[GRASS-SVN] r50903 - grass/branches/releasebranch_6_4/ps/ps.map/decorations
Mon Feb 20 10:31:54 EST 2012
Author: annakrat
Date: 2012-02-20 07:31:54 -0800 (Mon, 20 Feb 2012)
New Revision: 50903
Added:
   grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow1.eps
   grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow3.eps
   grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow5.eps
   grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow1.eps
   grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow1_fancy.eps
   grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow2.eps
   grass/branches/releasebranch_6_4/ps/ps.map/decorations/north-arrow_1_simple_half_arrow.eps
fixed eps north arrow images with eps2eps (merge from trunk, r50901)
Copied: grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow1.eps (from rev 49326, grass/trunk/ps/ps.map/decorations/NorthArrow1.eps)
--- grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow1.eps	                        (rev 0)
+++ grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow1.eps	2012-02-20 15:31:54 UTC (rev 50903)
@@ -0,0 +1,91 @@
+%!PS-Adobe-3.0 EPSF-3.0
+%%BoundingBox: 0 0 87 101
+%%HiResBoundingBox: 0.450000 0.448828 86.608984 100.048828
+%%Creator: GPL Ghostscript 871 (epswrite)
+%%CreationDate: 2012/02/20 11:20:49
+%%DocumentData: Clean7Bit
+%%LanguageLevel: 2
+%%EndComments
+%%BeginProlog
+% This copyright applies to everything between here and the %%EndProlog:
+% Copyright (C) 2010 Artifex Software, Inc.  All rights reserved.
+%%BeginResource: procset GS_epswrite_2_0_1001 1.001 0
+/GS_epswrite_2_0_1001 80 dict dup begin
+/PageSize 2 array def/setpagesize{ PageSize aload pop 3 index eq exch
+4 index eq and{ pop pop pop}{ PageSize dup  1
+5 -1 roll put 0 4 -1 roll put dup null eq {false} {dup where} ifelse{ exch get exec}
+{ pop/setpagedevice where
+{ pop 1 dict dup /PageSize PageSize put setpagedevice}
+{ /setpage where{ pop PageSize aload pop pageparams 3 {exch pop} repeat
+setpage}if}ifelse}ifelse}ifelse} bind def
+/!{bind def}bind def/#{load def}!/N/counttomark #
+/rG{3{3 -1 roll 255 div}repeat setrgbcolor}!/G{255 div setgray}!/K{0 G}!
+/r6{dup 3 -1 roll rG}!/r5{dup 3 1 roll rG}!/r3{dup rG}!
+/w/setlinewidth #/J/setlinecap #
+/j/setlinejoin #/M/setmiterlimit #/d/setdash #/i/setflat #
+/m/moveto #/l/lineto #/c/rcurveto #
+/p{N 2 idiv{N -2 roll rlineto}repeat}!
+/P{N 0 gt{N -2 roll moveto p}if}!
+/h{p closepath}!/H{P closepath}!
+/lx{0 rlineto}!/ly{0 exch rlineto}!/v{0 0 6 2 roll c}!/y{2 copy c}!
+/re{4 -2 roll m exch dup lx exch ly neg lx h}!
+/^{3 index neg 3 index neg}!
+/f{P fill}!/f*{P eofill}!/s{H stroke}!/S{P stroke}!
+/q/gsave #/Q/grestore #/rf{re fill}!
+/Y{P clip newpath}!/Y*{P eoclip newpath}!/rY{re Y}!
+/|={pop exch 4 1 roll 1 array astore cvx 3 array astore cvx exch 1 index def exec}!
+/|{exch string readstring |=}!
+/+{dup type/nametype eq{2 index 7 add -3 bitshift 2 index mul}if}!
+/@/currentfile #/${+ @ |}!
+/B{{2 copy string{readstring pop}aload pop 4 array astore cvx
+3 1 roll}repeat pop pop true}!
+/Ix{[1 0 0 1 11 -2 roll exch neg exch neg]exch}!
+/,{true exch Ix imagemask}!/If{false exch Ix imagemask}!/I{exch Ix image}!
+/Ic{exch Ix false 3 colorimage}!
+/F{/Columns counttomark 3 add -2 roll/Rows exch/K -1/BlackIs1 true>>
+/CCITTFaxDecode filter}!/FX{<</EndOfBlock false F}!
+/X{/ASCII85Decode filter}!/@X{@ X}!/&2{2 index 2 index}!
+/@F{@ &2<<F}!/@C{@X &2 FX}!
+/$X{+ @X |}!/&4{4 index 4 index}!/$F{+ @ &4<<F |}!/$C{+ @X &4 FX |}!
+/IC{3 1 roll 10 dict begin 1{/ImageType/Interpolate/Decode/DataSource
+/ImageMatrix/BitsPerComponent/Height/Width}{exch def}forall
+currentdict end image}!
+/~{@ read {pop} if}!
+end def
+%%EndResource
+/pagesave null def
+%%EndProlog
+%%Page: 1 1
+%%BeginPageSetup
+GS_epswrite_2_0_1001 begin
+/pagesave save store 197 dict begin
+0.1 0.1 scale
+%%EndPageSetup
+gsave mark
+Q q
+0 0 250000 250000 re
+Y
+K
+435.27 846.6 27.66 -393.75 402.66 -27.04 -402.66 -27.03 -27.66 -393.79 -27.65 393.79 -402.62 27.03 402.62 27.04
+27.65 393.75 H
+f
+10 w
+4 M
+435.27 846.59 27.66 -393.75 402.66 -27.03 -402.66 -27.03 -27.66 -393.79 -27.65 393.79 -402.62 27.03 402.62 27.03
+27.65 393.75 H
+435.27 846.59 S
+374.34 859.95 0 140.04 22.65 0 50.78 -70.86 P
+11.57 -16.4 20.98 -30.97 28.32 -45.5 c
+0.71 0.19 p
+-1.88 18.71 -2.35 35.74 -2.35 57.35 c
+0 58.82 19.34 0 0 -140.04 -20.78 0 -50.51 71.06 p
+-11.09 15.59 -21.72 31.56 -29.53 46.76 c
+-0.7 -0.2 p
+1.21 -17.69 1.4 -34.49 1.4 -57.81 c
+0 -59.81 -19.33 0 h
+f
+cleartomark end end pagesave restore
+ showpage
+%%PageTrailer
+%%Trailer
+%%Pages: 1
Copied: grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow3.eps (from rev 49326, grass/trunk/ps/ps.map/decorations/NorthArrow3.eps)
--- grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow3.eps	                        (rev 0)
+++ grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow3.eps	2012-02-20 15:31:54 UTC (rev 50903)
@@ -0,0 +1,93 @@
+%%BoundingBox: 0 0 28 100
+%%HiResBoundingBox: 0.000000 0.000000 27.209766 99.950000
+%%CreationDate: 2012/02/20 11:21:50
+%%LanguageLevel: 2
+%%EndComments
+%%BeginProlog
+end def
+%%EndResource
+/pagesave null def
+%%EndProlog
+%%Page: 1 1
+%%BeginPageSetup
+0.1 0.1 scale
+%%EndPageSetup
+gsave mark
+Q q
+Y
+K
+63.28 843.69 0 155.31 25.16 0 56.25 -78.55 P
+12.81 -18.2 23.28 -34.37 31.44 -50.47 c
+0.75 0.24 p
+-2.08 20.74 -2.62 39.61 -2.62 63.55 c
+0 65.23 21.44 0 0 -155.31 -23 0 -56.02 78.79 p
+-12.3 17.31 -24.1 35.04 -32.73 51.88 c
+-0.79 -0.24 p
+1.33 -19.61 1.57 -38.24 1.57 -64.06 c
+0 -66.37 -21.45 0 h
+f
+88.75 4.98047 85.8984 589.848 re
+f
+10 w
+4 M
+88.75 4.98438 85.8984 589.84 re
+S
+134.1 821.7 64.53 -111.8 64.57 -111.83 -258.2 0 64.57 111.83 64.53 111.8 H
+f
+134.1 821.7 64.53 -111.8 64.57 -111.84 -258.2 0 64.57 111.84 64.53 111.8 H
+134.1 821.7 S
+ showpage
+%%PageTrailer
+%%Trailer
+%%Pages: 1
Copied: grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow5.eps (from rev 49326, grass/trunk/ps/ps.map/decorations/NorthArrow5.eps)
--- grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow5.eps	                        (rev 0)
+++ grass/branches/releasebranch_6_4/ps/ps.map/decorations/NorthArrow5.eps	2012-02-20 15:31:54 UTC (rev 50903)
@@ -0,0 +1,108 @@
+%%BoundingBox: -1 0 40 101
+%%HiResBoundingBox: -0.048828 0.001172 39.033984 100.403125
+%%CreationDate: 2012/02/20 11:22:00
+%%LanguageLevel: 2
+%%EndComments
+%%BeginProlog
+end def
+%%EndResource
+/pagesave null def
+%%EndProlog
+%%Page: 1 1
+%%BeginPageSetup
+0.1 0.1 scale
+%%EndPageSetup
+gsave mark
+Q q
+Y
+K
+372.3 370.25 m
+0 -101.45 -82.22 -183.67 -183.63 -183.67 c
+-101.44 0 -183.67 82.22 -183.67 183.67 c
+0 101.44 82.23 183.67 183.67 183.67 c
+101.45 0 183.67 -82.23 183.67 -183.67 c
+-0.04 0 h
+f
+10 w
+4 M
+372.3 370.25 m
+-0.04 0 h
+372.3 370.25 S
+128.871 5.01172 123.707 714.77 re
+f
+S
+194.22 994.7 92.97 -135.51 93.01 -135.47 -371.96 0 92.97 135.47 93.01 135.51 H
+f
+194.22 994.7 S
+255 G
+94.49 273.18 0 188.24 36.17 0 81.1 -95.24 P
+18.47 -22.07 33.55 -41.64 45.23 -61.13 c
+1.13 0.24 p
+-3 25.15 -3.74 48.04 -3.74 77.11 c
+0 79.02 30.93 0 0 -188.24 -33.2 0 -80.7 95.5 p
+-17.7 20.94 -34.69 42.47 -47.15 62.86 c
+-1.1 -0.32 p
+1.88 -23.71 2.27 -46.32 2.27 -77.61 c
+0 -80.43 -30.94 0 h
+f
+ showpage
+%%PageTrailer
+%%Trailer
+%%Pages: 1
Copied: grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow1.eps (from rev 49326, grass/trunk/ps/ps.map/decorations/n_arrow1.eps)
--- grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow1.eps	                        (rev 0)
+++ grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow1.eps	2012-02-20 15:31:54 UTC (rev 50903)
@@ -0,0 +1,80 @@
+%%BoundingBox: -1 0 51 102
+%%HiResBoundingBox: -0.039453 0.000000 50.700000 101.114453
+%%CreationDate: 2012/02/20 11:23:35
+%%LanguageLevel: 2
+%%EndComments
+%%BeginProlog
+end def
+%%EndResource
+/pagesave null def
+%%EndProlog
+%%Page: 1 1
+%%BeginPageSetup
+0.1 0.1 scale
+%%EndPageSetup
+gsave mark
+Q q
+Y
+K
+247.93 254.47 -11.33 740.78 263.13 -983.95 -251.8 243.17 f
+255 G
+247.93 254.47 -11.33 740.78 -232.85 -991.48 244.18 250.7 f
+7.5 w
+K
+247.93 254.47 -244.18 -250.7 232.85 991.48 263.13 -983.95 -251.8 243.17 H
+247.93 254.47 S
+ showpage
+%%PageTrailer
+%%Trailer
+%%Pages: 1
Copied: grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow1_fancy.eps (from rev 49326, grass/trunk/ps/ps.map/decorations/n_arrow1_fancy.eps)
--- grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow1_fancy.eps	                        (rev 0)
+++ grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow1_fancy.eps	2012-02-20 15:31:54 UTC (rev 50903)
@@ -0,0 +1,92 @@
+%%BoundingBox: 0 0 76 100
+%%HiResBoundingBox: 0.000000 0.000000 75.355078 99.013281
+%%CreationDate: 2012/02/20 11:23:18
+%%LanguageLevel: 2
+%%EndComments
+%%BeginProlog
+end def
+%%EndResource
+/pagesave null def
+%%EndProlog
+%%Page: 1 1
+%%BeginPageSetup
+0.1 0.1 scale
+%%EndPageSetup
+gsave mark
+Q q
+Y
+K
+379.18 219.06 -7.23 473.12 167.35 -628.43 -160.12 155.31 f
+255 G
+379.18 219.06 -7.23 473.12 -148.04 -633.24 155.27 160.12 f
+7.5 w
+K
+379.18 219.06 -155.27 -160.12 148.04 633.25 167.35 -628.44 -160.12 155.31 H
+379.18 219.06 S
+17.5 w
+744.8 376.8 m
+0 -203.29 -164.76 -368.05 -368 -368.05 c
+-203.28 0 -368.05 164.76 -368.05 368.05 c
+0 203.24 164.77 368 368.05 368 c
+203.24 0 368 -164.76 368 -368 c
+h
+744.8 376.8 S
+0.2 i
+428.03 990.14 -17.99 -0.28 1.92 -125.09 -81.93 123.86 -21.21 -0.33 2.36 -153.44 18 0.28 -1.92 124.66
+81.07 -123.44 22.05 0.34 H
+f
+ showpage
+%%PageTrailer
+%%Trailer
+%%Pages: 1
Copied: grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow2.eps (from rev 49326, grass/trunk/ps/ps.map/decorations/n_arrow2.eps)
--- grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow2.eps	                        (rev 0)
+++ grass/branches/releasebranch_6_4/ps/ps.map/decorations/n_arrow2.eps	2012-02-20 15:31:54 UTC (rev 50903)
@@ -0,0 +1,82 @@
+%%BoundingBox: 0 0 22 100
+%%HiResBoundingBox: 0.025000 0.000000 22.000000 99.766406
+%%CreationDate: 2012/02/20 11:23:00
+%%LanguageLevel: 2
+%%EndComments
+%%BeginProlog
+end def
+%%EndResource
+/pagesave null def
+%%EndProlog
+%%Page: 1 1
+%%BeginPageSetup
+0.1 0.1 scale
+%%EndPageSetup
+gsave mark
+Q q
+Y
+20.2885 w
+4 M
+K
+q 0.83196 1.16804 scale
+132.22 852.68 -94.29 -648.26 47.04 -6.86 102.45 -112.16 -7.98 112.16 47.04 6.86 -94.28 648.26 H
+132.22 852.68 S
+Q
+15.49 49.79 -3.47 -32.48 60.1 -8.77 8.22 122.54 111.97 -122.54 60.1 8.77 -3.48 32.48 S
+Q
+ showpage
+%%PageTrailer
+%%Trailer
+%%Pages: 1
Copied: grass/branches/releasebranch_6_4/ps/ps.map/decorations/north-arrow_1_simple_half_arrow.eps (from rev 49326, grass/trunk/ps/ps.map/decorations/north-arrow_1_simple_half_arrow.eps)
--- grass/branches/releasebranch_6_4/ps/ps.map/decorations/north-arrow_1_simple_half_arrow.eps	                        (rev 0)
+++ grass/branches/releasebranch_6_4/ps/ps.map/decorations/north-arrow_1_simple_half_arrow.eps	2012-02-20 15:31:54 UTC (rev 50903)
@@ -0,0 +1,78 @@
+%%BoundingBox: -1 -1 20 101
+%%HiResBoundingBox: -0.049609 -0.049609 19.191016 100.050000
+%%CreationDate: 2012/02/20 11:22:27
+%%LanguageLevel: 2
+%%EndComments
+%%BeginProlog
+end def
+%%EndResource
+/pagesave null def
+%%EndProlog
+%%Page: 1 1
+%%BeginPageSetup
+0.1 0.1 scale
+%%EndPageSetup
+gsave mark
+Q q
+Y
+K
+32.54 0 3.44 868.67 155.43 -255.58 -107.07 69.06 6.91 -680.43 -58.71 -1.72 H
+f
+0 1000 27.97 0 36.48 -53.59 0 53.59 28.25 0 0 -96.91 ^ -36.29 53.2
+0 -53.2 -28.16 0 0 96.91 H
+f
+ showpage
+%%PageTrailer
+%%Trailer
+%%Pages: 1
