[GRASS-SVN] r50125 - in grass/branches/develbranch_6: gui/wxpython/xml locale/po vector/v.vol.rst
Tue Jan 10 07:05:20 EST 2012
Author: neteler
Date: 2012-01-10 04:05:20 -0800 (Tue, 10 Jan 2012)
New Revision: 50125
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
   grass/branches/develbranch_6/locale/po/grassmods_ar.po
   grass/branches/develbranch_6/locale/po/grassmods_cs.po
   grass/branches/develbranch_6/locale/po/grassmods_de.po
   grass/branches/develbranch_6/locale/po/grassmods_el.po
   grass/branches/develbranch_6/locale/po/grassmods_es.po
   grass/branches/develbranch_6/locale/po/grassmods_fr.po
   grass/branches/develbranch_6/locale/po/grassmods_hi.po
   grass/branches/develbranch_6/locale/po/grassmods_it.po
   grass/branches/develbranch_6/locale/po/grassmods_ja.po
   grass/branches/develbranch_6/locale/po/grassmods_ko.po
   grass/branches/develbranch_6/locale/po/grassmods_lv.po
   grass/branches/develbranch_6/locale/po/grassmods_mr.po
   grass/branches/develbranch_6/locale/po/grassmods_pl.po
   grass/branches/develbranch_6/locale/po/grassmods_pt.po
   grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
   grass/branches/develbranch_6/locale/po/grassmods_ru.po
   grass/branches/develbranch_6/locale/po/grassmods_sl.po
   grass/branches/develbranch_6/locale/po/grassmods_th.po
   grass/branches/develbranch_6/locale/po/grassmods_tr.po
   grass/branches/develbranch_6/locale/po/grassmods_vi.po
   grass/branches/develbranch_6/locale/po/grassmods_zh.po
   grass/branches/develbranch_6/locale/po/grasswxpy_cs.po
   grass/branches/develbranch_6/locale/po/grasswxpy_de.po
   grass/branches/develbranch_6/locale/po/grasswxpy_el.po
   grass/branches/develbranch_6/locale/po/grasswxpy_es.po
   grass/branches/develbranch_6/locale/po/grasswxpy_fr.po
   grass/branches/develbranch_6/locale/po/grasswxpy_id.po
   grass/branches/develbranch_6/locale/po/grasswxpy_it.po
   grass/branches/develbranch_6/locale/po/grasswxpy_ja.po
   grass/branches/develbranch_6/locale/po/grasswxpy_ml.po
   grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
   grass/branches/develbranch_6/locale/po/grasswxpy_pt.po
   grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po
   grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
   grass/branches/develbranch_6/locale/po/grasswxpy_th.po
   grass/branches/develbranch_6/locale/po/grasswxpy_tr.po
   grass/branches/develbranch_6/locale/po/grasswxpy_vi.po
   grass/branches/develbranch_6/locale/po/grasswxpy_zh.po
   grass/branches/develbranch_6/vector/v.vol.rst/main.c
G3D grid volume -> 3D raster map
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2012-01-10 12:05:20 UTC (rev 50125)
@@ -2808,7 +2808,7 @@
     </menuitem>
    	<menuitem>
 	  <label>Interpolate volume from points</label>
-	  <help>Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm.</help>
+	  <help>Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm.</help>
 	  <keywords>vector,interpolation</keywords>
 	  <handler>OnMenuCmd</handler>
 	  <command>v.vol.rst</command>
Modified: grass/branches/develbranch_6/locale/po/grassmods_ar.po
--- grass/branches/develbranch_6/locale/po/grassmods_ar.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_ar.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -22853,7 +22853,7 @@
 #: ../vector/v.vol.rst/main.c:204
 msgid ""
-"Interpolates point data to a G3D grid volume using regularized spline with "
+"Interpolates point data to a 3D raster map using regularized spline with "
 "tension (RST) algorithm."
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_cs.po
--- grass/branches/develbranch_6/locale/po/grassmods_cs.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_cs.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -22990,7 +22990,7 @@
 msgid ""
 msgstr ""
 "Interpoluje bodová data do G3D volume za pou¾ití regularized spline with "
Modified: grass/branches/develbranch_6/locale/po/grassmods_de.po
--- grass/branches/develbranch_6/locale/po/grassmods_de.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_de.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -21063,7 +21063,7 @@
 msgstr "%d Elemente verarbeitet."
-msgid "Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
 msgstr "Interpoliert Punkte zu einem G3D Grid Volumen unter Verwendung des regularized spline with tension (RST) Algorithmus."
 #: ../vector/v.vol.rst/main.c:237
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -21716,7 +21716,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -23175,7 +23175,7 @@
 msgid ""
 msgstr ""
 "Interpola datos de puntos a volumen de cuadrícula G3D usando spline "
Modified: grass/branches/develbranch_6/locale/po/grassmods_fr.po
--- grass/branches/develbranch_6/locale/po/grassmods_fr.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_fr.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -24491,7 +24491,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_hi.po
--- grass/branches/develbranch_6/locale/po/grassmods_hi.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_hi.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -23375,7 +23375,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -21649,7 +21649,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ja.po
--- grass/branches/develbranch_6/locale/po/grassmods_ja.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_ja.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -21053,7 +21053,7 @@
 msgstr "%d の要素を処理しました"
 msgstr "テンション (RST) アルゴリズムの正規化スプライン曲線を使って,ポイントデータを3Dグリッドボリュームへ挿入"
Modified: grass/branches/develbranch_6/locale/po/grassmods_ko.po
--- grass/branches/develbranch_6/locale/po/grassmods_ko.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_ko.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -21930,7 +21930,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_lv.po
--- grass/branches/develbranch_6/locale/po/grassmods_lv.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_lv.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -22660,7 +22660,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_mr.po
--- grass/branches/develbranch_6/locale/po/grassmods_mr.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_mr.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -22083,7 +22083,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pl.po
--- grass/branches/develbranch_6/locale/po/grassmods_pl.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_pl.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -21437,7 +21437,7 @@
 #, fuzzy
 msgstr "Interpoluje dane punktowe do G3D za pomocÄ… algorytmu RST."
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -23680,7 +23680,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -23518,7 +23518,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -23022,7 +23022,7 @@
 msgid ""
 msgstr ""
 "Интерполировать точечные данные в G3D объемный грид, используя алгоритм "
Modified: grass/branches/develbranch_6/locale/po/grassmods_sl.po
--- grass/branches/develbranch_6/locale/po/grassmods_sl.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_sl.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -23087,7 +23087,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_th.po
--- grass/branches/develbranch_6/locale/po/grassmods_th.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_th.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -22650,7 +22650,7 @@
 msgid ""
 msgstr ""
 "ข้อมูลจุดไม่เหมาะสม กับค่า G3D กริด ใช้ regularized spline กับ tension (RST) "
Modified: grass/branches/develbranch_6/locale/po/grassmods_tr.po
--- grass/branches/develbranch_6/locale/po/grassmods_tr.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_tr.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -22041,7 +22041,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_vi.po
--- grass/branches/develbranch_6/locale/po/grassmods_vi.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_vi.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -22961,7 +22961,7 @@
 msgid ""
 msgstr ""
 "Nội suy dữ liệu điểm thành thể tích lưới G3D bằng cách dùng thuật toán đường "
Modified: grass/branches/develbranch_6/locale/po/grassmods_zh.po
--- grass/branches/develbranch_6/locale/po/grassmods_zh.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grassmods_zh.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -22945,7 +22945,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_cs.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_cs.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_cs.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4494,7 +4494,7 @@
 #: ../gui/wxpython/menustrings.py:746
 msgid ""
 msgstr ""
 "Interpoluje bodová data do G3D 3D rastrové grid vrstvy za pou¾ití "
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_de.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_de.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_de.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4004,7 +4004,7 @@
 msgstr "Interpoliere Volumen aus Punkten"
 #: ../gui/wxpython/menustrings.py:747
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_el.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_el.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_el.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4163,7 +4163,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_es.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_es.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_es.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4566,7 +4566,7 @@
 msgid ""
 msgstr ""
 "Interpola datos de puntos a volumen de cuadrícula G3D usando una spline "
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_fr.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_fr.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_fr.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4267,7 +4267,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_id.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_id.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_id.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4655,7 +4655,7 @@
 msgid ""
 msgstr ""
 "Interpolasi data titik dari sebuah volume grid 3D dengan algoritma "
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_it.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_it.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_it.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -3986,7 +3986,7 @@
 msgstr "Interpolate volume da punti"
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ja.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ja.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ja.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4005,7 +4005,7 @@
 msgstr "ポイントからボリュームを補間"
 msgstr "テンション(RST)アルゴリズムによる正規化スプライン曲線を使用して3Dグリッドのポイントを補間する"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ml.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ml.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ml.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4270,7 +4270,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pl.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pl.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4017,7 +4017,7 @@
 msgstr "Raster 3D z punktów"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pt.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pt.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pt.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4894,7 +4894,7 @@
 #, fuzzy
 msgid ""
 msgstr "Interpola datos de puntos a volumen de cuadrícula G3D usando"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -5056,7 +5056,7 @@
 #, fuzzy
 msgid ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ru.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ru.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4630,7 +4630,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_th.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_th.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_th.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4424,7 +4424,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_tr.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_tr.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_tr.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4529,7 +4529,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_vi.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_vi.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_vi.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4633,7 +4633,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_zh.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_zh.po	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_zh.po	2012-01-10 12:05:20 UTC (rev 50125)
@@ -4403,7 +4403,7 @@
 msgid ""
 msgstr ""
Modified: grass/branches/develbranch_6/vector/v.vol.rst/main.c
--- grass/branches/develbranch_6/vector/v.vol.rst/main.c	2012-01-10 12:03:18 UTC (rev 50124)
+++ grass/branches/develbranch_6/vector/v.vol.rst/main.c	2012-01-10 12:05:20 UTC (rev 50125)
@@ -201,7 +201,7 @@
     module = G_define_module();
     module->keywords = _("vector, interpolation");
     module->description =
-	_("Interpolates point data to a G3D grid volume using "
+	_("Interpolates point data to a 3D raster map using "
 	  "regularized spline with tension (RST) algorithm.");
     if (G_get_set_window(&cellhd) == -1)
