[GRASS-SVN] r50346 - grass/trunk/lib/db/dbmi_client
Sat Jan 21 07:35:22 EST 2012
Author: mmetz
Date: 2012-01-21 04:35:22 -0800 (Sat, 21 Jan 2012)
New Revision: 50346
   grass/trunk/lib/db/dbmi_client/column.c
db lib: fix memory leak
Modified: grass/trunk/lib/db/dbmi_client/column.c
--- grass/trunk/lib/db/dbmi_client/column.c	2012-01-21 12:31:27 UTC (rev 50345)
+++ grass/trunk/lib/db/dbmi_client/column.c	2012-01-21 12:35:22 UTC (rev 50346)
@@ -54,6 +54,8 @@
     dbString table_name;
     dbColumn *column;
     int ncol, cl, type;
+    type = -1;
     db_init_string(&table_name);
     db_set_string(&table_name, tab);
@@ -67,11 +69,13 @@
 	column = db_get_table_column(table, cl);
 	if (strcmp(db_get_column_name(column), col) == 0) {
 	    type = db_get_column_sqltype(column);
-	    return type;
+	    break;
+    db_free_table(table);
-    return -1;
+    return type;
