[GRASS-SVN] r50693 - in grass/trunk/raster3d: . r3.support
Mon Feb 6 08:25:15 EST 2012
Author: huhabla
Date: 2012-02-06 05:25:14 -0800 (Mon, 06 Feb 2012)
New Revision: 50693
Added:
   grass/trunk/raster3d/r3.support/
   grass/trunk/raster3d/r3.support/Makefile
   grass/trunk/raster3d/r3.support/check.c
   grass/trunk/raster3d/r3.support/local_proto.h
   grass/trunk/raster3d/r3.support/main.c
   grass/trunk/raster3d/r3.support/r3.support.html
Added r3.support module to create/modify raster3d map metadata.
Added: grass/trunk/raster3d/r3.support/Makefile
--- grass/trunk/raster3d/r3.support/Makefile	                        (rev 0)
+++ grass/trunk/raster3d/r3.support/Makefile	2012-02-06 13:25:14 UTC (rev 50693)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = r3.support
+LIBES = $(RASTER3DLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTER3DDEP) $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster3d/r3.support/check.c
--- grass/trunk/raster3d/r3.support/check.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.support/check.c	2012-02-06 13:25:14 UTC (rev 50693)
@@ -0,0 +1,43 @@
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/raster3d.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+ * check_stats() - Check and update statistics
+ * RETURN: EXIT_SUCCESS / EXIT_FAILURE
+int check_stats(const char *name)
+    struct Categories cats;
+    struct FPRange fprange;
+    int cats_ok;
+    G_message(_("\n  Updating statistics for [%s]"), name);
+    /* Get category status and max */
+    cats_ok = (Rast3d_read_cats(name, "", &cats) >= 0);
+    Rast3d_read_range(name, "", &fprange);
+    /* Further category checks */
+    if (!cats_ok)
+	Rast_init_cats("", &cats);
+    else if (cats.num != fprange.max) {
+	cats.num = fprange.max;
+	cats_ok = 0;
+    /* Update categories if needed */
+    if (!cats_ok) {
+	G_message(_("   Updating the number of categories for "
+		    "[%s]\n\n"), name);
+	Rast3d_write_cats(name, &cats);
+    Rast_free_cats(&cats);
+    return 0;
Added: grass/trunk/raster3d/r3.support/local_proto.h
--- grass/trunk/raster3d/r3.support/local_proto.h	                        (rev 0)
+++ grass/trunk/raster3d/r3.support/local_proto.h	2012-02-06 13:25:14 UTC (rev 50693)
@@ -0,0 +1,2 @@
+/* check.c */
+int check_stats(const char *);
Added: grass/trunk/raster3d/r3.support/main.c
--- grass/trunk/raster3d/r3.support/main.c	                        (rev 0)
+++ grass/trunk/raster3d/r3.support/main.c	2012-02-06 13:25:14 UTC (rev 50693)
@@ -0,0 +1,262 @@
+ * MODULE:       r3.support (GRASS core)
+ * AUTHOR(S):    Soeren Gebbert vTI/AK based on r.support
+ *               Original r.support by Michael Shapiro - CERL
+ * PURPOSE:      Build support files for raster map
+ *               - Edit header, units
+ *               - Update status (range)
+ * COPYRIGHT:    (C) 2000-2007 by the GRASS Development Team
+ *               This program is free software under the GNU General
+ *               Public License (>=v2). Read the file COPYING that comes
+ *               with GRASS for details.
+#include <unistd.h>
+#include <string.h>
+#define MAX_TITLE_LEN 1022
+int main(int argc, char *argv[])
+    const char *mapset;
+    struct GModule *module;
+    struct Option *raster, *title_opt, *history_opt;
+    struct Option *datasrc1_opt, *datasrc2_opt, *datadesc_opt;
+    struct Option *map_opt, *units_opt, *vunits_opt;
+    struct Option *load_opt, *save_opt;
+    struct Flag *stats_flag;
+    const char *infile;
+    char title[MAX_TITLE_LEN + 1];
+    struct History hist;
+    /* Initialize GIS engine */
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster3d"));
+    G_add_keyword(_("metadata"));
+    module->description = _("Allows creation and/or modification of "
+			    "raster3d map layer support files.");
+    raster = G_define_standard_option(G_OPT_R3_MAP);
+    title_opt = G_define_option();
+    title_opt->key = "title";
+    title_opt->key_desc = "phrase";
+    title_opt->type = TYPE_STRING;
+    title_opt->required = NO;
+    title_opt->description = _("Text to use for map title");
+    history_opt = G_define_option();
+    history_opt->key = "history";
+    history_opt->key_desc = "phrase";
+    history_opt->type = TYPE_STRING;
+    history_opt->required = NO;
+    history_opt->description =
+	_("Text to append to the next line of the map's metadata file");
+    units_opt = G_define_option();
+    units_opt->key = "unit";
+    units_opt->type = TYPE_STRING;
+    units_opt->required = NO;
+    units_opt->description = _("The map data unit");
+    vunits_opt = G_define_option();
+    vunits_opt->key = "vunit";
+    vunits_opt->type = TYPE_STRING;
+    vunits_opt->required = NO;
+    vunits_opt->description = _("The vertical unit of the map");
+    datasrc1_opt = G_define_option();
+    datasrc1_opt->key = "source1";
+    datasrc1_opt->key_desc = "phrase";
+    datasrc1_opt->type = TYPE_STRING;
+    datasrc1_opt->required = NO;
+    datasrc1_opt->description = _("Text to use for data source, line 1");
+    datasrc2_opt = G_define_option();
+    datasrc2_opt->key = "source2";
+    datasrc2_opt->key_desc = "phrase";
+    datasrc2_opt->type = TYPE_STRING;
+    datasrc2_opt->required = NO;
+    datasrc2_opt->description = _("Text to use for data source, line 2");
+    datadesc_opt = G_define_option();
+    datadesc_opt->key = "description";
+    datadesc_opt->key_desc = "phrase";
+    datadesc_opt->type = TYPE_STRING;
+    datadesc_opt->required = NO;
+    datadesc_opt->description =
+	_("Text to use for data description or keyword(s)");
+    map_opt = G_define_option();
+    map_opt->key = "raster";
+    map_opt->type = TYPE_STRING;
+    map_opt->required = NO;
+    map_opt->gisprompt = "old,cell,raster";
+    map_opt->description = _("Raster map from which to copy category table");
+    load_opt = G_define_standard_option(G_OPT_F_INPUT);
+    load_opt->key = "loadhistory";
+    load_opt->required = NO;
+    load_opt->description = _("Text file from which to load history");
+    save_opt = G_define_standard_option(G_OPT_F_OUTPUT);
+    save_opt->key = "savehistory";
+    save_opt->required = NO;
+    save_opt->description = _("Text file in which to save history");
+    stats_flag = G_define_flag();
+    stats_flag->key = 's';
+    stats_flag->description = _("Update range");
+    /* Parse command-line options */
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    /* Make sure raster exists and set mapset */
+    infile = raster->answer;
+    mapset = G_find_raster3d(infile, G_mapset());	/* current mapset only for editing */
+    if (!mapset || strcmp(mapset, G_mapset()) != 0)
+	G_fatal_error(_("Raster3d map <%s> not found in current mapset"), infile);
+    if (title_opt->answer) {
+	strncpy(title, title_opt->answer, MAX_TITLE_LEN);
+	title[MAX_TITLE_LEN - 1] = '\0';	/* strncpy doesn't null terminate over-sized input */
+	G_strip(title);
+	G_debug(3, "map title= [%s]  (%d chars)", title, (int)strlen(title));
+        Rast3d_read_history(raster->answer, "", &hist);
+        Rast_set_history(&hist, HIST_TITLE, title);
+	Rast3d_write_history(raster->answer, &hist);
+    if (save_opt->answer) {
+	FILE *fp = fopen(save_opt->answer, "w");
+	int i;
+	if (!fp)
+	    G_fatal_error(_("Unable to open output file <%s>"), save_opt->answer);
+	for (i = 0; i < Rast_history_length(&hist); i++)
+	    fprintf(fp, "%s\n", Rast_history_line(&hist, i));
+	fclose(fp);
+    if (load_opt->answer) {
+	FILE *fp = fopen(load_opt->answer, "r");
+	if (!fp)
+	    G_fatal_error(_("Unable to open input file <%s>"), load_opt->answer);
+	Rast_clear_history(&hist);
+	for (;;) {
+	    char buf[80];
+	    if (!G_getl2(buf, sizeof(buf), fp))
+		break;
+	    Rast_append_history(&hist, buf);
+	fclose(fp);
+    if (history_opt->answer) {
+	/* two less than defined as if only one less a newline gets appended in the hist file. bug? */
+	/* Should be RECORD_LEN, but r.info truncates at > 71 chars */
+	if (strlen(history_opt->answer) > 71) {
+	    int i;
+	    for (i = 0; i < strlen(history_opt->answer); i += 71) {
+		char buf[72];
+		strncpy(buf, &history_opt->answer[i], sizeof(buf)-1);
+		buf[sizeof(buf)-1] = '\0';
+	else
+	    Rast_append_history(&hist, history_opt->answer);
+    if(units_opt->answer || vunits_opt->answer) {
+        RASTER3D_Map *map;
+        map = Rast3d_open_cell_old(raster->answer, G_mapset(), \
+                RASTER3D_DEFAULT_WINDOW, RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_DEFAULT);
+        /* Modify the units */
+        if (units_opt->answer)
+            Rast3d_set_unit(map, units_opt->answer);
+        if (vunits_opt->answer)
+            Rast3d_set_vertical_unit(map, vunits_opt->answer);
+        Rast3d_rewrite_header(map);
+        Rast3d_close(map);
+    if (datasrc1_opt->answer || datasrc2_opt->answer || datadesc_opt->answer) {
+	if (datasrc1_opt->answer)
+	    Rast_set_history(&hist, HIST_DATSRC_1, datasrc1_opt->answer);
+	if (datasrc2_opt->answer)
+	    Rast_set_history(&hist, HIST_DATSRC_2, datasrc2_opt->answer);
+	if (datadesc_opt->answer)
+	    Rast_set_history(&hist, HIST_KEYWRD, datadesc_opt->answer);
+    if (map_opt->answer) {	/* use cats from another map */
+	int fd;
+	fd = Rast_open_old(infile, "");
+	if (Rast3d_read_cats(map_opt->answer, "", &cats) < 0)
+	    G_fatal_error(_("Unable to read category file of raster map <%s>"),
+			  map_opt->answer);
+	Rast3d_write_cats(infile, &cats);
+	G_message(_("cats table for [%s] set to %s"),
+		  infile, map_opt->answer);
+	Rast_close(fd);
+    /* Check the histogram and range */
+    if (stats_flag->answer)
+	check_stats(raster->answer);
+    return EXIT_SUCCESS;
Added: grass/trunk/raster3d/r3.support/r3.support.html
--- grass/trunk/raster3d/r3.support/r3.support.html	                        (rev 0)
+++ grass/trunk/raster3d/r3.support/r3.support.html	2012-02-06 13:25:14 UTC (rev 50693)
@@ -0,0 +1,26 @@
+<h2>DESCRIPTION</h2>
+<b>r3.support</b> allows the user to create and/or edit raster3d map support
+information. Editing of raster3d map units, history, description and title is supported.
+<h2>NOTES</h2>
+Freeform metadata information is stored in a "<tt>hist</tt>" file which may be
+appended to by using the <b>history</b> option. Currently this is limited to
+text with a maximum line length of 78 characters. Any input
+larger than this will be wrapped to the next line.
+All other metadata strings available as standard options are limited to
+79 characters.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r3.info.html">r.info</a>,
+<a href="r3.timestamp.html">r.timestamp</a>
+</em>
+<h2>AUTHORS</h2>
+Soeren Gebbert, vTI/AK, soerengebbert gmooglemail.com<br>
+Based on r.support written by Micharl Shapiro, CERL and others
+<p><i>Last changed: $Date: 2011-11-08 22:24:20 +0100 (Di, 08 Nov 2011) $</i>
