[GRASS-SVN] r50874 - in grass/branches/releasebranch_6_4: . mswindows mswindows/osgeo4w
Sun Feb 19 09:53:42 EST 2012
Author: martinl
Date: 2012-02-19 06:53:42 -0800 (Sun, 19 Feb 2012)
New Revision: 50874
Added:
   grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl
   grass/branches/releasebranch_6_4/mswindows/GRASS-Packager.bat.tmpl
   grass/branches/releasebranch_6_4/mswindows/Makefile
Removed:
   grass/branches/releasebranch_6_4/Makefile
   grass/branches/releasebranch_6_4/mswindows/env.bat
   grass/branches/releasebranch_6_4/mswindows/osgeo4w/env.bat.tmpl
wingrass: backport from devbr6
Modified: grass/branches/releasebranch_6_4/Makefile
--- grass/branches/releasebranch_6_4/Makefile	2012-02-19 14:45:36 UTC (rev 50873)
+++ grass/branches/releasebranch_6_4/Makefile	2012-02-19 14:53:42 UTC (rev 50874)
@@ -47,7 +47,8 @@
 	vector \
 	visualization \
 	man \
-	macosx
+	macosx \
+	mswindows
 ifeq ($(strip $(MINGW)),)
 	SUBDIRS += gem
Property changes on: grass/branches/releasebranch_6_4/mswindows
___________________________________________________________________
Added: svn:ignore
   + GRASS-Packager.bat
GRASS-Installer.nsi
Deleted: grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi
--- grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi	2012-02-19 14:45:36 UTC (rev 50873)
+++ grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi	2012-02-19 14:53:42 UTC (rev 50874)
@@ -1,936 +0,0 @@
-;GRASS Installer for Windows
-;Written by Marco Pasetti
-;Updated for OSGeo4W by Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
-;Last Update: $Id$
-;Mail to: grass-dev at lists.osgeo.org
-;Define the source path of the demolocation files
-!define DEMOLOCATION_PATH "c:\osgeo4w\usr\src\grass64_release\demolocation"
-;Define the source of the patched msys.bat
-!define MSYS_BATCH "C:\OSGeo4W\usr\src\grass64_release\mswindows\osgeo4w\msys.bat"
-;Select if you are building a "Development Version" (Devel) or a "Release Version" (Release) of the GRASS Installer
-!define INSTALLER_TYPE "Devel"
-;set compression configuration
-SetCompressor /SOLID lzma
-SetCompressorDictSize 64
-;Version variables
-!define SVN_REVISION "36599"
-!define BINARY_REVISION "1"
-!if ${INSTALLER_TYPE} == "Release"
-	!define VERSION_NUMBER "6.4.2"
-	!define GRASS_COMMAND "grass64"
-	!define GRASS_BASE "GRASS 6.4.2"
-!else
-	!define VERSION_NUMBER "6.4.2svn"
-	!define GRASS_COMMAND "grass64svn"
-	!define GRASS_BASE "GRASS 6.4.2svn"
-!endif
-;Don't modify the following lines
-;NSIS Includes
-!include "MUI2.nsh"
-!include "LogicLib.nsh"
-;Set the installer variables, depending on the selected version to build
-!define PACKAGE_FOLDER ".\GRASS-64-Package"
-	!define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
-	!define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-${BINARY_REVISION}"
-	!define CHECK_INSTALL_NAME "GRASS 64"
-!else
-	!define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
-	!define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
-	!define CHECK_INSTALL_NAME "GRASS 64 SVN"
-!endif
-;Publisher variables
-!define PUBLISHER "GRASS Development Team"
-!define WEB_SITE "http://grass.osgeo.org"
-!define WIKI_PAGE "http://grass.osgeo.org/wiki"
-;General Definitions
-;Name of the application shown during install
-Name "${DISPLAYED_NAME}"
-;Name of the output file (installer executable)
-OutFile "${INSTALLER_NAME}"
-;Define installation folder
-InstallDir "$PROGRAMFILES\${GRASS_BASE}"
-;Request application privileges for Windows Vista
-RequestExecutionLevel admin
-;Tell the installer to show Install and Uninstall details as default
-ShowInstDetails show
-ShowUnInstDetails show
-;StrReplace Function
-;Replaces all ocurrences of a given needle within a haystack with another string
-;Written by dandaman32
-Var STR_REPLACE_VAR_0
-Var STR_REPLACE_VAR_1
-Var STR_REPLACE_VAR_2
-Var STR_REPLACE_VAR_3
-Var STR_REPLACE_VAR_4
-Var STR_REPLACE_VAR_5
-Var STR_REPLACE_VAR_6
-Var STR_REPLACE_VAR_7
-Var STR_REPLACE_VAR_8
-Function StrReplace
-	Exch $STR_REPLACE_VAR_2
-	Exch 1
-	Exch $STR_REPLACE_VAR_1
-	Exch 2
-	Exch $STR_REPLACE_VAR_0
-		StrCpy $STR_REPLACE_VAR_3 -1
-		StrLen $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_1
-		StrLen $STR_REPLACE_VAR_6 $STR_REPLACE_VAR_0
-		loop:
-			IntOp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_3 + 1
-			StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_3
-			StrCmp $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_1 found
-			StrCmp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_6 done
-			Goto loop
-		found:
-			StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_3
-			IntOp $STR_REPLACE_VAR_8 $STR_REPLACE_VAR_3 + $STR_REPLACE_VAR_4
-			StrCpy $STR_REPLACE_VAR_7 $STR_REPLACE_VAR_0 "" $STR_REPLACE_VAR_8
-			StrCpy $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_5$STR_REPLACE_VAR_2$STR_REPLACE_VAR_7
-			Goto loop
-		done:
-	Pop $STR_REPLACE_VAR_1 ; Prevent "invalid opcode" errors and keep the
-	Pop $STR_REPLACE_VAR_1 ; stack as it was before the function was called
-FunctionEnd
-!macro _strReplaceConstructor OUT NEEDLE NEEDLE2 HAYSTACK
-	Push "${HAYSTACK}"
-	Push "${NEEDLE}"
-	Push "${NEEDLE2}"
-	Call StrReplace
-	Pop "${OUT}"
-!macroend
-!define StrReplace '!insertmacro "_strReplaceConstructor"'
-;.onInit Function (called when the installer is nearly finished initializing)
-;Check if GRASS is already installed on the system and, if yes, what version and binary release;
-;depending on that, select the install procedure:
-;1. first installation = if GRASS is not already installed
-;install GRASS asking for the install PATH
-;2. upgrade installation = if an older release of GRASS is already installed
-;call the uninstaller of the currently installed GRASS release
-;if the uninstall procedure succeeded, call the current installer without asking for the install PATH
-;GRASS will be installed in the same PATH of the previous installation
-;3. downgrade installation = if a newer release of GRASS is already installed
-;4. repair installation = if the same release of GRASS is already installed
-;if the uninstall procedure succeeded, call the current installer asking for the install PATH
-;the currently installed release of GRASS is defined by the variable $INSTALLED_VERSION = $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
-Function .onInit
-	Var /GLOBAL ASK_FOR_PATH
-	StrCpy $ASK_FOR_PATH "YES"
-	Var /GLOBAL UNINSTALL_STRING
-	Var /GLOBAL INSTALL_PATH
-	Var /GLOBAL INSTALLED_VERSION_NUMBER
-	Var /GLOBAL INSTALLED_SVN_REVISION
-	Var /GLOBAL INSTALLED_BINARY_REVISION
-	Var /GLOBAL DISPLAYED_INSTALLED_VERSION
-	Var /GLOBAL MESSAGE_0_
-	Var /GLOBAL MESSAGE_1_
-	Var /GLOBAL MESSAGE_2_
-	Var /GLOBAL MESSAGE_3_
-	Var /GLOBAL R_HKLM_INSTALL_PATH
-	Var /GLOBAL R_HKCU_INSTALL_PATH
-	ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
-	ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
-	ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
-	ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
-	ReadRegStr $R_HKLM_INSTALL_PATH HKLM "Software\R-core\R" "InstallPath"
-	ReadRegStr $R_HKCU_INSTALL_PATH HKCU "Software\R-core\R" "InstallPath"
-	${If} $INSTALLED_SVN_REVISION == ""
-		ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
-	${EndIf}
-	ReadRegStr $INSTALLED_BINARY_REVISION HKLM "Software\${GRASS_BASE}" "BinaryRevision"
-	StrCpy $MESSAGE_0_ "${CHECK_INSTALL_NAME} is already installed on your system.$\r$\n"
-	StrCpy $MESSAGE_0_ "$MESSAGE_0_$\r$\n"
-	!if ${INSTALLER_TYPE} == "Release"
-		${If} $INSTALLED_BINARY_REVISION == ""
-			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER"
-		${Else}
-			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_BINARY_REVISION"
-		${EndIf}
-	!else
-		StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_SVN_REVISION-$INSTALLED_BINARY_REVISION"
-	!endif
-	StrCpy $MESSAGE_0_ "$MESSAGE_0_The installed release is $DISPLAYED_INSTALLED_VERSION$\r$\n"
-	StrCpy $MESSAGE_1_ "$MESSAGE_0_$\r$\n"
-	StrCpy $MESSAGE_1_ "$MESSAGE_1_You are going to install a newer release of ${CHECK_INSTALL_NAME}$\r$\n"
-	StrCpy $MESSAGE_1_ "$MESSAGE_1_$\r$\n"
-	StrCpy $MESSAGE_1_ "$MESSAGE_1_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
-	StrCpy $MESSAGE_1_ "$MESSAGE_1_ and install ${DISPLAYED_NAME} or Cancel to quit."
-	StrCpy $MESSAGE_2_ "$MESSAGE_0_$\r$\n"
-	StrCpy $MESSAGE_2_ "$MESSAGE_2_You are going to install an older release of ${CHECK_INSTALL_NAME}$\r$\n"
-	StrCpy $MESSAGE_2_ "$MESSAGE_2_$\r$\n"
-	StrCpy $MESSAGE_2_ "$MESSAGE_2_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
-	StrCpy $MESSAGE_2_ "$MESSAGE_2_ and install ${DISPLAYED_NAME} or Cancel to quit."
-	StrCpy $MESSAGE_3_ "$MESSAGE_0_$\r$\n"
-	StrCpy $MESSAGE_3_ "$MESSAGE_3_This is the latest release available.$\r$\n"
-	StrCpy $MESSAGE_3_ "$MESSAGE_3_$\r$\n"
-	StrCpy $MESSAGE_3_ "$MESSAGE_3_Press OK to reinstall ${DISPLAYED_NAME} or Cancel to quit."
-	IntOp $INSTALLED_SVN_REVISION $INSTALLED_SVN_REVISION * 1
-	IntOp $INSTALLED_BINARY_REVISION $INSTALLED_BINARY_REVISION * 1
-	IntOp $INSTALLED_VERSION $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
-	!define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
-	${If} $INSTALLED_VERSION_NUMBER == ""
-	${Else}
-		${If} $INSTALLED_VERSION < ${VERSION}
-			MessageBox MB_OKCANCEL "$MESSAGE_1_" IDOK upgrade IDCANCEL quit_upgrade
-			upgrade:
-				StrCpy $ASK_FOR_PATH "NO"
-				ExecWait '"$UNINSTALL_STRING" _?=$INSTALL_PATH' $0
-				Goto continue_upgrade
-			quit_upgrade:
-				Abort
-			continue_upgrade:
-		${ElseIf} $INSTALLED_VERSION > ${VERSION}
-			MessageBox MB_OKCANCEL "$MESSAGE_2_" IDOK downgrade IDCANCEL quit_downgrade
-			downgrade:
-				Goto continue_downgrade
-			quit_downgrade:
-				Abort
-			continue_downgrade:
-		${ElseIf} $INSTALLED_VERSION = ${VERSION}
-			MessageBox MB_OKCANCEL "$MESSAGE_3_" IDOK reinstall IDCANCEL quit_reinstall
-			reinstall:
-				Goto continue_reinstall
-			quit_reinstall:
-				Abort
-			continue_reinstall:
-		${EndIf}
-	${EndIf}
-	${Else}
-		${If} $0 = 0
-		${Else}
-			Abort
-		${EndIf}
-	${EndIf}
-FunctionEnd
-;CheckUpdate Function
-;Check if to show the MUI_PAGE_DIRECTORY during the installation (to ask for the install PATH)
-Function CheckUpdate
-	${If} $ASK_FOR_PATH == "NO"
-		Abort
-	${EndIf}
-FunctionEnd
-;CheckInstDir Function
-;this is commented out, because the installation path should be in $PROGRAMFILES
-;Check if GRASS is going to be installed in a directory containing spaces
-;if yes, show a warning message
-;Function CheckInstDir
-;	Var /GLOBAL INSTDIR_TEST
-;	Var /GLOBAL INSTDIR_LENGHT
-;	Var /GLOBAL INSTDIR_TEST_LENGHT
-;	Var /GLOBAL MESSAGE_CHKINST_
-;	StrCpy $MESSAGE_CHKINST_ "WARNING: you are about to install GRASS into a directory that has spaces$\r$\n"
-;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_in either its name or the path of directories leading up to it.$\r$\n"
-;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_Some functionalities of GRASS might be hampered by this. We would highly$\r$\n"
-;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_appreciate if you tried and reported any problems, so that we can fix them.$\r$\n"
-;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_However, if you want to avoid any such issues, we recommend that you$\r$\n"
-;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_choose a simple installation path without spaces, such as: C:\${GRASS_BASE}.$\r$\n"
-;	${StrReplace} "$INSTDIR_TEST" " " "" "$INSTDIR"
-;	StrLen $INSTDIR_LENGHT "$INSTDIR"
-;	StrLen $INSTDIR_TEST_LENGHT "$INSTDIR_TEST"
-;	${If} $INSTDIR_TEST_LENGHT < $INSTDIR_LENGHT
-;		MessageBox MB_OK|MB_ICONEXCLAMATION "$MESSAGE_CHKINST_"
-;	${EndIf}
-;FunctionEnd
-;Interface Settings
-!define MUI_ABORTWARNING
-!define MUI_ICON ".\Installer-Files\Install_GRASS.ico"
-!define MUI_UNICON ".\Installer-Files\Uninstall_GRASS.ico"
-!define MUI_HEADERIMAGE_BITMAP_NOSTETCH ".\Installer-Files\InstallHeaderImage.bmp"
-!define MUI_HEADERIMAGE_UNBITMAP_NOSTRETCH ".\Installer-Files\UnInstallHeaderImage.bmp"
-!define MUI_WELCOMEFINISHPAGE_BITMAP ".\Installer-Files\WelcomeFinishPage.bmp"
-!define MUI_UNWELCOMEFINISHPAGE_BITMAP ".\Installer-Files\UnWelcomeFinishPage.bmp"
-;Installer Pages
-!insertmacro MUI_PAGE_WELCOME
-;These indented statements modify settings for MUI_PAGE_LICENSE
-; (with thanks to Ubuntu)
-    !define MUI_LICENSEPAGE_TEXT_BOTTOM "GRASS is software libre. You are encouraged and legally \
-	entitled to copy, reinstall, modify, and redistribute this program \
-	for yourself and your friends under the terms of the GPL. Happy \
-	mapping!"
-    !define MUI_LICENSEPAGE_BUTTON "Next >"
-!insertmacro MUI_PAGE_LICENSE "${PACKAGE_FOLDER}\GPL.TXT"
-!define MUI_PAGE_CUSTOMFUNCTION_PRE CheckUpdate
-!insertmacro MUI_PAGE_DIRECTORY
-;Page custom CheckInstDir
-!insertmacro MUI_PAGE_COMPONENTS
-!insertmacro MUI_PAGE_INSTFILES
-;These indented statements modify settings for MUI_PAGE_FINISH
-    !define MUI_FINISHPAGE_NOAUTOCLOSE
-    !define MUI_FINISHPAGE_RUN
-    !define MUI_FINISHPAGE_RUN_NOTCHECKED
-    !define MUI_FINISHPAGE_RUN_TEXT "Launch GRASS GIS"
-    !define MUI_FINISHPAGE_RUN_FUNCTION "LaunchGrass"
-    !define MUI_FINISHPAGE_SHOWREADME
-    !define MUI_FINISHPAGE_SHOWREADME_NOTCHECKED
-    !define MUI_FINISHPAGE_SHOWREADME_TEXT "View the reference manual"
-    !define MUI_FINISHPAGE_SHOWREADME_FUNCTION "ViewReadme"
-!insertmacro MUI_PAGE_FINISH
-!insertmacro MUI_UNPAGE_WELCOME
-!insertmacro MUI_UNPAGE_CONFIRM
-!insertmacro MUI_UNPAGE_INSTFILES
-!insertmacro MUI_UNPAGE_FINISH
-;Language files
-!insertmacro MUI_LANGUAGE "English"
-;launch Grass Gis by exit the installation wizard
-Function LaunchGrass
-     ExecShell "" "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
-FunctionEnd
-;launch reference manual by exit the installation wizard
-Function ViewReadme
-      ExecShell "open" "$INSTDIR\docs\html\index.html"
-FunctionEnd
-;Installer Sections
-;Declares the variables for optional Sample Data Sections
-Var /GLOBAL HTTP_PATH
-Var /GLOBAL ARCHIVE_NAME
-Var /GLOBAL EXTENDED_ARCHIVE_NAME
-Var /GLOBAL ORIGINAL_UNTAR_FOLDER
-Var /GLOBAL CUSTOM_UNTAR_FOLDER
-Var /GLOBAL ARCHIVE_SIZE_KB
-Var /GLOBAL ARCHIVE_SIZE_MB
-Var /GLOBAL DOWNLOAD_MESSAGE_
-Section "GRASS" SecGRASS
-	SectionIn RO
-	;Set the INSTALL_DIR variable
-	Var /GLOBAL INSTALL_DIR
-		StrCpy $INSTALL_DIR "$INSTALL_PATH"
-	${Else}
-		StrCpy $INSTALL_DIR "$INSTDIR"
-	${EndIf}
-	;Set to try to overwrite existing files
-	SetOverwrite try
-	;Set the GIS_DATABASE directory
-	SetShellVarContext current
-	Var /GLOBAL GIS_DATABASE
-	StrCpy $GIS_DATABASE "$DOCUMENTS\GIS DataBase"
-	;Create the GIS_DATABASE directory
-	CreateDirectory "$GIS_DATABASE"
-	;add Installer files
-	SetOutPath "$INSTALL_DIR\icons"
-	File .\Installer-Files\GRASS.ico
-	File .\Installer-Files\GRASS_Web.ico
-	File .\Installer-Files\GRASS_tcltk.ico
-	File .\Installer-Files\GRASS_MSys.ico
-	File .\Installer-Files\GRASS_CMD.ico
-	File .\Installer-Files\MSYS_Custom_Icon.ico
-	File .\Installer-Files\WinGRASS.ico
-	SetOutPath "$INSTALL_DIR"
-	File .\Installer-Files\GRASS-WebSite.url
-	File .\Installer-Files\WinGRASS-README.url
-	;add GRASS files
-	File /r ${PACKAGE_FOLDER}\*.*
-	;create run_gmkfontcap.bat
-	ClearErrors
-	FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat w
-	IfErrors done_create_run_gmkfontcap.bat
-	FileWrite $0 '@echo off$\r$\n'
-	FileWrite $0 'rem #########################################################################$\r$\n'
-	FileWrite $0 'rem #$\r$\n'
-	FileWrite $0 'rem # Run g.mkfontcap outside a grass session during installation$\r$\n'
-	FileWrite $0 'echo Setup of WinGRASS-${VERSION_NUMBER}$\r$\n'
-	FileWrite $0 'echo Generating the font configuration file by scanning various directories for fonts.$\r$\n'
-	FileWrite $0 'echo Please wait. Console window will close automatically ....$\r$\n'
-	FileWrite $0 '$\r$\n'
-	FileWrite $0 'rem set gisbase$\r$\n'
-	FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
-	FileWrite $0 'rem set path to freetype dll$\r$\n'
-	FileWrite $0 'set FREETYPEBASE=$INSTALL_DIR\extralib;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
-	FileWrite $0 'rem set dependecies path$\r$\n'
-	FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
-	FileWrite $0 'rem run g.mkfontcap outside a grass session$\r$\n'
-	FileWrite $0 '"%GISBASE%\bin\g.mkfontcap.exe" -o$\r$\n'
-	FileWrite $0 'exit$\r$\n'
-	FileClose $0
-	done_create_run_gmkfontcap.bat:
-	;create run_gmkfontcap.bat.manifest
-	ClearErrors
-	FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat.manifest w
-	IfErrors done_create_run_gmkfontcap.bat.manifest
-	FileWrite $0 '	<?xml version="1.0" encoding="UTF-8" standalone="yes"?>$\r$\n'
-	FileWrite $0 '<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">$\r$\n'
-	FileWrite $0 '  <assemblyIdentity version="1.0.0.0"$\r$\n'
-	FileWrite $0 '     processorArchitecture="X86"$\r$\n'
-	FileWrite $0 '     name="run_gmkfontcap"$\r$\n'
-	FileWrite $0 '     type="win32"/>$\r$\n'
-	FileWrite $0 '  <description>GRASS help script:run_gmkfontcap<description>$\r$\n'
-	FileWrite $0 '  <!-- Identify the application security requirements. -->$\r$\n'
-	FileWrite $0 '  <trustInfo xmlns="urn:schemas-microsoft-com:asm.v2">$\r$\n'
-	FileWrite $0 '    <security>$\r$\n'
-	FileWrite $0 '      <requestedPrivileges>$\r$\n'
-	FileWrite $0 '        <requestedExecutionLevel$\r$\n'
-	FileWrite $0 '          level="asInvoker"$\r$\n'
-	FileWrite $0 '          uiAccess="false"/>$\r$\n'
-	FileWrite $0 '        </requestedPrivileges>$\r$\n'
-	FileWrite $0 '       </security>$\r$\n'
-	FileWrite $0 '  </trustInfo>$\r$\n'
-	FileWrite $0 '</assembly>$\r$\n'
-	FileClose $0
-	done_create_run_gmkfontcap.bat.manifest:
-	;Run g.mkfontcap outside a grass session during installation to catch all fonts
-	ExecWait '"$INSTALL_DIR\etc\run_gmkfontcap.bat"'
-	;Install demolocation into the GIS_DATABASE directory
-	SetOutPath "$GIS_DATABASE\demolocation"
-	File /r ${DEMOLOCATION_PATH}\*.*
-	;add msys.bat into the INSTALL_DIR\msys directory
-	SetOutPath "$INSTALL_DIR\msys"
-	File /r ${MSYS_BATCH}
-	;Create the Uninstaller
-	WriteUninstaller "$INSTALL_DIR\Uninstall-GRASS.exe"
-	;Registry Key Entries
-	;HKEY_LOCAL_MACHINE Install entries
-	;Set the Name, Version and Revision of GRASS + PublisherInfo + InstallPath
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "Name" "GRASS 6.4"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "VersionNumber" "${VERSION_NUMBER}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "SvnRevision" "${SVN_REVISION}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "BinaryRevision" "${BINARY_REVISION}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "WebSite" "${WEB_SITE}"
-	WriteRegStr HKLM "Software\${GRASS_BASE}" "InstallPath" "$INSTALL_DIR"
-	;HKEY_LOCAL_MACHINE Uninstall entries
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayName" "GRASS 6.4"
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString" "$INSTALL_DIR\Uninstall-GRASS.exe"
-		WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"\
-		"DisplayVersion" "${VERSION_NUMBER}-${BINARY_REVISION}"
-	!else
-		"DisplayVersion" "${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
-	!endif
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayIcon" "$INSTALL_DIR\icons\GRASS.ico"
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "EstimatedSize" 1
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "HelpLink" "${WIKI_PAGE}"
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "URLInfoAbout" "${WEB_SITE}"
-	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
-	;Create the Desktop Shortcut
-	CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
-	"$INSTALL_DIR\icons\GRASS.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with wxGUI"
-	;Create the Windows Start Menu Shortcuts
-	SetShellVarContext all
-	CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} Old TclTk GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-tcltk"\
-	"$INSTALL_DIR\icons\GRASS_tcltk.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with the old TclTk GUI"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} GUI with MSYS.lnk" "$INSTALL_DIR\msys\msys.bat" "/grass/${GRASS_COMMAND}.sh -wx"\
-	"$INSTALL_DIR\icons\GRASS_MSys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and a MSYS UNIX terminal"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} Command Line.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-text"\
-	"$INSTALL_DIR\icons\GRASS_CMD.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} in text mode"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\MSYS UNIX Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
-	"$INSTALL_DIR\icons\MSYS_Custom_Icon.ico" "" SW_SHOWNORMAL "" "Open a MSYS UNIX console"
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
-	"$INSTALL_DIR\icons\GRASS_Web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS website"
-; FIXME: ship the WinGrass release notes .html file instead of URL
-; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass64/binary/mswindows/native/README.html?format=raw
-; probably ship with devel versions too? ie Release Notes, not the Release Announcement press release.
-		CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
-		"$INSTALL_DIR\icons\WinGRASS.ico" "" SW_SHOWNORMAL "" "Visit the WinGRASS Project Web Page"
-	!endif
-	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Uninstall GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\Uninstall-GRASS.exe" ""\
-	"$INSTALL_DIR\Uninstall-GRASS.exe" "" SW_SHOWNORMAL "" "Uninstall GRASS ${VERSION_NUMBER}"
-	;Create the grass_command.bat
-	ClearErrors
-	FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.bat w
-	IfErrors done_create_grass_command.bat
-	FileWrite $0 'rem # File dynamically created by NSIS installer script;$\r$\n'
-	FileWrite $0 'rem # GRASS Initialization$\r$\n'
-	FileWrite $0 'rem Set GRASS Installation Directory Variable$\r$\n'
-	${If} $R_HKLM_INSTALL_PATH != ""
-	FileWrite $0 'set PATH=$R_HKLM_INSTALL_PATH\bin;%PATH%$\r$\n'
-	${EndIf}
-	${If} $R_HKCU_INSTALL_PATH != ""
-	FileWrite $0 'set PATH=$R_HKCU_INSTALL_PATH\bin;%PATH%$\r$\n'
-	${EndIf}
-	FileWrite $0 'call "%GISBASE%\etc\env.bat"$\r$\n'
-	FileWrite $0 'cd "%USERPROFILE%"'
-	FileWrite $0 '"%GISBASE%\etc\Init.bat" %*'
-	FileClose $0
-	done_create_grass_command.bat:
-	;Set the UNIX_LIKE GRASS Path
-	Var /GLOBAL UNIX_LIKE_DRIVE
-	Var /GLOBAL UNIX_LIKE_GRASS_PATH
-	StrCpy $UNIX_LIKE_DRIVE "$INSTALL_DIR" 3
-	StrCpy $UNIX_LIKE_GRASS_PATH "$INSTALL_DIR" "" 3
-	;replace "\" with "/" in $UNIX_LIKE_DRIVE
-	${StrReplace} "$UNIX_LIKE_DRIVE" "\" "/" "$UNIX_LIKE_DRIVE"
-	;replace ":" with "" in $UNIX_LIKE_DRIVE
-	${StrReplace} "$UNIX_LIKE_DRIVE" ":" "" "$UNIX_LIKE_DRIVE"
-	;replace "\" with "/" in $UNIX_LIKE_GRASS_PATH
-	${StrReplace} "$UNIX_LIKE_GRASS_PATH" "\" "/" "$UNIX_LIKE_GRASS_PATH"
-	;Set the USERNAME variable
-	Var /GLOBAL USERNAME
-	Var /GLOBAL PROFILE_DRIVE
-	Var /GLOBAL PROFILE_ROOT
-	;It first searches for the Key Regestry value "Logon User Name" in HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer"
-	ReadRegStr $USERNAME HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer" "Logon User Name"
-	;If the Key Registry value is empty, it uses a work around, retrieving the Username string from the System User Profile variable ($PROFILE)
-	;It first read the $PROFILE variable, to scan the OS version:
-	;If equal to "drive:\Users\UserName", the OS is Vista, and the $USERNAME variable set to $PROFILE -  "drive:\Users\"
-	;If not, the OS is XP or previous, and the $USERNAME variable set to $PROFILE -  "drive:\Documents and Settings\"
-	${If} $USERNAME == ""
-		StrCpy $PROFILE_DRIVE "$PROFILE" 2
-		StrCpy $PROFILE_ROOT "$PROFILE" 5 -3
-		${If} $USERNAME = "Users"
-			${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Users\" "" "$PROFILE"
-		${Else}
-			${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Documents and Settings\" "" "$PROFILE"
-		${EndIf}
-	${EndIf}
-	;Create the $INSTALL_DIR\msys\home and the $INSTALL_DIR\msys\home\$USERNAME directories
-	CreateDirectory $INSTALL_DIR\msys\home
-	CreateDirectory $INSTALL_DIR\msys\home\$USERNAME
-	;create the $INSTALL_DIR\bin grass_command
-	ClearErrors
-	FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.sh w
-	FileWrite $0 '#! /bin/sh$\r$\n'
-	FileWrite $0 '#########################################################################$\r$\n'
-	FileWrite $0 '#$\r$\n'
-	FileWrite $0 '# File dynamically created by NSIS installer script;$\r$\n'
-	FileWrite $0 '# Written by Marco Pasetti;$\r$\n'
-	FileWrite $0 '# MODULE:   	GRASS Initialization$\r$\n'
-	FileWrite $0 '# AUTHOR(S):	Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th$\r$\n'
-	FileWrite $0 '# PURPOSE:  	The source file for this shell script is in$\r$\n'
-	FileWrite $0 '#   	    	lib/init/grass.src and is the grass startup script. It$\r$\n'
-	FileWrite $0 '#   	    	requires a source file because the definition of GISBASE$\r$\n'
-	FileWrite $0 '#   	    	is not known until compile time and is substituted from the$\r$\n'
-	FileWrite $0 '#   	    	Makefile. Any command line options are passed to Init.sh.$\r$\n'
-	FileWrite $0 '# COPYRIGHT:  	(C) 2000-2010 by the GRASS Development Team$\r$\n'
-	FileWrite $0 '#             	This program is free software under the GNU General Public$\r$\n'
-	FileWrite $0 '#   	    	License (>=v2). Read the file COPYING that comes with GRASS$\r$\n'
-	FileWrite $0 '#   	    	for details.$\r$\n'
-	FileWrite $0 '# Modified by Marco Pasetti$\r$\n'
-	FileWrite $0 '# added the export PATH instruction to let GRASS work from$\r$\n'
-	FileWrite $0 '# the MSYS environment in the dynamic NSIS installation$\r$\n'
-	FileWrite $0 'trap "echo '
-	FileWrite $0 "'User break!' ; "
-	FileWrite $0 'exit" 2 3 9 15$\r$\n'
-	FileWrite $0 '# Set the GISBASE variable$\r$\n'
-	FileWrite $0 'GISBASE="/$UNIX_LIKE_DRIVE$UNIX_LIKE_GRASS_PATH"$\r$\n'
-	FileWrite $0 'export GISBASE$\r$\n'
-	FileWrite $0 '# Set the PATH variable$\r$\n'
-	FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
-	FileWrite $0 'PATH="$$GISBASE/tcl-tk/bin:$$GISBASE/sqlite/bin:$$GISBASE/gpsbabel:$$PATH"$\r$\n'
-	FileWrite $0 'export PATH$\r$\n'
-	FileWrite $0 '# Set the PYTHONPATH variable$\r$\n'
-	FileWrite $0 'PYTHONPATH="$$GISBASE/etc/python:$$GISBASE/Python27:$$PYTHONPATH"$\r$\n'
-	FileWrite $0 'export PYTHONPATH$\r$\n'
-	FileWrite $0 'PYTHONHOME="$INSTALL_DIR\Python27"$\r$\n'
-	FileWrite $0 'export PYTHONHOME$\r$\n'
-	FileWrite $0 'if [ -z "$$GRASS_PYTHON" ] ; then$\r$\n'
-	FileWrite $0 '   GRASS_PYTHON=python$\r$\n'
-	FileWrite $0 '   export GRASS_PYTHON$\r$\n'
-	FileWrite $0 'fi$\r$\n'
-	FileWrite $0 '# Set to default web browser$\r$\n'
-	FileWrite $0 'GRASS_HTML_BROWSER=explorer$\r$\n'
-	FileWrite $0 'export GRASS_HTML_BROWSER$\r$\n'
-	FileWrite $0 '# Set the GRASS_PROJSHARE variable$\r$\n'
-	FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
-	FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
-	FileWrite $0 '# Set the GDAL_DATA variable$\r$\n'
-	FileWrite $0 'GDAL_DATA="$INSTALL_DIR\share\gdal"$\r$\n'
-	FileWrite $0 'export GDAL_DATA$\r$\n'
-	FileWrite $0 '# Set the PROJ_LIB variable$\r$\n'
-	FileWrite $0 'PROJ_LIB="$INSTALL_DIR\proj"$\r$\n'
-	FileWrite $0 'export PROJ_LIB $\r$\n'
-	FileWrite $0 '# Set the GEOTIFF_CSV variable$\r$\n'
-	FileWrite $0 'GEOTIFF_CSV="$INSTALL_DIR\share\epsg_csv"$\r$\n'
-	FileWrite $0 'export GEOTIFF_CSV $\r$\n'
-	FileWrite $0 'cd "$USERPROFILE"'
-	FileWrite $0 'exec "$$GISBASE/etc/Init.sh" "$$@"'
-	FileClose $0
-	done_create_grass_command:
-	;Create the $INSTALL_DIR\msys\grass link directory
-	CreateDirectory $INSTALL_DIR\msys\grass
-	;Get the short form of the install path (to allow for paths with spaces)
-	VAR /GLOBAL INST_DIR_SHORT
-	GetFullPathName /SHORT $INST_DIR_SHORT $INSTALL_DIR
-	;create the $INSTALL_DIR\msys\etc\fstab with the main grass dir mount info
-	ClearErrors
-	FileOpen $0 $INSTALL_DIR\msys\etc\fstab w
-	IfErrors done_create_fstab
-	FileWrite $0 '$INST_DIR_SHORT   /grass$\r$\n'
-	FileClose $0
-	done_create_fstab:
-	;Set the Unix-Like GIS_DATABASE Path
-	Var /GLOBAL UNIX_LIKE_GIS_DATABASE_PATH
-	;replace \ with / in $GIS_DATABASE
-	${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
-	${If} ${FileExists} "$APPDATA\GRASS6\grassrc6"
-	      DetailPrint "File $APPDATA\GRASS6\grassrc6 already exists. Skipping."
-	${Else}
-	      ;create $APPDATA\GRASS6\grassrc6
-	      ClearErrors
-	      CreateDirectory	$APPDATA\GRASS6
-	      FileOpen $0 $APPDATA\GRASS6\grassrc6 w
-	      IfErrors done_create_grass6_rc
-	      FileWrite $0 'GISDBASE: $UNIX_LIKE_GIS_DATABASE_PATH$\r$\n'
-	      FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
-	      FileWrite $0 'MAPSET: PERMANENT$\r$\n'
-	      FileClose $0
-	      done_create_grass6_rc:
-	${EndIf}
-	CopyFiles $APPDATA\GRASS6\grassrc6 $INSTALL_DIR\msys\home\$USERNAME\.grassrc6
-SectionEnd
-Function DownloadDataSet
-	IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
-	StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the GRASS"
-	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
-	MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
-	download:
-	InitPluginsDir
-	NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
-	Pop $0
-	StrCmp $0 "success" download_ok download_failed
-	download_ok:
-	InitPluginsDir
-	untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
-	Pop $0
-	StrCmp $0 "success" untar_ok untar_failed
-	untar_ok:
-	Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
-	Delete "$TEMP\$ARCHIVE_NAME"
-	Goto end
-	download_failed:
-	DetailPrint "$0" ;print error message to log
-	MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
-	Goto end
-	cancel_download:
-	MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
-	Goto end
-	untar_failed:
-	end:
-FunctionEnd
-Section /O "North Carolina (Wake County) Data Set" SecNorthCarolinaSDB
-	;Set the size (in KB)  of the archive file
-	StrCpy $ARCHIVE_SIZE_KB 138629
-	;Set the size (in KB) of the unpacked archive file
-	AddSize 293314
-  	StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
-	StrCpy $ARCHIVE_NAME "nc_spm_latest.tar.gz"
-	StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina (Wake County)"
-	StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08"
-	StrCpy $CUSTOM_UNTAR_FOLDER "North-Carolina"
-	Call DownloadDataSet
-SectionEnd
-Section /O "South Dakota (Spearfish County) Data Set" SecSpearfishSDB
-	StrCpy $ARCHIVE_SIZE_KB 20803
-	AddSize 42171
-	StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
-	StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish County)"
-	StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
-	StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
-SectionEnd
-;Uninstaller Section
-Section "Uninstall"
-	;remove files & folders
-	RMDir /r "$INSTDIR"
-	;remove the Desktop ShortCut
-	Delete "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
-	Delete "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk"
-	;remove the Programs Start ShortCuts
-	RMDir /r "$SMPROGRAMS\${GRASS_BASE}"
-	;remove the $APPDATA\GRASS6 folder
-	;disabled, don't remove user settings
-	;SetShellVarContext current
-	;RMDir /r "$APPDATA\GRASS6"
-	;${If} ${FileExists} "$APPDATA\GRASS6\addons\*.*"
-	;      RMDir /r "$APPDATA\GRASS6\addons"
-	;${EndIf}
-	;remove the Registry Entries
-	DeleteRegKey HKLM "Software\${GRASS_BASE}"
-	DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
-SectionEnd
-;Installer Section Descriptions
-!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
-	!insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
-	!insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina (Wake County) sample data set"
-	!insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish County) sample data set"
-!insertmacro MUI_FUNCTION_DESCRIPTION_END
Copied: grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl (from rev 50873, grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi)
--- grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl	                        (rev 0)
+++ grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl	2012-02-19 14:53:42 UTC (rev 50874)
@@ -0,0 +1,990 @@
+;GRASS Installer for Windows
+;Written by Marco Pasetti
+;Updated for OSGeo4W by Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
+;Last Update: $Id$
+;Mail to: grass-dev at lists.osgeo.org
+;Define the source path of the demolocation files
+!define DEMOLOCATION_PATH "c:\osgeo4w\usr\src\grass_trunk\demolocation"
+;Define the source of the patched msys.bat
+!define MSYS_BATCH "C:\OSGeo4W\usr\src\grass_trunk\mswindows\osgeo4w\msys.bat"
+;Select if you are building a "Development Version" (Devel) or a "Release Version" (Release) of the GRASS Installer
+!define INSTALLER_TYPE "Devel"
+;set compression configuration
+SetCompressor /SOLID lzma
+SetCompressorDictSize 64
+;Version variables
+!define SVN_REVISION "@GRASS_VERSION_SVN@"
+!define BINARY_REVISION "1"
+!define VERSION_NUMBER "@GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@"
+!define GRASS_BASE "GRASS @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@"
+!if ${INSTALLER_TYPE} == "Release"
+        !define GRASS_COMMAND "grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@"
+!else
+        !define GRASS_COMMAND "grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at svn"
+!endif
+;Don't modify the following lines
+;NSIS Includes
+!include "MUI2.nsh"
+!include "LogicLib.nsh"
+;Set the installer variables, depending on the selected version to build
+!define PACKAGE_FOLDER ".\GRASS- at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at -Package"
+	!define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
+	!define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-${BINARY_REVISION}"
+	!define CHECK_INSTALL_NAME "GRASS @GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@"
+!else
+	!define INSTALLER_NAME "WinGRASS-${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}-Setup.exe"
+	!define DISPLAYED_NAME "GRASS ${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+	!define CHECK_INSTALL_NAME "GRASS @GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@ SVN"
+!endif
+;Publisher variables
+!define PUBLISHER "GRASS Development Team"
+!define WEB_SITE "http://grass.osgeo.org"
+!define WIKI_PAGE "http://grass.osgeo.org/wiki"
+;General Definitions
+;Name of the application shown during install
+Name "${DISPLAYED_NAME}"
+;Name of the output file (installer executable)
+OutFile "${INSTALLER_NAME}"
+;Define installation folder
+InstallDir "$PROGRAMFILES\${GRASS_BASE}"
+;Request application privileges for Windows Vista
+RequestExecutionLevel admin
+;Tell the installer to show Install and Uninstall details as default
+ShowInstDetails show
+ShowUnInstDetails show
+;StrReplace Function
+;Replaces all ocurrences of a given needle within a haystack with another string
+;Written by dandaman32
+Var STR_REPLACE_VAR_0
+Var STR_REPLACE_VAR_1
+Var STR_REPLACE_VAR_2
+Var STR_REPLACE_VAR_3
+Var STR_REPLACE_VAR_4
+Var STR_REPLACE_VAR_5
+Var STR_REPLACE_VAR_6
+Var STR_REPLACE_VAR_7
+Var STR_REPLACE_VAR_8
+Function StrReplace
+	Exch $STR_REPLACE_VAR_2
+	Exch 1
+	Exch $STR_REPLACE_VAR_1
+	Exch 2
+	Exch $STR_REPLACE_VAR_0
+		StrCpy $STR_REPLACE_VAR_3 -1
+		StrLen $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_1
+		StrLen $STR_REPLACE_VAR_6 $STR_REPLACE_VAR_0
+		loop:
+			IntOp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_3 + 1
+			StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_4 $STR_REPLACE_VAR_3
+			StrCmp $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_1 found
+			StrCmp $STR_REPLACE_VAR_3 $STR_REPLACE_VAR_6 done
+			Goto loop
+		found:
+			StrCpy $STR_REPLACE_VAR_5 $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_3
+			IntOp $STR_REPLACE_VAR_8 $STR_REPLACE_VAR_3 + $STR_REPLACE_VAR_4
+			StrCpy $STR_REPLACE_VAR_7 $STR_REPLACE_VAR_0 "" $STR_REPLACE_VAR_8
+			StrCpy $STR_REPLACE_VAR_0 $STR_REPLACE_VAR_5$STR_REPLACE_VAR_2$STR_REPLACE_VAR_7
+			Goto loop
+		done:
+	Pop $STR_REPLACE_VAR_1 ; Prevent "invalid opcode" errors and keep the
+	Pop $STR_REPLACE_VAR_1 ; stack as it was before the function was called
+FunctionEnd
+!macro _strReplaceConstructor OUT NEEDLE NEEDLE2 HAYSTACK
+	Push "${HAYSTACK}"
+	Push "${NEEDLE}"
+	Push "${NEEDLE2}"
+	Call StrReplace
+	Pop "${OUT}"
+!macroend
+!define StrReplace '!insertmacro "_strReplaceConstructor"'
+;.onInit Function (called when the installer is nearly finished initializing)
+;Check if GRASS is already installed on the system and, if yes, what version and binary release;
+;depending on that, select the install procedure:
+;1. first installation = if GRASS is not already installed
+;install GRASS asking for the install PATH
+;2. upgrade installation = if an older release of GRASS is already installed
+;call the uninstaller of the currently installed GRASS release
+;if the uninstall procedure succeeded, call the current installer without asking for the install PATH
+;GRASS will be installed in the same PATH of the previous installation
+;3. downgrade installation = if a newer release of GRASS is already installed
+;4. repair installation = if the same release of GRASS is already installed
+;if the uninstall procedure succeeded, call the current installer asking for the install PATH
+;the currently installed release of GRASS is defined by the variable $INSTALLED_VERSION = $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+Function .onInit
+	Var /GLOBAL ASK_FOR_PATH
+	StrCpy $ASK_FOR_PATH "YES"
+	Var /GLOBAL UNINSTALL_STRING
+	Var /GLOBAL INSTALL_PATH
+	Var /GLOBAL INSTALLED_VERSION_NUMBER
+	Var /GLOBAL INSTALLED_SVN_REVISION
+	Var /GLOBAL INSTALLED_BINARY_REVISION
+	Var /GLOBAL DISPLAYED_INSTALLED_VERSION
+	Var /GLOBAL MESSAGE_0_
+	Var /GLOBAL MESSAGE_1_
+	Var /GLOBAL MESSAGE_2_
+	Var /GLOBAL MESSAGE_3_
+	Var /GLOBAL R_HKLM_INSTALL_PATH
+	Var /GLOBAL R_HKCU_INSTALL_PATH
+	ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
+	ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
+	ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
+	ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
+	ReadRegStr $R_HKLM_INSTALL_PATH HKLM "Software\R-core\R" "InstallPath"
+	ReadRegStr $R_HKCU_INSTALL_PATH HKCU "Software\R-core\R" "InstallPath"
+	${If} $INSTALLED_SVN_REVISION == ""
+		ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
+	${EndIf}
+	ReadRegStr $INSTALLED_BINARY_REVISION HKLM "Software\${GRASS_BASE}" "BinaryRevision"
+	StrCpy $MESSAGE_0_ "${CHECK_INSTALL_NAME} is already installed on your system.$\r$\n"
+	StrCpy $MESSAGE_0_ "$MESSAGE_0_$\r$\n"
+	!if ${INSTALLER_TYPE} == "Release"
+		${If} $INSTALLED_BINARY_REVISION == ""
+			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER"
+		${Else}
+			StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_BINARY_REVISION"
+		${EndIf}
+	!else
+		StrCpy $DISPLAYED_INSTALLED_VERSION "$INSTALLED_VERSION_NUMBER-$INSTALLED_SVN_REVISION-$INSTALLED_BINARY_REVISION"
+	!endif
+	StrCpy $MESSAGE_0_ "$MESSAGE_0_The installed release is $DISPLAYED_INSTALLED_VERSION$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_0_$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_You are going to install a newer release of ${CHECK_INSTALL_NAME}$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_$\r$\n"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
+	StrCpy $MESSAGE_1_ "$MESSAGE_1_ and install ${DISPLAYED_NAME} or Cancel to quit."
+	StrCpy $MESSAGE_2_ "$MESSAGE_0_$\r$\n"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_You are going to install an older release of ${CHECK_INSTALL_NAME}$\r$\n"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_$\r$\n"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_Press OK to uninstall GRASS $DISPLAYED_INSTALLED_VERSION"
+	StrCpy $MESSAGE_2_ "$MESSAGE_2_ and install ${DISPLAYED_NAME} or Cancel to quit."
+	StrCpy $MESSAGE_3_ "$MESSAGE_0_$\r$\n"
+	StrCpy $MESSAGE_3_ "$MESSAGE_3_This is the latest release available.$\r$\n"
+	StrCpy $MESSAGE_3_ "$MESSAGE_3_$\r$\n"
+	StrCpy $MESSAGE_3_ "$MESSAGE_3_Press OK to reinstall ${DISPLAYED_NAME} or Cancel to quit."
+	IntOp $INSTALLED_SVN_REVISION $INSTALLED_SVN_REVISION * 1
+	IntOp $INSTALLED_BINARY_REVISION $INSTALLED_BINARY_REVISION * 1
+	IntOp $INSTALLED_VERSION $INSTALLED_SVN_REVISION + $INSTALLED_BINARY_REVISION
+	!define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
+	${If} $INSTALLED_VERSION_NUMBER == ""
+	${Else}
+		${If} $INSTALLED_VERSION < ${VERSION}
+			MessageBox MB_OKCANCEL "$MESSAGE_1_" IDOK upgrade IDCANCEL quit_upgrade
+			upgrade:
+				StrCpy $ASK_FOR_PATH "NO"
+				ExecWait '"$UNINSTALL_STRING" _?=$INSTALL_PATH' $0
+				Goto continue_upgrade
+			quit_upgrade:
+				Abort
+			continue_upgrade:
+		${ElseIf} $INSTALLED_VERSION > ${VERSION}
+			MessageBox MB_OKCANCEL "$MESSAGE_2_" IDOK downgrade IDCANCEL quit_downgrade
+			downgrade:
+				Goto continue_downgrade
+			quit_downgrade:
+				Abort
+			continue_downgrade:
+		${ElseIf} $INSTALLED_VERSION = ${VERSION}
+			MessageBox MB_OKCANCEL "$MESSAGE_3_" IDOK reinstall IDCANCEL quit_reinstall
+			reinstall:
+				Goto continue_reinstall
+			quit_reinstall:
+				Abort
+			continue_reinstall:
+		${EndIf}
+	${EndIf}
+	${Else}
+		${If} $0 = 0
+		${Else}
+			Abort
+		${EndIf}
+	${EndIf}
+FunctionEnd
+;CheckUpdate Function
+;Check if to show the MUI_PAGE_DIRECTORY during the installation (to ask for the install PATH)
+Function CheckUpdate
+	${If} $ASK_FOR_PATH == "NO"
+		Abort
+	${EndIf}
+FunctionEnd
+;CheckInstDir Function
+;this is commented out, because the installation path should be in $PROGRAMFILES
+;Check if GRASS is going to be installed in a directory containing spaces
+;if yes, show a warning message
+;Function CheckInstDir
+;	Var /GLOBAL INSTDIR_TEST
+;	Var /GLOBAL INSTDIR_LENGHT
+;	Var /GLOBAL INSTDIR_TEST_LENGHT
+;	Var /GLOBAL MESSAGE_CHKINST_
+;	StrCpy $MESSAGE_CHKINST_ "WARNING: you are about to install GRASS into a directory that has spaces$\r$\n"
+;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_in either its name or the path of directories leading up to it.$\r$\n"
+;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_Some functionalities of GRASS might be hampered by this. We would highly$\r$\n"
+;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_appreciate if you tried and reported any problems, so that we can fix them.$\r$\n"
+;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_However, if you want to avoid any such issues, we recommend that you$\r$\n"
+;	StrCpy $MESSAGE_CHKINST_ "$MESSAGE_CHKINST_choose a simple installation path without spaces, such as: C:\${GRASS_BASE}.$\r$\n"
+;	${StrReplace} "$INSTDIR_TEST" " " "" "$INSTDIR"
+;	StrLen $INSTDIR_LENGHT "$INSTDIR"
+;	StrLen $INSTDIR_TEST_LENGHT "$INSTDIR_TEST"
+;	${If} $INSTDIR_TEST_LENGHT < $INSTDIR_LENGHT
+;		MessageBox MB_OK|MB_ICONEXCLAMATION "$MESSAGE_CHKINST_"
+;	${EndIf}
+;FunctionEnd
+;ReplaceLineString Function
+;Replace String in an existing file
+; code taken from http://nsis.sourceforge.net/Replace_line_that_starts_with_specified_string
+Function ReplaceLineStr
+ Exch $R0 ; string to replace that whole line with
+ Exch
+ Exch $R1 ; string that line should start with
+ Exch
+ Exch 2
+ Exch $R2 ; file
+ Push $R3 ; file handle
+ Push $R4 ; temp file
+ Push $R5 ; temp file handle
+ Push $R6 ; global
+ Push $R7 ; input string length
+ Push $R8 ; line string length
+ Push $R9 ; global
+  StrLen $R7 $R1
+  GetTempFileName $R4
+  FileOpen $R5 $R4 w
+  FileOpen $R3 $R2 r
+  ReadLoop:
+  ClearErrors
+   FileRead $R3 $R6
+    IfErrors Done
+   StrLen $R8 $R6
+   StrCpy $R9 $R6 $R7 -$R8
+   StrCmp $R9 $R1 0 +3
+    FileWrite $R5 "$R0$\r$\n"
+    Goto ReadLoop
+    FileWrite $R5 $R6
+    Goto ReadLoop
+  Done:
+  FileClose $R3
+  FileClose $R5
+  SetDetailsPrint none
+   Delete $R2
+   Rename $R4 $R2
+  SetDetailsPrint both
+ Pop $R9
+ Pop $R8
+ Pop $R7
+ Pop $R6
+ Pop $R5
+ Pop $R4
+ Pop $R3
+ Pop $R2
+ Pop $R1
+ Pop $R0
+FunctionEnd
+;Interface Settings
+!define MUI_ABORTWARNING
+!define MUI_ICON ".\Installer-Files\Install_GRASS.ico"
+!define MUI_UNICON ".\Installer-Files\Uninstall_GRASS.ico"
+!define MUI_HEADERIMAGE_BITMAP_NOSTETCH ".\Installer-Files\InstallHeaderImage.bmp"
+!define MUI_HEADERIMAGE_UNBITMAP_NOSTRETCH ".\Installer-Files\UnInstallHeaderImage.bmp"
+!define MUI_WELCOMEFINISHPAGE_BITMAP ".\Installer-Files\WelcomeFinishPage.bmp"
+!define MUI_UNWELCOMEFINISHPAGE_BITMAP ".\Installer-Files\UnWelcomeFinishPage.bmp"
+;Installer Pages
+!insertmacro MUI_PAGE_WELCOME
+;These indented statements modify settings for MUI_PAGE_LICENSE
+; (with thanks to Ubuntu)
+    !define MUI_LICENSEPAGE_TEXT_BOTTOM "GRASS is software libre. You are encouraged and legally \
+	entitled to copy, reinstall, modify, and redistribute this program \
+	for yourself and your friends under the terms of the GPL. Happy \
+	mapping!"
+    !define MUI_LICENSEPAGE_BUTTON "Next >"
+!insertmacro MUI_PAGE_LICENSE "${PACKAGE_FOLDER}\GPL.TXT"
+!define MUI_PAGE_CUSTOMFUNCTION_PRE CheckUpdate
+!insertmacro MUI_PAGE_DIRECTORY
+;Page custom CheckInstDir
+!insertmacro MUI_PAGE_COMPONENTS
+!insertmacro MUI_PAGE_INSTFILES
+;These indented statements modify settings for MUI_PAGE_FINISH
+    !define MUI_FINISHPAGE_NOAUTOCLOSE
+    !define MUI_FINISHPAGE_RUN
+    !define MUI_FINISHPAGE_RUN_NOTCHECKED
+    !define MUI_FINISHPAGE_RUN_TEXT "Launch GRASS GIS"
+    !define MUI_FINISHPAGE_RUN_FUNCTION "LaunchGrass"
+    !define MUI_FINISHPAGE_SHOWREADME
+    !define MUI_FINISHPAGE_SHOWREADME_NOTCHECKED
+    !define MUI_FINISHPAGE_SHOWREADME_TEXT "View the reference manual"
+    !define MUI_FINISHPAGE_SHOWREADME_FUNCTION "ViewReadme"
+!insertmacro MUI_PAGE_FINISH
+!insertmacro MUI_UNPAGE_WELCOME
+!insertmacro MUI_UNPAGE_CONFIRM
+!insertmacro MUI_UNPAGE_INSTFILES
+!insertmacro MUI_UNPAGE_FINISH
+;Language files
+!insertmacro MUI_LANGUAGE "English"
+;launch Grass Gis by exit the installation wizard
+Function LaunchGrass
+     ExecShell "" "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
+FunctionEnd
+;launch reference manual by exit the installation wizard
+Function ViewReadme
+      ExecShell "open" "$INSTDIR\docs\html\index.html"
+FunctionEnd
+;Installer Sections
+;Declares the variables for optional Sample Data Sections
+Var /GLOBAL HTTP_PATH
+Var /GLOBAL ARCHIVE_NAME
+Var /GLOBAL EXTENDED_ARCHIVE_NAME
+Var /GLOBAL ORIGINAL_UNTAR_FOLDER
+Var /GLOBAL CUSTOM_UNTAR_FOLDER
+Var /GLOBAL ARCHIVE_SIZE_KB
+Var /GLOBAL ARCHIVE_SIZE_MB
+Var /GLOBAL DOWNLOAD_MESSAGE_
+Section "GRASS" SecGRASS
+	SectionIn RO
+	;Set the INSTALL_DIR variable
+	Var /GLOBAL INSTALL_DIR
+		StrCpy $INSTALL_DIR "$INSTALL_PATH"
+	${Else}
+		StrCpy $INSTALL_DIR "$INSTDIR"
+	${EndIf}
+	;Set to try to overwrite existing files
+	SetOverwrite try
+	;Set the GIS_DATABASE directory
+	SetShellVarContext current
+	Var /GLOBAL GIS_DATABASE
+	StrCpy $GIS_DATABASE "$DOCUMENTS\GIS DataBase"
+	;Create the GIS_DATABASE directory
+	CreateDirectory "$GIS_DATABASE"
+	;add Installer files
+	SetOutPath "$INSTALL_DIR"
+	File .\Installer-Files\GRASS-WebSite.url
+	File .\Installer-Files\WinGRASS-README.url
+	;add GRASS files
+	File /r ${PACKAGE_FOLDER}\*.*
+	;create run_gmkfontcap.bat
+	ClearErrors
+	FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat w
+	IfErrors done_create_run_gmkfontcap.bat
+	FileWrite $0 '@echo off$\r$\n'
+	FileWrite $0 'rem #########################################################################$\r$\n'
+	FileWrite $0 'rem #$\r$\n'
+	FileWrite $0 'rem # Run g.mkfontcap outside a grass session during installation$\r$\n'
+	FileWrite $0 'echo Setup of WinGRASS-${VERSION_NUMBER}$\r$\n'
+	FileWrite $0 'echo Generating the font configuration file by scanning various directories for fonts.$\r$\n'
+	FileWrite $0 'echo Please wait. Console window will close automatically ....$\r$\n'
+	FileWrite $0 '$\r$\n'
+	FileWrite $0 'rem set gisbase$\r$\n'
+	FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
+	FileWrite $0 'rem set path to freetype dll$\r$\n'
+	FileWrite $0 'set FREETYPEBASE=$INSTALL_DIR\extralib;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
+	FileWrite $0 'rem set dependecies path$\r$\n'
+	FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
+	FileWrite $0 'rem run g.mkfontcap outside a grass session$\r$\n'
+	FileWrite $0 '"%GISBASE%\bin\g.mkfontcap.exe" -o$\r$\n'
+	FileWrite $0 'exit$\r$\n'
+	FileClose $0
+	done_create_run_gmkfontcap.bat:
+	;create run_gmkfontcap.bat.manifest
+	ClearErrors
+	FileOpen $0 $INSTALL_DIR\etc\run_gmkfontcap.bat.manifest w
+	IfErrors done_create_run_gmkfontcap.bat.manifest
+	FileWrite $0 '	<?xml version="1.0" encoding="UTF-8" standalone="yes"?>$\r$\n'
+	FileWrite $0 '<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">$\r$\n'
+	FileWrite $0 '  <assemblyIdentity version="1.0.0.0"$\r$\n'
+	FileWrite $0 '     processorArchitecture="X86"$\r$\n'
+	FileWrite $0 '     name="run_gmkfontcap"$\r$\n'
+	FileWrite $0 '     type="win32"/>$\r$\n'
+	FileWrite $0 '  <description>GRASS help script:run_gmkfontcap<description>$\r$\n'
+	FileWrite $0 '  <!-- Identify the application security requirements. -->$\r$\n'
+	FileWrite $0 '  <trustInfo xmlns="urn:schemas-microsoft-com:asm.v2">$\r$\n'
+	FileWrite $0 '    <security>$\r$\n'
+	FileWrite $0 '      <requestedPrivileges>$\r$\n'
+	FileWrite $0 '        <requestedExecutionLevel$\r$\n'
+	FileWrite $0 '          level="asInvoker"$\r$\n'
+	FileWrite $0 '          uiAccess="false"/>$\r$\n'
+	FileWrite $0 '        </requestedPrivileges>$\r$\n'
+	FileWrite $0 '       </security>$\r$\n'
+	FileWrite $0 '  </trustInfo>$\r$\n'
+	FileWrite $0 '</assembly>$\r$\n'
+	FileClose $0
+	done_create_run_gmkfontcap.bat.manifest:
+	;Run g.mkfontcap outside a grass session during installation to catch all fonts
+	ExecWait '"$INSTALL_DIR\etc\run_gmkfontcap.bat"'
+	;Install demolocation into the GIS_DATABASE directory
+	SetOutPath "$GIS_DATABASE\demolocation"
+	File /r ${DEMOLOCATION_PATH}\*.*
+	;add msys.bat into the INSTALL_DIR\msys directory
+	SetOutPath "$INSTALL_DIR\msys"
+	File /r ${MSYS_BATCH}
+	;Create the Uninstaller
+	WriteUninstaller "$INSTALL_DIR\Uninstall-GRASS.exe"
+	;Registry Key Entries
+	;HKEY_LOCAL_MACHINE Install entries
+	;Set the Name, Version and Revision of GRASS + PublisherInfo + InstallPath
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "Name" "GRASS @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR@"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "VersionNumber" "${VERSION_NUMBER}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "SvnRevision" "${SVN_REVISION}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "BinaryRevision" "${BINARY_REVISION}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "WebSite" "${WEB_SITE}"
+	WriteRegStr HKLM "Software\${GRASS_BASE}" "InstallPath" "$INSTALL_DIR"
+	;HKEY_LOCAL_MACHINE Uninstall entries
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayName" "GRASS @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR@"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString" "$INSTALL_DIR\Uninstall-GRASS.exe"
+		WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"\
+		"DisplayVersion" "${VERSION_NUMBER}-${BINARY_REVISION}"
+	!else
+		"DisplayVersion" "${VERSION_NUMBER}-r${SVN_REVISION}-${BINARY_REVISION}"
+	!endif
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "DisplayIcon" "$INSTALL_DIR\etc\gui\icons\grass.ico"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "EstimatedSize" 1
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "HelpLink" "${WIKI_PAGE}"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "URLInfoAbout" "${WEB_SITE}"
+	WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
+	;Create the Desktop Shortcut
+	CreateShortCut "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
+	"$INSTALL_DIR\etc\gui\icons\grass.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD terminal"
+	;Create the Windows Start Menu Shortcuts
+	SetShellVarContext all
+	CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
+	"$INSTALL_DIR\etc\gui\icons\grass.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD console"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} GUI with MSYS.lnk" "$INSTALL_DIR\${GRASS_COMMAND}_msys.bat" "-wx"\
+	"$INSTALL_DIR\etc\gui\icons\grass_msys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and MSYS UNIX console"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS ${VERSION_NUMBER} Command Line.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-text"\
+	"$INSTALL_DIR\etc\gui\icons\grass_cmd.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} in text mode"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\MSYS UNIX Console.lnk" "$INSTALL_DIR\msys\msys.bat" ""\
+	"$INSTALL_DIR\etc\gui\icons\msys.ico" "" SW_SHOWNORMAL "" "Open a MSYS UNIX console"
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\GRASS Web Site.lnk" "$INSTALL_DIR\GRASS-WebSite.url" ""\
+	"$INSTALL_DIR\etc\gui\icons\grass_web.ico" "" SW_SHOWNORMAL "" "Visit the GRASS website"
+; FIXME: ship the WinGrass release notes .html file instead of URL
+; http://trac.osgeo.org/grass/browser/grass-web/trunk/grass@GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@/binary/mswindows/native/README.html?format=raw
+; probably ship with devel versions too? ie Release Notes, not the Release Announcement press release.
+		CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Release Notes.lnk" "$INSTALL_DIR\WinGRASS-README.url" ""\
+		"$INSTALL_DIR\etc\gui\icons\wingrass.ico" "" SW_SHOWNORMAL "" "Visit the WinGRASS Project Web Page"
+	!endif
+	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\Uninstall GRASS ${VERSION_NUMBER}.lnk" "$INSTALL_DIR\Uninstall-GRASS.exe" ""\
+	"$INSTALL_DIR\Uninstall-GRASS.exe" "" SW_SHOWNORMAL "" "Uninstall GRASS ${VERSION_NUMBER}"
+	;Create the grass_command.bat
+	ClearErrors
+	FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.bat w
+	IfErrors done_create_grass_command.bat
+	FileWrite $0 'rem # File dynamically created by NSIS installer script;$\r$\n'
+	FileWrite $0 'rem # GRASS Initialization$\r$\n'
+	${If} $R_HKLM_INSTALL_PATH != ""
+	FileWrite $0 'set PATH=$R_HKLM_INSTALL_PATH\bin;%PATH%$\r$\n'
+	${EndIf}
+	${If} $R_HKCU_INSTALL_PATH != ""
+	FileWrite $0 'set PATH=$R_HKCU_INSTALL_PATH\bin;%PATH%$\r$\n'
+	${EndIf}
+	FileWrite $0 'call "%GISBASE%\etc\env.bat"$\r$\n'
+	FileWrite $0 'cd "%USERPROFILE%"'
+	FileWrite $0 '"%GISBASE%\etc\Init.bat" %*'
+	FileClose $0
+	done_create_grass_command.bat:
+	;Set the UNIX_LIKE GRASS Path
+	Var /GLOBAL UNIX_LIKE_DRIVE
+	Var /GLOBAL UNIX_LIKE_GRASS_PATH
+	StrCpy $UNIX_LIKE_DRIVE "$INSTALL_DIR" 3
+	StrCpy $UNIX_LIKE_GRASS_PATH "$INSTALL_DIR" "" 3
+	;replace "\" with "/" in $UNIX_LIKE_DRIVE
+	${StrReplace} "$UNIX_LIKE_DRIVE" "\" "/" "$UNIX_LIKE_DRIVE"
+	;replace ":" with "" in $UNIX_LIKE_DRIVE
+	${StrReplace} "$UNIX_LIKE_DRIVE" ":" "" "$UNIX_LIKE_DRIVE"
+	;replace "\" with "/" in $UNIX_LIKE_GRASS_PATH
+	${StrReplace} "$UNIX_LIKE_GRASS_PATH" "\" "/" "$UNIX_LIKE_GRASS_PATH"
+	;Set the USERNAME variable
+	Var /GLOBAL USERNAME
+	Var /GLOBAL PROFILE_DRIVE
+	Var /GLOBAL PROFILE_ROOT
+	;It first searches for the Key Regestry value "Logon User Name" in HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer"
+	ReadRegStr $USERNAME HKCU "Software\Microsoft\Windows\CurrentVersion\Explorer" "Logon User Name"
+	;If the Key Registry value is empty, it uses a work around, retrieving the Username string from the System User Profile variable ($PROFILE)
+	;It first read the $PROFILE variable, to scan the OS version:
+	;If equal to "drive:\Users\UserName", the OS is Vista, and the $USERNAME variable set to $PROFILE -  "drive:\Users\"
+	;If not, the OS is XP or previous, and the $USERNAME variable set to $PROFILE -  "drive:\Documents and Settings\"
+	${If} $USERNAME == ""
+		StrCpy $PROFILE_DRIVE "$PROFILE" 2
+		StrCpy $PROFILE_ROOT "$PROFILE" 5 -3
+		${If} $USERNAME = "Users"
+			${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Users\" "" "$PROFILE"
+		${Else}
+			${StrReplace} "$USERNAME" "$PROFILE_DRIVE\Documents and Settings\" "" "$PROFILE"
+		${EndIf}
+	${EndIf}
+	;create the grass_command.sh
+	ClearErrors
+	FileOpen $0 $INSTALL_DIR\${GRASS_COMMAND}.sh w
+	FileWrite $0 '#! /bin/sh$\r$\n'
+	FileWrite $0 '#########################################################################$\r$\n'
+	FileWrite $0 '#$\r$\n'
+	FileWrite $0 '# File dynamically created by NSIS installer script;$\r$\n'
+	FileWrite $0 '# Written by Marco Pasetti;$\r$\n'
+	FileWrite $0 '# MODULE:   	GRASS Initialization$\r$\n'
+	FileWrite $0 '# AUTHOR(S):	Justin Hickey - Thailand - jhickey at hpcc.nectec.or.th$\r$\n'
+	FileWrite $0 '# PURPOSE:  	The source file for this shell script is in$\r$\n'
+	FileWrite $0 '#   	    	lib/init/grass.src and is the grass startup script. It$\r$\n'
+	FileWrite $0 '#   	    	requires a source file because the definition of GISBASE$\r$\n'
+	FileWrite $0 '#   	    	is not known until compile time and is substituted from the$\r$\n'
+	FileWrite $0 '#   	    	Makefile. Any command line options are passed to Init.sh.$\r$\n'
+	FileWrite $0 '# COPYRIGHT:  	(C) 2000-2010 by the GRASS Development Team$\r$\n'
+	FileWrite $0 '#             	This program is free software under the GNU General Public$\r$\n'
+	FileWrite $0 '#   	    	License (>=v2). Read the file COPYING that comes with GRASS$\r$\n'
+	FileWrite $0 '#   	    	for details.$\r$\n'
+	FileWrite $0 '# Modified by Marco Pasetti$\r$\n'
+	FileWrite $0 '# added the export PATH instruction to let GRASS work from$\r$\n'
+	FileWrite $0 '# the MSYS environment in the dynamic NSIS installation$\r$\n'
+	FileWrite $0 'trap "echo '
+	FileWrite $0 "'User break!' ; "
+	FileWrite $0 'exit" 2 3 9 15$\r$\n'
+	FileWrite $0 '# Set the GISBASE variable$\r$\n'
+	FileWrite $0 'GISBASE="/$UNIX_LIKE_DRIVE$UNIX_LIKE_GRASS_PATH"$\r$\n'
+	FileWrite $0 'export GISBASE$\r$\n'
+	FileWrite $0 '# Set the PATH variable$\r$\n'
+	FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
+	FileWrite $0 'PATH="$$GISBASE/tcl-tk/bin:$$GISBASE/sqlite/bin:$$GISBASE/gpsbabel:$$PATH"$\r$\n'
+	FileWrite $0 'export PATH$\r$\n'
+	FileWrite $0 '# Set the PYTHONPATH variable$\r$\n'
+	FileWrite $0 'PYTHONPATH="$$GISBASE/etc/python:$$GISBASE/Python27:$$PYTHONPATH"$\r$\n'
+	FileWrite $0 'export PYTHONPATH$\r$\n'
+	FileWrite $0 'PYTHONHOME="$INSTALL_DIR\Python27"$\r$\n'
+	FileWrite $0 'export PYTHONHOME$\r$\n'
+	FileWrite $0 'if [ -z "$$GRASS_PYTHON" ] ; then$\r$\n'
+	FileWrite $0 '   GRASS_PYTHON=python$\r$\n'
+	FileWrite $0 '   export GRASS_PYTHON$\r$\n'
+	FileWrite $0 'fi$\r$\n'
+	FileWrite $0 '# Set to default web browser$\r$\n'
+	FileWrite $0 'GRASS_HTML_BROWSER=explorer$\r$\n'
+	FileWrite $0 'export GRASS_HTML_BROWSER$\r$\n'
+	FileWrite $0 '# Set the GRASS_PROJSHARE variable$\r$\n'
+	FileWrite $0 'GRASS_PROJSHARE="$INSTALL_DIR\proj"$\r$\n'
+	FileWrite $0 'export GRASS_PROJSHARE$\r$\n'
+	FileWrite $0 '# Set the GDAL_DATA variable$\r$\n'
+	FileWrite $0 'GDAL_DATA="$INSTALL_DIR\share\gdal"$\r$\n'
+	FileWrite $0 'export GDAL_DATA$\r$\n'
+	FileWrite $0 '# Set the PROJ_LIB variable$\r$\n'
+	FileWrite $0 'PROJ_LIB="$INSTALL_DIR\proj"$\r$\n'
+	FileWrite $0 'export PROJ_LIB $\r$\n'
+	FileWrite $0 '# Set the GEOTIFF_CSV variable$\r$\n'
+	FileWrite $0 'GEOTIFF_CSV="$INSTALL_DIR\share\epsg_csv"$\r$\n'
+	FileWrite $0 'export GEOTIFF_CSV$\r$\n'
+	FileWrite $0 'cd "$USERPROFILE"'
+	FileWrite $0 'exec "$$GISBASE/etc/Init.sh" "$$@"'
+	FileClose $0
+	done_create_grass_command:
+	;Get the short form of the install path (to allow for paths with spaces)
+	VAR /GLOBAL INST_DIR_SHORT
+	GetFullPathName /SHORT $INST_DIR_SHORT $INSTALL_DIR
+	;create the $INSTALL_DIR\msys\etc\fstab with the main grass dir mount info
+	ClearErrors
+	FileOpen $0 $INSTALL_DIR\msys\etc\fstab w
+	IfErrors done_create_fstab
+	FileWrite $0 '$INST_DIR_SHORT   /grass$\r$\n'
+	FileClose $0
+	done_create_fstab:
+	;Set the Unix-Like GIS_DATABASE Path
+ 	;Var /GLOBAL UNIX_LIKE_GIS_DATABASE_PATH
+	;replace \ with / in $GIS_DATABASE
+	;${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
+	${If} ${FileExists} "$APPDATA\GRASS at GRASS_VERSION_MAJOR@\rc"
+	      DetailPrint "File $APPDATA\GRASS at GRASS_VERSION_MAJOR@\rc already exists. Skipping."
+	${Else}
+	      ;create $APPDATA\GRASS at GRASS_VERSION_MAJOR@\rc
+	      ClearErrors
+	      CreateDirectory	$APPDATA\GRASS at GRASS_VERSION_MAJOR@
+	      FileOpen $0 $APPDATA\GRASS at GRASS_VERSION_MAJOR@\rc w
+	      IfErrors done_create_grass_rc
+	      FileWrite $0 'GISDBASE: $GIS_DATABASE$\r$\n'
+	      FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
+	      FileWrite $0 'MAPSET: PERMANENT$\r$\n'
+	      FileClose $0
+	      done_create_grass_rc:
+	${EndIf}
+	;replace gisbase = "/c/OSGeo4W/apps/grass/grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@" in grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py with $INSTDIR
+	Push "$INSTDIR\etc\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py" ; file to modify
+	Push 'gisbase = "/c/OSGeo4W/apps/grass/grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@"' ; string that a line must begin with *WS Sensitive*
+	Push 'gisbase = "$INSTDIR"' ; string to replace whole line with
+	Call ReplaceLineStr
+	;replace config_projshare = "/c/OSGeo4W/share/proj" i n grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py with $INSTDIR\proj
+	Push 'config_projshare = "/c/OSGeo4W/share/proj"' ; string that a line must begin with *WS Sensitive*
+	Push 'config_projshare = "$INSTDIR\proj"' ; string to replace whole line with
+SectionEnd
+Function DownloadDataSet
+	IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
+	StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the GRASS"
+	StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
+	MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
+	download:
+	InitPluginsDir
+	NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
+	Pop $0
+	StrCmp $0 "success" download_ok download_failed
+	download_ok:
+	InitPluginsDir
+	untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
+	Pop $0
+	StrCmp $0 "success" untar_ok untar_failed
+	untar_ok:
+	Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
+	Delete "$TEMP\$ARCHIVE_NAME"
+	Goto end
+	download_failed:
+	DetailPrint "$0" ;print error message to log
+	MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+	Goto end
+	cancel_download:
+	MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+	Goto end
+	untar_failed:
+	end:
+FunctionEnd
+Section /O "North Carolina (Wake County) Data Set" SecNorthCarolinaSDB
+	;Set the size (in KB)  of the archive file
+	StrCpy $ARCHIVE_SIZE_KB 138629
+	;Set the size (in KB) of the unpacked archive file
+	AddSize 293314
+  	StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
+	StrCpy $ARCHIVE_NAME "nc_spm_latest.tar.gz"
+	StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina (Wake County)"
+	StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08"
+	StrCpy $CUSTOM_UNTAR_FOLDER "North-Carolina"
+	Call DownloadDataSet
+SectionEnd
+Section /O "South Dakota (Spearfish County) Data Set" SecSpearfishSDB
+	StrCpy $ARCHIVE_SIZE_KB 20803
+	AddSize 42171
+	StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
+	StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish County)"
+	StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
+	StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
+SectionEnd
+;Uninstaller Section
+Section "Uninstall"
+	;remove files & folders
+	RMDir /r "$INSTDIR"
+	;remove the Desktop ShortCut
+	Delete "$DESKTOP\GRASS ${VERSION_NUMBER}.lnk"
+	Delete "$DESKTOP\GRASS ${VERSION_NUMBER} with MSYS.lnk"
+	;remove the Programs Start ShortCuts
+	RMDir /r "$SMPROGRAMS\${GRASS_BASE}"
+	;remove the $APPDATA\GRASS at GRASS_VERSION_MAJOR@ folder
+	;disabled, don't remove user settings
+	; SetShellVarContext current
+	;RMDir /r "$APPDATA\GRASS at GRASS_VERSION_MAJOR@"
+	;${If} ${FileExists} "$APPDATA\GRASS at GRASS_VERSION_MAJOR@\addons\*.*"
+	;      RMDir /r "$APPDATA\GRASS at GRASS_VERSION_MAJOR@\addons"
+	;${EndIf}
+	;remove the Registry Entries
+	DeleteRegKey HKLM "Software\${GRASS_BASE}"
+	DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
+SectionEnd
+;Installer Section Descriptions
+!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina (Wake County) sample data set"
+	!insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish County) sample data set"
+!insertmacro MUI_FUNCTION_DESCRIPTION_END
Deleted: grass/branches/releasebranch_6_4/mswindows/GRASS-Packager.bat
--- grass/branches/releasebranch_6_4/mswindows/GRASS-Packager.bat	2012-02-19 14:45:36 UTC (rev 50873)
+++ grass/branches/releasebranch_6_4/mswindows/GRASS-Packager.bat	2012-02-19 14:53:42 UTC (rev 50874)
@@ -1,238 +0,0 @@
- at echo off
-rem -----------------------------------------------------------------------------------------------------------------------
-rem Self Contained GRASS Automated Packager
-rem Edited by: Marco Pasetti
-rem Revised for OSGeo4W by: Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
-rem Last Update: $Id$
-rem --------------------------------------------------------------------------------------------------------------------------
-rem Set the script variables
-set PACKAGE_DIR=.\GRASS-64-Package
-set OSGEO4W_DIR=c:\osgeo4w
-set GRASS_PREFIX=%OSGEO4W_DIR%\apps\grass\grass-6.4.3svn
-set SVN_PATH=c:\Subversion
- at echo.
- at echo -----------------------------------------------------------------------------------------------------------------------
- at echo Remove the previous Selected Package and create a new PACKAGE_DIR
- at echo.
-if exist %PACKAGE_DIR% rmdir /S/Q %PACKAGE_DIR%
-mkdir %PACKAGE_DIR%
- at echo.
- at echo Copy %GRASS_PREFIX% content to PACKAGE_DIR
- at echo.
-xcopy %GRASS_PREFIX% %PACKAGE_DIR% /S/V/F
- at echo.
- at echo Copy Extralibs to PACKAGE_DIR\extralib
- at echo.
-mkdir %PACKAGE_DIR%\extralib
-copy %OSGEO4W_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
-del %PACKAGE_DIR%\extralib\libgrass_*6.4.0*.dll
-del %PACKAGE_DIR%\extralib\libgrass_*6.4.1*.dll
-del %PACKAGE_DIR%\extralib\libgrass_*6.5*.dll
-del %PACKAGE_DIR%\extralib\libgrass_*7.0*.dll
-del %PACKAGE_DIR%\extralib\Qt*4.dll
-rem copy %OSGEO4W_DIR%\pgsql\lib\libpq.dll %PACKAGE_DIR%\extralib
- at echo.
- at echo Move GRASS libs from extralib to lib
- at echo.
-move %PACKAGE_DIR%\extralib\libgrass_*.dll %PACKAGE_DIR%\lib
- at echo.
- at echo Copy Extrabins to PACKAGE_DIR\extrabin
- at echo.
-mkdir %PACKAGE_DIR%\extrabin
-mkdir %PACKAGE_DIR%\extrabin\gdalplugins
-copy %OSGEO4W_DIR%\bin\*.exe %PACKAGE_DIR%\extrabin
- at echo.
- at echo Copy SQLite content to PACKAGE_DIR\sqlite
- at echo.
-mkdir %PACKAGE_DIR%\sqlite
-mkdir %PACKAGE_DIR%\sqlite\bin
-mkdir %PACKAGE_DIR%\sqlite\include
-mkdir %PACKAGE_DIR%\sqlite\lib
-xcopy %OSGEO4W_DIR%\bin\sqlite3.dll %PACKAGE_DIR%\sqlite\bin /S/V/F/I
-copy %OSGEO4W_DIR%\include\btree.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\fts1*.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\hash.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\keywordhash.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\opcodes.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\os.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\os_common.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\pager.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\parse.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\sqlite*.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\vdbe.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\include\vdbeInt.h %PACKAGE_DIR%\sqlite\include
-copy %OSGEO4W_DIR%\lib\sqlite3_i.lib %PACKAGE_DIR%\sqlite\lib
- at echo.
- at echo Copy GPSBABEL executable and dll to PACKAGE_DIR\gpsbabel
- at echo.
-mkdir %PACKAGE_DIR%\gpsbabel
-copy %OSGEO4W_DIR%\gpsbabel.exe %PACKAGE_DIR%\gpsbabel
-rem copy %OSGEO4W_DIR%\libexpat.dll %PACKAGE_DIR%\gpsbabel
- at echo.
- at echo Copy shared PROJ.4 files to PACKAGE_DIR\proj
- at echo.
-xcopy %OSGEO4W_DIR%\share\proj %PACKAGE_DIR%\proj /S/V/F/I
- at echo.
- at echo Copy shared GDAL files to PACKAGE_DIR\share\gdal
- at echo.
-mkdir %PACKAGE_DIR%\share
-mkdir %PACKAGE_DIR%\share\gdal
-xcopy %OSGEO4W_DIR%\share\gdal %PACKAGE_DIR%\share\gdal /S/V/F/I
- at echo.
- at echo Copy shared GEOTIFF files to PACKAGE_DIR\share\epsg_csv
- at echo.
-mkdir %PACKAGE_DIR%\share\epsg_csv
-xcopy %OSGEO4W_DIR%\share\epsg_csv %PACKAGE_DIR%\share\epsg_csv /S/V/F/I
- at echo.
- at echo Copy Tcl/Tk content to PACKAGE_DIR\tcl-tk
- at echo.
-mkdir %PACKAGE_DIR%\tcl-tk
-mkdir %PACKAGE_DIR%\tcl-tk\bin
-mkdir %PACKAGE_DIR%\tcl-tk\include
-mkdir %PACKAGE_DIR%\tcl-tk\lib
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8.5\encoding
-mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5
-xcopy %OSGEO4W_DIR%\bin\tclpip85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tcl85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tclsh.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tclsh85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\tk85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\wish.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\bin\wish85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
-copy %OSGEO4W_DIR%\include\tcl*.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tk*.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tommath_class.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\tommath_superclass.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\include\ttkDecls.h %PACKAGE_DIR%\tcl-tk\include
-copy %OSGEO4W_DIR%\lib\tcl8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-copy %OSGEO4W_DIR%\lib\tcl8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
-copy %OSGEO4W_DIR%\lib\tcl8.5\encoding\*.enc %PACKAGE_DIR%\tcl-tk\lib\tcl8.5\encoding
-copy %OSGEO4W_DIR%\lib\tk8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-copy %OSGEO4W_DIR%\lib\tk8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tk8.5
-xcopy %OSGEO4W_DIR%\lib\tk8.5\ttk %PACKAGE_DIR%\tcl-tk\lib\tk8.5\ttk /S/V/F/I
-xcopy %OSGEO4W_DIR%\lib\tcl8\8.5 %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5 /S/V/F/I
- at echo.
- at echo Copy MSYS files to PACKAGE_DIR\msys
- at echo.
-mkdir %PACKAGE_DIR%\msys
-copy %OSGEO4W_DIR%\apps\msys\* %PACKAGE_DIR%\msys
-xcopy %OSGEO4W_DIR%\apps\msys\bin %PACKAGE_DIR%\msys\bin /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\doc %PACKAGE_DIR%\msys\doc /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\etc %PACKAGE_DIR%\msys\etc /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\info %PACKAGE_DIR%\msys\info /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\lib %PACKAGE_DIR%\msys\lib /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\msys\man %PACKAGE_DIR%\msys\man /S/V/F/I
-del %PACKAGE_DIR%\msys\etc\fstab
-rem delete msys.bat from osgeo4w because there is an adaption (for spaces in installation path) written by GRASS-Installer.nsi
-del %PACKAGE_DIR%\msys\msys.bat
- at echo.
- at echo Copy Python content to PACKAGE_DIR\Python27
- at echo.
-mkdir %PACKAGE_DIR%\Python27
-copy %OSGEO4W_DIR%\apps\Python27\* %PACKAGE_DIR%\Python27
-xcopy %OSGEO4W_DIR%\apps\Python27\DLLs %PACKAGE_DIR%\Python27\DLLs /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\include %PACKAGE_DIR%\Python27\include /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\Lib %PACKAGE_DIR%\Python27\Lib /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\libs %PACKAGE_DIR%\Python27\libs /S/V/F/I
-xcopy %OSGEO4W_DIR%\apps\Python27\Scripts %PACKAGE_DIR%\Python27\Scripts /S/V/F/I
- at echo.
- at echo Copy Subversion content to PACKAGE_DIR\extrabin & PACKAGE_DIR\extralib
- at echo.
-copy %SVN_PATH%\svn.exe %PACKAGE_DIR%\extrabin
-copy %SVN_PATH%\*.dll %PACKAGE_DIR%\extralib
- at echo.
- at echo Copy env.bat
- at echo.
-copy env.bat %PACKAGE_DIR%\etc
- at echo.
- at echo Packaging Completed
- at echo.
Copied: grass/branches/releasebranch_6_4/mswindows/GRASS-Packager.bat.tmpl (from rev 50873, grass/branches/releasebranch_6_4/mswindows/GRASS-Packager.bat)
--- grass/branches/releasebranch_6_4/mswindows/GRASS-Packager.bat.tmpl	                        (rev 0)
+++ grass/branches/releasebranch_6_4/mswindows/GRASS-Packager.bat.tmpl	2012-02-19 14:53:42 UTC (rev 50874)
@@ -0,0 +1,236 @@
+rem -----------------------------------------------------------------------------------------------------------------------
+rem Self Contained GRASS Automated Packager
+rem Edited by: Marco Pasetti
+rem Revised for OSGeo4W by: Colin Nielsen, Helmut Kudrnovsky, and Martin Landa
+rem Last Update: $Id$
+ at echo off
+rem --------------------------------------------------------------------------------------------------------------------------
+rem Set the script variables
+set PACKAGE_DIR=.\GRASS- at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at -Package
+set OSGEO4W_DIR=c:\osgeo4w
+set GRASS_PREFIX=%OSGEO4W_DIR%\apps\grass\grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@
+set GRASS_BIN_PREFIX=%OSGEO4W_DIR%\bin
+set SVN_PATH=c:\Subversion
+ at echo.
+ at echo -----------------------------------------------------------------------------------------------------------------------
+ at echo Remove the previous Selected Package and create a new PACKAGE_DIR
+ at echo.
+if exist %PACKAGE_DIR% rmdir /S/Q %PACKAGE_DIR%
+mkdir %PACKAGE_DIR%
+ at echo.
+ at echo Copy %GRASS_PREFIX% & %GRASS_BIN_PREFIX% content to PACKAGE_DIR
+ at echo.
+rem xcopy %GRASS_BIN_PREFIX%\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR at .py %PACKAGE_DIR% /S/V/F
+xcopy %GRASS_PREFIX% %PACKAGE_DIR% /S/V/F
+ at echo.
+ at echo Copy Extralibs to PACKAGE_DIR\extralib
+ at echo.
+mkdir %PACKAGE_DIR%\extralib
+copy %OSGEO4W_DIR%\bin\*.dll %PACKAGE_DIR%\extralib
+del %PACKAGE_DIR%\extralib\libgrass_*6.4*.dll
+del %PACKAGE_DIR%\extralib\libgrass_*6.5*.dll
+del %PACKAGE_DIR%\extralib\Qt*4.dll
+rem copy %OSGEO4W_DIR%\pgsql\lib\libpq.dll %PACKAGE_DIR%\extralib
+ at echo.
+ at echo Move GRASS libs from extralib to lib
+ at echo.
+move %PACKAGE_DIR%\extralib\libgrass_*.dll %PACKAGE_DIR%\lib
+ at echo.
+ at echo Copy Extrabins to PACKAGE_DIR\extrabin
+ at echo.
+mkdir %PACKAGE_DIR%\extrabin
+mkdir %PACKAGE_DIR%\extrabin\gdalplugins
+copy %OSGEO4W_DIR%\bin\*.exe %PACKAGE_DIR%\extrabin
+ at echo.
+ at echo Copy SQLite content to PACKAGE_DIR\sqlite
+ at echo.
+mkdir %PACKAGE_DIR%\sqlite
+mkdir %PACKAGE_DIR%\sqlite\bin
+mkdir %PACKAGE_DIR%\sqlite\include
+mkdir %PACKAGE_DIR%\sqlite\lib
+xcopy %OSGEO4W_DIR%\bin\sqlite3.dll %PACKAGE_DIR%\sqlite\bin /S/V/F/I
+copy %OSGEO4W_DIR%\include\btree.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\fts1*.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\hash.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\keywordhash.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\opcodes.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\os.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\os_common.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\pager.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\parse.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\sqlite*.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\vdbe.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\include\vdbeInt.h %PACKAGE_DIR%\sqlite\include
+copy %OSGEO4W_DIR%\lib\sqlite3_i.lib %PACKAGE_DIR%\sqlite\lib
+ at echo.
+ at echo Copy GPSBABEL executable and dll to PACKAGE_DIR\gpsbabel
+ at echo.
+mkdir %PACKAGE_DIR%\gpsbabel
+copy %OSGEO4W_DIR%\gpsbabel.exe %PACKAGE_DIR%\gpsbabel
+rem copy %OSGEO4W_DIR%\libexpat.dll %PACKAGE_DIR%\gpsbabel
+ at echo.
+ at echo Copy shared PROJ.4 files to PACKAGE_DIR\proj
+ at echo.
+xcopy %OSGEO4W_DIR%\share\proj %PACKAGE_DIR%\proj /S/V/F/I
+ at echo.
+ at echo Copy shared GDAL files to PACKAGE_DIR\share\gdal
+ at echo.
+mkdir %PACKAGE_DIR%\share
+mkdir %PACKAGE_DIR%\share\gdal
+xcopy %OSGEO4W_DIR%\share\gdal %PACKAGE_DIR%\share\gdal /S/V/F/I
+ at echo.
+ at echo Copy shared GEOTIFF files to PACKAGE_DIR\share\epsg_csv
+ at echo.
+mkdir %PACKAGE_DIR%\share\epsg_csv
+xcopy %OSGEO4W_DIR%\share\epsg_csv %PACKAGE_DIR%\share\epsg_csv /S/V/F/I
+ at echo.
+ at echo Copy Tcl/Tk content to PACKAGE_DIR\tcl-tk
+ at echo.
+mkdir %PACKAGE_DIR%\tcl-tk
+mkdir %PACKAGE_DIR%\tcl-tk\bin
+mkdir %PACKAGE_DIR%\tcl-tk\include
+mkdir %PACKAGE_DIR%\tcl-tk\lib
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+mkdir %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5
+xcopy %OSGEO4W_DIR%\bin\tclpip85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tcl85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tclsh.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tclsh85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\tk85.dll %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\wish.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\bin\wish85.exe %PACKAGE_DIR%\tcl-tk\bin /S/V/F/I
+copy %OSGEO4W_DIR%\include\tcl*.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tk*.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tommath_class.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\tommath_superclass.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\include\ttkDecls.h %PACKAGE_DIR%\tcl-tk\include
+copy %OSGEO4W_DIR%\lib\tcl8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+copy %OSGEO4W_DIR%\lib\tcl8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tcl8.5
+copy %OSGEO4W_DIR%\lib\tk8.5\*.tcl %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+copy %OSGEO4W_DIR%\lib\tk8.5\tclIndex %PACKAGE_DIR%\tcl-tk\lib\tk8.5
+xcopy %OSGEO4W_DIR%\lib\tk8.5\ttk %PACKAGE_DIR%\tcl-tk\lib\tk8.5\ttk /S/V/F/I
+xcopy %OSGEO4W_DIR%\lib\tcl8\8.5 %PACKAGE_DIR%\tcl-tk\lib\tcl8\8.5 /S/V/F/I
+ at echo.
+ at echo Copy MSYS files to PACKAGE_DIR\msys
+ at echo.
+mkdir %PACKAGE_DIR%\msys
+copy %OSGEO4W_DIR%\apps\msys\* %PACKAGE_DIR%\msys
+xcopy %OSGEO4W_DIR%\apps\msys\bin %PACKAGE_DIR%\msys\bin /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\doc %PACKAGE_DIR%\msys\doc /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\etc %PACKAGE_DIR%\msys\etc /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\info %PACKAGE_DIR%\msys\info /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\lib %PACKAGE_DIR%\msys\lib /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\msys\man %PACKAGE_DIR%\msys\man /S/V/F/I
+del %PACKAGE_DIR%\msys\etc\fstab
+rem delete msys.bat from osgeo4w because there is an adaption (for spaces in installation path) written by GRASS-Installer.nsi
+del %PACKAGE_DIR%\msys\msys.bat
+ at echo.
+ at echo Copy Python content to PACKAGE_DIR\Python27
+ at echo.
+mkdir %PACKAGE_DIR%\Python27
+copy %OSGEO4W_DIR%\apps\Python27\* %PACKAGE_DIR%\Python27
+xcopy %OSGEO4W_DIR%\apps\Python27\DLLs %PACKAGE_DIR%\Python27\DLLs /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python27\include %PACKAGE_DIR%\Python27\include /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python27\Lib %PACKAGE_DIR%\Python27\Lib /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python27\libs %PACKAGE_DIR%\Python27\libs /S/V/F/I
+xcopy %OSGEO4W_DIR%\apps\Python27\Scripts %PACKAGE_DIR%\Python27\Scripts /S/V/F/I
+ at echo.
+ at echo Copy Subversion content to PACKAGE_DIR\extrabin & PACKAGE_DIR\extralib
+ at echo.
+copy %SVN_PATH%\svn.exe %PACKAGE_DIR%\extrabin
+copy %SVN_PATH%\*.dll %PACKAGE_DIR%\extralib
+ at echo.
+ at echo Copy env.bat
+ at echo.
+copy env.bat %PACKAGE_DIR%\etc
+ at echo.
+ at echo Packaging Completed
+ at echo.
Added: grass/branches/releasebranch_6_4/mswindows/Makefile
--- grass/branches/releasebranch_6_4/mswindows/Makefile	                        (rev 0)
+++ grass/branches/releasebranch_6_4/mswindows/Makefile	2012-02-19 14:53:42 UTC (rev 50874)
@@ -0,0 +1,26 @@
+MODULE_TOPDIR = ..
+include $(MODULE_TOPDIR)/include/Make/Platform.make
+include $(MODULE_TOPDIR)/include/Make/Grass.make
+include $(MODULE_TOPDIR)/include/Make/Rules.make
+EXTRA_CLEAN_FILES = GRASS-Packager.bat GRASS-Installer.nsi
+ifneq ($(MINGW),)
+default: GRASS-Packager.bat GRASS-Installer.nsi
+endif
+GRASS-Packager.bat: GRASS-Packager.bat.tmpl
+	sed \
+	-e 's#@GRASS_VERSION_MAJOR@#$(GRASS_VERSION_MAJOR)#' \
+	-e 's#@GRASS_VERSION_MINOR@#$(GRASS_VERSION_MINOR)#' \
+	-e 's#@GRASS_VERSION_RELEASE@#$(GRASS_VERSION_RELEASE)#' \
+GRASS-Installer.nsi: GRASS-Installer.nsi.tmpl
+	sed \
+	-e 's#@GRASS_VERSION_SVN@#$(GRASS_VERSION_SVN)#' \
Modified: grass/branches/releasebranch_6_4/mswindows/env.bat
--- grass/branches/releasebranch_6_4/mswindows/env.bat	2012-02-19 14:45:36 UTC (rev 50873)
+++ grass/branches/releasebranch_6_4/mswindows/env.bat	2012-02-19 14:53:42 UTC (rev 50874)
@@ -1,35 +1,17 @@
-set WINGISBASE=%GISBASE%
+rem Environmental variables for GRASS stand-alone installer
-rem Directory where your .grassrc6 file will be stored
-set HOME=%USERPROFILE%
-rem Name of the wish (Tk) executable
-set GRASS_WISH=wish.exe
-rem Path to the shell command
+set GRASS_WISH=%GISBASE%\extrabin\wish.exe
+set GRASS_PYTHON=python
+set GRASS_PROJSHARE=%GISBASE%\proj
+set GRASS_HTML_BROWSER=explorer
 set GRASS_SH=%GISBASE%\msys\bin\sh.exe
-rem Set Path to utilities (libraries and binaries) used by GRASS
-set PATH=%GISBASE%\msys\bin;%PATH%
-set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%
-set PATH=%GISBASE%\tcl-tk\bin;%GISBASE%\sqlite\bin;%GISBASE%\gpsbabel;%PATH%
-set PATH=%GISBASE%\bin;%GISBASE%\scripts;%PATH%
-rem Set Path to default web browser
-set GRASS_HTML_BROWSER=explorer
-rem Path to the proj files (notably the epsg projection list)
-set GRASS_PROJSHARE=%GISBASE%\proj
-rem Set GDAL_DATA
+set PYTHONHOME=%GISBASE%\Python27
 set GDAL_DATA=%GISBASE%\share\gdal
-rem Set PROJ_LIB
 set PROJ_LIB=%GISBASE%\proj
-rem Set GEOTIFF_CSV
 set GEOTIFF_CSV=%GISBASE%\share\epsg_csv
-rem Path to the python directory
-set PYTHONHOME=%GISBASE%\Python27
-if "x%GRASS_PYTHON%" == "x" set GRASS_PYTHON=python
+set PATH=%GISBASE%\msys\bin;%PATH%
+set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%
+set PATH=%GISBASE%\tcl-tk\bin;%GISBASE%\sqlite\bin;%GISBASE%\gpsbabel;%PATH%
+set PATH=%GISBASE%\bin;%PATH%
Modified: grass/branches/releasebranch_6_4/mswindows/osgeo4w/env.bat.tmpl
--- grass/branches/releasebranch_6_4/mswindows/osgeo4w/env.bat.tmpl	2012-02-19 14:45:36 UTC (rev 50873)
+++ grass/branches/releasebranch_6_4/mswindows/osgeo4w/env.bat.tmpl	2012-02-19 14:53:42 UTC (rev 50874)
@@ -1,9 +1,16 @@
+rem Environmental variables for GRASS OSGeo4W installer
 set GISBASE=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@
 set GRASS_SH=%OSGEO4W_ROOT%\apps\msys\bin\sh.exe
 set GRASS_WISH=%OSGEO4W_ROOT%\bin\wish.exe
-set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python.exe
 set GRASS_PROJSHARE=%OSGEO4W_ROOT%\share\proj
-set PATH=%OSGEO4W_ROOT%\apps\msys\bin;%PATH%
-set PATH=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@\bin;%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@\lib;%PATH%
+set PYTHONHOME=%OSGEO4W_ROOT%\apps\Python27
+set GDAL_DATA=%OSGEO4W_ROOT%\share\gdal
+set PROJ_LIB=%OSGEO4W_ROOT%\proj
+set GEOTIFF_CSV=%OSGEO4W_ROOT%\share\epsg_csv
+set PATH=%GISBASE%\bin;%OSGEO4W_ROOT%\apps\msys\bin;%PATH%
