[GRASS-SVN] r50109 - grass-addons/grass7/raster/r.hydrodem
Mon Jan 9 12:41:57 EST 2012
Author: mmetz
Date: 2012-01-09 09:41:56 -0800 (Mon, 09 Jan 2012)
New Revision: 50109
Added:
   grass-addons/grass7/raster/r.hydrodem/hydro_con.c
   grass-addons/grass7/raster/r.hydrodem/r.hydrodem.html
Removed:
   grass-addons/grass7/raster/r.hydrodem/del_streams.c
   grass-addons/grass7/raster/r.hydrodem/r.stream.extract.html
   grass-addons/grass7/raster/r.hydrodem/streams.c
   grass-addons/grass7/raster/r.hydrodem/thin.c
   grass-addons/grass7/raster/r.hydrodem/Makefile
   grass-addons/grass7/raster/r.hydrodem/close.c
   grass-addons/grass7/raster/r.hydrodem/do_astar.c
   grass-addons/grass7/raster/r.hydrodem/init_search.c
   grass-addons/grass7/raster/r.hydrodem/load.c
   grass-addons/grass7/raster/r.hydrodem/local_proto.h
   grass-addons/grass7/raster/r.hydrodem/main.c
new module for sink removal
Modified: grass-addons/grass7/raster/r.hydrodem/Makefile
--- grass-addons/grass7/raster/r.hydrodem/Makefile	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/Makefile	2012-01-09 17:41:56 UTC (rev 50109)
@@ -1,11 +1,9 @@
 MODULE_TOPDIR = ../..
-PGM = r.stream.extract
+PGM = r.hydrodem
-LIBES     = $(SEGMENTLIB) $(RASTERLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB)
-DEPENDENCIES = $(SEGMENTDEP) $(RASTERDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
-EXTRA_INC = $(VECT_INC)
-EXTRA_CFLAGS = $(VECT_CFLAGS)
+LIBES     = $(SEGMENTLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(SEGMENTDEP) $(RASTERDEP) $(GISDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Property changes on: grass-addons/grass7/raster/r.hydrodem/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Modified: grass-addons/grass7/raster/r.hydrodem/close.c
--- grass-addons/grass7/raster/r.hydrodem/close.c	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/close.c	2012-01-09 17:41:56 UTC (rev 50109)
@@ -1,322 +1,57 @@
+#include <grass/gis.h>
 #include <grass/raster.h>
 #include <grass/glocale.h>
-#include <grass/vector.h>
-#include <grass/dbmi.h>
 #include "local_proto.h"
-int close_streamvect(char *stream_vect)
+int close_map(char *ele_rast, int ele_map_type)
-    int i, r, c, r_nbr, c_nbr, done;
-    CELL stream_id, stream_nbr;
-    char aspect;
-    int next_node;
-    struct sstack
-	int stream_id;
-	int next_trib;
-    } *nodestack;
-    int top = 0, stack_step = 1000;
-    int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
-    int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
-    struct Map_info Out;
-    static struct line_pnts *Points;
-    struct line_cats *Cats;
-    dbDriver *driver;
-    dbHandle handle;
-    dbString table_name, dbsql, valstr;
-    struct field_info *Fi;
-    char *cat_col_name = "cat", buf[2000];
-    struct Cell_head window;
-    double north_offset, west_offset, ns_res, ew_res;
-    int next_cat;
+    int ele_fd, r, c;
+    void *ele_buf, *ele_ptr;
+    struct History history;
+    size_t ele_size;
+    CELL ele_val;
-    G_message(_("Write vector map <%s>..."), stream_vect);
+    G_message(_("Write conditioned DEM"));
-    if (0 > Vect_open_new(&Out, stream_vect, 0)) {
-	G_fatal_error(_("Unable to create vector map <%s>"), stream_vect);
+    ele_fd = Rast_open_new(ele_rast, ele_map_type);
+    ele_size = Rast_cell_size(ele_map_type);
+    ele_buf = Rast_allocate_buf(ele_map_type);
-    nodestack = (struct sstack *)G_malloc(stack_step * sizeof(struct sstack));
+    for (r = 0; r < nrows; r++) {
+	G_percent(r, nrows, 2);
-    Points = Vect_new_line_struct();
-    Cats = Vect_new_cats_struct();
+	Rast_set_null_value(ele_buf, ncols, ele_map_type);	/* reset row to all NULL */
-    G_get_set_window(&window);
-    ns_res = window.ns_res;
-    ew_res = window.ew_res;
-    north_offset = window.north - 0.5 * ns_res;
-    west_offset = window.west + 0.5 * ew_res;
+	ele_ptr = ele_buf;
-    next_cat = n_stream_nodes + 1;
+	for (c = 0; c < ncols; c++) {
+	    cseg_get(&ele, &ele_val, r, c);
-    for (i = 0; i < n_outlets; i++, next_cat++) {
-	G_percent(i, n_outlets, 2);
-	r = outlets[i].r;
-	c = outlets[i].c;
-	cseg_get(&stream, &stream_id, r, c);
+	    if (!Rast_is_c_null_value(&ele_val)) {
-	if (!stream_id)
-	    continue;
-	Vect_reset_line(Points);
-	Vect_reset_cats(Cats);
-	/* outlet */
-	Vect_cat_set(Cats, 1, stream_id);
-	Vect_cat_set(Cats, 2, 2);
-	Vect_append_point(Points, west_offset + c * ew_res,
-			  north_offset - r * ns_res, 0);
-	Vect_write_line(&Out, GV_POINT, Points, Cats);
-	/* add root node to stack */
-	G_debug(3, "add root node");
-	top = 0;
-	nodestack[top].stream_id = stream_id;
-	nodestack[top].next_trib = 0;
-	/* depth first post order traversal */
-	G_debug(3, "traverse");
-	while (top >= 0) {
-	    done = 1;
-	    stream_id = nodestack[top].stream_id;
-	    G_debug(3, "stream_id %d", stream_id);
-	    if (nodestack[top].next_trib < stream_node[stream_id].n_trib) {
-		/* add to stack */
-		next_node =
-		    stream_node[stream_id].trib[nodestack[top].next_trib];
-		G_debug(3, "add to stack: next %d, trib %d, n trib %d",
-			next_node, nodestack[top].next_trib,
-			stream_node[stream_id].n_trib);
-		nodestack[top].next_trib++;
-		top++;
-		if (top >= stack_step) {
-		    /* need more space */
-		    stack_step += 1000;
-		    nodestack =
-			(struct sstack *)G_realloc(nodestack,
-						   stack_step *
-						   sizeof(struct sstack));
+		switch (ele_map_type) {
+		case CELL_TYPE:
+		    *((CELL *) ele_ptr) = ele_val;
+		    break;
+		case FCELL_TYPE:
+		    *((FCELL *) ele_ptr) = (FCELL) ele_val / ele_scale;
+		    break;
+		case DCELL_TYPE:
+		    *((DCELL *) ele_ptr) = (DCELL) ele_val / ele_scale;
+		    break;
-		nodestack[top].stream_id = next_node;
-		done = 0;
-		G_debug(3, "go further down");
-	    if (done) {
-		G_debug(3, "write stream segment");
-		r_nbr = stream_node[stream_id].r;
-		c_nbr = stream_node[stream_id].c;
-		cseg_get(&stream, &stream_nbr, r_nbr, c_nbr);
-		if (stream_nbr <= 0)
-		    G_fatal_error("stream id %d not set, top is %d, parent is %d", stream_id, top, nodestack[top - 1].stream_id);
-		if (stream_node[stream_id].n_trib == 0)
-		    Vect_cat_set(Cats, 2, 0);
-		else
-		    Vect_cat_set(Cats, 2, 1);
-		Vect_append_point(Points, west_offset + c_nbr * ew_res,
-				  north_offset - r_nbr * ns_res, 0);
-		bseg_get(&asp, &aspect, r_nbr, c_nbr);
-		while (aspect > 0) {
-		    r_nbr = r_nbr + asp_r[(int)aspect];
-		    c_nbr = c_nbr + asp_c[(int)aspect];
-			G_fatal_error("stream id not set while tracing");
-		    if (stream_nbr != stream_id) {
-			/* first point of parent stream */
-			break;
-		Vect_write_line(&Out, GV_LINE, Points, Cats);
-		top--;
+	    ele_ptr = G_incr_void_ptr(ele_ptr, ele_size);
+	Rast_put_row(ele_fd, ele_buf, ele_map_type);
-    G_percent(n_outlets, n_outlets, 1);	/* finish it */
-    G_message(_("Write vector attribute table"));
-    /* Prepeare strings for use in db_* calls */
-    db_init_string(&dbsql);
-    db_init_string(&valstr);
-    db_init_string(&table_name);
-    db_init_handle(&handle);
-    /* Preparing database for use */
-    /* Create database for new vector map */
-    Fi = Vect_default_field_info(&Out, 1, NULL, GV_1TABLE);
-    driver = db_start_driver_open_database(Fi->driver,
-					   Vect_subst_var(Fi->database,
-							          &Out));
-    if (driver == NULL) {
-	G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
-    G_debug(1, "table: %s", Fi->table);
-    G_debug(1, "driver: %s", Fi->driver);
-    G_debug(1, "database: %s", Fi->database);
-    sprintf(buf,
-	    "create table %s (%s integer, stream_type varchar(20), type_code integer)",
-	    Fi->table, cat_col_name);
-    db_set_string(&dbsql, buf);
-    if (db_execute_immediate(driver, &dbsql) != DB_OK) {
-	db_close_database(driver);
-	db_shutdown_driver(driver);
-	G_fatal_error(_("Cannot create table: %s"), db_get_string(&dbsql));
-    if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
-	G_warning(_("Cannot create index"));
-    if (db_grant_on_table(driver, Fi->table, DB_PRIV_SELECT,
-			  DB_GROUP | DB_PUBLIC) != DB_OK)
-	G_fatal_error(_("Cannot grant privileges on table %s"), Fi->table);
-    db_begin_transaction(driver);
-    /* stream nodes */
-    for (i = 1; i <= n_stream_nodes; i++) {
-	sprintf(buf, "insert into %s values ( %d, \'%s\', %d )",
-		Fi->table, i,
-		(stream_node[i].n_trib > 0 ? "intermediate" : "start"),
-		(stream_node[i].n_trib > 0));
-	    G_fatal_error(_("Cannot insert new row: %s"),
-			  db_get_string(&dbsql));
-    db_commit_transaction(driver);
-    db_close_database_shutdown_driver(driver);
-    Vect_map_add_dblink(&Out, 1, NULL, Fi->table,
-			cat_col_name, Fi->database, Fi->driver);
-    G_debug(1, "close vector");
-    Vect_hist_command(&Out);
-    Vect_build(&Out);
-    Vect_close(&Out);
-    G_free(nodestack);
-    return 1;
-int close_maps(char *stream_rast, char *stream_vect, char *dir_rast)
-    int stream_fd, dir_fd, r, c, i;
-    CELL *cell_buf1, *cell_buf2;
-    struct History history;
-    char flag_value;
-    CELL stream_id;
-    char aspect;
-    /* cheating... */
-    stream_fd = dir_fd = -1;
-    cell_buf1 = cell_buf2 = NULL;
-    G_message(_("Write raster %s"),
-              (stream_rast != NULL) + (dir_rast != NULL) > 1 ? "maps" : "map");
-    /* write requested output rasters */
-    if (stream_rast) {
-	stream_fd = Rast_open_new(stream_rast, CELL_TYPE);
-	cell_buf1 = Rast_allocate_c_buf();
-    if (dir_rast) {
-	dir_fd = Rast_open_new(dir_rast, CELL_TYPE);
-	cell_buf2 = Rast_allocate_c_buf();
-    for (r = 0; r < nrows; r++) {
-	G_percent(r, nrows, 2);
-	if (stream_rast)
-	    Rast_set_c_null_value(cell_buf1, ncols);	/* reset row to all NULL */
-	if (dir_rast)
-	    Rast_set_c_null_value(cell_buf2, ncols);	/* reset row to all NULL */
-	for (c = 0; c < ncols; c++) {
-		if (stream_id)
-		    cell_buf1[c] = stream_id;
-	    if (dir_rast) {
-		bseg_get(&bitflags, &flag_value, r, c);
-		if (!FLAG_GET(flag_value, NULLFLAG)) {
-		    bseg_get(&asp, &aspect, r, c);
-		    cell_buf2[c] = aspect;
-	if (stream_rast)
-	    Rast_put_row(stream_fd, cell_buf1, CELL_TYPE);
-	if (dir_rast)
-	    Rast_put_row(dir_fd, cell_buf2, CELL_TYPE);
     G_percent(nrows, nrows, 2);	/* finish it */
-	Rast_close(stream_fd);
-	G_free(cell_buf1);
-	Rast_short_history(stream_rast, "raster", &history);
-	Rast_command_history(&history);
-	Rast_write_history(stream_rast, &history);
-    if (dir_rast) {
-	Rast_close(dir_fd);
-	G_free(cell_buf2);
-	Rast_short_history(dir_rast, "raster", &history);
-	Rast_write_history(dir_rast, &history);
+    Rast_close(ele_fd);
+    G_free(ele_buf);
+    Rast_short_history(ele_rast, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(ele_rast, &history);
-    /* close stream vector */
-    if (stream_vect) {
-	if (close_streamvect(stream_vect) < 0)
-	    G_fatal_error(_("Unable to write vector map <%s>"), stream_vect);
-    /* rearranging desk chairs on the Titanic... */
-    G_free(outlets);
-    /* free stream nodes */
-	if (stream_node[i].n_alloc > 0) {
-	    G_free(stream_node[i].trib);
-    G_free(stream_node);
     return 1;
Deleted: grass-addons/grass7/raster/r.hydrodem/del_streams.c
--- grass-addons/grass7/raster/r.hydrodem/del_streams.c	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/del_streams.c	2012-01-09 17:41:56 UTC (rev 50109)
@@ -1,194 +0,0 @@
-#include <stdlib.h>
-#include <math.h>
-#include <grass/raster.h>
-#include <grass/glocale.h>
-#include "local_proto.h"
-/* get stream segment length */
-int seg_length(CELL stream_id, CELL *next_stream_id)
-    int r, c, r_nbr, c_nbr;
-    int slength = 1;
-    CELL curr_stream;
-    char aspect;
-    r = stream_node[stream_id].r;
-    c = stream_node[stream_id].c;
-    if (next_stream_id)
-	*next_stream_id = stream_id;
-    /* get next downstream point */
-	r_nbr = r + asp_r[(int)aspect];
-	c_nbr = c + asp_c[(int)aspect];
-	/* user-defined depression */
-	if (r_nbr == r && c_nbr == c)
-	    break;
-	/* outside region */
-	if (r_nbr < 0 || r_nbr >= nrows || c_nbr < 0 || c_nbr >= ncols)
-	    break;
-	/* next stream */
-	cseg_get(&stream, &curr_stream, r_nbr, c_nbr);
-	    *next_stream_id = curr_stream;
-	if (curr_stream != stream_id)
-	    break;
-	slength++;
-	r = r_nbr;
-	c = c_nbr;
-    return slength;
-/* change downstream id: update or remove */
-int update_stream_id(CELL stream_id, CELL new_stream_id)
-    int i, r, c, r_nbr, c_nbr;
-    CELL new_stream = new_stream_id;
-    CELL curr_stream;
-    char aspect;
-    cseg_get(&stream, &curr_stream, r, c);
-	G_fatal_error("update downstream id: curr_stream != stream_id");
-    cseg_put(&stream, &new_stream, r, c);
-    curr_stream = stream_id;
-	    break;
-	    break;
-	/* next stream */
-	    break;
-	r = r_nbr;
-	c = c_nbr;
-    if (curr_stream <= 0)
-	return curr_stream;
-    /* update tributaries */
-    if (curr_stream != stream_id) {
-	int last_i = -1;
-	for (i = 0; i < stream_node[curr_stream].n_trib; i++) {
-	    if (stream_node[curr_stream].trib[i] == stream_id) {
-		if (new_stream_id) {
-		    stream_node[curr_stream].trib[i] = new_stream_id;
-		else {
-		    stream_node[curr_stream].n_trib--;
-		    stream_node[curr_stream].trib[i] = stream_node[curr_stream].trib[stream_node[curr_stream].n_trib];
-		    stream_node[curr_stream].trib[stream_node[curr_stream].n_trib] = 0;
-		last_i = i;
-		break;
-		G_warning("last_i %d, i %d", last_i, i);
-		G_warning("failed updating stream %d at node %d", stream_id, curr_stream);
-/* delete stream segments shorter than threshold */
-int del_streams(int min_length)
-    int i;
-    int n_deleted = 0;
-    CELL curr_stream, stream_id;
-    int other_trib, tmp_trib;
-    int slength;
-    G_message(_("Delete stream segments shorter than %d cells..."), min_length);
-    /* TODO: proceed from stream heads to outlets
-     *       -> use depth first post order traversal */
-    /* go through all nodes */
-	G_percent(i, n_stream_nodes, 2);
-	/* not a stream head */
-	if (stream_node[i].n_trib > 0)
-	    continue;
-	/* already deleted */
-	cseg_get(&stream, &curr_stream, stream_node[i].r, stream_node[i].c);
-	if (curr_stream == 0)
-	    continue;
-	/* get length counted as n cells */
-	if ((slength = seg_length(i, &curr_stream)) >= min_length)
-	    continue;
-	stream_id = i;
-	/* check n sibling tributaries */
-	    /* only one sibling tributary */
-	    if (stream_node[curr_stream].n_trib == 2) {
-		if (stream_node[curr_stream].trib[0] != stream_id)
-		    other_trib = stream_node[curr_stream].trib[0];
-		else
-		    other_trib = stream_node[curr_stream].trib[1];
-		/* other trib is also stream head */
-		if (stream_node[other_trib].n_trib == 0) {
-		    /* use shorter one */
-		    if (seg_length(other_trib, NULL) < slength) {
-			tmp_trib = stream_id;
-			stream_id = other_trib;
-			other_trib = tmp_trib;
-		update_stream_id(stream_id, 0);
-		n_deleted++;
-		/* update downstream IDs */
-		update_stream_id(curr_stream, other_trib);
-	    /* more than one other tributary */
-	    else {
-		n_deleted++;
-	/* stream head is also outlet */
-	else {
-	    n_deleted++;
-    G_verbose_message(_("%d stream segments deleted"), n_deleted);
-    return n_deleted;
Modified: grass-addons/grass7/raster/r.hydrodem/do_astar.c
--- grass-addons/grass7/raster/r.hydrodem/do_astar.c	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/do_astar.c	2012-01-09 17:41:56 UTC (rev 50109)
@@ -1,43 +1,53 @@
 #include <stdlib.h>
 #include <math.h>
 #define GET_PARENT(c) ((unsigned int)(((c) - 2) >> 2) + 1)
 #define GET_CHILD(p) ((unsigned int)((p) << 2) - 2)
-HEAP_PNT heap_drop(void);
-int sift_up(unsigned int, HEAP_PNT);
+#define HEAP_CMP(a, b) (((a)->ele < (b)->ele) ? 1 : \
+                       (((a)->ele > (b)->ele) ? 0 : \
+		       (((a)->added < (b)->added) ? 1 : 0)))
+struct heap_point heap_drop(void);
 double get_slope(CELL, CELL, double);
 int do_astar(void)
     int r, c, r_nbr, c_nbr, ct_dir;
-    unsigned int first_cum, count;
+    int count;
     int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
     int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
-    CELL ele_val, ele_up, ele_nbr[8];
-    WAT_ALT wa;
-    char asp_val;
+    int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
+    int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
+    CELL ele_val, ele_down, ele_nbr[8];
+    char is_bottom;
+    char asp_val, asp_val_this;
     char flag_value, is_in_list, is_worked;
-    HEAP_PNT heap_p;
+    struct heap_point heap_p;
     /* sides
      * |7|1|4|
      * |2| |3|
      * |5|0|6|
-    int nbr_ew[8] = { 0, 1, 2, 3, 1, 0, 0, 1 };
-    int nbr_ns[8] = { 0, 1, 2, 3, 3, 2, 3, 2 };
+    int nbr_ew[8] = { 0, 1, 2, 3, 1, 0, 0, 1};
+    int nbr_ns[8] = { 0, 1, 2, 3, 3, 2, 3, 2};
     double dx, dy, dist_to_nbr[8], ew_res, ns_res;
     double slope[8];
+    int skip_diag;
-    int skip_me;
     count = 0;
     first_cum = n_points;
+    sinks = first_sink = NULL;
+    n_sinks = 0;
     G_message(_("A* Search..."));
     Rast_get_window(&window);
@@ -56,7 +66,7 @@
     while (heap_size > 0) {
 	G_percent(count++, n_points, 1);
 	if (count > n_points)
@@ -70,17 +80,31 @@
 	heap_p = heap_drop();
-	r = heap_p.pnt.r;
-	c = heap_p.pnt.c;
+	/* flow accumulation order is not needed */
+	r = heap_p.r;
+	c = heap_p.c;
-	ele_val = heap_p.ele;
+	first_cum--;
+	bseg_get(&bitflags, &flag_value, r, c);
+	FLAG_SET(flag_value, WORKEDFLAG);
+	bseg_put(&bitflags, &flag_value, r, c);
+	ele_val = ele_down = heap_p.ele;
+	is_bottom = 0;
+	bseg_get(&draindir, &asp_val_this, r, c);
+	if (asp_val_this > 0 && !FLAG_GET(flag_value, EDGEFLAG)) {
+	    r_nbr = r + asp_r[(int)asp_val_this];
+	    c_nbr = c + asp_c[(int)asp_val_this];
+	    cseg_get(&ele, &ele_down, r_nbr, c_nbr);
+	    if (ele_down > ele_val)
+		is_bottom = 1;
 	for (ct_dir = 0; ct_dir < sides; ct_dir++) {
 	    /* get r, c (r_nbr, c_nbr) for neighbours */
 	    r_nbr = r + nextdr[ct_dir];
 	    c_nbr = c + nextdc[ct_dir];
 	    slope[ct_dir] = ele_nbr[ct_dir] = 0;
-	    skip_me = 0;
 	    /* check that neighbour is within region */
@@ -89,73 +113,105 @@
 	    bseg_get(&bitflags, &flag_value, r_nbr, c_nbr);
 	    is_in_list = FLAG_GET(flag_value, INLISTFLAG);
 	    is_worked = FLAG_GET(flag_value, WORKEDFLAG);
+	    skip_diag = 0;
+	    /* avoid diagonal flow direction bias */
 	    if (!is_worked) {
-		seg_get(&watalt, (char *)&wa, r_nbr, c_nbr);
-		ele_nbr[ct_dir] = wa.ele;
+		cseg_get(&ele, &ele_nbr[ct_dir], r_nbr, c_nbr);
 		slope[ct_dir] = get_slope(ele_val, ele_nbr[ct_dir],
-			                  dist_to_nbr[ct_dir]);
+		                          dist_to_nbr[ct_dir]);
-	    /* avoid diagonal flow direction bias */
 	    if (!is_in_list) {
 		if (ct_dir > 3 && slope[ct_dir] > 0) {
 		    if (slope[nbr_ew[ct_dir]] > 0) {
 			/* slope to ew nbr > slope to center */
-			if (slope[ct_dir] <
-			    get_slope(ele_nbr[nbr_ew[ct_dir]],
-				       ele_nbr[ct_dir], ew_res))
-			    skip_me = 1;
+			if (slope[ct_dir] < get_slope(ele_nbr[nbr_ew[ct_dir]],
+			                              ele_nbr[ct_dir], ew_res))
+			    skip_diag = 1;
-		    if (!skip_me && slope[nbr_ns[ct_dir]] > 0) {
+		    if (!skip_diag && slope[nbr_ns[ct_dir]] > 0) {
 			/* slope to ns nbr > slope to center */
-			    get_slope(ele_nbr[nbr_ns[ct_dir]],
-				       ele_nbr[ct_dir], ns_res))
-			    skip_me = 1;
+			if (slope[ct_dir] < get_slope(ele_nbr[nbr_ns[ct_dir]],
+			                              ele_nbr[ct_dir], ns_res))
+			    skip_diag = 1;
-	    if (is_in_list == 0 && skip_me == 0) {
-		ele_up = ele_nbr[ct_dir];
+	    if (is_in_list == 0 && skip_diag == 0) {
 		asp_val = drain[r_nbr - r + 1][c_nbr - c + 1];
-		bseg_put(&asp, &asp_val, r_nbr, c_nbr);
-		heap_add(r_nbr, c_nbr, ele_up);
-		FLAG_SET(flag_value, INLISTFLAG);
-		bseg_put(&bitflags, &flag_value, r_nbr, c_nbr);
+		heap_add(r_nbr, c_nbr, ele_nbr[ct_dir], asp_val, flag_value);
+		if (ele_nbr[ct_dir] < ele_val)
+		    is_bottom = 0;
 	    else if (is_in_list && is_worked == 0) {
 		if (FLAG_GET(flag_value, EDGEFLAG)) {
-		    /* neighbour is edge in list, not yet worked */
-		    bseg_get(&asp, &asp_val, r_nbr, c_nbr);
+		    bseg_get(&draindir, &asp_val, r_nbr, c_nbr);
 		    if (asp_val < 0) {
-			/* adjust flow direction for edge cell */
-			asp_val = drain[r_nbr - r + 1][c_nbr - c + 1];
+			/* update edge cell ? no */
+			/* asp_val = drain[r_nbr - r + 1][c_nbr - c + 1]; */
+			/* check if this causes trouble */
+			bseg_put(&draindir, &asp_val, r_nbr, c_nbr);
+			    is_bottom = 0;
 		else if (FLAG_GET(flag_value, DEPRFLAG)) {
 		    G_debug(3, "real depression");
 		    /* neighbour is inside real depression, not yet worked */
 		    if (asp_val == 0 && ele_val <= ele_nbr[ct_dir]) {
 			FLAG_UNSET(flag_value, DEPRFLAG);
 	}    /* end neighbours */
-	/* add astar points to sorted list for flow accumulation and stream extraction */
-	first_cum--;
-	seg_put(&astar_pts, (char *)&heap_p.pnt, 0, first_cum);
-	FLAG_SET(flag_value, WORKEDFLAG);
-	bseg_put(&bitflags, &flag_value, r, c);
+	if (is_bottom) {
+	    /* add sink bottom */
+	    /* process upstream */
+	    if (1) {
+		if (first_sink) {
+		    sinks->next =
+			(struct sink_list *)
+			G_malloc(sizeof(struct sink_list));
+		    sinks = sinks->next;
+		/* first sink */
+		else {
+		    first_sink =
+		    sinks = first_sink;
+		sinks->next = NULL;
+	    /* process downstream */
+	    if (0) {
+		sinks =
+		sinks->next = first_sink;
+		first_sink = sinks;
+	    sinks->r = r;
+	    sinks->c = c;
+	    n_sinks++;
     }    /* end A* search */
     G_percent(n_points, n_points, 1);	/* finish it */
+    if (first_cum)
+	G_warning(_("processed points mismatch of %u"), first_cum);
     return 1;
@@ -163,7 +219,8 @@
  * compare function for heap
  * returns 1 if point1 < point2 else 0
-int heap_cmp(HEAP_PNT *a, HEAP_PNT *b)
+static int heap_cmp(struct heap_point *a, struct heap_point *b)
     if (a->ele < b->ele)
 	return 1;
@@ -174,15 +231,16 @@
     return 0;
-int sift_up(unsigned int start, HEAP_PNT child_p)
+int sift_up(unsigned int start, struct heap_point child_p)
     unsigned int parent, child;
-    HEAP_PNT heap_p;
     child = start;
     while (child > 1) {
 	parent = GET_PARENT(child);
 	seg_get(&search_heap, (char *)&heap_p, 0, parent);
 	/* push parent point down if child is smaller */
@@ -191,7 +249,7 @@
 	    child = parent;
 	else
-	    /* no more sifting up, found slot for child */
+	    /* no more sifting up, found new slot for child */
 	    break;
@@ -205,22 +263,30 @@
  * add item to heap
  * returns heap_size
-unsigned int heap_add(int r, int c, CELL ele)
+unsigned int heap_add(int r, int c, CELL ele, char asp, char flag_value)
-    HEAP_PNT heap_p;
     /* add point to next free position */
     heap_size++;
+    if (heap_size > n_points)
+	G_fatal_error(_("Heapsize too large"));
+    heap_p.r = r;
+    heap_p.c = c;
+    heap_p.ele = ele;
     heap_p.added = nxt_avail_pt;
-    heap_p.ele = ele;
-    heap_p.pnt.r = r;
-    heap_p.pnt.c = c;
+    bseg_put(&draindir, &asp, r, c);
+    FLAG_SET(flag_value, INLISTFLAG);
     nxt_avail_pt++;
     /* sift up: move new point towards top of heap */
     sift_up(heap_size, heap_p);
     return heap_size;
@@ -230,11 +296,11 @@
  * drop item from heap
  * returns heap size
     unsigned int child, childr, parent;
     int i;
-    HEAP_PNT child_p, childr_p, last_p, root_p;
+    struct heap_point child_p, childr_p, last_p, root_p;
     seg_get(&search_heap, (char *)&last_p, 0, heap_size);
     seg_get(&search_heap, (char *)&root_p, 0, 1);
@@ -245,14 +311,14 @@
     parent = 1;
-    while ((child = GET_CHILD(parent)) < heap_size) {
+    while ((child = GET_CHILD(parent)) <= heap_size) {
 	seg_get(&search_heap, (char *)&child_p, 0, child);
 	if (child < heap_size) {
 	    childr = child + 1;
 	    i = child + 4;
-	    while (childr < heap_size && childr < i) {
+	    while (childr <= heap_size && childr < i) {
 		seg_get(&search_heap, (char *)&childr_p, 0, childr);
 		if (heap_cmp(&childr_p, &child_p)) {
 		    child = childr;
@@ -261,7 +327,6 @@
 		childr++;
 	if (heap_cmp(&last_p, &child_p)) {
 	    break;
Added: grass-addons/grass7/raster/r.hydrodem/hydro_con.c
--- grass-addons/grass7/raster/r.hydrodem/hydro_con.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.hydrodem/hydro_con.c	2012-01-09 17:41:56 UTC (rev 50109)
@@ -0,0 +1,859 @@
+#include <stdlib.h>
+#include <math.h>
+#include <limits.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+struct ns
+    int r, c;
+    int next_side;
+    int n_ngbrs;
+static struct ns *n_stack;
+static unsigned int stack_alloc;
+int count_fill(int peak_r, int peak_c, CELL peak_ele, int *n_splits, CELL *next_ele)
+    int r, c, r_nbr, c_nbr, ct_dir;
+    int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
+    int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
+    CELL ele_val, ele_nbr;
+    int n_to_fill;
+    int top, done;
+    char drain_val;
+    /* go upstream from spill point */
+    r = peak_r;
+    c = peak_c;
+    ele_val = peak_ele;
+    *n_splits = 0;
+    n_to_fill = 0;
+    /* post-order traversal */
+    /* add spill point as root to stack */
+    top = 0;
+    n_stack[top].r = peak_r;
+    n_stack[top].c = peak_c;
+    n_stack[top].next_side = 0;
+    n_stack[top].n_ngbrs = 0;
+    while (top >= 0) {
+	done = 1;
+	r = n_stack[top].r;
+	c = n_stack[top].c;
+	for (ct_dir = n_stack[top].next_side; ct_dir < sides; ct_dir++) {
+	    r_nbr = r + nextdr[ct_dir];
+	    c_nbr = c + nextdc[ct_dir];
+	    /* check that neighbour is within region */
+	    if (r_nbr >= 0 && r_nbr < nrows && c_nbr >= 0 && c_nbr < ncols) {
+		cseg_get(&ele, &ele_nbr, r_nbr, c_nbr);
+		bseg_get(&draindir, &drain_val, r_nbr, c_nbr);
+		if (drain_val > 0) {
+		    /* contributing cell */
+		    if (r_nbr + asp_r[(int)drain_val] == r &&
+			c_nbr + asp_c[(int)drain_val] == c) {
+			/* contributing neighbour is lower than spill point, add to stack */
+			if (peak_ele >= ele_nbr) {
+			    if (peak_ele > ele_nbr)
+				n_to_fill++;
+			    n_stack[top].next_side = ct_dir + 1;
+			    n_stack[top].n_ngbrs++;
+			    top++;
+			    if (top >= stack_alloc) {
+				stack_alloc += nrows + ncols;
+				n_stack =
+				    (struct ns *)G_realloc(n_stack,
+							   stack_alloc *
+							   sizeof(struct ns));
+			    n_stack[top].r = r_nbr;
+			    n_stack[top].c = c_nbr;
+			    done = 0;
+			    break;
+			else if (next_ele && peak_ele < ele_nbr) {
+			    if (*next_ele > ele_nbr)
+				*next_ele = ele_nbr;
+		}    /* end contributing */
+	    }    /* end in region */
+	}    /* end sides */
+	if (done) {
+	    *n_splits += (n_stack[top].n_ngbrs > 1);
+	    n_stack[top].next_side = sides;
+	    top--;
+    return n_to_fill;
+/* detect flat area:
+ * count neighbouring cells with same ele
+ * exclude contributing cells and cell this one is contributing to */
+int is_flat(int r, int c, CELL this_ele)
+    int r_nbr, c_nbr, ct_dir;
+    CELL ele_nbr;
+    char drain_val, drain_val_nbr;
+    int counter = 0;
+    bseg_get(&draindir, &drain_val, r, c);
+    if (drain_val < 1)
+	return 0;
+    for (ct_dir = 0; ct_dir < sides; ct_dir++) {
+	    bseg_get(&draindir, &drain_val_nbr, r_nbr, c_nbr);
+	    if (drain_val_nbr > 0) {
+		/* not a contributing cell */
+		if (r_nbr + asp_r[(int)drain_val_nbr] != r ||
+		    c_nbr + asp_c[(int)drain_val_nbr] != c) {
+		    /* does not contribute to this cell */
+		    if (r + asp_r[(int)drain_val] != r_nbr ||
+		        c + asp_c[(int)drain_val] != c_nbr) {
+			if (ele_nbr == this_ele)
+			    counter++;
+    return (counter > 0);
+int fill_sink(int peak_r, int peak_c, CELL peak_ele)
+    CELL ele_nbr;
+    int n_to_fill = 0;
+    int top, done;
+    char drain_val;
+    top = 0;
+	done = 1;
+			    n_to_fill++;
+			    top++;
+				n_stack =
+							   stack_alloc *
+			    done = 0;
+			    break;
+	}			/* end sides */
+	if (done) {
+	    cseg_put(&ele, &peak_ele, r, c);
+	    top--;
+    return n_to_fill;
+/* carve channel */
+int carve(int bottom_r, int bottom_c, CELL bottom_ele, int peak_r, int peak_c)
+    int r, c, r_nbr, c_nbr, carved = 0;
+    char drain_val;
+    int ct_dir;
+    int top, done;
+    /* carve upstream from spill point --> */
+    top = 0;
+	done = 1;
+		    if (r_nbr + asp_r[(int) drain_val] == r &&
+			c_nbr + asp_c[(int) drain_val] == c) {
+			/* contributing neighbour is lower than current point, add to stack */
+			if (ele_val > ele_nbr && ele_nbr >= bottom_ele) {
+			    top++;
+				n_stack =
+							   stack_alloc *
+			    done = 0;
+			    break;
+	}			/* end sides */
+	if (done) {
+	    /* lower all cells to bottom ele that have lower lying contributing neighbours */
+	    if (n_stack[top].n_ngbrs > 0)
+		cseg_put(&ele, &bottom_ele, r, c);
+	    top--;
+    /* <-- carve upstream from spill point */
+    /* carve downstream from sink bottom */
+    bseg_get(&draindir, &drain_val, bottom_r, bottom_c);
+    if (drain_val < 1) {
+	G_warning(_("Can't carve downstream from r %d, c %d"), bottom_r,
+		  bottom_c);
+	return 0;
+    r_nbr = bottom_r + asp_r[(int) drain_val];
+    c_nbr = bottom_c + asp_c[(int) drain_val];
+    /* go downstream up to peak and down to bottom again */
+    while (ele_nbr >= bottom_ele) {
+	cseg_put(&ele, &bottom_ele, r_nbr, c_nbr);
+	carved++;
+	    r_nbr = r_nbr + asp_r[(int) drain_val];
+	    c_nbr = c_nbr + asp_c[(int) drain_val];
+	else {
+	    G_debug(2, "%d carved to edge", carved);
+	    return carved;
+    return carved;
+/* remove sinks */
+int hydro_con(void)
+    int counter = 1;
+    int r, c, r_nbr, c_nbr, peak_r, peak_c, noedge, force_carve;
+    CELL ele_val, ele_nbr, ele_last, peak_ele, bottom_ele;
+    int down_uphill, down_downhill, n_cells;
+    struct sink_list *last_sink;
+    char drain_val, flag_value;
+    int n_splits, n_to_fill;
+    int n_filled, n_carved, n_just_a_bit, n_processed;
+    int carve_to_edge, skipme;
+    stack_alloc = nrows + ncols;
+    n_stack = (struct ns *)G_malloc(stack_alloc * sizeof(struct ns));
+    G_message(_("Processing %d sinks"), n_sinks);
+    n_filled = n_carved = n_just_a_bit = n_processed = 0;
+    while (first_sink) {
+	G_percent(counter++, n_sinks, 1);
+	r = first_sink->r;
+	c = first_sink->c;
+	bottom_ele = ele_val;
+	skipme = 0;
+	G_debug(1, "get spill point");
+	/* go downstream, get spill point */
+	peak_r = r;
+	peak_c = c;
+	r_nbr = r + asp_r[(int) drain_val];
+	c_nbr = c + asp_c[(int) drain_val];
+	down_uphill = down_downhill = 0;
+	noedge = 1;
+	ele_last = bottom_ele;
+	n_cells = 0;
+	while (ele_nbr >= ele_last) {
+	    n_cells++;
+	    if (ele_nbr > ele_last) {
+		down_uphill = n_cells;
+		peak_r = r_nbr;
+		peak_c = c_nbr;
+		ele_last = ele_nbr;
+	    else {
+		break;
+	cseg_get(&ele, &peak_ele, peak_r, peak_c);
+	bseg_get(&bitflags, &flag_value, peak_r, peak_c);
+	noedge = (FLAG_GET(flag_value, EDGEFLAG) == 0);
+	r_nbr = peak_r;
+	c_nbr = peak_c;
+	ele_nbr = peak_ele;
+	/* check */
+	if (down_uphill == 0) {
+	    G_debug(2, "sink already processed");
+	    n_processed++;
+	    last_sink = first_sink;
+	    first_sink = first_sink->next;
+	    G_free(last_sink);
+	    continue;
+	carve_to_edge = 0;
+	if (noedge) {
+	    G_debug(1, "go downstream from spill point");
+	    /* go downstream from spill point until we reach bottom ele again */
+		if (ele_nbr > bottom_ele)
+		    down_downhill++;
+		/* detect flat area ? */
+		else {
+		    carve_to_edge = 1;
+		    break;
+	G_debug(1, "%d cells downstream from spill point", down_downhill);
+	/* count number of cells that would be filled from current spill point upstream */
+	G_debug(1, "count fill");
+	n_to_fill = count_fill(peak_r, peak_c, peak_ele, &n_splits, NULL);
+	skipme = (!do_all && n_to_fill <= size_max);
+	nat_thresh = 10;
+	/* shallow inland pans:
+	 * - bottom is close to center of the depression
+	 * - long channel to carve downstream from spill point
+	 * - shallowness */
+	if (n_to_fill > nat_thresh && peak_ele - bottom_ele < 10 && sqrt(n_to_fill) / 4.0 < down_uphill)
+	    G_debug(1, "shallow inland pan?");
+	/* set correction method */
+	/* force carving if edge not past spill point ? */
+	force_carve = (noedge == 0);
+	force_carve = 0;
+	if (!force_carve && (do_all || n_mod_max >= 4) &&
+	    down_uphill + down_downhill <= 4 &&
+	    down_uphill + down_downhill <= n_to_fill)
+	    force_carve = 0;
+	/* apply selected correction method */
+	/* force carve channel to edge if edge not past spill point */
+	if (force_carve) {
+	    G_debug(1, "force carve small channel or to edge");
+	    carve(first_sink->r, first_sink->c, bottom_ele, peak_r, peak_c);
+	    n_carved++;
+	/* impact reduction algorithm */
+	else if (!skipme) {
+	    int next_r, next_c;
+	    int n_new_splits, is_edge = 0, this_is_flat;
+	    CELL min_bottom_ele, last_ele, next_bottom_ele;
+	    int least_impact, li_max;
+	    int least_impact_r, least_impact_c;
+	    CELL least_impact_ele;
+	    /* initialize least impact */
+	    li_max = n_to_fill + down_uphill + down_downhill;
+	    least_impact = down_uphill + down_downhill;
+	    least_impact_r = first_sink->r;
+	    least_impact_c = first_sink->c;
+	    least_impact_ele = bottom_ele;
+	    /* IRA --> */
+	    G_debug(1, "impact reduction algorithm");
+	    /* start with sink bottom, proceed to spill point */
+	    /* fill incrementally, for each step check if IRA condition fulfilled */
+	    /* proceed until condition no longer met, then use least impact solution */
+	    /* the determined new sink bottom can be
+	     * - the original sink bottom: no filling, only carving
+	     * - the spill point: no carving, only filling
+	     * - any cell in between the two */
+	    next_r = first_sink->r;
+	    next_c = first_sink->c;
+	    min_bottom_ele = bottom_ele;
+	    G_debug(1, "find new fill point");
+	    /* include no filling, full carving, and full filling, no carving */
+	    while (bottom_ele <= peak_ele) {
+		/* get n_to_fill, down_uphill, down_downhill */
+		down_uphill = 0;
+		down_downhill = 0;
+		/* count cells to fill */
+		next_bottom_ele = peak_ele;
+		n_to_fill = count_fill(next_r, next_c, bottom_ele,
+		                       &n_new_splits, &next_bottom_ele);
+		/* count channel length from spill point */
+		G_debug(2, "count channel length from spill point");
+		r_nbr = peak_r;
+		c_nbr = peak_c;
+		last_ele = ele_nbr = peak_ele;
+		this_is_flat = 0;
+		while (ele_nbr >= bottom_ele && this_is_flat < 3) {
+		    if (ele_nbr > bottom_ele) {
+			down_downhill++;
+			/* catch min 2 consecutive cells in flat area with same ele */
+			if (is_flat(r_nbr, c_nbr, ele_nbr)) {
+			    if (ele_nbr == last_ele) {
+				this_is_flat++;
+				if (this_is_flat > 1 && ele_nbr > min_bottom_ele)
+				    min_bottom_ele = bottom_ele + 1;
+			    else
+				this_is_flat = 1;
+			if (next_bottom_ele > ele_nbr)
+			    next_bottom_ele = ele_nbr;
+			last_ele = ele_nbr;
+		    else {
+			G_debug(2, "reached edge past spill point");
+			break;
+		/* carving ok */
+		if (this_is_flat < 3) {
+		    /* count cells to carve from sink bottom to spill point */
+		    ele_last = ele_nbr = bottom_ele;
+		    r_nbr = next_r;
+		    c_nbr = next_c;
+		    n_cells = 0;
+			n_cells++;
+			else {
+			    break;
+		    /* remember least impact */
+		    if (least_impact > n_to_fill + down_uphill + down_downhill) {
+			least_impact = n_to_fill + down_uphill + down_downhill;
+			least_impact_r = next_r;
+			least_impact_c = next_c;
+		/* carving not ok, need to fill more */
+		else {
+		    G_debug(2, "carving not ok");
+		    least_impact = li_max;
+		    least_impact_r = peak_r;
+		    least_impact_c = peak_c;
+		    least_impact_ele = peak_ele;
+		G_debug(2,
+			"channel length to spill point %d, channel length from spill point %d, cells to fill %d",
+			down_uphill, down_downhill, n_to_fill);
+		/* check IRA condition */
+		/* preference for channel carving, relaxed stream split condition */
+		/* continue filling ? */
+		/* remains a mystery why this condition results in less modifications... */
+		/* sqrt(n_to_fill) < (down_uphill + down_downhill) / 2.0 ||
+		 * n_new_splits <= n_splits_max */
+		if (sqrt(n_to_fill) < (down_uphill + down_downhill) / 1.0 ||
+		    n_new_splits <= 4 ||
+		    bottom_ele < min_bottom_ele ||
+		    least_impact == li_max) {
+		    /* continue with IRA */
+		    G_debug(2, "IRA conditions fulfilled");
+		/* IRA condition no longer fulfilled */
+		else {
+		    G_debug(2, "IRA conditions not met");
+		    G_debug(2, "n to fill: %d", n_to_fill);
+		    G_debug(2, "down_uphill: %d", down_uphill);
+		    G_debug(2, "down_downhill: %d", down_downhill);
+		    break;
+		if (bottom_ele >= peak_ele)
+		    break;
+		/* below spill point, get next higher cell downstream of current bottom */
+		G_debug(2, "get next fill point candidate");
+		r_nbr = next_r;
+		c_nbr = next_c;
+		    /* go to next higher cell downstream */
+		    while (ele_nbr == bottom_ele || ele_nbr < min_bottom_ele) {
+			else {
+			    is_edge = 1;
+			    break;
+		    /* got next downstream cell that's higher than sink bottom */
+		    G_debug(2, "got next downstream cell");
+		else
+		    is_edge = 1;
+		if (is_edge) {
+		    G_warning(_("IRA reached edge !!!"));
+		    break;
+		/* increase ele or go to next point */
+		if (ele_nbr > bottom_ele + 1 && bottom_ele + 1 >= min_bottom_ele) {
+		    G_debug(2, "increase ele, keep point");
+		    bottom_ele = bottom_ele + 1;
+		if (ele_nbr > next_bottom_ele && next_bottom_ele >= min_bottom_ele) {
+		    bottom_ele = next_bottom_ele;
+		else {
+		    next_r = r_nbr;
+		    next_c = c_nbr;
+		    bottom_ele = ele_nbr;
+	    /* <-- IRA */
+	    if (least_impact == li_max)
+		G_warning(_("IRA error"));
+	    if (do_all || least_impact <= n_mod_max) {
+		/* (partially) fill the sink */
+		n_to_fill = 0;
+		cseg_get(&ele, &ele_val, first_sink->r, first_sink->c);
+		if (least_impact_ele != ele_val) {
+		    G_debug(1, "IRA sink filling");
+		    cseg_get(&ele, &ele_val, least_impact_r, least_impact_c);
+		    if (ele_val != least_impact_ele) {
+			G_debug(1, "changing ele from %d to %d", ele_val, least_impact_ele);
+			cseg_put(&ele, &least_impact_ele, least_impact_r, least_impact_c);
+		    n_to_fill = fill_sink(least_impact_r, least_impact_c, least_impact_ele);
+		    first_sink->r = least_impact_r;
+		    first_sink->c = least_impact_c;
+		    if (least_impact_ele < peak_ele)
+			n_just_a_bit++;
+		    else
+			n_filled++;
+		else {
+		    n_carved++;
+		    G_debug(1, "IRA at bottom");
+		/* carve if not completely filled */
+		if (least_impact_ele < peak_ele) {
+		    G_debug(2, "IRA carving");
+		    down_downhill = carve(first_sink->r, first_sink->c,
+				          least_impact_ele, peak_r, peak_c);
+	G_debug(1, "get next sink");
+    G_verbose_message
+    G_verbose_message(_("%d sinks processed"), n_sinks);
+    G_verbose_message(_("%d sinks within larger sinks"), n_processed);
+    G_verbose_message(_("%d sinks completely filled"), n_filled);
+    G_verbose_message(_("%d sinks partially filled and carved with IRA"), n_just_a_bit);
+    G_verbose_message(_("%d channels carved"), n_carved);
+    G_verbose_message
+    return 1;
+int one_cell_extrema(int do_peaks, int do_pits, int all)
+    int r, c, r_nbr, c_nbr;
+    int ct_dir;
+    int skipme;
+    CELL ele_min, ele_max, ele_this, ele_nbr;
+    unsigned int n_pits = 0;
+    unsigned int n_peaks = 0;
+    unsigned int counter = 0;
+    double sumofsquares, mean, stddev, upperci, lowerci;
+    int n_valid;
+    G_message(_("Remove one cell extremas"));
+    /* not for edges */
+	    skipme = 0;
+	    cseg_get(&ele, &ele_this, r, c);
+	    if (Rast_is_c_null_value(&ele_this))
+		continue;
+	    ele_min = INT_MAX;
+	    ele_max = INT_MIN;
+	    sumofsquares = mean = n_valid = 0;
+	    /* TODO: better use 5x5 neighbourhood ? */
+		/* get r, c (r_nbr, c_nbr) for neighbours */
+		    c_nbr < ncols) {
+		    if (Rast_is_c_null_value(&ele_nbr)) {
+			skipme = 1;
+			break;
+		    n_valid++;
+		    sumofsquares += ele_nbr * ele_nbr;
+		    mean += ele_nbr;
+		    if (ele_min > ele_nbr) {
+			ele_min = ele_nbr;
+		    if (ele_max < ele_nbr) {
+			ele_max = ele_nbr;
+		else {
+		    skipme = 1;
+		    break;
+	    if (skipme)
+		continue;
+	    counter++;
+	    if (all) {
+		upperci = ele_this - 1;
+		lowerci = ele_this + 1;
+	    else {
+		/* remove extremas only if outside 95% CI = mean +- 1.96 * SD */
+		mean /= n_valid;
+		stddev = sqrt(sumofsquares / n_valid - mean * mean);
+		upperci = mean + 1.96 * stddev;
+		lowerci = mean - 1.96 * stddev;
+	    /* one cell pit, lower than all surrounding neighbours */
+	    if (do_pits) {
+		if (ele_this < ele_min && ele_this < lowerci) {
+		    ele_this = ele_min;
+		    cseg_put(&ele, &ele_this, r, c);
+		    n_pits++;
+	    /* one cell peak, higher than all surrounding neighbours */
+	    if (do_peaks) {
+		if (ele_this > ele_max && ele_this > upperci) {
+		    ele_this = ele_max;
+		    n_peaks++;
+    G_percent(nrows, nrows, 1);	/* finish it */
+    G_verbose_message("%u cells checked", counter);
+    G_verbose_message("%u one-cell peaks removed", n_peaks);
+    G_verbose_message("%u one-cell pits removed", n_pits);
+    return 1;
Property changes on: grass-addons/grass7/raster/r.hydrodem/hydro_con.c
   + text/x-csrc
   + native
Modified: grass-addons/grass7/raster/r.hydrodem/init_search.c
--- grass-addons/grass7/raster/r.hydrodem/init_search.c	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/init_search.c	2012-01-09 17:41:56 UTC (rev 50109)
@@ -5,28 +5,39 @@
 int init_search(int depr_fd)
-    CELL *depr_buf, ele_value;
+    void *depr_buf, *depr_ptr;
+    CELL ele_value;
     char flag_value, flag_value_nbr, is_null;
-    WAT_ALT wa;
     char asp_value;
     unsigned int n_depr_cells = 0;
+    unsigned int n_null_cells = nrows * ncols - n_points;
+    int depr_map_type, depr_size;
     nxt_avail_pt = heap_size = 0;
     /* load edge cells and real depressions to A* heap */
-    if (depr_fd >= 0)
-	depr_buf = Rast_allocate_buf(CELL_TYPE);
-    else
+    G_message(_("Set edge points"));
+    if (depr_fd > -1) {
+	depr_map_type = Rast_get_map_type(depr_fd);
+	depr_size = Rast_cell_size(depr_map_type);
+	depr_buf = Rast_allocate_buf(depr_map_type);
+    else {
 	depr_buf = NULL;
+	depr_map_type = 0;
+	depr_size = 0;
+    depr_ptr = NULL;
-    G_message(_("Initialize A* Search..."));
 	if (depr_fd >= 0) {
-	    Rast_get_row(depr_fd, depr_buf, r, CELL_TYPE);
+	    Rast_get_row(depr_fd, depr_buf, r, depr_map_type);
+	    depr_ptr = depr_buf;
@@ -34,10 +45,15 @@
 	    is_null = FLAG_GET(flag_value, NULLFLAG);
-	    if (is_null)
+	    if (is_null) {
+		if (depr_fd > -1)
+		    depr_ptr = G_incr_void_ptr(depr_ptr, depr_size);
 		continue;
 	    asp_value = 0;
 	    if (r == 0 || r == nrows - 1 || c == 0 || c == ncols - 1) {
 		if (r == 0 && c == 0)
@@ -57,60 +73,62 @@
 		else if (c == ncols - 1)
 		    asp_value = -8;
-		seg_get(&watalt, (char *)&wa, r, c);
-		ele_value = wa.ele;
-		heap_add(r, c, ele_value);
+		cseg_get(&ele, &ele_value, r, c);
 		FLAG_SET(flag_value, EDGEFLAG);
-		bseg_put(&asp, &asp_value, r, c);
+		heap_add(r, c, ele_value, asp_value, flag_value);
+		if (depr_fd > -1)
 		continue;
-	    /* any neighbour NULL ? */
-	    for (ct_dir = 0; ct_dir < sides; ct_dir++) {
-		/* get r, c (r_nbr, c_nbr) for neighbours */
-		r_nbr = r + nextdr[ct_dir];
-		c_nbr = c + nextdc[ct_dir];
+	    if (n_null_cells > 0) {
+		/* any neighbour NULL ? */
-		bseg_get(&bitflags, &flag_value_nbr, r_nbr, c_nbr);
-		is_null = FLAG_GET(flag_value_nbr, NULLFLAG);
+		    bseg_get(&bitflags, &flag_value_nbr, r_nbr, c_nbr);
+		    is_null = FLAG_GET(flag_value_nbr, NULLFLAG);
-		if (is_null) {
-		    asp_value = -1 * drain[r - r_nbr + 1][c - c_nbr + 1];
-		    FLAG_SET(flag_value, EDGEFLAG);
+		    if (is_null) {
+			asp_value = -1 * drain[r - r_nbr + 1][c - c_nbr + 1];
+			FLAG_SET(flag_value, EDGEFLAG);
-		    break;
+			break;
-	    if (asp_value) /* some neighbour was NULL, point added to list */
+	    if (asp_value) { /* some neighbour was NULL, point added to list */
+		if (depr_fd > -1)
 		continue;
 	    /* real depression ? */
-	    if (depr_fd >= 0) {
-		if (!Rast_is_c_null_value(&depr_buf[c]) && depr_buf[c] != 0) {
+		DCELL depr_val = Rast_get_d_value(depr_ptr, depr_map_type);
+		if (!Rast_is_null_value(depr_ptr, depr_map_type) && depr_val != 0) {
 		    FLAG_SET(flag_value, DEPRFLAG);
 		    n_depr_cells++;
-	Rast_close(depr_fd);
 	G_free(depr_buf);
Modified: grass-addons/grass7/raster/r.hydrodem/load.c
--- grass-addons/grass7/raster/r.hydrodem/load.c	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/load.c	2012-01-09 17:41:56 UTC (rev 50109)
@@ -1,3 +1,4 @@
@@ -2,36 +3,25 @@
-/* need elevation map, do A* search on elevation like for r.watershed */
 int ele_round(double x)
-    if (x >= 0.0)
-	return x + .5;
-    else
-	return x - .5;
+    return (x > 0.0 ? x + .5 : x - .5);
- * loads elevation and optional flow accumulation map to memory and
- * gets start points for A* Search
+ * loads elevation map to segment file and gets start points for A* Search,
  * start points are edges
-int load_maps(int ele_fd, int acc_fd)
+int load_map(int ele_fd, int depr_fd)
     int r, c;
-    void *ele_buf, *ptr, *acc_buf = NULL, *acc_ptr = NULL;
-    CELL ele_value, *stream_id;
-    DCELL dvalue, acc_value;
-    size_t ele_size, acc_size = 0;
-    int ele_map_type, acc_map_type = 0;
-    WAT_ALT *wabuf;
-    char *flag_value_buf, *aspect;
+    char flag_value, asp_value = 0;
+    void *ele_buf, *ptr;
+    CELL ele_value;
+    DCELL dvalue;
+    int ele_size;
+    int ele_map_type;
-    if (acc_fd < 0)
-	G_message(_("Load elevation map..."));
-    else
-	G_message(_("Load input maps..."));
+    G_message(_("Load elevation map"));
     n_search_points = n_points = 0;
-    G_debug(1, "get buffers");
     ele_map_type = Rast_get_map_type(ele_fd);
@@ -45,25 +35,10 @@
 	return -1;
-    if (acc_fd >= 0) {
-	acc_map_type = Rast_get_map_type(acc_fd);
-	acc_size = Rast_cell_size(acc_map_type);
-	acc_buf = Rast_allocate_buf(acc_map_type);
-	if (acc_buf == NULL) {
-	    G_warning(_("Could not allocate memory"));
-	    return -1;
     ele_scale = 1;
     if (ele_map_type == FCELL_TYPE || ele_map_type == DCELL_TYPE)
 	ele_scale = 1000;	/* should be enough to do the trick */
-    wabuf = G_malloc(ncols * sizeof(WAT_ALT));
-    flag_value_buf = G_malloc(ncols * sizeof(char));
-    stream_id = G_malloc(ncols * sizeof(CELL));
-    aspect = G_malloc(ncols * sizeof(char));
     G_debug(1, "start loading %d rows, %d cols", nrows, ncols);
@@ -72,26 +47,17 @@
 	Rast_get_row(ele_fd, ele_buf, r, ele_map_type);
 	ptr = ele_buf;
-	    Rast_get_row(acc_fd, acc_buf, r, acc_map_type);
-	    acc_ptr = acc_buf;
-	    flag_value_buf[c] = 0;
-	    aspect[c] = 0;
-	    stream_id[c] = 0;
+	    flag_value = 0;
 	    /* check for masked and NULL cells */
 	    if (Rast_is_null_value(ptr, ele_map_type)) {
-		FLAG_SET(flag_value_buf[c], NULLFLAG);
-		FLAG_SET(flag_value_buf[c], INLISTFLAG);
-		FLAG_SET(flag_value_buf[c], WORKEDFLAG);
-		FLAG_SET(flag_value_buf[c], WORKED2FLAG);
+		FLAG_SET(flag_value, NULLFLAG);
+		FLAG_SET(flag_value, WORKED2FLAG);
 		Rast_set_c_null_value(&ele_value, 1);
-		/* flow accumulation */
-		Rast_set_d_null_value(&acc_value, 1);
 	    else {
@@ -109,54 +75,23 @@
 		    ele_value = ele_round(dvalue);
 		    break;
-		if (acc_fd < 0)
-		    acc_value = 1;
-		else {
-		    if (Rast_is_null_value(acc_ptr, acc_map_type))
-			G_fatal_error(_("Accumulation map does not match elevation map!"));
-		    switch (acc_map_type) {
-		    case CELL_TYPE:
-			acc_value = *((CELL *) acc_ptr);
-			break;
-		    case FCELL_TYPE:
-			acc_value = *((FCELL *) acc_ptr);
-			break;
-		    case DCELL_TYPE:
-			acc_value = *((DCELL *) acc_ptr);
-			break;
 		n_points++;
-	    wabuf[c].wat = acc_value;
-	    wabuf[c].ele = ele_value;
+	    cseg_put(&ele, &ele_value, r, c);
+	    bseg_put(&draindir, &asp_value, r, c);
 	    ptr = G_incr_void_ptr(ptr, ele_size);
-	    if (acc_fd >= 0)
-		acc_ptr = G_incr_void_ptr(acc_ptr, acc_size);
-	seg_put_row(&watalt, (char *) wabuf, r);
-	bseg_put_row(&asp, aspect, r);
-	cseg_put_row(&stream, stream_id, r);
-	bseg_put_row(&bitflags, flag_value_buf, r);
     Rast_close(ele_fd);
     G_free(ele_buf);
-    G_free(wabuf);
-    G_free(flag_value_buf);
-    G_free(stream_id);
-    G_free(aspect);
-	Rast_close(acc_fd);
-	G_free(acc_buf);
     G_debug(1, "%d non-NULL cells", n_points);
-    return n_points;
+    return 1;
Modified: grass-addons/grass7/raster/r.hydrodem/local_proto.h
--- grass-addons/grass7/raster/r.hydrodem/local_proto.h	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/local_proto.h	2012-01-09 17:41:56 UTC (rev 50109)
@@ -2,39 +2,38 @@
 #ifndef __LOCAL_PROTO_H__
 #define __LOCAL_PROTO_H__
-#include "flag.h"
 #include "seg.h"
+#include "flag.h"
 #define INDEX(r, c) ((r) * ncols + (c))
 #define MAXDEPTH 1000     /* maximum supported tree depth of stream network */
-#define POINT       struct a_point
-POINT {
+struct ddir
+    int pos;
+    int dir;
+struct point
     int r, c;
-#define HEAP_PNT    struct heap_point
-HEAP_PNT {
+struct heap_point {
    unsigned int added;
    CELL ele;
-   POINT pnt;
+   int r, c;
-#define WAT_ALT    struct wat_altitude
-WAT_ALT {
-   CELL ele;
-   DCELL wat;
+struct sink_list
+    int r, c;
+    struct sink_list *next;
-/* global variables */
-#ifdef MAIN
-#       define GLOBAL
-#else
-#       define GLOBAL extern
-#endif
-GLOBAL struct snode
+struct snode
     int r, c;
     int id;
@@ -42,51 +41,48 @@
     int n_trib_total;     /* number of all upstream stream segments */
     int n_alloc;          /* n allocated tributaries */
     int *trib;
+    double *acc;
 } *stream_node;
-GLOBAL int nrows, ncols;
-GLOBAL unsigned int n_search_points, n_points, nxt_avail_pt;
-GLOBAL unsigned int heap_size;
-GLOBAL unsigned int n_stream_nodes, n_alloc_nodes;
-GLOBAL POINT *outlets;
-GLOBAL unsigned int n_outlets, n_alloc_outlets;
-GLOBAL char drain[3][3];
-GLOBAL char sides;
-GLOBAL int c_fac;
-GLOBAL int ele_scale;
-GLOBAL int have_depressions;
+extern int nrows, ncols;
+extern unsigned int n_search_points, n_points, nxt_avail_pt;
+extern unsigned int heap_size;
+extern unsigned int n_sinks;
+extern int n_mod_max, size_max;
+extern int do_all, keep_nat, nat_thresh;
+extern unsigned int n_stream_nodes, n_alloc_nodes;
+extern struct point *outlets;
+extern struct sink_list *sinks, *first_sink;
+extern unsigned int n_outlets, n_alloc_outlets;
+extern char drain[3][3];
+extern unsigned int first_cum;
+extern char sides;
+extern int c_fac;
+extern int ele_scale;
+extern struct RB_TREE *draintree;
-GLOBAL SSEG search_heap;
-GLOBAL SSEG astar_pts;
-GLOBAL BSEG bitflags;
-GLOBAL SSEG watalt;
-GLOBAL BSEG asp;
-GLOBAL CSEG stream;
+extern SSEG search_heap;
+extern SSEG astar_pts;
+extern BSEG bitflags;
+extern CSEG ele;
+extern BSEG draindir;
+extern CSEG stream;
 /* load.c */
-int load_maps(int, int);
+int load_map(int, int);
 /* init_search.c */
 int init_search(int);
 /* do_astar.c */
 int do_astar(void);
-unsigned int heap_add(int, int, CELL);
+unsigned int heap_add(int, int, CELL, char, char);
-/* streams.c */
-int do_accum(double);
-int extract_streams(double, double, int, int);
+/* hydro_con.c */
+int hydro_con(void);
+int one_cell_extrema(int, int, int);
-/* thin.c */
-int thin_streams(void);
-/* basins.c */
-int basin_borders(void);
-/* del_streams.c */
-int del_streams(int);
 /* close.c */
-int close_maps(char *, char *, char *);
+int close_map(char *, int);
 #endif /* __LOCAL_PROTO_H__ */
Modified: grass-addons/grass7/raster/r.hydrodem/main.c
--- grass-addons/grass7/raster/r.hydrodem/main.c	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/main.c	2012-01-09 17:41:56 UTC (rev 50109)
@@ -1,11 +1,10 @@
- * MODULE:       r.stream.extract
+ * MODULE:       r.hydrodem
  * AUTHOR(S):    Markus Metz <markus.metz.giswork gmail.com>
  * PURPOSE:      Hydrological analysis
- *               Extracts stream networks from accumulation raster with
- *               given threshold
+ *               DEM hydrological conditioning based on A* Search
  * COPYRIGHT:    (C) 1999-2009 by the GRASS Development Team
  *               This program is free software under the GNU General Public
@@ -16,59 +15,59 @@
 #include <stdlib.h>
 #include <string.h>
 #include <float.h>
-#include <math.h>
-#define MAIN
 int nrows, ncols;
+unsigned int n_sinks;
+int n_mod_max, size_max;
+int do_all, keep_nat, nat_thresh;
-POINT *outlets;
+struct point *outlets;
+struct sink_list *sinks, *first_sink;
 char drain[3][3] = { {7, 6, 5}, {8, 0, 4}, {1, 2, 3} };
+unsigned int first_cum;
 char sides;
 int c_fac;
 int ele_scale;
-int have_depressions;
+struct RB_TREE *draintree;
 SSEG search_heap;
-SSEG astar_pts;
 BSEG bitflags;
-SSEG watalt;
-BSEG asp;
+CSEG ele;
+BSEG draindir;
 CSEG stream;
-CELL *astar_order;
 int main(int argc, char *argv[])
     struct
-	struct Option *ele, *acc, *depression;
-	struct Option *threshold, *d8cut;
-	struct Option *mont_exp;
-	struct Option *min_stream_length;
-	struct Option *memory;
+	struct Option *ele, *depr, *memory;
     } input;
     struct
-	struct Option *stream_rast;
-	struct Option *stream_vect;
-	struct Option *dir_rast;
+	struct Option *ele_hydro;
+	struct Option *mod_max;
+	struct Option *size_max;
+	struct Flag *do_all;
     } output;
     struct GModule *module;
-    int ele_fd, acc_fd, depr_fd;
-    double threshold, d8cut, mont_exp;
-    int min_stream_length = 0, memory;
+    int ele_fd, ele_map_type, depr_fd;
+    int memory;
     int seg_cols, seg_rows;
     double seg2kb;
     int num_open_segs, num_open_array_segs, num_seg_total;
     double memory_divisor, heap_mem, disk_space;
     const char *mapset;
+    struct Colors colors;
     G_gisinit(argv[0]);
@@ -76,64 +75,21 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
     G_add_keyword(_("hydrology"));
-    module->description = _("Stream network extraction");
+    module->description = _("Hydrological conditioning, sink removal");
     input.ele = G_define_standard_option(G_OPT_R_INPUT);
-    input.ele->key = "elevation";
+    input.ele->key = "input";
     input.ele->label = _("Elevation map");
-    input.ele->description = _("Elevation on which entire analysis is based");
+    input.ele->description =
+	_("Elevation map to be hydrologically corrected");
-    input.acc = G_define_standard_option(G_OPT_R_INPUT);
-    input.acc->key = "accumulation";
-    input.acc->label = _("Accumulation map");
-    input.acc->required = NO;
-    input.acc->description =
-	_("Stream extraction will use provided accumulation instead of calculating it anew");
+    input.depr = G_define_standard_option(G_OPT_R_INPUT);
+    input.depr->key = "depression";
+    input.depr->required = NO;
+    input.depr->label = _("Depression map");
+    input.depr->description =
+	_("Map indicating real depressions that must not be modified");
-    input.depression = G_define_standard_option(G_OPT_R_INPUT);
-    input.depression->key = "depression";
-    input.depression->label = _("Map with real depressions");
-    input.depression->required = NO;
-    input.depression->description =
-	_("Streams will not be routed out of real depressions");
-    input.threshold = G_define_option();
-    input.threshold->key = "threshold";
-    input.threshold->label = _("Minimum flow accumulation for streams");
-    input.threshold->description = _("Must be > 0");
-    input.threshold->required = YES;
-    input.threshold->type = TYPE_DOUBLE;
-    input.d8cut = G_define_option();
-    input.d8cut->key = "d8cut";
-    input.d8cut->label = _("Use SFD above this threshold");
-    input.d8cut->description =
-	_("If accumulation is larger than d8cut, SFD is used instead of MFD."
-	  " Applies only if no accumulation map is given.");
-    input.d8cut->required = NO;
-    input.d8cut->answer = "infinity";
-    input.d8cut->type = TYPE_DOUBLE;
-    input.mont_exp = G_define_option();
-    input.mont_exp->key = "mexp";
-    input.mont_exp->type = TYPE_DOUBLE;
-    input.mont_exp->required = NO;
-    input.mont_exp->answer = "0";
-    input.mont_exp->label =
-	_("Montgomery exponent for slope, disabled with 0");
-    input.mont_exp->description =
-	_("Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold.");
-    input.min_stream_length = G_define_option();
-    input.min_stream_length->key = "stream_length";
-    input.min_stream_length->type = TYPE_INTEGER;
-    input.min_stream_length->required = NO;
-    input.min_stream_length->answer = "0";
-    input.min_stream_length->label =
-	_("Delete stream segments shorter than stream_length cells.");
-    input.min_stream_length->description =
-	_("Applies only to first-order stream segments (springs/stream heads).");
     input.memory = G_define_option();
     input.memory->key = "memory";
     input.memory->type = TYPE_INTEGER;
@@ -141,27 +97,36 @@
     input.memory->answer = "300";
     input.memory->description = _("Maximum memory to be used in MB");
-    output.stream_rast = G_define_standard_option(G_OPT_R_OUTPUT);
-    output.stream_rast->key = "stream_rast";
-    output.stream_rast->description =
-	_("Output raster map with unique stream ids");
-    output.stream_rast->required = NO;
-    output.stream_rast->guisection = _("Output options");
+    output.ele_hydro = G_define_standard_option(G_OPT_R_OUTPUT);
+    output.ele_hydro->key = "output";
+    output.ele_hydro->description =
+	_("Name of hydrologically conditioned raster map");
+    output.ele_hydro->required = YES;
-    output.stream_vect = G_define_standard_option(G_OPT_V_OUTPUT);
-    output.stream_vect->key = "stream_vect";
-    output.stream_vect->description =
-	_("Output vector with unique stream ids");
-    output.stream_vect->required = NO;
-    output.stream_vect->guisection = _("Output options");
+    output.mod_max = G_define_option();
+    output.mod_max->key = "mod";
+    output.mod_max->description =
+	(_("Only remove sinks requiring not more than <mod> cell modifications."));
+    output.mod_max->type = TYPE_INTEGER;
+    output.mod_max->answer = "4";
+    output.mod_max->required = YES;
-    output.dir_rast = G_define_standard_option(G_OPT_R_OUTPUT);
-    output.dir_rast->key = "direction";
-    output.dir_rast->description =
-	_("Output raster map with flow direction");
-    output.dir_rast->required = NO;
-    output.dir_rast->guisection = _("Output options");
+    output.size_max = G_define_option();
+    output.size_max->key = "size";
+    output.size_max->description =
+	(_("Only remove sinks not larger than <size> cells."));
+    output.size_max->type = TYPE_INTEGER;
+    output.size_max->answer = "4";
+    output.size_max->required = YES;
+    output.do_all = G_define_flag();
+    output.do_all->key = 'a';
+    output.do_all->label = (_("Remove all sinks."));
+    output.do_all->description =
+	(_("By default only minor corrections are done to the DEM and "
+	  "the result will not be 100% hydrologically correct."
+	  "Use this flag to override default."));
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -172,59 +137,21 @@
     /* input maps exist ? */
     if (!G_find_raster(input.ele->answer, ""))
 	G_fatal_error(_("Raster map <%s> not found"), input.ele->answer);
-    if (input.acc->answer) {
-	if (!G_find_raster(input.acc->answer, ""))
-	    G_fatal_error(_("Raster map <%s> not found"), input.acc->answer);
+    if (input.depr->answer) {
+	if (!G_find_raster(input.depr->answer, ""))
+	    G_fatal_error(_("Raster map <%s> not found"),
+	                  input.depr->answer);
-    if (input.depression->answer) {
-	if (!G_find_raster(input.depression->answer, ""))
-	    G_fatal_error(_("Raster map <%s> not found"), input.depression->answer);
-	have_depressions = 1;
-    else
-	have_depressions = 0;
+    if ((n_mod_max = atoi(output.mod_max->answer)) <= 0)
+	G_fatal_error(_("'%s' must be a positive integer"),
+	              output.mod_max->key);
-    /* threshold makes sense */
-    threshold = atof(input.threshold->answer);
-    if (threshold <= 0)
-	G_fatal_error(_("Threshold must be > 0 but is %f"), threshold);
+    if ((size_max = atoi(output.size_max->answer)) <= 0)
+		      output.size_max->key);
-    /* d8cut */
-    if (strcmp(input.d8cut->answer, "infinity") == 0) {
-	d8cut = DBL_MAX;
-    else {
-	d8cut = atof(input.d8cut->answer);
-	if (d8cut < 0)
-	    G_fatal_error(_("d8cut must be positive or zero but is %f"),
-			  d8cut);
-    /* Montgomery stream initiation */
-    if (input.mont_exp->answer) {
-	mont_exp = atof(input.mont_exp->answer);
-	if (mont_exp < 0)
-	    G_fatal_error(_("Montgomery exponent must be positive or zero but is %f"),
-			  mont_exp);
-	if (mont_exp > 3)
-	    G_warning(_("Montgomery exponent is %f, recommended range is 0.0 - 3.0"),
-		      mont_exp);
-    else
-	mont_exp = 0;
-    /* Minimum stream segment length */
-    if (input.min_stream_length->answer) {
-	min_stream_length = atoi(input.min_stream_length->answer);
-	if (min_stream_length < 0)
-	    G_fatal_error(_("Minimum stream length must be positive or zero but is %d"),
-			  min_stream_length);
-    else
-	min_stream_length = 0;
     if (input.memory->answer) {
 	memory = atoi(input.memory->answer);
 	if (memory <= 0)
@@ -234,11 +161,13 @@
     else
 	memory = 300;
-    /* Check for some output map */
-    if ((output.stream_rast->answer == NULL)
-	&& (output.stream_vect->answer == NULL)
-	&& (output.dir_rast->answer == NULL)) {
-	G_fatal_error(_("Sorry, you must choose at least one output map."));
+    do_all = output.do_all->answer;
+    if (!do_all) {
+	G_verbose_message(_("All sinks with max %d cells to be modified will be removed"),
+			  n_mod_max);
+	G_verbose_message(_("All sinks not larger than %d cells will be removed."),
+			  size_max);
@@ -251,22 +180,12 @@
     if (ele_fd < 0)
 	G_fatal_error(_("Could not open input map %s"), input.ele->answer);
-	mapset = G_find_raster2(input.acc->answer, "");
-	acc_fd = Rast_open_old(input.acc->answer, mapset);
-	if (acc_fd < 0)
-	    G_fatal_error(_("Could not open input map %s"),
-			  input.acc->answer);
-    else
-	acc_fd = -1;
-	mapset = G_find_raster2(input.depression->answer, "");
-	depr_fd = Rast_open_old(input.depression->answer, mapset);
+	mapset = G_find_raster2(input.depr->answer, "");
+	depr_fd = Rast_open_old(input.depr->answer, mapset);
 	if (depr_fd < 0)
-			  input.depression->answer);
     else
 	depr_fd = -1;
@@ -274,111 +193,77 @@
     /* set global variables */
     nrows = Rast_window_rows();
     ncols = Rast_window_cols();
-    sides = 8;	/* not a user option */
-    c_fac = 5;	/* not a user option, MFD covergence factor 5 gives best results */
+    sides = 8;			/* not a user option */
+    ele_map_type = Rast_get_map_type(ele_fd);
     /* segment structures */
     seg_rows = seg_cols = 64;
     seg2kb = seg_rows * seg_cols / 1024.;
-    /* elevation + accumulation: 12 byte -> 48 KB / segment
-     * aspect: 1 byte -> 4 KB / segment
-     * stream: 4 byte -> 16 KB / segment
-     * flag: 1 byte -> 4 KB / segment
-     * Total MB / segment so far: 0.07
-     * astar_points: 8 byte -> 32 KB / segment
-     * heap_points: 16 byte -> 64 KB / segment
-     * Total MB / segment: 0.16
     /* balance segment files */
-    /* elevation + accumulation: * 2 */
-    memory_divisor = sizeof(WAT_ALT) * 2;
-    disk_space = sizeof(WAT_ALT);
-    /* aspect: as is */
-    memory_divisor += sizeof(char);
-    disk_space += sizeof(char);
-    /* stream ids: / 2 */
-    memory_divisor += sizeof(int) / 2.;
-    disk_space += sizeof(int);
+    /* elevation: * 2 */
+    memory_divisor = seg2kb * sizeof(CELL) * 2;
+    /* drainage direction: as is */
+    memory_divisor += seg2kb * sizeof(char);
     /* flags: * 4 */
-    memory_divisor += sizeof(char) * 4;
-    /* astar_points: / 16 */
-    /* ideally only a few but large segments */
-    memory_divisor += sizeof(POINT) / 16.;
-    disk_space += sizeof(POINT);
+    memory_divisor += seg2kb * sizeof(char) * 4;
     /* heap points: / 4 */
-    memory_divisor += sizeof(HEAP_PNT) / 4.;
-    disk_space += sizeof(HEAP_PNT);
+    memory_divisor += seg2kb * sizeof(struct heap_point) / 4.;
     /* KB -> MB */
-    memory_divisor *= seg2kb / 1024.;
-    disk_space *= seg2kb / 1024.;
+    memory_divisor /= 1024.;
     num_open_segs = memory / memory_divisor;
-    heap_mem = num_open_segs * seg2kb * sizeof(HEAP_PNT) /
+    /* heap_mem is in MB */
+    heap_mem = num_open_segs * seg2kb * sizeof(struct heap_point) /
                (4. * 1024.);
     num_seg_total = (ncols / seg_cols + 1) * (nrows / seg_rows + 1);
     if (num_open_segs > num_seg_total) {
 	heap_mem += (num_open_segs - num_seg_total) * memory_divisor;
 	heap_mem -= (num_open_segs - num_seg_total) * seg2kb *
-		    sizeof(HEAP_PNT) / (4. * 1024.);
+	            sizeof(struct heap_point) / (4. * 1024.);
 	num_open_segs = num_seg_total;
     if (num_open_segs < 16) {
 	num_open_segs = 16;
 	           (4. * 1024.);
+    disk_space = (1. * sizeof(CELL) + 2 * sizeof(char) +
+                 sizeof(struct heap_point));
+    disk_space *= (num_seg_total * seg2kb / 1024.);  /* KB -> MB */
     G_verbose_message(_("%.2f of data are kept in memory"),
                       100. * num_open_segs / num_seg_total);
-    disk_space *= num_seg_total;
-    if (disk_space < 1024.0)
-	G_verbose_message(_("Will need up to %.2f MB of disk space"), disk_space);
-    else
-	G_verbose_message(_("Will need up to %.2f GB (%.0f MB) of disk space"),
-	           disk_space / 1024.0, disk_space);
+    G_verbose_message(_("Will need up to %.2f MB of disk space"), disk_space);
     /* open segment files */
     G_verbose_message(_("Create temporary files..."));
-    seg_open(&watalt, nrows, ncols, seg_rows, seg_cols, num_open_segs * 2,
-        sizeof(WAT_ALT), 1);
+    cseg_open(&ele, seg_rows, seg_cols, num_open_segs * 2);
     if (num_open_segs * 2 > num_seg_total)
-	heap_mem += (num_open_segs * 2 - num_seg_total) * seg2kb *
-	            sizeof(WAT_ALT) / 1024.;
-    cseg_open(&stream, seg_rows, seg_cols, num_open_segs / 2.);
-    bseg_open(&asp, seg_rows, seg_cols, num_open_segs);
+	heap_mem += (num_open_segs * 2 - num_seg_total) * seg2kb * sizeof(CELL) / 1024.;
+    bseg_open(&draindir, seg_rows, seg_cols, num_open_segs);
     bseg_open(&bitflags, seg_rows, seg_cols, num_open_segs * 4);
     if (num_open_segs * 4 > num_seg_total)
 	heap_mem += (num_open_segs * 4 - num_seg_total) * seg2kb / 1024.;
-    /* load maps */
-    if (load_maps(ele_fd, acc_fd) < 0)
-	G_fatal_error(_("Could not load input map(s)"));
-    else if (!n_points)
-	G_fatal_error(_("No non-NULL cells in input map(s)"));
-    G_debug(1, "open segments for A* points");
-    /* columns per segment */
-    seg_cols = seg_rows * seg_rows;
-    num_seg_total = n_points / seg_cols;
-    if (n_points % seg_cols > 0)
-	num_seg_total++;
-    /* no need to have more segments open than exist */
-    num_open_array_segs = num_open_segs / 16.;
-    if (num_open_array_segs > num_seg_total)
-	num_open_array_segs = num_seg_total;
-    if (num_open_array_segs < 1)
-	num_open_array_segs = 1;
+    /* load map */
+    if (load_map(ele_fd, depr_fd) < 0) {
+	cseg_close(&ele);
+	bseg_close(&draindir);
+	bseg_close(&bitflags);
+	G_fatal_error(_("Could not load input map"));
-    G_debug(1, "segment size for A* points: %d", seg_cols);
-    seg_open(&astar_pts, 1, n_points, 1, seg_cols, num_open_array_segs,
-	     sizeof(POINT), 1);
+    if (n_points == 0) {
+	cseg_close(&ele);
+	G_fatal_error(_("No non-NULL cells loaded from input map"));
-    /* one-based d-ary search_heap with astar_pts */
+    /* one-based d-ary search_heap */
     G_debug(1, "open segments for A* search heap");
     /* allowed memory for search heap in MB */
@@ -390,7 +275,8 @@
 	num_seg_total++;
-    num_open_array_segs = (1 << 20) * heap_mem / (seg_cols * sizeof(HEAP_PNT));
+    num_open_array_segs = (1 << 20) * heap_mem /
+                           (seg_cols * sizeof(struct heap_point));
     if (num_open_array_segs < 2)
@@ -402,53 +288,60 @@
     /* the search heap will not hold more than 5% of all points at any given time ? */
     /* chances are good that the heap will fit into one large segment */
     seg_open(&search_heap, 1, n_points + 1, 1, seg_cols,
-	     num_open_array_segs, sizeof(HEAP_PNT), 1);
+	     num_open_array_segs, sizeof(struct heap_point), 1);
     /*    processing    */
+    /* remove one cell extrema */
+    one_cell_extrema(1, 1, 0);
     /* initialize A* search */
-    if (init_search(depr_fd) < 0)
+    if (init_search(depr_fd) < 0) {
+	seg_close(&search_heap);
+	cseg_close(&ele);
 	G_fatal_error(_("Could not initialize search"));
+    if (depr_fd >= 0) {
+	Rast_close(depr_fd);
     /* sort elevation and get initial stream direction */
-    if (do_astar() < 0)
+    if (do_astar() < 0) {
+	cseg_close(&ele);
 	G_fatal_error(_("Could not sort elevation map"));
-    if (acc_fd < 0) {
-	/* accumulate surface flow */
-	if (do_accum(d8cut) < 0)
-	    G_fatal_error(_("Could not calculate flow accumulation"));
+    /* hydrological corrections */
+    if (hydro_con() < 0) {
+	cseg_close(&ele);
+	G_fatal_error(_("Could not apply hydrological conditioning"));
-    /* extract streams */
-    if (extract_streams
-	(threshold, mont_exp, min_stream_length, acc_fd < 0) < 0)
-	G_fatal_error(_("Could not extract streams"));
-    seg_close(&astar_pts);
-    seg_close(&watalt);
-    /* thin streams */
-    if (thin_streams() < 0)
-	G_fatal_error(_("Could not thin streams"));
-    /* delete short streams */
-    if (min_stream_length) {
-	if (del_streams(min_stream_length) < 0)
-	    G_fatal_error(_("Could not delete short stream segments"));
+    /* write output maps */
+    if (close_map(output.ele_hydro->answer, ele_map_type) < 0) {
+	cseg_close(&ele);
+	G_fatal_error(_("Could not write output map"));
-    /* write output maps */
-    if (close_maps(output.stream_rast->answer, output.stream_vect->answer,
-		   output.dir_rast->answer) < 0)
-	G_fatal_error(_("Could not write output maps"));
-    bseg_close(&asp);
-    cseg_close(&stream);
+    cseg_close(&ele);
+    Rast_read_colors(input.ele->answer, mapset, &colors);
+    Rast_write_colors(output.ele_hydro->answer, G_mapset(), &colors);
     exit(EXIT_SUCCESS);
Copied: grass-addons/grass7/raster/r.hydrodem/r.hydrodem.html (from rev 50108, grass-addons/grass7/raster/r.hydrodem/r.stream.extract.html)
--- grass-addons/grass7/raster/r.hydrodem/r.hydrodem.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.hydrodem/r.hydrodem.html	2012-01-09 17:41:56 UTC (rev 50109)
@@ -0,0 +1,84 @@
+<h2>DESCRIPTION</h2>
+<em>r.hydrodem</em> applies hydrological conditioning (sink removal) to
+a required input <em>elevation</em> map. If the conditioned elevation
+map is going to be used as input elevation for <em>r.watershed</em>,
+only small sinks should be removed and the amount of modifications
+restricted with the <b>mod</b> option. For other modules such as
+<em>r.terraflow</em> or third-party software, full sink removal is
+recommended.
+<h2>OPTIONS</h2>
+<dl>
+<dt><b>input</b>
+<dd>Input map, required: Digital elevation model to be corrected. Gaps
+in the elevation map that are located within the area of interest should
+be filled beforehand, e.g. with <em>r.fillnulls</em> or
+<em>r.resamp.bspline</em>, to avoid distortions.
+<p>
+<dt><b>output</b>
+<dd>Output map, required: Hydrologically conditioned digital elevation
+model. By default, only minor modifications are done and not all sinks
+are removed.
+<p>
+<dt><b>size</b>
+<dd>All sinks of up to <b>size</b> cells will be removed.
+Default is 4, if in doubt, decrease and not increase.
+<p>
+<dt><b>mod</b>
+<dd>All sinks will be removed that require not more than <b>mod</b>
+cells to be modifed. Often, rather large sinks can be removed by
+carving through only few cells. Default is 4, if in doubt, increase
+and not decrease.
+<p>
+<dt><b>-a</b>
+<dd><b>Not recommended if input for <em>r.watershed</em> is generated.</b>
+<br>
+With the <b>-a</b> flag set, all sinks will be removed using an impact
+reduction approach based on Lindsay &amp; Creed (2005). The output will be a
+depression-less digital elevation model, suitable for e.g.
+<em>r.terraflow</em> or other hydrological analyses that require a
+depression-less DEM as input.
+</dl>
+<h2>NOTES</h2>
+This module is designed for <em>r.watershed</em> with the purpose to
+slightly denoise a DEM prior to analysis. First, all one-cell peaks and
+pits are removed, then the actual hydrological corrections are applied.
+In most cases, the removal of one-cell extrema could already be
+sufficient to improve <em>r.watershed</em> results in difficult terrain,
+particularly nearly flat areas.
+<p>
+The impact reduction algorithm used by <em>r.hydrodem</em> is based on
+Lindsay &amp; Creed (2005), with some additional checks for
+hydrological consistency. With complete sink removal, results of
+<em>r.terraflow</em> are very similar to results of <em>r.watershed</em>.
+<p>
+<em>r.hydrodem</em> uses the same method to determine drainage directions
+like <em>r.watershed</em>.
+<p>
+<h2>REFERENCES</h2>
+Lindsay, J. B., and Creed, I. F. 2005. Removal of artifact depressions
+from digital elevation models: towards a minimum impact approach.
+Hydrological Processes 19, 3113-3126.
+DOI: <a href=http://dx.doi.org/10.1002/hyp.5835>10.1002/hyp.5835</a>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.watershed.html">r.watershed</a>,
+<a href="r.terraflow.html">r.terraflow</a>,
+<a href="r.fill.dir.html">r.fill.dir</a>,
+<a href="r.fillnulls.html">r.fillnulls</a>,
+<a href="r.resamp.bspline.html">r.resamp.bspline</a>
+</em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/raster/r.hydrodem/r.stream.extract.html
--- grass-addons/grass7/raster/r.hydrodem/r.stream.extract.html	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/r.stream.extract.html	2012-01-09 17:41:56 UTC (rev 50109)
@@ -1,228 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.stream.extract</em> extracts streams in both raster and vector
-format from a required input <em>elevation</em> map and optional input
-<em>accumulation map</em>.
-<h2>OPTIONS</h2>
-<dl>
-<dt><em>elevation</em>
-<dd>Input map, required: Elevation on which entire analysis is based.
-NULL (nodata) cells are ignored, zero and negative values are valid
-elevation data. Gaps in the elevation map that are located within the
-area of interest must be filled beforehand, e.g. with
-<em>r.fillnulls</em>, to avoid distortions.
-<p>
-<dt><em>accumulation</em>
-<dd>Input map, optional: Accumulation values of the provided
-<em>accumulation</em> map are used and not calculated from the input
-<em>elevation</em> map. If <em>accumulation</em> is given,
-<em>elevation</em> must be exactly the same map used to calculate
-<em>accumulation</em>. If <em>accumulation</em> was calculated with
-<a href="r.terraflow.html">r.terraflow</a>, the filled elevation output
-of r.terraflow must be used. Further on, the current region's resolution
-should be identical to the <em>accumulation map</em>. Flow direction is
-first calculated from <em>elevation</em> and then adjusted to
-<em>accumulation</em>. It is not necessary to provide <em>accumulation</em>
-as the number of cells, it can also be the optionally adjusted or
-weighed total contributing area in square meters or any other unit.
-<p>
-<dt><em>depression</em>
-<dd>Input map, optional: All non-NULL and non-zero cells will be regarded
-as real depressions. Streams will not be routed out of depressions. If an
-area is marked as depression but the elevation model has no depression
-at this location, streams will not stop there. If a flow accumulation map
-and a map with real depressions are provided, the flow accumulation map
-must match the depression map such that flow is not distributed out of
-the indicated depressions. It is recommended to use internally computed
-flow accumulation if a depression map is provided.
-<p>
-<dt><em>threshold</em>
-<dd>Required: <em>threshold</em> for stream initiation by overland flow:
-the minumum (optionally modifed) flow accumulation value that will initiate
-a new stream. If Montgomery's method for channel initiation is used, the
-cell value of the accumulation input map is multiplied by
-(tan(local slope))<sup>mexp</sup> and then compared to <em>threshold</em>.
-<p>
-<dt><em>d8cut</em>
-<dd>Minimum amount of overland flow (accumulation) when SFD (D8) will be
-used instead of MFD (FD8) to calculate flow accumulation. Only applies
-if no accumulation map is provided. Setting to 0 disables MFD completely.
-<p>
-<dt><em>mexp</em>
-<dd>Use the method of Montgomery and Foufoula-Georgiou (1993) to
-initiate a stream with exponent <em>mexp</em>. The cell value of the
-accumulation input map is multiplied by (tan(local slope))<sup>mexp</sup>
-and then compared to <em>threshold</em>. If threshold is reached or
-exceeded, a new stream is initiated. The default value 0 disables
-Montgomery. Montgomery and Foufoula-Georgiou (1993) generally recommend
-to use 2.0 as exponent. <em>mexp</em> values closer to 0 will produce
-streams more similar to streams extracted with Montgomery disabled.
-Larger <em>mexp</em> values decrease the number of streams in flat areas
-and increase the number of streams in steep areas. If <em>weight</em> is
-given, the weight is applied first.
-<p>
-<dt><em>stream_length</em>
-<dd>Minimum stream length in number of cells for first-order (head/spring)
-stream segments. All first-order stream segments shorter than
-<em>stream_length</em> will be deleted.
-<p>
-<dt><em>stream_rast</em>
-<dd>Output raster map with extracted streams. Cell values encode unique
-ID for each stream segment.
-<p>
-<dt><em>stream_vect</em>
-<dd>Output vector map with extracted stream segments and points. Points
-are written at the start location of each stream segment and at the
-outlet of a stream network. In layer 1, categories are unique IDs,
-identical to the cell value of the raster output. The attribute table
-for layer 1 holds information about the type of stream segment: start
-segment, or intermediate segment with tributaries. Columns are cat int,
-stream_type varchar(), type_code int. The encoding for type_code is 0 =
-start, 1 = intermediate. In layer 2, categories are identical to
-type_code in layer 1 with additional category 2 = outlet for outlet
-points. Points with category 1 = intermediate in layer 2 are at the
-location of confluences.
-<p>
-<dt><em>direction</em>
-<dd>Output raster map with flow direction for all non-NULL cells in
-input elevation. Flow direction is of D8 type with a range of 1 to 8.
-Multiplying values with 45 gives degrees CCW from East. Flow direction
-was adjusted during thinning, taking shortcuts and skipping cells that
-were eliminated by the thinning procedure.
-</dl>
-<h2>NOTES</h2>
-<h4>Stream extraction</h4>
-If no accumulation input map is provided, flow accumulation is
-determined with a hydrological anaylsis similar to
-<a href="r.watershed.html">r.watershed</a>. The algorithm is
-MFD (FD8) after Holmgren 1994, as for
-<a href="r.watershed.html">r.watershed</a>. The <em>threshold</em>
-option determines the number of streams and detail of stream networks.
-Whenever flow accumulation reaches <em>threshold</em>, a new stream is
-started and traced downstream to its outlet point. As for
-<a href="r.watershed.html">r.watershed</a>, flow accumulation is
-calculated as the number of cells draining through a cell.
-<h4>Weighed flow accumulation</h4>
-Flow accumulation can be calculated first, e.g. with
-<a href="r.watershed.html">r.watershed</a>, and then modified before
-using it as input for <em>r.stream.extract</em>. In its general form, a
-weighed accumulation map is generated by first creating a weighing map
-and then multiplying the accumulation map with the weighing map using
-<a href="r.mapcalc.html">r.mapcalc</a>. It is highly recommended to
-evaluate the weighed flow accumulation map first, before using it as
-input for <em>r.stream.extract</em>.
-<p>
-This allows e.g. to decrease the number of streams in dry areas and
-increase the number of streams in wet areas by setting <em>weight</em>
-to smaller than 1 in dry areas and larger than 1 in wet areas.
-<p>
-Another possibility is to restrict channel initiation to valleys
-determined from terrain morphology. Valleys can be determined with
-<a href="r.param.scale.html">r.param.scale</a> param=crosc
-(cross-sectional or tangential curvature). Curvature values &lt; 0
-indicate concave features, i.e. valleys. The size of the processing
-window determines whether narrow or broad valleys will be identified
-(See example below).
-<h4>Stream output</h4>
-The <em>stream_rast</em> output raster and vector contains stream
-segments with unique IDs. Note that these IDs are different from the IDs
-assigned by <a href="r.watershed.html">r.watershed</a>. The vector
-output also contains points at the location of the start of a stream
-segment, at confluences and at stream network outlet locations.
-<p>
-<h2>EXAMPLE</h2>
-This example is based on the elevation map <em>elevation.10m</em> in the
-sample dataset spearfish60 and uses valleys determined with
-<a href="r.param.scale.html">r.param.scale</a> to weigh an accumulation
-map produced with <a href="r.watershed.html">r.watershed</a>.
-<pre>
-# set region
-g.region -p rast=elevation.10m at PERMANENT
-# calculate flow accumulation
-r.watershed ele=elevation.10m at PERMANENT acc=elevation.10m.acc -f
-# curvature to get narrow valleys
-r.param.scale input="elevation.10m at PERMANENT" output="tangential_curv_5" size=5 param=crosc
-# curvature to get a bit broader valleys
-r.param.scale input="elevation.10m at PERMANENT" output="tangential_curv_7" size=7 param=crosc
-# curvature to get broad valleys
-r.param.scale input="elevation.10m at PERMANENT" output="tangential_curv_11" size=11 param=crosc
-# create weight map
-r.mapcalc "weight = if(tangential_curv_5 < 0, -100 * tangential_curv_5, \
-                    if(tangential_curv_7 < 0, -100 * tangential_curv_7, \
-		    if(tangential_curv_11 < 0, -100 * tangential_curv_11, 0.000001)))"
-# weigh accumulation map
-r.mapcalc "elevation.10m.acc.weighed = elevation.10m.acc * weight"
-# copy color table from original accumulation map
-r.colors map=elevation.10m.acc.weighed raster=elevation.10m.acc
-</pre>
-Display both the original and the weighed accumulation map.
-<br>
-Compare them and proceed if the weighed accumulation map makes sense.
-<pre>
-# extract streams
-r.stream.extract elevation=elevation.10m at PERMANENT \
-                 accumulation=elevation.10m.acc.weighed \
-		 threshold=1000 \
-		 stream_rast=elevation.10m.streams
-# extract streams using the original accumulation map
-                 accumulation=elevation.10m.acc \
-		 threshold=1000 \
-		 stream_rast=elevation.10m.streams.noweight
-</pre>
-Now display both stream maps and decide which one is more realistic.
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.param.scale.html">r.param.scale</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.thin.html">r.thin</a>,
-<a href="r.to.vect.html">r.to.vect</a>
-</em>
-<h2>REFERENCES</h2>
-Ehlschlaeger, C. (1989). <i>Using the A<sup>T</sup> Search Algorithm
-to Develop Hydrologic Models from Digital Elevation Data</i>,
-<b>Proceedings of International Geographic Information Systems (IGIS)
-Symposium '89</b>, pp 275-281 (Baltimore, MD, 18-19 March 1989).<br>
-URL: <a href="http://faculty.wiu.edu/CR-Ehlschlaeger2/older/IGIS/paper.html">
-http://faculty.wiu.edu/CR-Ehlschlaeger2/older/IGIS/paper.html</a>
-<p>
-Holmgren, P. (1994). <i>Multiple flow direction algorithms for runoff
-modelling in grid based elevation models: An empirical evaluation.</i>
-<b>Hydrological Processes</b> Vol 8(4), pp 327-334.<br>
-DOI: <a href="http://dx.doi.org/10.1002/hyp.3360080405">10.1002/hyp.3360080405</a>
-<p>
-Montgomery, D.R., Foufoula-Georgiou, E. (1993). <i>Channel network source
-representation using digital elevation models.</i>
-<b>Water Resources Research</b> Vol 29(12), pp 3925-3934.
-<h2>AUTHOR</h2>
-Markus Metz
-<p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/raster/r.hydrodem/streams.c
--- grass-addons/grass7/raster/r.hydrodem/streams.c	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/streams.c	2012-01-09 17:41:56 UTC (rev 50109)
@@ -1,730 +0,0 @@
-#include <stdlib.h>
-#include <math.h>
-#include <grass/raster.h>
-#include <grass/glocale.h>
-#include "local_proto.h"
-double mfd_pow(double base)
-    int i;
-    double result = base;
-    for (i = 2; i <= c_fac; i++) {
-	result *= base;
-    return result;
-int continue_stream(CELL stream_id, int r, int c, int r_max, int c_max,
-		    int *stream_no)
-    char aspect;
-    CELL curr_stream, stream_nbr, old_stream;
-    int r_nbr, c_nbr;
-    int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
-    int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
-    int stream_node_step = 1000;
-    char this_flag_value;
-    G_debug(3, "continue stream");
-    cseg_get(&stream, &curr_stream, r_max, c_max);
-    if (curr_stream <= 0) {
-	/* no confluence, just continue */
-	G_debug(3, "no confluence, just continue stream");
-	curr_stream = stream_id;
-	cseg_put(&stream, &curr_stream, r_max, c_max);
-	bseg_get(&bitflags, &this_flag_value, r_max, c_max);
-	FLAG_SET(this_flag_value, STREAMFLAG);
-	bseg_put(&bitflags, &this_flag_value, r_max, c_max);
-	return 0;
-    G_debug(3, "confluence");
-    /* new confluence */
-    if (stream_node[curr_stream].r != r_max ||
-	stream_node[curr_stream].c != c_max) {
-	size_t new_size;
-	G_debug(3, "new confluence");
-	/* set new stream id */
-	(*stream_no)++;
-	/* add stream node */
-	if (*stream_no >= n_alloc_nodes - 1) {
-	    n_alloc_nodes += stream_node_step;
-	    stream_node =
-		(struct snode *)G_realloc(stream_node,
-					  n_alloc_nodes *
-					  sizeof(struct snode));
-	stream_node[*stream_no].r = r_max;
-	stream_node[*stream_no].c = c_max;
-	stream_node[*stream_no].id = *stream_no;
-	stream_node[*stream_no].n_trib = 0;
-	stream_node[*stream_no].n_trib_total = 0;
-	stream_node[*stream_no].n_alloc = 0;
-	stream_node[*stream_no].trib = NULL;
-	n_stream_nodes++;
-	/* debug */
-	if (n_stream_nodes != *stream_no)
-	    G_warning(_("BUG: stream_no %d and n_stream_nodes %d out of sync"),
-		      *stream_no, n_stream_nodes);
-	stream_node[*stream_no].n_alloc += 2;
-	new_size = stream_node[*stream_no].n_alloc * sizeof(int);
-	    (int *)G_realloc(stream_node[*stream_no].trib, new_size);
-	/* add the two tributaries */
-	G_debug(3, "add tributaries");
-	stream_node[*stream_no].trib[stream_node[*stream_no].n_trib++] =
-	    curr_stream;
-	    stream_id;
-	/* update stream IDs downstream */
-	G_debug(3, "update stream IDs downstream");
-	r_nbr = r_max;
-	c_nbr = c_max;
-	old_stream = curr_stream;
-	curr_stream = *stream_no;
-	cseg_put(&stream, &curr_stream, r_nbr, c_nbr);
-	bseg_get(&asp, &aspect, r_nbr, c_nbr);
-	while (aspect > 0) {
-	    r_nbr = r_nbr + asp_r[(int)aspect];
-	    c_nbr = c_nbr + asp_c[(int)aspect];
-	    cseg_get(&stream, &stream_nbr, r_nbr, c_nbr);
-	    if (stream_nbr != old_stream)
-		aspect = -1;
-	    else {
-    else {
-	/* stream node already existing here */
-	G_debug(3, "existing confluence");
-	/* add new tributary to stream node */
-	if (stream_node[curr_stream].n_trib >=
-	    stream_node[curr_stream].n_alloc) {
-	    size_t new_size;
-	    stream_node[curr_stream].n_alloc += 2;
-	    new_size = stream_node[curr_stream].n_alloc * sizeof(int);
-	    stream_node[curr_stream].trib =
-		(int *)G_realloc(stream_node[curr_stream].trib, new_size);
-	stream_node[curr_stream].trib[stream_node[curr_stream].n_trib++] =
-	    stream_id;
-    G_debug(3, "%d tribs", stream_node[curr_stream].n_trib);
-    if (stream_node[curr_stream].n_trib == 1)
-	G_warning(_("BUG: stream node %d has only 1 tributary: %d"), curr_stream,
-		  stream_node[curr_stream].trib[0]);
-    return 1;
- * accumulate surface flow
-int do_accum(double d8cut)
-    int r, c, dr, dc;
-    CELL ele_val, *ele_nbr;
-    DCELL value, *wat_nbr;
-    struct Cell_head window;
-    int mfd_cells, astar_not_set;
-    double *dist_to_nbr, *weight, sum_weight, max_weight;
-    double dx, dy;
-    int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side;
-    int is_worked;
-    char aspect;
-    double max_acc, prop;
-    int edge;
-    int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
-    int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
-    unsigned int workedon, killer, count;
-    char *flag_nbr, this_flag_value;
-    POINT astarpoint;
-    WAT_ALT wa;
-    G_message(_("Calculate flow accumulation..."));
-    /* distances to neighbours */
-    dist_to_nbr = (double *)G_malloc(sides * sizeof(double));
-    weight = (double *)G_malloc(sides * sizeof(double));
-    flag_nbr = (char *)G_malloc(sides * sizeof(char));
-    wat_nbr = (DCELL *)G_malloc(sides * sizeof(DCELL));
-    ele_nbr = (CELL *)G_malloc(sides * sizeof(CELL));
-    G_get_set_window(&window);
-	r_nbr = nextdr[ct_dir];
-	c_nbr = nextdc[ct_dir];
-	/* account for rare cases when ns_res != ew_res */
-	dy = abs(r_nbr) * window.ns_res;
-	dx = abs(c_nbr) * window.ew_res;
-	if (ct_dir < 4)
-	    dist_to_nbr[ct_dir] = dx + dy;
-	else
-	    dist_to_nbr[ct_dir] = sqrt(dx * dx + dy * dy);
-    /* distribute and accumulate */
-    count = 0;
-    for (killer = 0; killer < n_points; killer++) {
-	G_percent(killer, n_points, 1);
-	seg_get(&astar_pts, (char *)&astarpoint, 0, killer);
-	r = astarpoint.r;
-	c = astarpoint.c;
-	bseg_get(&asp, &aspect, r, c);
-	/* do not distribute flow along edges or out of real depressions */
-	if (aspect <= 0) {
-	    bseg_get(&bitflags, &this_flag_value, r, c);
-	    FLAG_UNSET(this_flag_value, WORKEDFLAG);
-	    bseg_put(&bitflags, &this_flag_value, r, c);
-	    continue;
-	if (aspect) {
-	    dr = r + asp_r[abs((int)aspect)];
-	    dc = c + asp_c[abs((int)aspect)];
-	r_max = dr;
-	c_max = dc;
-	value = wa.wat;
-	/* WORKEDFLAG has been set during A* Search
-	 * reversed meaning here: 0 = done, 1 = not yet done */
-	/*  get weights for flow distribution  */
-	max_weight = 0;
-	sum_weight = 0;
-	np_side = -1;
-	mfd_cells = 0;
-	astar_not_set = 1;
-	ele_val = wa.ele;
-	edge = 0;
-	/* this loop is needed to get the sum of weights */
-	    /* get r_nbr, c_nbr for neighbours */
-	    weight[ct_dir] = -1;
-	    wat_nbr[ct_dir] = 0;
-	    ele_nbr[ct_dir] = 0;
-	    /* check that neighbour is within region */
-	    if (r_nbr >= 0 && r_nbr < nrows && c_nbr >= 0 && c_nbr < ncols) {
-		bseg_get(&bitflags, &flag_nbr[ct_dir], r_nbr, c_nbr);
-		if ((edge = FLAG_GET(flag_nbr[ct_dir], NULLFLAG)))
-		    break;
-		seg_get(&watalt, (char *)&wa, r_nbr, c_nbr);
-		wat_nbr[ct_dir] = wa.wat;
-		ele_nbr[ct_dir] = wa.ele;
-		is_worked = FLAG_GET(flag_nbr[ct_dir], WORKEDFLAG) == 0;
-		if (is_worked == 0) {
-		    if (ele_nbr[ct_dir] <= ele_val) {
-			if (ele_nbr[ct_dir] < ele_val) {
-			    weight[ct_dir] =
-				mfd_pow((ele_val -
-					 ele_nbr[ct_dir]) / dist_to_nbr[ct_dir]);
-			if (ele_nbr[ct_dir] == ele_val) {
-			    weight[ct_dir] =
-				mfd_pow(0.5 / dist_to_nbr[ct_dir]);
-			sum_weight += weight[ct_dir];
-			mfd_cells++;
-			if (weight[ct_dir] > max_weight) {
-			    max_weight = weight[ct_dir];
-			if (dr == r_nbr && dc == c_nbr) {
-			    astar_not_set = 0;
-		    np_side = ct_dir;
-	    else
-		edge = 1;
-	    if (edge)
-		break;
-	/* do not distribute flow along edges, this causes artifacts */
-	if (edge) {
-	    G_debug(3, "edge");
-	    continue;
-	/* honour A * path
-	 * mfd_cells == 0: fine, SFD along A * path
-	 * mfd_cells == 1 && astar_not_set == 0: fine, SFD along A * path
-	 * mfd_cells > 0 && astar_not_set == 1: A * path not included, add to mfd_cells
-	/*  distribute and accumulate flow  */
-	/* MFD, A * path not included, add to mfd_cells */
-	if (mfd_cells > 0 && astar_not_set == 1) {
-	    mfd_cells++;
-	    sum_weight += max_weight;
-	    weight[np_side] = max_weight;
-	/* use SFD (D8) if d8cut threshold exceeded */
-	if (fabs(value) > d8cut)
-	    mfd_cells = 0;
-	max_acc = -1;
-	if (mfd_cells > 1) {
-	    prop = 0.0;
-		    c_nbr < ncols && weight[ct_dir] > -0.5) {
-			weight[ct_dir] = weight[ct_dir] / sum_weight;
-			/* check everything sums up to 1.0 */
-			prop += weight[ct_dir];
-			wa.wat = wat_nbr[ct_dir] + value * weight[ct_dir];
-			wa.ele = ele_nbr[ct_dir];
-			seg_put(&watalt, (char *)&wa, r_nbr, c_nbr);
-		    else if (ct_dir == np_side) {
-			/* check for consistency with A * path */
-			workedon++;
-	    if (fabs(prop - 1.0) > 5E-6f) {
-		G_warning(_("MFD: cumulative proportion of flow distribution not 1.0 but %f"),
-			  prop);
-	/* get out of depression in SFD mode */
-	else {
-	    wa.wat = wat_nbr[np_side] + value;
-	    wa.ele = ele_nbr[np_side];
-	    seg_put(&watalt, (char *)&wa, dr, dc);
-    G_percent(1, 1, 2);
-    G_free(dist_to_nbr);
-    G_free(weight);
-    G_free(wat_nbr);
-    G_free(ele_nbr);
-    G_free(flag_nbr);
-    return 1;
- * extracts streams for threshold, accumulation is provided
-int extract_streams(double threshold, double mont_exp, int min_length, int internal_acc)
-    int r, c, dr, dc;
-    CELL is_swale, ele_val, *ele_nbr;
-    DCELL value, valued, *wat_nbr;
-    int mfd_cells, stream_cells, swale_cells, astar_not_set;
-    double *dist_to_nbr;
-    double dx, dy;
-    int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side, max_side;
-    int is_worked;
-    char aspect;
-    double max_acc;
-    int edge, flat;
-    /* sides */
-     *  | 7 | 1 | 4 |
-     *  | 2 |   | 3 |
-     *  | 5 | 0 | 6 |
-    int stream_no = 0, stream_node_step = 1000;
-    double slope, diag;
-    POINT astarpoint;
-    WAT_ALT wa;
-    G_message(_("Extract streams..."));
-    /* init stream nodes */
-    n_alloc_nodes = stream_node_step;
-    stream_node =
-	(struct snode *)G_malloc(n_alloc_nodes * sizeof(struct snode));
-    n_stream_nodes = 0;
-    /* init outlet nodes */
-    n_alloc_outlets = stream_node_step;
-    outlets =
-	(POINT *)G_malloc(n_alloc_outlets * sizeof(POINT));
-    n_outlets = 0;
-	if (ct_dir < 4)
-	else
-    diag = sqrt(2);
-    workedon = 0;
-    count = 0;
-	r = astarpoint.r;
-	c = astarpoint.c;
-	/* internal acc: SET, external acc: UNSET */
-	if (internal_acc)
-	    FLAG_SET(this_flag_value, WORKEDFLAG);
-	else
-	/* do not distribute flow along edges */
-	    is_swale = FLAG_GET(this_flag_value, STREAMFLAG);
-	    if (is_swale) {
-		G_debug(2, "edge outlet");
-		/* add outlet point */
-		if (n_outlets >= n_alloc_outlets) {
-		    n_alloc_outlets += stream_node_step;
-		    outlets =
-			(POINT *)G_realloc(outlets,
-						  n_alloc_outlets *
-						  sizeof(POINT));
-		outlets[n_outlets].r = r;
-		outlets[n_outlets].c = c;
-		n_outlets++;
-	    if (aspect == 0) {
-		/* can only happen with real depressions */
-		if (!have_depressions)
-		    G_fatal_error(_("Bug in stream extraction"));
-		G_debug(2, "bottom of real depression");
-	    continue;
-	if (aspect) {
-	else {
-	    /* can only happen with real depressions,
-	     * but should not get to here */
-	    dr = r;
-	    dc = c;
-	r_nbr = r_max = dr;
-	c_nbr = c_max = dc;
-	value = wa.wat;
-	/*  find main drainage direction  */
-	max_acc = -1;
-	max_side = np_side = -1;
-	mfd_cells = 0;
-	stream_cells = 0;
-	swale_cells = 0;
-	ele_val = wa.ele;
-	edge = 0;
-	flat = 1;
-	    flag_nbr[ct_dir] = 0;
-		    np_side = ct_dir;
-		    break;
-		/* check for swale cells */
-		is_swale = FLAG_GET(flag_nbr[ct_dir], STREAMFLAG);
-		if (is_swale)
-		    swale_cells++;
-		/* check for stream cells */
-		valued = fabs(wat_nbr[ct_dir]);
-		/* check all upstream neighbours */
-		if (valued >= threshold && ct_dir != np_side &&
-		    ele_nbr[ct_dir] > ele_val)
-		    stream_cells++;
-		is_worked = FLAG_GET(flag_nbr[ct_dir], WORKEDFLAG);
-		if (!internal_acc)
-		    is_worked = is_worked == 0;
-		    if (ele_nbr[ct_dir] != ele_val)
-			flat = 0;
-			mfd_cells++;
-			/* set main drainage direction */
-			if (valued >= max_acc) {
-			    max_acc = valued;
-			    r_max = r_nbr;
-			    c_max = c_nbr;
-			    max_side = ct_dir;
-		else if (ct_dir == np_side && !edge) {
-		    workedon++;
-	    else
-		edge = 1;
-	    if (edge)
-		break;
-	/* do not continue streams along edges, these are artifacts */
-	if (edge) {
-	    if (is_swale) {
-		    outlets =
-						  n_alloc_outlets *
-						  sizeof(POINT));
-		n_outlets++;
-		if (aspect > 0) {
-		    aspect = -1 * drain[r - r_nbr + 1][c - c_nbr + 1];
-		    bseg_put(&asp, &aspect, r, c);
-	    continue;
-	if (np_side < 0)
-	    G_fatal_error("np_side < 0");
-	/* set main drainage direction to A* path if possible */
-	if (mfd_cells > 0 && max_side != np_side) {
-	    if (fabs(wat_nbr[np_side] >= max_acc)) {
-		max_acc = fabs(wat_nbr[np_side]);
-		r_max = dr;
-		c_max = dc;
-		max_side = np_side;
-	if (mfd_cells == 0) {
-	    flat = 0;
-	    r_max = dr;
-	    c_max = dc;
-	/* update aspect */
-	/* r_max == r && c_max == c should not happen */
-	if ((r_max != dr || c_max != dc) && (r_max != r || c_max != c)) {
-	    aspect = drain[r - r_max + 1][c - c_max + 1];
-	/*  start new stream  */
-	/* Montgomery's stream initiation acc * (tan(slope))^mont_exp */
-	/* uses whatever unit is accumulation */
-	if (mont_exp > 0) {
-	    if (r_max == r && c_max == c)
-		G_warning
-		    (_("Can't use Montgomery's method, no stream direction found"));
-	    else {
-		slope = (double)(ele_val - ele_nbr[max_side]) / ele_scale;
-		if (max_side > 3)
-		    slope /= diag;
-		value *= pow(fabs(slope), mont_exp);
-	if (!is_swale && fabs(value) >= threshold && stream_cells < 1 &&
-	    swale_cells < 1 && !flat) {
-	    G_debug(2, "start new stream");
-	    is_swale = ++stream_no;
-	    cseg_put(&stream, &is_swale, r, c);
-	    if (stream_no >= n_alloc_nodes - 1) {
-		stream_node =
-					      n_alloc_nodes *
-	    stream_node[stream_no].r = r;
-	    stream_node[stream_no].c = c;
-	    stream_node[stream_no].id = stream_no;
-	    stream_node[stream_no].n_trib = 0;
-	    stream_node[stream_no].n_trib_total = 0;
-	    stream_node[stream_no].n_alloc = 0;
-	    stream_node[stream_no].trib = NULL;
-	    n_stream_nodes++;
-	    /* debug */
-	    if (n_stream_nodes != stream_no)
-			  stream_no, n_stream_nodes);
-	/*  continue stream  */
-	if (is_swale > 0) {
-	    cseg_get(&stream, &is_swale, r, c);
-	    if (r_max == r && c_max == c) {
-		/* can't continue stream, add outlet point
-		 * r_max == r && c_max == c should not happen */
-		G_debug(1, "can't continue stream at r %d c %d", r, c);
-		    outlets =
-						 sizeof(POINT));
-		n_outlets++;
-	    else {
-		continue_stream(is_swale, r, c, r_max, c_max,
-				&stream_no);
-    if (workedon)
-	G_warning(_("MFD: A * path already processed when setting drainage direction: %d of %d cells"),
-		  workedon, n_points);
-    G_free(wat_nbr);
-    G_free(ele_nbr);
-    G_free(flag_nbr);
-    G_debug(1, "%d outlets", n_outlets);
-    G_debug(1, "%d nodes", n_stream_nodes);
-    G_debug(1, "%d streams", stream_no);
-    return 1;
Deleted: grass-addons/grass7/raster/r.hydrodem/thin.c
--- grass-addons/grass7/raster/r.hydrodem/thin.c	2012-01-09 17:37:16 UTC (rev 50108)
+++ grass-addons/grass7/raster/r.hydrodem/thin.c	2012-01-09 17:41:56 UTC (rev 50109)
@@ -1,172 +0,0 @@
-#include <grass/gis.h>
-int thin_seg(int stream_id)
-    int thinned = 0;
-    int r, c, r_nbr, c_nbr, last_r, last_c;
-    CELL curr_stream, no_stream = 0;
-    char flag_value, aspect;
-    r = stream_node[stream_id].r;
-    c = stream_node[stream_id].c;
-    cseg_get(&stream, &curr_stream, r, c);
-    if (aspect > 0) {
-	/* get downstream point */
-	last_r = r + asp_r[(int)aspect];
-	last_c = c + asp_c[(int)aspect];
-	cseg_get(&stream, &curr_stream, last_r, last_c);
-	if (curr_stream != stream_id)
-	    return thinned;
-	/* get next downstream point */
-	bseg_get(&asp, &aspect, last_r, last_c);
-	    r_nbr = last_r + asp_r[(int)aspect];
-	    c_nbr = last_c + asp_c[(int)aspect];
-	    if (r_nbr == last_r && c_nbr == last_c)
-		return thinned;
-	    if (r_nbr < 0 || r_nbr >= nrows || c_nbr < 0 || c_nbr >= ncols)
-		return thinned;
-	    cseg_get(&stream, &curr_stream, r_nbr, c_nbr);
-		return thinned;
-	    if (abs(r_nbr - r) < 2 && abs(c_nbr - c) < 2) {
-		/* eliminate last point */
-		cseg_put(&stream, &no_stream, last_r, last_c);
-		bseg_get(&bitflags, &flag_value, last_r, last_c);
-		FLAG_UNSET(flag_value, STREAMFLAG);
-		bseg_put(&bitflags, &flag_value, last_r, last_c);
-		/* update start point */
-		aspect = drain[r - r_nbr + 1][c - c_nbr + 1];
-		thinned = 1;
-	    else {
-		/* nothing to eliminate, continue from last point */
-		r = last_r;
-		c = last_c;
-	    last_r = r_nbr;
-	    last_c = c_nbr;
-    return thinned;
-    int i, j, r, c, done;
-    CELL stream_id;
-    int next_node;
-    struct sstack
-	int stream_id;
-	int next_trib;
-    } *nodestack;
-    int top = 0, stack_step = 1000;
-    int n_trib_total;
-    int n_thinned = 0;
-    G_message(_("Thin stream segments..."));
-    nodestack = (struct sstack *)G_malloc(stack_step * sizeof(struct sstack));
-    for (i = 0; i < n_outlets; i++) {
-	G_percent(i, n_outlets, 2);
-	r = outlets[i].r;
-	c = outlets[i].c;
-	cseg_get(&stream, &stream_id, r, c);
-	if (stream_id == 0)
-	    continue;
-	/* add root node to stack */
-	G_debug(2, "add root node");
-	top = 0;
-	nodestack[top].stream_id = stream_id;
-	nodestack[top].next_trib = 0;
-	/* depth first post order traversal */
-	G_debug(2, "traverse");
-	while (top >= 0) {
-	    done = 1;
-	    stream_id = nodestack[top].stream_id;
-	    G_debug(3, "stream_id %d, top %d", stream_id, top);
-	    if (nodestack[top].next_trib < stream_node[stream_id].n_trib) {
-		/* add to stack */
-		G_debug(3, "get next node");
-		next_node =
-		    stream_node[stream_id].trib[nodestack[top].next_trib];
-		G_debug(3, "add to stack: next %d, trib %d, n trib %d",
-			next_node, nodestack[top].next_trib,
-			stream_node[stream_id].n_trib);
-		nodestack[top].next_trib++;
-		top++;
-		if (top >= stack_step) {
-		    /* need more space */
-		    stack_step += 1000;
-		    nodestack =
-			(struct sstack *)G_realloc(nodestack,
-						   stack_step *
-						   sizeof(struct sstack));
-		nodestack[top].stream_id = next_node;
-		done = 0;
-		G_debug(3, "go further down");
-	    if (done) {
-		/* thin stream segment */
-		G_debug(3, "thin stream segment %d", stream_id);
-		if (thin_seg(stream_id) == 0)
-		    G_debug(3, "segment %d not thinned", stream_id);
-		else {
-		    G_debug(3, "segment %d thinned", stream_id);
-		    n_thinned++;
-		top--;
-		/* count tributaries */
-		if (top >= 0) {
-		    n_trib_total = 0;
-		    for (j = 0; j < stream_node[stream_id].n_trib; j++) {
-			/* intermediate */
-			if (stream_node[stream_node[stream_id].trib[j]].
-			    n_trib > 0)
-			    n_trib_total +=
-				stream_node[stream_node[stream_id].trib[j]].
-				n_trib_total;
-			/* start */
-			else
-			    n_trib_total++;
-		    stream_node[stream_id].n_trib_total = n_trib_total;
-    G_percent(n_outlets, n_outlets, 1);	/* finish it */
-    G_free(nodestack);
-    G_verbose_message(_("%d of %d stream segments were thinned"), n_thinned, n_stream_nodes);
-    return 1;
