[GRASS-SVN] r50502 - grass/trunk/vector/v.to.rast3
Fri Jan 27 16:00:24 EST 2012
Author: neteler
Date: 2012-01-27 13:00:24 -0800 (Fri, 27 Jan 2012)
New Revision: 50502
   grass/trunk/vector/v.to.rast3/main.c
fix r50489
Modified: grass/trunk/vector/v.to.rast3/main.c
--- grass/trunk/vector/v.to.rast3/main.c	2012-01-27 18:10:35 UTC (rev 50501)
+++ grass/trunk/vector/v.to.rast3/main.c	2012-01-27 21:00:24 UTC (rev 50502)
@@ -59,7 +59,7 @@
     col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     col_opt->required = YES;
-    col_opt->description = _("Name of attrbitute column (data type must be numeric)");
+    col_opt->description = _("Name of attribute column (data type must be numeric)");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
