[GRASS-SVN] r50355 - grass/branches/develbranch_6/gui/wxpython/docs
Sat Jan 21 11:02:02 EST 2012
Author: martinl
Date: 2012-01-21 08:02:02 -0800 (Sat, 21 Jan 2012)
New Revision: 50355
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
wxGUI: note python/wxpython
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html	2012-01-21 15:53:30 UTC (rev 50354)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.html	2012-01-21 16:02:02 UTC (rev 50355)
@@ -1,41 +1,47 @@
 <h2>DESCRIPTION</h2>
-<b>wxGUI</b> is a new generation of the GUI for GRASS GIS. It's a successor
-of the <em><a href="gis.m.html">Tcl/Tk GUI</a></em> from GRASS 6.
+<b>wxGUI</b> is a new generation of the <em>Graphical User
+Interface</em> (GUI) for GRASS GIS written
+in <a href="http://www.python.org">Python</a>
+using <a href="http://www.wxpython.org">wxPython</a> library. It's a
+successor of the <em><a href="gis.m.html">Tcl/Tk GUI</a></em> from
+GRASS 6.
 <p>
 If wxGUI is not your default GUI, you can define it as default by
-typing at GRASS command line prompt
+typing at GRASS command line prompt:
 <div class="code"><pre>
-   g.gui -u wxpython
+g.gui -u wxpython
 </pre></div>
-or define in your <tt>.grassrc6</tt> file 'GRASS_GUI' variable
+Alternatively it may be defined in GISRC file
+(<tt>$HOME/.grassrc6</tt> on GNU/Linux, <tt>$APPDATA\GRASS6\grassrc6</tt>
+on MS Windows) by <tt>GRASS_GUI</tt> variable
-    GRASS_GUI: wxpython
+GRASS_GUI: wxpython
 </pre></div>
 The GUI can be quit by selecting the 'File->Exit' menu item. The GUI
 can be restarted from the GRASS command line prompt by typing
-    g.gui wxpython
+g.gui wxpython
 </pre></div>
-or  to restart with previously saved workspace type:
+To restart with previously saved workspace file:
-    g.gui wxpython workspace=file.gxw
+g.gui wxpython workspace=file.gxw
 </pre></div>
 <p>
-You can also start GRASS from the shell command line with wxGUI
-defined by the <tt>-wxpython</tt> switch:
+The user can also start GRASS from the shell command line with the wxGUI
+specifying the <tt>-gui</tt> (or <tt>-wxpython</tt>) switch:
-    grass64 -wxpython
+grass65 -gui
 </pre></div>
 <p>
