[GRASS-SVN] r50661 - grass/trunk
Sun Feb 5 06:38:00 EST 2012
Author: hamish
Date: 2012-02-05 03:38:00 -0800 (Sun, 05 Feb 2012)
New Revision: 50661
   grass/trunk/configure
   grass/trunk/configure.in
handle case when source tree is not a svn branch (#587)
Modified: grass/trunk/configure
--- grass/trunk/configure	2012-02-05 10:25:11 UTC (rev 50660)
+++ grass/trunk/configure	2012-02-05 11:38:00 UTC (rev 50661)
@@ -1323,6 +1323,9 @@
 if test "$SVN_VERSION" != "no" ; then
    GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
+   if test "$GRASS_VERSION_SVN" = "exported" ; then
+      GRASS_VERSION_SVN=
+   fi
 fi
@@ -1347,7 +1350,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1351: checking for MacOSX App" >&5
+echo "configure:1354: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1359,7 +1362,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1363: checking for MacOSX architectures" >&5
+echo "configure:1366: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1388,7 +1391,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1392: checking for MacOSX SDK" >&5
+echo "configure:1395: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1398,7 +1401,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1402: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1405: checking for $with_macosx_sdk/SDKSettings.plist" >&5
 if test "$cross_compiling" = yes; then
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1442,7 +1445,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1446: checking how to build libraries" >&5
+echo "configure:1449: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -2287,7 +2290,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2291: checking for additional include dirs" >&5
+echo "configure:2294: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2310,7 +2313,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2314: checking for additional library dirs" >&5
+echo "configure:2317: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2344,7 +2347,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2348: checking for a BSD compatible install" >&5
+echo "configure:2351: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -2397,7 +2400,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:2401: checking for $ac_word" >&5
+echo "configure:2404: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2428,13 +2431,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2432: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2435: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-l$ac_lib  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 2438 "configure"
+#line 2441 "configure"
 #include "confdefs.h"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -2445,7 +2448,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:2449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -2470,7 +2473,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:2474: checking for $ac_word" >&5
+echo "configure:2477: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -2510,7 +2513,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:2514: checking for $ac_word" >&5
+echo "configure:2517: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2541,7 +2544,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:2545: checking for $ac_word" >&5
+echo "configure:2548: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -2579,7 +2582,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:2583: checking for $ac_word" >&5
+echo "configure:2586: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2608,7 +2611,7 @@
-echo "configure:2612: checking for $ac_word" >&5
+echo "configure:2615: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2639,7 +2642,7 @@
-echo "configure:2643: checking for $ac_word" >&5
+echo "configure:2646: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2668,7 +2671,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:2672: checking for $ac_word" >&5
+echo "configure:2675: checking for $ac_word" >&5
 case "$PERL" in
@@ -2699,7 +2702,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2703: checking how to run the C preprocessor" >&5
+echo "configure:2706: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -2712,13 +2715,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 2716 "configure"
+#line 2719 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2725: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -2729,13 +2732,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 2733 "configure"
+#line 2736 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2739: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2742: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2746,13 +2749,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 2750 "configure"
+#line 2753 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2756: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2776,10 +2779,10 @@
 echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2780: checking for ANSI C header files" >&5
+echo "configure:2783: checking for ANSI C header files" >&5
-#line 2783 "configure"
+#line 2786 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -2787,7 +2790,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:2791: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2794: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2804,7 +2807,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2808 "configure"
+#line 2811 "configure"
 #include <string.h>
 EOF
@@ -2822,7 +2825,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2826 "configure"
+#line 2829 "configure"
 #include <stdlib.h>
 EOF
@@ -2843,7 +2846,7 @@
 else
-#line 2847 "configure"
+#line 2850 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2854,7 +2857,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:2858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -2881,15 +2884,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2885: checking for $ac_hdr" >&5
+echo "configure:2888: checking for $ac_hdr" >&5
-#line 2888 "configure"
+#line 2891 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2893: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2918,15 +2921,15 @@
 do
-echo "configure:2922: checking for $ac_hdr" >&5
+echo "configure:2925: checking for $ac_hdr" >&5
-#line 2925 "configure"
+#line 2928 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2933: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2955,15 +2958,15 @@
 do
-echo "configure:2959: checking for $ac_hdr" >&5
+echo "configure:2962: checking for $ac_hdr" >&5
-#line 2962 "configure"
+#line 2965 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2967: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2992,15 +2995,15 @@
 do
-echo "configure:2996: checking for $ac_hdr" >&5
+echo "configure:2999: checking for $ac_hdr" >&5
-#line 2999 "configure"
+#line 3002 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3004: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3029,15 +3032,15 @@
 do
-echo "configure:3033: checking for $ac_hdr" >&5
+echo "configure:3036: checking for $ac_hdr" >&5
-#line 3036 "configure"
+#line 3039 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3041: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3044: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3063,10 +3066,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3067: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3070: checking whether time.h and sys/time.h may both be included" >&5
-#line 3070 "configure"
+#line 3073 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -3075,7 +3078,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:3079: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3082: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -3095,10 +3098,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3099: checking for off_t" >&5
+echo "configure:3102: checking for off_t" >&5
-#line 3102 "configure"
+#line 3105 "configure"
 #if STDC_HEADERS
@@ -3125,10 +3128,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3129: checking for uid_t in sys/types.h" >&5
+echo "configure:3132: checking for uid_t in sys/types.h" >&5
-#line 3132 "configure"
+#line 3135 "configure"
 EOF
@@ -3156,10 +3159,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3160: checking return type of signal handlers" >&5
+echo "configure:3163: checking return type of signal handlers" >&5
-#line 3163 "configure"
+#line 3166 "configure"
 #include <signal.h>
@@ -3176,7 +3179,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:3180: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3183: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -3194,10 +3197,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3198: checking for Cygwin environment" >&5
+echo "configure:3201: checking for Cygwin environment" >&5
-#line 3201 "configure"
+#line 3204 "configure"
 int main() {
@@ -3208,7 +3211,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:3212: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3215: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -3226,10 +3229,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3230: checking for $ac_func" >&5
+echo "configure:3233: checking for $ac_func" >&5
-#line 3233 "configure"
+#line 3236 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -3252,7 +3255,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -3278,10 +3281,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:3282: checking for $ac_func" >&5
+echo "configure:3285: checking for $ac_func" >&5
-#line 3285 "configure"
+#line 3288 "configure"
@@ -3304,7 +3307,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3330,10 +3333,10 @@
 for ac_func in drand48
 do
-echo "configure:3334: checking for $ac_func" >&5
+echo "configure:3337: checking for $ac_func" >&5
-#line 3337 "configure"
+#line 3340 "configure"
@@ -3356,7 +3359,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3382,10 +3385,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:3386: checking for $ac_func" >&5
+echo "configure:3389: checking for $ac_func" >&5
-#line 3389 "configure"
+#line 3392 "configure"
@@ -3408,7 +3411,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3434,10 +3437,10 @@
 for ac_func in nanosleep
 do
-echo "configure:3438: checking for $ac_func" >&5
+echo "configure:3441: checking for $ac_func" >&5
-#line 3441 "configure"
+#line 3444 "configure"
@@ -3460,7 +3463,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3485,13 +3488,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3489: checking whether setpgrp takes no argument" >&5
+echo "configure:3492: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 3495 "configure"
+#line 3498 "configure"
 #ifdef HAVE_UNISTD_H
@@ -3511,7 +3514,7 @@
 EOF
-if { (eval echo configure:3515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -3539,16 +3542,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3543: checking for long long int" >&5
+echo "configure:3546: checking for long long int" >&5
-#line 3545 "configure"
+#line 3548 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:3552: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3555: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 echo "$ac_t""yes" 1>&6
@@ -3568,7 +3571,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3572: checking for W11" >&5
+echo "configure:3575: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3596,7 +3599,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3600: checking for X" >&5
+echo "configure:3603: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3656,12 +3659,12 @@
   # First, try using that file with no special directory specified.
-#line 3660 "configure"
+#line 3663 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:3665: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3730,14 +3733,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3734 "configure"
+#line 3737 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -3842,17 +3845,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3846: checking whether -R must be followed by a space" >&5
+echo "configure:3849: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3849 "configure"
+#line 3852 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3868,14 +3871,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3872 "configure"
+#line 3875 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -3907,13 +3910,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3911: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3914: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 3917 "configure"
+#line 3920 "configure"
@@ -3924,7 +3927,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3945,13 +3948,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3949: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3952: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 3955 "configure"
+#line 3958 "configure"
@@ -3962,7 +3965,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3990,10 +3993,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3994: checking for gethostbyname" >&5
+echo "configure:3997: checking for gethostbyname" >&5
-#line 3997 "configure"
+#line 4000 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -4016,7 +4019,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -4036,13 +4039,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4040: checking for gethostbyname in -lnsl" >&5
+echo "configure:4043: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4046 "configure"
+#line 4049 "configure"
@@ -4053,7 +4056,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4082,10 +4085,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4086: checking for connect" >&5
+echo "configure:4089: checking for connect" >&5
-#line 4089 "configure"
+#line 4092 "configure"
     which can conflict with char connect(); below.  */
@@ -4108,7 +4111,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4128,13 +4131,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4132: checking for connect in -lsocket" >&5
+echo "configure:4135: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4138 "configure"
+#line 4141 "configure"
@@ -4145,7 +4148,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4168,10 +4171,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4172: checking for remove" >&5
+echo "configure:4175: checking for remove" >&5
-#line 4175 "configure"
+#line 4178 "configure"
     which can conflict with char remove(); below.  */
@@ -4194,7 +4197,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4201: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4214,13 +4217,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4218: checking for remove in -lposix" >&5
+echo "configure:4221: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4224 "configure"
+#line 4227 "configure"
@@ -4231,7 +4234,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4254,10 +4257,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4258: checking for shmat" >&5
+echo "configure:4261: checking for shmat" >&5
-#line 4261 "configure"
+#line 4264 "configure"
     which can conflict with char shmat(); below.  */
@@ -4280,7 +4283,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4300,13 +4303,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4304: checking for shmat in -lipc" >&5
+echo "configure:4307: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4310 "configure"
+#line 4313 "configure"
@@ -4317,7 +4320,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4349,13 +4352,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4353: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4356: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4359 "configure"
+#line 4362 "configure"
@@ -4366,7 +4369,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4406,12 +4409,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4410: checking for library containing cuserid" >&5
+echo "configure:4413: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4415 "configure"
+#line 4418 "configure"
@@ -4422,7 +4425,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4433,7 +4436,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4437 "configure"
+#line 4440 "configure"
@@ -4444,7 +4447,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4470,10 +4473,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:4474: checking for xdrmem_create" >&5
+echo "configure:4477: checking for xdrmem_create" >&5
-#line 4477 "configure"
+#line 4480 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -4496,7 +4499,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -4514,13 +4517,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:4518: checking for xdrmem_create in -lsun" >&5
+echo "configure:4521: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 4524 "configure"
+#line 4527 "configure"
@@ -4531,7 +4534,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4550,13 +4553,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:4554: checking for xdrmem_create in -lnsl" >&5
+echo "configure:4557: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4560 "configure"
+#line 4563 "configure"
@@ -4567,7 +4570,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4586,13 +4589,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:4590: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:4593: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 4596 "configure"
+#line 4599 "configure"
@@ -4603,7 +4606,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4622,13 +4625,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:4626: checking for xdrmem_create in -lxdr" >&5
+echo "configure:4629: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 4632 "configure"
+#line 4635 "configure"
@@ -4639,7 +4642,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4673,10 +4676,10 @@
 for ac_func in asprintf
 do
-echo "configure:4677: checking for $ac_func" >&5
+echo "configure:4680: checking for $ac_func" >&5
-#line 4680 "configure"
+#line 4683 "configure"
@@ -4699,7 +4702,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4726,10 +4729,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4730: checking for atan" >&5
+echo "configure:4733: checking for atan" >&5
-#line 4733 "configure"
+#line 4736 "configure"
     which can conflict with char atan(); below.  */
@@ -4752,7 +4755,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4770,13 +4773,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4774: checking for atan in -lm" >&5
+echo "configure:4777: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4780 "configure"
+#line 4783 "configure"
@@ -4787,7 +4790,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4814,10 +4817,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4818: checking for dlsym" >&5
+echo "configure:4821: checking for dlsym" >&5
-#line 4821 "configure"
+#line 4824 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4840,7 +4843,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4858,13 +4861,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4862: checking for dlsym in -ldl" >&5
+echo "configure:4865: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4868 "configure"
+#line 4871 "configure"
@@ -4875,7 +4878,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4902,10 +4905,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4906: checking for iconv" >&5
+echo "configure:4909: checking for iconv" >&5
-#line 4909 "configure"
+#line 4912 "configure"
     which can conflict with char iconv(); below.  */
@@ -4928,7 +4931,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4946,13 +4949,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4950: checking for iconv in -liconv" >&5
+echo "configure:4953: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4956 "configure"
+#line 4959 "configure"
@@ -4963,7 +4966,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4982,13 +4985,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4986: checking for iconv in -lgiconv" >&5
+echo "configure:4989: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4992 "configure"
+#line 4995 "configure"
@@ -4999,7 +5002,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5018,10 +5021,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:5022: checking for libiconv" >&5
+echo "configure:5025: checking for libiconv" >&5
-#line 5025 "configure"
+#line 5028 "configure"
     which can conflict with char libiconv(); below.  */
@@ -5044,7 +5047,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -5062,13 +5065,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:5066: checking for libiconv in -liconv" >&5
+echo "configure:5069: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5072 "configure"
+#line 5075 "configure"
@@ -5079,7 +5082,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5098,13 +5101,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:5102: checking for libiconv in -lgiconv" >&5
+echo "configure:5105: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5108 "configure"
+#line 5111 "configure"
@@ -5115,7 +5118,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5152,10 +5155,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5156: checking for socket" >&5
+echo "configure:5159: checking for socket" >&5
-#line 5159 "configure"
+#line 5162 "configure"
     which can conflict with char socket(); below.  */
@@ -5178,7 +5181,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -5196,13 +5199,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5200: checking for socket in -lsocket" >&5
+echo "configure:5203: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 5206 "configure"
+#line 5209 "configure"
@@ -5213,7 +5216,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:5217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5261,7 +5264,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5265: checking for location of zlib includes" >&5
+echo "configure:5268: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5287,15 +5290,15 @@
 do
-echo "configure:5291: checking for $ac_hdr" >&5
+echo "configure:5294: checking for $ac_hdr" >&5
-#line 5294 "configure"
+#line 5297 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5299: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5329,7 +5332,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5333: checking for location of zlib library" >&5
+echo "configure:5336: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5354,13 +5357,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5358: checking for deflate in -lz" >&5
+echo "configure:5361: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5364 "configure"
+#line 5367 "configure"
@@ -5371,7 +5374,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5419,7 +5422,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5423: checking for location of External PROJ.4 includes" >&5
+echo "configure:5426: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5445,15 +5448,15 @@
 do
-echo "configure:5449: checking for $ac_hdr" >&5
+echo "configure:5452: checking for $ac_hdr" >&5
-#line 5452 "configure"
+#line 5455 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5457: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5490,7 +5493,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5494: checking External PROJ.4 version" >&5
+echo "configure:5497: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5498,7 +5501,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 5502 "configure"
+#line 5505 "configure"
 #include <stdio.h>
@@ -5510,7 +5513,7 @@
 EOF
-if { (eval echo configure:5514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5535,7 +5538,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5539: checking for location of External PROJ.4 library" >&5
+echo "configure:5542: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5560,13 +5563,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5564: checking for pj_get_def in -lproj" >&5
+echo "configure:5567: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5570 "configure"
+#line 5573 "configure"
@@ -5577,7 +5580,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5611,7 +5614,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5615: checking for location of External PROJ.4 data files" >&5
+echo "configure:5618: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5635,14 +5638,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5639: checking for epsg" >&5
+echo "configure:5642: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5646: checking for $PROJSHARE/epsg" >&5
+echo "configure:5649: checking for $PROJSHARE/epsg" >&5
@@ -5674,7 +5677,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:5678: checking for $ac_word" >&5
+echo "configure:5681: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5714,7 +5717,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5718: checking whether to use regex" >&5
+echo "configure:5721: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5734,7 +5737,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5738: checking for location of regex includes" >&5
+echo "configure:5741: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5760,15 +5763,15 @@
 do
-echo "configure:5764: checking for $ac_hdr" >&5
+echo "configure:5767: checking for $ac_hdr" >&5
-#line 5767 "configure"
+#line 5770 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5772: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5802,7 +5805,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5806: checking for location of regex library" >&5
+echo "configure:5809: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5827,10 +5830,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5831: checking for regcomp" >&5
+echo "configure:5834: checking for regcomp" >&5
-#line 5834 "configure"
+#line 5837 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5853,7 +5856,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5880,13 +5883,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5884: checking for regcomp in -lregex" >&5
+echo "configure:5887: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5890 "configure"
+#line 5893 "configure"
@@ -5897,7 +5900,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5947,7 +5950,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5951: checking whether to use Readline" >&5
+echo "configure:5954: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5968,7 +5971,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5972: checking for location of Readline includes" >&5
+echo "configure:5975: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5994,15 +5997,15 @@
 do
-echo "configure:5998: checking for $ac_hdr" >&5
+echo "configure:6001: checking for $ac_hdr" >&5
-#line 6001 "configure"
+#line 6004 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6006: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6038,15 +6041,15 @@
 do
-echo "configure:6042: checking for $ac_hdr" >&5
+echo "configure:6045: checking for $ac_hdr" >&5
-#line 6045 "configure"
+#line 6048 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6053: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6080,7 +6083,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6084: checking for location of Readline library" >&5
+echo "configure:6087: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6105,13 +6108,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6109: checking for readline in -lreadline" >&5
+echo "configure:6112: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 6115 "configure"
+#line 6118 "configure"
@@ -6122,7 +6125,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:6126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6157,13 +6160,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6161: checking for add_history in -lhistory" >&5
+echo "configure:6164: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 6167 "configure"
+#line 6170 "configure"
@@ -6174,7 +6177,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:6178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6217,7 +6220,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:6221: checking whether to use JPEG" >&5
+echo "configure:6224: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -6237,7 +6240,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:6241: checking for location of JPEG includes" >&5
+echo "configure:6244: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -6263,15 +6266,15 @@
 do
-echo "configure:6267: checking for $ac_hdr" >&5
+echo "configure:6270: checking for $ac_hdr" >&5
-#line 6270 "configure"
+#line 6273 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6275: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6278: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6305,7 +6308,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:6309: checking for location of JPEG library" >&5
+echo "configure:6312: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -6332,13 +6335,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:6336: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6339: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 6342 "configure"
+#line 6345 "configure"
@@ -6349,7 +6352,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:6353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6368,13 +6371,13 @@
-echo "configure:6372: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6375: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 6378 "configure"
+#line 6381 "configure"
@@ -6385,7 +6388,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6434,7 +6437,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6438: checking whether to use GDAL" >&5
+echo "configure:6441: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6452,7 +6455,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:6456: checking for $ac_word" >&5
+echo "configure:6459: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6507,14 +6510,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6511 "configure"
+#line 6514 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -6523,14 +6526,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6527 "configure"
+#line 6530 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6562,7 +6565,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6566: checking whether to use libLAS" >&5
+echo "configure:6569: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6579,7 +6582,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6583: checking for $ac_word" >&5
+echo "configure:6586: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6627,14 +6630,14 @@
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6631 "configure"
+#line 6634 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6642,14 +6645,14 @@
   rm -rf conftest*
-#line 6646 "configure"
+#line 6649 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6681,7 +6684,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6685: checking whether to use GEOS" >&5
+echo "configure:6688: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -6699,7 +6702,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6703: checking for $ac_word" >&5
+echo "configure:6706: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6747,15 +6750,15 @@
 do
-echo "configure:6751: checking for $ac_hdr" >&5
+echo "configure:6754: checking for $ac_hdr" >&5
-#line 6754 "configure"
+#line 6757 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6762: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6791,13 +6794,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6795: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6798: checking for initGEOS in -lgeos_c_i" >&5
 ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c_i  $LIBS"
-#line 6801 "configure"
+#line 6804 "configure"
@@ -6808,7 +6811,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6815: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6844,13 +6847,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6848: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6851: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6854 "configure"
+#line 6857 "configure"
@@ -6861,7 +6864,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6905,7 +6908,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6909: checking whether to use TIFF" >&5
+echo "configure:6912: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6925,7 +6928,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6929: checking for location of TIFF includes" >&5
+echo "configure:6932: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6951,15 +6954,15 @@
 do
-echo "configure:6955: checking for $ac_hdr" >&5
+echo "configure:6958: checking for $ac_hdr" >&5
-#line 6958 "configure"
+#line 6961 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6963: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6966: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6993,7 +6996,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6997: checking for location of TIFF library" >&5
+echo "configure:7000: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7024,13 +7027,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7028: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7031: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 7034 "configure"
+#line 7037 "configure"
@@ -7041,7 +7044,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7060,13 +7063,13 @@
-echo "configure:7064: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7067: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7070 "configure"
+#line 7073 "configure"
@@ -7077,7 +7080,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7096,13 +7099,13 @@
-echo "configure:7100: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7103: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7106 "configure"
+#line 7109 "configure"
@@ -7113,7 +7116,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7132,13 +7135,13 @@
-echo "configure:7136: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7139: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7142 "configure"
+#line 7145 "configure"
@@ -7149,7 +7152,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7168,13 +7171,13 @@
-echo "configure:7172: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7175: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7178 "configure"
+#line 7181 "configure"
@@ -7185,7 +7188,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7204,13 +7207,13 @@
-echo "configure:7208: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7211: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7214 "configure"
+#line 7217 "configure"
@@ -7221,7 +7224,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7240,13 +7243,13 @@
-echo "configure:7244: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7247: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7250 "configure"
+#line 7253 "configure"
@@ -7257,7 +7260,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7276,13 +7279,13 @@
-echo "configure:7280: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7283: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7286 "configure"
+#line 7289 "configure"
@@ -7293,7 +7296,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7391,7 +7394,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7395: checking whether to use PNG" >&5
+echo "configure:7398: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7410,7 +7413,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7414: checking for location of PNG includes" >&5
+echo "configure:7417: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7436,15 +7439,15 @@
 do
-echo "configure:7440: checking for $ac_hdr" >&5
+echo "configure:7443: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 7443 "configure"
+#line 7446 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7448: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7451: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7478,7 +7481,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7482: checking for location of PNG library" >&5
+echo "configure:7485: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7503,13 +7506,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7507: checking for png_read_image in -lpng" >&5
+echo "configure:7510: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7513 "configure"
+#line 7516 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7520,7 +7523,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7562,7 +7565,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7566: checking whether to use PostgreSQL" >&5
+echo "configure:7569: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7589,7 +7592,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7593: checking for location of PostgreSQL includes" >&5
+echo "configure:7596: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7615,15 +7618,15 @@
 do
-echo "configure:7619: checking for $ac_hdr" >&5
+echo "configure:7622: checking for $ac_hdr" >&5
-#line 7622 "configure"
+#line 7625 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7630: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7661,7 +7664,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7665: checking for location of PostgreSQL library" >&5
+echo "configure:7668: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7690,13 +7693,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7694: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7697: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7700 "configure"
+#line 7703 "configure"
@@ -7707,7 +7710,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7726,13 +7729,13 @@
-echo "configure:7730: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7733: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7736 "configure"
+#line 7739 "configure"
@@ -7743,7 +7746,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7762,13 +7765,13 @@
-echo "configure:7766: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7769: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7772 "configure"
+#line 7775 "configure"
@@ -7779,7 +7782,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7798,13 +7801,13 @@
-echo "configure:7802: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7805: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7808 "configure"
+#line 7811 "configure"
@@ -7815,7 +7818,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7872,13 +7875,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7876: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7879: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7882 "configure"
+#line 7885 "configure"
@@ -7889,7 +7892,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7911,13 +7914,13 @@
-echo "configure:7915: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7918: checking for PQcmdTuples in -lpq" >&5
-#line 7921 "configure"
+#line 7924 "configure"
@@ -7928,7 +7931,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7971,7 +7974,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7975: checking whether to use MySQL" >&5
+echo "configure:7978: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7991,7 +7994,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7995: checking for location of MySQL includes" >&5
+echo "configure:7998: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8017,15 +8020,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8021: checking for $ac_hdr" >&5
+echo "configure:8024: checking for $ac_hdr" >&5
-#line 8024 "configure"
+#line 8027 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8062,7 +8065,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8066: checking for location of MySQL library" >&5
+echo "configure:8069: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8093,13 +8096,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8097: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8100: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 8103 "configure"
+#line 8106 "configure"
@@ -8110,7 +8113,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8129,13 +8132,13 @@
-echo "configure:8133: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8136: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8139 "configure"
+#line 8142 "configure"
@@ -8146,7 +8149,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8165,13 +8168,13 @@
-echo "configure:8169: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8172: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8175 "configure"
+#line 8178 "configure"
@@ -8182,7 +8185,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8201,13 +8204,13 @@
-echo "configure:8205: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8208: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8211 "configure"
+#line 8214 "configure"
@@ -8218,7 +8221,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8237,13 +8240,13 @@
-echo "configure:8241: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8244: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8247 "configure"
+#line 8250 "configure"
@@ -8254,7 +8257,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8273,13 +8276,13 @@
-echo "configure:8277: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8280: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8283 "configure"
+#line 8286 "configure"
@@ -8290,7 +8293,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8309,13 +8312,13 @@
-echo "configure:8313: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8316: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8319 "configure"
+#line 8322 "configure"
@@ -8326,7 +8329,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8345,13 +8348,13 @@
-echo "configure:8349: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8352: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8355 "configure"
+#line 8358 "configure"
@@ -8362,7 +8365,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8452,7 +8455,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8456: checking for $ac_word" >&5
+echo "configure:8459: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8501,10 +8504,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8505: checking for mysql_server_init" >&5
+echo "configure:8508: checking for mysql_server_init" >&5
-#line 8508 "configure"
+#line 8511 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -8530,7 +8533,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8582,7 +8585,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8586: checking whether to use SQLite" >&5
+echo "configure:8589: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8602,7 +8605,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8606: checking for location of SQLite includes" >&5
+echo "configure:8609: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8628,15 +8631,15 @@
 do
-echo "configure:8632: checking for $ac_hdr" >&5
+echo "configure:8635: checking for $ac_hdr" >&5
-#line 8635 "configure"
+#line 8638 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8640: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8643: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8679,7 +8682,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8683: checking for location of SQLite library" >&5
+echo "configure:8686: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8708,13 +8711,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8712: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8715: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8718 "configure"
+#line 8721 "configure"
@@ -8725,7 +8728,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8744,13 +8747,13 @@
-echo "configure:8748: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8751: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8754 "configure"
+#line 8757 "configure"
@@ -8761,7 +8764,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8780,13 +8783,13 @@
-echo "configure:8784: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8787: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8790 "configure"
+#line 8793 "configure"
@@ -8797,7 +8800,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8816,13 +8819,13 @@
-echo "configure:8820: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8823: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8826 "configure"
+#line 8829 "configure"
@@ -8833,7 +8836,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8902,7 +8905,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8906: checking whether to use FFMPEG" >&5
+echo "configure:8909: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -8922,7 +8925,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8926: checking for location of FFMPEG includes" >&5
+echo "configure:8929: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8948,15 +8951,15 @@
 do
-echo "configure:8952: checking for $ac_hdr" >&5
+echo "configure:8955: checking for $ac_hdr" >&5
-#line 8955 "configure"
+#line 8958 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8963: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8992,15 +8995,15 @@
 do
-echo "configure:8996: checking for $ac_hdr" >&5
+echo "configure:8999: checking for $ac_hdr" >&5
-#line 8999 "configure"
+#line 9002 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9004: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9036,15 +9039,15 @@
 do
-echo "configure:9040: checking for $ac_hdr" >&5
+echo "configure:9043: checking for $ac_hdr" >&5
-#line 9043 "configure"
+#line 9046 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9051: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9087,7 +9090,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:9091: checking for location of FFMPEG library" >&5
+echo "configure:9094: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -9114,13 +9117,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:9118: checking for av_free in -lavutil" >&5
+echo "configure:9121: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 9124 "configure"
+#line 9127 "configure"
@@ -9131,7 +9134,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:9135: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9150,13 +9153,13 @@
-echo "configure:9154: checking for av_free in -lavutil" >&5
+echo "configure:9157: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 9160 "configure"
+#line 9163 "configure"
@@ -9167,7 +9170,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:9171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9212,13 +9215,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:9216: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9219: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 9222 "configure"
+#line 9225 "configure"
@@ -9229,7 +9232,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:9233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9248,13 +9251,13 @@
-echo "configure:9252: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9255: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 9258 "configure"
+#line 9261 "configure"
@@ -9265,7 +9268,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:9269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9310,13 +9313,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9314: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9317: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 9320 "configure"
+#line 9323 "configure"
@@ -9327,7 +9330,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9346,13 +9349,13 @@
-echo "configure:9350: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9353: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9356 "configure"
+#line 9359 "configure"
@@ -9363,7 +9366,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9422,7 +9425,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9426: checking whether to use OpenGL" >&5
+echo "configure:9429: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9456,7 +9459,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9460: checking for location of OpenGL includes" >&5
+echo "configure:9463: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9482,15 +9485,15 @@
 do
-echo "configure:9486: checking for $ac_hdr" >&5
+echo "configure:9489: checking for $ac_hdr" >&5
-#line 9489 "configure"
+#line 9492 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9494: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9524,7 +9527,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9528: checking for location of OpenGL library" >&5
+echo "configure:9531: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9553,13 +9556,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9557: checking for glBegin in -lGL" >&5
+echo "configure:9560: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9563 "configure"
+#line 9566 "configure"
@@ -9570,7 +9573,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9589,13 +9592,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:9593: checking for glBegin in -lGL" >&5
+echo "configure:9596: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9599 "configure"
+#line 9602 "configure"
@@ -9606,7 +9609,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9625,13 +9628,13 @@
-echo "configure:9629: checking for glBegin in -lGL" >&5
+echo "configure:9632: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9635 "configure"
+#line 9638 "configure"
@@ -9642,7 +9645,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9661,13 +9664,13 @@
-echo "configure:9665: checking for glBegin in -lGL" >&5
+echo "configure:9668: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9671 "configure"
+#line 9674 "configure"
@@ -9678,7 +9681,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9740,13 +9743,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9744: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9747: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9750 "configure"
+#line 9753 "configure"
@@ -9757,7 +9760,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9776,13 +9779,13 @@
-echo "configure:9780: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9783: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9786 "configure"
+#line 9789 "configure"
@@ -9793,7 +9796,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9840,10 +9843,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9844: checking for glXCreatePbuffer" >&5
+echo "configure:9847: checking for glXCreatePbuffer" >&5
-#line 9847 "configure"
+#line 9850 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9866,7 +9869,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9903,10 +9906,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9907: checking for glXCreateGLXPixmap" >&5
+echo "configure:9910: checking for glXCreateGLXPixmap" >&5
-#line 9910 "configure"
+#line 9913 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9929,7 +9932,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9972,7 +9975,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9976: checking for location of OpenGL framework" >&5
+echo "configure:9979: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9996,15 +9999,15 @@
 do
-echo "configure:10000: checking for $ac_hdr" >&5
+echo "configure:10003: checking for $ac_hdr" >&5
-#line 10003 "configure"
+#line 10006 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10011: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10040,10 +10043,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:10044: checking for glBegin" >&5
+echo "configure:10047: checking for glBegin" >&5
-#line 10047 "configure"
+#line 10050 "configure"
     which can conflict with char glBegin(); below.  */
@@ -10066,7 +10069,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -10103,10 +10106,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:10107: checking for gluBeginCurve" >&5
+echo "configure:10110: checking for gluBeginCurve" >&5
-#line 10110 "configure"
+#line 10113 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -10129,7 +10132,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -10177,7 +10180,7 @@
-echo "configure:10181: checking for location of OpenGL includes" >&5
+echo "configure:10184: checking for location of OpenGL includes" >&5
@@ -10203,15 +10206,15 @@
 do
-echo "configure:10207: checking for $ac_hdr" >&5
+echo "configure:10210: checking for $ac_hdr" >&5
-#line 10210 "configure"
+#line 10213 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10245,7 +10248,7 @@
-echo "configure:10249: checking for location of OpenGL library" >&5
+echo "configure:10252: checking for location of OpenGL library" >&5
@@ -10270,18 +10273,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10274: checking for OpenGL library" >&5
+echo "configure:10277: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 10278 "configure"
+#line 10281 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:10285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -10305,18 +10308,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10309: checking for GLU library" >&5
+echo "configure:10312: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10313 "configure"
+#line 10316 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10365,7 +10368,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10369: checking whether to use Tcl/Tk" >&5
+echo "configure:10372: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -10385,7 +10388,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10389: checking for location of Tcl/Tk includes" >&5
+echo "configure:10392: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10411,15 +10414,15 @@
 do
-echo "configure:10415: checking for $ac_hdr" >&5
+echo "configure:10418: checking for $ac_hdr" >&5
-#line 10418 "configure"
+#line 10421 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10423: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10456,15 +10459,15 @@
 do
-echo "configure:10460: checking for $ac_hdr" >&5
+echo "configure:10463: checking for $ac_hdr" >&5
-#line 10463 "configure"
+#line 10466 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10468: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10471: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10498,7 +10501,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10502: checking Tcl version" >&5
+echo "configure:10505: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -10506,7 +10509,7 @@
 else
-#line 10510 "configure"
+#line 10513 "configure"
 #include <stdio.h>
@@ -10518,7 +10521,7 @@
 EOF
-if { (eval echo configure:10522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -10536,7 +10539,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10540: checking Tk version" >&5
+echo "configure:10543: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10544,7 +10547,7 @@
 else
-#line 10548 "configure"
+#line 10551 "configure"
 #include <stdio.h>
@@ -10556,7 +10559,7 @@
 EOF
-if { (eval echo configure:10560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -10585,7 +10588,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10589: checking for location of Tcl/Tk library" >&5
+echo "configure:10592: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10625,13 +10628,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10629: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10632: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 10635 "configure"
+#line 10638 "configure"
@@ -10642,7 +10645,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10661,13 +10664,13 @@
-echo "configure:10665: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10668: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10671 "configure"
+#line 10674 "configure"
@@ -10678,7 +10681,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10705,13 +10708,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10709: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10712: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10715 "configure"
+#line 10718 "configure"
@@ -10722,7 +10725,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10741,13 +10744,13 @@
-echo "configure:10745: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10748: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10751 "configure"
+#line 10754 "configure"
@@ -10758,7 +10761,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10785,13 +10788,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10789: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10792: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10795 "configure"
+#line 10798 "configure"
@@ -10802,7 +10805,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10821,13 +10824,13 @@
-echo "configure:10825: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10828: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10831 "configure"
+#line 10834 "configure"
@@ -10838,7 +10841,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10916,13 +10919,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10920: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10923: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10926 "configure"
+#line 10929 "configure"
@@ -10933,7 +10936,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10952,13 +10955,13 @@
-echo "configure:10956: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10959: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10962 "configure"
+#line 10965 "configure"
@@ -10969,7 +10972,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10996,13 +10999,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11000: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11003: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 11006 "configure"
+#line 11009 "configure"
@@ -11013,7 +11016,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11032,13 +11035,13 @@
-echo "configure:11036: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11039: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11042 "configure"
+#line 11045 "configure"
@@ -11049,7 +11052,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11076,13 +11079,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11080: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11083: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 11086 "configure"
+#line 11089 "configure"
@@ -11093,7 +11096,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11112,13 +11115,13 @@
-echo "configure:11116: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11119: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11122 "configure"
+#line 11125 "configure"
@@ -11129,7 +11132,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11219,13 +11222,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:11223: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:11226: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 11229 "configure"
+#line 11232 "configure"
@@ -11236,7 +11239,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11286,7 +11289,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11290: checking whether to use ODBC" >&5
+echo "configure:11293: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11305,7 +11308,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11309: checking for location of ODBC includes" >&5
+echo "configure:11312: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11331,15 +11334,15 @@
 do
-echo "configure:11335: checking for $ac_hdr" >&5
+echo "configure:11338: checking for $ac_hdr" >&5
-#line 11338 "configure"
+#line 11341 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11343: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11346: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11373,7 +11376,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11377: checking for location of ODBC library" >&5
+echo "configure:11380: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11398,13 +11401,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11402: checking for SQLConnect in -lodbc" >&5
+echo "configure:11405: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11408 "configure"
+#line 11411 "configure"
@@ -11415,7 +11418,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11440,13 +11443,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11444: checking for SQLConnect in -liodbc" >&5
+echo "configure:11447: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 11450 "configure"
+#line 11453 "configure"
@@ -11457,7 +11460,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11482,11 +11485,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11486: checking for ODBC library" >&5
+echo "configure:11489: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 11490 "configure"
+#line 11493 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -11494,7 +11497,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:11498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11543,7 +11546,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11547: checking whether to use FFTW" >&5
+echo "configure:11550: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -11562,7 +11565,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11566: checking for location of FFTW includes" >&5
+echo "configure:11569: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11588,15 +11591,15 @@
 do
-echo "configure:11592: checking for $ac_hdr" >&5
+echo "configure:11595: checking for $ac_hdr" >&5
-#line 11595 "configure"
+#line 11598 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11600: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11603: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11624,15 +11627,15 @@
 do
-echo "configure:11628: checking for $ac_hdr" >&5
+echo "configure:11631: checking for $ac_hdr" >&5
-#line 11631 "configure"
+#line 11634 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11636: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11639: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11660,15 +11663,15 @@
 do
-echo "configure:11664: checking for $ac_hdr" >&5
+echo "configure:11667: checking for $ac_hdr" >&5
-#line 11667 "configure"
+#line 11670 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11675: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11714,7 +11717,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11718: checking for location of FFTW library" >&5
+echo "configure:11721: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11739,13 +11742,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11743: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11746: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11749 "configure"
+#line 11752 "configure"
@@ -11756,7 +11759,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:11760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11781,13 +11784,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11785: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11788: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 11791 "configure"
+#line 11794 "configure"
@@ -11798,7 +11801,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11823,13 +11826,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11827: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11830: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11833 "configure"
+#line 11836 "configure"
@@ -11840,7 +11843,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11897,7 +11900,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11901: checking whether to use BLAS" >&5
+echo "configure:11904: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -11918,7 +11921,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11922: checking for location of BLAS includes" >&5
+echo "configure:11925: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11938,7 +11941,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11942: checking for location of BLAS library" >&5
+echo "configure:11945: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11964,15 +11967,15 @@
 do
-echo "configure:11968: checking for $ac_hdr" >&5
+echo "configure:11971: checking for $ac_hdr" >&5
-#line 11971 "configure"
+#line 11974 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11976: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11979: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12007,13 +12010,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12011: checking for dnrm2_ in -lblas" >&5
+echo "configure:12014: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12017 "configure"
+#line 12020 "configure"
@@ -12024,7 +12027,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12043,13 +12046,13 @@
-echo "configure:12047: checking for dnrm2_ in -lblas" >&5
+echo "configure:12050: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12053 "configure"
+#line 12056 "configure"
@@ -12060,7 +12063,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12104,13 +12107,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12108: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12111: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12114 "configure"
+#line 12117 "configure"
@@ -12121,7 +12124,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12136,13 +12139,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12140: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12143: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12146 "configure"
+#line 12149 "configure"
@@ -12153,7 +12156,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12168,13 +12171,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12172: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12175: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12178 "configure"
+#line 12181 "configure"
@@ -12185,7 +12188,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12231,16 +12234,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12235: checking for sgemm in $vlib_flags" >&5
+echo "configure:12238: checking for sgemm in $vlib_flags" >&5
-#line 12237 "configure"
+#line 12240 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12258,13 +12261,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12262: checking for sgemm_ in -lblas" >&5
+echo "configure:12265: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12268 "configure"
+#line 12271 "configure"
@@ -12275,7 +12278,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12290,13 +12293,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12294: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12297: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12300 "configure"
+#line 12303 "configure"
@@ -12307,7 +12310,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12322,13 +12325,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12326: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12329: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12332 "configure"
+#line 12335 "configure"
@@ -12339,7 +12342,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12373,13 +12376,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12377: checking for acosp in -lsunmath" >&5
+echo "configure:12380: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12383 "configure"
+#line 12386 "configure"
@@ -12390,7 +12393,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12405,13 +12408,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12409: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12412: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12415 "configure"
+#line 12418 "configure"
 #include "confdefs.h"
@@ -12422,7 +12425,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12452,13 +12455,13 @@
 # Generic BLAS library
-echo "configure:12456: checking for sgemm_ in -lblas" >&5
+echo "configure:12459: checking for sgemm_ in -lblas" >&5
 ac_save_LIBS="$LIBS"
 LIBS="-lblas  $LIBS"
-#line 12462 "configure"
+#line 12465 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12469,7 +12472,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12508,7 +12511,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12512: checking whether to use LAPACK" >&5
+echo "configure:12515: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -12533,7 +12536,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12537: checking for location of LAPACK includes" >&5
+echo "configure:12540: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12553,7 +12556,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12557: checking for location of LAPACK library" >&5
+echo "configure:12560: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12579,15 +12582,15 @@
 do
-echo "configure:12583: checking for $ac_hdr" >&5
+echo "configure:12586: checking for $ac_hdr" >&5
-#line 12586 "configure"
+#line 12589 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12591: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12594: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12619,10 +12622,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12623: checking for dsegv_" >&5
+echo "configure:12626: checking for dsegv_" >&5
-#line 12626 "configure"
+#line 12629 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -12645,7 +12648,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -12672,13 +12675,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12676: checking for desgv_ in -llapack" >&5
+echo "configure:12679: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 12682 "configure"
+#line 12685 "configure"
@@ -12689,7 +12692,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12721,13 +12724,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12725: checking for dgesv_ in -llapack" >&5
+echo "configure:12728: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 12731 "configure"
+#line 12734 "configure"
@@ -12738,7 +12741,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12757,13 +12760,13 @@
-echo "configure:12761: checking for dgesv_ in -llapack" >&5
+echo "configure:12764: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12767 "configure"
+#line 12770 "configure"
@@ -12774,7 +12777,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12830,7 +12833,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12834: checking whether to use Cairo" >&5
+echo "configure:12837: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -12862,7 +12865,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12866: checking for location of cairo includes" >&5
+echo "configure:12869: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12888,15 +12891,15 @@
 do
-echo "configure:12892: checking for $ac_hdr" >&5
+echo "configure:12895: checking for $ac_hdr" >&5
-#line 12895 "configure"
+#line 12898 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12932,7 +12935,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12936: checking for location of cairo library" >&5
+echo "configure:12939: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12952,7 +12955,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12956: checking for cairo linking flags" >&5
+echo "configure:12959: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12968,10 +12971,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12972: checking for cairo_create" >&5
+echo "configure:12975: checking for cairo_create" >&5
-#line 12975 "configure"
+#line 12978 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -12994,7 +12997,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13028,10 +13031,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:13032: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:13035: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 13035 "configure"
+#line 13038 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -13054,7 +13057,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -13087,10 +13090,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13091: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:13094: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13094 "configure"
+#line 13097 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -13113,7 +13116,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -13155,7 +13158,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13159: checking whether to use FreeType" >&5
+echo "configure:13162: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13174,7 +13177,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13178: checking for location of FreeType includes" >&5
+echo "configure:13181: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13200,15 +13203,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13204: checking for $ac_hdr" >&5
+echo "configure:13207: checking for $ac_hdr" >&5
-#line 13207 "configure"
+#line 13210 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13242,7 +13245,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13246: checking for location of FreeType library" >&5
+echo "configure:13249: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13267,13 +13270,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13271: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13274: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 13277 "configure"
+#line 13280 "configure"
@@ -13284,7 +13287,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13325,7 +13328,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13329: checking whether to use NLS" >&5
+echo "configure:13332: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13345,10 +13348,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13349: checking for gettext" >&5
+echo "configure:13352: checking for gettext" >&5
-#line 13352 "configure"
+#line 13355 "configure"
     which can conflict with char gettext(); below.  */
@@ -13371,7 +13374,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13389,13 +13392,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13393: checking for gettext in -lintl" >&5
+echo "configure:13396: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13399 "configure"
+#line 13402 "configure"
@@ -13406,7 +13409,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13441,7 +13444,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13445: checking whether to use C++" >&5
+echo "configure:13448: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -13457,7 +13460,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13461: checking for $ac_word" >&5
+echo "configure:13464: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13486,7 +13489,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13490: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13493: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13497,12 +13500,12 @@
 cat > conftest.$ac_ext << EOF
-#line 13501 "configure"
+#line 13504 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:13506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -13528,19 +13531,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13532: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13535: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13537: checking whether we are using GNU C++" >&5
+echo "configure:13540: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13547: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -13558,7 +13561,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13562: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13565: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13599,7 +13602,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13603: checking whether to use openDWG" >&5
+echo "configure:13606: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -13619,7 +13622,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13623: checking for location of openDGW includes" >&5
+echo "configure:13626: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13645,15 +13648,15 @@
 do
-echo "configure:13649: checking for $ac_hdr" >&5
+echo "configure:13652: checking for $ac_hdr" >&5
-#line 13652 "configure"
+#line 13655 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13657: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13660: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13687,7 +13690,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13691: checking for location of openDWG library" >&5
+echo "configure:13694: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13728,7 +13731,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13732: checking whether to use POSIX threads" >&5
+echo "configure:13735: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -13748,7 +13751,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13752: checking for location of POSIX threads includes" >&5
+echo "configure:13755: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13774,15 +13777,15 @@
 do
-echo "configure:13778: checking for $ac_hdr" >&5
+echo "configure:13781: checking for $ac_hdr" >&5
-#line 13781 "configure"
+#line 13784 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13786: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13789: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13816,7 +13819,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13820: checking for location of POSIX threads library" >&5
+echo "configure:13823: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13841,10 +13844,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13845: checking for pthread_create" >&5
+echo "configure:13848: checking for pthread_create" >&5
-#line 13848 "configure"
+#line 13851 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -13867,7 +13870,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -13894,13 +13897,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13898: checking for pthread_create in -lpthread" >&5
+echo "configure:13901: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 13904 "configure"
+#line 13907 "configure"
@@ -13911,7 +13914,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:13915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13961,7 +13964,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:13965: checking whether to use OpenMP" >&5
+echo "configure:13968: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -13982,7 +13985,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:13986: checking for location of OpenMP includes" >&5
+echo "configure:13989: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -14008,15 +14011,15 @@
 do
-echo "configure:14012: checking for $ac_hdr" >&5
+echo "configure:14015: checking for $ac_hdr" >&5
-#line 14015 "configure"
+#line 14018 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14020: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14023: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14054,7 +14057,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:14058: checking for location of OpenMP library" >&5
+echo "configure:14061: checking for location of OpenMP library" >&5
 case "$with_gomp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -14079,10 +14082,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:14083: checking for GOMP_parallel_start" >&5
+echo "configure:14086: checking for GOMP_parallel_start" >&5
-#line 14086 "configure"
+#line 14089 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -14105,7 +14108,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -14132,13 +14135,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:14136: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:14139: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 14142 "configure"
+#line 14145 "configure"
@@ -14149,7 +14152,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14228,7 +14231,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14232: checking for special C compiler options needed for large files" >&5
+echo "configure:14235: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14236,7 +14239,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14240 "configure"
+#line 14243 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14252,7 +14255,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14256: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14259: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14261,7 +14264,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14265 "configure"
+#line 14268 "configure"
@@ -14277,7 +14280,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14281: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14284: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14297,11 +14300,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14301: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14304: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14305 "configure"
+#line 14308 "configure"
@@ -14317,14 +14320,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14321: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14324: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 14328 "configure"
+#line 14331 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14342,7 +14345,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14346: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14349: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14361,11 +14364,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14365: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14368: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14369 "configure"
+#line 14372 "configure"
@@ -14381,14 +14384,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14385: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14388: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14392 "configure"
+#line 14395 "configure"
 #define _LARGE_FILES 1
@@ -14406,7 +14409,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14410: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14413: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14425,25 +14428,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14429: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14432: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14433 "configure"
+#line 14436 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14440: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14443: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14447 "configure"
+#line 14450 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14452,7 +14455,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14456: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14459: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14473,25 +14476,25 @@
    fi
-echo "configure:14477: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14480: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14481 "configure"
+#line 14484 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14488: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14491: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14495 "configure"
+#line 14498 "configure"
 #include <stdio.h>
@@ -14500,7 +14503,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14504: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14507: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -14523,18 +14526,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14527: checking for fseeko" >&5
+echo "configure:14530: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 14531 "configure"
+#line 14534 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:14538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -14551,10 +14554,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14555: checking if system supports Large Files at all" >&5
+echo "configure:14558: checking if system supports Large Files at all" >&5
-#line 14558 "configure"
+#line 14561 "configure"
 #include <stdio.h>
@@ -14586,7 +14589,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14590: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14593: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14615,7 +14618,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14619: checking whether to use wxWidgets" >&5
+echo "configure:14622: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14636,7 +14639,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14640: checking for $ac_word" >&5
+echo "configure:14643: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14684,7 +14687,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14688: checking wxWidgets version" >&5
+echo "configure:14691: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -14707,15 +14710,15 @@
 do
-echo "configure:14711: checking for $ac_hdr" >&5
+echo "configure:14714: checking for $ac_hdr" >&5
-#line 14714 "configure"
+#line 14717 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2012-02-05 10:25:11 UTC (rev 50660)
+++ grass/trunk/configure.in	2012-02-05 11:38:00 UTC (rev 50661)
@@ -128,6 +128,9 @@
 AC_PATH_PROG(SVN_VERSION, svnversion, no)
 if test "$SVN_VERSION" != "no" ; then
    GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
+   if test "$GRASS_VERSION_SVN" = "exported" ; then
+      GRASS_VERSION_SVN=
+   fi
 fi
 AC_SUBST(GRASS_VERSION_FILE)
