[GRASS-SVN] r50128 - grass/trunk/scripts/r.fillnulls
Tue Jan 10 08:32:50 EST 2012
Author: lucadelu
Date: 2012-01-10 05:32:50 -0800 (Tue, 10 Jan 2012)
New Revision: 50128
   grass/trunk/scripts/r.fillnulls/r.fillnulls.html
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
add support to v.surf.spline
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.html
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.html	2012-01-10 13:32:40 UTC (rev 50127)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.html	2012-01-10 13:32:50 UTC (rev 50128)
@@ -2,8 +2,8 @@
 <em>r.fillnulls</em> fills NULL pixels (no data areas) in input map and
 stores filled map to a new output map. The fill data are interpolated
-from the no data area boundaries buffer using <em>v.surf.rst</em>
-spline interpolation.
+from the no data area boundaries buffer using <em>v.surf.rst</em>  or
+<em>v.surf.bspline</em> spline interpolation.
 <h2>NOTES</h2>
@@ -11,7 +11,7 @@
 three points around the edge. This way the algorithm interpolates into the hole with
 a trained slope and curvature at the edges, in order to avoid that such a flat plane
 is generated in a hole.
-<p>During the interpolation following warning may occur:<p>
+<p>During the interpolation following warning may occur when using the RST method:<p>
 <tt>
 Warning: strip exists with insufficient data<br>
 Warning: taking too long to find points for interpolation--please change
@@ -24,13 +24,16 @@
 <h2>NOTES</h2>
-The algorithm is based on <em>v.surf.rst</em>
+When using the default RST method, the algorithm is based on <em>v.surf.rst</em>
 regularized splines with tension interpolation module which interpolates the
 raster cell values for NULL data areas from the boundary values of the NULL
 data area. An eventual raster MASK is respected during the NULL data area(s)
 filling. The interpolated values are patched into the NULL data area(s) of
 the input map and saved into a new raster map.
+Otherwise, either the bilinear or bicubic method can be selected (based on
+<em>v.surf.bspline</em>).
 <h2>WARNING</h2>
 Depending on the shape of the NULL data area(s) problems may occur due to an
@@ -38,7 +41,8 @@
 problems will occur if a NULL data area reaches a large amount of the map
 boundary. The user will have to carefully check the result using
 <em>r.mapcalc</em> (generating a difference map to the
-input map) and/or <em>d.what.rast</em> to query individual cell values.
+input map and applying the "differences" color table with <em>r.colors</em>)
+and/or <em>d.what.rast</em> to query individual cell values.
 <h2>EXAMPLE</h2>
@@ -65,7 +69,8 @@
 <em>
 <a href="r.fill.dir.html">r.fill.dir</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="v.surf.bspline.html">v.surf.bspline</a>,
 <a href="v.surf.rst.html">v.surf.rst</a>
 </em>
@@ -91,7 +96,8 @@
 <i>Mathematical Geology</i> 25, 657-667.
 <h2>AUTHORS</h2>
-r.fillnulls: Markus Neteler, University of Hannover<p>and authors of v.surf.rst<br>
+r.fillnulls: Markus Neteler, University of Hannover  and Fondazione Edmund Mach
+<p>and authors of v.surf.rst<br>
 Improvement by Hamish Bowman, NZ
 <p><i>Last changed: $Date$</i>
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2012-01-10 13:32:40 UTC (rev 50127)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2012-01-10 13:32:50 UTC (rev 50128)
@@ -3,15 +3,16 @@
 # MODULE:	r.fillnulls
-# AUTHOR(S):	Markus Neteler <neteler itc it>
+# AUTHOR(S):	Markus Neteler
 #               Updated to GRASS 5.7 by Michael Barton
 #               Updated to GRASS 6.0 by Markus Neteler
 #               Ring improvements by Hamish Bowman
 #               Converted to Python by Glynn Clements
+#               Add support to v.surf.bspline by Luca Delucchi
 # PURPOSE:	fills NULL (no data areas) in raster maps
 #               The script respects a user mask (MASK) if present.
-# COPYRIGHT:	(C) 2001,2004-2005,2008 by the GRASS Development Team
+# COPYRIGHT:	(C) 2001-2012 by the GRASS Development Team
 #		This program is free software under the GNU General Public
 #		License (>=v2). Read the file COPYING that comes with GRASS
@@ -21,7 +22,7 @@
 #%module
-#% description: Fills no-data areas in raster maps using splines interpolation.
+#% description: Fills no-data areas in raster maps using spline interpolation.
 #% keywords: raster
 #% keywords: elevation
 #% keywords: interpolation
@@ -44,6 +45,14 @@
 #% required : no
 #% answer : 0.1
 #%end
+#%option
+#% key: method
+#% type: string
+#% description: Interpolation method
+#% required : yes
+#% options : bilinear,bicubic,rst
+#% answer : rst
+#%end
 import sys
 import os
@@ -75,6 +84,7 @@
     output = options['output']
     tension = options['tension']
     smooth = options['smooth']
+    method = options['method']
     mapset = grass.gisenv()['MAPSET']
     unique = str(os.getpid())
@@ -140,30 +150,44 @@
     # remove internal MASK first -- WHY???? MN 10/2005
     grass.run_command('g.remove', quiet = True, rast = 'MASK')
+    # print message is a usermask it was present
     if grass.find_file(usermask, mapset = mapset)['file']:
 	grass.message(_("Using user mask while interpolating"))
 	maskmap = usermask
     else:
 	maskmap = None
-    segmax = 600
-    if pointsnumber > segmax:
-	grass.message(_("Using segmentation for interpolation..."))
-	segmax = None
-    else:
-	grass.message(_("Using no segmentation for interpolation as not needed..."))
+    #check if method is rst to use v.surf.rst
+    if method == 'rst':
+        # set the max number before segmantation
+        segmax = 600
+        if pointsnumber > segmax:
+            grass.message(_("Using segmentation for interpolation..."))
+            segmax = None
+        else:
+            grass.message(_("Using no segmentation for interpolation as not needed..."))
+        # launch v.surf.rst
+	grass.message(_("Using RST interpolation..."))
+	grass.run_command('v.surf.rst', input = vecttmp, elev = tmp1 + '_filled',
+			zcol = 'value', tension = tension, smooth = smooth,
+			maskmap = maskmap, segmax = segmax)
-    grass.run_command('v.surf.rst', input = vecttmp, elev = tmp1 + '_filled',
-		      zcol = 'value', tension = tension, smooth = smooth,
-		      maskmap = maskmap, segmax = segmax)
+	grass.message(_("Note: Above warnings may be ignored."))
-    grass.message(_("Note: Above warnings may be ignored."))
     # restoring user's mask, if present:
 	grass.message(_("Restoring user mask (MASK)..."))
 	grass.run_command('g.rename', quiet = True, rast = (usermask, 'MASK'))
+    #check if method is different from rst to use v.surf.bspline
+    if method != 'rst':
+	grass.message(_("Using %s (v.surf.bspline) interpolation") % method)
+	reg = grass.region()
+	# launch v.surf.bspline
+	grass.run_command('v.surf.bspline', input = vecttmp, layer = 1,
+			raster = tmp1 + '_filled', method = method, column = 'value',
+			sie = reg['ewres'], sin = reg['nsres'])
     # patch orig and fill map
     grass.message(_("Patching fill data into NULL areas..."))
     # we can use --o here as g.parser already checks on startup
