[GRASS-SVN] r50835 - grass-addons/grass7/imagery/i.topo.corr
Thu Feb 16 06:12:59 EST 2012
Author: mmetz
Date: 2012-02-16 03:12:59 -0800 (Thu, 16 Feb 2012)
New Revision: 50835
   grass-addons/grass7/imagery/i.topo.corr/correction.c
   grass-addons/grass7/imagery/i.topo.corr/main.c
i.topo.corr: various bug fixes
Modified: grass-addons/grass7/imagery/i.topo.corr/correction.c
--- grass-addons/grass7/imagery/i.topo.corr/correction.c	2012-02-16 09:57:01 UTC (rev 50834)
+++ grass-addons/grass7/imagery/i.topo.corr/correction.c	2012-02-16 11:12:59 UTC (rev 50835)
@@ -40,29 +40,19 @@
 	for (row = 0; row < nrows; row++) {
 	    G_percent(row, nrows, 2);
-	    Rast_get_row(band->fd, band->rast, row, DCELL_TYPE);
+	    Rast_get_row(band->fd, band->rast, row, band->type);
 	    Rast_get_row(cosi->fd, cosi->rast, row, cosi->type);
+	    pref = band->rast;
+	    pcos = cosi->rast;
 	    for (col = 0; col < ncols; col++) {
-		switch (cosi->type) {
-		case FCELL_TYPE:
-		    pcos = (void *)((FCELL *) cosi->rast + col);
-		    cos_i = (double)((FCELL *) cosi->rast)[col];
-		    break;
-		case DCELL_TYPE:
-		    pcos = (void *)((DCELL *) cosi->rast + col);
-		    cos_i = (double)((DCELL *) cosi->rast)[col];
-		    break;
-		default:
-		    pcos = NULL;
-		    cos_i = 0.;
-		    break;
-		pref = (void *)((DCELL *) band->rast + col);
+		cos_i = Rast_get_d_value(pcos, cosi->type);
-		if (!Rast_is_null_value(pref, DCELL_TYPE) &&
+		if (!Rast_is_null_value(pref, band->type) &&
 		    !Rast_is_null_value(pcos, cosi->type)) {
-		    ref_i = (double)*((DCELL *) pref);
+		    ref_i = Rast_get_d_value(pref, band->type);
 		    switch (method) {
 		    case MINNAERT:
 			if (cos_i > 0. && cos_z > 0. && ref_i > 0.) {
@@ -88,6 +78,8 @@
 			break;
+		pref = G_incr_void_ptr(pref, Rast_cell_size(band->type));
+		pcos = G_incr_void_ptr(pcos, Rast_cell_size(cosi->type));
 	m = (n == 0.) ? 1. : (n * sxy - sx * sy) / (n * sxx - sx * sx);
@@ -121,30 +113,19 @@
+	Rast_set_null_value(out->rast, ncols, DCELL_TYPE);
-	    case FCELL_TYPE:
-		cos_i = (double)*((FCELL *) pcos);
-		break;
-	    case DCELL_TYPE:
-		cos_i = (double)*((DCELL *) pcos);
-		break;
-	    default:
-		pcos = NULL;
-		cos_i = 0.;
-		break;
-	    if (pcos == NULL ||
-		Rast_is_null_value(pref, DCELL_TYPE) ||
-		Rast_is_null_value(pcos, cosi->type)) {
-		Rast_set_null_value((DCELL *) out->rast + col, 1, DCELL_TYPE);
-	    else {
+		!Rast_is_null_value(pcos, cosi->type)) {
 		((DCELL *) out->rast)[col] =
 		    (DCELL) (ref_i * pow((cos_z + cka) / (cos_i + ckb), kk));
 		G_debug(3,
@@ -152,6 +133,8 @@
 			ref_i, cka, cos_i, ckb, kk,
 			((DCELL *) out->rast)[col]);
 	Rast_put_row(out->fd, out->rast, out->type);
Modified: grass-addons/grass7/imagery/i.topo.corr/main.c
--- grass-addons/grass7/imagery/i.topo.corr/main.c	2012-02-16 09:57:01 UTC (rev 50834)
+++ grass-addons/grass7/imagery/i.topo.corr/main.c	2012-02-16 11:12:59 UTC (rev 50835)
@@ -30,8 +30,6 @@
     struct GModule *module;
     struct Cell_head hd_band, hd_dem, window;
-    char bufname[128];		/* TODO: use GNAME_MAX? */
     int i;
     struct Option *base, *output, *input, *zeni, *azim, *metho;
     struct Flag *ilum;
@@ -101,6 +99,7 @@
 	    (_("Reflectance maps are necessary to make topographic correction"));
     zenith = atof(zeni->answer);
+    out.type = DCELL_TYPE;
     /* Evaluate only cos_i raster file */
     /* i.topo.corr -i out=cosi.on07 base=SRTM_v2 zenith=33.3631 azimuth=59.8897 */
@@ -109,18 +108,18 @@
 	azimuth = atof(azim->answer);
 	/* Warning: make buffers and output after set window */
 	strcpy(dem.name, base->answer);
-	dem.fd = Rast_open_old(dem.name, "");
-	dem.type = Rast_get_map_type(dem.fd);
 	/* Set window to DEM file */
 	Rast_get_window(&window);
 	Rast_get_cellhd(dem.name, "", &hd_dem);
 	Rast_align_window(&window, &hd_dem);
+	dem.fd = Rast_open_old(dem.name, "");
+	dem.type = Rast_get_map_type(dem.fd);
 	/* Open and buffer of the output file */
 	strcpy(out.name, output->answer);
 	out.fd = Rast_open_new(output->answer, DCELL_TYPE);
 	out.rast = Rast_allocate_buf(out.type);
 	/* Open and buffer of the elevation file */
-	dem.rast = Rast_allocate_buf(DCELL_TYPE);
+	dem.rast = Rast_allocate_buf(dem.type);
 	eval_cosi(&out, &dem, zenith, azimuth);
 	/* Close files, buffers, and write history */
 	G_free(dem.rast);
@@ -153,7 +152,8 @@
 	    G_fatal_error(_("Invalid method: %s"), metho->answer);
 	dem.fd = Rast_open_old(base->answer, "");
-	dem.type= Rast_open_old(base->answer, "");
+	Rast_close(dem.fd);
 	if (dem.type == CELL_TYPE)
 	    G_fatal_error(_("Illumination model is of CELL type"));
@@ -161,6 +161,8 @@
 	    G_message(_("Band %s: "), input->answers[i]);
 	    /* Abre fichero de bandas y el de salida */
 	    strcpy(band.name, input->answers[i]);
+	    Rast_get_cellhd(band.name, "", &hd_band);
+	    Rast_set_window(&hd_band);	/* Antes de out_open y allocate para mismo tamaño */
 	    band.fd = Rast_open_old(band.name, "");
 	    band.type = Rast_get_map_type(band.fd);
 	    if (band.type != DCELL_TYPE) {
@@ -169,12 +171,11 @@
 		Rast_close(band.fd);
 		continue;
-	    Rast_get_cellhd(band.name, "", &hd_band);
-	    Rast_set_window(&hd_band);	/* Antes de out_open y allocate para mismo tamaño */
-	    snprintf(bufname, 127, "%s.%s", output->answer,
+	    dem.fd = Rast_open_old(base->answer, "");
+	    snprintf(out.name, GNAME_MAX - 1, "%s.%s", output->answer,
 		     input->answers[i]);
-	    out.fd = Rast_open_new(bufname, DCELL_TYPE);
+	    out.fd = Rast_open_new(out.name, DCELL_TYPE);
 	    band.rast = Rast_allocate_buf(band.type);
@@ -182,6 +183,7 @@
 	    eval_tcor(method, &out, &dem, &band, zenith);
 	    G_free(dem.rast);
 	    G_free(band.rast);
 	    G_free(out.rast);
@@ -194,13 +196,13 @@
 		struct FPRange range;
 		DCELL min, max;
 		struct Colors grey;
 		Rast_read_fp_range(out.name, G_mapset(), &range);
 		Rast_get_fp_range_min_max(&range, &min, &max);
 		Rast_make_grey_scale_colors(&grey, min, max);
 		Rast_write_colors(out.name, G_mapset(), &grey);
-	Rast_close(dem.fd);
     exit(EXIT_SUCCESS);
