[GRASS-SVN] r50111 - in grass/trunk/gui/wxpython: gui_core psmap
Mon Jan 9 15:09:01 EST 2012
Author: annakrat
Date: 2012-01-09 12:09:01 -0800 (Mon, 09 Jan 2012)
New Revision: 50111
   grass/trunk/gui/wxpython/gui_core/dialogs.py
   grass/trunk/gui/wxpython/gui_core/forms.py
   grass/trunk/gui/wxpython/gui_core/widgets.py
   grass/trunk/gui/wxpython/psmap/dialogs.py
wxGUI/wxpsmap bug #1531 fixed
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2012-01-09 17:45:28 UTC (rev 50110)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2012-01-09 20:09:01 UTC (rev 50111)
@@ -39,6 +39,10 @@
 import wx
 import wx.lib.filebrowsebutton as filebrowse
 import wx.lib.mixins.listctrl as listmix
+try:
+    from wx.lib.buttons import ThemedGenBitmapToggleButton as BTButton
+except ImportError: # not sure about TGBTButton version
+    from wx.lib.buttons import GenBitmapToggleButton as BTButton
 from grass.script import core as grass
 from grass.script import task as gtask
@@ -47,6 +51,7 @@
 from core.gcmd        import GError, RunCommand, GMessage
 from gui_core.gselect import ElementSelect, LocationSelect, MapsetSelect, Select, OgrTypeSelect, GdalSelect, MapsetSelect
 from gui_core.forms   import GUI
+from gui_core.widgets import SingleSymbolPanel, EVT_SYMBOL_SELECTION_CHANGED
 from core.utils       import GetListOfMapsets, GetLayerNameFromCmd, GetValidLayerName
 from core.settings    import UserSettings
 from core.debug       import Debug
@@ -2382,3 +2387,160 @@
         """!Close window
         self.Close()
+class SymbolDialog(wx.Dialog):
+    """!Dialog for GRASS symbols selection.
+    Dialog is called in gui_core::forms module.
+    def __init__(self, parent, symbolPath, currentSymbol = None, title = _("Symbols")):
+        """!Dialog constructor.
+        It is assumed that symbolPath contains folders with symbols.
+        @param parent dialog parent
+        @param symbolPath absolute path to symbols
+        @param currentSymbol currently selected symbol (e.g. 'basic/x')
+        @param title dialog title
+        wx.Dialog.__init__(self, parent = parent, title = title, id = wx.ID_ANY)
+        self.symbolPath = symbolPath
+        self.currentSymbol = currentSymbol # default basic/x
+        self.selected = None
+        self._layout()
+    def _layout(self):
+        mainPanel = wx.Panel(self, id = wx.ID_ANY)
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
+        staticBox = wx.StaticBox(parent = mainPanel, id = wx.ID_ANY,
+                                 label = " %s " % _("Symbol selection"))
+        self.staticSizer = wx.StaticBoxSizer(staticBox, wx.VERTICAL)
+        hSizer = wx.BoxSizer(wx.HORIZONTAL)
+        self.folderChoice = wx.Choice(mainPanel, id = wx.ID_ANY, choices = os.listdir(self.symbolPath))
+        self.folderChoice.Bind(wx.EVT_CHOICE, self.OnFolderSelect)
+        self.staticSizer.Add(self.folderChoice, proportion = 0,
+                             flag = wx.ALL, border = 5)
+        self.panels = self._createSymbolPanels(mainPanel)
+        for panel in self.panels:
+            self.staticSizer.Add(panel, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
+            panel.Bind(EVT_SYMBOL_SELECTION_CHANGED, self.SelectionChanged)
+        self.infoLabel = wx.StaticText(mainPanel, id = wx.ID_ANY)
+        self.staticSizer.Add(self.infoLabel, proportion = 0,
+                             flag = wx.ALL | wx.ALIGN_CENTRE_VERTICAL, border = 5)
+        mainSizer.Add(self.staticSizer, proportion = 1, flag = wx.ALL| wx.EXPAND, border = 5)
+        self.btnCancel = wx.Button(parent = mainPanel, id = wx.ID_CANCEL)
+        self.btnOK     = wx.Button(parent = mainPanel, id = wx.ID_OK)
+        self.btnOK.SetDefault()
+        self.btnOK.Enable(False)
+        # buttons
+        btnSizer = wx.StdDialogButtonSizer()
+        btnSizer.AddButton(self.btnCancel)
+        btnSizer.AddButton(self.btnOK)
+        btnSizer.Realize()
+        mainSizer.Add(item = btnSizer, proportion = 0,
+                      flag = wx.EXPAND | wx.ALL, border = 5)
+        # show panel with the largest number of images and fit size
+        count = []
+        for folder in os.listdir(self.symbolPath):
+            count.append(len(os.listdir(os.path.join(self.symbolPath, folder))))
+        index = count.index(max(count))
+        self.folderChoice.SetSelection(index)
+        self.OnFolderSelect(None)
+        mainPanel.SetSizerAndFit(mainSizer)
+        self.SetSize(self.GetBestSize())
+        # show currently selected symbol
+        if self.currentSymbol:
+            selected = os.path.split(self.currentSymbol)[0]
+            self.folderChoice.SetStringSelection(selected)
+        else:
+            self.folderChoice.SetSelection(0)
+    def _createSymbolPanels(self, parent):
+        """!Creates multiple panels with symbols.
+        Panels are shown/hidden according to selected folder."""
+        folders = os.listdir(self.symbolPath)
+        self.panels = []
+        self.symbolPanels = []
+        maxImages = 0
+        for folder in folders:
+            panel = wx.Panel(parent)
+            sizer = wx.GridSizer(cols = 6, vgap = 3, hgap = 3)
+            images = self._getSymbols(path = os.path.join(self.symbolPath, folder))
+            symbolPanels = []
+            for img in images:
+                btn = BTButton(parent = panel, id = wx.ID_ANY, bitmap = wx.Bitmap(img), name = img)
+                #iP = SingleSymbolPanel(parent = panel, symbolPath = img)
+                sizer.Add(item = btn, proportion = 0, flag = wx.ALL, border = 0)
+                symbolPanels.append(btn)
+            panel.SetSizerAndFit(sizer)
+            panel.Hide()
+            self.panels.append(panel)
+            self.symbolPanels.append(symbolPanels)
+        return self.panels
+    def _getSymbols(self, path):
+        # we assume that images are in subfolders (1 level only)
+        imageList = []
+        for image in os.listdir(path):
+            imageList.append(os.path.join(path, image))
+        return sorted(imageList)
+    def OnFolderSelect(self, event):
+        """!Selected folder with symbols changed."""
+        idx = self.folderChoice.GetSelection()
+        for i in range(len(self.panels)):
+            sizer = self.panels[i].GetContainingSizer()
+            sizer.Show(self.panels[i], i == idx, recursive = True)
+            sizer.Layout()
+        self.infoLabel.SetLabel('')
+        self.btnOK.Disable()
+    def SelectionChanged(self, event):
+        """!Selected symbol changed."""
+        if event.doubleClick:
+            self.EndModal(wx.ID_OK)
+        # deselect all
+            for panel in self.symbolPanels[i]:
+                if panel.GetName() != event.name:
+                    panel.Deselect()
+        self.btnOK.Enable()
+        self.selected = os.path.join(self.folderChoice.GetStringSelection(), event.name)
+        self.infoLabel.SetLabel(event.name)
+    def GetSelectedSymbol(self, fullPath = False):
+        """!Returns currently selected symbol.
+        @param fullPath true to return absolute path to symbol,
+        otherwise returns e.g. 'basic/x'
+        if fullPath:
+            return os.path.join(self.symbolPath, self.selected)
+        return self.selected
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py	2012-01-09 17:45:28 UTC (rev 50110)
+++ grass/trunk/gui/wxpython/gui_core/forms.py	2012-01-09 20:09:01 UTC (rev 50111)
@@ -92,6 +92,7 @@
 from gui_core.widgets import FloatValidator, GNotebook
 wxUpdateDialog, EVT_DIALOG_UPDATE = NewEvent()
 # From lib/gis/col_str.c, except purple which is mentioned
@@ -152,6 +153,10 @@
     """!Escapes ampersands with additional ampersand for GUI"""
     return string.replace(text, "&", "&&")
+def symbolPath():
+    """!Returnes absolute path to symbols"""
+    return "/home/anna/Desktop/symbols"
 class UpdateThread(Thread):
     """!Update dialog widgets in the thread"""
     def __init__(self, parent, event, eventId, task):
@@ -1034,19 +1039,38 @@
                         p['wxId'] = [ txt2.GetId(), ]
                         txt2.Bind(wx.EVT_TEXT, self.OnSetValue)
                     else:
-                        # list of values (combo)
                         title_txt.SetLabel(title + ':')
-                        cb = wx.ComboBox(parent = which_panel, id = wx.ID_ANY, value = p.get('default',''),
-                                         size = globalvar.DIALOG_COMBOBOX_SIZE,
-                                         choices = valuelist, style = wx.CB_DROPDOWN)
                         value = self._getValue(p)
-                        if value:
-                            cb.SetValue(value) # parameter previously set
-                        which_sizer.Add(item = cb, proportion = 0,
-                                        flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border = 5)
-                        p['wxId'] = [cb.GetId(),]
-                        cb.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
-                        cb.Bind(wx.EVT_TEXT, self.OnSetValue)
+                        if p['name'] == 'icon': # symbols
+                            bitmap = wx.Bitmap(os.path.join(symbolPath(), value) + '.png')
+                            bb = wx.BitmapButton(parent = which_panel, id = wx.ID_ANY,
+                                                 bitmap = bitmap)
+                            iconLabel = wx.StaticText(parent = which_panel, id = wx.ID_ANY)
+                            iconLabel.SetLabel(value)
+                            p['value'] = value
+                            p['wxId'] = [bb.GetId(),iconLabel.GetId()]
+                            bb.Bind(wx.EVT_BUTTON, self.OnSetSymbol)
+                            this_sizer = wx.BoxSizer(wx.HORIZONTAL)
+                            this_sizer.Add(item = bb, proportion = 0,
+                                            flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border = 5)
+                            this_sizer.Add(item = iconLabel, proportion = 0,
+                                            flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT | wx.ALIGN_CENTER_VERTICAL, border = 5)
+                            which_sizer.Add(item = this_sizer, proportion = 0,
+                                            flag = wx.ADJUST_MINSIZE, border = 0)
+                        else:
+                            # list of values (combo)
+                            cb = wx.ComboBox(parent = which_panel, id = wx.ID_ANY, value = p.get('default',''),
+                                             size = globalvar.DIALOG_COMBOBOX_SIZE,
+                                             choices = valuelist, style = wx.CB_DROPDOWN)
+                            if value:
+                                cb.SetValue(value) # parameter previously set
+                            which_sizer.Add(item = cb, proportion = 0,
+                            p['wxId'] = [cb.GetId(),]
+                            cb.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
+                            cb.Bind(wx.EVT_TEXT, self.OnSetValue)
             # text entry
             if (p.get('type','string') in ('string','integer','float')
@@ -1863,6 +1887,26 @@
         event.Skip()
+    def OnSetSymbol(self, event):
+        """!Shows dialog for symbol selection"""
+        myId = event.GetId()
+        for p in self.task.params:
+            if 'wxId' in p and myId in p['wxId']:
+                from gui_core.dialogs import SymbolDialog
+                dlg = SymbolDialog(self, symbolPath = symbolPath(), currentSymbol = p['value'])
+                if dlg.ShowModal() == wx.ID_OK:
+                    img = dlg.GetSelectedSymbol(fullPath = True)
+                    bitmapButton = wx.FindWindowById(p['wxId'][0])
+                    label = wx.FindWindowById(p['wxId'][1])
+                    bitmapButton.SetBitmapLabel(wx.Bitmap(img + '.png'))
+                    p['value'] = dlg.GetSelectedSymbol(fullPath = False)
+                    label.SetLabel(p['value'])
+                    self.OnUpdateValues(event)
+                dlg.Destroy()
     def OnUpdateSelection(self, event):
         """!Update dialog (layers, tables, columns, etc.)
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py	2012-01-09 17:45:28 UTC (rev 50110)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py	2012-01-09 20:09:01 UTC (rev 50111)
@@ -25,6 +25,7 @@
 @author Anna Kratochvilova <kratochanna gmail.com> (Google SoC 2011)
+import os
 import string
 import wx
@@ -44,6 +45,8 @@
 from core        import globalvar
+from   wx.lib.newevent import NewEvent
+wxSymbolSelectionChanged, EVT_SYMBOL_SELECTION_CHANGED  = NewEvent()
 class GNotebook(FN.FlatNotebook):
     """!Generic notebook widget
@@ -409,3 +412,53 @@
             if itemSelected:
                 self.ToggleItemSelection(itemSelected)
             self.itemSelected = None
+class SingleSymbolPanel(wx.Panel):
+    """!Panel for displaying one symbol.
+    Changes background when selected. Assumes that parent will catch
+    events emitted on mouse click. Used in gui_core::dialog::SymbolDialog.
+    def __init__(self, parent, symbolPath):
+        """!Panel constructor
+        @param parent parent (gui_core::dialog::SymbolDialog)
+        wx.Panel.__init__(self, parent, id = wx.ID_ANY, style = wx.BORDER_RAISED)
+        self.SetName(os.path.splitext(os.path.basename(symbolPath))[0])
+        self.sBmp = wx.StaticBitmap(self, wx.ID_ANY, wx.Bitmap(symbolPath))
+        self.selected = False
+        self.selectionColor = wx.Colour(255, 252, 120)
+        sizer = wx.BoxSizer()
+        sizer.Add(item = self.sBmp, proportion = 0, flag = wx.ALL, border = 0)
+        self.SetBackgroundStyle(wx.BG_STYLE_SYSTEM)
+        self.SetMinSize(self.GetBestSize())
+        self.SetSizerAndFit(sizer)
+        # binding to both (staticBitmap, Panel) necessary
+        self.sBmp.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
+        self.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
+        self.Bind(wx.EVT_LEFT_DCLICK, self.OnDoubleClick)
+        self.sBmp.Bind(wx.EVT_LEFT_DCLICK, self.OnDoubleClick)
+    def OnLeftDown(self, event):
+        """!Panel selected, background changes"""
+        self.selected = True
+        self.SetBackgroundColour(self.selectionColor)
+        event.Skip()
+        event = wxSymbolSelectionChanged(name = self.GetName(), doubleClick = False)
+        wx.PostEvent(self.GetParent(), event)
+    def OnDoubleClick(self, event):
+        event = wxSymbolSelectionChanged(name = self.GetName(), doubleClick = True)
+    def Deselect(self):
+        """!Panel deselected, background changes back to default"""
+        self.SetBackgroundColour(wx.NullColor)
Modified: grass/trunk/gui/wxpython/psmap/dialogs.py
--- grass/trunk/gui/wxpython/psmap/dialogs.py	2012-01-09 17:45:28 UTC (rev 50110)
+++ grass/trunk/gui/wxpython/psmap/dialogs.py	2012-01-09 20:09:01 UTC (rev 50111)
@@ -2925,9 +2925,11 @@
         self.select = Select(self, id = wx.ID_ANY,# size = globalvar.DIALOG_GSELECT_SIZE,
                              type = 'vector', multiple = False,
                              updateOnPopup = True, onPopup = None)
-        topologyType = [_("points"), _("lines"), _("areas")]
-        self.vectorType = wx.RadioBox(self, id = wx.ID_ANY, label = " %s " % _("Data Type"), choices = topologyType,
-                                        majorDimension = 3, style = wx.RA_SPECIFY_COLS)
+        topologyTypeTr = [_("points"), _("lines"), _("areas")]
+        self.topologyTypeList = ["points", "lines", "areas"]
+        self.vectorType = wx.RadioBox(self, id = wx.ID_ANY, label = " %s " % _("Data Type"), choices = topologyTypeTr,
+                                      majorDimension = 3, style = wx.RA_SPECIFY_COLS)
         self.AddVector = wx.Button(self, id = wx.ID_ANY, label = _("Add"))
         gridBagSizer.Add(text, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
@@ -3008,16 +3010,17 @@
                 mapset = '(' + vmap.split('@')[1] + ')'
             except IndexError:
                 mapset = ''
-            type = self.vectorType.GetStringSelection()
-            record = "%s - %s" % (vmap,type)
+            idx = self.vectorType.GetSelection()
+            ttype = self.topologyTypeList[idx]
+            record = "%s - %s" % (vmap, ttype)
             id = wx.NewId()
             lpos = 1
             label = mapname + mapset
-            self.vectorList.insert(0, [vmap, type, id, lpos, label])
+            self.vectorList.insert(0, [vmap, ttype, id, lpos, label])
             self.reposition()
             self.listbox.InsertItems([record], 0)
-            vector = VProperties(id, type)
+            vector = VProperties(id, ttype)
             self.tmpDialogDict[id] = vector.GetInstruction()
             self.tmpDialogDict[id]['name'] = vmap
@@ -3224,7 +3227,7 @@
             if id == item[2]:
                 self.vectorName = item[0]
                 self.type = item[1]
-        self.SetTitle(self.vectorName + " "+ _("properties"))
+        self.SetTitle(_("%s properties") % self.vectorName)
         #vector map info
         self.connection = True
