[GRASS-SVN] r50807 - in grass/trunk: lib/python/temporal temporal/tr.list temporal/tr.out.vtk temporal/tr.series temporal/tr.to.rast3
Mon Feb 13 19:04:11 EST 2012
Author: huhabla
Date: 2012-02-13 16:04:11 -0800 (Mon, 13 Feb 2012)
New Revision: 50807
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/temporal/tr.list/test.tr.list.sh
   grass/trunk/temporal/tr.out.vtk/test.tr.out.vtk.sh
   grass/trunk/temporal/tr.series/test.tr.series.sh
   grass/trunk/temporal/tr.to.rast3/test.tr.to.rast3.sh
   grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py
Modified tests to use t.register and t.unregister.
tr.to.rast3 now creates space time voxel cubes with time stamps and
vertical unit.
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-02-13 23:34:14 UTC (rev 50806)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-02-14 00:04:11 UTC (rev 50807)
@@ -538,7 +538,7 @@
                     if self.is_time_absolute():
                         map.set_absolute_time(start, end)
                     elif self.is_time_relative():
-                        map.set_relative_time(start, end)
+                        map.set_relative_time(start, end, self.get_relative_time_unit())
                     maplist.append(copy.copy(map))
                 result["samples"] = maplist
@@ -549,7 +549,7 @@
@@ -618,7 +618,7 @@
                         map.set_absolute_time(start, next)
-                        map.set_relative_time(start, next)
+                        map.set_relative_time(start, next, self.get_relative_time_unit())
@@ -677,7 +677,7 @@
                         obj_list.append(copy.copy(map))
         if connect == True:
Modified: grass/trunk/temporal/tr.list/test.tr.list.sh
--- grass/trunk/temporal/tr.list/test.tr.list.sh	2012-02-13 23:34:14 UTC (rev 50806)
+++ grass/trunk/temporal/tr.list/test.tr.list.sh	2012-02-14 00:04:11 UTC (rev 50807)
@@ -72,7 +72,7 @@
 t.create --o type=strds temporaltype=absolute output=precip_abs5 title="A test with input files" descr="A test with input files"
 # The @test
-tr.register -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=rast -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
 tr.list    fs=" | " method=comma     input=precip_abs0
 tr.list -h input=precip_abs1
 tr.list -h fs=" | " method=cols      input=precip_abs0
@@ -80,7 +80,7 @@
 tr.list -h fs=" | " method=deltagaps input=precip_abs0
 tr.list -h fs=" | " method=gran      input=precip_abs0
-tr.register    input=precip_abs1 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=rast    input=precip_abs1 file="${n1}" start="2001-01-01" increment="1 months"
 tr.list    fs=" | " method=comma     input=precip_abs1
 tr.list -h fs=" | " method=cols      input=precip_abs1
@@ -88,7 +88,7 @@
 tr.list -h fs=" | " method=deltagaps input=precip_abs1
 tr.list -h fs=" | " method=gran      input=precip_abs1
-tr.register -i input=precip_abs2 file="${n2}" start=file
+t.register type=rast -i input=precip_abs2 file="${n2}"
 tr.list    fs=" | " method=comma     input=precip_abs2
 tr.list -h input=precip_abs2
 tr.list -h fs=" | " method=cols      input=precip_abs2
@@ -96,19 +96,19 @@
 tr.list -h fs=" | " method=deltagaps input=precip_abs2
 tr.list -h fs=" | " method=gran      input=precip_abs2
-tr.register -i input=precip_abs3 file="${n3}" start=file end=file
+t.register type=rast -i input=precip_abs3 file="${n3}"
 tr.list    fs=" | " method=comma     input=precip_abs3
 tr.list -h fs=" | " method=delta     input=precip_abs3
 tr.list -h fs=" | " method=deltagaps input=precip_abs3
 tr.list -h fs=" | " method=gran      input=precip_abs3
-tr.register -i input=precip_abs4 file="${n4}" start=file end=file
+t.register type=rast -i input=precip_abs4 file="${n4}"
 tr.list    fs=" | " method=comma     input=precip_abs4
 tr.list -h fs=" | " method=delta     input=precip_abs4
 tr.list -h fs=" | " method=deltagaps input=precip_abs4
 tr.list -h fs=" | " method=gran      input=precip_abs4
-tr.register -i input=precip_abs5 file="${n5}" start=file end=file
+t.register type=rast -i input=precip_abs5 file="${n5}"
 tr.list    fs=" | " method=comma     input=precip_abs5
 tr.list -h input=precip_abs5
 tr.list -h fs=" | " method=cols      input=precip_abs5
@@ -116,5 +116,5 @@
 tr.list -h fs=" | " method=deltagaps input=precip_abs5
 tr.list -h fs=" | " method=gran      input=precip_abs5
-t.remove type=rast input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
 t.remove type=strds input=precip_abs0,precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5
Modified: grass/trunk/temporal/tr.out.vtk/test.tr.out.vtk.sh
--- grass/trunk/temporal/tr.out.vtk/test.tr.out.vtk.sh	2012-02-13 23:34:14 UTC (rev 50806)
+++ grass/trunk/temporal/tr.out.vtk/test.tr.out.vtk.sh	2012-02-14 00:04:11 UTC (rev 50807)
@@ -31,17 +31,17 @@
 # The first @test
 mkdir /tmp/test1
-tr.register -i input=precip_abs1 file="${n1}" start=file end=file
+t.register -i type=rast input=precip_abs1 file="${n1}"
 tr.out.vtk input=precip_abs1 expdir=/tmp/test1
 ls -al /tmp/test1
 mkdir /tmp/test2
-tr.register -i input=precip_abs2 file="${n1}"
+t.register -i type=rast input=precip_abs2 file="${n1}"
 tr.out.vtk input=precip_abs2 expdir=/tmp/test2 elevation=elevation
 ls -al /tmp/test2
 mkdir /tmp/test3
-tr.register -i input=precip_abs3 file="${n1}"
+t.register -i type=rast input=precip_abs3 file="${n1}"
 tr.out.vtk -g input=precip_abs3 expdir=/tmp/test3 elevation=elevation
 ls -al /tmp/test3
@@ -49,5 +49,5 @@
 rm -rf /tmp/test2
 rm -rf /tmp/test3
 t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3
Modified: grass/trunk/temporal/tr.series/test.tr.series.sh
--- grass/trunk/temporal/tr.series/test.tr.series.sh	2012-02-13 23:34:14 UTC (rev 50806)
+++ grass/trunk/temporal/tr.series/test.tr.series.sh	2012-02-14 00:04:11 UTC (rev 50807)
@@ -1,12 +1,5 @@
-# This is a test to register and unregister raster maps in
-# space time raster input.
-# The raster maps will be registered in different space time raster
-# inputs
 # We need to set a specific region in the
-# @preprocess step of this test. We generate
-# raster with r.mapcalc and create two space time raster inputs
-# with relative and absolute time
+# @preprocess step of this test.
 # The region setting should work for UTM and LL test locations
 g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
@@ -17,18 +10,16 @@
 r.mapcalc --o expr="prec_5 = 500"
 r.mapcalc --o expr="prec_6 = 600"
-# The first @test
-# We create the space time raster inputs and register the raster maps with absolute time interval
+# @test
 t.create --v --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
-tr.register --v input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 months"
+t.register --v type=rast input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 months"
 tr.series --o input=precip_abs method=average output=prec_average where="start_time > '2001-03-01'"
 tr.series --o -t input=precip_abs method=maximum output=prec_max order=start_time
 tr.series --o -t input=precip_abs method=sum output=prec_sum
-t.remove --v type=rast input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.unregister --v type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
 t.remove --v type=strds input=precip_abs
 r.info prec_average
Modified: grass/trunk/temporal/tr.to.rast3/test.tr.to.rast3.sh
--- grass/trunk/temporal/tr.to.rast3/test.tr.to.rast3.sh	2012-02-13 23:34:14 UTC (rev 50806)
+++ grass/trunk/temporal/tr.to.rast3/test.tr.to.rast3.sh	2012-02-14 00:04:11 UTC (rev 50807)
@@ -1,8 +1,3 @@
-# inputs
@@ -17,17 +12,25 @@
-# The first @test
+# @test
 t.create --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
+t.create --o type=strds temporaltype=relative output=precip_rel title="A test" descr="A test"
-tr.register -i input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 months"
+t.register --o --v -i type=rast input=precip_abs maps=prec_1,prec_2,prec_3 start="2001-01-01" increment="1 months"
+t.info type=strds input=precip_abs
-tr.to.rast3 --o input=precip_abs output=preciptiation
+tr.to.rast3 --o input=precip_abs output=precipitation
+t.info type=rast3d input=precipitation
+r3.info precipitation
-t.remove type=strds input=precip_abs
+t.register --o --v -i type=rast input=precip_rel maps=prec_4,prec_5,prec_6 start=0 increment=100 unit=years
+t.info type=strds input=precip_rel
-r3.info preciptiation
-g.region s=0 n=80 w=0 e=120 b=0 t=1 res=10 res3=1
+tr.to.rast3 --o input=precip_rel output=precipitation
+t.remove type=strds input=precip_abs,precip_rel
Modified: grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py
--- grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py	2012-02-13 23:34:14 UTC (rev 50806)
+++ grass/trunk/temporal/tr.to.rast3/tr.to.rast3.py	2012-02-14 00:04:11 UTC (rev 50807)
@@ -64,13 +64,14 @@
     maps = sp.get_registered_maps_as_objects_by_granularity()
-    # Compute relative granularity and set bottom, top and top-bottom resolution
+    # Get the granularity and set bottom, top and top-bottom resolution
     granularity = sp.get_granularity()
-    # We do not convert months or years into days, we simply use
-    # The digit of the string as topo-bottom resolution
     if sp.is_time_absolute():
+        unit = granularity.split(" ")[1]
         granularity = int(granularity.split(" ")[0])
+    else:
+        unit = sp.get_relative_time_unit()
     num_maps = len(maps)
     bottom = 0
@@ -81,7 +82,7 @@
     if ret != 0:
         grass.fatal(_("Unable to set 3d region"))
-    # Create a NULL map in case of granularity support
+    # Create a NULL map to fill the gaps
     null_map = "temporary_null_map_%i" % os.getpid()
     grass.mapcalc("%s = null()" % (null_map))
@@ -109,6 +110,37 @@
     grass.run_command("g.remove", rast=null_map)
+    title = _("Space time voxel cube")
+    descr = _("This space time voxel cube was created with tr.to.rast3")
+    # Set the unit
+    ret = grass.run_command("r3.support", map=output, vunit=unit, title=title, description=descr, overwrite=grass.overwrite())
+    # Register the space time voxel cube in the temporal GIS
+    if output.find("@") >= 0:
+        id = output
+    else:
+        id = output + "@" + mapset
+    start, end = sp.get_valid_time()
+    r3ds = tgis.raster3d_dataset(id)
+    if r3ds.is_in_db():
+        r3ds.select()
+        r3ds.delete()
+    r3ds.load()
+    if sp.is_time_absolute():
+        r3ds.set_absolute_time(start, end)
+        r3ds.write_absolute_time_to_file()
+    else:
+        r3ds.set_relative_time(start, end, sp.get_relative_time_unit())
+        r3ds.write_relative_time_to_file()
+    r3ds.insert()
 if __name__ == "__main__":
     options, flags = grass.parser()
     main()
