[GRASS-SVN] r50379 - grass/trunk/lib/db/dbmi_base
Sun Jan 22 03:30:59 EST 2012
Author: mmetz
Date: 2012-01-22 00:30:59 -0800 (Sun, 22 Jan 2012)
New Revision: 50379
   grass/trunk/lib/db/dbmi_base/string.c
fix r50370
Modified: grass/trunk/lib/db/dbmi_base/string.c
--- grass/trunk/lib/db/dbmi_base/string.c	2012-01-22 08:28:19 UTC (rev 50378)
+++ grass/trunk/lib/db/dbmi_base/string.c	2012-01-22 08:30:59 UTC (rev 50379)
@@ -104,7 +104,7 @@
     else {
 	db_free_string(x);
 	x->string = s;
-	x->nalloc = -1; /* fixme */
+	x->nalloc = -1;
     return DB_OK;
@@ -120,14 +120,9 @@
 int db_enlarge_string(dbString * x, int len)
-    if (x->nalloc <= 0) {
-	x->string = db_malloc(len * sizeof(char));
-	if (x->string == NULL)
-	    return DB_MEMORY_ERR;
-	x->nalloc = len;
-	strcpy(x->string, "");
-    else if (x->nalloc < len) {
+    if (x->nalloc < len) {
+	if (x->nalloc < 0)
+	    x->string = NULL;
 	x->string = db_realloc((void *)x->string, len);
@@ -155,7 +150,7 @@
 void db_free_string(dbString * x)
-    if (x->nalloc != 0)
+    if (x->nalloc > 0)
 	db_free(x->string);
     db_init_string(x);
@@ -213,10 +208,10 @@
     int len;
     int stat;
-    if (db_get_string(x))
-	len = strlen(db_get_string(x)) + strlen(s) + 1;
-    else
-	len = strlen(s) + 1;
+    if (!db_get_string(x))
+	return db_set_string(x, s);
+    len = strlen(db_get_string(x)) + strlen(s) + 1;
     stat = db_enlarge_string(x, len);
     if (stat != DB_OK)
 	return stat;
