[GRASS-SVN] r50209 - grass/branches/develbranch_6/raster/r.proj
Mon Jan 16 03:11:12 EST 2012
Author: hamish
Date: 2012-01-16 00:11:11 -0800 (Mon, 16 Jan 2012)
New Revision: 50209
   grass/branches/develbranch_6/raster/r.proj/description.html
copy over some missing notes from the v.proj help page
Modified: grass/branches/develbranch_6/raster/r.proj/description.html
--- grass/branches/develbranch_6/raster/r.proj/description.html	2012-01-16 08:09:04 UTC (rev 50208)
+++ grass/branches/develbranch_6/raster/r.proj/description.html	2012-01-16 08:11:11 UTC (rev 50209)
@@ -133,6 +133,19 @@
 <h2>NOTES</h2>
+If <b>output</b> is not specified it is set to be the same as input map
+name.
+<br>
+If <b>mapset</b> is not specified, its name is assumed to be the same
+as the current mapset's name.
+<br>
+If <b>dbase</b> is not specified it is assumed to be the current
+database. The user only has to specify <b>dbase</b> if the source
+location is stored in another separate GRASS database.
+<p>
 To avoid excessive time consumption when reprojecting a map the region and
 resolution of the target location should be set appropriately beforehand.
 A simple way to do this is to generate a vector "box" map of the region in
