[GRASS-SVN] r50805 - grass/trunk/vector/v.surf.bspline
Mon Feb 13 18:31:01 EST 2012
Author: hamish
Date: 2012-02-13 15:31:01 -0800 (Mon, 13 Feb 2012)
New Revision: 50805
   grass/trunk/vector/v.surf.bspline/main.c
change default lambda_i to 0.01 (see #1088), add some code comments about where to multi-thread it, and a debug message
Modified: grass/trunk/vector/v.surf.bspline/main.c
--- grass/trunk/vector/v.surf.bspline/main.c	2012-02-13 21:59:09 UTC (rev 50804)
+++ grass/trunk/vector/v.surf.bspline/main.c	2012-02-13 23:31:01 UTC (rev 50805)
@@ -164,7 +164,7 @@
     lambda_f_opt->type = TYPE_DOUBLE;
     lambda_f_opt->required = NO;
     lambda_f_opt->description = _("Tykhonov regularization parameter (affects smoothing)");
-    lambda_f_opt->answer = "1";
+    lambda_f_opt->answer = "0.01";
     lambda_f_opt->guisection = _("Settings");
     dfield_opt = G_define_standard_option(G_OPT_V_FIELD);
@@ -443,6 +443,7 @@
 	seg_size = (seg_size * SEGSIZE * SEGSIZE) / (1 << 20);
 	segments_in_memory = seg_mb / seg_size + 0.5;
+	G_debug(1, "%d %dx%d segments held in memory", segments_in_memory, SEGSIZE, SEGSIZE);
 	out_file = G_tempfile();
 	out_fd = creat(out_file, 0666);
@@ -586,6 +587,10 @@
 	last_column = FALSE;
 	subregion_col = 0;
+	/* TODO: process each subregion using its own thread (via OpenMP or pthreads) */
+	/*     I'm not sure about pthreads, but you can tell OpenMP to start all at the
+		same time and it will keep num_workers supplied with the next job as free
+		cpus become available */
 	while (last_column == FALSE) {	/* For each subregion column */
 	    int npoints = 0;
 	    /* needed for sparse points interpolation */
