[GRASS-SVN] r50544 - grass/trunk/vector/v.extrude
Mon Jan 30 04:51:17 EST 2012
Author: mmetz
Date: 2012-01-30 01:51:17 -0800 (Mon, 30 Jan 2012)
New Revision: 50544
   grass/trunk/vector/v.extrude/main.c
check column type only once
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c	2012-01-30 04:53:50 UTC (rev 50543)
+++ grass/trunk/vector/v.extrude/main.c	2012-01-30 09:51:17 UTC (rev 50544)
@@ -47,7 +47,7 @@
     struct cat_list *Clist;
     int field;
-    int i, only_type, cat, ctype, fdrast = -1, areanum = 0;
+    int i, only_type, cat, ctype = -1, fdrast = -1, areanum = 0;
     int nelements;
     int line, type;
     int area, trace, centroid;
@@ -171,6 +171,13 @@
 	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 			  Fi->database, Fi->driver);
+	ctype = db_column_Ctype(driver, Fi->table, hcolumn->answer);
+	if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_STRING &&
+	    ctype != DB_C_TYPE_DOUBLE) {
+	    G_fatal_error(_("Column <%s>: invalid data type"),
+			  hcolumn->answer);
     /* do we work with elevation raster? */
@@ -295,17 +302,6 @@
 		/* objheight value */
 		value = db_get_column_value(column);
-		/* host_type -> ctype ?
-		   objheight =
-		   db_get_value_as_double(value,
-		   db_get_column_host_type(column));
-		ctype = db_sqltype_to_Ctype(db_get_column_sqltype(column));
-		if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_STRING &&
-		    ctype != DB_C_TYPE_DOUBLE) {
-		    G_fatal_error(_("Column <%s>: invalid data type"),
-				  db_get_column_name(column));
 		objheight = db_get_value_as_double(value, ctype);
 		/* only draw if hcolumn was defined */
