[GRASS-SVN] r50079 - grass-addons/grass7/raster/r.in.srtm.region
Sat Jan 7 06:30:50 EST 2012
Author: mmetz
Date: 2012-01-07 03:30:50 -0800 (Sat, 07 Jan 2012)
New Revision: 50079
Added:
   grass-addons/grass7/raster/r.in.srtm.region/Makefile
   grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html
   grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
import new module r.in.srtm.region
Added: grass-addons/grass7/raster/r.in.srtm.region/Makefile
--- grass-addons/grass7/raster/r.in.srtm.region/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.in.srtm.region/Makefile	2012-01-07 11:30:50 UTC (rev 50079)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.in.srtm.region
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html
--- grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html	2012-01-07 11:30:50 UTC (rev 50079)
@@ -0,0 +1,36 @@
+<h2>DESCRIPTION</h2>
+<em>r.in.srtm.region</em> imports all SRTM V2.1 tiles covering the
+current region or region extents given with <b>region</b> into GRASS,
+patches the tiles together and optionally interpolates holes.
+<p>
+<em>r.in.srtm.region</em> downloads SRTM tiles from:<br>
+<a href="http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/">http://dds.cr.usgs.gov/srtm/</a>
+<br>
+or optionally uses a local folder with previously downloaded files if
+the <b>local</b> option is given.
+<h2>NOTES</h2>
+<em>r.in.srtm.region</em> imports only SRTM tiles with 3 arcsec resolution.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.in.srtm.html">r.in.srtm</a>
+</em>
+<p>The <a href="http://www2.jpl.nasa.gov/srtm/">Shuttle Radar Topography Mission</a>
+homepage at NASA's JPL.
+<br>
+The <a href="http://pub7.bravenet.com/forum/537683448/">SRTM Web Forum</a>
+<h2>REFERENCES</h2>
+M. Neteler, 2005. <a href="http://grass.osgeo.org/newsletter/GRASSNews_vol3.pdf">SRTM and VMAP0 data in OGR and GRASS.</a> <i><a href="http://grass.osgeo.org/newsletter/">GRASS Newsletter</a></i>, Vol.3, pp. 2-6, June 2005. ISSN 1614-8746.
+<h2>AUTHORS</h2>
+Markus Metz<br>
+<p><i>Last changed: $Date: 2011-11-18 08:53:00 +0100 (Fri, 18 Nov 2011) $</i>
Added: grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
--- grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py	2012-01-07 11:30:50 UTC (rev 50079)
@@ -0,0 +1,347 @@
+#!/usr/bin/env python
+# MODULE:       r.in.srtm.region
+# AUTHOR(S):    Markus Metz
+# PURPOSE:      Create a DEM from 3 arcsec SRTM v2.1 tiles
+# COPYRIGHT:    (C) 2011 GRASS development team
+#               This program is free software under the GNU General
+#               Public License (>=v2). Read the file COPYING that
+#               comes with GRASS for details.
+#%module
+#% description: Creates a DEM from 3 arcsec SRTM v2.1 tiles.
+#% keywords: raster
+#% keywords: import
+#%end
+#%option
+#% key: url
+#% description: base url to fetch SRTM v2.1 tiles
+#% answer: http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/
+#% required: no
+#%end
+#%option G_OPT_M_DIR
+#% key: local
+#% label: local folder with SRTM v2.1 tiles
+#% description: use local folder instead of url to retrieve SRTM tiles
+#% required: no
+#%end
+#%option
+#% key: region
+#% type: double
+#% label: Import subregion only (default is current region)
+#% description: Format: xmin,ymin,xmax,ymax - usually W,S,E,N
+#% key_desc: xmin,ymin,xmax,ymax
+#% multiple: yes
+#% required: no
+#%end
+#%option G_OPT_R_OUTPUT
+#% description: Name for output raster map
+#% required: yes
+#%end
+#%option
+#% key: memory
+#% type: integer
+#% description: Memory in MB for interpolation
+#% answer: 300
+#% required: no
+#%end
+#%flag
+#%  key: n
+#%  description: Fill null cells
+#%end
+proj = ''.join([
+    'GEOGCS[',
+    '"wgs84",',
+    'DATUM["WGS_1984",SPHEROID["wgs84",6378137,298.257223563],TOWGS84[0.000000,0.000000,0.000000]],',
+    'PRIMEM["Greenwich",0],',
+    'UNIT["degree",0.0174532925199433]',
+import sys
+import os
+import shutil
+import atexit
+import urllib
+import urllib2
+import time
+import grass.script as grass
+def import_local_tile(tile, local, pid):
+    output = tile + '.r.in.srtm2.tmp.' + str(pid)
+    local_tile = str(tile) + '.hgt.zip'
+    path = os.path.join(local, local_tile)
+    if os.path.exists(path):
+	path = os.path.join(local, tile)
+	grass.run_command('r.in.srtm', input = path, output = output, quiet = True)
+	return 1
+    # SRTM subdirs: Africa, Australia, Eurasia, Islands, North_America, South_America
+    for srtmdir in ('Africa', 'Australia', 'Eurasia', 'Islands', 'North_America', 'South_America'):
+	path = os.path.join(local, srtmdir, local_tile)
+	    path = os.path.join(local, srtmdir, tile)
+	    return 1
+    return 0
+def download_tile(tile, url, pid):
+    urllib.urlcleanup()
+	remote_tile = str(url) + str(srtmdir) + '/' + local_tile
+	goturl = 1
+	try:
+	    f = urllib2.urlopen(remote_tile)
+	    fo = open(local_tile, 'w+b')
+	    fo.write(f.read())
+	    fo.close
+	    time.sleep(0.5)
+	    # does not work:
+	    #urllib.urlretrieve(remote_tile, local_tile, data = None)
+	except:
+	    goturl = 0
+	    pass
+	if goturl == 1:
+	    return 1
+    return 0
+def cleanup():
+    if not in_temp:
+	return
+    os.chdir(currdir)
+    grass.run_command('g.region', region = tmpregionname)
+    grass.run_command('g.remove', region = tmpregionname, quiet = True)
+    #grass.try_rmdir(tmpdir)
+def main():
+    global tile, tmpdir, in_temp, currdir, tmpregionname
+    in_temp = False
+    url = options['url']
+    local = options['local']
+    output = options['output']
+    memory = options['memory']
+    fillnulls = flags['n']
+    if len(url) == 0 and len(local) == 0:
+	grass.fatal(_("Either 'url' or 'local' is needed"))
+    if len(local) == 0:
+	local = None
+    # are we in LatLong location?
+    s = grass.read_command("g.proj", flags='j')
+    kv = grass.parse_key_val(s)
+    if kv['+proj'] != 'longlat':
+	grass.fatal(_("This module only operates in LatLong locations"))
+    if fillnulls == 1 and memory <= 0:
+	grass.warning(_("Amount of memory to use for interpolation must be positive, setting to 300 MB"))
+	memory = '300'
+    # make a temporary directory
+    tmpdir = grass.tempfile()
+    grass.try_remove(tmpdir)
+    os.mkdir(tmpdir)
+    currdir = os.getcwd()
+    pid = os.getpid()
+    # change to temporary directory
+    os.chdir(tmpdir)
+    in_temp = True
+    if local is None:
+	local = tmpdir
+    # get extents
+    reg = grass.region()
+    tmpregionname = 'r_in_srtm2_tmp_region'
+    grass.run_command('g.region', save = tmpregionname)
+    if options['region'] is None or options['region'] == '':
+	north = reg['n']
+	south = reg['s']
+	east = reg['e']
+	west = reg['w']
+    else:
+	west, south, east, north = options['region'].split(',')
+	west = float(west)
+	south = float(south)
+	east = float(east)
+	north = float(north)
+    # adjust extents to cover SRTM tiles: 1 degree bounds
+    tmpint = int(north)
+    if tmpint < north:
+	north = tmpint + 1
+    else:
+	north = tmpint
+    tmpint = int(south)
+    if tmpint > south:
+	south = tmpint - 1
+    else:
+	south = tmpint
+    tmpint = int(east)
+    if tmpint < east:
+	east = tmpint + 1
+    else:
+	east = tmpint
+    tmpint = int(west)
+    if tmpint > west:
+	west = tmpint - 1
+    else:
+	west = tmpint
+    rows = abs(north - south)
+    cols = abs(east - west)
+    ntiles = rows * cols
+    grass.message(_("Importing %d SRTM tiles...") % ntiles, flag = 'i')
+    counter = 1
+    srtmtiles = ''
+    valid_tiles = 0
+    for ndeg in range(south, north):
+	for edeg in range(west, east):
+	    grass.percent(counter, ntiles, 1)
+	    counter += 1
+	    if ndeg < 0:
+		tile = 'S'
+	    else:
+		tile = 'N'
+	    tile = tile + '%02d' % abs(ndeg)
+	    if edeg < 0:
+		tile = tile + 'W'
+	    else:
+		tile = tile + 'E'
+	    tile = tile + '%03d' % abs(edeg)
+	    grass.debug("Tile: %s" % tile, debug = 1)
+	    if local != tmpdir:
+		gotit = import_local_tile(tile, local, pid)
+	    else:
+		gotit = download_tile(tile, url, pid)
+		if gotit == 1:
+		    gotit = import_local_tile(tile, tmpdir, pid)
+	    if gotit == 1:
+		grass.verbose(_("Tile %s successfully imported") % tile)
+		valid_tiles += 1
+	    else:
+		# create tile with zeros
+		# north
+		if ndeg < 0:
+		    tmpn = '%02d:59:58.5S' % (abs(ndeg) - 2)
+		else:
+		    tmpn = '%02d:00:01.5N' % (ndeg + 1)
+		# south
+		if ndeg <= 0:
+		    tmps = '%02d:00:01.5S' % abs(ndeg)
+		else:
+		    tmps = '%02d:59:58.5N' % (ndeg - 1)
+		# east
+		if edeg < 0:
+		    tmpe = '%03d:59:58.5W' % (abs(edeg) - 2)
+		else:
+		    tmpe = '%03d:00:01.5E' % (edeg + 1)
+		# west
+		if edeg <= 0:
+		    tmpw = '%03d:00:01.5W' % abs(edeg)
+		else:
+		    tmpw = '%03d:59:58.5E' % (edeg - 1)
+		grass.run_command('g.region', n = tmpn, s = tmps, e = tmpe, w = tmpw, res = '00:00:03')
+		grass.run_command('r.mapcalc', expression = "%s = 0" % (tile + '.r.in.srtm2.tmp.' + str(pid)), quiet = True)
+    # g.mlist with fs = comma does not work ???
+    srtmtiles = grass.read_command('g.mlist',
+                                   type = 'rast',
+				   pattern = '*.r.in.srtm2.tmp.%d' % pid,
+				   fs = 'newline',
+				   quiet = True)
+    srtmtiles = srtmtiles.splitlines()
+    srtmtiles = ','.join(srtmtiles)
+    if valid_tiles == 0:
+	grass.run_command('g.remove', rast = str(srtmtiles), quiet = True)
+	grass.warning(_("No tiles imported"))
+	    grass.fatal(_("Please check if local folder <%s> is correct.") % local)
+	else:
+	    grass.fatal(_("Please check internet connection and if url <%s> is correct.") % url)
+    grass.run_command('g.region', rast = str(srtmtiles));
+    if fillnulls == 0:
+	grass.run_command('r.patch', input = srtmtiles, output = output)
+    else:
+	ncells = grass.region()['cells']
+	if long(ncells) > 1000000000:
+	    grass.message(_("%s cells to interpolate, this will take some time") % str(ncells), flag = 'i')
+	grass.run_command('r.patch', input = srtmtiles, output = output + '.holes')
+	mapstats = grass.parse_command('r.univar', map = output + '.holes', flags = 'g', quiet = True)
+	if mapstats['null_cells'] == '0':
+	    grass.run_command('g.rename', rast = '%s,%s' % (output + '.holes', output), quiet = True)
+	else:
+	    grass.run_command('r.resamp.bspline',
+			      input = output + '.holes',
+			      output = output + '.interp',
+			      se = '0.0025', sn = '0.0025',
+			      method = 'bilinear',
+			      memory = memory,
+			      flags = 'n')
+	                      input = '%s,%s' % (output + '.holes',
+			      output + '.interp'),
+			      output = output + '.float',
+			      flags = 'z')
+	    grass.run_command('r.mapcalc', expression = '%s = round(%s)' % (output, output + '.float'))
+			      rast = '%s,%s,%s' % (output + '.holes', output + '.interp', output + '.float'),
+			      quiet = True)
+    # nice color table
+    grass.run_command('r.colors', map = output, color = 'srtm', quiet = True)
+    # write metadata:
+    tmphist = grass.tempfile()
+    f = open(tmphist, 'w+')
+    f.write(os.environ['CMDLINE'])
+    f.close()
+    grass.run_command('r.support', map = output,
+		      loadhistory = tmphist,
+		      description = 'generated by r.in.srtm.region',
+		      source1 = 'SRTM V2.1',
+		      source2 = (local if local != tmpdir else url))
+    grass.try_remove(tmphist)
+    grass.message(_("Done: generated map <%s>") % output)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    main()
Property changes on: grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
___________________________________________________________________
Added: svn:executable
