >&5
+echo "configure:13395: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -13406,7 +13412,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13410: checking for $ac_word" >&5
+echo "configure:13416: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -13454,7 +13460,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13458: checking wxWidgets version" >&5
+echo "configure:13464: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -13477,15 +13483,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13481: checking for $ac_hdr" >&5
+echo "configure:13487: checking for $ac_hdr" >&5
-#line 13484 "configure"
+#line 13490 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13495: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
