[GRASS-SVN] r50702 - grass/branches/develbranch_6/gui/wxpython/xml
Tue Feb 7 06:11:21 EST 2012
Author: hamish
Date: 2012-02-07 03:11:21 -0800 (Tue, 07 Feb 2012)
New Revision: 50702
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
r.le.trace req's an Xterm
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2012-02-07 10:49:56 UTC (rev 50701)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2012-02-07 11:11:21 UTC (rev 50702)
@@ -1442,7 +1442,7 @@
 	      <command>r.le.patch</command>
 	    </menuitem>
 	    <menuitem>
-	      <label>Output</label>
+	      <label>Summary and display (requires XTerm)</label>
 	      <help>Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file.</help>
 	      <keywords>raster,landscape structure analysis,patch index</keywords>
 	      <handler>OnXTerm</handler>
