[GRASS-SVN] r50403 - grass/branches/releasebranch_6_4/scripts/g.extension
Tue Jan 24 00:47:46 EST 2012
Author: hamish
Date: 2012-01-23 21:47:46 -0800 (Mon, 23 Jan 2012)
New Revision: 50403
   grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
add some whitespace to make the 'make won't work with spaces in pathnames' warning message less burried in the noise (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
--- grass/branches/releasebranch_6_4/scripts/g.extension/g.extension	2012-01-24 05:34:59 UTC (rev 50402)
+++ grass/branches/releasebranch_6_4/scripts/g.extension/g.extension	2012-01-24 05:47:46 UTC (rev 50403)
@@ -257,6 +257,7 @@
     g.message -w "The specified install path: [$PREFIX] contains a space. $GLOOM"
 fi
 if [ `echo "$TMPDIR" | grep -c ' '` -gt 0 ] ; then
+    # a problem because $MAPSET/.tmp/ is used as the compile dir
     g.message -w "The path to your GIS data: [`g.gisenv GISDBASE`] may contain a space. $GLOOM"
 fi
@@ -287,6 +288,7 @@
    exit 0
 fi
+g.message message=""
 g.message -d "svn co [$SVNURL_ADDONS]/[$MODULECLASS]/[$MODULE]"
 cd "$TMPDIR"
