[GRASS-SVN] r50662 - grass/branches/develbranch_6
Sun Feb 5 06:40:47 EST 2012
Author: hamish
Date: 2012-02-05 03:40:47 -0800 (Sun, 05 Feb 2012)
New Revision: 50662
   grass/branches/develbranch_6/configure
   grass/branches/develbranch_6/configure.in
handle case when source tree is not a svn branch (#587, merge from trunk)
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure	2012-02-05 11:38:00 UTC (rev 50661)
+++ grass/branches/develbranch_6/configure	2012-02-05 11:40:47 UTC (rev 50662)
@@ -1326,6 +1326,9 @@
 if test "$SVN_VERSION" != "no" ; then
    GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
+   if test "$GRASS_VERSION_SVN" = "exported" ; then
+      GRASS_VERSION_SVN=
+   fi
 fi
@@ -1350,7 +1353,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1354: checking for MacOSX App" >&5
+echo "configure:1357: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1362,7 +1365,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1366: checking for MacOSX architectures" >&5
+echo "configure:1369: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1391,7 +1394,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1395: checking for MacOSX SDK" >&5
+echo "configure:1398: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1401,7 +1404,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1405: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1408: checking for $with_macosx_sdk/SDKSettings.plist" >&5
 if test "$cross_compiling" = yes; then
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1445,7 +1448,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1449: checking how to build libraries" >&5
+echo "configure:1452: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1488,7 +1491,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1492: checking for $ac_word" >&5
+echo "configure:1495: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1513,7 +1516,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1517: checking how to run the C preprocessor" >&5
+echo "configure:1520: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1526,13 +1529,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
   cat > conftest.$ac_ext <<EOF
-#line 1530 "configure"
+#line 1533 "configure"
 #include "confdefs.h"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1539: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1543,13 +1546,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1547 "configure"
+#line 1550 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1553: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1560,13 +1563,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1564 "configure"
+#line 1567 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1570: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1594,7 +1597,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1598: checking if 64bit support is requested" >&5
+echo "configure:1601: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1614,7 +1617,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1618: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1621: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1638,7 +1641,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1642: checking system version (for dynamic loading)" >&5
+echo "configure:1645: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1664,13 +1667,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1668: checking for dlopen in -ldl" >&5
+echo "configure:1671: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1674 "configure"
+#line 1677 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1681,7 +1684,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1728,7 +1731,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1732: checking for $ac_word" >&5
+echo "configure:1735: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1857,13 +1860,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1861: checking for gettimeofday in -lbsd" >&5
+echo "configure:1864: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1867 "configure"
+#line 1870 "configure"
@@ -1874,7 +1877,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1915,13 +1918,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1919: checking for inet_ntoa in -lbind" >&5
+echo "configure:1922: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1925 "configure"
+#line 1928 "configure"
@@ -1932,7 +1935,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1993,13 +1996,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1997: checking for shl_load in -ldld" >&5
+echo "configure:2000: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 2003 "configure"
+#line 2006 "configure"
@@ -2010,7 +2013,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2075,13 +2078,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:2079: checking for shl_load in -ldld" >&5
+echo "configure:2082: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 2085 "configure"
+#line 2088 "configure"
@@ -2092,7 +2095,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2214,15 +2217,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2218: checking for dld.h" >&5
+echo "configure:2221: checking for dld.h" >&5
-#line 2221 "configure"
+#line 2224 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2226: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2282,15 +2285,15 @@
 	    else
-echo "configure:2286: checking for dld.h" >&5
+echo "configure:2289: checking for dld.h" >&5
-#line 2289 "configure"
+#line 2292 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2387,9 +2390,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2391: checking for ELF" >&5
+echo "configure:2394: checking for ELF" >&5
-#line 2393 "configure"
+#line 2396 "configure"
 #ifdef __ELF__
@@ -2419,15 +2422,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2423: checking for dlfcn.h" >&5
+echo "configure:2426: checking for dlfcn.h" >&5
-#line 2426 "configure"
+#line 2429 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2451,9 +2454,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2455: checking for ELF" >&5
+echo "configure:2458: checking for ELF" >&5
-#line 2457 "configure"
+#line 2460 "configure"
 #ifdef __ELF__
@@ -2777,17 +2780,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2781: checking for ld accepts -Bexport flag" >&5
+echo "configure:2784: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2784 "configure"
+#line 2787 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3612,7 +3615,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3616: checking for additional include dirs" >&5
+echo "configure:3619: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3635,7 +3638,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3639: checking for additional library dirs" >&5
+echo "configure:3642: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3669,7 +3672,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3673: checking for a BSD compatible install" >&5
+echo "configure:3676: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3722,7 +3725,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3726: checking for $ac_word" >&5
+echo "configure:3729: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3753,13 +3756,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3757: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3760: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3763 "configure"
+#line 3766 "configure"
@@ -3770,7 +3773,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3795,7 +3798,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3799: checking for $ac_word" >&5
+echo "configure:3802: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3835,7 +3838,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3839: checking for $ac_word" >&5
+echo "configure:3842: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3866,7 +3869,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3870: checking for $ac_word" >&5
+echo "configure:3873: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3904,7 +3907,7 @@
-echo "configure:3908: checking for $ac_word" >&5
+echo "configure:3911: checking for $ac_word" >&5
@@ -3933,7 +3936,7 @@
-echo "configure:3937: checking for $ac_word" >&5
+echo "configure:3940: checking for $ac_word" >&5
@@ -3964,7 +3967,7 @@
-echo "configure:3968: checking for $ac_word" >&5
+echo "configure:3971: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3993,7 +3996,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3997: checking for $ac_word" >&5
+echo "configure:4000: checking for $ac_word" >&5
 case "$PERL" in
@@ -4024,10 +4027,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:4028: checking for ANSI C header files" >&5
+echo "configure:4031: checking for ANSI C header files" >&5
-#line 4031 "configure"
+#line 4034 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -4035,7 +4038,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:4039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4052,7 +4055,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4056 "configure"
+#line 4059 "configure"
 #include <string.h>
 EOF
@@ -4070,7 +4073,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4074 "configure"
+#line 4077 "configure"
 #include <stdlib.h>
 EOF
@@ -4091,7 +4094,7 @@
 else
-#line 4095 "configure"
+#line 4098 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4102,7 +4105,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:4106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -4129,15 +4132,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4133: checking for $ac_hdr" >&5
+echo "configure:4136: checking for $ac_hdr" >&5
-#line 4136 "configure"
+#line 4139 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4144: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4166,15 +4169,15 @@
 do
-echo "configure:4170: checking for $ac_hdr" >&5
+echo "configure:4173: checking for $ac_hdr" >&5
-#line 4173 "configure"
+#line 4176 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4203,15 +4206,15 @@
 do
-echo "configure:4207: checking for $ac_hdr" >&5
+echo "configure:4210: checking for $ac_hdr" >&5
-#line 4210 "configure"
+#line 4213 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4240,15 +4243,15 @@
 do
-echo "configure:4244: checking for $ac_hdr" >&5
+echo "configure:4247: checking for $ac_hdr" >&5
-#line 4247 "configure"
+#line 4250 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4277,15 +4280,15 @@
 do
-echo "configure:4281: checking for $ac_hdr" >&5
+echo "configure:4284: checking for $ac_hdr" >&5
-#line 4284 "configure"
+#line 4287 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4292: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4311,10 +4314,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4315: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4318: checking whether time.h and sys/time.h may both be included" >&5
-#line 4318 "configure"
+#line 4321 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4323,7 +4326,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4327: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4343,10 +4346,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4347: checking for off_t" >&5
+echo "configure:4350: checking for off_t" >&5
-#line 4350 "configure"
+#line 4353 "configure"
 #if STDC_HEADERS
@@ -4373,10 +4376,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4377: checking for uid_t in sys/types.h" >&5
+echo "configure:4380: checking for uid_t in sys/types.h" >&5
-#line 4380 "configure"
+#line 4383 "configure"
 EOF
@@ -4404,10 +4407,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4408: checking return type of signal handlers" >&5
+echo "configure:4411: checking return type of signal handlers" >&5
-#line 4411 "configure"
+#line 4414 "configure"
 #include <signal.h>
@@ -4424,7 +4427,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4428: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4442,10 +4445,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4446: checking for Cygwin environment" >&5
+echo "configure:4449: checking for Cygwin environment" >&5
-#line 4449 "configure"
+#line 4452 "configure"
 int main() {
@@ -4456,7 +4459,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4460: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4463: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4474,10 +4477,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4478: checking for $ac_func" >&5
+echo "configure:4481: checking for $ac_func" >&5
-#line 4481 "configure"
+#line 4484 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4500,7 +4503,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4526,10 +4529,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4530: checking for $ac_func" >&5
+echo "configure:4533: checking for $ac_func" >&5
-#line 4533 "configure"
+#line 4536 "configure"
@@ -4552,7 +4555,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4578,10 +4581,10 @@
 for ac_func in drand48
 do
-echo "configure:4582: checking for $ac_func" >&5
+echo "configure:4585: checking for $ac_func" >&5
-#line 4585 "configure"
+#line 4588 "configure"
@@ -4604,7 +4607,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4630,10 +4633,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4634: checking for $ac_func" >&5
+echo "configure:4637: checking for $ac_func" >&5
-#line 4637 "configure"
+#line 4640 "configure"
@@ -4656,7 +4659,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4682,10 +4685,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4686: checking for $ac_func" >&5
+echo "configure:4689: checking for $ac_func" >&5
-#line 4689 "configure"
+#line 4692 "configure"
@@ -4708,7 +4711,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4733,13 +4736,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4737: checking whether setpgrp takes no argument" >&5
+echo "configure:4740: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4743 "configure"
+#line 4746 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4759,7 +4762,7 @@
 EOF
-if { (eval echo configure:4763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4787,16 +4790,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4791: checking for long long int" >&5
+echo "configure:4794: checking for long long int" >&5
-#line 4793 "configure"
+#line 4796 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4800: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 echo "$ac_t""yes" 1>&6
@@ -4816,7 +4819,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4820: checking for W11" >&5
+echo "configure:4823: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4844,7 +4847,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4848: checking for X" >&5
+echo "configure:4851: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4904,12 +4907,12 @@
   # First, try using that file with no special directory specified.
-#line 4908 "configure"
+#line 4911 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4913: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4978,14 +4981,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4982 "configure"
+#line 4985 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -5090,17 +5093,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5094: checking whether -R must be followed by a space" >&5
+echo "configure:5097: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5097 "configure"
+#line 5100 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -5116,14 +5119,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5120 "configure"
+#line 5123 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5155,13 +5158,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5159: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5162: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5165 "configure"
+#line 5168 "configure"
@@ -5172,7 +5175,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5193,13 +5196,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5197: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5200: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5203 "configure"
+#line 5206 "configure"
@@ -5210,7 +5213,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5238,10 +5241,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5242: checking for gethostbyname" >&5
+echo "configure:5245: checking for gethostbyname" >&5
-#line 5245 "configure"
+#line 5248 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5264,7 +5267,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5284,13 +5287,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5288: checking for gethostbyname in -lnsl" >&5
+echo "configure:5291: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5294 "configure"
+#line 5297 "configure"
@@ -5301,7 +5304,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5330,10 +5333,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5334: checking for connect" >&5
+echo "configure:5337: checking for connect" >&5
-#line 5337 "configure"
+#line 5340 "configure"
     which can conflict with char connect(); below.  */
@@ -5356,7 +5359,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5376,13 +5379,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5380: checking for connect in -lsocket" >&5
+echo "configure:5383: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5386 "configure"
+#line 5389 "configure"
@@ -5393,7 +5396,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5416,10 +5419,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5420: checking for remove" >&5
+echo "configure:5423: checking for remove" >&5
-#line 5423 "configure"
+#line 5426 "configure"
     which can conflict with char remove(); below.  */
@@ -5442,7 +5445,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5462,13 +5465,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5466: checking for remove in -lposix" >&5
+echo "configure:5469: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5472 "configure"
+#line 5475 "configure"
@@ -5479,7 +5482,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5502,10 +5505,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5506: checking for shmat" >&5
+echo "configure:5509: checking for shmat" >&5
-#line 5509 "configure"
+#line 5512 "configure"
     which can conflict with char shmat(); below.  */
@@ -5528,7 +5531,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5548,13 +5551,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5552: checking for shmat in -lipc" >&5
+echo "configure:5555: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5558 "configure"
+#line 5561 "configure"
@@ -5565,7 +5568,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5597,13 +5600,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5601: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5604: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5607 "configure"
+#line 5610 "configure"
@@ -5614,7 +5617,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5652,7 +5655,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5656: checking whether to use Curses" >&5
+echo "configure:5659: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5671,15 +5674,15 @@
 do
-echo "configure:5675: checking for $ac_hdr" >&5
+echo "configure:5678: checking for $ac_hdr" >&5
-#line 5678 "configure"
+#line 5681 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5683: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5710,10 +5713,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5714: checking curses.h WINDOW structure component" >&5
+echo "configure:5717: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5717 "configure"
+#line 5720 "configure"
 #include <curses.h>
@@ -5722,7 +5725,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5726: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5729: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5731,7 +5734,7 @@
 fi
 rm -f conftest*
-#line 5735 "configure"
+#line 5738 "configure"
 #include <curses.h>
@@ -5740,7 +5743,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5744: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5747: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5756,13 +5759,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5760: checking for initscr in -lncurses" >&5
+echo "configure:5763: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5766 "configure"
+#line 5769 "configure"
@@ -5773,7 +5776,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5792,13 +5795,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5796: checking for initscr in -lcurses" >&5
+echo "configure:5799: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5802 "configure"
+#line 5805 "configure"
@@ -5809,7 +5812,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5838,13 +5841,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5842: checking for keypad in -lncurses" >&5
+echo "configure:5845: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5848 "configure"
+#line 5851 "configure"
@@ -5855,7 +5858,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5877,13 +5880,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5881: checking for keypad in -lcurses" >&5
+echo "configure:5884: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5887 "configure"
+#line 5890 "configure"
@@ -5894,7 +5897,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5924,13 +5927,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5928: checking for gtty in -lcompat" >&5
+echo "configure:5931: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5934 "configure"
+#line 5937 "configure"
@@ -5941,7 +5944,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5960,13 +5963,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5964: checking for gtty in -lbsd-compat" >&5
+echo "configure:5967: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5970 "configure"
+#line 5973 "configure"
@@ -5977,7 +5980,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5996,13 +5999,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:6000: checking for gtty in -lbsd" >&5
+echo "configure:6003: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 6006 "configure"
+#line 6009 "configure"
@@ -6013,7 +6016,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:6017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6047,12 +6050,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6051: checking for library containing cuserid" >&5
+echo "configure:6054: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 6056 "configure"
+#line 6059 "configure"
@@ -6063,7 +6066,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -6074,7 +6077,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 6078 "configure"
+#line 6081 "configure"
@@ -6085,7 +6088,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -6111,10 +6114,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6115: checking for xdrmem_create" >&5
+echo "configure:6118: checking for xdrmem_create" >&5
-#line 6118 "configure"
+#line 6121 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -6137,7 +6140,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -6155,13 +6158,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6159: checking for xdrmem_create in -lsun" >&5
+echo "configure:6162: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 6165 "configure"
+#line 6168 "configure"
@@ -6172,7 +6175,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6191,13 +6194,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6195: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6198: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 6201 "configure"
+#line 6204 "configure"
@@ -6208,7 +6211,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6227,13 +6230,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6231: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6234: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6237 "configure"
+#line 6240 "configure"
@@ -6244,7 +6247,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6263,13 +6266,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6267: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6270: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6273 "configure"
+#line 6276 "configure"
@@ -6280,7 +6283,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6314,10 +6317,10 @@
 for ac_func in asprintf
 do
-echo "configure:6318: checking for $ac_func" >&5
+echo "configure:6321: checking for $ac_func" >&5
-#line 6321 "configure"
+#line 6324 "configure"
@@ -6340,7 +6343,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6367,10 +6370,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6371: checking for atan" >&5
+echo "configure:6374: checking for atan" >&5
-#line 6374 "configure"
+#line 6377 "configure"
     which can conflict with char atan(); below.  */
@@ -6393,7 +6396,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6411,13 +6414,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6415: checking for atan in -lm" >&5
+echo "configure:6418: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6421 "configure"
+#line 6424 "configure"
@@ -6428,7 +6431,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6455,10 +6458,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6459: checking for dlsym" >&5
+echo "configure:6462: checking for dlsym" >&5
-#line 6462 "configure"
+#line 6465 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6481,7 +6484,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6499,13 +6502,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6503: checking for dlsym in -ldl" >&5
+echo "configure:6506: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6509 "configure"
+#line 6512 "configure"
@@ -6516,7 +6519,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6543,10 +6546,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6547: checking for iconv" >&5
+echo "configure:6550: checking for iconv" >&5
-#line 6550 "configure"
+#line 6553 "configure"
     which can conflict with char iconv(); below.  */
@@ -6569,7 +6572,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6587,13 +6590,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6591: checking for iconv in -liconv" >&5
+echo "configure:6594: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6597 "configure"
+#line 6600 "configure"
@@ -6604,7 +6607,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6623,13 +6626,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6627: checking for iconv in -lgiconv" >&5
+echo "configure:6630: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6633 "configure"
+#line 6636 "configure"
@@ -6640,7 +6643,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6659,10 +6662,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6663: checking for libiconv" >&5
+echo "configure:6666: checking for libiconv" >&5
-#line 6666 "configure"
+#line 6669 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6685,7 +6688,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6703,13 +6706,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6707: checking for libiconv in -liconv" >&5
+echo "configure:6710: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6713 "configure"
+#line 6716 "configure"
@@ -6720,7 +6723,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6739,13 +6742,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6743: checking for libiconv in -lgiconv" >&5
+echo "configure:6746: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6749 "configure"
+#line 6752 "configure"
@@ -6756,7 +6759,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6793,10 +6796,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6797: checking for socket" >&5
+echo "configure:6800: checking for socket" >&5
-#line 6800 "configure"
+#line 6803 "configure"
     which can conflict with char socket(); below.  */
@@ -6819,7 +6822,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6837,13 +6840,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6841: checking for socket in -lsocket" >&5
+echo "configure:6844: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6847 "configure"
+#line 6850 "configure"
@@ -6854,7 +6857,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6902,7 +6905,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6906: checking for location of zlib includes" >&5
+echo "configure:6909: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6928,15 +6931,15 @@
 do
-echo "configure:6932: checking for $ac_hdr" >&5
+echo "configure:6935: checking for $ac_hdr" >&5
-#line 6935 "configure"
+#line 6938 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6943: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6970,7 +6973,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6974: checking for location of zlib library" >&5
+echo "configure:6977: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6995,13 +6998,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6999: checking for deflate in -lz" >&5
+echo "configure:7002: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 7005 "configure"
+#line 7008 "configure"
@@ -7012,7 +7015,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:7016: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7060,7 +7063,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7064: checking for location of External PROJ.4 includes" >&5
+echo "configure:7067: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7086,15 +7089,15 @@
 do
-echo "configure:7090: checking for $ac_hdr" >&5
+echo "configure:7093: checking for $ac_hdr" >&5
-#line 7093 "configure"
+#line 7096 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7131,7 +7134,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7135: checking External PROJ.4 version" >&5
+echo "configure:7138: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7139,7 +7142,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 7143 "configure"
+#line 7146 "configure"
 #include <stdio.h>
@@ -7151,7 +7154,7 @@
 EOF
-if { (eval echo configure:7155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -7176,7 +7179,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7180: checking for location of External PROJ.4 library" >&5
+echo "configure:7183: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7201,13 +7204,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7205: checking for pj_get_def in -lproj" >&5
+echo "configure:7208: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 7211 "configure"
+#line 7214 "configure"
@@ -7218,7 +7221,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7252,7 +7255,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7256: checking for location of External PROJ.4 data files" >&5
+echo "configure:7259: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7276,14 +7279,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7280: checking for epsg" >&5
+echo "configure:7283: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7287: checking for $PROJSHARE/epsg" >&5
+echo "configure:7290: checking for $PROJSHARE/epsg" >&5
@@ -7315,7 +7318,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:7319: checking for $ac_word" >&5
+echo "configure:7322: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7355,7 +7358,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7359: checking whether to use regex" >&5
+echo "configure:7362: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -7375,7 +7378,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7379: checking for location of regex includes" >&5
+echo "configure:7382: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7401,15 +7404,15 @@
 do
-echo "configure:7405: checking for $ac_hdr" >&5
+echo "configure:7408: checking for $ac_hdr" >&5
-#line 7408 "configure"
+#line 7411 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7416: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7443,7 +7446,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7447: checking for location of regex library" >&5
+echo "configure:7450: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7468,10 +7471,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7472: checking for regcomp" >&5
+echo "configure:7475: checking for regcomp" >&5
-#line 7475 "configure"
+#line 7478 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7494,7 +7497,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7521,13 +7524,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7525: checking for regcomp in -lregex" >&5
+echo "configure:7528: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7531 "configure"
+#line 7534 "configure"
@@ -7538,7 +7541,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7588,7 +7591,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7592: checking whether to use Readline" >&5
+echo "configure:7595: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7609,7 +7612,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7613: checking for location of Readline includes" >&5
+echo "configure:7616: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7635,15 +7638,15 @@
 do
-echo "configure:7639: checking for $ac_hdr" >&5
+echo "configure:7642: checking for $ac_hdr" >&5
-#line 7642 "configure"
+#line 7645 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7647: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7650: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7679,15 +7682,15 @@
 do
-echo "configure:7683: checking for $ac_hdr" >&5
+echo "configure:7686: checking for $ac_hdr" >&5
-#line 7686 "configure"
+#line 7689 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7691: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7721,7 +7724,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7725: checking for location of Readline library" >&5
+echo "configure:7728: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7746,13 +7749,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7750: checking for readline in -lreadline" >&5
+echo "configure:7753: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7756 "configure"
+#line 7759 "configure"
 #include "confdefs.h"
@@ -7763,7 +7766,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7798,13 +7801,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7802: checking for add_history in -lhistory" >&5
+echo "configure:7805: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7808 "configure"
+#line 7811 "configure"
@@ -7815,7 +7818,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7858,7 +7861,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7862: checking whether to use JPEG" >&5
+echo "configure:7865: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7878,7 +7881,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7882: checking for location of JPEG includes" >&5
+echo "configure:7885: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7904,15 +7907,15 @@
 do
-echo "configure:7908: checking for $ac_hdr" >&5
+echo "configure:7911: checking for $ac_hdr" >&5
-#line 7911 "configure"
+#line 7914 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7946,7 +7949,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7950: checking for location of JPEG library" >&5
+echo "configure:7953: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7973,13 +7976,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7977: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7980: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ljpeg  $LIBS"
-#line 7983 "configure"
+#line 7986 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7990,7 +7993,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -8009,13 +8012,13 @@
-echo "configure:8013: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:8016: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 8019 "configure"
+#line 8022 "configure"
@@ -8026,7 +8029,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8075,7 +8078,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:8079: checking whether to use GDAL" >&5
+echo "configure:8082: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -8093,7 +8096,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8097: checking for $ac_word" >&5
+echo "configure:8100: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -8148,14 +8151,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 8152 "configure"
+#line 8155 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:8159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -8164,14 +8167,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 8168 "configure"
+#line 8171 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:8175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -8203,7 +8206,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:8207: checking whether to use GEOS" >&5
+echo "configure:8210: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -8221,7 +8224,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:8225: checking for $ac_word" >&5
+echo "configure:8228: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -8269,15 +8272,15 @@
 do
-echo "configure:8273: checking for $ac_hdr" >&5
+echo "configure:8276: checking for $ac_hdr" >&5
-#line 8276 "configure"
+#line 8279 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8313,13 +8316,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:8317: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:8320: checking for initGEOS in -lgeos_c_i" >&5
 ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c_i  $LIBS"
-#line 8323 "configure"
+#line 8326 "configure"
@@ -8330,7 +8333,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8366,13 +8369,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8370: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8373: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 8376 "configure"
+#line 8379 "configure"
@@ -8383,7 +8386,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8427,7 +8430,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8431: checking whether to use TIFF" >&5
+echo "configure:8434: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8447,7 +8450,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8451: checking for location of TIFF includes" >&5
+echo "configure:8454: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8473,15 +8476,15 @@
 do
-echo "configure:8477: checking for $ac_hdr" >&5
+echo "configure:8480: checking for $ac_hdr" >&5
-#line 8480 "configure"
+#line 8483 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8485: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8515,7 +8518,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8519: checking for location of TIFF library" >&5
+echo "configure:8522: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8546,13 +8549,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8550: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8553: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8556 "configure"
+#line 8559 "configure"
@@ -8563,7 +8566,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8582,13 +8585,13 @@
-echo "configure:8586: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8589: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8592 "configure"
+#line 8595 "configure"
@@ -8599,7 +8602,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8618,13 +8621,13 @@
-echo "configure:8622: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8625: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8628 "configure"
+#line 8631 "configure"
@@ -8635,7 +8638,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8654,13 +8657,13 @@
-echo "configure:8658: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8661: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8664 "configure"
+#line 8667 "configure"
@@ -8671,7 +8674,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8690,13 +8693,13 @@
-echo "configure:8694: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8697: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8700 "configure"
+#line 8703 "configure"
@@ -8707,7 +8710,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8726,13 +8729,13 @@
-echo "configure:8730: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8733: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8736 "configure"
+#line 8739 "configure"
@@ -8743,7 +8746,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8762,13 +8765,13 @@
-echo "configure:8766: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8769: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8772 "configure"
+#line 8775 "configure"
@@ -8779,7 +8782,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8798,13 +8801,13 @@
-echo "configure:8802: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8805: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8808 "configure"
+#line 8811 "configure"
@@ -8815,7 +8818,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8913,7 +8916,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8917: checking whether to use PNG" >&5
+echo "configure:8920: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8932,7 +8935,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8936: checking for location of PNG includes" >&5
+echo "configure:8939: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8958,15 +8961,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8962: checking for $ac_hdr" >&5
+echo "configure:8965: checking for $ac_hdr" >&5
-#line 8965 "configure"
+#line 8968 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8973: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9000,7 +9003,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:9004: checking for location of PNG library" >&5
+echo "configure:9007: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -9025,13 +9028,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:9029: checking for png_read_image in -lpng" >&5
+echo "configure:9032: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 9035 "configure"
+#line 9038 "configure"
@@ -9042,7 +9045,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:9046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9084,7 +9087,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9088: checking whether to use PostgreSQL" >&5
+echo "configure:9091: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9111,7 +9114,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9115: checking for location of PostgreSQL includes" >&5
+echo "configure:9118: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9137,15 +9140,15 @@
 do
-echo "configure:9141: checking for $ac_hdr" >&5
+echo "configure:9144: checking for $ac_hdr" >&5
-#line 9144 "configure"
+#line 9147 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9183,7 +9186,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9187: checking for location of PostgreSQL library" >&5
+echo "configure:9190: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9212,13 +9215,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9216: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9219: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9222 "configure"
+#line 9225 "configure"
@@ -9229,7 +9232,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9248,13 +9251,13 @@
-echo "configure:9252: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9255: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9258 "configure"
+#line 9261 "configure"
@@ -9265,7 +9268,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9284,13 +9287,13 @@
-echo "configure:9288: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9291: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9294 "configure"
+#line 9297 "configure"
@@ -9301,7 +9304,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9320,13 +9323,13 @@
-echo "configure:9324: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9327: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9330 "configure"
+#line 9333 "configure"
@@ -9337,7 +9340,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9394,13 +9397,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9398: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9401: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9404 "configure"
+#line 9407 "configure"
@@ -9411,7 +9414,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9433,13 +9436,13 @@
-echo "configure:9437: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9440: checking for PQcmdTuples in -lpq" >&5
-#line 9443 "configure"
+#line 9446 "configure"
@@ -9450,7 +9453,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9493,7 +9496,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9497: checking whether to use MySQL" >&5
+echo "configure:9500: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9513,7 +9516,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9517: checking for location of MySQL includes" >&5
+echo "configure:9520: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9539,15 +9542,15 @@
 do
-echo "configure:9543: checking for $ac_hdr" >&5
+echo "configure:9546: checking for $ac_hdr" >&5
-#line 9546 "configure"
+#line 9549 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9551: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9584,7 +9587,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9588: checking for location of MySQL library" >&5
+echo "configure:9591: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9615,13 +9618,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9619: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9622: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9625 "configure"
+#line 9628 "configure"
@@ -9632,7 +9635,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9651,13 +9654,13 @@
-echo "configure:9655: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9658: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9661 "configure"
+#line 9664 "configure"
@@ -9668,7 +9671,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9687,13 +9690,13 @@
-echo "configure:9691: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9694: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9697 "configure"
+#line 9700 "configure"
@@ -9704,7 +9707,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9723,13 +9726,13 @@
-echo "configure:9727: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9730: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9733 "configure"
+#line 9736 "configure"
@@ -9740,7 +9743,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9759,13 +9762,13 @@
-echo "configure:9763: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9766: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9769 "configure"
+#line 9772 "configure"
@@ -9776,7 +9779,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9795,13 +9798,13 @@
-echo "configure:9799: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9802: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9805 "configure"
+#line 9808 "configure"
@@ -9812,7 +9815,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9831,13 +9834,13 @@
-echo "configure:9835: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9838: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9841 "configure"
+#line 9844 "configure"
@@ -9848,7 +9851,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9867,13 +9870,13 @@
-echo "configure:9871: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9874: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9877 "configure"
+#line 9880 "configure"
@@ -9884,7 +9887,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9974,7 +9977,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9978: checking for $ac_word" >&5
+echo "configure:9981: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10015,10 +10018,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10019: checking for mysql_server_init" >&5
+echo "configure:10022: checking for mysql_server_init" >&5
-#line 10022 "configure"
+#line 10025 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10041,7 +10044,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10079,7 +10082,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10083: checking whether to use SQLite" >&5
+echo "configure:10086: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10099,7 +10102,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10103: checking for location of SQLite includes" >&5
+echo "configure:10106: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10125,15 +10128,15 @@
 do
-echo "configure:10129: checking for $ac_hdr" >&5
+echo "configure:10132: checking for $ac_hdr" >&5
-#line 10132 "configure"
+#line 10135 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10137: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10140: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10176,7 +10179,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10180: checking for location of SQLite library" >&5
+echo "configure:10183: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10205,13 +10208,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10209: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10212: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10215 "configure"
+#line 10218 "configure"
@@ -10222,7 +10225,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10241,13 +10244,13 @@
-echo "configure:10245: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10248: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 10251 "configure"
+#line 10254 "configure"
@@ -10258,7 +10261,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10277,13 +10280,13 @@
-echo "configure:10281: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10284: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10287 "configure"
+#line 10290 "configure"
@@ -10294,7 +10297,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10313,13 +10316,13 @@
-echo "configure:10317: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10320: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10323 "configure"
+#line 10326 "configure"
@@ -10330,7 +10333,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10399,7 +10402,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10403: checking whether to use FFMPEG" >&5
+echo "configure:10406: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10419,7 +10422,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10423: checking for location of FFMPEG includes" >&5
+echo "configure:10426: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10445,15 +10448,15 @@
 do
-echo "configure:10449: checking for $ac_hdr" >&5
+echo "configure:10452: checking for $ac_hdr" >&5
-#line 10452 "configure"
+#line 10455 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10457: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10489,15 +10492,15 @@
 do
-echo "configure:10493: checking for $ac_hdr" >&5
+echo "configure:10496: checking for $ac_hdr" >&5
-#line 10496 "configure"
+#line 10499 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10501: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10533,15 +10536,15 @@
 do
-echo "configure:10537: checking for $ac_hdr" >&5
+echo "configure:10540: checking for $ac_hdr" >&5
-#line 10540 "configure"
+#line 10543 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10545: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10584,7 +10587,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10588: checking for location of FFMPEG library" >&5
+echo "configure:10591: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10611,13 +10614,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10615: checking for av_free in -lavutil" >&5
+echo "configure:10618: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10621 "configure"
+#line 10624 "configure"
@@ -10628,7 +10631,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10647,13 +10650,13 @@
-echo "configure:10651: checking for av_free in -lavutil" >&5
+echo "configure:10654: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10657 "configure"
+#line 10660 "configure"
@@ -10664,7 +10667,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10709,13 +10712,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10713: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10716: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10719 "configure"
+#line 10722 "configure"
@@ -10726,7 +10729,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10745,13 +10748,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10749: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10752: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10755 "configure"
+#line 10758 "configure"
@@ -10762,7 +10765,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10807,13 +10810,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10811: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10814: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10817 "configure"
+#line 10820 "configure"
@@ -10824,7 +10827,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10843,13 +10846,13 @@
-echo "configure:10847: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10850: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10853 "configure"
+#line 10856 "configure"
@@ -10860,7 +10863,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10919,7 +10922,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10923: checking whether to use OpenGL" >&5
+echo "configure:10926: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10953,7 +10956,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10957: checking for location of OpenGL includes" >&5
+echo "configure:10960: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10979,15 +10982,15 @@
 do
-echo "configure:10983: checking for $ac_hdr" >&5
+echo "configure:10986: checking for $ac_hdr" >&5
-#line 10986 "configure"
+#line 10989 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10991: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10994: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11021,7 +11024,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11025: checking for location of OpenGL library" >&5
+echo "configure:11028: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11050,13 +11053,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11054: checking for glBegin in -lGL" >&5
+echo "configure:11057: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11060 "configure"
+#line 11063 "configure"
@@ -11067,7 +11070,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11086,13 +11089,13 @@
-echo "configure:11090: checking for glBegin in -lGL" >&5
+echo "configure:11093: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11096 "configure"
+#line 11099 "configure"
@@ -11103,7 +11106,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11122,13 +11125,13 @@
-echo "configure:11126: checking for glBegin in -lGL" >&5
+echo "configure:11129: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11132 "configure"
+#line 11135 "configure"
@@ -11139,7 +11142,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11158,13 +11161,13 @@
-echo "configure:11162: checking for glBegin in -lGL" >&5
+echo "configure:11165: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11168 "configure"
+#line 11171 "configure"
@@ -11175,7 +11178,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11237,13 +11240,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11241: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11244: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11247 "configure"
+#line 11250 "configure"
@@ -11254,7 +11257,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11273,13 +11276,13 @@
-echo "configure:11277: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11280: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11283 "configure"
+#line 11286 "configure"
@@ -11290,7 +11293,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11334,10 +11337,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11338: checking for glXCreatePbuffer" >&5
+echo "configure:11341: checking for glXCreatePbuffer" >&5
-#line 11341 "configure"
+#line 11344 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11360,7 +11363,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11382,10 +11385,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11386: checking for glXCreateGLXPixmap" >&5
+echo "configure:11389: checking for glXCreateGLXPixmap" >&5
-#line 11389 "configure"
+#line 11392 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11408,7 +11411,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11447,7 +11450,7 @@
-echo "configure:11451: checking for location of OpenGL includes" >&5
+echo "configure:11454: checking for location of OpenGL includes" >&5
@@ -11473,15 +11476,15 @@
 do
-echo "configure:11477: checking for $ac_hdr" >&5
+echo "configure:11480: checking for $ac_hdr" >&5
-#line 11480 "configure"
+#line 11483 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11485: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11516,10 +11519,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11520: checking for glBegin" >&5
+echo "configure:11523: checking for glBegin" >&5
-#line 11523 "configure"
+#line 11526 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11542,7 +11545,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11557,10 +11560,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11561: checking for gluBeginCurve" >&5
+echo "configure:11564: checking for gluBeginCurve" >&5
-#line 11564 "configure"
+#line 11567 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11583,7 +11586,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11627,7 +11630,7 @@
-echo "configure:11631: checking for location of OpenGL includes" >&5
+echo "configure:11634: checking for location of OpenGL includes" >&5
@@ -11653,15 +11656,15 @@
 do
-echo "configure:11657: checking for $ac_hdr" >&5
+echo "configure:11660: checking for $ac_hdr" >&5
-#line 11660 "configure"
+#line 11663 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11665: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11695,7 +11698,7 @@
-echo "configure:11699: checking for location of OpenGL library" >&5
+echo "configure:11702: checking for location of OpenGL library" >&5
@@ -11720,18 +11723,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11724: checking for OpenGL library" >&5
+echo "configure:11727: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11728 "configure"
+#line 11731 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11755,18 +11758,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11759: checking for GLU library" >&5
+echo "configure:11762: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11763 "configure"
+#line 11766 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11815,7 +11818,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11819: checking whether to use Tcl/Tk" >&5
+echo "configure:11822: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11835,7 +11838,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11839: checking for location of Tcl/Tk includes" >&5
+echo "configure:11842: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11861,15 +11864,15 @@
 do
-echo "configure:11865: checking for $ac_hdr" >&5
+echo "configure:11868: checking for $ac_hdr" >&5
-#line 11868 "configure"
+#line 11871 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11906,15 +11909,15 @@
 do
-echo "configure:11910: checking for $ac_hdr" >&5
+echo "configure:11913: checking for $ac_hdr" >&5
-#line 11913 "configure"
+#line 11916 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11918: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11921: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11947,7 +11950,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11951: checking Tcl version" >&5
+echo "configure:11954: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11955,7 +11958,7 @@
 else
-#line 11959 "configure"
+#line 11962 "configure"
 #include <stdio.h>
@@ -11967,7 +11970,7 @@
 EOF
-if { (eval echo configure:11971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11985,7 +11988,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11989: checking Tk version" >&5
+echo "configure:11992: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11993,7 +11996,7 @@
 else
-#line 11997 "configure"
+#line 12000 "configure"
 #include <stdio.h>
@@ -12005,7 +12008,7 @@
 EOF
-if { (eval echo configure:12009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:12012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -12036,7 +12039,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:12040: checking for location of Tcl/Tk library" >&5
+echo "configure:12043: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -12076,13 +12079,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:12080: checking for Tcl_Init in -ltcl" >&5
+echo "configure:12083: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 12086 "configure"
+#line 12089 "configure"
@@ -12093,7 +12096,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12112,13 +12115,13 @@
-echo "configure:12116: checking for Tcl_Init in -ltcl" >&5
+echo "configure:12119: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 12122 "configure"
+#line 12125 "configure"
@@ -12129,7 +12132,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12156,13 +12159,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12160: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12163: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 12166 "configure"
+#line 12169 "configure"
@@ -12173,7 +12176,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12192,13 +12195,13 @@
-echo "configure:12196: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12199: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12202 "configure"
+#line 12205 "configure"
@@ -12209,7 +12212,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12236,13 +12239,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12240: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12243: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12246 "configure"
+#line 12249 "configure"
@@ -12253,7 +12256,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12272,13 +12275,13 @@
-echo "configure:12276: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12279: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12282 "configure"
+#line 12285 "configure"
@@ -12289,7 +12292,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12367,13 +12370,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12371: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12374: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12377 "configure"
+#line 12380 "configure"
@@ -12384,7 +12387,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12403,13 +12406,13 @@
-echo "configure:12407: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12410: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12413 "configure"
+#line 12416 "configure"
@@ -12420,7 +12423,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12447,13 +12450,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12451: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12454: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12457 "configure"
+#line 12460 "configure"
@@ -12464,7 +12467,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12483,13 +12486,13 @@
-echo "configure:12487: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12490: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12493 "configure"
+#line 12496 "configure"
@@ -12500,7 +12503,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12527,13 +12530,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12531: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12534: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12537 "configure"
+#line 12540 "configure"
@@ -12544,7 +12547,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12563,13 +12566,13 @@
-echo "configure:12567: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12570: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12573 "configure"
+#line 12576 "configure"
@@ -12580,7 +12583,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12670,13 +12673,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12674: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12677: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12680 "configure"
+#line 12683 "configure"
@@ -12687,7 +12690,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12736,7 +12739,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12740: checking whether to use ODBC" >&5
+echo "configure:12743: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12755,7 +12758,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12759: checking for location of ODBC includes" >&5
+echo "configure:12762: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12781,15 +12784,15 @@
 do
-echo "configure:12785: checking for $ac_hdr" >&5
+echo "configure:12788: checking for $ac_hdr" >&5
-#line 12788 "configure"
+#line 12791 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12793: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12796: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12823,7 +12826,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12827: checking for location of ODBC library" >&5
+echo "configure:12830: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12848,13 +12851,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12852: checking for SQLConnect in -lodbc" >&5
+echo "configure:12855: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12858 "configure"
+#line 12861 "configure"
 #include "confdefs.h"
@@ -12865,7 +12868,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12890,13 +12893,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12894: checking for SQLConnect in -liodbc" >&5
+echo "configure:12897: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12900 "configure"
+#line 12903 "configure"
@@ -12907,7 +12910,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12932,11 +12935,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12936: checking for ODBC library" >&5
+echo "configure:12939: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12940 "configure"
+#line 12943 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12944,7 +12947,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12993,7 +12996,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12997: checking whether to use FFTW" >&5
+echo "configure:13000: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -13012,7 +13015,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:13016: checking for location of FFTW includes" >&5
+echo "configure:13019: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -13038,15 +13041,15 @@
 do
-echo "configure:13042: checking for $ac_hdr" >&5
+echo "configure:13045: checking for $ac_hdr" >&5
-#line 13045 "configure"
+#line 13048 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13053: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13074,15 +13077,15 @@
 do
-echo "configure:13078: checking for $ac_hdr" >&5
+echo "configure:13081: checking for $ac_hdr" >&5
-#line 13081 "configure"
+#line 13084 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13086: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13089: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13110,15 +13113,15 @@
 do
-echo "configure:13114: checking for $ac_hdr" >&5
+echo "configure:13117: checking for $ac_hdr" >&5
-#line 13117 "configure"
+#line 13120 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13122: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13125: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13164,7 +13167,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:13168: checking for location of FFTW library" >&5
+echo "configure:13171: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13189,13 +13192,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13193: checking for fftw_execute in -lfftw3" >&5
+echo "configure:13196: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13199 "configure"
+#line 13202 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13206,7 +13209,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:13210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13231,13 +13234,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13235: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13238: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 13241 "configure"
+#line 13244 "configure"
@@ -13248,7 +13251,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13273,13 +13276,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13277: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13280: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13283 "configure"
+#line 13286 "configure"
@@ -13290,7 +13293,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13347,7 +13350,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13351: checking whether to use BLAS" >&5
+echo "configure:13354: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -13368,7 +13371,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13372: checking for location of BLAS includes" >&5
+echo "configure:13375: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13388,7 +13391,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13392: checking for location of BLAS library" >&5
+echo "configure:13395: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13414,15 +13417,15 @@
 do
-echo "configure:13418: checking for $ac_hdr" >&5
+echo "configure:13421: checking for $ac_hdr" >&5
-#line 13421 "configure"
+#line 13424 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13457,13 +13460,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13461: checking for dnrm2_ in -lblas" >&5
+echo "configure:13464: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 13467 "configure"
+#line 13470 "configure"
@@ -13474,7 +13477,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13493,13 +13496,13 @@
-echo "configure:13497: checking for dnrm2_ in -lblas" >&5
+echo "configure:13500: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13503 "configure"
+#line 13506 "configure"
@@ -13510,7 +13513,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13554,13 +13557,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13558: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13561: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13564 "configure"
+#line 13567 "configure"
@@ -13571,7 +13574,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13586,13 +13589,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13590: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13593: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13596 "configure"
+#line 13599 "configure"
@@ -13603,7 +13606,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13618,13 +13621,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13622: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13625: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13628 "configure"
+#line 13631 "configure"
@@ -13635,7 +13638,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13681,16 +13684,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13685: checking for sgemm in $vlib_flags" >&5
+echo "configure:13688: checking for sgemm in $vlib_flags" >&5
-#line 13687 "configure"
+#line 13690 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13708,13 +13711,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13712: checking for sgemm_ in -lblas" >&5
+echo "configure:13715: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13718 "configure"
+#line 13721 "configure"
@@ -13725,7 +13728,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13740,13 +13743,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13744: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13747: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13750 "configure"
+#line 13753 "configure"
@@ -13757,7 +13760,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13772,13 +13775,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13776: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13779: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13782 "configure"
+#line 13785 "configure"
@@ -13789,7 +13792,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13823,13 +13826,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13827: checking for acosp in -lsunmath" >&5
+echo "configure:13830: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13833 "configure"
+#line 13836 "configure"
@@ -13840,7 +13843,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13855,13 +13858,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13859: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13862: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13865 "configure"
+#line 13868 "configure"
@@ -13872,7 +13875,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13902,13 +13905,13 @@
 # Generic BLAS library
-echo "configure:13906: checking for sgemm_ in -lblas" >&5
+echo "configure:13909: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13912 "configure"
+#line 13915 "configure"
@@ -13919,7 +13922,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13958,7 +13961,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13962: checking whether to use LAPACK" >&5
+echo "configure:13965: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13983,7 +13986,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13987: checking for location of LAPACK includes" >&5
+echo "configure:13990: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -14003,7 +14006,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:14007: checking for location of LAPACK library" >&5
+echo "configure:14010: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -14029,15 +14032,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14033: checking for $ac_hdr" >&5
+echo "configure:14036: checking for $ac_hdr" >&5
-#line 14036 "configure"
+#line 14039 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14041: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14044: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14069,10 +14072,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:14073: checking for dsegv_" >&5
+echo "configure:14076: checking for dsegv_" >&5
-#line 14076 "configure"
+#line 14079 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -14095,7 +14098,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -14122,13 +14125,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14126: checking for desgv_ in -llapack" >&5
+echo "configure:14129: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 14132 "configure"
+#line 14135 "configure"
@@ -14139,7 +14142,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:14143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14171,13 +14174,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14175: checking for dgesv_ in -llapack" >&5
+echo "configure:14178: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 14181 "configure"
+#line 14184 "configure"
@@ -14188,7 +14191,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:14192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14207,13 +14210,13 @@
-echo "configure:14211: checking for dgesv_ in -llapack" >&5
+echo "configure:14214: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14217 "configure"
+#line 14220 "configure"
@@ -14224,7 +14227,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:14228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14280,7 +14283,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14284: checking whether to use Motif" >&5
+echo "configure:14287: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -14299,7 +14302,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14303: checking for location of Motif includes" >&5
+echo "configure:14306: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14325,15 +14328,15 @@
 do
-echo "configure:14329: checking for $ac_hdr" >&5
+echo "configure:14332: checking for $ac_hdr" >&5
-#line 14332 "configure"
+#line 14335 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14337: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14367,7 +14370,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14371: checking for location of Motif library" >&5
+echo "configure:14374: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14392,13 +14395,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14396: checking for XmStringCreate in -lXm" >&5
+echo "configure:14399: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 14402 "configure"
+#line 14405 "configure"
@@ -14409,7 +14412,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:14413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14450,7 +14453,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14454: checking whether to use Cairo" >&5
+echo "configure:14457: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -14482,7 +14485,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14486: checking for location of cairo includes" >&5
+echo "configure:14489: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14508,15 +14511,15 @@
 do
-echo "configure:14512: checking for $ac_hdr" >&5
+echo "configure:14515: checking for $ac_hdr" >&5
-#line 14515 "configure"
+#line 14518 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14520: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14552,7 +14555,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14556: checking for location of cairo library" >&5
+echo "configure:14559: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14572,7 +14575,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14576: checking for cairo linking flags" >&5
+echo "configure:14579: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14588,10 +14591,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14592: checking for cairo_create" >&5
+echo "configure:14595: checking for cairo_create" >&5
-#line 14595 "configure"
+#line 14598 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14614,7 +14617,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14648,10 +14651,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14652: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14655: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14655 "configure"
+#line 14658 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14674,7 +14677,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14707,10 +14710,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14711: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14714: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14714 "configure"
+#line 14717 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -14733,7 +14736,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -14775,7 +14778,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14779: checking whether to use GLw" >&5
+echo "configure:14782: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14794,7 +14797,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14798: checking for location of GLw includes" >&5
+echo "configure:14801: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14820,15 +14823,15 @@
 do
-echo "configure:14824: checking for $ac_hdr" >&5
+echo "configure:14827: checking for $ac_hdr" >&5
-#line 14827 "configure"
+#line 14830 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14832: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14835: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14856,15 +14859,15 @@
 do
-echo "configure:14860: checking for $ac_hdr" >&5
+echo "configure:14863: checking for $ac_hdr" >&5
-#line 14863 "configure"
+#line 14866 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14868: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14871: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14904,7 +14907,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14908: checking for location of GLw library" >&5
+echo "configure:14911: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14929,13 +14932,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14933: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14936: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14939 "configure"
+#line 14942 "configure"
@@ -14946,7 +14949,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14971,13 +14974,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14975: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14978: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14981 "configure"
+#line 14984 "configure"
@@ -14988,7 +14991,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15013,13 +15016,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:15017: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:15020: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15023 "configure"
+#line 15026 "configure"
@@ -15030,7 +15033,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:15034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15055,13 +15058,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15059: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:15062: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15065 "configure"
+#line 15068 "configure"
@@ -15072,7 +15075,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15097,13 +15100,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15101: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:15104: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 15107 "configure"
+#line 15110 "configure"
@@ -15114,7 +15117,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15139,13 +15142,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15143: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:15146: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15149 "configure"
+#line 15152 "configure"
@@ -15156,7 +15159,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15183,13 +15186,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:15187: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15190: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15193 "configure"
+#line 15196 "configure"
@@ -15200,7 +15203,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15219,13 +15222,13 @@
-echo "configure:15223: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15226: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15229 "configure"
+#line 15232 "configure"
@@ -15236,7 +15239,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15263,13 +15266,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15267: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15270: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15273 "configure"
+#line 15276 "configure"
@@ -15280,7 +15283,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15299,13 +15302,13 @@
-echo "configure:15303: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15306: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15309 "configure"
+#line 15312 "configure"
@@ -15316,7 +15319,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15429,7 +15432,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15433: checking whether to use FreeType" >&5
+echo "configure:15436: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -15448,7 +15451,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15452: checking for location of FreeType includes" >&5
+echo "configure:15455: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15474,15 +15477,15 @@
 do
-echo "configure:15478: checking for $ac_hdr" >&5
+echo "configure:15481: checking for $ac_hdr" >&5
-#line 15481 "configure"
+#line 15484 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15516,7 +15519,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15520: checking for location of FreeType library" >&5
+echo "configure:15523: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15541,13 +15544,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15545: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15548: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15551 "configure"
+#line 15554 "configure"
@@ -15558,7 +15561,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15599,7 +15602,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15603: checking whether to use NLS" >&5
+echo "configure:15606: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15619,10 +15622,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15623: checking for gettext" >&5
+echo "configure:15626: checking for gettext" >&5
-#line 15626 "configure"
+#line 15629 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15645,7 +15648,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15663,13 +15666,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15667: checking for gettext in -lintl" >&5
+echo "configure:15670: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15673 "configure"
+#line 15676 "configure"
@@ -15680,7 +15683,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15715,7 +15718,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15719: checking whether to use C++" >&5
+echo "configure:15722: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15731,7 +15734,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15735: checking for $ac_word" >&5
+echo "configure:15738: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15760,7 +15763,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15764: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15767: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15771,12 +15774,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15775 "configure"
+#line 15778 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15802,19 +15805,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15806: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15809: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15811: checking whether we are using GNU C++" >&5
+echo "configure:15814: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15818: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15821: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15832,7 +15835,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15836: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15839: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15873,7 +15876,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15877: checking whether to use openDWG" >&5
+echo "configure:15880: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15893,7 +15896,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15897: checking for location of openDGW includes" >&5
+echo "configure:15900: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15919,15 +15922,15 @@
 do
-echo "configure:15923: checking for $ac_hdr" >&5
+echo "configure:15926: checking for $ac_hdr" >&5
-#line 15926 "configure"
+#line 15929 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15931: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15934: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15961,7 +15964,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15965: checking for location of openDWG library" >&5
+echo "configure:15968: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -16008,7 +16011,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:16012: checking for special C compiler options needed for large files" >&5
+echo "configure:16015: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -16016,7 +16019,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 16020 "configure"
+#line 16023 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -16032,7 +16035,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16036: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -16041,7 +16044,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 16045 "configure"
+#line 16048 "configure"
@@ -16057,7 +16060,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16061: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16064: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -16077,11 +16080,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:16081: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:16084: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 16085 "configure"
+#line 16088 "configure"
@@ -16097,14 +16100,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16101: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16104: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 16108 "configure"
+#line 16111 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -16122,7 +16125,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16126: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16129: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -16141,11 +16144,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:16145: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:16148: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 16149 "configure"
+#line 16152 "configure"
@@ -16161,14 +16164,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16165: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16168: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16172 "configure"
+#line 16175 "configure"
 #define _LARGE_FILES 1
@@ -16186,7 +16189,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:16190: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16193: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -16205,25 +16208,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16209: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16212: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 16213 "configure"
+#line 16216 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16220: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16223: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 16227 "configure"
+#line 16230 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -16232,7 +16235,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:16236: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16239: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -16253,10 +16256,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16257: checking if system supports Large Files at all" >&5
+echo "configure:16260: checking if system supports Large Files at all" >&5
-#line 16260 "configure"
+#line 16263 "configure"
 #include <stdio.h>
@@ -16288,7 +16291,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:16292: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16295: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -16317,7 +16320,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16321: checking whether to use Python" >&5
+echo "configure:16324: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -16337,7 +16340,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:16341: checking for $ac_word" >&5
+echo "configure:16344: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -16379,15 +16382,15 @@
 do
-echo "configure:16383: checking for $ac_hdr" >&5
+echo "configure:16386: checking for $ac_hdr" >&5
-#line 16386 "configure"
+#line 16389 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16457,7 +16460,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16461: checking whether to use wxWidgets" >&5
+echo "configure:16464: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16478,7 +16481,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16482: checking for $ac_word" >&5
+echo "configure:16485: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16526,7 +16529,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16530: checking wxWidgets version" >&5
+echo "configure:16533: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16549,15 +16552,15 @@
 do
-echo "configure:16553: checking for $ac_hdr" >&5
+echo "configure:16556: checking for $ac_hdr" >&5
-#line 16556 "configure"
+#line 16559 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16561: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16564: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in	2012-02-05 11:38:00 UTC (rev 50661)
+++ grass/branches/develbranch_6/configure.in	2012-02-05 11:40:47 UTC (rev 50662)
@@ -128,6 +128,9 @@
 AC_PATH_PROG(SVN_VERSION, svnversion, no)
 if test "$SVN_VERSION" != "no" ; then
    GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
+   if test "$GRASS_VERSION_SVN" = "exported" ; then
+      GRASS_VERSION_SVN=
+   fi
 fi
 AC_SUBST(GRASS_VERSION_FILE)
