[GRASS-SVN] r50784 - grass/branches/develbranch_6/scripts/r.fillnulls
Mon Feb 13 05:34:53 EST 2012
Author: hamish
Date: 2012-02-13 02:34:53 -0800 (Mon, 13 Feb 2012)
New Revision: 50784
   grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls
use 3D points instead of writing to a table; use a better default for lambda_i
Modified: grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls
--- grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls	2012-02-13 09:48:04 UTC (rev 50783)
+++ grass/branches/develbranch_6/scripts/r.fillnulls/r.fillnulls	2012-02-13 10:34:53 UTC (rev 50784)
@@ -139,8 +139,8 @@
 USERMASK="usermask_$MASKTMP"
 eval `g.findfile element=cell file=MASK`
 if [ "$file" ] ; then
- g.message "A user raster mask (MASK) is present. Saving it..."
- g.rename MASK,"$USERMASK" --quiet > /dev/null
+    g.message "A user raster mask (MASK) is present. Saving it..."
+    g.rename MASK,"$USERMASK" --quiet > /dev/null
 fi
 #make a mask of NULL cells
@@ -165,6 +165,7 @@
 # check-me: quoting ok?
 RES="`echo $nsres $ewres | awk '{printf "%f", ($1+$2) * 3. / 2.}'`"  # avg*3
+# maybe use r.grow here..
 r.buffer input="$TMP1" dist="$RES" out="$TMP1.buf"
 if [ $? -ne 0 ] ; then
     g.message -e "$0 abandoned. Removing temporary map, restoring user mask if needed:"
@@ -182,7 +183,8 @@
 g.message "Creating interpolation points..."
 ## use the -b flag to avoid topology building on big jobs?
-r.to.vect input="$GIS_OPT_INPUT" output="$VECTTMP" feature=point
+## no, can't, 'g.region vect=' currently wants to see level 2
+r.to.vect -z input="$GIS_OPT_INPUT" output="$VECTTMP" feature=point
     g.message -e "$0 abandoned. Removing temporary maps, restoring user mask if needed:"
@@ -233,9 +235,9 @@
    eval `g.findfile element=cell file=$USERMASK`
       g.message "Using user mask while interpolating"
-      RST_CMD="v.surf.rst zcol=value tension=$GIS_OPT_TENSION smooth=$GIS_OPT_SMOOTH maskmap=$USERMASK"
+      RST_CMD="v.surf.rst -z layer=0 tension=$GIS_OPT_TENSION smooth=$GIS_OPT_SMOOTH maskmap=$USERMASK"
    else
-      RST_CMD="v.surf.rst zcol=value tension=$GIS_OPT_TENSION smooth=$GIS_OPT_SMOOTH"
+      RST_CMD="v.surf.rst -z layer=0 tension=$GIS_OPT_TENSION smooth=$GIS_OPT_SMOOTH"
    fi
    g.message "Note: The following warnings may be ignored."
@@ -277,8 +279,8 @@
    SIE=`echo "$ewres" | awk '{printf "%f", $1 * 3.}'`
    SIN=`echo "$nsres" | awk '{printf "%f", $1 * 3.}'`
-   v.surf.bspline input="$VECTTMP" raster="${TMP1}_filled" layer=1 \
-      method="$GIS_OPT_METHOD" column=value sie="$SIE" sin="$SIN"
+   v.surf.bspline input="$VECTTMP" raster="${TMP1}_filled" layer=0 \
+      method="$GIS_OPT_METHOD" sie="$SIE" sin="$SIN" lambda_i=0.005
 fi
