[GRASS-SVN] r50330 - grass/trunk/display/d.info
Fri Jan 20 13:56:50 EST 2012
Author: martinl
Date: 2012-01-20 10:56:50 -0800 (Fri, 20 Jan 2012)
New Revision: 50330
   grass/trunk/display/d.info/main.c
d.info: cosmetics in module description
Modified: grass/trunk/display/d.info/main.c
--- grass/trunk/display/d.info/main.c	2012-01-20 18:51:42 UTC (rev 50329)
+++ grass/trunk/display/d.info/main.c	2012-01-20 18:56:50 UTC (rev 50330)
@@ -4,7 +4,7 @@
  * MODULE:       d.info
  * AUTHOR(S):    Glynn Clements
  * PURPOSE:      Display information about the active display monitor
- * COPYRIGHT:    (C) 2004 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2004, 2012 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -29,9 +29,11 @@
     module = G_define_module();
     G_add_keyword(_("display"));
-    G_add_keyword(_("metadata"));
+    G_add_keyword(_("monitors"));
+    module->label =
+	_("Displays information about the active display monitor.");
     module->description =
-	_("Display information about the active display monitor");
+	_("Display monitors are maintained by d.mon.");
     rflag = G_define_flag();
     rflag->key = 'r';
@@ -60,8 +62,7 @@
     if (!rflag->answer && !dflag->answer &&
 	!fflag->answer && !bflag->answer && !gflag->answer) {
-	G_usage();
-	exit(EXIT_FAILURE);
+	G_fatal_error(_("No flag given"));
     if (D_open_driver() != 0)
@@ -112,5 +113,5 @@
     D_close_driver();
-    return EXIT_SUCCESS;
+    exit(EXIT_SUCCESS);
