[GRASS-SVN] r54349 - grass/trunk/imagery/i.maxlik
Wed Dec 19 14:16:15 PST 2012
Author: mmetz
Date: 2012-12-19 14:16:15 -0800 (Wed, 19 Dec 2012)
New Revision: 54349
   grass/trunk/imagery/i.maxlik/i.maxlik.html
i.maxlik: update manual
Modified: grass/trunk/imagery/i.maxlik/i.maxlik.html
--- grass/trunk/imagery/i.maxlik/i.maxlik.html	2012-12-19 01:12:30 UTC (rev 54348)
+++ grass/trunk/imagery/i.maxlik/i.maxlik.html	2012-12-19 22:16:15 UTC (rev 54349)
@@ -107,11 +107,13 @@
 on each discriminant result at various threshold levels of
 confidence to determine at what confidence level each cell
 classified (categorized). It is the reject threshold map
-layer, and contains one calculated confidence level for
-each classified cell in the classified image. One of the
-possible uses for this map layer is as a mask, to identify
-cells in the classified image that have the lowest
-probability of being assigned to the correct class.
+layer, and contains the index to one calculated confidence level for
+each classified cell in the classified image. 16 confidence intervals
+are predefined, and the reject map is to be interpreted as 1 = keep and
+16 = reject. One of the possible uses for this map layer is as a mask,
+to identify cells in the classified image that have a low
+probability (high reject index) of being assigned to the correct
+class.
 </dl>
