[GRASS-SVN] r50462 - grass/trunk/lib/vector/Vlib
Thu Jan 26 02:44:41 EST 2012
Author: hamish
Date: 2012-01-25 23:44:40 -0800 (Wed, 25 Jan 2012)
New Revision: 50462
   grass/trunk/lib/vector/Vlib/header.c
write out PROJ code to vector/head if known; move obvious handling of PROJECTION_OTHER by Vect_get_proj_name()
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c	2012-01-26 06:30:56 UTC (rev 50461)
+++ grass/trunk/lib/vector/Vlib/header.c	2012-01-26 07:44:40 UTC (rev 50462)
@@ -96,6 +96,8 @@
     fprintf(head_fp, "MAP DATE:     %s\n", Vect_get_map_date(Map));
     fprintf(head_fp, "MAP SCALE:    %d\n", Vect_get_scale(Map));
     fprintf(head_fp, "OTHER INFO:   %s\n", Vect_get_comment(Map));
+    if (Vect_get_proj(Map) > 0)
+	fprintf(head_fp, "PROJ:         %d\n", Vect_get_proj(Map));
     fprintf(head_fp, "ZONE:         %d\n", Vect_get_zone(Map));
     fprintf(head_fp, "MAP THRESH:   %f\n", Vect_get_thresh(Map));
@@ -615,18 +617,18 @@
     case PROJECTION_LL:
     case PROJECTION_SP:
 	return G__projection_name(n);
+    case PROJECTION_OTHER:
+	/* this won't protect against differing "other" projections, so
+	   better to just include P_OTHER in the above list so we return the
+	   strictly more correct, but less nice, string: "Other projection" ? */
+	return G_database_projection_name();
     default:
 	G_debug(1, "Vect_get_proj_name(): "
 		   "Vect_get_proj() returned an invalid result (%d)", n);
 	break;
-    /* Vect_get_proj() didn't return a useful result,
-       fallback to G_database_projection_name() */
-    /* (is this behavior desirable?) */
-    if (!lookup(PROJECTION_FILE, "name", name, sizeof(name)))
-	strcpy(name, _("Unknown projection"));
+    strcpy(name, _("Unknown projection"));
     return G_store(name);
