[GRASS-SVN] r50443 - in grass/trunk/db/drivers: dbf mysql odbc ogr postgres sqlite
Wed Jan 25 09:06:13 EST 2012
Author: martinl
Date: 2012-01-25 06:06:13 -0800 (Wed, 25 Jan 2012)
New Revision: 50443
   grass/trunk/db/drivers/dbf/column.c
   grass/trunk/db/drivers/dbf/create_table.c
   grass/trunk/db/drivers/dbf/cursor.c
   grass/trunk/db/drivers/dbf/db.c
   grass/trunk/db/drivers/dbf/dbfexe.c
   grass/trunk/db/drivers/dbf/describe.c
   grass/trunk/db/drivers/dbf/driver.c
   grass/trunk/db/drivers/dbf/error.c
   grass/trunk/db/drivers/dbf/execute.c
   grass/trunk/db/drivers/dbf/main.c
   grass/trunk/db/drivers/dbf/proto.h
   grass/trunk/db/drivers/dbf/select.c
   grass/trunk/db/drivers/dbf/table.c
   grass/trunk/db/drivers/mysql/create_table.c
   grass/trunk/db/drivers/mysql/cursor.c
   grass/trunk/db/drivers/mysql/db.c
   grass/trunk/db/drivers/mysql/dbe.c
   grass/trunk/db/drivers/mysql/describe.c
   grass/trunk/db/drivers/mysql/error.c
   grass/trunk/db/drivers/mysql/execute.c
   grass/trunk/db/drivers/mysql/fetch.c
   grass/trunk/db/drivers/mysql/index.c
   grass/trunk/db/drivers/mysql/listtab.c
   grass/trunk/db/drivers/mysql/parse.c
   grass/trunk/db/drivers/mysql/proto.h
   grass/trunk/db/drivers/mysql/select.c
   grass/trunk/db/drivers/odbc/connect.c
   grass/trunk/db/drivers/odbc/create_table.c
   grass/trunk/db/drivers/odbc/cursor.c
   grass/trunk/db/drivers/odbc/db.c
   grass/trunk/db/drivers/odbc/describe.c
   grass/trunk/db/drivers/odbc/driver.c
   grass/trunk/db/drivers/odbc/error.c
   grass/trunk/db/drivers/odbc/execute.c
   grass/trunk/db/drivers/odbc/listdb.c
   grass/trunk/db/drivers/odbc/listtab.c
   grass/trunk/db/drivers/odbc/proto.h
   grass/trunk/db/drivers/odbc/select.c
   grass/trunk/db/drivers/odbc/table.c
   grass/trunk/db/drivers/ogr/cursor.c
   grass/trunk/db/drivers/ogr/db.c
   grass/trunk/db/drivers/ogr/describe.c
   grass/trunk/db/drivers/ogr/error.c
   grass/trunk/db/drivers/ogr/execute.c
   grass/trunk/db/drivers/ogr/fetch.c
   grass/trunk/db/drivers/ogr/listtab.c
   grass/trunk/db/drivers/ogr/proto.h
   grass/trunk/db/drivers/ogr/select.c
   grass/trunk/db/drivers/postgres/create_table.c
   grass/trunk/db/drivers/postgres/cursor.c
   grass/trunk/db/drivers/postgres/db.c
   grass/trunk/db/drivers/postgres/describe.c
   grass/trunk/db/drivers/postgres/error.c
   grass/trunk/db/drivers/postgres/execute.c
   grass/trunk/db/drivers/postgres/fetch.c
   grass/trunk/db/drivers/postgres/index.c
   grass/trunk/db/drivers/postgres/listdb.c
   grass/trunk/db/drivers/postgres/listtab.c
   grass/trunk/db/drivers/postgres/parse.c
   grass/trunk/db/drivers/postgres/priv.c
   grass/trunk/db/drivers/postgres/proto.h
   grass/trunk/db/drivers/postgres/select.c
   grass/trunk/db/drivers/sqlite/create_table.c
   grass/trunk/db/drivers/sqlite/cursor.c
   grass/trunk/db/drivers/sqlite/db.c
   grass/trunk/db/drivers/sqlite/describe.c
   grass/trunk/db/drivers/sqlite/error.c
   grass/trunk/db/drivers/sqlite/execute.c
   grass/trunk/db/drivers/sqlite/fetch.c
   grass/trunk/db/drivers/sqlite/index.c
   grass/trunk/db/drivers/sqlite/listtab.c
   grass/trunk/db/drivers/sqlite/proto.h
   grass/trunk/db/drivers/sqlite/select.c
DB drivers: use db_d_report_error() instead of its own mechanism
   	    i18n
Modified: grass/trunk/db/drivers/dbf/column.c
--- grass/trunk/db/drivers/dbf/column.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/column.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -20,6 +20,7 @@
 #include <dirent.h>
 #include <grass/dbmi.h>
 #include <grass/gis.h>
+#include <grass/glocale.h>
 #include "globals.h"
 #include "proto.h"
@@ -45,8 +46,9 @@
     /* Check if the column exists */
     for (c = 0; c < db.tables[tab].ncols; c++) {
 	if (G_strcasecmp(db.tables[tab].cols[c].name, name) == 0) {
-	    append_error("Column '%s' already exists (duplicate name)\n",
-			 name);
+	    db_d_append_error(_("Column '%s' already exists (duplicate name)"),
+			      name);
+	    db_d_report_error();
 	    return DB_FAILED;
@@ -94,7 +96,8 @@
     c = find_column(tab, name);
     if (c == -1) {
-	append_error("Column '%s' does not exist\n", name);
+	db_d_append_error(_("Column '%s' does not exist"), name);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/dbf/create_table.c
--- grass/trunk/db/drivers/dbf/create_table.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/create_table.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -1,4 +1,5 @@
 #include "proto.h"
@@ -18,8 +19,8 @@
     ret = execute(db_get_string(&sql), NULL);
     if (ret == DB_FAILED) {
-	append_error("Cannot create table");
-	report_error();
+	db_d_append_error(_("Unable to create table"));
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/dbf/cursor.c
--- grass/trunk/db/drivers/dbf/cursor.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/cursor.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -17,6 +17,7 @@
 #include <stdlib.h>
 #include "proto.h"
@@ -43,7 +44,8 @@
     /* allocate the cursor */
     c = (cursor *) db_malloc(sizeof(cursor));
     if (c == NULL) {
-	append_error("cannot alloc new cursor");
+	db_d_append_error(_("Unable to allocate new cursor"));
 	return c;
@@ -54,7 +56,8 @@
     if (c->token < 0) {
 	free_cursor(c);
 	c = NULL;
-	append_error("cannot tokenize new cursor\n");
+	db_d_append_error(_("Unable to tokenize new cursor"));
     return c;
Modified: grass/trunk/db/drivers/dbf/db.c
--- grass/trunk/db/drivers/dbf/db.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/db.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -22,6 +22,7 @@
 #include <errno.h>
 #include "proto.h"
@@ -89,14 +90,14 @@
 	    status = G_mkdir(db.name);
 	    if (status != 0) {	/* mkdir failed */
-		append_error("Cannot create dbf database: %s\n", name);
-		report_error();
+		db_d_append_error(_("Unable create DBF database: %s"), name);
 		return DB_FAILED;
 	else {			/* some other problem */
-	    append_error("Cannot open dbf database: %s\n", name);
-	    report_error();
+	    db_d_append_error(_("Unable to open DBF database: %s"), name);
 	    return DB_FAILED;
Modified: grass/trunk/db/drivers/dbf/dbfexe.c
--- grass/trunk/db/drivers/dbf/dbfexe.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/dbfexe.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -22,6 +22,7 @@
 #include <grass/shapefil.h>
 #include "proto.h"
@@ -67,8 +68,11 @@
     if (yyparse() != 0) {
 	G_free(tmpsql);
-	append_error("SQL parser error: %s\n", st->errmsg);
-	append_error("in statement:\n%s\n", sql);
+	db_d_append_error("%s (%s) %s\n%s\n",
+			  _("SQL parser error"),
+			  st->errmsg,
+			  _("in statement:"),
+			  sql);
 	sqpFreeStmt(st);
 	return DB_FAILED;
@@ -81,7 +85,7 @@
     /* find table */
     tab = find_table(st->table);
     if (tab < 0 && st->command != SQLP_CREATE) {
-	append_error("Table '%s' doesn't exist.\n", st->table);
+	db_d_append_error(_("Table '%s' doesn't exist."), st->table);
 	return DB_FAILED;
@@ -89,7 +93,7 @@
     if ((st->command != SQLP_CREATE)) {
 	ret = load_table_head(tab);
-	    append_error("Cannot load table head.\n");
+	    db_d_append_error(_("Unable to load table head."));
 	    return DB_FAILED;
@@ -99,8 +103,8 @@
 	(st->command == SQLP_ADD_COLUMN) || (st->command == SQLP_DROP_COLUMN)
 	if (db.tables[tab].write == FALSE) {
-	    append_error
-		("Cannot modify table, don't have write permission for DBF file.\n");
+	    db_d_append_error(_("Unable to modify table, "
+				"don't have write permission for DBF file."));
 	    return DB_FAILED;
@@ -114,7 +118,7 @@
 	    for (i = 0; i < ncols; i++) {
 		cols[i] = find_column(tab, st->Col[i].s);
 		if (cols[i] == -1) {
-		    append_error("Column '%s' not found\n", st->Col[i].s);
+		    db_d_append_error(_("Column '%s' not found"), st->Col[i].s);
 		    return DB_FAILED;
@@ -138,7 +142,7 @@
 		if ((dtype == DBF_INT && stype != SQLP_I)
 		    || (dtype == DBF_DOUBLE && stype == SQLP_S)
 		    || (dtype == DBF_CHAR && stype != SQLP_S)) {
-		    append_error("Incompatible value type.\n");
+		    db_d_append_error(_("Incompatible value type."));
 		    return DB_FAILED;
@@ -154,7 +158,7 @@
 	get_col_def(st, 0, &dtype, &width, &decimals);
 	ret = add_column(tab, dtype, st->Col[0].s, width, decimals);
-	    append_error("Cannot add column.\n");
+	    db_d_append_error(_("Unable to add column."));
 	    return DB_FAILED;
 	/* Add column to each row */
@@ -176,7 +180,7 @@
     case (SQLP_DROP_COLUMN):
 	load_table(tab);
 	if (drop_column(tab, st->Col[0].s) != DB_OK) {
-	    append_error("Cannot delete column.\n");
+	    db_d_append_error(_("Unable to delete column."));
 	    return DB_FAILED;
 	db.tables[tab].updated = TRUE;
@@ -184,7 +188,8 @@
     case (SQLP_CREATE):
 	if (tab >= 0) {
-	    append_error("Table %s already exists\n", st->table);
+	    db_d_append_error(_("Table %s already exists"), st->table);
 	    return DB_FAILED;
 	sprintf(name, "%s.dbf", st->table);
@@ -198,7 +203,7 @@
 	    get_col_def(st, i, &dtype, &width, &decimals);
 	    ret = add_column(tab, dtype, st->Col[i].s, width, decimals);
-		append_error("Cannot create table.\n");
+		db_d_append_error(_("Unable to create table."));
 		db.tables[tab].alive = FALSE;
 		return DB_FAILED;
@@ -255,7 +260,7 @@
 	c->ncols = ncols;
 	c->nrows = sel(st, tab, &(c->set));
 	if (c->nrows < 0) {
-	    append_error("Error in selecting rows\n");
+	    db_d_append_error(_("Error in selecting rows"));
 	    return DB_FAILED;
 	c->cur = -1;
@@ -265,7 +270,7 @@
     case (SQLP_UPDATE):
 	nrows = sel(st, tab, &selset);
 	if (nrows < 0) {
 	    return DB_FAILED;
 	dbrows = db.tables[tab].rows;
@@ -295,7 +300,7 @@
     case (SQLP_DELETE):
 	if (nrows < 0) {
 	    return DB_FAILED;
@@ -544,7 +549,7 @@
     ret = load_table(tab);
-	append_error("Cannot load table.\n");
+	db_d_append_error(_("Cannot load table."));
 	return -1;
@@ -559,12 +564,12 @@
 	G_debug(4, "node result type = %d", node_type);
 	if (node_type == -1) {
-	    append_error("Incompatible types in WHERE condition.\n");
+	    db_d_append_error(_("Incompatible types in WHERE condition."));
 	    return -1;
 	else if (node_type == SQLP_S || node_type == SQLP_I ||
 		 node_type == SQLP_D) {
-	    append_error("Result of WHERE condition is not of type BOOL.\n");
+	    db_d_append_error(_("Result of WHERE condition is not of type BOOL."));
 	    return -1;
 	else if (node_type == SQLP_NULL) {
@@ -580,8 +585,8 @@
 		G_debug(4, "condition = %d", condition);
 		if (condition == NODE_ERROR) {	/* e.g. division by 0 */
-		    append_error("Error in evaluation of WHERE condition.\n");
-		    return (-1);
+		    db_d_append_error(_("Error in evaluation of WHERE condition."));
+		    return -1;
 		else if (condition == NODE_TRUE) {	/* true */
 		    if (nset == aset) {
@@ -592,15 +597,14 @@
 		    nset++;
 		else if (condition != NODE_FALSE && condition != NODE_NULL) {	/* Should not happen */
-		    append_error("Unknown result (%d) of WHERE evaluation.\n",
-				 condition);
+		    db_d_append_error(_("Unknown result (%d) of WHERE evaluation"),
+				      condition);
 		    return -1;
 	else {			/* Should not happen */
-	    append_error
-		("Unknown WHERE condition type (bug in DBF driver).\n");
+	    db_d_append_error(_("Unknown WHERE condition type (bug in DBF driver)."));
 	    return -1;
@@ -626,7 +630,7 @@
 	if (cur_cmp_ocol < 0) {
-	    append_error("Cannot find order column '%s'\n", st->orderCol);
+	    db_d_append_error(_("Unable to find order column '%s'"), st->orderCol);
 	    return -1;
@@ -771,7 +775,7 @@
 		    dval = left_dval / right_dval;
 		else {
-		    append_error("Division by zero\n");
+		    db_d_append_error(_("Division by zero"));
 		    return NODE_ERROR;
 		break;
@@ -910,7 +914,7 @@
 		return NODE_TRUE;
 	    else if (left == NODE_VALUE || right == NODE_VALUE) {	/* Should not happen */
-		append_error("Value operand for AND\n");
+		db_d_append_error(_("Value operand for AND"));
 		return NODE_ERROR;
 	    else {
@@ -924,7 +928,7 @@
 		return NODE_TRUE;
-		append_error("Value operand for OR\n");
+		db_d_append_error(_("Value operand for OR"));
 		return NODE_ERROR;
 	    else {
@@ -939,7 +943,7 @@
 		return NODE_FALSE;
 	    else if (right == NODE_VALUE) {	/* Should not happen */
-		append_error("Value operand for NOT\n");
+		db_d_append_error(_("Value operand for NOT"));
 		return NODE_ERROR;
 	    else {
@@ -947,7 +951,7 @@
 	default:
-	    append_error("Unknown operator %d\n", nptr->oper);
+	    db_d_append_error(_("Unknown operator %d"), nptr->oper);
 	    return NODE_FALSE;
@@ -1016,8 +1020,8 @@
     case SQLP_NODE_COLUMN:
 	ccol = find_column(tab, nptr->column_name);
 	if (ccol == -1) {
-	    append_error("Column '%s' not found\n", nptr->column_name);
-	    return (-1);
+	    db_d_append_error(_("Column '%s' not found"), nptr->column_name);
+	    return -1;
 	col = &(db.tables[tab].cols[ccol]);
 	switch (col->type) {
@@ -1054,8 +1058,7 @@
 	case SQLP_MLTP:
 	case SQLP_DIV:
 	    if (left == SQLP_S || right == SQLP_S) {
-		append_error
-		    ("Arithmetical operation with strings is not allowed\n");
+		db_d_append_error(_("Arithmetical operation with strings is not allowed"));
 		return -1;
 	    else if (left == SQLP_NULL || right == SQLP_NULL) {
@@ -1077,8 +1080,7 @@
 	case SQLP_NE:
 	    if ((left == SQLP_S && (right == SQLP_I || right == SQLP_D)) ||
 		(right == SQLP_S && (left == SQLP_I || left == SQLP_D))) {
-		append_error
-		    ("Comparison between string and number is not allowed\n");
+		db_d_append_error(_("Comparison between string and number is not allowed"));
 		return -1;
@@ -1093,8 +1095,8 @@
 	case SQLP_GT:
 	case SQLP_GE:
-		append_error("Comparison '%s' between strings not allowed\n",
-			     sqpOperatorName(nptr->oper));
+		db_d_append_error(_("Comparison '%s' between strings not allowed"),
+				  sqpOperatorName(nptr->oper));
 		return -1;
@@ -1107,7 +1109,7 @@
 	case SQLP_MTCH:
 	    if (left == SQLP_I || left == SQLP_D || right == SQLP_I ||
 		right == SQLP_D) {
-		append_error("Match (~) between numbers not allowed\n");
+		db_d_append_error(_("Match (~) between numbers not allowed"));
 		return -1;
@@ -1146,7 +1148,7 @@
 	default:
 	    return -1;
Modified: grass/trunk/db/drivers/dbf/describe.c
--- grass/trunk/db/drivers/dbf/describe.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/describe.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -18,6 +18,7 @@
 #include <grass/datetime.h>
 #include "proto.h"
@@ -30,8 +31,9 @@
     tab = find_table(name);
     if (tab == -1) {
-	append_error("Table '%s' doesn't exist", db_get_string(table_name));
-	report_error();
+	db_d_append_error(_("Table '%s' doesn't exist"),
+			  db_get_string(table_name));
 	return DB_FAILED;
     describe_table(tab, NULL, 0, table);
Modified: grass/trunk/db/drivers/dbf/driver.c
--- grass/trunk/db/drivers/dbf/driver.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/driver.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -17,9 +17,11 @@
+#include "proto.h"
 int db__driver_init(int argc, char *argv[])
+    init_error();
     return DB_OK;
Modified: grass/trunk/db/drivers/dbf/error.c
--- grass/trunk/db/drivers/dbf/error.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/error.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -8,38 +8,5 @@
 /* init error message */
 void init_error(void)
-    if (!errMsg) {
-	errMsg = (dbString *) G_malloc(sizeof(dbString));
-	db_init_string(errMsg);
-    db_set_string(errMsg, "DBMI-DBF driver error:\n");
+    db_d_init_error("DBF");
-/* append error message */
-void append_error(const char *fmt, ...)
-    FILE *fp = NULL;
-    char *work = NULL;
-    int count = 0;
-    va_list ap;
-    va_start(ap, fmt);
-    if ((fp = tmpfile())) {
-	count = vfprintf(fp, fmt, ap);
-	if (count >= 0 && (work = G_calloc(count + 1, 1))) {
-	    rewind(fp);
-	    fread(work, 1, count, fp);
-	    db_append_string(errMsg, work);
-	    G_free(work);
-	fclose(fp);
-    va_end(ap);
-void report_error(void)
-    db_append_string(errMsg, "\n");
-    db_error(db_get_string(errMsg));
Modified: grass/trunk/db/drivers/dbf/execute.c
--- grass/trunk/db/drivers/dbf/execute.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/execute.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -15,6 +15,7 @@
 #include "proto.h"
@@ -28,8 +29,8 @@
     ret = execute(s, NULL);
-	append_error("Error in db_execute_immediate()");
-	report_error();
+	db_d_append_error(_("Unable to execute statement."));
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/dbf/main.c
--- grass/trunk/db/drivers/dbf/main.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/main.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -30,7 +30,6 @@
     char *name;
     init_dbdriver();
-    init_error();
     /* Do not call G_getenv() nor other functions reading GISRC here! It may be that grass variables are
      * not available here, but will be set in db_driver() */
Modified: grass/trunk/db/drivers/dbf/proto.h
--- grass/trunk/db/drivers/dbf/proto.h	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/proto.h	2012-01-25 14:06:13 UTC (rev 50443)
@@ -1,7 +1,5 @@
 /* error.c */
 void init_error(void);
-void append_error(const char *fmt, ...);
-void report_error(void);
 int save_string(VALUE *, char *);
Modified: grass/trunk/db/drivers/dbf/select.c
--- grass/trunk/db/drivers/dbf/select.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/select.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -17,6 +17,7 @@
 #include "proto.h"
@@ -40,8 +41,8 @@
     ret = execute(sql, c);
-	append_error("Error in db_open_select_cursor()");
-	report_error();
+	db_d_append_error(_("Unable to open cursor."));
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/dbf/table.c
--- grass/trunk/db/drivers/dbf/table.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/dbf/table.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -34,6 +34,7 @@
 #include "proto.h"
@@ -113,7 +114,7 @@
     /* load */
     dbf = DBFOpen(db.tables[t].file, "r");
     if (dbf == NULL) {
-	append_error("Cannot open dbf file.\n");
+	db_d_append_error(_("Unable to open DBF file."));
 	return DB_FAILED;
@@ -166,7 +167,7 @@
     if (dbf == NULL) {
 	return DB_FAILED;
@@ -305,7 +306,8 @@
     /* Copy */
     if (G_rename_file(name, db.tables[t].file)) {
-	append_error("Cannot move %s\nto %s\n", name, db.tables[t].file);
+	db_d_append_error(_("Unable to move '%s' to '%s'."),
+			    name, db.tables[t].file);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/mysql/create_table.c
--- grass/trunk/db/drivers/mysql/create_table.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/create_table.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -29,8 +29,6 @@
     G_debug(3, "db__driver_create_table()");
-    init_error();
     db_init_string(&sql);
     db_set_string(&sql, "CREATE TABLE ");
@@ -106,11 +104,11 @@
     G_debug(3, " SQL: %s", db_get_string(&sql));
     if (mysql_query(connection, db_get_string(&sql)) != 0) {
-	append_error("Cannot create table:\n");
-	append_error(db_get_string(&sql));
-	append_error("\n");
-	append_error(mysql_error(connection));
-	report_error();
+	db_d_append_error("%s\n%s\%s",
+			  _("Unable to create table:"),
+			  db_get_string(&sql),
+			  mysql_error(connection));
 	db_free_string(&sql);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/mysql/cursor.c
--- grass/trunk/db/drivers/mysql/cursor.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/cursor.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -22,8 +22,6 @@
     cursor *c;
-    init_error();
     /* get my cursor via the dbc token */
     c = (cursor *) db_find_token(db_get_cursor_token(dbc));
     if (c == NULL)
@@ -43,7 +41,7 @@
     if (c == NULL) {
-	append_error(_("Cannot allocate cursor."));
+	db_d_append_error(_("Unable allocate cursor."));
 	return NULL;
@@ -52,7 +50,7 @@
     /* tokenize it */
     c->token = db_new_token(c);
     if (c->token < 0) {
-	append_error(_("Cannot ad new token."));
+	db_d_append_error(_("Unable to add dnew token."));
 	return NULL;
Modified: grass/trunk/db/drivers/mysql/db.c
--- grass/trunk/db/drivers/mysql/db.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/db.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -25,7 +25,6 @@
     dbConnection default_connection;
     MYSQL *res;
-    init_error();
     db_get_connection(&default_connection);
     name = db_get_handle_dbname(handle);
@@ -42,7 +41,7 @@
 	CONNPAR connpar;
 	if (parse_conn(name, &connpar) == DB_FAILED) {
-	    report_error();
 	    return DB_FAILED;
@@ -58,9 +57,10 @@
 				 connpar.dbname, connpar.port, NULL, 0);
 	if (res == NULL) {
-	    append_error(_("Cannot connect to MySQL: "));
-	    report_error();
+	    db_d_append_error("%s\n%s",
+			      _("Connection failed."),
 	    return DB_FAILED;
@@ -70,7 +70,6 @@
 int db__driver_close_database(void)
-    init_error();
     mysql_close(connection);	/* this will also release connection */
     return DB_OK;
Modified: grass/trunk/db/drivers/mysql/dbe.c
--- grass/trunk/db/drivers/mysql/dbe.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/dbe.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -25,7 +25,6 @@
     MYSQL *res;
-    init_error();
     name = G_store(db_get_handle_dbname(handle));
@@ -43,7 +42,7 @@
 	char *buf;
 	if (!replace_variables(name, &datadir, &database)) {
-	    append_error(_("Cannot parse MySQL embedded database name"));
+	    append_error(_("Unable parse MySQL embedded database name"));
 	    report_error();
 	    return DB_FAILED;
@@ -78,7 +77,7 @@
 	free(database);
 	if (res == NULL) {
-	    append_error(_("Cannot connect to MySQL embedded server: "));
+	    append_error(_("Unable to connect to MySQL embedded server: "));
 	    report_error();
 	    return DB_FAILED;
@@ -90,7 +89,6 @@
-    init_error();
     mysql_server_end();
Modified: grass/trunk/db/drivers/mysql/describe.c
--- grass/trunk/db/drivers/mysql/describe.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/describe.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -28,26 +28,27 @@
     db_append_string(&sql, " where 1 = 0");
-	report_error();
+	db_d_append_error("%s\n%s\n%s",
+			  _("Unable to describe table:"),
 	return DB_FAILED;
     res = mysql_store_result(connection);
     if (res == NULL) {
-	report_error();
 	return DB_FAILED;
     if (describe_table(res, table, NULL) == DB_FAILED) {
-	append_error("Cannot describe table\n");
-	report_error();
+	db_d_append_error(_("Unable to describe table"));
 	mysql_free_result(res);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/mysql/error.c
--- grass/trunk/db/drivers/mysql/error.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/error.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -13,7 +13,6 @@
-#include <grass/glocale.h>
 #include "proto.h"
@@ -21,22 +20,5 @@
-    if (!errMsg) {
-    db_set_string(errMsg, _("DBMI-MySQL driver error:\n"));
+    db_d_init_error("MySQL");
-void append_error(const char *msg)
-    db_append_string(errMsg, (char *)msg);
Modified: grass/trunk/db/drivers/mysql/execute.c
--- grass/trunk/db/drivers/mysql/execute.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/execute.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -22,8 +22,6 @@
     char *str;
-    init_error();
     /* In addition to standard escape character ' (apostrophe)
      * MySQL supports also \ (backslash). Because this is not SQL
      * standard, GRASS modules cannot escape all \ in the text
@@ -39,11 +37,11 @@
     G_debug(3, "Escaped SQL: %s", str);
     if (mysql_query(connection, str) != 0) {
-	append_error("Cannot execute: \n");
-	append_error(str);
-	report_error();
+			  _("Unable to execute:"),
+			  str,
 	if (str)
 	    G_free(str);
 	return DB_FAILED;
@@ -59,12 +57,11 @@
     G_debug(2, "mysql: START TRANSACTION");
-    init_error();
     if (mysql_query(connection, "START TRANSACTION") != 0) {
-	append_error("Cannot start transaction: \n");
-	report_error();
+	db_d_append_error("%s %s",
+			  _("Unable to start transaction:"),
 	return DB_FAILED;
@@ -75,12 +72,11 @@
     G_debug(2, "mysql: COMMIT");
-    init_error();
     if (mysql_query(connection, "COMMIT") != 0) {
-	append_error("Cannot commit transaction: \n");
-	report_error();
+			  _("Unable to commit transaction:"),
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/mysql/fetch.c
--- grass/trunk/db/drivers/mysql/fetch.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/fetch.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -31,8 +31,8 @@
     /* get the cursor by its token */
     if (!(c = (cursor *) db_find_token(token))) {
-	append_error(_("Cursor not found"));
-	report_error();
+	db_d_append_error(_("Cursor not found"));
 	return DB_FAILED;
@@ -49,9 +49,9 @@
     case DB_FIRST:
     case DB_LAST:
     default:
-	append_error(_("Cursor position is not supported "
-		       "by MySQL driver"));
-	report_error();
+	db_d_append_error(_("Cursor position is not supported "
+			    "by MySQL driver"));
 	return DB_FAILED;
@@ -187,17 +187,19 @@
 				&(value->t.minute), &(value->t.seconds));
 		    if (ns != 6) {
-			append_error(_("Cannot scan timestamp: "));
-			append_error(val);
-			report_error();
+					  _("Unable to scan timestamp: "),
+					  val);
 			return DB_FAILED;
 		    break;
 		default:
-		    append_error(_("Unknown timestamp format: "));
-		    report_error();
+				      _("Unknown timestamp format: "),
+				      val);
 		    return DB_FAILED;
@@ -209,9 +211,10 @@
 			&(value->t.month), &(value->t.day));
 	    if (ns != 3) {
-		append_error(_("Cannot scan date: "));
-		report_error();
+				  _("Unable to scan date: "),
+				  val);
 		return DB_FAILED;
 	    break;
@@ -222,9 +225,10 @@
 	    if (ns != 3) {
-		append_error(_("Cannot scan time: "));
-		report_error();
+				  _("Unable to scan time: "),
+				  val);
 		return DB_FAILED;
 	    break;
@@ -237,9 +241,10 @@
 	    if (ns != 6) {
-		append_error(_("Cannot scan datetime: "));
-		report_error();
+				  _("Unable to scan datetime:"),
+				  val);
 		return DB_FAILED;
 	    break;
@@ -268,8 +273,8 @@
-	append_error("Cursor not found");
-	report_error();
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/mysql/index.c
--- grass/trunk/db/drivers/mysql/index.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/index.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -24,7 +24,6 @@
     G_debug(3, "db__create_index()");
-    init_error();
     ncols = db_get_index_number_of_columns(index);
@@ -52,11 +51,11 @@
-	append_error("Cannot create index:\n");
-	report_error();
+			  _("Unable to create index:"),
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/mysql/listtab.c
--- grass/trunk/db/drivers/mysql/listtab.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/listtab.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -33,9 +33,10 @@
     res = mysql_list_tables(connection, NULL);
     if (res == NULL) {
-	append_error(_("Cannot get list of tables:\n"));
-	report_error();
+	db_d_append_error("%s\%s",
+			  _("Unable get list of tables:"),
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/mysql/parse.c
--- grass/trunk/db/drivers/mysql/parse.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/parse.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -57,9 +57,10 @@
 		long port = atol(tokens[i] + 5);
 		if (port <= 0) {
-		    append_error(_("Wrong port number in MySQL database "
-				   "definition: "));
-		    append_error(tokens[i] + 5);
+				      _("Wrong port number in MySQL database "
+					"definition: "),
+				      tokens[i] + 5);
 		    return DB_FAILED;
 		conn->port = (unsigned int)port;
@@ -76,9 +77,10 @@
 			    "is not supported, use db.login"));
 	    else {
-		append_error(_("Unknown option in database definition for "));
-		append_error("MySQL: ");
-		append_error(tokens[i]);
+				  _("Unknown option in database definition "
+				    "for MySQL: "),
+				  tokens[i]);
 		return DB_FAILED;
 	    i++;
Modified: grass/trunk/db/drivers/mysql/proto.h
--- grass/trunk/db/drivers/mysql/proto.h	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/proto.h	2012-01-25 14:06:13 UTC (rev 50443)
@@ -1,7 +1,5 @@
 /* error.c */
-void append_error(const char *);
 /* cursor.c */
 cursor *alloc_cursor();
Modified: grass/trunk/db/drivers/mysql/select.c
--- grass/trunk/db/drivers/mysql/select.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/mysql/select.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -24,8 +24,6 @@
     dbTable *table;
     char *str;
-    init_error();
     /* allocate cursor */
     c = alloc_cursor();
     if (c == NULL)
@@ -40,13 +38,13 @@
-	append_error(_("Cannot select data: \n"));
-	append_error(db_get_string(sel));
+			  _("Unable to select data:"),
+			  db_get_string(sel),
 	if (str)
 	    G_free(str);
-	report_error();
 	return DB_FAILED;
@@ -55,16 +53,16 @@
     c->res = mysql_store_result(connection);
     if (c->res == NULL) {
-	report_error();
 	return DB_FAILED;
     if (describe_table(c->res, &table, c) == DB_FAILED) {
-	report_error();
+	db_d_append_error(_("Unable to describe table."));
 	mysql_free_result(c->res);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/odbc/connect.c
--- grass/trunk/db/drivers/odbc/connect.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/connect.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -10,14 +10,16 @@
     /* Allocate Environment handle and register version */
     ret = SQLAllocHandle(SQL_HANDLE_ENV, SQL_NULL_HANDLE, &ODenvi);
     if ((ret != SQL_SUCCESS) && (ret != SQL_SUCCESS_WITH_INFO)) {
-	report_error("SQLAllocHandle()");
+	db_d_append_error("SQLAllocHandle()");
 	return DB_FAILED;
     ret =
 	SQLSetEnvAttr(ODenvi, SQL_ATTR_ODBC_VERSION, (void *)SQL_OV_ODBC3, 0);
-	report_error("SQLSetEnvAttr()");
+	db_d_append_error("SQLSetEnvAttr()");
 	SQLFreeHandle(SQL_HANDLE_ENV, ODenvi);
 	return DB_FAILED;
@@ -25,7 +27,8 @@
     /* Allocate connection handle */
     ret = SQLAllocHandle(SQL_HANDLE_DBC, ODenvi, &ODconn);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/odbc/create_table.c
--- grass/trunk/db/drivers/odbc/create_table.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/create_table.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -28,9 +28,9 @@
 	SQLGetDiagRec(SQL_HANDLE_STMT, c->stmt, 1, NULL, &err, msg,
 		      sizeof(msg), NULL);
-	G_asprintf(&emsg, "SQLExecDirect():\n%s\n%s (%d)\n",
-		   db_get_string(&sql), msg, (int)err);
-	report_error(emsg);
+	db_d_append_error("SQLExecDirect():\n%s\n%s (%d)\n",
+			  db_get_string(&sql), msg, (int)err);
 	G_free(emsg);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/odbc/cursor.c
--- grass/trunk/db/drivers/odbc/cursor.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/cursor.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -1,6 +1,7 @@
+#include <stdio.h>
-#include <stdio.h>
 #include "odbc.h"
 #include "proto.h"
@@ -27,13 +28,13 @@
     cursor *c;
     SQLRETURN ret;
     char msg[OD_MSG];
-    char *emsg = NULL;
     SQLINTEGER err;
     if (c == NULL) {
-	report_error("allocate cursor");
+	db_d_append_error(_("Unable to allocate cursor"));
 	return c;
@@ -41,10 +42,8 @@
 	SQLGetDiagRec(SQL_HANDLE_DBC, ODconn, 1, NULL, &err, msg, sizeof(msg),
 		      NULL);
-	G_asprintf(&emsg, "AllocStatement()\n%s (%d)\n", msg, (int)err);
-	G_free(emsg);
+	db_d_append_error( "AllocStatement()\n%s (%d)\n", msg, (int)err);
 	return c;
@@ -53,7 +52,8 @@
     if (c->token < 0) {
 	free_cursor(c);
 	c = NULL;
-	report_error("db_new_token()");
+	db_d_append_error(_("Unable to add new token."));
     return c;
Modified: grass/trunk/db/drivers/odbc/db.c
--- grass/trunk/db/drivers/odbc/db.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/db.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -10,7 +10,6 @@
     char msg[OD_MSG];
     const char *name;
     SQLRETURN ret;
     SQLINTEGER err;
     dbConnection connection;
@@ -34,10 +33,9 @@
 		      NULL);
-	G_asprintf(&emsg, "SQLConnect():\n%s (%d)\n", msg, (int)err);
-	G_free(emsg);
+	db_d_append_error("SQLConnect():\n%s (%d)\n", msg, (int)err);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/odbc/describe.c
--- grass/trunk/db/drivers/odbc/describe.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/describe.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -17,7 +17,6 @@
     cursor *c;
     char s[100];
     char msg[OD_MSG];
-    char *emsg;
     c = alloc_cursor();
@@ -34,9 +33,9 @@
 		      sizeof(msg), NULL);
-	G_asprintf(&emsg, "SQLExecDirect():\n%s\n%s (%d)\n", s, msg,
-		   (int)err);
+	db_d_append_error("SQLExecDirect():\n%s\n%s (%d)\n", s, msg,
+			  (int)err);
 	return DB_FAILED;
@@ -75,7 +74,8 @@
     /* get the number of colummns */
     ret = SQLNumResultCols(stmt, &ncols);
-	report_error("SQLNumResultCols()");
+	db_d_append_error("SQLNumResultCols()");
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/odbc/driver.c
--- grass/trunk/db/drivers/odbc/driver.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/driver.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -1,10 +1,11 @@
 #include "odbc.h"
+#include "proto.h"
-int db__driver_init(argc, argv)
-     char *argv[];
+int db__driver_init(int argc, char **argv)
+    init_error();
     return DB_OK;
Modified: grass/trunk/db/drivers/odbc/error.c
--- grass/trunk/db/drivers/odbc/error.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/error.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -18,20 +18,8 @@
 #include "odbc.h"
- * \fn void report_error (char *err)
- * \brief Reports database driver error.
- * \param[in] err error message
-void report_error(char *err)
+/* init error message */
+void init_error(void)
-    char *msg = NULL;
-    G_asprintf(&msg, "DBMI-ODBC driver error: %s", err);
-    db_error(msg);
-    G_free(msg);
+    db_d_init_error("ODBC");
Modified: grass/trunk/db/drivers/odbc/execute.c
--- grass/trunk/db/drivers/odbc/execute.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/execute.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -23,7 +23,6 @@
 int db__driver_execute_immediate(dbString * sql)
     char *s, msg[OD_MSG];
-    char *emsg;
     cursor *c;
     SQLRETURN ret;
     SQLINTEGER err;
@@ -39,10 +38,9 @@
 		      sizeof(msg), NULL);
-		   (int)err);
-	G_free(emsg);
+			  (int)err);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/odbc/listdb.c
--- grass/trunk/db/drivers/odbc/listdb.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/listdb.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -1,13 +1,10 @@
 #include "odbc.h"
 #include "proto.h"
-int db__driver_list_databases(dbpath, npaths, dblist, dbcount)
-     dbString *dbpath;
-     int npaths;
-     dbHandle **dblist;
-     int *dbcount;
+int db__driver_list_databases(dbString *dbpath, int npaths, dbHandle **dblist, int *dbcount)
     int i, count = 0;
     dbHandle *list;
@@ -29,7 +26,8 @@
     list = db_alloc_handle_array(count);
     if (list == NULL) {
-	report_error("db_alloc_handle_array()");
+	db_d_append_error(_("Unable to allocate handle."));
 	return DB_FAILED;
@@ -39,7 +37,8 @@
 			  NULL, desc, sizeof(desc), NULL) == SQL_SUCCESS) {
 	db_init_handle(&list[i]);
 	if (db_set_handle(&list[i], dsn, desc) != DB_OK) {
-	    report_error("db_set_handle()");
+	    db_d_append_error(_("Unable to set handle"));
 	    db_free_handle_array(list, count);
 	    return DB_FAILED;
Modified: grass/trunk/db/drivers/odbc/listtab.c
--- grass/trunk/db/drivers/odbc/listtab.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/listtab.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -33,7 +33,8 @@
     ret = SQLTables(c->stmt, NULL, 0, NULL, 0, NULL, 0, ttype, sizeof(ttype));
     if (ret != SQL_SUCCESS && ret != SQL_SUCCESS_WITH_INFO) {
-	report_error("SQLTables()");
+	db_d_append_error("SQLTables()");
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/odbc/proto.h
--- grass/trunk/db/drivers/odbc/proto.h	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/proto.h	2012-01-25 14:06:13 UTC (rev 50443)
@@ -1,5 +1,5 @@
 /* error.c */
-void report_error(char *err);
+void init_error();
 /* connect.c */
 int open_connection();
Modified: grass/trunk/db/drivers/odbc/select.c
--- grass/trunk/db/drivers/odbc/select.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/select.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -4,15 +4,12 @@
 #include "proto.h"
 #include <stdio.h>
-int db__driver_open_select_cursor(sel, dbc, mode)
-     dbString *sel;
-     dbCursor *dbc;
-     int mode;
+int db__driver_open_select_cursor(dbString *sel, dbCursor *dbc, int mode)
     cursor *c;
     SQLRETURN ret;
     SQLINTEGER err;
-    char *sql, msg[OD_MSG], emsg[DB_MSG];
+    char *sql, msg[OD_MSG];
     dbTable *table;
     int nrows;
@@ -30,8 +27,8 @@
 		      sizeof(msg), NULL);
-	sprintf(emsg, "SQLExecDirect():\n%s\n%s (%d)\n", sql, msg, (int)err);
+	db_d_append_error("SQLExecDirect():\n%s\n%s (%d)", sql, msg, (int)err);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/odbc/table.c
--- grass/trunk/db/drivers/odbc/table.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/odbc/table.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -17,6 +17,7 @@
 #include <string.h>
 #include "odbc.h"
 #include "proto.h"
@@ -127,7 +128,6 @@
     cursor *c;
     SQLRETURN ret;
     char msg[OD_MSG];
     SQLINTEGER err;
     SQLCHAR ttype[50], *tname;
     SQLINTEGER nrow = 0;
@@ -142,21 +142,23 @@
     ret = SQLTables(c->stmt, NULL, 0, NULL, 0, tname, sizeof(tname), NULL, 0);
 	return DB_FAILED;
     /* Get number of rows */
     ret = SQLRowCount(c->stmt, &nrow);
-	report_error("SQLRowCount()");
+	db_d_append_error("SQLRowCount()");
 	return DB_FAILED;
     if (nrow == 0) {
-	G_asprintf(&emsg, "Table %s doesn't exist\n", tname);
-	G_free(emsg);
+	db_d_append_error(_("Table %s doesn't exist"), tname);
 	return DB_FAILED;
@@ -171,11 +173,10 @@
 	sprintf(cmd, "DROP VIEW %s", tname);
     else {
-	G_asprintf(&emsg, "Table %s isn't 'TABLE' or 'VIEW' but %s\n", tname,
-		   ttype);
-	G_free(emsg);
+	db_d_append_error(_("Table %s isn't 'TABLE' or 'VIEW' but %s"),
+			  tname, ttype);
 	return DB_FAILED;
@@ -185,11 +186,10 @@
 		      sizeof(msg), NULL);
-	G_asprintf(&emsg, "SQLExecDirect():\n%s\n%s (%d)\n", cmd, msg,
-		   (int)err);
-	G_free(emsg);
+	db_d_append_error("SQLExecDirect():\n%s\n%s (%d)", cmd, msg,
+			  (int)err);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/ogr/cursor.c
--- grass/trunk/db/drivers/ogr/cursor.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/ogr/cursor.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -36,8 +36,6 @@
     G_debug(3, "db_driver_close_cursor()");
-    init_error();
     if (c == NULL)
@@ -64,7 +62,7 @@
     if (c == NULL) {
-	append_error(_("Unable to allocate cursor"));
 	return NULL;
@@ -73,7 +71,7 @@
     /* tokenize it */
     if (c->token < 0) {
-	append_error(_("Unable to add new token"));
+	db_d_append_error(_("Unable to add new token"));
 	return NULL;
     return c;
Modified: grass/trunk/db/drivers/ogr/db.c
--- grass/trunk/db/drivers/ogr/db.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/ogr/db.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -36,7 +36,6 @@
     const char *name;
-    init_error();
     db_get_connection(&connection);
@@ -51,8 +50,8 @@
     hDs = OGROpen(name, TRUE, NULL);
     if (hDs == NULL) {
-	append_error(_("Unable to open OGR data source"));
-	report_error();
+	db_d_append_error(_("Unable to open OGR data source"));
 	return DB_FAILED;
@@ -71,7 +70,6 @@
     G_debug(3, "db_driver_close_database()");
-    init_error();
     OGR_DS_Destroy(hDs);
     G_debug(3, "Database closed");
Modified: grass/trunk/db/drivers/ogr/describe.c
--- grass/trunk/db/drivers/ogr/describe.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/ogr/describe.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -52,16 +52,16 @@
     if (hLayer == NULL) {
-	append_error(_("OGR layer <%s> does not exist\n"),
-		     db_get_string(table_name));
-	report_error();
+	db_d_append_error(_("OGR layer <%s> does not exist\n"),
 	return DB_FAILED;
     G_debug(3, "->>");
     if (describe_table(hLayer, table, NULL) == DB_FAILED) {
-	append_error(_("Unable to describe table\n"));
-	report_error();
+	db_d_append_error(_("Unable to describe table\n"));
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/ogr/error.c
--- grass/trunk/db/drivers/ogr/error.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/ogr/error.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -17,57 +17,14 @@
 #include <ogr_api.h>
 #include "proto.h"
-  \brief Init error message
-    if (!errMsg) {
-    db_set_string(errMsg, _("DBMI-OGR driver error:\n"));
+    db_d_init_error("OGR");
-  \brief Append error message
-  \param fmt formatted string
-    FILE *fp = NULL;
-    int count = 0;
-    va_list ap;
-	    rewind(fp);
-	    G_free(work);
-	fclose(fp);
-    va_end(ap);
-  \brief Report errors
Modified: grass/trunk/db/drivers/ogr/execute.c
--- grass/trunk/db/drivers/ogr/execute.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/ogr/execute.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -37,8 +37,6 @@
     G_debug(1, "db__driver_execute_immediate():");
-    init_error();
     G_debug(3, "\tSQL: '%s'", db_get_string(sql));
     /* try RDBMS SQL */
@@ -55,8 +53,8 @@
     /* get OGR layer */
     hLayer = OGR_DS_GetLayerByName(hDs, table);
     if (!hLayer) {
-	append_error(_("OGR layer <%s> not found"), table);
-	report_error();
+	db_d_append_error(_("OGR layer <%s> not found"), table);
 	return DB_FAILED;
@@ -68,9 +66,9 @@
 	cols[i].index = OGR_FD_GetFieldIndex(hFeatureDefn, cols[i].name);
 	if (cols[i].index < 0) {
-	    append_error(_("Column <%s> not found in table <%s>"),
-			 cols[i].name, table);
-	    report_error();
+	    db_d_append_error(_("Column <%s> not found in table <%s>"),
+			      cols[i].name, table);
 	    return DB_FAILED;
 	cols[i].qindex = OGR_FD_GetFieldIndex(hFeatureDefn, cols[i].value);
Modified: grass/trunk/db/drivers/ogr/fetch.c
--- grass/trunk/db/drivers/ogr/fetch.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/ogr/fetch.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -52,8 +52,8 @@
-	report_error();
 	return DB_FAILED;
@@ -68,8 +68,8 @@
     case DB_CURRENT:
 	break;
     case DB_PREVIOUS:
-	append_error(_("DB_PREVIOUS not supported"));
-	report_error();
+	db_d_append_error(_("DB_PREVIOUS not supported"));
 	return DB_FAILED;
 	break;
     case DB_FIRST:
@@ -79,8 +79,8 @@
 	c->hFeature = OGR_L_GetNextFeature(c->hLayer);
 	break;
     case DB_LAST:
-	append_error(_("DB_LAST not supported"));
-	report_error();
+	db_d_append_error(_("DB_LAST not supported"));
 	return DB_FAILED;
 	break;
@@ -185,8 +185,8 @@
-	report_error();
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/ogr/listtab.c
--- grass/trunk/db/drivers/ogr/listtab.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/ogr/listtab.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -37,7 +37,6 @@
     OGRLayerH hLayer;
     OGRFeatureDefnH hFeatureDefn;
-    init_error();
     *tlist = NULL;
     *tcount = 0;
@@ -47,8 +46,8 @@
     list = db_alloc_string_array(nlayers);
     if (list == NULL) {
-	append_error(_("Unable to db_alloc_string_array()"));
-	report_error();
+	db_d_append_error(_("Unable to db_alloc_string_array()"));
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/ogr/proto.h
--- grass/trunk/db/drivers/ogr/proto.h	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/ogr/proto.h	2012-01-25 14:06:13 UTC (rev 50443)
@@ -25,5 +25,3 @@
 /* error.c */
-void append_error(const char *, ...);
Modified: grass/trunk/db/drivers/ogr/select.c
--- grass/trunk/db/drivers/ogr/select.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/ogr/select.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -35,8 +35,6 @@
     cursor *c;
     dbTable *table;
-    init_error();
     c = alloc_cursor();
     if (c == NULL)
@@ -49,16 +47,16 @@
     c->hLayer = OGR_DS_ExecuteSQL(hDs, db_get_string(sel), NULL, NULL);
     if (c->hLayer == NULL) {
-	append_error(_("Unable to select: \n"));
-	report_error();
+	db_d_append_error(_("Unable to select: \n"));
+	db_d_append_error(db_get_string(sel));
+	db_d_append_error("\n");
 	return DB_FAILED;
     if (describe_table(c->hLayer, &table, c) == DB_FAILED) {
-	report_error();
 	OGR_DS_ReleaseResultSet(hDs, c->hLayer);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/postgres/create_table.c
--- grass/trunk/db/drivers/postgres/create_table.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/create_table.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -27,8 +27,6 @@
-    init_error();
     /* db_table_to_sql ( table, &sql ); */
@@ -101,11 +99,11 @@
     res = PQexec(pg_conn, db_get_string(&sql));
     if (!res || PQresultStatus(res) != PGRES_COMMAND_OK) {
-	append_error(_("Unable to create table:\n"));
-	append_error(PQerrorMessage(pg_conn));
-	report_error();
+			  PQerrorMessage(pg_conn));
 	PQclear(res);
 	return DB_FAILED;
@@ -130,11 +128,11 @@
-	append_error(_("Unable to grant select on table:\n"));
-	report_error();
+			  _("Unable to grant select on table:"),
 	PQclear(res);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/postgres/cursor.c
--- grass/trunk/db/drivers/postgres/cursor.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/cursor.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -19,8 +19,6 @@
     cursor *c;
-    init_error();
     if (c == NULL)
@@ -40,7 +38,7 @@
     if (c == NULL) {
-	append_error(_("Unable allocate cursor."));
 	return NULL;
@@ -49,7 +47,7 @@
     /* tokenize it */
     if (c->token < 0) {
-	append_error(_("Unable to add new token."));
 	return NULL;
Modified: grass/trunk/db/drivers/postgres/db.c
--- grass/trunk/db/drivers/postgres/db.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/db.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -27,7 +27,6 @@
     PGresult *res;
     int row;
-    init_error();
@@ -40,7 +39,7 @@
 	    name);
     if (parse_conn(name, &pgconn) == DB_FAILED) {
-	report_error();
 	return DB_FAILED;
@@ -57,9 +56,10 @@
 			   pgconn.dbname, user, password);
     if (PQstatus(pg_conn) == CONNECTION_BAD) {
-	append_error(_("Unable to connect to Postgres: "));
-	report_error();
 	PQfinish(pg_conn);
 	return DB_FAILED;
@@ -83,9 +83,10 @@
 	res = PQexec(pg_conn, buf);
-	    append_error(_("Unable to set schema: "));
-	    append_error(schema);
-	    report_error();
+			      _("Unable to set schema:"),
+			      schema);
 	    PQclear(res);
 	    return DB_FAILED;
@@ -101,8 +102,8 @@
 		 "'bool', 'geometry' ) order by oid");
     if (!res || PQresultStatus(res) != PGRES_TUPLES_OK) {
-	append_error(_("Unable to select data types"));
-	report_error();
+	db_d_append_error(_("Unable to select data types"));
 	PQclear(res);
 	return DB_FAILED;
@@ -168,7 +169,6 @@
 int db__driver_close_database()
-    init_error();
     PQfinish(pg_conn);
     return DB_OK;
Modified: grass/trunk/db/drivers/postgres/describe.c
--- grass/trunk/db/drivers/postgres/describe.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/describe.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -28,17 +28,17 @@
-	report_error();
 	PQclear(res);
 	return DB_FAILED;
-	report_error();
 	PQclear(res);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/postgres/error.c
--- grass/trunk/db/drivers/postgres/error.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/error.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -12,30 +12,12 @@
 #include <stdio.h>
-    if (!errMsg) {
-    db_set_string(errMsg, _("DBMI-Postgres driver error:\n"));
+    db_d_init_error("PostgreSQL");
-    db_append_string(errMsg, msg);
-/* report error message */
Modified: grass/trunk/db/drivers/postgres/execute.c
--- grass/trunk/db/drivers/postgres/execute.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/execute.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -23,8 +23,6 @@
     PGresult *res;
     char *str;
-    init_error();
     /* Postgres supports in addition to standard escape character '
      * (apostrophe) also \ (basckslash) as this is not SQL standard,
      * GRASS modules cannot work escape all \ in the text because
@@ -40,11 +38,11 @@
     res = PQexec(pg_conn, str);
-	append_error(_("Unable to execute:\n"));
-	report_error();
+			  str,
 	PQclear(res);
 	if (str)
 	    G_free(str);
@@ -64,12 +62,11 @@
     G_debug(2, "pg : BEGIN");
-    init_error();
     res = PQexec(pg_conn, "BEGIN");
-	append_error(_("Unable to 'BEGIN' transaction"));
-	report_error();
+	db_d_append_error(_("Unable to 'BEGIN' transaction"));
 	PQclear(res);
 	return DB_FAILED;
@@ -85,12 +82,11 @@
     G_debug(2, "pg : COMMIT");
-    init_error();
     res = PQexec(pg_conn, "COMMIT");
-	append_error(_("Unable to 'COMMIT' transaction"));
-	report_error();
+	db_d_append_error(_("Unable to 'COMMIT' transaction"));
 	PQclear(res);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/postgres/fetch.c
--- grass/trunk/db/drivers/postgres/fetch.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/fetch.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -30,8 +30,8 @@
-	report_error();
 	return DB_FAILED;
@@ -125,9 +125,10 @@
 			&(value->t.year), &(value->t.month), &(value->t.day));
 	    if (ns != 3) {
-		append_error(_("Unable to scan date:"));
-		append_error(PQgetvalue(c->res, c->row, col));
-		report_error();
+				  _("Unable to scan date:"),
+				  PQgetvalue(c->res, c->row, col));
 		return DB_FAILED;
 	    value->t.hour = 0;
@@ -142,9 +143,10 @@
 	    if (ns != 3) {
-		append_error(_("Unable to scan time:"));
-		report_error();
+				  _("Unable to scan time:"),
 		return DB_FAILED;
 	    value->t.year = 0;
@@ -160,15 +162,19 @@
 			&(value->t.minute), &(value->t.seconds), &tz);
 	    if (ns == 7) {
-		append_error(_("Unable to scan timestamp (no idea how to process time zone):"));
-		report_error();
+				  _("Unable to scan timestamp "
+				    "(no idea how to process time zone):"),
 		return DB_FAILED;
 	    else if (ns < 6) {
-		append_error(_("Unable to scan timestamp (not enough arguments):"));
-		report_error();
+				    "(not enough arguments):"),
 		return DB_FAILED;
 	    break;
@@ -197,8 +203,8 @@
-	append_error(_("Taken not found"));
-	report_error();
+	db_d_append_error(_("Taken not found"));
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/postgres/index.c
--- grass/trunk/db/drivers/postgres/index.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/index.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -26,7 +26,6 @@
-    init_error();
@@ -56,11 +55,11 @@
-	append_error(_("Unable to create index:\n"));
-	report_error();
+			  _("Unable to create index:\n"),
 	PQclear(res);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/postgres/listdb.c
--- grass/trunk/db/drivers/postgres/listdb.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/listdb.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -22,20 +22,18 @@
     int rec_num = 0;
     dbHandle *list;
-    init_error();
     *dblist = NULL;
     *dbcount = 0;
     /* TODO: the solution below is not good as user usually does not have permissions for "template1" */
-    append_error
-	(_("db_driver_list_databases() is not implemented in pg driver"));
-    report_error();
+    db_d_append_error(_("db_driver_list_databases() is not implemented"));
     return DB_FAILED;
     if (npaths > 0) {
 	G_debug(3, "location: %s", db_get_string(dbpath));
 	if (parse_conn(db_get_string(dbpath), &pgconn) == DB_FAILED) {
-	    report_error();
 	    return DB_FAILED;
@@ -48,9 +46,10 @@
 		"template1");
-	append_error(_("Unable to connect to Postgres:\n"));
-	report_error();
+			  _("Unable to connect to Postgres:"),
 	PQfinish(pg_conn);
 	return DB_FAILED;
@@ -58,9 +57,10 @@
     res = PQexec(pg_conn, "select datname from pg_database");
-	append_error(_("Unable to select from Postgres:\n"));
-	report_error();
+			  _("Unable to select from Postgres:"),
 	PQclear(res);
 	PQfinish(pg_conn);
 	return DB_FAILED;
@@ -70,16 +70,16 @@
     list = db_alloc_handle_array(rec_num);
     if (list == NULL) {
-	append_error(_("Out of memory"));
-	report_error();
+	db_d_append_error(_("Out of memory"));
 	return DB_FAILED;
     for (i = 0; i < rec_num; i++) {
 	if (db_set_handle(&list[i], PQgetvalue(res, i, 0), NULL) != DB_OK) {
-	    append_error("db_set_handle()");
-	    report_error();
 	    db_free_handle_array(list, rec_num);
 	    return DB_FAILED;
Modified: grass/trunk/db/drivers/postgres/listtab.c
--- grass/trunk/db/drivers/postgres/listtab.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/listtab.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -23,7 +23,6 @@
     PGresult *rest, *resv;
     char buf[1000];
-    init_error();
     *tlist = NULL;
     *tcount = 0;
@@ -34,9 +33,10 @@
 	       "select * from pg_tables where tablename !~ 'pg_*' order by tablename");
     if (!rest || PQresultStatus(rest) != PGRES_TUPLES_OK) {
-	append_error(_("Unable to select table names\n"));
-	report_error();
+			  _("Unable to select table names."),
 	PQclear(rest);
 	return DB_FAILED;
@@ -59,9 +59,10 @@
 	       "SELECT * FROM pg_views WHERE schemaname NOT IN ('pg_catalog','information_schema') AND viewname !~ '^pg_'");
     if (!resv || PQresultStatus(resv) != PGRES_TUPLES_OK) {
-	append_error(_("Unable to select view names\n"));
-	report_error();
+			  _("Unable to select view names."),
 	PQclear(resv);
 	return DB_FAILED;
@@ -86,8 +87,8 @@
     list = db_alloc_string_array(nrows);
     if (list == NULL) {
-	append_error(_("db_alloc_string_array() failed"));
-	report_error();
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/postgres/parse.c
--- grass/trunk/db/drivers/postgres/parse.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/parse.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -64,8 +64,10 @@
 	    else if (strncmp(tokens[i], "schema", 6) == 0)
 		pgconn->schema = G_store(tokens[i] + 7);
 	    else {
-		append_error(_("Unknown option in database definition for PostgreSQL: "));
+				    "for PostgreSQL: "),
+				  tokens[i]);
 		return DB_FAILED;
 	    i++;
Modified: grass/trunk/db/drivers/postgres/priv.c
--- grass/trunk/db/drivers/postgres/priv.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/priv.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -23,7 +23,6 @@
-    init_error();
     db_set_string(&sql, "grant ");
     if (priv | DB_PRIV_SELECT)
@@ -50,11 +49,11 @@
-	append_error(_("Unable grant on table:\n"));
-	report_error();
+			  _("Unable grant on table:"),
 	PQclear(res);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/postgres/proto.h
--- grass/trunk/db/drivers/postgres/proto.h	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/proto.h	2012-01-25 14:06:13 UTC (rev 50443)
@@ -1,7 +1,5 @@
 /* error.c */
 /* cursor.c */
 cursor *alloc_cursor(void);
Modified: grass/trunk/db/drivers/postgres/select.c
--- grass/trunk/db/drivers/postgres/select.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/postgres/select.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -24,14 +24,12 @@
     dbTable *table;
     char *str;
-    init_error();
     /* Set datetime style */
     res = PQexec(pg_conn, "SET DATESTYLE TO ISO");
-	append_error(_("Unable set DATESTYLE"));
-	report_error();
+	db_d_append_error(_("Unable set DATESTYLE"));
 	PQclear(res);
 	return DB_FAILED;
@@ -53,11 +51,11 @@
     c->res = PQexec(pg_conn, str);
     if (!c->res || PQresultStatus(c->res) != PGRES_TUPLES_OK) {
-	append_error(_("Unable to select:\n'"));
-	append_error("'");
-	report_error();
+			  _("Unable to select:"),
 	PQclear(c->res);
 	if (str)
 	    G_free(str);
@@ -68,8 +66,8 @@
 	G_free(str);
-	append_error(_("Unable to describe table"));
-	report_error();
 	PQclear(res);
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/sqlite/create_table.c
--- grass/trunk/db/drivers/sqlite/create_table.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/create_table.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -14,6 +14,7 @@
 #include "proto.h"
@@ -36,9 +37,7 @@
     int ret;
-    init_error();
@@ -119,11 +118,11 @@
 	ret = sqlite3_prepare(sqlite, db_get_string(&sql), -1, &statement, &rest);
 	if (ret != SQLITE_OK) {
-	    append_error((char *)sqlite3_errmsg(sqlite));
-	    report_error();
+			      (char *)sqlite3_errmsg(sqlite));
 	    sqlite3_finalize(statement);
 	    return DB_FAILED;
@@ -138,9 +137,10 @@
 	    /* try again */
 	else if (ret != SQLITE_OK) {
-	    append_error("Error in sqlite3_step():\n");
-	    report_error();
+			      _("Error in sqlite3_step():"),
 	    return DB_FAILED;
Modified: grass/trunk/db/drivers/sqlite/cursor.c
--- grass/trunk/db/drivers/sqlite/cursor.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/cursor.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -15,6 +15,7 @@
 #include <stdio.h>
 #include "proto.h"
@@ -22,8 +23,6 @@
     cursor *c;
-    init_error();
     if (c == NULL)
@@ -45,7 +44,7 @@
     if (c == NULL) {
-	append_error("Cannot allocate cursor.");
+	db_d_append_error(_("Unable to allocate cursor."));
 	return NULL;
@@ -54,7 +53,7 @@
     /* tokenize it */
     if (c->token < 0) {
-	append_error("Cannot ad new token.");
 	return NULL;
Modified: grass/trunk/db/drivers/sqlite/db.c
--- grass/trunk/db/drivers/sqlite/db.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/db.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -36,7 +36,6 @@
     G_debug(3, "\ndb_driver_open_database()");
-    init_error();
     /* if name is empty use connection.databaseName */
@@ -82,9 +81,10 @@
     G_debug(2, "name2 = '%s'", name2);
     if (sqlite3_open(name2, &sqlite) != SQLITE_OK) {
-	append_error(_("Unable to open database: "));
-	report_error();
+			  _("Unable to open database: "),
 	return DB_FAILED;
@@ -105,7 +105,6 @@
     G_debug(3, "db_close_database()");
-    init_error();
     if (sqlite3_close(sqlite) == SQLITE_BUSY)
 	G_fatal_error(_("SQLite database connection is still busy"));
Modified: grass/trunk/db/drivers/sqlite/describe.c
--- grass/trunk/db/drivers/sqlite/describe.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/describe.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -56,11 +56,11 @@
-	    append_error("Error in sqlite3_prepare():");
-	    report_error();
+	    db_d_append_error("%s %s\n%s",
+			      _("Error in sqlite3_prepare():"),
 	    return DB_FAILED;
@@ -74,9 +74,10 @@
 	    /* try again */
-	    report_error();
 	    return DB_FAILED;
@@ -87,9 +88,10 @@
     if (describe_table(statement, table, NULL) == DB_FAILED) {
-	append_error("Cannot describe table:\n");
-	report_error();
 	return DB_FAILED;
@@ -126,9 +128,10 @@
     if (ret != SQLITE_DONE && ret != SQLITE_ROW) {
 	/* get real result code */
 	ret = sqlite3_reset(statement);
-	report_error();
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/sqlite/error.c
--- grass/trunk/db/drivers/sqlite/error.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/error.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -18,28 +18,8 @@
 #include "proto.h"
-static dbString *errMsg = NULL;	/* error message */
-    if (!errMsg) {
-    db_set_string(errMsg, "DBMI-SQLite driver error:\n");
+    db_d_init_error("SQLite");
Modified: grass/trunk/db/drivers/sqlite/execute.c
--- grass/trunk/db/drivers/sqlite/execute.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/execute.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -17,6 +17,7 @@
 #include <stdlib.h>
 #include "proto.h"
@@ -48,9 +49,10 @@
 	ret = sqlite3_prepare(sqlite, s, -1, &stmt, &rest);
-	    append_error("Error in sqlite3_prepare():\n");
-	    report_error();
 	    return DB_FAILED;
@@ -63,9 +65,10 @@
 	    /* try again */
-	    report_error();
 	    sqlite3_finalize(stmt);
 	    return DB_FAILED;
@@ -76,9 +79,10 @@
     ret = sqlite3_finalize(stmt);
-	append_error("Error in sqlite3_finalize():\n");
-	report_error();
+			  _("Error in sqlite3_finalize():"),
 	return DB_FAILED;
@@ -103,9 +107,10 @@
     ret = sqlite3_exec(sqlite, "BEGIN", NULL, NULL, NULL);
-	append_error("Cannot 'BEGIN' transaction:\n");
-	report_error();
+			  _("'BEGIN' transaction failed:"),
 	return DB_FAILED;
@@ -130,9 +135,10 @@
     ret = sqlite3_exec(sqlite, "COMMIT", NULL, NULL, NULL);
-	append_error("Cannot 'COMMIT' transaction:\n");
-	report_error();
+			  _("'COMMIT' transaction failed:"),
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/sqlite/fetch.c
--- grass/trunk/db/drivers/sqlite/fetch.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/fetch.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -48,8 +48,8 @@
-	report_error();
+	db_d_append_error(("Cursor not found"));
 	return DB_FAILED;
@@ -68,9 +68,10 @@
 	    ret = sqlite3_reset(c->statement);
-		append_error("Cannot fetch:\n");
-		report_error();
+				  _("Unable to fetch:"),
 		return DB_FAILED;
 	    *more = 0;
@@ -83,14 +84,14 @@
 	break;
     case DB_PREVIOUS:
-	append_error("DB_PREVIOUS is not supported");
-	report_error();
+	db_d_append_error(_("DB_PREVIOUS is not supported"));
 	return DB_FAILED;
 	break;
     case DB_LAST:
-	append_error("DB_LAST is not supported");
-	report_error();
+	db_d_append_error(_("DB_LAST is not supported"));
 	return DB_FAILED;
 	break;
@@ -166,9 +167,10 @@
 	    G_debug(3, "sqlite fetched date: %s", text);
 	    ns = sscanf(text, "%4d-%2d-%2d", &dt->year, &dt->month, &dt->day);
 	    if (ns != 3) {
-		append_error("Cannot scan date:");
-		append_error(text);
-		report_error();
+				  text);
 		return DB_FAILED;
 	    break;
@@ -182,9 +184,10 @@
 	    ns = sscanf(text, "%2d:%2d:%lf",
 			&dt->hour, &dt->minute, &dt->seconds);
 	    if (ns != 3) {
-		append_error("Cannot scan time:");
-		report_error();
+				  text);
 		return DB_FAILED;
 	    break;
@@ -196,9 +199,10 @@
 			&dt->year, &dt->month, &dt->day,
 	    if (ns != 6) {
-		append_error("Cannot scan timestamp:");
-		report_error();
+				  _("Unable to scan timestamp:"),
+				  text);
 		return DB_FAILED;
 	    break;
@@ -211,13 +215,14 @@
 	    dt->hour = 0;
 	    dt->minute = 0;
 	    G_debug(3, "sqlite fetched interval: %s", text);
-	    G_warning
-		("SQLite driver: parsing of interval values not implemented; assuming seconds");
+	    G_warning(_("SQLite driver: parsing of interval values "
+			"not implemented; assuming seconds"));
 	    ns = sscanf(text, "%lf", &dt->seconds);
 	    if (ns != 1) {
-		append_error("Cannot scan interval:");
-		report_error();
+				  _("Unable to scan interval:"),
+				  text);
 		return DB_FAILED;
 	    break;
@@ -257,8 +262,8 @@
-	report_error();
 	return DB_FAILED;
@@ -277,9 +282,10 @@
-	append_error("Cannot get number of rows\n");
-	report_error();
+			  _("Unable to get number of rows:"),
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/sqlite/index.c
--- grass/trunk/db/drivers/sqlite/index.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/index.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -14,6 +14,7 @@
 #include "proto.h"
@@ -38,7 +39,6 @@
-    init_error();
@@ -72,11 +72,11 @@
-	    report_error();
 	    return DB_FAILED;
@@ -91,9 +91,10 @@
 	    /* try again */
-	    report_error();
 	    return DB_FAILED;
Modified: grass/trunk/db/drivers/sqlite/listtab.c
--- grass/trunk/db/drivers/sqlite/listtab.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/listtab.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -16,6 +16,7 @@
 #include <stdlib.h>
 #include <string.h>
 #include "proto.h"
@@ -39,16 +40,16 @@
     const char *rest;
     int ret;
-    init_error();
+    G_debug(3, "db__driver_list_tables(): system = %d", system);
 			  "select name from sqlite_master where type = 'table' or type = 'view'",
-	append_error("Cannot list tables\n");
-	report_error();
+			  _("Unable to list tables:"),
 	return DB_FAILED;
@@ -61,9 +62,10 @@
-	report_error();
 	return DB_FAILED;
@@ -73,8 +75,8 @@
     if (list == NULL) {
-	append_error("Cannot db_alloc_string_array()");
-	report_error();
 	return DB_FAILED;
Modified: grass/trunk/db/drivers/sqlite/proto.h
--- grass/trunk/db/drivers/sqlite/proto.h	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/proto.h	2012-01-25 14:06:13 UTC (rev 50443)
@@ -5,8 +5,6 @@
 /* error.c */
 /* cursor.c */
Modified: grass/trunk/db/drivers/sqlite/select.c
--- grass/trunk/db/drivers/sqlite/select.c	2012-01-25 14:04:51 UTC (rev 50442)
+++ grass/trunk/db/drivers/sqlite/select.c	2012-01-25 14:06:13 UTC (rev 50443)
@@ -16,6 +16,7 @@
 #include <stdlib.h>
 #include "proto.h"
@@ -39,8 +40,6 @@
     const char *rest;
     int ret;
-    init_error();
     c = alloc_cursor();
     if (c == NULL)
@@ -60,11 +59,11 @@
 	ret = sqlite3_prepare(sqlite, str, -1, &(c->statement), &rest);
-	    report_error();
 	    return DB_FAILED;
@@ -77,9 +76,10 @@
 	    /* try again */
-	    report_error();
 	    sqlite3_finalize(c->statement);
 	    return DB_FAILED;
@@ -91,9 +91,10 @@
 	G_free(str);
     if (describe_table(c->statement, &table, c) == DB_FAILED) {
-	report_error();
 	return DB_FAILED;
