[GRASS-SVN] r50921 - grass/branches/releasebranch_6_4/scripts/r.mask
Wed Feb 22 14:36:23 EST 2012
Author: hamish
Date: 2012-02-22 11:36:23 -0800 (Wed, 22 Feb 2012)
New Revision: 50921
   grass/branches/releasebranch_6_4/scripts/r.mask/description.html
   grass/branches/releasebranch_6_4/scripts/r.mask/r.mask
merge changes from devbr6 (mainly quoting variables)
Modified: grass/branches/releasebranch_6_4/scripts/r.mask/description.html
--- grass/branches/releasebranch_6_4/scripts/r.mask/description.html	2012-02-22 19:34:14 UTC (rev 50920)
+++ grass/branches/releasebranch_6_4/scripts/r.mask/description.html	2012-02-22 19:36:23 UTC (rev 50921)
@@ -25,7 +25,7 @@
 <p>
 To restore raster operations to normal (i.e., all cells of the current region),
-remove the MASK file by setting the <b>-r</b> remove MASK flag. In this case, a
+remove the MASK map by setting the <b>-r</b> remove MASK flag. In this case, a
 dummy value must also be given for the input parameter.
 A MASK also can be removed by using <em>g.remove</em>
 or by renaming it to any other name with <em>g.rename</em>.
@@ -35,7 +35,7 @@
 The above method for specifying a "mask" may seem
 counterintuitive.  Areas inside the MASK are not hidden;
-areas outside the MASK will be ignored until the MASK file
+areas outside the MASK will be ignored until the MASK map
 is removed.
 <p>
@@ -60,19 +60,19 @@
 <h2>EXAMPLES</h2>
-Creating a raster mask, for showing only elevations of lakes:
+Creating a raster MASK, for showing only elevations of lakes:
 <div class="code"><pre>
 r.mask input=lakes
 # statistics only for elevation pixels in the lakes:
 r.univar elevation
 </pre></div>
-Removing a raster mask with the -r flag:
+Removing a raster MASK with the -r flag:
 r.mask -r
 </pre></div>
-Creating a mask from categories 3 through 6 in the North Carolina
+Creating a MASK from categories 3 through 6 in the North Carolina
 'geology_30m' raster map:
 g.region rast=geology_30m -p
Modified: grass/branches/releasebranch_6_4/scripts/r.mask/r.mask
--- grass/branches/releasebranch_6_4/scripts/r.mask/r.mask	2012-02-22 19:34:14 UTC (rev 50920)
+++ grass/branches/releasebranch_6_4/scripts/r.mask/r.mask	2012-02-22 19:36:23 UTC (rev 50921)
@@ -15,8 +15,8 @@
 #%module
-#%  description: Creates a MASK for limiting raster operation.
-#%  keywords: raster, mask
+#% description: Creates a MASK for limiting raster operation.
+#% keywords: raster, mask
 #%end
 #%option
 #% key: input
@@ -58,7 +58,7 @@
 fi
 if [ -z "$GRASS_VERBOSE" ] || [ "$GRASS_VERBOSE" -le 2 ] ; then
-  BEQUIET="--q"
+  BEQUIET="--quiet"
 else
   BEQUIET=""
 fi
@@ -83,10 +83,10 @@
 trap "exitprocedure" 2 3 15
 # if map is given check if existing
-if [ $GIS_OPT_INPUT ]; then
-   eval `g.findfile element=cell file=$GIS_OPT_INPUT`
-   filename="${fullname}"
-   if [ "$filename" = "" ] ; then
+if [ -n "$GIS_OPT_INPUT" ]; then
+   eval `g.findfile element=cell file="$GIS_OPT_INPUT"`
+   filename="$fullname"
+   if [ -z "$filename" ] ; then
       g.message -e "Raster map <$GIS_OPT_INPUT> not found"
       exit 1
    fi
@@ -103,39 +103,39 @@
 if [ "$GIS_FLAG_R" -eq 1 ]; then
 	if test -f "`g.gisenv GISDBASE`/`g.gisenv LOCATION_NAME`/`g.gisenv MAPSET`/cell/MASK" ; then
  		g.remove rast=MASK
- 		g.message ${BEQUIET} "Raster MASK removed"
+ 		g.message $BEQUIET "Raster MASK removed"
  	else
- 		g.message ${BEQUIET} -w "No existing MASK to remove"
+ 		g.message $BEQUIET -w "No existing MASK to remove"
 	fi
 else
-	if [ ! $GIS_OPT_INPUT ]; then
-		g.message ${BEQUIET} -w "No raster map for MASK provided"
+	if [ -z "$GIS_OPT_INPUT" ]; then
+		g.message $BEQUIET -w "No raster map for MASK provided"
 		exit 1;
 	fi
 	if [ "$GIS_FLAG_O" -eq 1 ]; then
-		echo "$GIS_OPT_MASKCATS = 1" | r.reclass input=$GIS_OPT_INPUT output=MASK --o
+		echo "$GIS_OPT_MASKCATS = 1" | r.reclass input="$GIS_OPT_INPUT" output=MASK --o
 	else
 		# does map exist in CURRENT mapset?
-		eval `g.findfile element=cell file=MASK mapset=$MAPSET`
-		if [ "$file" ] ; then
+		eval `g.findfile element=cell file=MASK mapset="$MAPSET"`
+		if [ -n "$file" ] ; then
 		   g.message -e "MASK already found in current mapset. Delete first or overwrite"
 		   exit 1
 		fi
 	fi
         if [ "$GIS_FLAG_I" -eq 1 ]; then
-		g.rename --q rast=MASK,$TEMPRAST
-		r.mapcalc "MASK=if(isnull($TEMPRAST),1,null())"
-		g.remove --q rast=$TEMPRAST
-		g.message ${BEQUIET} "Inverted MASK created. All subsequent raster operations"
+		g.rename --q rast=MASK,"$TEMPRAST"
+		r.mapcalc "MASK = if(isnull($TEMPRAST),1,null())"
+		g.remove --q rast="$TEMPRAST"
+		g.message $BEQUIET "Inverted MASK created. All subsequent raster operations"
 	else
-	  g.message ${BEQUIET} "MASK created. All subsequent raster operations"
+	  g.message $BEQUIET "MASK created. All subsequent raster operations"
 	fi
-        g.message ${BEQUIET} "will be limited to MASK area"
-        g.message ${BEQUIET} "Removing or renaming raster file named MASK will"
-        g.message ${BEQUIET} "restore raster operations to normal"
+        g.message $BEQUIET "will be limited to MASK area"
+        g.message $BEQUIET "Removing or renaming raster file named MASK will"
+        g.message $BEQUIET "restore raster operations to normal"
 fi
 exit 0
