[GRASS-SVN] r50795 - in grass/trunk/temporal: t.create t.remove t.sample t.support t.topology tr.univar tv.list
Mon Feb 13 09:55:21 EST 2012
Author: huhabla
Date: 2012-02-13 06:55:21 -0800 (Mon, 13 Feb 2012)
New Revision: 50795
   grass/trunk/temporal/t.create/t.create.py
   grass/trunk/temporal/t.remove/t.remove.py
   grass/trunk/temporal/t.sample/test.t.sample.sh
   grass/trunk/temporal/t.support/test.t.support.sh
   grass/trunk/temporal/t.topology/test.t.topology.abstime.sh
   grass/trunk/temporal/t.topology/test.t.topology.reltime.sh
   grass/trunk/temporal/tr.univar/test.tr.univar.sh
   grass/trunk/temporal/tv.list/test.tv.list.layer.sh
   grass/trunk/temporal/tv.list/test.tv.list.sh
New semantic types. Maps are now removed from the temporal database
using t.unregister rasther than t.remove. Updated several tests to use
t.register and t.unregister.
Modified: grass/trunk/temporal/t.create/t.create.py
--- grass/trunk/temporal/t.create/t.create.py	2012-02-13 14:35:00 UTC (rev 50794)
+++ grass/trunk/temporal/t.create/t.create.py	2012-02-13 14:55:21 UTC (rev 50795)
@@ -35,8 +35,8 @@
 #% description: The semantic type of the space time dataset
 #% required: yes
 #% multiple: no
-#% options: event, const, continuous
-#% answer: event
+#% options: min,max,sum,mean
+#% answer: mean
 #%end
 #%option
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py	2012-02-13 14:35:00 UTC (rev 50794)
+++ grass/trunk/temporal/t.remove/t.remove.py	2012-02-13 14:55:21 UTC (rev 50795)
@@ -5,7 +5,7 @@
 # MODULE:	t.remove
 # AUTHOR(S):	Soeren Gebbert
-# PURPOSE:	Remove space time or map dataset
+# PURPOSE:	Remove space time datasets from the temporal database
 # COPYRIGHT:	(C) 2011 by the GRASS Development Team
 #		This program is free software under the GNU General Public
@@ -15,7 +15,7 @@
 #%module
-#% description: Remove space time or map datasets from temporal database
+#% description: Remove space time datasets from temporal database
 #% keywords: spacetime
 #% keywords: dataset
 #% keywords: remove
@@ -24,7 +24,7 @@
 #%option
 #% key: input
 #% type: string
-#% description: Name(s) of the space time or map dataset to be removed from the temporal database
+#% description: Name(s) of the space time dataset to be removed from the temporal database
 #% required: no
 #% multiple: yes
 #%end
@@ -32,7 +32,7 @@
 #%option
 #% key: file
 #% type: string
-#% description: Input file with raster map names, one per line
+#% description: Input file with dataset names, one per line
 #% required: no
 #% multiple: no
 #%end
@@ -42,7 +42,7 @@
 #% type: string
 #% description: Type of the space time dataset, default is strds
 #% required: no
-#% options: strds, str3ds, stvds, rast, rast3d, vect
+#% options: strds, str3ds, stvds
 #% answer: strds
 #%end
Modified: grass/trunk/temporal/t.sample/test.t.sample.sh
--- grass/trunk/temporal/t.sample/test.t.sample.sh	2012-02-13 14:35:00 UTC (rev 50794)
+++ grass/trunk/temporal/t.sample/test.t.sample.sh	2012-02-13 14:55:21 UTC (rev 50795)
@@ -55,11 +55,11 @@
 t.create --o type=stvds temporaltype=absolute output=pnts_abs0 title="A test with vector input files" descr="A test with vector input files"
 t.create --o type=stvds temporaltype=absolute output=pnts_abs1 title="A test with vector input files" descr="A test with vector input files"
-tr.register -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=rast -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
 tr.list precip_abs0 -h
-tv.register    input=pnts_abs0 file="${n2}" start=file end=file
+t.register type=vect    input=pnts_abs0 file="${n2}" start=file end=file
 tv.list pnts_abs0 -h
-tv.register    input=pnts_abs1 file="${n3}" start=file end=file
+t.register type=vect    input=pnts_abs1 file="${n3}" start=file end=file
 tv.list pnts_abs1 -h
 # The @test
@@ -71,11 +71,11 @@
 # Test with temporal point data
-tr.register    input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=rast    input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
 t.sample input=precip_abs0 samtype=stvds sample=pnts_abs0 -h
 t.sample input=precip_abs0 samtype=stvds sample=pnts_abs1 -h
-t.remove type=rast input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
 t.remove type=strds input=precip_abs0
 t.remove type=stvds input=pnts_abs0,pnts_abs1
Modified: grass/trunk/temporal/t.support/test.t.support.sh
--- grass/trunk/temporal/t.support/test.t.support.sh	2012-02-13 14:35:00 UTC (rev 50794)
+++ grass/trunk/temporal/t.support/test.t.support.sh	2012-02-13 14:55:21 UTC (rev 50795)
@@ -1,15 +1,15 @@
 # We create several space time raster datasets
 # A simple space ime raster datasets creation and unpdate @test with absolute time
-t.create --v --o type=strds temporaltype=absolute output=precip_abs1 title="Test" descr="This is the 1 test strds" semantictype=event
+t.create --v --o type=strds temporaltype=absolute output=precip_abs1 title="Test" descr="This is the 1 test strds" semantictype=sum
 t.info type=strds input=precip_abs1
-t.support --v type=strds input=precip_abs1 title="Test support" descr="This is the support test strds" semantictype=const
+t.support --v type=strds input=precip_abs1 title="Test support" descr="This is the support test strds" semantictype=mean
 # A simple space ime raster datasets creation and update @test with relative time
-t.create --v --o type=strds temporaltype=relative output=precip_rel1 title="Test" descr="This is the 1 test strds" semantictype=event
+t.create --v --o type=strds temporaltype=relative output=precip_rel1 title="Test" descr="This is the 1 test strds" semantictype=min
 t.info type=strds input=precip_rel1
-t.support --v type=strds input=precip_rel1 title="Test support" descr="This is the support test strds" semantictype=continuous
+t.support --v type=strds input=precip_rel1 title="Test support" descr="This is the support test strds" semantictype=max
 t.remove --v type=strds input=precip_abs1,precip_rel1
Modified: grass/trunk/temporal/t.topology/test.t.topology.abstime.sh
--- grass/trunk/temporal/t.topology/test.t.topology.abstime.sh	2012-02-13 14:35:00 UTC (rev 50794)
+++ grass/trunk/temporal/t.topology/test.t.topology.abstime.sh	2012-02-13 14:55:21 UTC (rev 50795)
@@ -87,36 +87,36 @@
 t.create --o type=strds temporaltype=absolute output=precip_abs title="A test with input files" descr="A test with input files"
 t.create --o type=strds temporaltype=absolute output=maps title="A test with maps in input files" descr="A test with maps in input files"
-tr.register -i input=precip_abs file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=rast -i input=precip_abs file="${n1}" start="2001-01-01" increment="1 months"
 cat "${n1}"
 t.topology    input=precip_abs
 t.topology -m input=precip_abs
-tr.register -i input=precip_abs file="${n2}" start=file
+t.register type=rast -i input=precip_abs file="${n2}"
 cat "${n2}"
-tr.register -i input=precip_abs file="${n3}" start=file end=file
+t.register type=rast -i input=precip_abs file="${n3}"
 cat "${n3}"
-tr.register -i input=precip_abs file="${n4}" start=file end=file
+t.register type=rast -i input=precip_abs file="${n4}"
 cat "${n4}"
-tr.register -i input=precip_abs file="${n5}" start=file end=file
+t.register type=rast -i input=precip_abs file="${n5}"
 cat "${n5}"
-tr.register -i input=maps file="${n6}" start=file end=file
+t.register type=rast -i input=maps file="${n6}"
 cat "${n6}"
 t.topology    input=maps
 t.topology -m input=maps
 t.remove type=strds input=precip_abs,maps
-t.remove type=rast file="${n1}"
-t.remove type=rast input=A,B,C,D
+t.unregister type=rast file="${n1}"
+t.unregister type=rast maps=A,B,C,D
Modified: grass/trunk/temporal/t.topology/test.t.topology.reltime.sh
--- grass/trunk/temporal/t.topology/test.t.topology.reltime.sh	2012-02-13 14:35:00 UTC (rev 50794)
+++ grass/trunk/temporal/t.topology/test.t.topology.reltime.sh	2012-02-13 14:55:21 UTC (rev 50795)
@@ -74,31 +74,31 @@
 t.create --o type=strds temporaltype=relative output=precip_rel_d title="A test with input files of unti days" descr="A test with input files"
 t.create --o type=strds temporaltype=relative output=precip_rel_y title="A test with input files of unit years" descr="A test with input files"
-tr.register -i --v input=precip_rel_d file="${n1}" start=0 increment=1 unit=days
+t.register type=rast -i --v input=precip_rel_d file="${n1}" start=0 increment=1 unit=days
 cat "${n1}"
 t.topology    input=precip_rel_d
 t.topology -m input=precip_rel_d
-tr.register -i input=precip_rel_d file="${n2}" start=file unit=days
+t.register type=rast -i input=precip_rel_d file="${n2}" unit=days
 cat "${n2}"
-tr.register -i input=precip_rel_d file="${n3}" start=file end=file unit=days
+t.register type=rast -i input=precip_rel_d file="${n3}" unit=days
 cat "${n3}"
-tr.register -i input=precip_rel_y file="${n4}" start=file end=file unit=years
+t.register type=rast -i input=precip_rel_y file="${n4}" unit=years
 cat "${n4}"
 t.topology    input=precip_rel_y
 t.topology -m input=precip_rel_y
-tr.register -i input=precip_rel_y file="${n5}" start=file end=file unit=years
+t.register type=rast -i input=precip_rel_y file="${n5}" unit=years
 cat "${n5}"
 t.remove type=strds input=precip_rel_d
 t.remove type=strds input=precip_rel_y
Modified: grass/trunk/temporal/tr.univar/test.tr.univar.sh
--- grass/trunk/temporal/tr.univar/test.tr.univar.sh	2012-02-13 14:35:00 UTC (rev 50794)
+++ grass/trunk/temporal/tr.univar/test.tr.univar.sh	2012-02-13 14:55:21 UTC (rev 50795)
@@ -13,10 +13,10 @@
 r.mapcalc --o expr="prec_6 = rand(0, 650)"
 t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-tr.register --v -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
+t.register type=rast --v -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
 # The first @test
 tr.univar -he input=precip_abs1
 t.remove type=strds input=precip_abs1
Modified: grass/trunk/temporal/tv.list/test.tv.list.layer.sh
--- grass/trunk/temporal/tv.list/test.tv.list.layer.sh	2012-02-13 14:35:00 UTC (rev 50794)
+++ grass/trunk/temporal/tv.list/test.tv.list.layer.sh	2012-02-13 14:55:21 UTC (rev 50795)
@@ -33,48 +33,48 @@
 n5=`g.tempfile pid=5 -d`
 cat > "${n1}" << EOF
-soils|1
-soils|2
-soils|3
-soils|4
-soils|5
-soils|6
+soils:1
+soils:2
+soils:3
+soils:4
+soils:5
+soils:6
 EOF
 cat > "${n2}" << EOF
-soils|1|2001-01-01
-soils|2|2001-02-01
-soils|3|2001-03-01
-soils|4|2001-04-01
-soils|5|2001-05-01
-soils|6|2001-06-01
+soils:1|2001-01-01
+soils:2|2001-02-01
+soils:3|2001-03-01
+soils:4|2001-04-01
+soils:5|2001-05-01
+soils:6|2001-06-01
 EOF
 cat > "${n3}" << EOF
-soils|1|2001-01-01|2001-04-01
-soils|2|2001-05-01|2001-07-01
-soils|3|2001-08-01|2001-10-01
-soils|4|2001-11-01|2002-01-01
-soils|5|2002-02-01|2002-04-01
-soils|6|2002-05-01|2002-07-01
+soils:1|2001-01-01|2001-04-01
+soils:2|2001-05-01|2001-07-01
+soils:3|2001-08-01|2001-10-01
+soils:4|2001-11-01|2002-01-01
+soils:5|2002-02-01|2002-04-01
+soils:6|2002-05-01|2002-07-01
 EOF
 cat > "${n4}" << EOF
-soils|1|2001-01-01|2001-07-01
-soils|2|2001-02-01|2001-04-01
-soils|3|2001-03-01|2001-04-01
-soils|4|2001-04-01|2001-06-01
-soils|5|2001-05-01|2001-06-01
-soils|6|2001-06-01|2001-07-01
+soils:1|2001-01-01|2001-07-01
+soils:2|2001-02-01|2001-04-01
+soils:3|2001-03-01|2001-04-01
+soils:4|2001-04-01|2001-06-01
+soils:5|2001-05-01|2001-06-01
+soils:6|2001-06-01|2001-07-01
 EOF
 cat > "${n5}" << EOF
-soils|1|2001-01-01|2001-03-11
-soils|3|2001-03-01|2001-06-02
-soils|4|2001-04-01|2001-04-01
-soils|5|2001-05-01|2001-05-01
+soils:1|2001-01-01|2001-03-11
+soils:3|2001-03-01|2001-06-02
+soils:4|2001-04-01|2001-04-01
+soils:5|2001-05-01|2001-05-01
 EOF
 t.create --o type=stvds temporaltype=absolute output=soils_abs1 title="A test with input files" descr="A test with input files"
@@ -84,38 +84,38 @@
 t.create --o type=stvds temporaltype=absolute output=soils_abs5 title="A test with input files" descr="A test with input files"
 # The first @test
-tv.register    input=soils_abs1 file="${n1}" layer=file start="2001-01-01" increment="1 months"
+t.register type=vect    input=soils_abs1 file="${n1}" start="2001-01-01" increment="1 months"
 tv.list    fs=" | " method=comma     input=soils_abs1
 tv.list -h input=soils_abs1
 tv.list -h fs=" | " method=cols      input=soils_abs1
 tv.list -h fs=" | " method=delta     input=soils_abs1
 tv.list -h fs=" | " method=deltagaps input=soils_abs1
-tv.register -i input=soils_abs2 file="${n2}" layer=file start=file
+t.register type=vect -i input=soils_abs2 file="${n2}"
 tv.list    fs=" | " method=comma     input=soils_abs2
 tv.list -h input=soils_abs2
 tv.list -h fs=" | " method=cols      input=soils_abs2
 tv.list -h fs=" | " method=delta     input=soils_abs2
 tv.list -h fs=" | " method=deltagaps input=soils_abs2
-tv.register -i input=soils_abs3 file="${n3}" layer=file start=file end=file
+t.register type=vect -i input=soils_abs3 file="${n3}"
 tv.list    fs=" | " method=comma     input=soils_abs3
 tv.list -h fs=" | " method=delta     input=soils_abs3
 tv.list -h fs=" | " method=deltagaps input=soils_abs3
-tv.register -i input=soils_abs4 file="${n4}" layer=file start=file end=file
+t.register type=vect -i input=soils_abs4 file="${n4}"
 tv.list    fs=" | " method=comma     input=soils_abs4
 tv.list -h fs=" | " method=delta     input=soils_abs4
 tv.list -h fs=" | " method=deltagaps input=soils_abs4
-tv.register -i input=soils_abs5 file="${n5}" layer=file start=file end=file
+t.register type=vect -i input=soils_abs5 file="${n5}"
 tv.list    fs=" | " method=comma     input=soils_abs5
 tv.list -h input=soils_abs5
 tv.list -h fs=" | " method=cols      input=soils_abs5
 tv.list -h fs=" | " method=delta     input=soils_abs5
 tv.list -h fs=" | " method=deltagaps input=soils_abs5
-t.remove type=vect input=soils:1,soils:2,soils:3,soils:4,soils:5,soils:6
+t.unregister type=vect maps=soils:1,soils:2,soils:3,soils:4,soils:5,soils:6
 t.remove type=stvds input=soils_abs1,soils_abs2,soils_abs3,soils_abs4,soils_abs5
 g.remove vect=soil_orig,soils
Modified: grass/trunk/temporal/tv.list/test.tv.list.sh
--- grass/trunk/temporal/tv.list/test.tv.list.sh	2012-02-13 14:35:00 UTC (rev 50794)
+++ grass/trunk/temporal/tv.list/test.tv.list.sh	2012-02-13 14:55:21 UTC (rev 50795)
@@ -70,36 +70,36 @@
 t.create --o type=stvds temporaltype=absolute output=lidar_abs5 title="A test with input files" descr="A test with input files"
 # The first @test
-tv.register    input=lidar_abs1 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=vect  input=lidar_abs1 file="${n1}" start="2001-01-01" increment="1 months"
 tv.list    fs=" | " method=comma     input=lidar_abs1
 tv.list -h input=lidar_abs1
 tv.list -h fs=" | " method=cols      input=lidar_abs1
 tv.list -h fs=" | " method=delta     input=lidar_abs1
 tv.list -h fs=" | " method=deltagaps input=lidar_abs1
-tv.register -i input=lidar_abs2 file="${n2}" start=file
+t.register type=vect -i input=lidar_abs2 file="${n2}"
 tv.list    fs=" | " method=comma     input=lidar_abs2
 tv.list -h input=lidar_abs2
 tv.list -h fs=" | " method=cols      input=lidar_abs2
 tv.list -h fs=" | " method=delta     input=lidar_abs2
 tv.list -h fs=" | " method=deltagaps input=lidar_abs2
-tv.register -i input=lidar_abs3 file="${n3}" start=file end=file
+t.register type=vect -i input=lidar_abs3 file="${n3}"
 tv.list    fs=" | " method=comma     input=lidar_abs3
 tv.list -h fs=" | " method=delta     input=lidar_abs3
 tv.list -h fs=" | " method=deltagaps input=lidar_abs3
-tv.register -i input=lidar_abs4 file="${n4}" start=file end=file
+t.register type=vect -i input=lidar_abs4 file="${n4}"
 tv.list    fs=" | " method=comma     input=lidar_abs4
 tv.list -h fs=" | " method=delta     input=lidar_abs4
 tv.list -h fs=" | " method=deltagaps input=lidar_abs4
-tv.register -i input=lidar_abs5 file="${n5}" start=file end=file
+t.register type=vect -i input=lidar_abs5 file="${n5}"
 tv.list    fs=" | " method=comma     input=lidar_abs5
 tv.list -h input=lidar_abs5
 tv.list -h fs=" | " method=cols      input=lidar_abs5
 tv.list -h fs=" | " method=delta     input=lidar_abs5
 tv.list -h fs=" | " method=deltagaps input=lidar_abs5
-t.remove type=vect input=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
+t.unregister type=vect maps=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
 t.remove type=stvds input=lidar_abs1,lidar_abs2,lidar_abs3,lidar_abs4,lidar_abs5
