[GRASS-SVN] r50672 - in grass/trunk/doc: . gui gui/wxpython gui/wxpython/example
Sun Feb 5 14:21:42 EST 2012
Author: annakrat
Date: 2012-02-05 11:21:42 -0800 (Sun, 05 Feb 2012)
New Revision: 50672
Added:
   grass/trunk/doc/gui/
   grass/trunk/doc/gui/wxpython/
   grass/trunk/doc/gui/wxpython/example/
   grass/trunk/doc/gui/wxpython/example/README
   grass/trunk/doc/gui/wxpython/example/dialogs.py
   grass/trunk/doc/gui/wxpython/example/frame.py
   grass/trunk/doc/gui/wxpython/example/toolbars.py
   grass/trunk/doc/gui/wxpython/example/wxGUI.Example.html
wxGUI: example module added
Added: grass/trunk/doc/gui/wxpython/example/README
--- grass/trunk/doc/gui/wxpython/example/README	                        (rev 0)
+++ grass/trunk/doc/gui/wxpython/example/README	2012-02-05 19:21:42 UTC (rev 50672)
@@ -0,0 +1,73 @@
+Motivation
+Example Tool should help new GRASS GUI programmers who are interested in
+adding or improving GRASS GIS functionality or writing GRASS GIS GUI-based
+application for their own purposes.
+How to use Example Tool
+Example Tool is a simple template for applications which are
+supposed to display maps and make computations using GRASS modules.
+It covers several often occurring tasks. It can be helpful for all
+new developers who are interested in wxGUI programming.
+Run Example Tool, have a look at wxGUI.Example.html and than
+look at the source code to see how it works.
+Run Example Tool
+To run Example Tool can run as a standalone application (in GRASS environment)
+or it can be launched from Layer Manager menu.
+1. Go to GRASS root directory
+2. Copy directory ./doc/gui/wxpython/example to ./gui/wxpython/example
+3. Move file ./gui/wxpython/example/wxGUI.Example.html to ./gui/wxpython/docs/
+4. Edit ./gui/wxpython/Makefile:
+ SRCFILES := $(wildcard icons/*.* scripts/* xml/*) \
+-	$(wildcard core/* dbmgr/* gcp/* gmodeler/* ... \
++	$(wildcard core/* dbmgr/* example/* gcp/* gmodeler/* ... \
+-PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,core dbmgr gcp gmodeler ... \
++PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,core dbmgr example gcp gmodeler ... \
+5. Run make (in ./gui/wxpython)
+6. Now you should be able to run Example Tool as a standalone
+application in GRASS environment. Start GRASS GIS and start application:
+    > python ./gui/wxpython/example/frame.py
+If you want to access Example Tool from Layer Manager menu, there are
+a few more things to be done.
+7. Edit ./gui/wxpython/xml/menudata.xml. Add following code to appropriate place:
+    <menuitem>
+      <label>Example</label>
+      <help>Example help (for statusbar)</help>
+      <keywords>raster</keywords>
+      <handler>OnExample</handler>
+    </menuitem>
+8. Add folowing event handler to class GMFrame in ./gui/wxpython/lmgr/frame.py:
+    def OnExample(self, event):
+        """!Launch ExampleTool"""
+        win = ExampleMapFrame(parent = self)
+        win.CentreOnScreen()
+        win.Show()
+and don't forget to insert following line at the beginning of the file:
+    from example.frame import ExampleMapFrame
+9. Run make again.
+Note
+Feel free to improve Example Tool or suggest possible improvements.
Added: grass/trunk/doc/gui/wxpython/example/dialogs.py
--- grass/trunk/doc/gui/wxpython/example/dialogs.py	                        (rev 0)
+++ grass/trunk/doc/gui/wxpython/example/dialogs.py	2012-02-05 19:21:42 UTC (rev 50672)
@@ -0,0 +1,58 @@
+ at package example.dialogs
+ at brief Dialogs used in Example tool
+Classes:
+ - dialogs::ExampleMapDialog
+(C) 2006-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Anna Kratochvilova <kratochanna gmail.com>
+import wx
+from core               import globalvar
+from gui_core.dialogs   import ElementDialog, GroupDialog
+from gui_core           import gselect
+class ExampleMapDialog(ElementDialog):
+    """!Dialog for adding raster map.
+    Dialog can be easily changed to enable to choose vector, imagery groups or other elements.
+    def __init__(self, parent, title = _("Choose raster map"), id = wx.ID_ANY):
+        """!Calls super class constructor.
+        @param parent gui parent
+        @param title dialog window title
+        @param id id
+        ElementDialog.__init__(self, parent, title, label = _("Name of raster map:"))
+        # here is the place to determine element type
+        self.element = gselect.Select(parent = self.panel, type = 'raster',
+                                      size = globalvar.DIALOG_GSELECT_SIZE)
+        self.PostInit()
+        self.__Layout()
+        self.SetMinSize(self.GetSize())
+    def __Layout(self):
+        """!Do layout"""
+        self.dataSizer.Add(item = self.element, proportion = 0,
+                           flag = wx.EXPAND | wx.ALL, border = 5)
+        self.panel.SetSizer(self.sizer)
+        self.sizer.Fit(self)
+    def GetRasterMap(self):
+        """!Returns selected raster map"""
+        return self.GetElement()
Property changes on: grass/trunk/doc/gui/wxpython/example/dialogs.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass/trunk/doc/gui/wxpython/example/frame.py
--- grass/trunk/doc/gui/wxpython/example/frame.py	                        (rev 0)
+++ grass/trunk/doc/gui/wxpython/example/frame.py	2012-02-05 19:21:42 UTC (rev 50672)
@@ -0,0 +1,371 @@
+ at package example.frame
+ at brief Example tool for displaying raster map and related information
+Classes:
+ - frame::ExampleMapFrame
+ - frame::ExampleInfoTextManager
+for details.
+import os
+import sys
+import wx
+# this enables to run application standalone (> python example/frame.py )
+if __name__ == "__main__":
+    sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
+from gui_core.mapdisp   import SingleMapFrame
+from gui_core.forms     import GUI
+from mapdisp.mapwindow  import BufferedWindow
+from mapdisp            import statusbar as sb
+from core.render        import Map
+from core.debug         import Debug
+from core.gcmd          import RunCommand
+import grass.script as grass
+from example.toolbars import ExampleMapToolbar, ExampleMiscToolbar, ExampleMainToolbar
+from example.dialogs  import ExampleMapDialog
+# It is possible to call grass library functions (in C) directly via ctypes
+# however this is less stable. Example is available in trunk/doc/python/, ctypes
+# are used in nviz, vdigit, iclass gui modules.
+# from ctypes import *
+# try:
+#     from grass.lib.raster import *
+#     haveExample = True
+#     errMsg = ''
+# except ImportError, e:
+#     haveExample = False
+#     errMsg = _("Loading raster lib failed.\n%s") % e
+class ExampleMapFrame(SingleMapFrame):
+    """! Main frame of example tool.
+    Inherits from SingleMapFrame, so map is displayed in one map widow.
+    In case two map windows are needed, use DoubleMapFrame from (gui_core.mapdisp).
+    @see IClassMapFrame in iclass.frame
+    def __init__(self, parent = None, title = _("Example Tool"),
+                 toolbars = ["MiscToolbar", "MapToolbar", "MainToolbar"],
+                 size = (800, 600), name = 'exampleWindow', **kwargs):
+        """!Map Frame constructor
+        @param parent (no parent is expected)
+        @param title window title
+        @param toolbars list of active toolbars (default value represents all toolbars)
+        @param size default size
+        SingleMapFrame.__init__(self, parent = parent, title = title,
+                                name = name, Map = Map(), **kwargs)
+        # Place debug message where appropriate
+        # and set debug level from 1 to 5 (higher to lower level functions).
+        # To enable debug mode write:
+        # > g.gisenv set=WX_DEBUG=5
+        Debug.msg(1, "ExampleMapFrame.__init__()")
+        # Add toolbars to aui manager
+        toolbarsCopy = toolbars[:]
+        # workaround to have the same toolbar order on all platforms
+        if sys.platform == 'win32':
+            toolbarsCopy.reverse()
+        for toolbar in toolbarsCopy:
+            self.AddToolbar(toolbar)
+        # Add statusbar
+        # choose items in statusbar choice, which makes sense for your application
+        self.statusbarItems = [sb.SbCoordinates,
+                               sb.SbRegionExtent,
+                               sb.SbCompRegionExtent,
+                               sb.SbShowRegion,
+                               sb.SbAlignExtent,
+                               sb.SbResolution,
+                               sb.SbDisplayGeometry,
+                               sb.SbMapScale,
+                               sb.SbGoTo,
+                               sb.SbProjection]
+        # create statusbar and its manager
+        statusbar = self.CreateStatusBar(number = 4, style = 0)
+        statusbar.SetStatusWidths([-5, -2, -1, -1])
+        self.statusbarManager = sb.SbManager(mapframe = self, statusbar = statusbar)
+        # fill statusbar manager
+        self.statusbarManager.AddStatusbarItemsByClass(self.statusbarItems, mapframe = self, statusbar = statusbar)
+        self.statusbarManager.AddStatusbarItem(sb.SbMask(self, statusbar = statusbar, position = 2))
+        self.statusbarManager.AddStatusbarItem(sb.SbRender(self, statusbar = statusbar, position = 3))
+        self.statusbarManager.Update()
+        # create map window
+        self.MapWindow = BufferedWindow(self, Map = self.GetMap())
+        # create whatever you want, here it is a widget for displaying raster info
+        self.info = ExampleInfoTextManager(self)
+        # add map window (and other widgets) to aui manager
+        self._addPanes()
+        self._mgr.Update()
+        # default action in map toolbar
+        self.OnPan(event = None)
+        # initialize variables related to your application functionality
+        self.InitVariables()
+        self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+        self.SetSize(size)
+    def __del__(self):
+        """!Destructor deletes temporary region"""
+        grass.del_temp_region()
+    def OnCloseWindow(self, event):
+        """!Destroy frame"""
+        self.Destroy()
+    def IsStandalone(self):
+        """!Check if application is standalone.
+        Standalone application can work without parent.
+        Parent can be e.g. Layer Manager.
+        if self.parent:
+            return False
+        return True
+    def GetLayerManager(self):
+        """!Returns frame parent.
+        If IsStandalone() is True, returns None,
+        otherwise retuns frame parent (Layer Manager)
+        return self.parent
+    def InitVariables(self):
+        """!Initialize any variables nneded by application"""
+        self.currentRaster = None
+        self.statitistics = dict()
+        # use WIND_OVERRIDE region not to affect current region
+        grass.use_temp_region()
+    def _addPanes(self):
+        """!Add mapwindow (and other widgets) to aui manager"""
+        window = self.GetWindow()
+        name = "mainWindow"
+        self._mgr.AddPane(window, wx.aui.AuiPaneInfo().
+                  Name(name).CentrePane().
+                  Dockable(False).CloseButton(False).DestroyOnClose(True).
+                  Layer(0))
+        window = self.info.GetControl()
+        name = "infoText"
+                  Name(name).Caption(_("Raster Info")).MinSize((250, -1)).
+                  Dockable(True).CloseButton(False).
+                  Layer(0).Left())
+    def AddToolbar(self, name):
+        """!Add defined toolbar to the window
+        Currently known toolbars are:
+         - 'ExampleMapToolbar'        - basic map toolbar
+         - 'ExampleMainToolbar'       - toolbar with application specific tools
+         - 'ExampleMiscToolbar'       - toolbar with common tools (help, quit, ...)
+        # see wx.aui.AuiPaneInfo documentation for understanding all options
+        if name == "MapToolbar":
+            self.toolbars[name] = ExampleMapToolbar(self)
+            self._mgr.AddPane(self.toolbars[name],
+                              wx.aui.AuiPaneInfo().
+                              Name(name).Caption(_("Map Toolbar")).
+                              ToolbarPane().Top().
+                              LeftDockable(False).RightDockable(False).
+                              BottomDockable(False).TopDockable(True).
+                              CloseButton(False).Layer(1).Row(1).
+                              BestSize((self.toolbars[name].GetBestSize())))
+        if name == "MiscToolbar":
+            self.toolbars[name] = ExampleMiscToolbar(self)
+                              Name(name).Caption(_("Misc Toolbar")).
+        if name == "MainToolbar":
+            self.toolbars[name] = ExampleMainToolbar(self)
+                              Name(name).Caption(_("Main Toolbar")).
+    def GetMapToolbar(self):
+        """!Returns toolbar with zooming tools"""
+        return self.toolbars['MapToolbar']
+    def OnHelp(self, event):
+        """!Show help page"""
+        RunCommand('g.manual', entry = 'wxGUI.Example')
+    def OnSelectRaster(self, event):
+        """!Opens dialog to select raster map"""
+        dlg = ExampleMapDialog(self)
+        if dlg.ShowModal() == wx.ID_OK:
+            raster = grass.find_file(name = dlg.GetRasterMap(), element = 'cell')
+            if raster['fullname']:
+                self.SetLayer(name = raster['fullname'])
+        dlg.Destroy()
+    def SetLayer(self, name):
+        """!Sets layer in Map and updates statistics.
+        @param name layer (raster) name
+        Debug.msg (3, "ExampleMapFrame.SetLayer(): name=%s" % name)
+        # this simple application enables to keep only one raster
+        self.GetMap().DeleteAllLayers()
+        cmdlist = ['d.rast', 'map=%s' % name]
+        # add layer to Map instance (core.render)
+        newLayer = self.GetMap().AddLayer(type = 'raster', command = cmdlist, l_active = True,
+                                          name = name, l_hidden = False, l_opacity = 1.0,
+                                          l_render = True)
+        self.GetWindow().ZoomToMap(layers = [newLayer,], render = True)
+        self.currentRaster = name
+        # change comp. region to match new raster, so that the statistics
+        # are computed for the entire raster
+        RunCommand('g.region',
+                   rast = self.currentRaster,
+                   parent = self)
+        self.UpdateStatistics()
+    def ComputeStatitistics(self):
+        """!Computes statistics for raster map using 'r.univar' module.
+        @return statistic in form of dictionary
+        # RunCommand enables to run GRASS module
+        res = RunCommand('r.univar', # module name
+                         flags = 'g', # command flags
+                         map = self.currentRaster, # module parameters
+                         read = True) # get command output
+        return grass.parse_key_val(res, val_type = float)
+    def UpdateStatistics(self):
+        """!Upadate statistic information.
+        Called after changing raster map.
+        stats = self.ComputeStatitistics()
+        self.info.WriteStatistics(name = self.currentRaster, statDict = stats)
+class ExampleInfoTextManager:
+    """!Class for displaying information.
+    Wrraper for wx.TextCtrl.
+    def __init__(self, parent):
+        """!Creates wx.TextCtrl for displaying information.
+        self.textCtrl = wx.TextCtrl(parent, id = wx.ID_ANY,
+                                    style = wx.TE_MULTILINE | wx.TE_RICH2 | wx.TE_READONLY)
+        self.textCtrl.SetInsertionPoint(0)
+        self.textCtrl.Disable()
+        self.font = self.textCtrl.GetFont()
+        self.bgColor = wx.SystemSettings.GetColour(wx.SYS_COLOUR_BACKGROUND)
+    def GetControl(self):
+        """!Returns control itself."""
+        return self.textCtrl
+    def _setStyle(self, style):
+        """!Sets default style of textCtrl.
+        @param style "title"/"value"
+        if style == "title":
+            self.font.SetWeight(wx.FONTWEIGHT_BOLD)
+        elif style == "value":
+            self.font.SetWeight(wx.FONTWEIGHT_NORMAL)
+        else:
+            return
+        self.textCtrl.SetDefaultStyle(wx.TextAttr(colBack = self.bgColor, font = self.font))
+    def _writeLine(self, title, value):
+        """!Formats text (key, value pair) with styles."""
+        self._setStyle("title")
+        self.textCtrl.AppendText("%s: " % title)
+        self._setStyle("value")
+        self.textCtrl.AppendText("%.2f\n" % value)
+    def _writeRasterTitle(self, name):
+        """!Writes title."""
+        self.textCtrl.AppendText("%s\n\n" % name)
+    def WriteStatistics(self, name, statDict):
+        """!Write and format information about raster map
+        @param name raster map name
+        @param statDict dictionary containing information
+        self.GetControl().Clear()
+        self._writeRasterTitle(name = name)
+        for key, value in statDict.iteritems():
+            self._writeLine(title = key, value = value)
+def main():
+    import gettext
+    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+    app = wx.PySimpleApp()
+    wx.InitAllImageHandlers()
+    frame = ExampleMapFrame()
+    frame.Show()
+    app.MainLoop()
+    main()
Property changes on: grass/trunk/doc/gui/wxpython/example/frame.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
Added: grass/trunk/doc/gui/wxpython/example/toolbars.py
--- grass/trunk/doc/gui/wxpython/example/toolbars.py	                        (rev 0)
+++ grass/trunk/doc/gui/wxpython/example/toolbars.py	2012-02-05 19:21:42 UTC (rev 50672)
@@ -0,0 +1,110 @@
+ at package example.toolbars
+ at brief Example toolbars and icons.
+Classes:
+ - toolbars::ExampleMapToolbar
+ - toolbars::ExampleMainToolbar
+ - toolbars::ExampleMiscToolbar
+for details.
+import wx
+from gui_core.toolbars import BaseToolbar, BaseIcons
+from icons.icon import MetaIcon
+class ExampleMapToolbar(BaseToolbar):
+    """!Map toolbar (to control map zoom and rendering)
+        """!Map toolbar constructor
+        BaseToolbar.__init__(self, parent)
+        self.InitToolbar(self._toolbarData())
+        # realize the toolbar
+        self.Realize()
+        self.action = { 'id' : self.pan }
+        self.defaultAction = { 'id' : self.pan,
+                               'bind' : self.parent.OnPan }
+        self.EnableTool(self.zoomBack, False)
+    def _toolbarData(self):
+        """!Returns toolbar data (name, icon, handler)"""
+        # BaseIcons are a set of often used icons. It is possible
+        # to reuse icons in ./trunk/gui/icons/grass or add new ones there.
+        icons = BaseIcons
+        return self._getToolbarData((("displaymap", icons["display"],
+                                      self.parent.OnDraw),
+                                     ("rendermap", icons["render"],
+                                      self.parent.OnRender),
+                                     ("erase", icons["erase"],
+                                      self.parent.OnErase),
+                                     (None, ), # creates separator
+                                     ("pan", icons["pan"],
+                                      self.parent.OnPan,
+                                      wx.ITEM_CHECK), # toggle tool
+                                     ("zoomIn", icons["zoomIn"],
+                                      self.parent.OnZoomIn,
+                                      wx.ITEM_CHECK),
+                                     ("zoomOut", icons["zoomOut"],
+                                      self.parent.OnZoomOut,
+                                      wx.ITEM_CHECK),
+                                     (None, ),
+                                     ("zoomBack", icons["zoomBack"],
+                                      self.parent.OnZoomBack),
+                                     ("zoomToMap", icons["zoomExtent"],
+                                      self.parent.OnZoomToMap),
+class ExampleMainToolbar(BaseToolbar):
+    """!Toolbar with tools related to application functionality
+        """!Toolbar constructor
+        self.Realize()
+        """!Toolbar data"""
+        return self._getToolbarData((("addRaster", BaseIcons['addRast'],
+                                      self.parent.OnSelectRaster),
+class ExampleMiscToolbar(BaseToolbar):
+    """!Toolbar with miscellaneous tools related to app
+        self.Realize()
+        icons = BaseIcons
+        return self._getToolbarData((("help", icons['help'],
+                                      self.parent.OnHelp),
+                                     ("quit", icons['quit'],
+                                      self.parent.OnCloseWindow),
Property changes on: grass/trunk/doc/gui/wxpython/example/toolbars.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
Added: grass/trunk/doc/gui/wxpython/example/wxGUI.Example.html
--- grass/trunk/doc/gui/wxpython/example/wxGUI.Example.html	                        (rev 0)
+++ grass/trunk/doc/gui/wxpython/example/wxGUI.Example.html	2012-02-05 19:21:42 UTC (rev 50672)
@@ -0,0 +1,76 @@
+<!-- meta page description: wxGUI Example Tool -->
+<!-- meta page index: wxGUI -->
+<h2>DESCRIPTION</h2>
+<p>
+The purpose of the <b>Example Tool</b> is to make life easier
+for new wxGUI developers. It can serve as a basic template when
+creating standalone GRASS GUI-based application. Example tool
+can display one raster map a show information about it.
+</p>
+<p>
+Following topics are covered:
+</p>
+<ul>
+  <li>creating standalone window</li>
+  <li>adding toolbars, statusbar</li>
+  <li>displaying raster map</li>
+  <li>running GRASS modules from application</li>
+  <li>creating dialog for element (raster, vector, ...) selection</li>
+  <li>using temporary region</li>
+  <li>access from main menu</li>
+  <li>writing programmer documentation</li>
+  <li>writing user documentation</li>
+</ul>
+<h2>NOTE</h2>
+<p>
+See README to learn how to get Example Tool to work.
+</p>
+Put screenshot here
+<center>
+<br><img src="wxGUI_example.jpg" border="1"><br><br>
+</center>
+<h3>EXAMPLE TOOL TOOLBAR</h3>
+<dl>
+  <dt><img src="icons/layer-raster-add.png">&nbsp;
+    <em>Select raster layer</em></dt>
+  <dd>Select raster layer and compute statistics related to this layer.</dd>
+</dl>
+<h2>SEE ALSO</h2>
+<em>
+  <a href="wxGUI.html">wxGUI</a><br>
+  <a href="wxGUI.Components.html">wxGUI components</a>
+</em>
+Create wiki page and put the link here:
+<p>
+See also
+user <a href="http://grass.osgeo.org/wiki/WxGUI_...">wiki</a> page.
+</p>
+<h2>AUTHOR</h2>
+<p>
+Anna Kratochvilova,
+ <a href="http://www.cvut.cz">Czech Technical University in Prague</a>, Czech Republic<br>
+</p>
+<p>
+<i>$Date$</i>
Property changes on: grass/trunk/doc/gui/wxpython/example/wxGUI.Example.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
