[GRASS-SVN] r50781 - grass/branches/develbranch_6/vector/lidar/v.surf.bspline
Mon Feb 13 03:54:05 EST 2012
Author: hamish
Date: 2012-02-13 00:54:05 -0800 (Mon, 13 Feb 2012)
New Revision: 50781
   grass/branches/develbranch_6/vector/lidar/v.surf.bspline/crosscorr.c
less noisy output, spelling in comments, whitespace
Modified: grass/branches/develbranch_6/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/branches/develbranch_6/vector/lidar/v.surf.bspline/crosscorr.c	2012-02-13 06:59:19 UTC (rev 50780)
+++ grass/branches/develbranch_6/vector/lidar/v.surf.bspline/crosscorr.c	2012-02-13 08:54:05 UTC (rev 50781)
@@ -97,7 +97,7 @@
 	int BW, lbd_min;	/* lbd_min: index where minimun is found */
 	double mean_reg, *obs_mean;
-	int nrec, ctype = 0;
+	int nrec, ctype = 0, verbosity;
 	struct field_info *Fi;
 	dbDriver *driver_cats;
@@ -105,6 +105,8 @@
 	rms = G_alloc_vector(PARAM_LAMBDA);	/* number of parameter used used for cross validation */
 	stdev = G_alloc_vector(PARAM_LAMBDA);
+	verbosity = G_verbose(); /* store for later reset */
 	/* Working with attributes */
 	if (bspline_field > 0) {
 	    db_CatValArray_init(&cvarr);
@@ -159,7 +161,7 @@
 	TN = G_alloc_vector(nparam_spl);	/* vector */
 	parVect = G_alloc_vector(nparam_spl);	/* Parameters vector */
 	obsVect = G_alloc_matrix(ndata, 3);	/* Observation vector */
-	Q = G_alloc_vector(ndata);	/* "a priori" var-cov matrix */
+	Q = G_alloc_vector(ndata);		/* "a priori" var-cov matrix */
 	obs_mean = G_alloc_vector(ndata);
 	stat_vect = alloc_Stats(ndata);
@@ -168,21 +170,22 @@
 	    G_message(_("Begining cross validation with "
 			"lambda_i=%.4f..."), lambda[lbd]);
+	    G_set_verbose(G_verbose_min());
 	       How cross correlation algorithm is done:
 	       For each cicle, only the first ndata-1 "observ" elements are considered for the
 	       interpolation. Within every interpolation mean is calculated to lowering border
-	       errors. The point let out will be used for an estimation. The error between the
+	       errors. The point left out will be used for an estimation. The error between the
 	       estimation and the observation is recorded for further statistics.
 	       At the end of the cicle, the last point, that is, the ndata-1 index, and the point
 	       with j index are swapped.
 	    for (j = 0; j < ndata; j++) {	/* Cross Correlation will use all ndata points */
-		double out_x, out_y, out_z;	/* This point is let out */
+		double out_x, out_y, out_z;	/* This point is left out */
 		for (i = 0; i < ndata; i++) {	/* Each time, only the first ndata-1 points */
-		    double dval;	/* are considered in the interpolation */
+		    double dval;		/* are considered in the interpolation */
 		    /* Setting obsVect vector & Q matrix */
 		    Q[i] = 1;	/* Q=I */
@@ -233,7 +236,7 @@
 		    obsVect[i][2] -= mean_reg;
-		/* This is let out */
+		/* This is left out */
 		out_x = observ[ndata - 1].coordX;
 		out_y = observ[ndata - 1].coordY;
 		out_z = obsVect[ndata - 1][2];
@@ -277,8 +280,15 @@
 		G_debug(1, "CrossCorrelation: stat_vect.error[%d]  =  %lf", j,
 			stat_vect.error[j]);
-		observ = swap(observ, j, ndata - 1);	/* Once the last value is let out, it is swap with j-value */
+		observ = swap(observ, j, ndata - 1);	/* Once the last value is left out, it is swap with j-value */
+/* commented out as it could be problematic to use global libgis variables
+   if the different x-val cases are each sent to their own thread in future */
+/*		G_set_verbose(verbosity);
+		G_clicker();
+		G_set_verbose(G_verbose_min()); */
+	    G_set_verbose(verbosity);
 	    mean[lbd] = calc_mean(stat_vect.error, stat_vect.n_points);
 	    rms[lbd] =
@@ -289,6 +299,7 @@
 	    G_message(_("Mean = %.5lf"), mean[lbd]);
 	    G_message(_("Root Means Square (RMS) = %.5lf"),
 		      rms[lbd]);
+	    G_message("---");
 	}			/* ENDFOR each lambda value */
 	G_free_matrix(N);
@@ -434,7 +445,7 @@
 struct Point *swap(struct Point *point, int a, int b)
-    SWAP(point[a].coordX, point[b].coordX);	/* Once the last value is let out, it is swap with j-value */
+    SWAP(point[a].coordX, point[b].coordX);	/* Once the last value is left out, it is swap with j-value */
     SWAP(point[a].coordY, point[b].coordY);
     SWAP(point[a].coordZ, point[b].coordZ);
     SWAP(point[a].cat, point[b].cat);
