[GRASS-SVN] r50083 - grass/trunk/vector/v.overlay
Sat Jan 7 07:54:41 EST 2012
Author: mmetz
Date: 2012-01-07 04:54:41 -0800 (Sat, 07 Jan 2012)
New Revision: 50083
   grass/trunk/vector/v.overlay/main.c
v.overlay: DB_SQL_TYPE_TEXT != DB_SQL_TYPE_UNKNOWN; fix messages
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c	2012-01-07 12:53:35 UTC (rev 50082)
+++ grass/trunk/vector/v.overlay/main.c	2012-01-07 12:54:41 UTC (rev 50083)
@@ -326,6 +326,9 @@
 		    sprintf(buf, "varchar(%d)", db_get_column_length(Column));
 		    db_append_string(&col_defs, buf);
 		    break;
+		case DB_SQL_TYPE_TEXT:
+		    db_append_string(&col_defs, "varchar(250)");
+		    break;
 		case DB_SQL_TYPE_SMALLINT:
 		case DB_SQL_TYPE_INTEGER:
 		    db_append_string(&col_defs, "integer");
@@ -347,8 +350,8 @@
 		    db_append_string(&col_defs, "datetime");
 		    break;
 		default:
-		    G_warning(_("Unknown column type '%s'"),
-			      db_get_column_name(Column));
+		    G_warning(_("Unknown column type '%s' of column '%s'"),
+			      db_sqltype_name(sqltype), db_get_column_name(Column));
 		    sprintf(buf, "varchar(250)");
@@ -412,8 +415,8 @@
 			break;
 		    default:
-			G_warning(_("Unknown column type '%s' values lost"),
+			G_warning(_("Unknown column type '%s' of culumn '%s', values lost"),
 			db_append_string(&sql, "null");
