[GRASS-SVN] r50308 - grass/branches/develbranch_6/locale/po
Thu Jan 19 17:36:26 EST 2012
Author: neteler
Date: 2012-01-19 14:36:26 -0800 (Thu, 19 Jan 2012)
New Revision: 50308
   grass/branches/develbranch_6/locale/po/grasswxpy_de.po
cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_de.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_de.po	2012-01-19 22:36:20 UTC (rev 50307)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_de.po	2012-01-19 22:36:26 UTC (rev 50308)
@@ -12,7 +12,7 @@
 "Project-Id-Version: grasswxpy_de\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2011-10-05 23:24+0200\n"
-"PO-Revision-Date: 2012-01-12 12:03+0100\n"
+"PO-Revision-Date: 2012-01-19 19:24+0100\n"
 "Last-Translator: Markus Neteler <neteler osgeo.org>\n"
 "Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
 "Language: \n"
@@ -1808,7 +1808,7 @@
 #: ../gui/wxpython/menustrings.py:189
 msgid "Creates a 3D rendering of GIS data."
-msgstr ""
+msgstr "Erzeugt eine 3D Darstellung von GIS-Daten."
 #: ../gui/wxpython/menustrings.py:190
 msgid "Bearing/distance to coordinates"
@@ -6703,7 +6703,7 @@
 #: ../gui/wxpython/gui_modules/nviz_preferences.py:205
 #, fuzzy
 msgid "Image Appearance"
-msgstr "Image Appearance"
+msgstr "Erscheinungsbild"
 #: ../gui/wxpython/gui_modules/nviz_tools.py:241
 #: ../gui/wxpython/gui_modules/nviz_tools.py:3124
@@ -6969,7 +6969,7 @@
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1136
 #, fuzzy
 msgid "Follow source viewpoint"
-msgstr "Folge Quell-Betrachtungspunkt"
+msgstr "Quelle der Rasterwerte"
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1142
 msgid "Light source position"
@@ -6984,9 +6984,8 @@
 msgstr "Helligkeit:"
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1210
-#, fuzzy
 msgid "Ambient:"
-msgstr "Umgebend:"
+msgstr "Lichtwärme:"
 #: ../gui/wxpython/gui_modules/nviz_tools.py:1271
 msgid "Edges with fringe"
@@ -7736,13 +7735,13 @@
 #: ../gui/wxpython/gui_modules/psmap.py:545
 #: ../gui/wxpython/gui_modules/psmap.py:568
+#, fuzzy
 msgid "Please, create map frame first."
-msgstr ""
+msgstr "Digitalisiere Ebene (Selektiere die Ebene zuerst)"
 #: ../gui/wxpython/gui_modules/psmap.py:613
-#, fuzzy
 msgid "Scalebar is not appropriate for this projection"
-msgstr "Geben Sie Parameter an für die %s Projektion "
+msgstr "Maßstab ist für diese Projektion nicht geeignet"
 #: ../gui/wxpython/gui_modules/psmap.py:912
 msgid "wxGUI Cartographic Composer"
@@ -7763,7 +7762,7 @@
 #: ../gui/wxpython/gui_modules/psmap.py:1146
 msgid "Click and drag to resize object"
-msgstr ""
+msgstr "Anklicken und verschieben, um Größe zu verändern"
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:71
 msgid "GRASS GIS Manage Ground Control Points"
@@ -7909,9 +7908,8 @@
 msgstr "Variablen"
 #: ../gui/wxpython/gui_modules/gmodeler.py:639
-#, fuzzy
 msgid "GRASS GIS Graphical Modeler (experimental prototype)"
-msgstr "GRASS GIS Graphical Modeler"
+msgstr "GRASS GIS Cartographic Composer (experimenteller Prototyp)"
 #: ../gui/wxpython/gui_modules/gmodeler.py:688
 msgid "Model"
@@ -7992,9 +7990,8 @@
 msgstr "Die Datei existiert bereits."
 #: ../gui/wxpython/gui_modules/gmodeler.py:1036
-#, fuzzy
 msgid "Model is empty. Nothing to validate."
-msgstr "Modell ist leer. Nichts überprüft."
+msgstr "Modell ist leer. Nichts zu überprüfen."
 #: ../gui/wxpython/gui_modules/gmodeler.py:1046
 #, python-format
@@ -8160,13 +8157,12 @@
 "Hinzufügen einer neuen Aktion zu Modell nicht möglich."
 #: ../gui/wxpython/gui_modules/gmodeler.py:2595
-#, fuzzy
 msgid "Relation properties"
-msgstr "Dateneigenschaften"
+msgstr "Beziehungseigenschaften"
 #: ../gui/wxpython/gui_modules/gmodeler.py:2612
 msgid "From"
-msgstr ""
+msgstr "Von"
 #: ../gui/wxpython/gui_modules/gmodeler.py:2614
 #: ../gui/wxpython/gui_modules/dbm.py:935
@@ -8307,7 +8303,6 @@
 msgstr "Integer"
 #: ../gui/wxpython/gui_modules/gmodeler.py:3777
-#, fuzzy
 msgid "float"
 msgstr "Fließkomma"
@@ -8367,7 +8362,6 @@
 msgstr "Liste von Elementen - Rechtsklick für Löschen"
 #: ../gui/wxpython/gui_modules/gmodeler.py:4183
-#, fuzzy
 msgid "In block"
 msgstr "Im Block"
@@ -8494,7 +8488,7 @@
 msgid ""
 "Region cannot be set\n"
 "%s"
-msgstr "Auflösung kann nicht 0 sein"
+msgstr "Aktuelle Region kann nicht gesetzt werden."
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:751
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:901
@@ -8505,7 +8499,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1368
 #, fuzzy, python-format
 msgid "Failed to read instruction %s"
-msgstr "Kann die Liste nicht lesen: %s"
+msgstr "Kann Datei %s nicht lesen."
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:765
 #, python-format
@@ -8545,7 +8539,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:844
 msgid "Failed to read instruction %s."
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:939
 #, python-format
@@ -8587,7 +8581,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1701
 #, fuzzy
 msgid "Choose color:"
-msgstr "Wählen Sie das Verzeichnis:"
+msgstr "Wählen Sie die Farbe:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1749
 msgid "Close dialog and apply changes"
@@ -8623,8 +8617,9 @@
 msgstr "Rechts"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1836
+#, fuzzy
 msgid "Literal is not allowed!"
-msgstr ""
+msgstr "Diese Schrittgröße ist nicht erlaubt."
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2431
@@ -8651,19 +8646,16 @@
 msgstr "Querformat"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1953
-#, fuzzy
 msgid "Map settings"
-msgstr "Speichere Einstellungen"
+msgstr "Karteneinstellungen"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1959
-#, fuzzy
 msgid "Map frame settings"
-msgstr "Aktualisiere Einstellungen"
+msgstr "Kartenrahmeneinstellungen"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2076
-#, fuzzy
 msgid "Map frame options:"
-msgstr "Kartenprojektionen"
+msgstr "Kartenrahmenoptionen:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2077
 #, fuzzy
@@ -8685,9 +8677,8 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2088
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2256
-#, fuzzy
 msgid "Map selection"
+msgstr "Kartenauswahl"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2096
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2673
@@ -8699,9 +8690,8 @@
 msgstr "Region:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2115
-#, fuzzy
 msgid "Map scale and center"
-msgstr "Kartenmaßstab"
+msgstr "Maßstab und Zentrum"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2120
 msgid "Center:"
@@ -8724,28 +8714,27 @@
 msgstr "1 :"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2146
+#, fuzzy
 msgid "Map max resolution (dpi):"
-msgstr ""
+msgstr "[%s]: Karte hat die falsche Auflösung."
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2159
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4015
-#, fuzzy
 msgid "Border"
-msgstr "1. Ordnung"
+msgstr "Rand"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2163
 msgid "draw border around map frame"
 msgstr ""
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2169
-#, fuzzy
 msgid "border color:"
-msgstr "Gitterfarbe"
+msgstr "Randfarbe:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2170
 #, fuzzy
 msgid "border width (pts):"
-msgstr "Liniebreite (in Pixel):"
+msgstr "Setze breite (in Punkt):"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2264
 msgid ""
@@ -8754,9 +8743,8 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2271
-#, fuzzy
 msgid "Region selection"
-msgstr "Invertiere Auswahl"
+msgstr "Auswahl der Region"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2430
 msgid "No map selected!"
@@ -8834,21 +8822,19 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2904
 #, fuzzy
 msgid "Raster map settings"
-msgstr "Raster Einstellungen"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2941
-#, fuzzy
 msgid "Vector maps settings"
-msgstr "Vektor Einstellungen"
+msgstr "Vektorkarteneinstellungen"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2976
 msgid "properties"
 msgstr "Eigenschaften"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3026
-#, fuzzy
 msgid "Data selection"
+msgstr "Datenauswahl"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3033
 msgid "Feature type"
@@ -8863,18 +8849,16 @@
 msgstr "Flächengrenzen"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3055
-#, fuzzy
 msgid "Layer selection"
+msgstr "Layerauswahl"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3062
-#, fuzzy
 msgid "Select layer:"
-msgstr "Layer löschen"
+msgstr "Wählen Sie ein Layer:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3085
 msgid "list of categories (e.g. 1,3,5-7)"
-msgstr ""
+msgstr "Liste der Kategorien (z.B. 1,3,5-7)"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3115
 msgid "Use current mask"
@@ -8887,14 +8871,13 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3137
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3236
-#, fuzzy
 msgid "Outline"
-msgstr "Linie"
+msgstr "Umrandung"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3141
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3245
 msgid "draw outline"
-msgstr ""
+msgstr "Zeichne Umrandung"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3144
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3249
@@ -8920,7 +8903,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3200
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3304
 msgid "color from map table column:"
-msgstr ""
+msgstr "Farbwert aus Vektorkartentabellen-Spalte:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3247
 msgid "No effect for fill color from table column"
@@ -8966,9 +8949,8 @@
 msgstr "Größe:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3381
-#, fuzzy
 msgid "size from map table column:"
-msgstr "Lösche alle Spalten"
+msgstr "Größe aus Vektorkartentabellen-Spalte:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3383
 msgid "scale:"
@@ -8984,12 +8966,11 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3422
 msgid "counterclockwise in degrees:"
-msgstr ""
+msgstr "Gegenuhrzeigersinn in Grad:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3424
-#, fuzzy
 msgid "from map table column:"
+msgstr "von Vektorkartentabellen-Spalte:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3467
 msgid "Set width (pts):"
@@ -9006,14 +8987,12 @@
 msgstr "Liniestil"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3497
-#, fuzzy
 msgid "Choose line style:"
-msgstr "Grober Stil:"
+msgstr "Wählen Sie einen Linienstil:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3507
-#, fuzzy
 msgid "Choose linecap:"
-msgstr "Wählen die Datei"
+msgstr "Wählen Sie ein Linienende"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3532
 msgid "Pattern"
@@ -9021,7 +9000,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3537
 msgid "use pattern:"
-msgstr ""
+msgstr "Verwende Muster:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3538
 msgid "Choose pattern file:"
@@ -9033,7 +9012,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3544
 msgid "pattern scale factor:"
-msgstr ""
+msgstr "Skalierungsfaktor für Muster:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3843
 msgid "Raster legend"
@@ -9066,8 +9045,9 @@
 msgstr "Legendentyp"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3889
+#, fuzzy
 msgid "discrete legend (categorical maps)"
-msgstr ""
+msgstr "Kodiert kategorische Rasterkarten um."
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3891
 msgid "continuous color gradient legend (floating point map)"
@@ -9078,8 +9058,9 @@
 msgstr "Fortgeschrittene Legendeneinstellungen"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3906
+#, fuzzy
 msgid "draw \"no data\" box"
-msgstr ""
+msgstr "Keine Eingabekarte angegeben."
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3912
 msgid "draw ticks across color table"
@@ -9155,7 +9136,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4306
 msgid "Edit legend label:"
-msgstr ""
+msgstr "Editiere Legendenlabel:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4347
 msgid "No raster map selected!"
@@ -9219,7 +9200,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4911
 msgid "Label every "
-msgstr ""
+msgstr "Beschrifte jede"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4912
 msgid "segments"
@@ -9227,7 +9208,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4921
 msgid "transparent text background"
-msgstr ""
+msgstr "transparenter Texthintergrund"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4998
 msgid "Length of scale bar is not defined"
@@ -9249,7 +9230,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5106
 msgid "text background"
-msgstr ""
+msgstr "Texthintergrundfarbe"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5109
 msgid "highlight"
@@ -9265,12 +9246,12 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5189
 msgid "relatively to paper"
-msgstr ""
+msgstr "in Bezug auf Papier"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5190
 #, fuzzy
 msgid "by map coordinates"
-msgstr "Setze GCP-Koordinaten"
+msgstr "Ost Koordinaten des Austrittspunkts"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5206
 msgid ""
@@ -9300,7 +9281,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5289
 msgid "rotate text (counterclockwise)"
-msgstr ""
+msgstr "Textrotation (Gegenuhrzeigersinn)"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5365
 msgid "No text entered!"
@@ -9511,7 +9492,7 @@
 #: ../gui/wxpython/gui_modules/toolbars.py:404
 #, fuzzy
 msgid "Set map canvas for "
-msgstr "Setze Darstellungsfenster für"
+msgstr "2. Bild für das Mosaik."
 #: ../gui/wxpython/gui_modules/toolbars.py:406
 msgid " / Zoom to map"
@@ -10282,9 +10263,8 @@
 msgstr "Typ der Kartenebene:"
 #: ../gui/wxpython/gui_modules/gdialogs.py:912
-#, fuzzy
 msgid "Select toggle"
-msgstr "Wähle umschalten"
+msgstr "Umschalter auswählen"
 #: ../gui/wxpython/gui_modules/gdialogs.py:929
 msgid "Filter:"
@@ -10973,8 +10953,9 @@
 msgstr "Ausgewählte anzeigen"
 #: ../gui/wxpython/gui_modules/preferences.py:647
+#, fuzzy
 msgid "Classic (labels only)"
-msgstr ""
+msgstr "Gebe nur Wertespanne aus."
 #: ../gui/wxpython/gui_modules/preferences.py:648
 msgid "Combined (labels and module names)"
@@ -11021,9 +11002,9 @@
 msgstr "Histogramm"
 #: ../gui/wxpython/gui_modules/preferences.py:714
-#, fuzzy, python-format
+#, python-format
 msgid "Unable to read settings file <%s>\n"
-msgstr "Kann die Einstellungen '%s' nicht parsen."
+msgstr "Kann die Einstellungsdatei <%s> nicht lesen\n"
 #: ../gui/wxpython/gui_modules/preferences.py:738
@@ -11104,9 +11085,9 @@
 #: ../gui/wxpython/gui_modules/preferences.py:1165
 #: ../gui/wxpython/gui_modules/preferences.py:1175
-#, python-format
+#, fuzzy, python-format
 msgid "Hide '%s' tab (requires GUI restart)"
-msgstr ""
+msgstr "Menü-Stil (benötigt GUI-Neustart):"
 #: ../gui/wxpython/gui_modules/preferences.py:1188
 msgid "Automatically copy selected text to clipboard (in Command console)"
@@ -11600,6 +11581,9 @@
 "\n"
 "If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
 msgstr ""
+"SIND SIE WIRKLICH SICHER?\n"
+"\n"
+"Wenn Sie schon eine andere GRASS-Sitzung geöffnet haben, könnte das Weitermachen hier Ihre Daten beschädigen. Überprüfen Sie sicherheitshalber die Prozesstabelle..."
 #: ../gui/wxpython/gis_set.py:771
 #, python-format
@@ -12741,9 +12725,8 @@
 #~ "Es ist keine Attributtabelle mit der Vektorkarte <%(vector)s> verlinkt. %(msg)s\n"
 #~ " Sie können diese Meldung in den Digitalisierungseinstellungen ausschalten. Oder Sie können mit dem Attributtabellenmanager eine Attributtabelle erzeugen und mit der Vektorkarte verknüpfen "
-#, fuzzy
 #~ msgid "Item properties"
-#~ msgstr "Dateneigenschaften"
+#~ msgstr "Eintragseigenschaften"
 #~ msgid "Fetch full info including description and keywords"
 #~ msgstr "Abruf der gesamten Information inklusive Beschreibung und Schlüsselworte"
@@ -12792,3 +12775,12 @@
 #~ msgid "Topographic correction"
 #~ msgstr "Topographische Korrektur"
+#~ msgid "Loop"
+#~ msgstr "Schleife"
+#~ msgid "Removes installed GRASS AddOns extension."
+#~ msgstr "Entfernen einer installierten Erweiterung aus den GRASS Addons."
+#~ msgid "Satellite images products"
+#~ msgstr "Satellitenbildprodukte"
