[GRASS-SVN] r50579 - grass/trunk/debian
Mon Jan 30 21:32:47 EST 2012
Author: hamish
Date: 2012-01-30 18:32:47 -0800 (Mon, 30 Jan 2012)
New Revision: 50579
   grass/trunk/debian/README.debian
sudo as needed (merge from devbr6)
Modified: grass/trunk/debian/README.debian
--- grass/trunk/debian/README.debian	2012-01-31 02:32:00 UTC (rev 50578)
+++ grass/trunk/debian/README.debian	2012-01-31 02:32:47 UTC (rev 50579)
@@ -16,7 +16,7 @@
 # have to install a bunch of -dev packages. Look at the debian/control
 # file and install the packages on the "Build-depends" lines.
-  apt-get install flex bison libreadline-dev libncurses5-dev # ... etc.
+  sudo apt-get install flex bison libreadline-dev libncurses5-dev # ... etc.
 # In your favorite text editor open debian/changelog and adjust the
@@ -33,7 +33,7 @@
 # in main GRASS source directory. After the packages are generated, you can
 # install them with:
-  dpkg -i ../grass*.deb
+  sudo dpkg -i ../grass*.deb
 # (make sure to remove older grass*.deb files first)
