[GRASS-SVN] r50821 - grass/trunk/raster/r.in.gdal
Wed Feb 15 12:34:13 EST 2012
Author: martinl
Date: 2012-02-15 09:34:13 -0800 (Wed, 15 Feb 2012)
New Revision: 50821
   grass/trunk/raster/r.in.gdal/main.c
r.in.gdal: add some more debug messages
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2012-02-15 09:33:48 UTC (rev 50820)
+++ grass/trunk/raster/r.in.gdal/main.c	2012-02-15 17:34:13 UTC (rev 50821)
@@ -249,10 +249,11 @@
     hDS = GDALOpen(input, GA_ReadOnly);
     if (hDS == NULL)
-	return 1;
+	exit(EXIT_FAILURE);
     hDriver = GDALGetDatasetDriver(hDS);	/* needed for AVHRR data */
     /* L1B - NOAA/AVHRR data must be treated differently */
     /* for hDriver names see gdal/frmts/gdalallregister.cpp */
+    G_debug(3, "GDAL Driver: %s", GDALGetDriverShortName(hDriver));
     if (strcmp(GDALGetDriverShortName(hDriver), "L1B") != 0)
 	l1bdriver = 0;
     else {
@@ -262,9 +263,14 @@
 		    "thin plate spline rectification instead. (-tps)"));
+    /* zero cell header */
+    G_zero(&cellhd, sizeof(struct Cell_head));
     /*      Set up the window representing the data we have.                */
+    G_debug(3, "GDAL size: row = %d, col = %d", GDALGetRasterYSize(hDS),
+	    GDALGetRasterXSize(hDS));
     cellhd.rows = GDALGetRasterYSize(hDS);
     cellhd.rows3 = GDALGetRasterYSize(hDS);
     cellhd.cols = GDALGetRasterXSize(hDS);
@@ -504,9 +510,12 @@
 	I_init_group_ref(&ref);
+	colornamebuf2[0] = '\0';
 	for (nBand = 1; nBand <= GDALGetRasterCount(hDS); nBand++) {
+	    G_debug(3, "Import raster band %d", nBand);
 	    hBand = GDALGetRasterBand(hDS, nBand);
-	    hBand = GDALGetRasterBand(hDS, nBand);
+	    if (!hBand)
+		G_fatal_error(_("Unable to get raster band number %d"), nBand);
 	    if (!flag_k->answer) {
 		/* use channel color names if present: */
 		strcpy(colornamebuf,
@@ -722,7 +731,7 @@
     /*      Select a cell type for the new cell.                            */
     eRawGDT = GDALGetRasterDataType(hBand);
     switch (eRawGDT) {
     case GDT_Float32:
     case GDT_Float64:
