[GRASS-SVN] r50304 - grass/trunk/gui/wxpython/vdigit
Thu Jan 19 12:42:27 EST 2012
Author: martinl
Date: 2012-01-19 09:42:27 -0800 (Thu, 19 Jan 2012)
New Revision: 50304
   grass/trunk/gui/wxpython/vdigit/toolbars.py
   grass/trunk/gui/wxpython/vdigit/wxdigit.py
wxGUI/digit: implement `redo` tool
Modified: grass/trunk/gui/wxpython/vdigit/toolbars.py
--- grass/trunk/gui/wxpython/vdigit/toolbars.py	2012-01-19 17:30:56 UTC (rev 50303)
+++ grass/trunk/gui/wxpython/vdigit/toolbars.py	2012-01-19 17:42:27 UTC (rev 50304)
@@ -46,6 +46,7 @@
         self.comboid  = self.combo = None
         self.undo     = -1
+        self.redo     = -1
         # only one dialog can be open
         self.settingsDialog   = None
@@ -70,14 +71,16 @@
             self.combo.Show()
         # disable undo/redo
-        if self.undo:
+        if self.undo > 0:
             self.EnableTool(self.undo, False)
+        if self.redo > 0:
+            self.EnableTool(self.redo, False)
         # toogle to pointer by default
         self.OnTool(None)
         self.FixSize(width = 105)
     def _toolbarData(self):
         """!Toolbar data
@@ -133,9 +136,12 @@
                                          label = _('Additional tools '
                                                    '(copy, flip, connect, etc.)'),
                                          desc = _('Left: Select; Ctrl+Left: Unselect; Right: Confirm')),
-            'undo'             : MetaIcon(img = 'undo',
-                                          label = _('Undo'),
-                                          desc = _('Undo previous changes')),
+            'undo'            : MetaIcon(img = 'undo',
+                                         label = _('Undo'),
+                                         desc = _('Undo previous changes')),
+            'redo'            : MetaIcon(img = 'redo',
+                                         label = _('Redo'),
+                                         desc = _('Redo previous changes')),
         if not self.tools or 'selector' in self.tools:
@@ -207,6 +213,9 @@
         if not self.tools or 'undo' in self.tools:
             data.append(("undo", icons["undo"],
                          self.OnUndo))
+        if not self.tools or 'redo' in self.tools:
+            data.append(("redo", icons["redo"],
+                         self.OnRedo))
         if not self.tools or 'settings' in self.tools:
             data.append(("settings", icons["settings"],
                          self.OnSettings))
@@ -386,21 +395,36 @@
         event.Skip()
+    def OnRedo(self, event):
+        """!Undo previous changes"""
+        self.digit.Undo(level = 1)
+        event.Skip()
     def EnableUndo(self, enable = True):
         """!Enable 'Undo' in toolbar
         @param enable False for disable
-        # iclass has no undo, we need to check it
-        if self.FindById(self.undo) is None:
+        self._enableTool(self.undo, enable)
+    def EnableRedo(self, enable = True):
+        """!Enable 'Redo' in toolbar
+        @param enable False for disable
+        self._enableTool(self.redo, enable)
+    def _enableTool(self, tool, enable):
+        if not self.FindById(tool):
             return
         if enable:
-            if self.GetToolEnabled(self.undo) is False:
-                self.EnableTool(self.undo, True)
+            if self.GetToolEnabled(tool) is False:
+                self.EnableTool(tool, True)
         else:
-            if self.GetToolEnabled(self.undo) is True:
-                self.EnableTool(self.undo, False)
+            if self.GetToolEnabled(tool) is True:
+                self.EnableTool(tool, False)
     def OnSettings(self, event):
         """!Show settings dialog"""
@@ -724,6 +748,7 @@
         fType = self.digit.GetFeatureType()
         self.EnableAll()
         self.EnableUndo(False)
+        self.EnableRedo(False)
         if fType == 'Point':
             for tool in (self.addLine, self.addBoundary, self.addCentroid,
Modified: grass/trunk/gui/wxpython/vdigit/wxdigit.py
--- grass/trunk/gui/wxpython/vdigit/wxdigit.py	2012-01-19 17:30:56 UTC (rev 50303)
+++ grass/trunk/gui/wxpython/vdigit/wxdigit.py	2012-01-19 17:42:27 UTC (rev 50304)
@@ -171,7 +171,6 @@
         # undo/redo
         self.changesets = list()
         self.changesetCurrent = -1 # first changeset to apply
-        self.changesetEnd     = -1 # last changeset to be applied
         if self.poMapInfo:
             self.InitCats()
@@ -351,17 +350,12 @@
         if changeset < 0 or changeset >= len(self.changesets):
             return -1
-        if self.changesetEnd < 0:
-            self.changesetEnd = changeset
         ret = 0
         actions = self.changesets[changeset]
-        for action in actions:
-            add = bool(action['offset'] > 0)
+        for action in actions:
             line = action['line']
-            if (undo and add) or \
-                    (not undo and not add):
+            if action['offset'] > 0:
                 if Vect_line_alive(self.poMapInfo, line):
                     Debug.msg(3, "IVDigit._applyChangeset(): changeset=%d, action=add, line=%d -> deleted",
                               changeset, line)
@@ -1216,13 +1210,11 @@
         if changesetLast < 0:
             return changesetLast
-        if self.changesetCurrent == -2: # value uninitialized
-            self.changesetCurrent = changesetLast
         if level > 0 and self.changesetCurrent < 0:
             self.changesetCurrent = 0
-        if level == 0:
+        elif level < 0 and self.changesetCurrent > changesetLast:
+            self.changesetCurrent = changesetLast
+        elif level == 0:
             # 0 -> undo all
             level = -1 * changesetLast + 1
@@ -1241,19 +1233,22 @@
                 self._applyChangeset(changeset, undo = False)
         self.changesetCurrent += level
-        Debug.msg(2, "Digit.Undo(): changeset_current=%d, changeset_last=%d, changeset_end=%d",
-                  self.changesetCurrent, changesetLast, self.changesetEnd)
-        if self.changesetCurrent == self.changesetEnd:
-            self.changesetEnd = changesetLast
-            return -1
+        Debug.msg(2, "Digit.Undo(): changeset_current=%d, changeset_last=%d",
+                  self.changesetCurrent, changesetLast)
         self.mapWindow.UpdateMap(render = False)
         if self.changesetCurrent < 0: # disable undo tool
             self.toolbar.EnableUndo(False)
+        else:
+            self.toolbar.EnableUndo(True)
+        if self.changesetCurrent <= changesetLast:
+            self.toolbar.EnableRedo(True)
+        else:
+            self.toolbar.EnableRedo(False)
     def ZBulkLines(self, pos1, pos2, start, step):
         """!Z-bulk labeling
