[GRASS-SVN] r50656 - grass-addons/tools
Sun Feb 5 02:43:15 EST 2012
Author: hamish
Date: 2012-02-04 23:43:14 -0800 (Sat, 04 Feb 2012)
New Revision: 50656
Added:
   grass-addons/tools/module_key_list.sh
initial version of a script to dump module options and flag names to a text file for comparison with another version of GRASS (test_suite)
Added: grass-addons/tools/module_key_list.sh
--- grass-addons/tools/module_key_list.sh	                        (rev 0)
+++ grass-addons/tools/module_key_list.sh	2012-02-05 07:43:14 UTC (rev 50656)
@@ -0,0 +1,131 @@
+#!/bin/sh
+# MODULE:       module_key_list.sh
+# AUTHOR(S):    Hamish Bowman, Dunedin, New Zealand
+# PURPOSE:      make a list of all the module options for later comparison
+# COPYRIGHT:    (C) 2012 GRASS Development Team/hb
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%Module
+#%  description: Generates a list of all modules' option and flag names.
+#%  keywords: infrastructure
+#%End
+if [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." 1>&2
+    exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    exec g.parser "$0" "$@"
+fi
+TEMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TEMPFILE" ] ; then
+    g.message -e "Unable to create temporary files"
+    exit 1
+fi
+#### check if we have awk
+if [ ! -x "`which xml2`" ] ; then
+    g.message -e "xml2 is required, please install it first"
+    exit 1
+fi
+OUTFILE="module_key_list_$GRASS_VERSION.txt"
+# check if we will overwrite data
+if [ -e "$OUTFILE" ] ; then
+   if [ -z "$GRASS_OVERWRITE" ] || [ "$GRASS_OVERWRITE" -ne 1 ] ; then
+      g.message -e "Output file <$OUTFILE> already exists."
+      exit 1
+   fi
+fi
+BASE_DIR="`pwd`"
+cd "$GISBASE"
+for MOD in bin/* scripts/* ; do
+    MODULE=`basename "$MOD"`
+    if [ "$MODULE" = "g.parser" ] || \
+       [ "$MODULE" = "r.mapcalc" ] || \
+       [ "$MODULE" = "r3.mapcalc" ] ; then
+	continue
+    fi
+    g.message -v "[$MODULE]"
+    "$MODULE"  --interface-description >> "$TEMPFILE"
+done
+# -i is a GNU extension, won't work on a Mac?
+sed -i -e 's/^<?xml .*//' -e 's/^<!DOCTYPE .*//' "$TEMPFILE"
+cat << EOF > "$TEMPFILE.header"
+<?xml version="1.0" encoding="ANSI_X3.4-1968"?>
+<!DOCTYPE task SYSTEM "grass-interface.dtd">
+<modules>
+EOF
+cat << EOF > "$TEMPFILE.footer"
+</modules>
+EOF
+cat "$TEMPFILE.header" "$TEMPFILE" "$TEMPFILE.footer" > "$TEMPFILE.xml"
+cd "$BASE_DIR"
+echo "# `g.version`module key list -- `date`" > "$OUTFILE"
+xml2 < "$TEMPFILE.xml" | grep '/@name=' | \
+   sed -e 's+^/modules/task/++' -e 's+ at name=+name=+' \
+       -e 's+^\(name=\)+\n\1+' -e 's/name=//'| \
+   grep -v '^flag/verbose$\|^flag/quiet$' \
+ >> "$OUTFILE"
+g.message "List written to <$OUTFILE>."
+g.message " Next run: diff -u -c 7 module_key_list_\$OLD.txt module_key_list_\$NEW.txt"
+## todo: how to sort per-module params and flags so a re-arrangement of
+##       order doesn't indicate an interface change?
+#cleanup
+rm -f "$TEMPFILE" "$TEMPFILE.xml" "$TEMPFILE.header" "$TEMPFILE.footer"
+exit 0
+### howto get this to work ????
+# see http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=506788
+BASE="modules/task"
+FIELDS="
+ at name
+parameter/@name
+flag/@name
+   grep -v '/flag/@name=verbose$\|/flag/@name=quiet' | \
+   2csv -d'|' $BASE $FIELDS | less
Property changes on: grass-addons/tools/module_key_list.sh
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
   + text/x-sh
Added: svn:eol-style
   + native
