[GRASS-SVN] r54299 - in grass/trunk/temporal: t.list t.rast.colors t.register t.remove t.sample
Sat Dec 15 11:15:05 PST 2012
Author: annakrat
Date: 2012-12-15 11:15:05 -0800 (Sat, 15 Dec 2012)
New Revision: 54299
   grass/trunk/temporal/t.list/t.list.py
   grass/trunk/temporal/t.rast.colors/t.rast.colors.py
   grass/trunk/temporal/t.register/t.register.py
   grass/trunk/temporal/t.remove/t.remove.py
   grass/trunk/temporal/t.sample/t.sample.py
temporal: add more guisections
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py	2012-12-15 16:59:46 UTC (rev 54298)
+++ grass/trunk/temporal/t.list/t.list.py	2012-12-15 19:15:05 UTC (rev 54299)
@@ -25,15 +25,24 @@
 #% key: type
 #% type: string
 #% description: Type of the space time dataset or map, default is strds
+#% guisection: Selection
 #% required: no
 #% options: strds, str3ds, stvds, rast, rast3d, vect
 #% answer: strds
 #%end
+#%option G_OPT_T_TYPE
+#% multiple: yes
+#% answer: absolute,relative
+#%end
 #%option
 #% key: order
 #% type: string
-#% description: Sort the space time dataset by category. Columns number_of_maps and granularity only available fpr space time datasets
+#% description: Columns number_of_maps and granularity only available for space time datasets
+#% label: Sort the space time dataset by category
+#% guisection: Formatting
 #% required: no
 #% multiple: yes
 #% options: id, name, creator, mapset, number_of_maps, creation_time, start_time, end_time, interval, north, south, west, east, granularity
@@ -43,7 +52,9 @@
 #%option
 #% key: columns
 #% type: string
-#% description: Columns to be printed to stdout. Columns number_of_maps and granularity only available for space time datasets
+#% label: Columns to be printed to stdout
 #% required: no
 #% multiple: yes
 #% options: id, name, creator, mapset, number_of_maps, creation_time, start_time, end_time, north, south, west, east, granularity, all
@@ -51,23 +62,21 @@
 #%end
 #%option G_OPT_T_WHERE
 #%end
-#%option G_OPT_T_TYPE
-#% multiple: yes
-#% answer: absolute,relative
-#%end
 #%option
 #% key: fs
 #% type: string
 #% description: The field separator character between the columns, default is tabular "\t"
 #% required: no
 #%end
 #%flag
 #% key: c
 #% description: Print the column names as first row
 #%end
 import grass.script as grass
Modified: grass/trunk/temporal/t.rast.colors/t.rast.colors.py
--- grass/trunk/temporal/t.rast.colors/t.rast.colors.py	2012-12-15 16:59:46 UTC (rev 54298)
+++ grass/trunk/temporal/t.rast.colors/t.rast.colors.py	2012-12-15 19:15:05 UTC (rev 54299)
@@ -29,29 +29,34 @@
 #% description: Name of color table (see r.color help)
 #% required: no
 #% multiple: no
+#% guisection: Define
 #%end
 #%option G_OPT_R_INPUT
 #% key: raster
 #% description: Raster map from which to copy color table
 #% required: no
 #%end
 #%option G_OPT_R3_INPUT
 #% key: volume
 #% description: 3D raster map from which to copy color table
 #% required: no
 #%end
 #%option G_OPT_F_INPUT
 #% key: rules
 #% description: Path to rules file
 #% required: no
 #%end
 #%flag
 #% key: r
 #% description: Remove existing color tables
+#% guisection: Remove
 #%end
 #%flag
@@ -62,26 +67,31 @@
 #%flag
 #% key: l
 #% description: List available rules then exit
+#% guisection: Print
 #%end
 #%flag
 #% key: n
 #% description: Invert colors
 #%end
 #%flag
 #% key: g
 #% description: Logarithmic scaling
 #%end
 #%flag
 #% key: a
 #% description: Logarithmic-absolute scaling
 #%end
 #%flag
 #% key: e
 #% description: Histogram equalization
 #%end
Modified: grass/trunk/temporal/t.register/t.register.py
--- grass/trunk/temporal/t.register/t.register.py	2012-12-15 16:59:46 UTC (rev 54298)
+++ grass/trunk/temporal/t.register/t.register.py	2012-12-15 19:15:05 UTC (rev 54299)
@@ -23,20 +23,24 @@
 #%option G_OPT_STDS_INPUT
 #% required: no
+#% guisection: Input
 #%end
 #%option G_OPT_MAP_INPUTS
 #% required: no
 #%end
 #%option G_OPT_MAP_TYPE
 #% guidependency: input,maps
 #%end
 #% key: file
 #% required: no
 #% description: Input file with map names, one per line. Additionally the start time and the end time can be specified per line
 #%end
 #%option
@@ -45,6 +49,7 @@
 #% description: Valid start date and time of the first map. Format absolute time: "yyyy-mm-dd HH:MM:SS +HHMM", relative time is of type integer).
 #% required: no
 #% multiple: no
+#% guisection: Time & Date
 #%end
 #%option
@@ -53,6 +58,7 @@
 #% description: Valid end date and time of all map. Format absolute time: "yyyy-mm-dd HH:MM:SS +HHMM", relative time is of type integer).
 #% required: no
 #% multiple: no
 #%end
 #%option
@@ -62,6 +68,7 @@
 #% required: no
 #% multiple: no
 #% options: years,months,days,hours,minutes,seconds
 #%end
 #%option
@@ -70,6 +77,7 @@
 #% description: Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer: 5)
 #% required: no
 #% multiple: no
 #%end
 #%option
@@ -78,11 +86,13 @@
 #% description: Field separator character of the input file
 #% required: no
 #% answer: |
 #%end
 #%flag
 #% key: i
 #% description: Create an interval (start and end time) in case an increment is provided
 #%end
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py	2012-12-15 16:59:46 UTC (rev 54298)
+++ grass/trunk/temporal/t.remove/t.remove.py	2012-12-15 19:15:05 UTC (rev 54299)
@@ -22,6 +22,7 @@
 #%end
 #%option G_OPT_STDS_INPUTS
 #% required: no
 #%end
@@ -30,6 +31,7 @@
 #% type: string
 #% description: Type of the space time dataset, default is strds
 #% guidependency: inputs
 #% required: no
 #% answer: strds
@@ -38,6 +40,7 @@
 #% key: file
 #% description: Input file with dataset names, one per line
 #% required: no
 #%end
Modified: grass/trunk/temporal/t.sample/t.sample.py
--- grass/trunk/temporal/t.sample/t.sample.py	2012-12-15 16:59:46 UTC (rev 54298)
+++ grass/trunk/temporal/t.sample/t.sample.py	2012-12-15 19:15:05 UTC (rev 54299)
@@ -30,10 +30,12 @@
 #%option G_OPT_STDS_TYPE
 #% key: intype
+#% guisection: Required
 #%end
 #% key: samtype
 #% description: Type of the sample space time dataset
 #%end
