[GRASS-SVN] r50712 - sandbox/lucadelu
Tue Feb 7 12:33:43 EST 2012
Author: lucadelu
Date: 2012-02-07 09:33:43 -0800 (Tue, 07 Feb 2012)
New Revision: 50712
   sandbox/lucadelu/r.li.setup.py
r.li.setup improvement
Modified: sandbox/lucadelu/r.li.setup.py
--- sandbox/lucadelu/r.li.setup.py	2012-02-07 13:24:00 UTC (rev 50711)
+++ sandbox/lucadelu/r.li.setup.py	2012-02-07 17:33:43 UTC (rev 50712)
@@ -58,8 +58,7 @@
         self.rlipath = os.path.join(os.environ['HOME'], '.grass%d' % self.major_version, 'r.li')
         #check if self.rlipath exists
         self.CheckFolder()
-        #return all the configuration files in self.rlipath
-        self.listfiles = os.listdir(self.rlipath)
+        self.listfiles = self.ListFiles()
         ###END VARIABLES
         #init of frame
         wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
@@ -77,12 +76,15 @@
         self.btn_remove = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Remove"))
         self.btn_remove.SetToolTipString(_('Remove a configuration file'))
         self.btn_new = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Create"))
-        self.btn_new.SetToolTipString(_('Create a new configuration file'))
+        self.btn_new.SetToolTipString(_('Create a new configuration file'))
+        self.btn_rename = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Rename"))
+        self.btn_rename.SetToolTipString(_('Renane a configuration file'))
         #set action for button
         self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
         self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
         self.btn_remove.Bind(wx.EVT_BUTTON, self.OnRemove)
-        self.btn_new.Bind(wx.EVT_BUTTON, self.OnNew)
+        self.btn_new.Bind(wx.EVT_BUTTON, self.OnNew)
+        self.btn_rename.Bind(wx.EVT_BUTTON, self.OnRename)
         self._layout()
         ###END BUTTONS
@@ -103,6 +105,7 @@
         ###BUTTONS
         buttonSizer = wx.BoxSizer(wx.HORIZONTAL)
         buttonSizer.Add(item = self.btn_new, flag = wx.ALL, border = 5)
+        buttonSizer.Add(item = self.btn_rename, flag = wx.ALL, border = 5)
         buttonSizer.Add(item = self.btn_remove, flag = wx.ALL, border = 5)
         buttonSizer.Add(item = self.btn_help, flag = wx.ALL, border = 5)
         buttonSizer.Add(item = self.btn_close, flag = wx.ALL, border = 5)
@@ -128,7 +131,14 @@
     def ListFiles(self):
         """!Check the configuration files inside the path"""
-        return os.listdir(self.rlipath)
+        # list of configuration file
+        listfiles = []
+        #return all the configuration files in self.rlipath, check if there are
+        #link or directory and doesn't add them
+        for l in os.listdir(self.rlipath):
+            if os.path.isfile(os.path.join(self.rlipath,l)):
+                listfiles.append(l)
+        return listfiles
     def OnClose(self,event):
         """!Close window"""
@@ -148,7 +158,28 @@
     def OnNew(self, event):
         """!Remove configuration file from path and update the list"""
         RLIWizard(self)
+        self.listfileBox.Clear()
+        self.listfileBox.Set(self.listfiles)
+    def OnRename(self, event):
+        """!Rename an existing configuration file"""
+        try:
+            confile = self.listfiles[self.listfileBox.GetSelections()[0]]
+        except:
+            gcmd.GMessage(parent = self,
+                          message = _("You have to select a configuration file"))
+            return
+        dlg = wx.TextEntryDialog(parent = self.parent,
+                 message = _('Set te new name for %s configuration file') % confile,
+                 caption = _('Rename configuration file'))
+        if dlg.ShowModal() == wx.ID_OK:
+            res = dlg.GetValue()
+            os.rename(os.path.join(self.rlipath,confile),os.path.join(self.rlipath,res))
 class RLIWizard(object):
     Start wizard here and finish wizard here
@@ -157,7 +188,9 @@
     def __init__(self, parent):
         self.parent = parent # GMFrame
         self.wizard = wiz.Wizard(parent=parent, id=wx.ID_ANY, title=_("Create new configuration file for r.li modules"))
+        self.major_version = int(grass.version()['version'].split('.', 1)[0])
+        self.rlipath = os.path.join(os.environ['HOME'], '.grass%d' % self.major_version, 'r.li')
         #pages
         self.startpage = FirstPage(self.wizard, self)
         self.keyboardpage = KeybordPage(self.wizard, self)
@@ -191,13 +224,13 @@
                                 style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
             if dlg.ShowModal() == wx.ID_NO:
-                dlg.Destroy()
-                print "no"
                 self._cleanup()
+                dlg.Destroy()
             else:
+                self._write_confile()
+                self._cleanup()
                 dlg.Destroy()
-                print "yes"
-                self._cleanup()
         else:
             self.wizard.Destroy()
             gcmd.GMessage(parent = self.parent,
@@ -205,13 +238,68 @@
                                  "Configuration file not created."))
             self._cleanup()
+    def _write_confile(self):
+        """Write the configuration file"""
+        f = open(os.path.join(self.rlipath,self.startpage.conf_name),'w')
+        self._write_region(f)
+        self._write_area(f)
+        f.close()
+    def _temp_region(self):
+        # save current settings:
+        grass.use_temp_region()
+        # Temporarily aligning region resolution to $RASTER resolution
+        # keep boundary settings
+        grass.run_command('g.region', rast = self.startpage.rast)
+        self.gregion = grass.region()
+    def _write_region(self,fil):
+        """Write the region"""
+        self.rasterinfo = grast.raster_info(self.startpage.rast)
+        if self.startpage.region == 'whole':
+            fil.write("SAMPLINGFRAME 0|0|1|1\n")
+            self._temp_region()
+            self.SF_X = 0.0
+            self.SF_Y = 0.0
+            self.SF_RL = abs(int(float(self.gregion['s']-self.gregion['n']) / float(self.gregion['nsres'])))
+            self.SF_CL = abs(int(float(self.gregion['e']-self.gregion['w']) / float(self.gregion['ewres'])))
+        elif self.startpage.region == 'key':
+            self.SF_X = self.keyboardpage.col_up
+            self.SF_Y = self.keyboardpage.row_up
+            self.SF_RL = self.keyboardpage.row_len
+            self.SF_CL =  self.keyboardpage.col_len
+            per_x = float(self.SF_X) / float(self.rasterinfo['cols'])
+            per_y = float(self.SF_Y) / float(self.rasterinfo['rows'])
+            per_rl = float(self.SF_RL) / float(self.rasterinfo['cols'])
+            per_cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
+            fil.write("SAMPLINGFRAME %f|%f|%f|%f\n" % (per_x,per_y,per_rl,per_cl))
+    def _write_area(self,fil):
+        if self.samplingareapage.samplingtype == 'whole':
+            x = float(self.SF_X) / float(self.rasterinfo['cols'])
+            cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
+            y = float(self.SF_Y) / float(self.rasterinfo['rows'])
+            rl = float(self.SF_RL) / float(self.rasterinfo['rows'])
+                fil.write("SAMPLEAREA %.1f|%.1f|%.1f|%.1f\n" % (x,y,rl,cl))
+                fil.write("SAMPLEAREA %f|%f|%f|%f\n" % (x,y,rl,cl))
     def _cleanup(self):
+        """Clean all the variables to save into configuration file"""
         self.startpage.conf_name = ''
         self.startpage.rast = ''
         self.startpage.vect = ''
         self.startpage.region = 'whole'
         self.keyboardpage.col_len = ''
-        self.keyboardpage.row_len = ''
+        self.keyboardpage.col_up = ''
+        self.keyboardpage.row_len = ''
+        self.keyboardpage.row_up = ''
         self.samplingareapage.samplingtype = 'whole'
         self.samplingunitskey.sizew = ''
         self.samplingunitskey.sizeh = ''
@@ -418,37 +506,21 @@
         """!Sets the name of configuration file"""
         self.col_up = self.ColUpLefttxt.GetValue()
         checkValue(self.col_up)
-        if self.col_up == '':
-            wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-        else:
-            wx.FindWindowById(wx.ID_FORWARD).Enable(True)
     def OnRowLeft(self,event):
         self.row_up = self.RowUpLefttxt.GetValue()
         checkValue(self.row_up)
-        if self.row_up == '':
-        else:
     def OnColLen(self,event):
         self.col_len = self.ColLentxt.GetValue()
         checkValue(self.col_len)
-        if self.col_len == '':
-        else:
         self.row_len = self.RowLentxt.GetValue()
         checkValue(self.row_len)
-        if self.row_len == '':
-        else:
     def OnEnterPage(self, event):
         """!Sets the default values, for the entire map
@@ -470,6 +542,7 @@
         if self.row_len == '' or self.col_len == '' or self.row_up == '' or self.col_up == '':
         else:
+            print self.row_len, self.col_len, self.row_up, self.col_up
 class SamplingAreasPage(TitledPage):
