[GRASS-SVN] r50953 - sandbox/lucadelu
Sun Feb 26 18:17:54 EST 2012
Author: lucadelu
Date: 2012-02-26 15:17:54 -0800 (Sun, 26 Feb 2012)
New Revision: 50953
   sandbox/lucadelu/r.li.setup.py
r.li.setup improvement
Modified: sandbox/lucadelu/r.li.setup.py
--- sandbox/lucadelu/r.li.setup.py	2012-02-26 23:00:05 UTC (rev 50952)
+++ sandbox/lucadelu/r.li.setup.py	2012-02-26 23:17:54 UTC (rev 50953)
@@ -10,6 +10,7 @@
 	      sampling region)
  - Keybord (page to insert region areas from keybord)
  - SamplingAreas (define sampling area)
+ - SummaryPage (show choosen options)
 (C) 2011 by the GRASS Development Team
 This program is free software under the GNU General Public License
@@ -30,9 +31,9 @@
 import time
 from core import globalvar
+from gui_core import gselect
 from core import gcmd
 from core import utils
-from gui_core import gselect
 from location_wizard.wizard import TitledPage as TitledPage
 from grass.script import core as grass
 from grass.script import raster as grast
@@ -47,17 +48,23 @@
     else:
         wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+def retRLiPath():
+    major_version = int(grass.version()['version'].split('.', 1)[0])
+    rlipath = os.path.join(os.environ['HOME'], '.grass%d' % major_version, 'r.li')
+    if os.path.exists(rlipath):
+        return rlipath
+    else:
+        os.mkdir(rlipath)
+        return rlipath
 class RLiSetupFrame(wx.Frame):
     def __init__(self, parent, id = wx.ID_ANY,
         style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
                 title = _("r.li.setup"), **kwargs):
-        ###VARIABLES
+	###VARIABLES
         self.parent = parent
         self.cmd = "r.li.setup"
-        self.major_version = int(grass.version()['version'].split('.', 1)[0])
-        self.rlipath = os.path.join(os.environ['HOME'], '.grass%d' % self.major_version, 'r.li')
-        #check if self.rlipath exists
-        self.CheckFolder()
+        self.rlipath = retRLiPath()
         self.listfiles = self.ListFiles()
         ###END VARIABLES
         #init of frame
@@ -121,14 +128,6 @@
         sizer.Fit(self.panel)
         self.Layout()
-    def CheckFolder(self):
-        """!Check if the folder of r.li it is present in the .grass7 path"""
-        if os.path.exists(self.rlipath):
-            return
-        else:
-            os.mkdir(self.rlipath)
-            return
     def ListFiles(self):
         """!Check the configuration files inside the path"""
         # list of configuration file
@@ -188,9 +187,7 @@
     def __init__(self, parent):
         self.parent = parent # GMFrame
         self.wizard = wiz.Wizard(parent=parent, id=wx.ID_ANY, title=_("Create new configuration file for r.li modules"))
         #pages
         self.startpage = FirstPage(self.wizard, self)
         self.keyboardpage = KeybordPage(self.wizard, self)
@@ -346,17 +343,17 @@
                         flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
         self.sizer.Add(item = self.vectselect, border=5, pos=(3, 2),
-        #define sempling region
-        self.sempling_reg = wx.RadioBox(parent=self, id=wx.ID_ANY,
-                                        label= _("Define sempling region (region for analysis)"),
-                                        choices=[_('Whole map layer'),
-                                        _('Keyboard setting'), _('Draw the sempling frame')],
-                                        majorDimension=wx.RA_SPECIFY_COLS)
-        self.sizer.Add(item=self.sempling_reg,
+        #define sampling region
+        self.sampling_reg = wx.RadioBox(parent=self, id=wx.ID_ANY,
+                                      label= _("Define sampling region (region for analysis)"),
+                                      choices=[_('Whole map layer'),
+                                      _('Keyboard setting'), _('Draw the sampling frame')],
+                                      majorDimension=wx.RA_SPECIFY_COLS)
+        self.sizer.Add(item=self.sampling_reg,
                         flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
                         pos=(5, 1), span=(5, 2))
         #bindings
-        self.sempling_reg.Bind(wx.EVT_RADIOBOX, self.OnSempling)
+        self.sampling_reg.Bind(wx.EVT_RADIOBOX, self.OnSampling)
         self.newconftxt.Bind(wx.EVT_KILL_FOCUS, self.OnName)
         self.vectselect.Bind(wx.EVT_TEXT, self.OnVector)
         self.mapselect.Bind(wx.EVT_TEXT, self.OnRast)
@@ -366,7 +363,7 @@
         wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-    def OnSempling(self,event):
+    def OnSampling(self,event):
         """!Change map type"""
         if event.GetInt() == 0:
             self.region = 'whole'
@@ -387,25 +384,30 @@
     def OnName(self,event):
-        """!Sets the name of configuration file"""
-        self.conf_name = self.newconftxt.GetValue()
-        if self.region != '' and self.rast != '' and self.conf_name != '' and not \
-                    wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
-            wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+	"""!Sets the name of configuration file"""
+	self.conf_name = self.newconftxt.GetValue()
+	if self.conf_name in self.parent.parent.listfiles:
+            gcmd.GMessage(parent = self,
+                          message = _("The configuration file %s already " % self.conf_name \
+                          + "exists, please change name"))
+            self.newconftxt.SetValue('')
+	if self.region != '' or self.rast != '' or self.conf_name != '' and not \
+				wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
+	    wx.FindWindowById(wx.ID_FORWARD).Enable(True)
     def OnRast(self, event):
         """!Sets raster map"""
         self.rast = event.GetString()
-	if self.region != '' and self.conf_name != '' and self.rast != '' and not \
+	if self.region != '' or self.conf_name != '' or self.rast != '' and not \
     def OnVector(self, event):
         """!Sets vector map"""
         self.vect = event.GetString()
     def OnExitPage(self, event=None):
         """!Function during exiting"""
@@ -440,7 +442,7 @@
     def __init__(self, wizard, parent):
-        TitledPage.__init__(self, wizard, _("Insert sempling frame parameter"))
+        TitledPage.__init__(self, wizard, _("Insert sampling frame parameter"))
         self.sizer.AddGrowableCol(2)
@@ -551,7 +553,7 @@
-        TitledPage.__init__(self, wizard, _("Insert sempling areas"))
+        TitledPage.__init__(self, wizard, _("Insert sampling areas"))
         self.samplingtype = 'whole'
@@ -687,7 +689,7 @@
 class SampleUnitsKeyPage(TitledPage):
     """!Set values from keyboard for sample units"""
         TitledPage.__init__(self, wizard, _("Units"))
@@ -699,105 +701,116 @@
         self.typeBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
 				      label= _("Select type of shape"),
 				      choices=[_('Rectangle'), _('Circle')],
-				      style=wx.VERTICAL)
-        self.sizer.Add(self.typeBox, pos = (1, 1),
-                      flag = wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
-        choicess = [_('Random non overlapping'), _('Systematic contiguos'),
-                    _('Stratified random'), _('Systematic non contiguos'),
-                    _('Centered over sites')]
-        self.distributionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
-                      label= _("Select method of sampling unit distribution"),
-                      choices = choicess, style=wx.VERTICAL)
-        self.distributionBox.EnableItem(4,False)
-        self.sizer.Add(self.distributionBox, pos = (1, 2),
-        # size width
-        self.sizewidth =   wx.StaticText(parent = self, id = wx.ID_ANY,
-                         label = _('What wide size (in cells)'))
-        self.sizewidthtxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
-        self.sizer.Add(self.sizewidth, pos = (2, 1),
-        self.sizer.Add(self.sizewidthtxt, border=5, pos=(2, 2),
-                       flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
-        # size width
-        wx.CallAfter(self.sizewidthtxt.SetFocus)
-        self.sizehight = wx.StaticText(parent = self, id = wx.ID_ANY,
-										label = _('What high size (in cells)'))
-        self.sizehighttxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
-        self.sizer.Add(self.sizehight, pos = (3, 1),
-        self.sizer.Add(self.sizehighttxt, border=5, pos=(3, 2),
-        wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-        self.typeBox.Bind(wx.EVT_RADIOBOX, self.OnType)
-        self.distributionBox.Bind(wx.EVT_RADIOBOX, self.OnMethod)
-        self.sizewidthtxt.Bind(wx.EVT_KILL_FOCUS, self.OnNameW)
-        self.sizehighttxt.Bind(wx.EVT_KILL_FOCUS, self.OnNameH)
+	self.sizer.Add(self.typeBox, flag = wx.ALIGN_LEFT, pos = (1, 1))
+	self.typeBox.Bind(wx.EVT_RADIOBOX, self.OnType)
         self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
-        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
     def OnEnterPage(self, event):
-        """!Check if sites vector it is present"""
-        # method of distribution
-        if self.parent.startpage.vect != '':
-            self.distributionBox.EnableItem(5, True)
+        try:
+            self.sizer.Hide(self.widthLabel)
+            self.sizer.Hide(self.widthTxt)
+            self.sizer.Remove(self.widthLabel)
+            self.sizer.Remove(self.widthTxt)
             self.sizer.Layout()
+        except:
+            print "except width"
+            pass
+        try:
+            self.sizer.Hide(self.heightLabel)
+            self.sizer.Hide(self.heightTxt)
+            self.sizer.Remove(self.heightLabel)
+            self.sizer.Remove(self.heightTxt)
+            self.sizer.Layout()
+        except:
+            pass
+        try:
+            self.sizer.Hide(self.distributionBox)
+            self.sizer.Remove(self.distributionBox)
+        except:
+            pass
-    def OnExitPage(self, event=None):
-        """!Function during exiting"""
-        if self.sizew == '' or self.sizeh == '':
-        else:
+        if self.parent.samplingareapage.samplingtype == 'moving':
+            self.widthLabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                   label = _('Width size (in cells)?)'))
+            self.widthTxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+            wx.CallAfter(self.widthLabel.SetFocus)
+            self.sizer.Add(item = self.widthLabel, border=5, pos=(2, 1),
+                          flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
+            self.sizer.Add(item = self.widthTxt, border=5, pos=(2, 2),
+            self.heightLabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                   label = _('Height size (in cells)?)'))
+            self.heightTxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+            wx.CallAfter(self.heightTxt.SetFocus)
+            self.sizer.Add(item = self.heightLabel, border=5, pos=(3, 1),
+            self.sizer.Add(item = self.heightTxt, border=5, pos=(3, 2),
+        elif self.parent.samplingareapage.samplingtype == 'units':
+            self.distributionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
+                      label= _("Select method of sampling unit distribution"),
+                      choices=[_('Random non overlapping'),
+                      _('Systematic contiguos'), _('Stratified random'),
+                      _('Systematic non contiguos'), _('Centered over sites')],
+            self.sizer.Add(item = self.distributionBox, border=5, pos=(2, 1),
-    def OnNameW(self,event):
-        self.sizew = self.sizewidthtxt.GetValue()
-    def OnNameH(self,event):
-        self.sizeh = self.sizehighttxt.GetValue()
     def OnType(self,event):
-        if event.GetInt() == 0:
-            try:
-                self.sizer.Hide(self.sizewidth)
-                self.sizer.Remove(self.sizewidth)
-                self.sizer.Hide(self.sizehight)
-                self.sizer.Remove(self.sizehight)
-                self.sizer.Layout()
-            except:
-                pass
+        try:
             self.sizer.Layout()
-        elif event.GetInt() == 1:
-            try:
-            except:
-                pass
-                            label = _('What radius size (in meters)'))
-                            label = _('Name for the circle mask'))
+        except:
+            pass
+	if event.GetInt() == 0:
+	elif event.GetInt() == 1:
+                                   label = _('What radius size (in meters)?)'))
+                                   label = _('Name of the circle mask'))
     def OnMethod(self,event):
                 # exit a window asking "What number of sampling units to use"
@@ -854,15 +867,16 @@
         self.sizer.Add(item = self.regiontxt, border=5, pos=(4, 2),
-        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
-        #sampling area
-        self.samplinglabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Sempling area type:'))
-        self.samplingtxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = "")
-        self.sizer.Add(item = self.samplinglabel, border=5, pos=(6, 1),
-        self.sizer.Add(item = self.samplingtxt, border=5, pos=(6, 2),
+	self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
+	self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
+	#sampling area
+	self.samplinglabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+					  label = _('Sampling area type:'))
+	self.samplingtxt = wx.StaticText(parent = self, id = wx.ID_ANY,
+					  label = "")
+	self.sizer.Add(item = self.samplinglabel, border=5, pos=(6, 1),
+	self.sizer.Add(item = self.samplingtxt, border=5, pos=(6, 2),
@@ -916,6 +930,12 @@
                     self.parent.keyboardpage.col_len, self.parent.keyboardpage.row_len)
             self.regionkeytxt.SetLabel(regKeyVals)
+    def OnExitPage(self, event):
+        """Write the output configuration file"""
+        outputFile = open(os.path.join(self.parent.rlipath,
+                      self.parent.startpage.conf_name),"w")
+        outputFile.write(self.parent.startpage.rast)
+        outputFile.close()
 if __name__ == "__main__":
     import gettext
