[GRASS-SVN] r50306 - in grass/trunk: include/vect lib/gis lib/python/temporal temporal/tr.register vector vector/v.info vector/v.timestamp
Thu Jan 19 17:30:23 EST 2012
Author: huhabla
Date: 2012-01-19 14:30:23 -0800 (Thu, 19 Jan 2012)
New Revision: 50306
Added:
   grass/trunk/vector/v.timestamp/
   grass/trunk/vector/v.timestamp/Makefile
   grass/trunk/vector/v.timestamp/main.c
   grass/trunk/vector/v.timestamp/v.timestamp.html
   grass/trunk/include/vect/dig_defines.h
   grass/trunk/lib/gis/timestamp.c
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/datetime_math.py
   grass/trunk/lib/python/temporal/space_time_datasets.py
   grass/trunk/lib/python/temporal/space_time_datasets_tools.py
   grass/trunk/temporal/tr.register/test.tr.register.sh
   grass/trunk/vector/Makefile
   grass/trunk/vector/v.info/print.c
Added timestamp support for vector maps with v.timestamp.
The *.timestamp modules are now used to attach the absolute time
from the temporal database to maps in the file system. Hence, C-modules
have easier access to temporal information.
Modified: grass/trunk/include/vect/dig_defines.h
--- grass/trunk/include/vect/dig_defines.h	2012-01-19 21:47:02 UTC (rev 50305)
+++ grass/trunk/include/vect/dig_defines.h	2012-01-19 22:30:23 UTC (rev 50306)
@@ -28,6 +28,8 @@
 #define GV_COLR_ELEMENT "colr"
 /*! \brief Name of directory for alternative color tables */
 #define GV_COLR2_DIRECTORY "vcolr2"
+/*! \brief Name of the timestamp file */
+#define GV_TIMESTAMP_ELEMENT "timestamp"
 /*! \brief Endian check
Modified: grass/trunk/lib/gis/timestamp.c
--- grass/trunk/lib/gis/timestamp.c	2012-01-19 21:47:02 UTC (rev 50305)
+++ grass/trunk/lib/gis/timestamp.c	2012-01-19 22:30:23 UTC (rev 50306)
@@ -76,11 +76,12 @@
 #include <string.h>
+#include <unistd.h>
 #include <grass/gis.h>
+#include <grass/vect/dig_defines.h>
 #include <grass/glocale.h>
 #define RAST_MISC "cell_misc"
-#define VECT_MISC "dig_misc"
 #define GRID3	  "grid3"
@@ -376,26 +377,52 @@
   \brief Read timestamp from vector map
-  Is this used anymore with the new GRASS 6 vector engine???
   \param name map name
   \param mapset mapset name
   \param[out] ts TimeStamp struct to populate
   \return 1 on success
-  \return 0 or negative on error
+  \return 0 no timestamp present
+  \return -1 Unable to open file
+  \return -2 invalid time stamp
 int G_read_vector_timestamp(const char *name, const char *mapset,
 			    struct TimeStamp *ts)
-    return read_timestamp("vector", VECT_MISC, name, mapset, ts);
+    FILE *fd;
+    int stat;
+    char dir[GPATH_MAX];
+    char path[GPATH_MAX + GNAME_MAX];
+    G_snprintf(dir, GPATH_MAX, "%s/%s", GV_DIRECTORY, name);
+    G_file_name(path, dir, GV_TIMESTAMP_ELEMENT, mapset);
+    G_debug(1, "Reading vector timestamp file: %s", path);
+    /* In case no timestamp file is present return 0 */
+    if (access(path, R_OK) != 0)
+	return 0;
+    fd = G_fopen_old(dir, GV_TIMESTAMP_ELEMENT, mapset);
+    if (fd == NULL) {
+	G_warning(_("Unable to open timestamp file for vector map <%s@%s>"),
+		  name, G_mapset());
+	return -1;
+    stat = G__read_timestamp(fd, ts);
+    fclose(fd);
+    if (stat == 0)
+	return 1;
+    G_warning(_("Invalid timestamp file for vector map <%s@%s>"),
+	        name, mapset);
+    return -2;
   \brief Remove timestamp from vector map
   Only timestamp files in current mapset can be removed.
@@ -406,7 +433,10 @@
 int G_remove_vector_timestamp(const char *name)
-    return G_remove_misc(VECT_MISC, "timestamp", name);
+    return G_remove(dir, GV_TIMESTAMP_ELEMENT);
@@ -470,7 +500,27 @@
 int G_write_vector_timestamp(const char *name, const struct TimeStamp *ts)
-    return write_timestamp("vector", VECT_MISC, name, ts);
+    FILE *fd;
+    int stat;
+    fd = G_fopen_new(dir, GV_TIMESTAMP_ELEMENT);
+    if (fd == NULL) {
+	G_warning(_("Unable to create timestamp file for vector map <%s@%s>"),
+	return -1;
+    stat = G__write_timestamp(fd, ts);
+    fclose(fd);
+    if (stat == 0)
+	return 1;
+    G_warning(_("Invalid timestamp specified for vector map <%s@%s>"),
+    return -2;
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-01-19 21:47:02 UTC (rev 50305)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-01-19 22:30:23 UTC (rev 50306)
@@ -21,6 +21,7 @@
 @author Soeren Gebbert
 from abstract_dataset import *
+from datetime_math import *
@@ -39,7 +40,7 @@
     def get_stds_register(self):
         """Return the space time dataset register table name in which stds are listed in which this map is registered"""
         raise IOError("This method must be implemented in the subclasses")
     def set_stds_register(self, name):
         """Set the space time dataset register table name.
@@ -48,7 +49,11 @@
            @param ident: The name of the register table
+    def get_timestamp_module_name(self):
+        """Return the name of the C-module to set the time stamp in the file system"""
+        raise IOError("This method must be implemented in the subclasses")
     def load(self):
         """Load the content of this object from map files"""
@@ -162,6 +167,14 @@
         if connect == True:
             dbif.close()
+        # Start the grass C-module to set the time in the file system
+        start = datetime_to_grass_datetime_string(start_time)
+        if end_time:
+            end = datetime_to_grass_datetime_string(end_time)
+            start += " / %s"%(end)
+        core.run_command(self.get_timestamp_module_name(), map=self.get_id(), date=start)
     def set_relative_time(self, start_time, end_time=None):
         """Set the relative time interval
@@ -188,8 +201,8 @@
     def update_relative_time(self, start_time, end_time=None, dbif = None):
         """Update the relative time interval
-           @param start_time: A double value in days
-           @param end_time: A double value in days
+           @param start_time: A double value
+           @param end_time: A double value
            @param dbif: The database interface to be used
         connect = False
@@ -276,6 +289,9 @@
             # Delete yourself from the database, trigger functions will take care of dependencies
             self.base.delete(dbif)
+        # Remove the timestamp from the file system
+        core.run_command(self.get_timestamp_module_name(), map=self.get_id(), date="none")
         self.reset(None)
         dbif.connection.commit()
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py	2012-01-19 21:47:02 UTC (rev 50305)
+++ grass/trunk/lib/python/temporal/datetime_math.py	2012-01-19 22:30:23 UTC (rev 50306)
@@ -23,6 +23,7 @@
 from datetime import datetime, date, time, timedelta
 import grass.script.core as core
 import copy
+from dateutil import parser
@@ -314,3 +315,35 @@
     return comp
+def string_to_datetime(time_string):
+    """Convert a string into a datetime object using the dateutil parser. Return None in case of failure"""
+    # BC is not suported
+    if time_string.find("bc") > 0:
+        core.error("Dates Before Christ are not supported in the temporal database")
+        return None
+    try:
+        dt = parser.parse(time_string)
+        return dt
+    except:
+        return None
+def datetime_to_grass_datetime_string(dt):
+    """Convert a python datetime object into a GRASS datetime string"""
+    # GRASS datetime month names
+    month_names  = ["", "jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec"]
+    # Check for time zone infor in the datetime object
+    if dt.tzinfo != None:
+        string = "%.2i %s %.2i %.2i:%.2i:%.2i %+.4i"%(dt.day, month_names[dt.month], dt.year, \
+                 dt.hour, dt.minute, dt.second, dt.tzinfo._offset.seconds/3600*100)
+    else:
+        string = "%.2i %s %.4i %.2i:%.2i:%.2i"%(dt.day, month_names[dt.month], dt.year, dt.hour, dt.minute, dt.second)
+    return string
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py	2012-01-19 21:47:02 UTC (rev 50305)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py	2012-01-19 22:30:23 UTC (rev 50306)
@@ -59,6 +59,10 @@
         """Set the space time dataset register table name in which stds are listed in which this map is registered"""
         self.metadata.set_strds_register(name)
+        return "r.timestamp"
     def reset(self, ident):
 	"""Reset the internal structure and set the identifier"""
@@ -133,6 +137,10 @@
         self.metadata.set_str3ds_register(name)
+        return "r3.timestamp"
@@ -211,6 +219,10 @@
         self.metadata.set_stvds_register(name)
+        return "v.timestamp"
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-01-19 21:47:02 UTC (rev 50305)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-01-19 22:30:23 UTC (rev 50306)
@@ -476,17 +476,17 @@
         connect = True
     if ttype == "absolute":
-        # Create the start time object
-        if start.find(":") > 0:
-            time_format = "%Y-%m-%d %H:%M:%S"
-        else:
-            time_format = "%Y-%m-%d"
-        start_time = datetime.strptime(start, time_format)
+        start_time = string_to_datetime(start)
+        if start_time == None:
+            dbif.close()
+            core.fatal_error(_("Unable to convert string \"%s\"into a datetime object")%(start))
         end_time = None
         if end:
-            end_time = datetime.strptime(end, time_format)
+            end_time = string_to_datetime(end)
+            if end_time == None:
+                dbif.close()
+                core.fatal_error(_("Unable to convert string \"%s\"into a datetime object")%(end))
         # Add the increment
         if increment:
Modified: grass/trunk/temporal/tr.register/test.tr.register.sh
--- grass/trunk/temporal/tr.register/test.tr.register.sh	2012-01-19 21:47:02 UTC (rev 50305)
+++ grass/trunk/temporal/tr.register/test.tr.register.sh	2012-01-19 22:30:23 UTC (rev 50306)
@@ -31,55 +31,67 @@
 tr.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 seconds"
 t.info type=strds input=precip_abs1
 t.info -g type=strds input=precip_abs1
+r.info map=prec_1
 tr.list input=precip_abs1
 t.topology input=precip_abs1
 tr.register -i input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 seconds, 5 minutes"
 t.info type=strds input=precip_abs2
 t.info -g type=strds input=precip_abs2
+r.info map=prec_1
 tr.list input=precip_abs2
 t.topology input=precip_abs2
 tr.register -i input=precip_abs3 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="8 hours"
 t.info -g type=strds input=precip_abs3
+r.info map=prec_1
 tr.list input=precip_abs3
 t.topology input=precip_abs3
 tr.register input=precip_abs4 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 days"
 t.info -g type=strds input=precip_abs4
+r.info map=prec_1
 tr.list input=precip_abs4
 t.topology input=precip_abs4
 tr.register input=precip_abs5 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="4 weeks"
 t.info -g type=strds input=precip_abs5
+r.info map=prec_1
 tr.list input=precip_abs5
 t.topology input=precip_abs5
 tr.register input=precip_abs6 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-08-01" increment="2 months"
 t.info -g type=strds input=precip_abs6
+r.info map=prec_1
 tr.list input=precip_abs6
 t.topology input=precip_abs6
 tr.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
 t.info -g type=strds input=precip_abs7
+r.info map=prec_1
 tr.list input=precip_abs7
 t.topology input=precip_abs7
 # Register with different valid time again
 tr.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+r.info map=prec_1
 # Register with different valid time again creating an interval
 tr.register -i input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+r.info map=prec_1
 tr.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" end="2002-01-01"
+r.info map=prec_1
 t.remove type=rast input=prec_1,prec_2,prec_3
 t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5,precip_abs6,precip_abs7
 t.remove type=rast input=prec_4,prec_5,prec_6
+r.info map=prec_1
Modified: grass/trunk/vector/Makefile
--- grass/trunk/vector/Makefile	2012-01-19 21:47:02 UTC (rev 50305)
+++ grass/trunk/vector/Makefile	2012-01-19 22:30:23 UTC (rev 50306)
@@ -79,6 +79,7 @@
 	v.surf.idw \
 	v.surf.rst \
 	v.transform \
+	v.timestamp \
 	v.to.3d \
 	v.to.db \
 	v.to.points \
Modified: grass/trunk/vector/v.info/print.c
--- grass/trunk/vector/v.info/print.c	2012-01-19 21:47:02 UTC (rev 50305)
+++ grass/trunk/vector/v.info/print.c	2012-01-19 22:30:23 UTC (rev 50306)
@@ -229,9 +229,21 @@
     int i;
     char line[100];
     char tmp1[100], tmp2[100];
+    char timebuff[256];
+    struct TimeStamp ts;
+    int time_ok = 0, first_time_ok = 0, second_time_ok = 0;
+    struct bound_box box;
+    /*Check the Timestamp */
+    time_ok = G_read_vector_timestamp(Vect_get_name(Map), "", &ts);
+    /*Check for valid entries, show none if no timestamp available */
+    if (time_ok == 1) {
+	if (ts.count > 0)
+	    first_time_ok = 1;
+	if (ts.count > 1)
+	    second_time_ok = 1;
-    struct bound_box box;
     divider('+');
     if (Vect_maptype(Map) & (GV_FORMAT_OGR | GV_FORMAT_OGR_DIRECT)) {
 	/* for OGR format print also datasource and layer */
@@ -284,6 +296,17 @@
 	    Vect_get_map_date(Map));
     printline(line);
+    /*This shows the TimeStamp */
+    if (time_ok  == 1 && (first_time_ok || second_time_ok)) {
+        G_format_timestamp(&ts, timebuff);
+        sprintf(line, "%-17s%s", _("Timestamp: "), timebuff);
+    else {
+        sprintf(line, "%-17s%s", _("Timestamp: none"), timebuff);
+    printline(line);
     divider('|');
     sprintf(line, "  %s: %s (%s: %i)",
Added: grass/trunk/vector/v.timestamp/Makefile
--- grass/trunk/vector/v.timestamp/Makefile	                        (rev 0)
+++ grass/trunk/vector/v.timestamp/Makefile	2012-01-19 22:30:23 UTC (rev 50306)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = v.timestamp
+LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/vector/v.timestamp/main.c
--- grass/trunk/vector/v.timestamp/main.c	                        (rev 0)
+++ grass/trunk/vector/v.timestamp/main.c	2012-01-19 22:30:23 UTC (rev 50306)
@@ -0,0 +1,79 @@
+ * MODULE:       v.timestamp
+ * AUTHOR(S):    Soeren Gebbert <soerengebbert googlemail.com>
+ *               based on r.timestamp from Michael Shapiro, CERL (original contributor)
+ * PURPOSE:      Print/add/remove a timestamp for a vector map
+ * COPYRIGHT:    (C) 2012 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+    struct GModule *module;
+    struct Option *map, *date;
+    char *name;
+    int modify;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("vector"));
+    G_add_keyword(_("metadata"));
+    G_add_keyword(_("timestamp"));
+    module->label = _("Modifies a timestamp for a vector map.");
+    module->description = _("Print/add/remove a timestamp for a vector map.");
+    map = G_define_standard_option(G_OPT_V_MAP);
+    date = G_define_option();
+    date->key = "date";
+    date->key_desc = "timestamp";
+    date->required = NO;
+    date->type = TYPE_STRING;
+    date->label = _("Datetime, datetime1/datetime2, or 'none' to remove");
+    date->description = _("Format: '15 jan 1994' (absolute) or '2 years' (relative)");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    name = map->answer;
+    modify = date->answer != NULL;
+    if (!modify) {
+	if (G_read_vector_timestamp(name, "", &ts) == 1) {
+	    G__write_timestamp(stdout, &ts);
+	    exit(EXIT_SUCCESS);
+	else
+    if (strcmp(date->answer, "none") == 0) {
+	G_remove_vector_timestamp(name);
+    if (1 == G_scan_timestamp(&ts, date->answer)) {
+	G_write_vector_timestamp(name, &ts);
+    else
+	G_fatal_error(_("Invalid timestamp"));
Added: grass/trunk/vector/v.timestamp/v.timestamp.html
--- grass/trunk/vector/v.timestamp/v.timestamp.html	                        (rev 0)
+++ grass/trunk/vector/v.timestamp/v.timestamp.html	2012-01-19 22:30:23 UTC (rev 50306)
@@ -0,0 +1,134 @@
+<h2>DESCRIPTION</h2>
+This command has 2 modes of operation. If no <b>date</b> argument is
+supplied, then the current timestamp for the vector map is printed. If
+a date argument is specified, then the timestamp for the vector map is
+set to the specified date(s). See examples below.
+<h2>NOTES</h2>
+Strings containing spaces should be quoted. For specifying a range of
+time, the two timestamps should be separated by a forward slash. To
+remove the timestamp from a vector map, use <b>date=none</b>.
+<h2>TIMESTAMP FORMAT</h2>
+The timestamp values must use the format as described in the <em>GRASS
+Datetime Library</em>. The source tree for this library should have a
+description of the format. For convience, the formats are reproduced
+here:
+<p>There are two types of datetime values:
+<ul>
+  <li><em>absolute</em> and
+  <li><em>relative</em>.
+</ul>
+Absolute values specify exact dates and/or times. Relative values
+specify a span of time.
+<h3>Absolute</h3>
+The general format for absolute values is:
+<div class="code"><pre>
+  day month year [bc] hour:minute:seconds timezone
+	     day is 1-31
+	     month is jan,feb,...,dec
+	     year is 4 digit year
+	     [bc] if present, indicates dates is BC
+	     hour is 0-23 (24 hour clock)
+	     mintue is 0-59
+	     second is 0-59.9999 (fractions of second allowed)
+	     timezone is +hhmm or -hhmm (eg, -0600)
+</pre></div>
+Some parts can be missing, for example
+	     1994 [bc]
+	     Jan 1994 [bc]
+	     15 jan 1000 [bc]
+	     15 jan 1994 [bc] 10 [+0000]
+	     15 jan 1994 [bc] 10:00 [+0100]
+	     15 jan 1994 [bc] 10:00:23.34 [-0500]
+</pre></div>
+<h3>Relative</h3>
+There are two types of relative datetime values, year-month and
+day-second. The formats are:
+	     [-] # years # months
+	     [-] # days # hours # minutes # seconds
+</pre></div>
+The words years, months, days, hours, minutes, seconds are literal
+words, and the # are the numeric values. Examples:
+	     2 years
+	     5 months
+	     2 years 5 months
+	     100 days
+	     15 hours 25 minutes 35.34 seconds
+	     100 days 25 minutes
+	     1000 hours 35.34 seconds
+</pre></div>
+The following are <i>illegal</i> because it mixes year-month and
+day-second (because the number of days in a month or in a year vary):
+	     3 months 15 days
+	     3 years 10 days
+</pre></div>
+<h2>EXAMPLES</h2>
+Prints the timestamp for the "lidar" vector map. If there is no
+timestamp for "lidar", nothing is printed. If there is a timestamp,
+one or two time strings are printed, depending on if the timestamp for
+the map consists of a single date or two dates (ie start and end
+dates).
+    v.timestamp map=lidar
+</pre></div>
+Sets the timestamp for "lidar" to the single date "15 sep 1987".
+    v.timestamp map=lidar date='15 sep 1987'
+</pre></div>
+Sets the timestamp for "lidar" to have the start date "15 sep 1987"
+and the end date "20 feb 1988".
+    v.timestamp map=lidar date='15 sep 1987/20 feb 1988'
+</pre></div>
+Removes the timestamp for the "lidar" vector map.
+    v.timestamp map=lidar date=none
+</pre></div>
+<h2>BUGS</h2>
+Spaces in the timestamp value are required.
+<h2>SEE ALSO</h2>
+<em>
+  <a href="v.info.html">v.info</a>
+</em>
+<h2>AUTHOR</h2>
+Michael Shapiro, U.S.Army Construction Engineering Research Laboratory
+<p><i>Last changed: $Date: 2011-11-08 22:24:20 +0100 (Di, 08 Nov 2011) $</i>
