[GRASS-SVN] r50167 - in grass/trunk/gui/wxpython: lmgr xml
Fri Jan 13 17:47:11 EST 2012
Author: mmetz
Date: 2012-01-13 14:47:11 -0800 (Fri, 13 Jan 2012)
New Revision: 50167
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: add option to change CWD
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2012-01-13 21:43:18 UTC (rev 50166)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2012-01-13 22:47:11 UTC (rev 50167)
@@ -704,6 +704,18 @@
                 GMessage(parent = self,
                          message = _("Current mapset is <%s>.") % mapset)
+    def OnChangeCWD(self, event):
+        """!Change current working directory
+        dlg = wx.DirDialog(parent = self, message = _("Choose a working directory"),
+                            defaultPath = os.getcwd(), style = wx.DD_CHANGE_DIR)
+        cwd_path = ''
+        if dlg.ShowModal() == wx.ID_OK:
+            cwd_path = dlg.GetPath()
+        # save path to somewhere ?
     def OnNewVector(self, event):
         """!Create new vector map layer"""
         dlg = CreateNewVector(self, log = self.goutput,
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2012-01-13 21:43:18 UTC (rev 50166)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2012-01-13 22:47:11 UTC (rev 50167)
@@ -911,6 +911,11 @@
 	  <handler>OnPreferences</handler>
 	  <id>ID_PREFERENCES</id>
 	</menuitem>
+        <menuitem>
+          <label>Change working directory</label>
+          <help>Change working directory</help>
+          <handler>OnChangeCWD</handler>
+        </menuitem>
       </items>
     </menu>
     <menu>
