[GRASS-SVN] r50343 - in grass/trunk: lib/python/temporal lib/temporal/SQL temporal temporal/t.time.abs temporal/t.time.rel temporal/t.topology temporal/tr.aggregate temporal/tr.aggregate.ds temporal/tr.export temporal/tr.list temporal/tr.register temporal/tr.series temporal/tr.univar temporal/tr3.register temporal/tv.list temporal/tv.register temporal/tv.what.rast
Fri Jan 20 19:35:25 EST 2012
Author: huhabla
Date: 2012-01-20 16:35:25 -0800 (Fri, 20 Jan 2012)
New Revision: 50343
Added:
   grass/trunk/temporal/tr.aggregate/test.tr.aggregate.relative_time.sh
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/aggregation.py
   grass/trunk/lib/python/temporal/datetime_math.py
   grass/trunk/lib/python/temporal/space_time_datasets_tools.py
   grass/trunk/lib/python/temporal/temporal_extent.py
   grass/trunk/lib/python/temporal/temporal_granularity.py
   grass/trunk/lib/temporal/SQL/map_tables_template.sql
   grass/trunk/lib/temporal/SQL/stds_tables_template.sql
   grass/trunk/temporal/Makefile
   grass/trunk/temporal/t.time.abs/test.t.time.abs.file.sh
   grass/trunk/temporal/t.time.rel/t.time.rel.py
   grass/trunk/temporal/t.time.rel/test.t.time.rel.file.sh
   grass/trunk/temporal/t.time.rel/test.t.time.rel.sh
   grass/trunk/temporal/t.topology/test.t.topology.abstime.sh
   grass/trunk/temporal/t.topology/test.t.topology.reltime.sh
   grass/trunk/temporal/tr.aggregate.ds/test.tr.aggregate.ds.sh
   grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py
   grass/trunk/temporal/tr.aggregate/test.tr.aggregate.sh
   grass/trunk/temporal/tr.aggregate/tr.aggregate.py
   grass/trunk/temporal/tr.export/test.tr.export.sh
   grass/trunk/temporal/tr.list/test.tr.list.sh
   grass/trunk/temporal/tr.register/ECAD_climate_analysis_1995_2010.py
   grass/trunk/temporal/tr.register/test.tr.register.file.sh
   grass/trunk/temporal/tr.register/tr.register.py
   grass/trunk/temporal/tr.series/tr.series.py
   grass/trunk/temporal/tr.univar/test.tr.univar.sh
   grass/trunk/temporal/tr3.register/test.tr3.register.sh
   grass/trunk/temporal/tr3.register/tr3.register.py
   grass/trunk/temporal/tv.list/test.tv.list.sh
   grass/trunk/temporal/tv.register/tv.register.py
   grass/trunk/temporal/tv.what.rast/test.tv.what.rast.sh
New relative time handling, compatible to the grass datetime library.
New database structure using different SQL datatypes.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -97,13 +97,32 @@
         return (start, end, tz)
     def get_relative_time(self):
-        """Returns the relative time interval (start_time, end_time) or None if not present"""
+        """Returns the relative time interval (start_time, end_time, unit) or None if not present"""
         start = self.relative_time.get_start_time()
         end = self.relative_time.get_end_time()
+        unit = self.relative_time.get_unit()
-        return (start, end)
+        return (start, end, unit)
+    def get_relative_time_unit(self):
+        """Returns the relative time unit or None if not present"""
+        return unit
+    def check_relative_time_unit(self, unit):
+        """Check if unit is of type  years, months, days, hours, minutes or seconds
+           Return True if success or False otherwise
+        # Check unit
+        units = ["years","months","days","hours","minutes","seconds"]
+        if unit not in units:
+            return False
+        return True
     def get_temporal_type(self):
         """Return the temporal type of this dataset"""
         return self.base.get_ttype()
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -87,14 +87,15 @@
         datasets = self.get_registered_datasets()
         count = 0
         string = ""
-        for ds in datasets:
-            if count == 0:
-                string += ds["id"]
-            else:
-                string += ",%s" % ds["id"]
-            count += 1
-            if count > 2:
-                string += " | ............................ "
+        if datasets:
+            for ds in datasets:
+                if count == 0:
+                    string += ds["id"]
+                else:
+                    string += ",%s" % ds["id"]
+                count += 1
+                if count > 2:
+                    string += " | ............................ "
         print " | Registered datasets ........ " + string
         print " +----------------------------------------------------------------------------+"
@@ -149,6 +150,9 @@
     def update_absolute_time(self, start_time, end_time=None, timezone=None, dbif = None):
         """Update the absolute time
+           This method should always be used to set the absolute time. Do not use insert() or update()
+           to the the time. This update functions assures that the *.timestamp commands are invoked.
            @param start_time: a datetime object specifying the start time of the map
            @param end_time: a datetime object specifying the end time of the map
            @param timezone: Thee timezone of the map
@@ -167,7 +171,12 @@
         if connect == True:
             dbif.close()
-        # Start the grass C-module to set the time in the file system
+        self.write_absolute_time_to_file()
+    def write_absolute_time_to_file(self):
+        """Start the grass timestamp module to set the time in the file system"""
+        start_time, end_time, unit = self.get_absolute_time()
         start = datetime_to_grass_datetime_string(start_time)
         if end_time:
             end = datetime_to_grass_datetime_string(end_time)
@@ -175,16 +184,26 @@
         core.run_command(self.get_timestamp_module_name(), map=self.get_id(), date=start)
-    def set_relative_time(self, start_time, end_time=None):
+    def set_relative_time(self, start_time, end_time, unit):
         """Set the relative time interval
-           @param start_time: A double value in days
-           @param end_time: A double value in days
+           @param start_time: A double value
+           @param end_time: A double value
+           @param unit: The unit of the relative time. Supported uits: years, months, days, hours, minutes, seconds
+           Return True for success and False otherwise
+        if not self.check_relative_time_unit(unit):
+            core.error(_("Unsupported relative time unit type for %s map <%s>: %s") % (self.get_type(), self.get_id(), unit))
+            return False
         if start_time != None and end_time != None:
-            if abs(float(start_time)) > abs(float(end_time)):
-                core.fatal(_("End time must be greater than start time for %s map <%s>") % (self.get_type(), self.get_id()))
+            if int(start_time) > int(end_time):
+                core.error(_("End time must be greater than start time for %s map <%s>") % (self.get_type(), self.get_id()))
+                return False
             else:
                 # Do not create an interval in case start and end time are equal
                 if start_time == end_time:
@@ -192,15 +211,21 @@
         self.base.set_ttype("relative")
-        self.relative_time.set_start_time(float(start_time))
+        self.relative_time.set_unit(unit)
+        self.relative_time.set_start_time(int(start_time))
         if end_time != None:
-            self.relative_time.set_end_time(float(end_time))
+            self.relative_time.set_end_time(int(end_time))
         else:
             self.relative_time.set_end_time(None)
-    def update_relative_time(self, start_time, end_time=None, dbif = None):
+        return True
+    def update_relative_time(self, start_time, end_time, unit, dbif = None):
         """Update the relative time interval
            @param dbif: The database interface to be used
@@ -212,14 +237,26 @@
             dbif.connect()
             connect = True
-        self.set_relative_time(start_time, end_time)
-        self.relative_time.update_all(dbif)
-        self.base.update(dbif)
-        dbif.connection.commit()
+        if self.set_relative_time(start_time, end_time, unit):
+            self.relative_time.update_all(dbif)
+            self.base.update(dbif)
+            dbif.connection.commit()
         if connect == True:
             dbif.close()
+        self.write_relative_time_to_file()
+    def write_relative_time_to_file(self):
+        start_time, end_time, unit = self.get_relative_time()
+        start = "%i %s"%(int(start_time), unit)
+        if end_time:
+            end = "%i %s"%(int(end_time), unit)
+            start += " / %s"%(end)
+        core.run_command(self.get_timestamp_module_name(), map=self.get_id(), date=start)
     def set_spatial_extent(self, north, south, east, west, top=0, bottom=0):
         """Set the spatial extent of the map
@@ -237,7 +274,7 @@
         if self.is_time_absolute():
             start, end, tz = self.get_absolute_time()
         else:
-            start, end = self.get_relative_time()
+            start, end, unit = self.get_relative_time()
         if start != None:
             if end != None:
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -39,6 +39,7 @@
     def __init__(self, ident):
 	self.reset(ident)
+        self.map_counter = 0
     def get_new_map_instance(self, ident=None):
         """Return a new instance of a map dataset which is associated with the type of this class
@@ -168,6 +169,19 @@
         else:
             core.fatal(_("Unknown temporal type \"%s\"") % (temporal_type))
+    def set_relative_time_unit(self, unit):
+        """Set the relative time unit which may be of type: years, months, days, hours, minutes or seconds
+           All maps registered in a (relative time) space time dataset must have the same unit
+        temporal_type = self.get_temporal_type()
+        if temporal_type == "relative":
+                core.fatal(_("Unsupported temporal unit: %s") % (unit))
     def get_map_time(self):
         """Return the type of the map time, interval, point, maixed or invalid"""
@@ -199,7 +213,7 @@
                 if count == 0:
                     relations = relation
                 else:
-                    relations += "," + relation
+                    relations += "," + str(relation)
                 count += 1
                 # Break if the the next map follows
                 if relation == "follows":
@@ -263,7 +277,7 @@
             if maps[i].is_time_absolute():
                 start, end, tz = maps[i].get_absolute_time()
             if maps[i].is_time_relative():
-                start, end = maps[i].get_relative_time()
+                start, end, unit = maps[i].get_relative_time()
             if start != None and end != None:
                 time_interval += 1
@@ -703,7 +717,7 @@
                     map.set_absolute_time(row["start_time"], row["end_time"])
                 elif self.is_time_relative():
-                    map.set_relative_time(row["start_time"], row["end_time"])
+                    map.set_relative_time(row["start_time"], row["end_time"], self.get_relative_time_unit())
                 obj_list.append(copy.copy(map))
                 count += 1
@@ -855,6 +869,8 @@
         map_name = map.base.get_name()
         map_mapset = map.base.get_mapset()
         map_register_table = map.get_stds_register()
+        map_rel_time_unit = map.get_relative_time_unit()
+        map_ttype = map.get_temporal_type()
         #print "Map register table", map_register_table
@@ -862,7 +878,24 @@
         stds_name = self.base.get_name()
         stds_mapset = self.base.get_mapset()
         stds_register_table = self.get_map_register()
+        stds_ttype = self.get_temporal_type()
+        # Check temporal types
+        if stds_ttype != map_ttype:
+            core.fatal(_("Temporal type of space time dataset <%s> and map <%s> are different") % (self.get_id(), map.get_id()))
+        # In case no map has been registered yet, set the relative time unit from the first map
+        if self.metadata.get_number_of_maps() == None and self.map_counter == 0 and self.is_time_relative():
+            self.set_relative_time_unit(map_rel_time_unit)
+            self.relative_time.update()
+            core.verbose(_("Set temporal unit for space time %s dataset <%s> to %s") %  (map.get_type(), self.get_id(), map_rel_time_unit))
+        stds_rel_time_unit = self.get_relative_time_unit()
+        # Check the relative time unit
+        if self.is_time_relative() and (stds_rel_time_unit != map_rel_time_unit):
+            core.fatal(_("Relative time units of space time dataset <%s> and map <%s> are different") % (self.get_id(), map.get_id()))
         #print "STDS register table", stds_register_table
         if stds_mapset != map_mapset:
@@ -887,7 +920,7 @@
         # Create tables
         sql_path = get_sql_template_path()
-        # We need to create the stmap raster register table bevor we can register the map
+        # We need to create the map raster register table bevor we can register the map
         if map_register_table == None:
             # Create a unique id
             uuid_rand = "map_" + str(uuid.uuid4()).replace("-", "")
@@ -987,6 +1020,9 @@
         if connect == True:
             dbif.close()
+        # increase the counter
+        self.map_counter += 1
         return True
     def unregister_map(self, map, dbif = None):
@@ -1050,6 +1086,9 @@
         if connect == True:
             dbif.close()
+        # decrease the counter
+        self.map_counter -= 1
     def update_from_registered_maps(self, dbif = None):
         """This methods updates the spatial and temporal extent as well as
@@ -1127,7 +1166,7 @@
             start_time, end_time, tz = self.get_absolute_time()
         else:
-            start_time, end_time = self.get_relative_time()
         # In case no end time is set, use the maximum start time of all registered maps as end time
         if end_time == None:
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/python/temporal/aggregation.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -68,7 +68,7 @@
     return names
-def aggregate_raster_maps(dataset, mapset, inputs, base, start, end, count, method, register_null, dbif):
+def aggregate_raster_maps(orig_ds, dataset, mapset, inputs, base, start, end, count, method, register_null, dbif):
     core.verbose(_("Aggregate %s raster maps") %(len(inputs)))
     output = "%s_%i" % (base, count)
@@ -118,7 +118,7 @@
     if dataset.is_time_absolute():
         new_map.set_absolute_time(start, end, None)
     else:
-        new_map.set_relative_time(start, end)
+        new_map.set_relative_time(start, end, orig_ds.get_relative_time_unit())
     # Insert map in temporal database
     new_map.insert(dbif)
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/python/temporal/datetime_math.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -25,7 +25,6 @@
 import copy
 from dateutil import parser
 def relative_time_to_time_delta(value):
@@ -42,7 +41,7 @@
 def time_delta_to_relative_time(delta):
-    """Convert the time delta into a
+    """Convert the time delta into a
        double value, representing days.
@@ -207,7 +206,10 @@
             seconds = 0
             minutes = 0
             hours = 0
-            days = days - weekday
+            if days > weekday:
+                days = days - weekday # this needs to be fixed
+            else:
+                days = days + weekday # this needs to be fixed
         elif has_months: # Start at the first day of the month at 00:00:00
             seconds = 0
             minutes = 0
@@ -341,7 +343,7 @@
     # Check for time zone infor in the datetime object
     if dt.tzinfo != None:
         string = "%.2i %s %.2i %.2i:%.2i:%.2i %+.4i"%(dt.day, month_names[dt.month], dt.year, \
-                 dt.hour, dt.minute, dt.second, dt.tzinfo._offset.seconds/3600*100)
+                 dt.hour, dt.minute, dt.second, dt.tzinfo._offset.seconds/60)
     else:
         string = "%.2i %s %.4i %.2i:%.2i:%.2i"%(dt.day, month_names[dt.month], dt.year, dt.hour, dt.minute, dt.second)
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -26,7 +26,7 @@
-def register_maps_in_space_time_dataset(type, name, maps=None, file=None, start=None, end=None, increment=None, dbif = None, interval=False, fs="|"):
+def register_maps_in_space_time_dataset(type, name, maps=None, file=None, start=None, end=None, unit=None, increment=None, dbif = None, interval=False, fs="|"):
     """Use this method to register maps in space time datasets. This function is generic and
        Additionally a start time string and an increment string can be specified
@@ -39,7 +39,9 @@
        @param name: The name of the space time dataset
        @param maps: A comma separated list of map names
        @param file: Input file one map with optional start and end time, one per line
-       @param start: The start date and time of the first raster map, in case the map has no date (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative 5.0)
+       @param start: The start date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative is integer 5)
+       @param end: The end date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative is integer 5)
+       @param unit: The unit of the relative time: years, months, days, hours, minutes, seconds
        @param increment: Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
        @param interval: If True, time intervals are created in case the start time and an increment is provided
@@ -182,7 +184,7 @@
         # Set the valid time
         if start:
-            assign_valid_time_to_map(ttype=sp.get_temporal_type(), map=map, start=start, end=end, increment=increment, mult=count, dbif=dbif, interval=interval)
+            assign_valid_time_to_map(ttype=sp.get_temporal_type(), map=map, start=start, end=end, unit=unit, increment=increment, mult=count, dbif=dbif, interval=interval)
         # Finally Register map in the space time dataset
         sp.register_map(map, dbif)
@@ -294,7 +296,7 @@
-def assign_valid_time_to_maps(type, maps, ttype, start, end=None, file=file, increment=None, dbif = None, interval=False, fs="|"):
+def assign_valid_time_to_maps(type, maps, ttype, start, end=None, unit=None, file=file, increment=None, dbif = None, interval=False, fs="|"):
     """Use this method to assign valid time (absolute or relative) to raster,
        raster3d and vector datasets.
@@ -305,8 +307,9 @@
        @param type: The type of the maps raster, raster3d or vector
-       @param start: The start date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative 5.0)
-       @param end: The end date and time of the first raster map (format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd", format relative 5.0)
@@ -437,7 +440,7 @@
             count = 1
-        assign_valid_time_to_map(ttype=ttype, map=map, start=start, end=end, increment=increment, mult=count, dbif=dbif, interval=interval)
+        assign_valid_time_to_map(ttype=ttype, map=map, start=start, end=end, unit=unit, increment=increment, mult=count, dbif=dbif, interval=interval)
         count += 1
@@ -455,14 +458,15 @@
-def assign_valid_time_to_map(ttype, map, start, end, increment=None, mult=1, dbif = None, interval=False):
+def assign_valid_time_to_map(ttype, map, start, end, unit, increment=None, mult=1, dbif = None, interval=False):
     """Assign the valid time to a map dataset
        @param ttype: The temporal type which should be assigned and which the time format is of
        @param map: A map dataset object derived from abstract_map_dataset
-       @param increment: Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
+       @param increment: Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer 1)
        @param multi: A multiplier for the increment
        @param dbif: The database interface to use for sql queries
@@ -479,14 +483,14 @@
         start_time = string_to_datetime(start)
         if start_time == None:
             dbif.close()
-            core.fatal_error(_("Unable to convert string \"%s\"into a datetime object")%(start))
+            core.fatal(_("Unable to convert string \"%s\"into a datetime object")%(start))
         end_time = None
         if end:
             end_time = string_to_datetime(end)
                 dbif.close()
-                core.fatal_error(_("Unable to convert string \"%s\"into a datetime object")%(end))
+                core.fatal(_("Unable to convert string \"%s\"into a datetime object")%(end))
         # Add the increment
         if increment:
@@ -497,19 +501,19 @@
         core.verbose(_("Set absolute valid time for map <%s> to %s - %s") % (map.get_id(), str(start_time), str(end_time)))
         map.update_absolute_time(start_time, end_time, None, dbif)
     else:
-        start_time = float(start)
+        start_time = int(start)
         end_time = None
         if end:
-            end_time = float(end)
+            end_time = int(end)
         if increment:
-            start_time = start_time + mult * float(increment)
+            start_time = start_time + mult * int(increment)
             if interval:
-                end_time = start_time + float(increment)
+                end_time = start_time + int(increment)
-        core.verbose(_("Set relative valid time for map <%s> to %f - %s") % (map.get_id(), start_time,  str(end_time)))
-        map.update_relative_time(start_time, end_time, dbif)
+        core.verbose(_("Set relative valid time for map <%s> to %i - %s with unit %s") % (map.get_id(), start_time,  str(end_time), unit))
+        map.update_relative_time(start_time, end_time, unit, dbif)
     if connect == True:
         dbif.close()
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/python/temporal/temporal_extent.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -357,11 +357,14 @@
 	self.set_timezone(timezone)
     def set_timezone(self, timezone):
-	"""Set the timezone of the map, integer from 1 - 24"""
+	"""Set the timezone of the map, the timezone is of type string.
+           Timezones are not supported yet, instead the timezone is set in the datetime string as offset in minutes.
 	self.D["timezone"] = timezone
     def get_timezone(self):
 	"""Get the timezone of the map
 	   @return None if not found"""
 	if self.D.has_key("timezone"):
 	    return self.D["timezone"]
@@ -474,18 +477,61 @@
 class relative_temporal_extent(abstract_temporal_extent):
     """This is the relative time class for all maps and spacetime datasets
-       start_time and end_time must be of type datetime
+       start_time and end_time must be of type integer
-    def __init__(self, table=None, ident=None, start_time=None, end_time=None):
+    def __init__(self, table=None, ident=None, start_time=None, end_time=None, unit=None):
 	abstract_temporal_extent.__init__(self, table, ident, start_time, end_time)
+	self.D["unit"] = unit
+    def set_unit(self, unit):
+        """Set the unit of the relative time. Valid units are:
+           * years
+           * months
+           * days
+           * hours
+           * minutes
+           * seconds
+    def get_unit(self):
+	"""Get the unit of the relative time
+	   @return None if not found"""
+	if self.D.has_key("unit"):
+	    return self.D["unit"]
+        else:
+	    return None
+    def temporal_relation(self, map):
+	"""Returns the temporal relation between temporal objects
+	   Temporal relationsships are implemented after [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic]
+        # Check units for relative time
+        if not self.D.has_key("unit"):
+            return None
+        if not map.D.has_key("unit"):
+            return None
+        # Units must be equal
+        if self.D["unit"] != map.D["unit"]:
+            return None
+	return abstract_temporal_extent.temporal_relation(self, map)
     def print_info(self):
         """Print information about this class in human readable style"""
         #      0123456789012345678901234567890
-        print " +-------------------- Reltive time ------------------------------------------+"
+        print " +-------------------- Relative time -----------------------------------------+"
         abstract_temporal_extent.print_info(self)
+        print " | Relative time unit:......... " + str(self.get_unit())
+    def print_shell_info(self):
+        """Print information about this class in shell style"""
+        abstract_temporal_extent.print_shell_info(self)
+        print "unit=" + str(self.get_unit())
 class raster_relative_time(relative_temporal_extent):
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -26,6 +26,9 @@
 def compute_relative_time_granularity(maps):
+    """ Compute the relative granularity"""
+    # The intervaltime must be scaled to days resoltuion
     granularity = None
     delta = []
@@ -33,9 +36,8 @@
     for map in maps:
         start, end = map.get_valid_time()
         if start and end:
-            t =  relative_time_to_time_delta(abs(end - start))
-            full_seconds = t.days * 86400 + t.seconds
-            delta.append(full_seconds)
+            t =  abs(end - start)
+            delta.append(int(t))
     # Compute the timedelta of the gaps
     for i in range(len(maps)):
@@ -46,23 +48,23 @@
                 start2, end2 = maps[i + 1].get_valid_time()
                 # Gaps are between intervals, intervals and points, points and points
                 if end1 and start2:
-                    t =  relative_time_to_time_delta(abs(end1 - start2))
+                    t =  abs(end1 - start2)
                 if  not end1 and start2:
-                    t =  relative_time_to_time_delta(abs(start1 - start2))
+                    t =  abs(start1 - start2)
     delta.sort()
     ulist = list(set(delta))
     if len(ulist) > 1:
         # Find greatest common divisor
         granularity = gcd_list(ulist)
+    elif len(ulist) == 1:
+        granularity = ulist[0]
     else:
-        granularity = ulist[0]
+        granularity = 0
-    return float(granularity / 86400.0)
+    return granularity
Modified: grass/trunk/lib/temporal/SQL/map_tables_template.sql
--- grass/trunk/lib/temporal/SQL/map_tables_template.sql	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/temporal/SQL/map_tables_template.sql	2012-01-21 00:35:25 UTC (rev 50343)
@@ -30,8 +30,9 @@
 -- Relative valid time interval with start and end time
 CREATE TABLE  GRASS_MAP_relative_time (
   id VARCHAR NOT NULL,          -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreign key
-  start_time DOUBLE PRECISION,  -- The relative valid start time in [days]
-  end_time DOUBLE PRECISION,    -- The relative valid end time in [days]
+  start_time INTEGER,  -- The relative valid start time in
+  end_time INTEGER,    -- The relative valid end time in
+  unit VARCHAR,                 -- The relative time unit, available are "years, months, days, minutes, seconds"
   PRIMARY KEY (id),
   FOREIGN KEY (id) REFERENCES  GRASS_MAP_base (id) ON DELETE CASCADE
@@ -40,7 +41,7 @@
   start_time TIMESTAMP,  --  Start of the valid time, can be NULL if no time information is available
   end_time TIMESTAMP,    --  End of the valid time, can be NULL if no time information is available or valid time is a single point in time
-  timezone SMALLINT,     -- The timezone of the valid time
+  timezone VARCHAR,      -- The timezone of the valid time stored as string. This is currently not in use. Instead the timezone is set in the datetime strings
   PRIMARY KEY (id),
Modified: grass/trunk/lib/temporal/SQL/stds_tables_template.sql
--- grass/trunk/lib/temporal/SQL/stds_tables_template.sql	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/lib/temporal/SQL/stds_tables_template.sql	2012-01-21 00:35:25 UTC (rev 50343)
@@ -15,7 +15,7 @@
   mapset VARCHAR NOT NULL,             -- mapset of the space-time dataset
   creator VARCHAR NOT NULL,            -- Name of the creator
   temporal_type VARCHAR NOT NULL,      -- The temporal type of the dataset "absolute" or "relative"
-  semantic_type VARCHAR NOT NULL,      -- The semantic data description used for aggregation/decomposition algorithm selection
+  semantic_type VARCHAR NOT NULL,      -- The semantic data description used for aggregation/decomposition algorithm selection: min, max, mean or sum
   creation_time TIMESTAMP NOT NULL,    -- The time of creation of the space-time dataset
 -- Uncommented due to performance issues
 --  modification_time TIMESTAMP NOT NULL,  -- The time of the last modification of the grass map
@@ -25,9 +25,10 @@
 CREATE TABLE  STDS_relative_time (
   id VARCHAR NOT NULL,            -- Id of the space-time dataset, this is the primary foreign key
-  granularity DOUBLE PRECISION,   -- The granularity in [days]
+  granularity INTEGER,            -- The granularity
   map_time VARCHAR,               -- The temporal type of the registered maps, may be interval, point or mixed
   PRIMARY KEY (id),
   FOREIGN KEY (id) REFERENCES  STDS_base (id) ON DELETE CASCADE
@@ -37,8 +38,8 @@
   start_time TIMESTAMP,           -- Start of the valid time, can be NULL if no map is registered
   end_time TIMESTAMP,             -- End of the valid time, can be NULL if no map is registered
-  granularity VARCHAR,            -- The granularity "NNN seconds, NNN minutes, NNN hours, NNN days, NNN weeks, NNN months, NNN years"
-  timezone SMALLINT,              -- The time zone number
+  granularity VARCHAR,            -- The granularity "NNN seconds, NNN minutes, NNN hours, NNN days, NNN months, NNN years"
   PRIMARY KEY (id),
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/Makefile	2012-01-21 00:35:25 UTC (rev 50343)
@@ -23,11 +23,13 @@
 	tr.out.vtk \
 	tr.import \
 	tr.extract \
+	tr3.extract \
 	tr3.register \
 	tv.register \
 	tr.unregister \
 	tr3.unregister \
 	tv.unregister \
+	tv.what.rast
 PGM = tgisintro
Modified: grass/trunk/temporal/t.time.abs/test.t.time.abs.file.sh
--- grass/trunk/temporal/t.time.abs/test.t.time.abs.file.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/t.time.abs/test.t.time.abs.file.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -17,7 +17,7 @@
 n2=`g.tempfile pid=2 -d` # Map names and start time
 n3=`g.tempfile pid=3 -d` # Map names start time and increment
-cat > $n1 << EOF
+cat > "${n1}" << EOF
 prec_1
 prec_2
 prec_3
@@ -25,9 +25,9 @@
 prec_5
 prec_6
 EOF
-cat $n1
+cat "${n1}"
-cat > $n2 << EOF
+cat > "${n2}" << EOF
 prec_1|2001-01-01
 prec_2|2001-02-01
 prec_3|2001-03-01
@@ -35,9 +35,9 @@
 prec_5|2001-05-01
 prec_6|2001-06-01
 EOF
-cat $n2
+cat "${n2}"
-cat > $n3 << EOF
+cat > "${n3}" << EOF
 prec_1|2001-01-01|2001-04-01
 prec_2|2001-04-01|2001-07-01
 prec_3|2001-07-01|2001-10-01
@@ -45,7 +45,7 @@
 prec_5|2002-01-01|2002-04-01
 prec_6|2002-04-01|2002-07-01
 EOF
-cat $n3
+cat "${n3}"
 # The first @test
 # We create the space time raster inputs and register the raster maps with absolute time interval
@@ -53,28 +53,28 @@
 # Test with input files
 # File 1
-t.time.abs file=$n1 start="2001-01-01" increment="1 months"
+t.time.abs file="${n1}" start="2001-01-01" increment="1 months"
-tr.register input=precip_abs8 file=$n1
+tr.register input=precip_abs8 file="${n1}"
 t.info type=strds input=precip_abs8
 tr.list input=precip_abs8
 # File 1
 # File 2
-t.time.abs file=$n2 start=file
+t.time.abs file="${n2}" start=file
 # File 2
-t.time.abs -i file=$n2 start=file increment="1 months"
+t.time.abs -i file="${n2}" start=file increment="1 months"
 # File 3
-t.time.abs file=$n3 start=file end=file
+t.time.abs file="${n3}" start=file end=file
 t.remove --v type=strds input=precip_abs8
-t.remove --v type=rast file=$n1
+t.remove --v type=rast file="${n1}"
Modified: grass/trunk/temporal/t.time.rel/t.time.rel.py
--- grass/trunk/temporal/t.time.rel/t.time.rel.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/t.time.rel/t.time.rel.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -33,24 +33,34 @@
 #%option
 #% key: start
-#% type: string
-#% description: The valid start value in [days] for all maps, or file in case the start time is located in the input file
+#% type: integer
+#% description: The valid integer start value for all maps, or file in case the start time is located in the input file
 #% required: no
 #% multiple: no
 #%end
 #%option
 #% key: end
+#% type: integer
+#% description: The valid integer end value for all maps, or file in case the start time is located in the input file
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: unit
 #% type: string
-#% description: The valid end value in [days] for all maps, or file in case the start time is located in the input file
+#% description: The unit of the relative time
 #% required: no
 #% multiple: no
+#% options: years,months,days,hours,minutes,seconds
+#% answer: days
 #%end
 #%option
 #% key: increment
-#% type: string
-#% description: Increment between maps for valid time interval creation in [days] e.g. 1.5
+#% type: integer
+#% description: Increment between maps for valid time interval creation
 #% required: no
 #% multiple: no
 #%end
@@ -100,13 +110,14 @@
     increment = options["increment"]
     fs = options["fs"]
     type = options["type"]
+    unit = options["unit"]
     interval = flags["i"]
     # Make sure the temporal database exists
     tgis.create_temporal_database()
     # Set valid absolute time to maps
     tgis.assign_valid_time_to_maps(type=type, maps=maps, ttype="relative", \
-                                   start=start, end=end, file=file, increment=increment, \
+                                   start=start, end=end, unit=unit, file=file, increment=increment, \
                                    dbif=None, interval=interval, fs=fs)
 if __name__ == "__main__":
Modified: grass/trunk/temporal/t.time.rel/test.t.time.rel.file.sh
--- grass/trunk/temporal/t.time.rel/test.t.time.rel.file.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/t.time.rel/test.t.time.rel.file.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -17,7 +17,7 @@
-cat > $n1 << EOF
 prec_1
 prec_2
 prec_3
@@ -25,9 +25,9 @@
 prec_5
 prec_6
 EOF
-cat $n1
+cat "${n1}"
-cat > $n2 << EOF
 prec_1|1
 prec_2|2
 prec_3|3
@@ -35,9 +35,9 @@
 prec_5|5
 prec_6|6
 EOF
-cat $n2
+cat "${n2}"
-cat > $n3 << EOF
 prec_1|1|4
 prec_2|4|7
 prec_3|7|10
@@ -45,7 +45,7 @@
 prec_5|11|14
 prec_6|14|17
 EOF
-cat $n3
+cat "${n3}"
 # The first @test
@@ -53,28 +53,28 @@
 # File 1
-t.time.rel -i file=$n1 start=20 increment=5
+t.time.rel -i file="${n1}" start=20 increment=5 unit=months
-tr.register input=precip_rel file=$n1
+tr.register input=precip_rel file="${n1}"
 t.info type=strds input=precip_rel
 tr.list input=precip_rel
 # File 1
-t.time.rel file=$n1 start=20
+t.time.rel file="${n1}" start=20 unit=months
 # File 2
-t.time.rel file=$n2 start=file
+t.time.rel file="${n2}" start=file unit=months
 # File 2
-t.time.rel -i file=$n2 start=file increment=5
+t.time.rel -i file="${n2}" start=file increment=5 unit=months
 # File 3
-t.time.rel file=$n3 start=file end=file
+t.time.rel file="${n3}" start=file end=file unit=months
 t.remove --v type=strds input=precip_rel
Modified: grass/trunk/temporal/t.time.rel/test.t.time.rel.sh
--- grass/trunk/temporal/t.time.rel/test.t.time.rel.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/t.time.rel/test.t.time.rel.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -13,33 +13,36 @@
 r.mapcalc --o expr="prec_5 = rand(0, 300)"
 r.mapcalc --o expr="prec_6 = rand(0, 650)"
-t.create --v --o type=strds temporaltype=relative output=precip_rel1 title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=relative output=precip_rel1 title="A test" descr="A test"
 t.create --v --o type=strds temporaltype=relative output=precip_rel2 title="A test" descr="A test"
 t.create --v --o type=strds temporaltype=relative output=precip_rel3 title="A test" descr="A test"
-t.time.rel --v input=prec_1,prec_2,prec_3 start=5 increment=2
+t.time.rel --v input=prec_1,prec_2,prec_3 start=5 increment=2 unit=days
 t.info type=rast input=prec_1
+r.info map=prec_1
 t.info type=rast input=prec_2
+r.info map=prec_2
 t.info type=rast input=prec_3
+r.info map=prec_3
-tr.register --v input=precip_rel1 maps=prec_1,prec_2,prec_3
-tr.register --v input=precip_rel2 maps=prec_1,prec_2,prec_3
-tr.register --v input=precip_rel3 maps=prec_1,prec_2,prec_3
+tr.register --v input=precip_rel1 maps=prec_1,prec_2,prec_3 unit=days
+tr.register --v input=precip_rel2 maps=prec_1,prec_2,prec_3 unit=days
+tr.register --v input=precip_rel3 maps=prec_1,prec_2,prec_3 unit=days
 # Check if the space time inputs are updated correctly
-t.time.rel --v input=prec_1,prec_2,prec_3 start=0 increment=1000
+t.time.rel --v input=prec_1,prec_2,prec_3 start=0 increment=1000 unit=days
 t.info type=strds input=precip_rel1
 t.topology type=strds input=precip_rel1
 t.topology -m type=strds input=precip_rel1
-t.time.rel --v -i input=prec_1,prec_2,prec_3 start=0 increment=1000 -i
+t.time.rel --v -i input=prec_1,prec_2,prec_3 start=0 increment=1000 unit=days
-t.time.rel --v input=prec_4,prec_5 start=5000 end=6000
+t.time.rel --v input=prec_4,prec_5 start=5000 end=6000 unit=days
 t.info type=rast input=prec_4
 t.info type=rast input=prec_5
-t.time.rel --v input=prec_6 start=6000
+t.time.rel --v input=prec_6 start=6000 unit=days
 t.info type=rast input=prec_6
 t.remove --v type=rast input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.topology/test.t.topology.abstime.sh
--- grass/trunk/temporal/t.topology/test.t.topology.abstime.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/t.topology/test.t.topology.abstime.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -23,7 +23,7 @@
 n4=`g.tempfile pid=4 -d`
 n5=`g.tempfile pid=5 -d`
-cat > $n1 << EOF
 prec_1
 prec_2
 prec_3
@@ -32,7 +32,7 @@
 prec_6
 EOF
-cat > $n2 << EOF
 prec_1|2001-01-01
 prec_2|2001-02-01
 prec_3|2001-03-01
@@ -41,7 +41,7 @@
 prec_6|2001-06-01
 EOF
-cat > $n3 << EOF
 prec_2|2001-05-01|2001-07-01
 prec_3|2001-08-01|2001-10-01
@@ -50,7 +50,7 @@
 prec_6|2002-05-01|2002-07-01
 EOF
-cat > $n4 << EOF
+cat > "${n4}" << EOF
 prec_1|2001-01-01|2001-07-01
 prec_2|2001-02-01|2001-04-01
 prec_3|2001-03-01|2001-04-01
@@ -59,7 +59,7 @@
 prec_6|2001-06-01|2001-07-01
 EOF
-cat > $n5 << EOF
+cat > "${n5}" << EOF
 prec_1|2001-01-01|2001-03-11
 prec_3|2001-03-01|2001-06-02
@@ -73,30 +73,30 @@
 t.create --o type=strds temporaltype=absolute output=precip_abs title="A test with input files" descr="A test with input files"
-tr.register -i input=precip_abs file=$n1 start="2001-01-01" increment="1 months"
-cat $n1
+tr.register -i input=precip_abs file="${n1}" start="2001-01-01" increment="1 months"
+cat "${n1}"
 t.topology    input=precip_abs
 t.topology -m input=precip_abs
-tr.register -i input=precip_abs file=$n2 start=file
-cat $n2
+tr.register -i input=precip_abs file="${n2}" start=file
+cat "${n2}"
-tr.register -i input=precip_abs file=$n3 start=file end=file
-cat $n3
+tr.register -i input=precip_abs file="${n3}" start=file end=file
+cat "${n3}"
-tr.register -i input=precip_abs file=$n4 start=file end=file
-cat $n4
+tr.register -i input=precip_abs file="${n4}" start=file end=file
+cat "${n4}"
-tr.register -i input=precip_abs file=$n5 start=file end=file
-cat $n5
+tr.register -i input=precip_abs file="${n5}" start=file end=file
+cat "${n5}"
 t.remove type=strds input=precip_abs
-t.remove type=rast file=$n1
+t.remove type=rast file="${n1}"
Modified: grass/trunk/temporal/t.topology/test.t.topology.reltime.sh
--- grass/trunk/temporal/t.topology/test.t.topology.reltime.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/t.topology/test.t.topology.reltime.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -23,7 +23,7 @@
-cat > $n1 << EOF
 prec_1
 prec_2
 prec_3
@@ -32,7 +32,7 @@
 prec_6
 EOF
-cat > $n2 << EOF
 prec_1|1
 prec_2|2
 prec_3|3
@@ -41,7 +41,7 @@
 prec_6|6
 EOF
-cat > $n3 << EOF
 prec_1|1|4
 prec_2|5|7
 prec_3|8|10
@@ -50,7 +50,7 @@
 prec_6|15|25
 EOF
-cat > $n4 << EOF
 prec_1|2001|2007
 prec_2|2002|2004
 prec_3|2003|2004
@@ -59,7 +59,7 @@
 prec_6|2006|2007
 EOF
-cat > $n5 << EOF
 prec_1|2001|2003
 prec_2|2002|2004
 prec_3|2003|2006
@@ -71,32 +71,34 @@
 # The first @test
 # We create the space time raster inputs and register the raster maps with relolute time interval
-t.create --o type=strds temporaltype=relative output=precip_rel title="A test with input files" descr="A test with input files"
+t.create --o type=strds temporaltype=relative output=precip_rel_d title="A test with input files of unti days" descr="A test with input files"
+t.create --o type=strds temporaltype=relative output=precip_rel_y title="A test with input files of unit years" descr="A test with input files"
-tr.register -i --v input=precip_rel file=$n1 start=0 increment=1
-cat $n1
-t.topology    input=precip_rel
-t.topology -m input=precip_rel
+tr.register -i --v input=precip_rel_d file="${n1}" start=0 increment=1 unit=days
+cat "${n1}"
+t.topology    input=precip_rel_d
+t.topology -m input=precip_rel_d
-tr.register -i input=precip_rel file=$n2 start=file
-cat $n2
+tr.register -i input=precip_rel_d file="${n2}" start=file unit=days
+cat "${n2}"
-tr.register -i input=precip_rel file=$n3 start=file end=file
-cat $n3
+tr.register -i input=precip_rel_d file="${n3}" start=file end=file unit=days
+cat "${n3}"
-tr.register -i input=precip_rel file=$n4 start=file end=file
-cat $n4
+tr.register -i input=precip_rel_y file="${n4}" start=file end=file unit=years
+cat "${n4}"
+t.topology    input=precip_rel_y
+t.topology -m input=precip_rel_y
-tr.register -i input=precip_rel file=$n5 start=file end=file
-cat $n5
+tr.register -i input=precip_rel_y file="${n5}" start=file end=file unit=years
+cat "${n5}"
-t.remove type=strds input=precip_rel
+t.remove type=strds input=precip_rel_d
+t.remove type=strds input=precip_rel_y
Added: grass/trunk/temporal/tr.aggregate/test.tr.aggregate.relative_time.sh
--- grass/trunk/temporal/tr.aggregate/test.tr.aggregate.relative_time.sh	                        (rev 0)
+++ grass/trunk/temporal/tr.aggregate/test.tr.aggregate.relative_time.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -0,0 +1,30 @@
+# Test the extraction of a subset of a space time raster input
+# We need to set a specific region in the
+# @preprocess step of this test.
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+# Data generation
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=strds temporaltype=relative output=precip_abs1 title="A test" descr="A test"
+tr.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start=0 unit=days increment=3
+# The first @test
+tr.aggregate --o --v input=precip_abs1 output=precip_abs2 base=prec_sum granularity=6 method=average sampling=start,during
+t.info type=strds input=precip_abs2
+tr.aggregate --o --v input=precip_abs1 output=precip_abs2 base=prec_sum granularity=9 method=maximum sampling=start,during
+tr.aggregate --o --v input=precip_abs1 output=precip_abs2 base=prec_sum granularity=4 method=minimum sampling=start,during
+tr.aggregate --o --v input=precip_abs1 output=precip_abs2 base=prec_sum granularity=5 method=sum sampling=start,during
+t.remove type=rast input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs1,precip_abs2
Modified: grass/trunk/temporal/tr.aggregate/test.tr.aggregate.sh
--- grass/trunk/temporal/tr.aggregate/test.tr.aggregate.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.aggregate/test.tr.aggregate.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -1,12 +1,10 @@
-# @preprocess step of this test. We generate
-# raster with r.mapcalc and create two space time raster inputs
-# with relative and absolute time
+# Generate data
Modified: grass/trunk/temporal/tr.aggregate/tr.aggregate.py
--- grass/trunk/temporal/tr.aggregate/tr.aggregate.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.aggregate/tr.aggregate.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -145,7 +145,12 @@
             grass.fatal(_("Space time raster dataset <%s> is empty") % out_id)
     # Modify the start time to fit the granularity
-    first_start_time = tgis.adjust_datetime_to_granularity( rows[0]["start_time"], gran)
+    if sp.is_time_absolute():
+        first_start_time = tgis.adjust_datetime_to_granularity( rows[0]["start_time"], gran)
+    else:
+        first_start_time = rows[0]["start_time"]
     last_start_time = rows[len(rows) - 1]["start_time"]
     next_start_time = first_start_time
@@ -155,13 +160,13 @@
             end = tgis.increment_datetime_by_string(next_start_time, gran)
         else:
-            end = next_start_time + gran
+            end = next_start_time + int(gran)
         next_start_time = end
         input_map_names = tgis.collect_map_names(sp, dbif, start, end, sampling)
         if input_map_names:
-            tgis.aggregate_raster_maps(new_sp, mapset, input_map_names, base, start, end, count, method, register_null, dbif)
+            tgis.aggregate_raster_maps(sp, new_sp, mapset, input_map_names, base, start, end, count, method, register_null, dbif)
         count += 1
Modified: grass/trunk/temporal/tr.aggregate.ds/test.tr.aggregate.ds.sh
--- grass/trunk/temporal/tr.aggregate.ds/test.tr.aggregate.ds.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.aggregate.ds/test.tr.aggregate.ds.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -20,14 +20,14 @@
 n1=`g.tempfile pid=1 -d`
-cat > $n1 << EOF
 soil_1|2001-01-01|2001-04-01
 soil_2|2001-05-01|2001-07-01
 soil_3|2001-08-01|2001-12-01
 EOF
 t.create --o type=stvds temporaltype=absolute output=soil_abs1 title="A test" descr="A test"
-tv.register input=soil_abs1 file="$n1" start=file end=file
+tv.register input=soil_abs1 file="${n1}" start=file end=file
 t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
 tr.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
Modified: grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py
--- grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -186,8 +186,7 @@
         if input_map_names:
     # Update the spatio-temporal extent and the raster metadata table entries
     new_sp.update_from_registered_maps(dbif)
Modified: grass/trunk/temporal/tr.export/test.tr.export.sh
--- grass/trunk/temporal/tr.export/test.tr.export.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.export/test.tr.export.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -15,7 +15,7 @@
-cat > $n1 << EOF
@@ -27,7 +27,7 @@
 t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test with input files" descr="A test with input files"
 # The first @test
-tr.register -i input=precip_abs1 file=$n1 start="2001-01-01" increment="1 months"
+tr.register -i input=precip_abs1 file="${n1}" start="2001-01-01" increment="1 months"
 tr.export input=precip_abs1 output=strds_export.tar.bz2 compression=bzip2 workdir=/tmp
Modified: grass/trunk/temporal/tr.list/test.tr.list.sh
--- grass/trunk/temporal/tr.list/test.tr.list.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.list/test.tr.list.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -19,7 +19,7 @@
-cat > $n1 << EOF
 prec_1
 prec_2
 prec_3
@@ -28,7 +28,7 @@
 prec_6
 EOF
-cat > $n2 << EOF
 prec_1|2001-01-01
 prec_2|2001-02-01
 prec_3|2001-03-01
@@ -37,7 +37,7 @@
 prec_6|2001-06-01
 EOF
-cat > $n3 << EOF
@@ -46,7 +46,7 @@
 EOF
-cat > $n4 << EOF
@@ -55,7 +55,7 @@
 EOF
-cat > $n5 << EOF
@@ -72,7 +72,7 @@
 t.create --o type=strds temporaltype=absolute output=precip_abs5 title="A test with input files" descr="A test with input files"
 # The @test
-tr.register -i input=precip_abs0 file=$n1 start="2001-01-01" increment="1 months"
+tr.register -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
 tr.list    fs=" | " method=comma     input=precip_abs0
 tr.list -h input=precip_abs1
 tr.list -h fs=" | " method=cols      input=precip_abs0
@@ -80,7 +80,7 @@
 tr.list -h fs=" | " method=deltagaps input=precip_abs0
 tr.list -h fs=" | " method=gran      input=precip_abs0
-tr.register    input=precip_abs1 file=$n1 start="2001-01-01" increment="1 months"
+tr.register    input=precip_abs1 file="${n1}" start="2001-01-01" increment="1 months"
 tr.list    fs=" | " method=comma     input=precip_abs1
 tr.list -h fs=" | " method=cols      input=precip_abs1
@@ -88,7 +88,7 @@
 tr.list -h fs=" | " method=deltagaps input=precip_abs1
 tr.list -h fs=" | " method=gran      input=precip_abs1
-tr.register -i input=precip_abs2 file=$n2 start=file
+tr.register -i input=precip_abs2 file="${n2}" start=file
 tr.list    fs=" | " method=comma     input=precip_abs2
 tr.list -h input=precip_abs2
 tr.list -h fs=" | " method=cols      input=precip_abs2
@@ -96,19 +96,19 @@
 tr.list -h fs=" | " method=deltagaps input=precip_abs2
 tr.list -h fs=" | " method=gran      input=precip_abs2
-tr.register -i input=precip_abs3 file=$n3 start=file end=file
+tr.register -i input=precip_abs3 file="${n3}" start=file end=file
 tr.list    fs=" | " method=comma     input=precip_abs3
 tr.list -h fs=" | " method=delta     input=precip_abs3
 tr.list -h fs=" | " method=deltagaps input=precip_abs3
 tr.list -h fs=" | " method=gran      input=precip_abs3
-tr.register -i input=precip_abs4 file=$n4 start=file end=file
+tr.register -i input=precip_abs4 file="${n4}" start=file end=file
 tr.list    fs=" | " method=comma     input=precip_abs4
 tr.list -h fs=" | " method=delta     input=precip_abs4
 tr.list -h fs=" | " method=deltagaps input=precip_abs4
 tr.list -h fs=" | " method=gran      input=precip_abs4
-tr.register -i input=precip_abs5 file=$n5 start=file end=file
+tr.register -i input=precip_abs5 file="${n5}" start=file end=file
 tr.list    fs=" | " method=comma     input=precip_abs5
 tr.list -h input=precip_abs5
 tr.list -h fs=" | " method=cols      input=precip_abs5
Modified: grass/trunk/temporal/tr.register/ECAD_climate_analysis_1995_2010.py
--- grass/trunk/temporal/tr.register/ECAD_climate_analysis_1995_2010.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.register/ECAD_climate_analysis_1995_2010.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -6,16 +6,16 @@
 # You need to download the european climate date from the ECA&D server http://eca.knmi.nl/ as netCDF time series
 # We only use the data from 1995 - 2010
 # First import the ECA&D data into GRASS GIS
-input = "tg_0.25deg_reg_1995-2010_v4.0.nc"
+input = "tg_0.25deg_reg_1995-2011_v5.0.nc"
 output = "temp_mean"
 grass.run_command("r.in.gdal", flags="e", input=input, output=output, overwrite=True)
-input = "tn_0.25deg_reg_1995-2010_v4.0.nc"
+input = "tn_0.25deg_reg_1995-2011_v5.0.nc"
 output = "temp_min"
-input = "tx_0.25deg_reg_1995-2010_v4.0.nc"
+input = "tx_0.25deg_reg_1995-2011_v5.0.nc"
 output = "temp_max"
-input = "rr_0.25deg_reg_1995-2010_v4.0.nc"
+input = "rr_0.25deg_reg_1995-2011_v5.0.nc"
 output = "precip"
@@ -25,12 +25,12 @@
 # Daily mean temperatue
-dataset = "temp_mean_1995_2010_daily"
+dataset = "temp_mean_1995_2011_daily"
 grass.run_command("t.create", type="strds", output=dataset,\
                   semantic="continuous", temporal="absolute", \
-		  title="European mean temperature 1995-2010", \
-		  description="The european daily mean temperature 1995 - 2010 from ECA&D ", \
+		  title="European mean temperature 1995-2011", \
+		  description="The european daily mean temperature 1995 - 2011 from ECA&D ", \
 		  overwrite=True)
 name = "temp_mean."
Modified: grass/trunk/temporal/tr.register/test.tr.register.file.sh
--- grass/trunk/temporal/tr.register/test.tr.register.file.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.register/test.tr.register.file.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -21,7 +21,7 @@
-cat > $n1 << EOF
 prec_1
 prec_2
 prec_3
@@ -29,9 +29,9 @@
 prec_5
 prec_6
 EOF
-cat $n1
+cat "${n1}"
-cat > $n2 << EOF
 prec_1|2001-01-01
 prec_2|2001-02-01
 prec_3|2001-03-01
@@ -39,9 +39,9 @@
 prec_5|2001-05-01
 prec_6|2001-06-01
 EOF
-cat $n2
+cat "${n2}"
-cat > $n3 << EOF
@@ -49,7 +49,7 @@
 EOF
-cat $n3
+cat "${n3}"
 # The first @test
@@ -57,25 +57,25 @@
 # File 1
-tr.register -i input=precip_abs8 file=$n1 start="2001-01-01" increment="1 months"
+tr.register -i input=precip_abs8 file="${n1}" start="2001-01-01" increment="1 months"
 # File 1
-tr.register input=precip_abs8 file=$n1 start="2001-01-01"
+tr.register input=precip_abs8 file="${n1}" start="2001-01-01"
 # File 2
-tr.register input=precip_abs8 file=$n2 start=file
+tr.register input=precip_abs8 file="${n2}" start=file
 # File 2
-tr.register input=precip_abs8 file=$n2 start=file increment="1 months"
+tr.register input=precip_abs8 file="${n2}" start=file increment="1 months"
 # File 3
-tr.register -i input=precip_abs8 file=$n3 start=file end=file
+tr.register -i input=precip_abs8 file="${n3}" start=file end=file
Modified: grass/trunk/temporal/tr.register/tr.register.py
--- grass/trunk/temporal/tr.register/tr.register.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.register/tr.register.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -61,9 +61,19 @@
 #%end
 #%option
+#% key: unit
+#% type: string
+#% required: no
+#% multiple: no
+#% answer: days
+#%end
+#%option
 #% key: increment
 #% type: string
-#% description: Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0), or "file" in case the increment is located in an input file
+#% description: Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer: 5), or "file" in case the increment is located in an input file
 #% required: no
 #% multiple: no
 #%end
@@ -95,6 +105,7 @@
     fs = options["fs"]
     start = options["start"]
     end = options["end"]
@@ -102,7 +113,7 @@
     # Register maps
     tgis.register_maps_in_space_time_dataset(type="strds", name=name, maps=maps, file=file, start=start, end=end, \
-                                             increment=increment, dbif=None, interval=interval, fs=fs)
+                                             unit=unit, increment=increment, dbif=None, interval=interval, fs=fs)
     options, flags = grass.parser()
Modified: grass/trunk/temporal/tr.series/tr.series.py
--- grass/trunk/temporal/tr.series/tr.series.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.series/tr.series.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -120,12 +120,14 @@
                 id = output + "@" + mapset
             map = sp.get_new_map_instance(id)
+            map.load()
-            map.load()
                 map.set_absolute_time(start_time, end_time, tz)
+                map.write_absolute_time_to_file()
             else:
                 map.set_relative_time(start_time, end_time)
+                map.write_relative_time_to_file()
             # Register the map in the temporal database
             if map.is_in_db():
Modified: grass/trunk/temporal/tr.univar/test.tr.univar.sh
--- grass/trunk/temporal/tr.univar/test.tr.univar.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr.univar/test.tr.univar.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -1,12 +1,10 @@
+# Data generation
@@ -21,4 +19,4 @@
 tr.univar -he input=precip_abs1
-t.remove type=strds input=precip_abs1,precip_abs2
Modified: grass/trunk/temporal/tr3.register/test.tr3.register.sh
--- grass/trunk/temporal/tr3.register/test.tr3.register.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr3.register/test.tr3.register.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -35,6 +35,12 @@
 tr3.register --v -i input=volume_abs2 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 seconds, 5 minutes"
 t.info type=str3ds input=volume_abs2
+r3.info volume_1
+r3.info volume_2
+r3.info volume_3
+r3.info volume_4
+r3.info volume_5
+r3.info volume_6
 tr3.register --v -i input=volume_abs3 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="8 hours"
 t.info type=str3ds input=volume_abs3
Modified: grass/trunk/temporal/tr3.register/tr3.register.py
--- grass/trunk/temporal/tr3.register/tr3.register.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tr3.register/tr3.register.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -61,9 +61,19 @@
 #%end
 #%option
+#% key: unit
+#% type: string
+#% required: no
+#% multiple: no
+#% answer: days
+#%end
+#%option
 #% key: increment
 #% type: string
 #% required: no
 #% multiple: no
 #%end
@@ -95,6 +105,7 @@
     fs = options["fs"]
@@ -102,7 +113,7 @@
     # Register maps
     tgis.register_maps_in_space_time_dataset(type="str3ds", name=name, maps=maps, file=file, start=start, end=end, \
Modified: grass/trunk/temporal/tv.list/test.tv.list.sh
--- grass/trunk/temporal/tv.list/test.tv.list.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tv.list/test.tv.list.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -1,8 +1,7 @@
 # This is a test to list vecter maps of a space time vecter dataset
-# vecter with r.mapcalc and create a space time vecter datasets
@@ -19,7 +18,7 @@
-cat > $n1 << EOF
 lidar_1
 lidar_2
 lidar_3
@@ -28,7 +27,7 @@
 lidar_6
 EOF
-cat > $n2 << EOF
 lidar_1|2001-01-01
 lidar_2|2001-02-01
 lidar_3|2001-03-01
@@ -37,7 +36,7 @@
 lidar_6|2001-06-01
 EOF
-cat > $n3 << EOF
 lidar_1|2001-01-01|2001-04-01
 lidar_2|2001-05-01|2001-07-01
 lidar_3|2001-08-01|2001-10-01
@@ -46,7 +45,7 @@
 lidar_6|2002-05-01|2002-07-01
 EOF
-cat > $n4 << EOF
 lidar_1|2001-01-01|2001-07-01
 lidar_2|2001-02-01|2001-04-01
 lidar_3|2001-03-01|2001-04-01
@@ -55,7 +54,7 @@
 lidar_6|2001-06-01|2001-07-01
 EOF
-cat > $n5 << EOF
 lidar_1|2001-01-01|2001-03-11
 lidar_3|2001-03-01|2001-06-02
@@ -71,31 +70,31 @@
 t.create --o type=stvds temporaltype=absolute output=lidar_abs5 title="A test with input files" descr="A test with input files"
 # The first @test
-tv.register    input=lidar_abs1 file=$n1 start="2001-01-01" increment="1 months"
+tv.register    input=lidar_abs1 file="${n1}" start="2001-01-01" increment="1 months"
 tv.list    fs=" | " method=comma     input=lidar_abs1
 tv.list -h input=lidar_abs1
 tv.list -h fs=" | " method=cols      input=lidar_abs1
 tv.list -h fs=" | " method=delta     input=lidar_abs1
 tv.list -h fs=" | " method=deltagaps input=lidar_abs1
-tv.register -i input=lidar_abs2 file=$n2 start=file
+tv.register -i input=lidar_abs2 file="${n2}" start=file
 tv.list    fs=" | " method=comma     input=lidar_abs2
 tv.list -h input=lidar_abs2
 tv.list -h fs=" | " method=cols      input=lidar_abs2
 tv.list -h fs=" | " method=delta     input=lidar_abs2
 tv.list -h fs=" | " method=deltagaps input=lidar_abs2
-tv.register -i input=lidar_abs3 file=$n3 start=file end=file
+tv.register -i input=lidar_abs3 file="${n3}" start=file end=file
 tv.list    fs=" | " method=comma     input=lidar_abs3
 tv.list -h fs=" | " method=delta     input=lidar_abs3
 tv.list -h fs=" | " method=deltagaps input=lidar_abs3
-tv.register -i input=lidar_abs4 file=$n4 start=file end=file
+tv.register -i input=lidar_abs4 file="${n4}" start=file end=file
 tv.list    fs=" | " method=comma     input=lidar_abs4
 tv.list -h fs=" | " method=delta     input=lidar_abs4
 tv.list -h fs=" | " method=deltagaps input=lidar_abs4
-tv.register -i input=lidar_abs5 file=$n5 start=file end=file
+tv.register -i input=lidar_abs5 file="${n5}" start=file end=file
 tv.list    fs=" | " method=comma     input=lidar_abs5
 tv.list -h input=lidar_abs5
 tv.list -h fs=" | " method=cols      input=lidar_abs5
Modified: grass/trunk/temporal/tv.register/tv.register.py
--- grass/trunk/temporal/tv.register/tv.register.py	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tv.register/tv.register.py	2012-01-21 00:35:25 UTC (rev 50343)
@@ -61,9 +61,19 @@
 #%end
 #%option
+#% key: unit
+#% type: string
+#% required: no
+#% multiple: no
+#% answer: days
+#%end
+#%option
 #% key: increment
 #% type: string
 #% required: no
 #% multiple: no
 #%end
@@ -95,6 +105,7 @@
     fs = options["fs"]
@@ -102,7 +113,7 @@
     # Register maps
     tgis.register_maps_in_space_time_dataset(type="stvds", name=name, maps=maps, file=file, start=start, end=end, \
Modified: grass/trunk/temporal/tv.what.rast/test.tv.what.rast.sh
--- grass/trunk/temporal/tv.what.rast/test.tv.what.rast.sh	2012-01-20 22:10:54 UTC (rev 50342)
+++ grass/trunk/temporal/tv.what.rast/test.tv.what.rast.sh	2012-01-21 00:35:25 UTC (rev 50343)
@@ -17,14 +17,14 @@
-cat > $n1 << EOF
 EOF
