[GRASS-SVN] r50119 - in grass/branches/releasebranch_6_4: raster/r.external raster/r.in.gdal vector/v.in.ogr
Tue Jan 10 00:34:37 EST 2012
Author: hamish
Date: 2012-01-09 21:34:37 -0800 (Mon, 09 Jan 2012)
New Revision: 50119
   grass/branches/releasebranch_6_4/raster/r.external/main.c
   grass/branches/releasebranch_6_4/raster/r.in.gdal/main.c
   grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c
Modules are only allowed to modify the current mapset. (#1507, merge r49734 and r49799 from devbr6)
Modified: grass/branches/releasebranch_6_4/raster/r.external/main.c
--- grass/branches/releasebranch_6_4/raster/r.external/main.c	2012-01-10 03:44:25 UTC (rev 50118)
+++ grass/branches/releasebranch_6_4/raster/r.external/main.c	2012-01-10 05:34:37 UTC (rev 50119)
@@ -87,7 +87,7 @@
 	/*      Does the projection of the current location match the           */
 	/*      dataset?                                                        */
-	G_get_window(&loc_wind);
+	G_get_default_window(&loc_wind);
 	if (loc_wind.proj != PROJECTION_XY) {
 	    loc_proj_info = G_get_projinfo();
 	    loc_proj_units = G_get_projunits();
@@ -237,24 +237,34 @@
     /*      Extend current window based on dataset.                         */
-    struct Cell_head def_wind;
+    struct Cell_head cur_wind;
-    G_get_default_window(&def_wind);
+    if (strcmp(G_mapset(), "PERMANENT") == 0)
+	/* fixme: expand WIND and DEFAULT_WIND independently. (currently
+	 WIND gets forgotten and DEFAULT_WIND is expanded for both) */
+	G_get_default_window(&cur_wind);
+    else
+	G_get_window(&cur_wind);
-    def_wind.north = MAX(def_wind.north, cellhd->north);
-    def_wind.south = MIN(def_wind.south, cellhd->south);
-    def_wind.west = MIN(def_wind.west, cellhd->west);
-    def_wind.east = MAX(def_wind.east, cellhd->east);
+    cur_wind.north = MAX(cur_wind.north, cellhd->north);
+    cur_wind.south = MIN(cur_wind.south, cellhd->south);
+    cur_wind.west = MIN(cur_wind.west, cellhd->west);
+    cur_wind.east = MAX(cur_wind.east, cellhd->east);
-    def_wind.rows = (int)ceil((def_wind.north - def_wind.south)
-			      / def_wind.ns_res);
-    def_wind.south = def_wind.north - def_wind.rows * def_wind.ns_res;
+    cur_wind.rows = (int)ceil((cur_wind.north - cur_wind.south)
+			      / cur_wind.ns_res);
+    cur_wind.south = cur_wind.north - cur_wind.rows * cur_wind.ns_res;
-    def_wind.cols = (int)ceil((def_wind.east - def_wind.west)
-			      / def_wind.ew_res);
-    def_wind.east = def_wind.west + def_wind.cols * def_wind.ew_res;
+    cur_wind.cols = (int)ceil((cur_wind.east - cur_wind.west)
+			      / cur_wind.ew_res);
+    cur_wind.east = cur_wind.west + cur_wind.cols * cur_wind.ew_res;
-    G__put_window(&def_wind, "../PERMANENT", "DEFAULT_WIND");
+    if (strcmp(G_mapset(), "PERMANENT") == 0) {
+	G__put_window(&cur_wind, "", "DEFAULT_WIND");
+	G_message(_("Default region for this location updated"));
+    G_put_window(&cur_wind);
+    G_message(_("Region for the current mapset updated"));
 static void query_band(GDALRasterBandH hBand, const char *output, int exact_range,
@@ -547,7 +557,9 @@
     flag_e = G_define_flag();
     flag_e->key = 'e';
-    flag_e->description = _("Extend location extents based on new dataset");
+    flag_e->label = _("Extend region extents based on new dataset");
+    flag_e->description =
+	_("Also updates the default region if in the PERMANENT mapset");
     flag_r = G_define_flag();
     flag_r->key = 'r';
Modified: grass/branches/releasebranch_6_4/raster/r.in.gdal/main.c
--- grass/branches/releasebranch_6_4/raster/r.in.gdal/main.c	2012-01-10 03:44:25 UTC (rev 50118)
+++ grass/branches/releasebranch_6_4/raster/r.in.gdal/main.c	2012-01-10 05:34:37 UTC (rev 50119)
@@ -51,7 +51,7 @@
     char *input;
     char *output;
     char *title;
-    struct Cell_head cellhd, loc_wind, def_wind;
+    struct Cell_head cellhd, loc_wind, cur_wind;
     struct Key_Value *proj_info = NULL, *proj_units = NULL;
     struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
     GDALDatasetH hDS;
@@ -135,7 +135,9 @@
     flag_e->key = 'e';
     flag_f = G_define_flag();
     flag_f->key = 'f';
@@ -343,7 +345,7 @@
 	    /*      dataset?                                                        */
@@ -358,8 +360,7 @@
 		     || (projcomp_error = G_compare_projections(loc_proj_info,
 								loc_proj_units,
 								proj_info,
-								proj_units)) <
-		     0) {
+								proj_units)) < 0) {
 		int i_value;
 		strcpy(error_msg,
@@ -595,22 +596,32 @@
     if (flag_e->answer) {
+	else
-	def_wind.north = MAX(def_wind.north, cellhd.north);
-	def_wind.south = MIN(def_wind.south, cellhd.south);
-	def_wind.west = MIN(def_wind.west, cellhd.west);
-	def_wind.east = MAX(def_wind.east, cellhd.east);
+	cur_wind.north = MAX(cur_wind.north, cellhd.north);
+	cur_wind.south = MIN(cur_wind.south, cellhd.south);
+	cur_wind.west = MIN(cur_wind.west, cellhd.west);
+	cur_wind.east = MAX(cur_wind.east, cellhd.east);
     exit(EXIT_SUCCESS);
Modified: grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c	2012-01-10 03:44:25 UTC (rev 50118)
+++ grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c	2012-01-10 05:34:37 UTC (rev 50119)
@@ -227,8 +227,10 @@
     extend_flag = G_define_flag();
     extend_flag->key = 'e';
+    extend_flag->label =
+	_("Extend region extents based on new dataset");
     extend_flag->description =
-	_("Extend location extents based on new dataset");
     tolower_flag = G_define_flag();
     tolower_flag->key = 'w';
@@ -496,7 +498,7 @@
 	/* Does the projection of the current location match the dataset? */
 	/* G_get_window seems to be unreliable if the location has been changed */
-	G__get_window(&loc_wind, "", "DEFAULT_WIND", "PERMANENT");
 	/* fetch LOCATION PROJ info */
@@ -695,30 +697,18 @@
 		/** Simple 32bit integer                     OFTInteger = 0        **/
 		/** List of 32bit integers                   OFTIntegerList = 1    **/
 		/** Double Precision floating point          OFTReal = 2           **/
 		/** List of doubles                          OFTRealList = 3       **/
 		/** String of ASCII chars                    OFTString = 4         **/
 		/** Array of strings                         OFTStringList = 5     **/
 		/** Double byte string (unsupported)         OFTWideString = 6     **/
 		/** List of wide strings (unsupported)       OFTWideStringList = 7 **/
 		/** Raw Binary data (unsupported)            OFTBinary = 8         **/
 		/**                                          OFTDate = 9           **/
 		/**                                          OFTTime = 10          **/
 		/**                                          OFTDateTime = 11      **/
 		if (Ogr_ftype == OFTInteger) {
 		    sprintf(buf, ", %s integer", Ogr_fieldname);
@@ -1186,22 +1176,32 @@
     if (extend_flag->answer) {
-	G_get_default_window(&loc_wind);
+	else
-	loc_wind.north = MAX(loc_wind.north, cellhd.north);
-	loc_wind.south = MIN(loc_wind.south, cellhd.south);
-	loc_wind.west = MIN(loc_wind.west, cellhd.west);
-	loc_wind.east = MAX(loc_wind.east, cellhd.east);
-	loc_wind.rows = (int)ceil((loc_wind.north - loc_wind.south)
-				  / loc_wind.ns_res);
-	loc_wind.south = loc_wind.north - loc_wind.rows * loc_wind.ns_res;
-	loc_wind.cols = (int)ceil((loc_wind.east - loc_wind.west)
-				  / loc_wind.ew_res);
-	loc_wind.east = loc_wind.west + loc_wind.cols * loc_wind.ew_res;
-	G__put_window(&loc_wind, "../PERMANENT", "DEFAULT_WIND");
     if (with_z && !z_flag->answer)
