[GRASS-SVN] r50586 - grass-addons/grass6/raster/r.xtent
Tue Jan 31 07:02:20 EST 2012
Author: hamish
Date: 2012-01-31 04:02:20 -0800 (Tue, 31 Jan 2012)
New Revision: 50586
   grass-addons/grass6/raster/r.xtent/Makefile
   grass-addons/grass6/raster/r.xtent/at_exit_funcs.c
   grass-addons/grass6/raster/r.xtent/at_exit_funcs.h
   grass-addons/grass6/raster/r.xtent/geom.c
   grass-addons/grass6/raster/r.xtent/geom.h
   grass-addons/grass6/raster/r.xtent/globals.h
   grass-addons/grass6/raster/r.xtent/gt_vector.c
   grass-addons/grass6/raster/r.xtent/gt_vector.h
   grass-addons/grass6/raster/r.xtent/main.c
   grass-addons/grass6/raster/r.xtent/r.xtent.001.png
   grass-addons/grass6/raster/r.xtent/r.xtent.002.png
   grass-addons/grass6/raster/r.xtent/r.xtent.003.png
   grass-addons/grass6/raster/r.xtent/r.xtent.004.png
   grass-addons/grass6/raster/r.xtent/r.xtent.005.png
   grass-addons/grass6/raster/r.xtent/r.xtent.006.png
   grass-addons/grass6/raster/r.xtent/r.xtent.007.png
   grass-addons/grass6/raster/r.xtent/tools.c
   grass-addons/grass6/raster/r.xtent/tools.h
   grass-addons/grass6/raster/r.xtent/xtent.c
   grass-addons/grass6/raster/r.xtent/xtent.h
svn props
Property changes on: grass-addons/grass6/raster/r.xtent/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/at_exit_funcs.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/at_exit_funcs.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/geom.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/geom.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/globals.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/gt_vector.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/gt_vector.h
   + text/x-chdr
   + native
Modified: grass-addons/grass6/raster/r.xtent/main.c
--- grass-addons/grass6/raster/r.xtent/main.c	2012-01-31 11:56:06 UTC (rev 50585)
+++ grass-addons/grass6/raster/r.xtent/main.c	2012-01-31 12:02:20 UTC (rev 50586)
@@ -1,1625 +1,1625 @@
-/* r.xtent */
-	TODO Version 1.0
-	BUGS:
-		- Win32:
-		  Complains about not being able to remove fcell element for tmapnames[i]. But there is no
-		  fcell element for those maps, anyway !!! Maybe this is just a bug in current CVS
-  	DBF TROUBLES:
-    		- column names are limited to 10 chars
-	TEST:
-		- what happens, if some attribute values are bad in the input centers map?
-		- does this work with CENTROIDS instead of POINTS, as well ?
-		- do line breaks work for the protocol on Win32 (both regular and tabular)?
-		- NULL cells in input cost surfaces
-	General coding
-		- VALGRIND
-		- replace all G_system() with G_spawn(). G_spawn returns -1 on error, so this can be checked!
-        	   -> adjust tools.c run_cmd() to use G_spawn() instead of G_system()
-		- improve HTML documentation: math typesetting, better formatting. Pictures. Cross references.
-		- make status display work on Win32. [currently impossible?]
-		- ATTRIBUTE TYP
 E CHECKING: SOME COULD BE DOUBLE OR INT, BUT SHOULD ALWAYS BE HANDLED AS DOUBLE
-			-> use functions GVT_numeric_exists and GVT_get_numeric (), that always returns a double !!!
-			- Currently, only C attribute supports double and int, all other do strict type-checking. Should this
-			be relaxed?
-		- replace Posix funcs like strcpy with GRASS funcs, where available
-		- make sure that memory is dealloc'd properly for things like cats, labels, colors ...
-	Program functionality
-	  - a switch to output areal calculations in ha
-	  - let user define sqkm per cell for areal calculations in non-world systems
-	Documentation updates:
-	  - C gets normalized automatically!
-	  - territorial partitioning will always be complete, unless 'strict' flag given or reach
-	    constraint set
-	  - paragraph breaks between figures
-	  - add more examples, with strict mode and reach constraints
-    	  - reach constraint together with unrestricted formula is the recommended way
 of defining
-      	    territorial reach, as it is easier to control than the original I>=0 contraint!
-	TODO VERSION 2.X
-		A version 1.x should be done if there is enough user demand
-		Political attributes:
-			- Model constraints
-				* find a way to store for each site:
-					- allies: cannot claim each other's territory: if second highest I is an ally: do not touch it!
-			- if any constraints are given, then there should be a check for validity
-					to see if they hold in the model result (?!)
-		Misc.:
-			- user should be able to provide a map for spatially variable k (?)
-			- in very complex situations, the model may produce fragmented territories. E.g.:
-			r.xtent cent=sites output=test comp_id=comp comp_str=strength elev=dem -g --o
-			(Oaxaca dataset, with region set to extents of 'dem' and res=0:00:59)
-				-> Should this be catered for? If so, if a center gets captured, then all of
-				its cells in the output map (basic I) shoul
 d be reclassified to the ID of
-				the new "boss" (this will automatically be taken care of in cases where
-				there is an a priori boss for that center, specified in the ruler= attribute).
-			- latex, html, rtf output style for protocols
-REVISON 0.99, OCT 2007
-FIX BUGS:
-UPDATE DOCUMENTATION!
-geom.c: in function get_distance():
-	delete line distance measure in case where a cost map is used to derive
-	distance: only take the cost value (costs[i]) and return that! [DONE]
-xent.c: the debugging output for "I=..." should be set to %.10f to allow floating
-	point values in much smaller ranges [DONE]
-Improvements for the next version of r.xtent:
-1. Normalize center weights, so that largest center's weight=1.0
-	-> Divide all weights by largest weight. This won't do
-	any harm to data that is already normalized, as it just
-	divides everything by "1"! This is also what R an
 d L did
-	in their original study. [DONE]
-2. Use standard weight of "k=0.0001" for regions that use projected
-meter systems. This is the same as R and L did (although they used km as
-their unit of distance measurements which meant "k=0.1").
-Use standard weight of "k=0.000001?" for cost surface maps generated with
-r.walk. [DONE]
-3. Provide different functions for distance decay:
-a. Linear (already DONE)
-b. Exponential
-c. Sigmoid-function: P(t)=(1)/(1+e^t)
-	--> see Wikipedia entry on Sigmoid
-	For our purposes : P(t)=( 1- (1)/(1+e^t) )
-*** Open questions:
-a) How to model the hierarchical relations of sites that form alliances?
-b) How to choose "k" for regions that use lat-long and plain x/y systems?
-c) what to do with "residual territories", i.e. territories still claimed by a site A that has been
-taken over by another site B? Maybe allocate all territory that once belonged to A to B in a
-second "clean-up" pass?
-#define
  LOCAL
-#include <stdlib.h>
-#include <stdio.h>
-#include <errno.h>
-#include <string.h>
-#include <time.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include "globals.h"
-#include "at_exit_funcs.h"
-#include "gt_vector.h"
-#include "xtent.h"
-#include "tools.h"
-/* variables global in main.c */
-GVT_map_s *pmap;
-double b_weight; /* weight for boundaries */
-double p_weight; /* weight for pathways */
-int *costf;
-CELL *cell;
-CELL *cell_second;
-DCELL *dcell;
-DCELL *dcell_boundaries;
-DCELL **costdcell;
-double *costs;
-double *reach;
-int *ruler;
-double *max_cost;
-char *boundaries_map;
-char *pathways_map;
-/* temporary map name strings */
-char *cmapname; /* name of a cost map */
-char *pseudomap; /* a pseudo friction map (all costs set to 1), used when only boundaries or pathways are supplied */
-/* DEFINE FLAGS AND OPTIONS */
-void define_opts ( int argc, char *argv[] ) {
-	module = G_define_module ();
-	module->description = "Calcu
 late variations or original version of Renfrew and Level's Xtent model for territorial modeling.";
-	module->label = "r.xtent: territorial modelling with boundaries and movement costs";
-	module->keywords = _("raster,Xtent,territories,territorial analysis");
-	/* vector map with centers (sites only or network) */
-	parm.centers = G_define_standard_option (G_OPT_V_INPUT);
-	parm.centers->key = "centers";
-	parm.centers->type = TYPE_STRING;
-	parm.centers->required = YES;
-	parm.centers->description = _("Input map with vector points representing centers");
-	parm.centers->guisection = _("Basic");
-	/* Output map name */
-	parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
-	parm.output->key = "territories";
-	parm.output->description = _("Output raster map showing territories");
-	parm.output->guisection = _("Basic");
-	/* attribute that stores C for each center */
-	parm.c = G_define_option ();
-	parm.c->key = "c";
-	parm.c->type = TYPE_STRING;
-	parm.c->requ
 ired = NO;
-	parm.c->description = _("Double or integer attribute in 'centers' map with individual 'C' values");
-	parm.c->guisection = _("Basic");
-	/* global a */
-	parm.a = G_define_option ();
-	parm.a->key = "a";
-	parm.a->type = TYPE_DOUBLE;
-	parm.a->required = YES;
-	parm.a->answer = "0.5";
-	parm.a->description = _("Global setting for 'a'");
-	parm.a->guisection = _("Basic");
-	/* global k */
-	parm.k = G_define_option ();
-	parm.k->key = "k";
-	parm.k->type = TYPE_DOUBLE;
-	parm.k->required = NO;
-	parm.k->description = _("Global setting for 'k'");
-	parm.k->guisection = _("Basic");
-	/* cost surface attribute */
-	parm.costs_att = G_define_option ();
-	parm.costs_att->key = "costs_att";
-	parm.costs_att->type = TYPE_STRING;
-	parm.costs_att->required = NO;
-	parm.costs_att->description = _("Text attribute in 'centers' map that stores names of raster cost maps");
-	parm.costs_att->guisection = _("Basic");
-	/* write ASCII report file? */
-	parm.report =
 G_define_standard_option (G_OPT_F_OUTPUT);
-	parm.report->key = "report";
-	parm.report->type = TYPE_STRING;
-	parm.report->required = NO;
-	parm.report->description = _("Name of ASCII file to write report to");
-	parm.report->guisection = _("Basic");
-	/* impose I >= 0 restriction? */
-	flag.strict = G_define_flag ();
-	flag.strict->key = 's';
-	flag.strict->description = _("Impose original restriction I >= 0");
-	flag.strict->guisection = _("Basic");
-	/* tabular format report file? */
-	flag.tabular = G_define_flag ();
-	flag.tabular->key = 't';
-	flag.tabular->description = _("Tabular output format for report file");
-	flag.tabular->guisection = _("Basic");
-	parm.second = G_define_standard_option(G_OPT_R_OUTPUT);
-	parm.second->key = "comp_id";
-	parm.second->type = TYPE_STRING;
-	parm.second->required = NO;
-	parm.second->description = _("New raster map to store ID of strongest competitor");
-	parm.second->guisection = _("Enhancements");
-	/* Error m
 ap/attribute name */
-	parm.errors = G_define_standard_option(G_OPT_R_OUTPUT);
-	parm.errors->key = "comp_strength";
-	parm.errors->type = TYPE_STRING;
-	parm.errors->required = NO;
-	parm.errors->description = _("New raster map to store strength of competitor");
-	parm.errors->guisection = _("Enhancements");
-	parm.maxdist = G_define_option ();
-	parm.maxdist->key = "reach";
-	parm.maxdist->type = TYPE_STRING;
-	parm.maxdist->required = NO;
-	parm.maxdist->description = _("Double attribute in 'centers' map for maximum distance/cost reach");
-	parm.maxdist->guisection = _("Enhancements");
-	parm.ruler = G_define_option ();
-	parm.ruler->key = "ruler";
-	parm.ruler->type = TYPE_STRING;
-	parm.ruler->required = NO;
-	parm.ruler->description = _("Integer attribute in 'centers' map that points to ID of ruling center");
-	parm.ruler->guisection = _("Enhancements");
-	#ifdef EXPERIMENTAL
-	parm.ally = G_define_option ();
-	parm.ally->key = "ally";
-	parm.ally->type = TYPE
 _STRING;
-	parm.ally->required = NO;
-	parm.ally->description = _("Text attribute in 'centers' map with comma-separated list of ally IDs");
-	parm.ally->guisection = _("Enhancements");
-	#endif
-	/* indexing attribute */
-	parm.cats = G_define_option ();
-	parm.cats->key = "categories";
-	parm.cats->type = TYPE_STRING;
-	parm.cats->required = NO;
-	parm.cats->answer = "cat";
-	parm.cats->description = _("Integer attribute in 'centers' map to use as output raster map categories");
-	parm.cats->guisection = _("Mapping");
-	/* can be used to label raster categories (mode 'areas') or add a labeling attribute in mode 'sites'*/
-	parm.labels = G_define_option ();
-	parm.labels->key = "labels";
-	parm.labels->type = TYPE_STRING;
-	parm.labels->required = NO;
-	parm.labels->description = _("Text attribute in 'centers' map for labeling output raster map categories");
-	parm.labels->guisection = _("Mapping");
-	/* RGB colouring attribute */
-	parm.rgbcol = G_define_option
-	parm.rgbcol->key = "rgb_column";
-	parm.rgbcol->type = TYPE_STRING;
-	parm.rgbcol->required = NO;
-	parm.rgbcol->answer = "GRASSRGB";
-	parm.rgbcol->description = _("String attribute (RRR:GGG:BBB) in 'centers' map for category colors");
-	parm.rgbcol->guisection = _("Mapping");
-	/* setup some basic GIS stuff */
-	G_gisinit (argv[0]);
-	if (G_parser(argc, argv))
-        	exit(-1);
-	/* do not pause after a warning message was displayed */
-	G_sleep_on_error (0);
-/* check for valid combinations of parameters/options */
-/* check for valid map and attribute names and types */
-void check_params ( void ) {
-	int num_specs;
-	double k_val;
-	/* enable verbosity, overwrite, progess display? */
-	VERBOSE = 0;
-	OVERWRITE = 0;
-	PROGRESS = 1;
-	if ( module->verbose ) {
-		VERBOSE = 1;
-	if ( module->overwrite ) {
-		OVERWRITE = 1;
-	/* stuff relating to report file writing */
-	if ( flag.tabular->answer ) {
-		if ( parm.report->answer ==
  NULL ) {
-			G_warning (_("-t flag only makes sense if option 'report=' is specified. Ignoring.\n"));
-	/* 1. FORMULA PROPERTIES */
-	if ( (parm.errors->answer) && (parm.second->answer==NULL) ) {
-		G_fatal_error (_("Mapping strength of competition requires providing a name for the 'competitor ID' map.\n"));
-	/* set appropriate value for k, if user did not provide one! */
-	if ( parm.k->answer == NULL ) {
-		G_warning (_("No value for k given. Will set a default value."));
-		parm.k->answer = G_malloc ( sizeof (char) * 255 );
-		k_val = 0.0001;
-		/* lat-long system */
-		if ( G_projection () == 3 ) {
-			G_warning (_("You are working in a lat-long location. Appropriate value for 'k' depends on latitude."));
-		} else {
-			/* we assume a system based on meters */
-			G_warning (_("Assuming meter-based coordinate system."));
-		if ( parm.costs_att->answer != NULL ) {
-			G_warning (_("Using cost maps. Appropriate value for k depends on cos
 t units."));
-		sprintf ( parm.k->answer, "%f", k_val);
-		G_warning (_("Guessing k = %f. No guarantee this will work"), k_val);
-	/* 3. DISTANCE MODE */
-	DISTANCE = STRAIGHT; /* default is to use a straight-line distance measure */
-	COSTMODE = NONE;
-	/* check if user specified more than one way of naming cost maps */
-		num_specs ++;
-		COSTMODE = ATTNAME;
-		DISTANCE = COST;
-/* write a report to an ASCII file on disk */
-void write_report ( int *cats, char **labels, int argc, char *argv[] ) {
-	struct report_struct *report;
-	FILE *fp;
-	int error;
-	int i,j;
-	int fd_output, fd_second, fd_errors;
-	long int total_cells;
-	long int *competitor;
-	long int max;
-	char tmp [5000];
-	time_t systime;
-	clock_t proctime;
-	unsigned long timeused;
-	unsigned int days, hours, mins, secs;
-	double sqdiff;
-	struct Cell_head window;
-	int row, col;
-	int nrows, ncols;
-	double east, no
 rth;
-	int boss;
-	G_get_window (&window);
-	nrows = G_window_rows ();
-	ncols = G_window_cols ();
-	fp = fopen ( parm.report->answer, "w+" );
-	if ( fp == NULL ) {
-		G_fatal_error ("Failed to open file '%s' for report writing.\n", parm.report->answer );
-	report = G_malloc ( num_centers * sizeof ( struct report_struct ) );
-	fd_output = G_open_cell_old ( parm.output->answer, G_find_cell ( parm.output->answer, "" ) );
-	fd_second = -1;
-	if ( parm.second->answer ) {
-		fd_second = G_open_cell_old ( parm.second->answer, G_find_cell ( parm.second->answer, "" ) );
-	fd_errors = -1;
-	if ( parm.errors->answer ) {
-		fd_errors = G_open_cell_old ( parm.errors->answer, G_find_cell ( parm.errors->answer, "" ) );
-	if ( PROGRESS )
-		G_message (_( "Writing report file to '%s':\n"), parm.report->answer);
-	/* alloc some counter arrays */
-	competitor = G_malloc ( sizeof ( long int) * num_centers );
-	/* make room for storing subjects */
 for ( i=0; i < num_centers; i ++ ) {
-		report[i].num_subjects = 0;
-		report[i].subject = G_malloc ( sizeof (int) * num_centers );
-		report[i].subject_id = G_malloc ( sizeof (int) * num_centers );
-		report[i].subject_name = G_malloc ( sizeof (char*) * num_centers );
-	/* init area calculations */
-	error = G_begin_cell_area_calculations ();
-	/* get map statistics */
-	if ( PROGRESS )
-		G_message (_("  Getting map statistics:\n" ));
-	GVT_rewind ( pmap );
-	i = 0;
-	while ( GVT_next ( pmap ) ) {
-		if ( error == 0 ) {
-			/* area cannot be calculated in x/y locations */
-			report[i].area = -1.0;
-		} else {
-			report[i].area = 0.0;
-		report[i].id = cats[i];
-		if ( parm.labels->answer ) {
-			report[i].name = strdup ( labels[i] );
-		/* get basic raster stats */
-		report[i].out_count = 0;
-		total_cells = 0;
-		for (row=0; row < nrows; row ++) {
-			G_get_c_raster_row ( fd_output, cell, row );
-			for (col=0; col < ncols; col ++) {
 if ( !G_is_c_null_value ( &cell[col]) ) {
-					if ( cell[col] == cats[i] ) {
-							report[i].out_count ++;
-							if ( error > 0 ) {
-								/* update area stats */
-								report[i].area = report[i].area + G_area_of_cell_at_row ( row );
-					total_cells ++;
-		/* calculate area (km^2), percentage and maximum reach of this center's territory */
-		report[i].area = report[i].area / 1000000;
-		report[i].percentage =  ( ( (double) report[i].out_count / (double) total_cells) * 100.0 );
-		report[i].max_cost = max_cost[i];
-		/* get error stats */
-			report[i].err_count = 0;
-			report[i].err_sum = 0.0;
-				G_get_d_raster_row ( fd_errors, dcell, row );
-					if ( !G_is_c_null_value ( &cell[col]) ) {
-								report[i].err_count ++
-								report[i].err_sum = report[i].err_sum + (double) dcell[col];
-			report[i].err_avg = ((double) report[i].err_sum / report[i].err_count);
-			/* now get error var and std */
-			report[i].err_var = 0;
-			report[i].err_std = 0.0;
-			sqdiff = 0.0;
-							sqdiff = sqdiff + pow ( ((double) dcell[col] - (double) report[i].err_avg), 2.0 );
-			report[i].err_var = (1.0 / (double) report[i].err_count) * sqdiff;
-			report[i].err_std = sqrt ( report[i].err_var );
-		/* get information about competitors (second highest I) */
-			/* initialize counters */
-			for ( j=0; j < num_centers; j ++ ) {
 				competitor[j] = 0;
-			report[i].aggressor = 0;
-				G_get_c_raster_row ( fd_second, cell_second, row );
-							/* we have a cell that belongs to the current center */
-							/* which on is the most frequent competitor in current center's territory?
-							 * count frequencies for all centers in array of i counters
-							 * we'll find the index of the largest counter when the raster map loop is done.
-							 for (j=0; j < num_centers; j++) {
-							 	if ( cats[j] == cell_second[col] ) {
-							 		competitor [j] ++;
-						} else {
-							/* we have a cell that is outside the current center's territory */
-							/* how frequent is the current center second
 highest I in the territory of another?  */
-							if ( cell_second[col] == cats[i] ) {
-								/* just sum up and also calculate percentage (against number of cells in foreing territories) */
-								report[i].aggressor ++;
-			/* find most frequent competitor */
-			max = -1;
-			report[i].competitor = 0;
-			report[i].competitor_id = cats[0];
-			for ( j=1; j< num_centers; j ++ ) {
-				if ( (competitor[j] > 0) && ( competitor[j] > max ) ) {
-					max = competitor[j];
-					report[i].competitor = j;
-					report[i].competitor_id = cats[j];
-			/* no competitor found! */
-			if ( max == -1 ) {
-				report[i].competitor = -1;
-			} else {
-				/* get percentage */
-				report[i].competitor_p = ((double) max / (double) report[i].out_count) * 100.0;
-			report[i].aggressor_p =  ( (double)report[i].aggressor / ((double)total_cells - (double)report[i].out_count) )  * 100.0;
-		if ( PROGRESS )
-			G_percent (i, num_centers-1, 1);		}
-		i ++;
-	/* now check for boss and/or subjects! */
-	/* check the cell under each center. If it's not owned by the center, then that
-	 * center is dominated by another and we need to store its ID.
-	i = 0;
-		report[i].boss = -1;
-		east = G_easting_to_col ( GVT_get_point_x ( pmap ), &window );
-		north = G_northing_to_row ( GVT_get_point_y ( pmap ), &window );
-		G_get_c_raster_row ( fd_output, cell, (int) north );
-		boss = (CELL) cell[(int) east];
-		if ( boss != cats[i] ) {
-			/* this center is dominated by another center! Store that center's ID */
-				if ( cats[j] == boss ) {
-					report[i].boss = j;
-					report[i].boss_id = boss;
-						report[i].boss_name = strdup ( labels[j] );
-					/* also: append ID and name of this center to the bosse's list */
-					re
 port[j].subject[report[j].num_subjects] = i;
-					report[j].subject_id[report[j].num_subjects] = cats[i];
-						report[j].subject_name[report[j].num_subjects] = strdup ( labels[i] );
-					report[j].num_subjects ++;
-		i++;
-	/* write records to ASCII file */
-	if ( PROGRESS )
-		G_message (_( "  Writing individual records:\n" ));
-		/* header line for tabular report output */
-		fprintf ( fp, "id\tname\trulerid\trname\tcells\tcellsp\tarea\treach" );
-			fprintf ( fp, "\taggressor\taggperc\tcompid\tcompname\tcompperc" );
-			fprintf ( fp, "\tstravg\tstrvar\tstrdev" );
-		fprintf ( fp, "\n" );
-	if ( !flag.tabular->answer ) {
-		/* make a nice header */
-		fprintf ( fp, "This is %s version %.2f\n", argv[0], PROGVERSION);
-		systime = time (NULL);
-		fprintf ( fp, "Ca
 lculation started on %s", ctime ( &systime ) );
-		fprintf ( fp, "\tlocation   = %s\n", G_location() );
-		fprintf ( fp, "\tmapset     = %s\n", G_mapset() );
-		sprintf ( tmp, "%s ", argv[0]);
-		for ( j=1; j < argc; j ++ ) {
-			strcat ( tmp, argv[j] );
-			if ( j < (argc - 1) ) {
-				strcat ( tmp, " " );
-		fprintf ( fp, "\tcommand    = %s\n\n", tmp );
-		fprintf ( fp, "===\n\n" );
-	for ( i=0; i < num_centers; i++ ) {
-			/* tabular output: one line per center and always with complete fields */
-			fprintf ( fp, "%i", report[i].id );
-				fprintf ( fp, "\t%s", report[i].name );
-			} else {
-				fprintf ( fp, "\tn.a." );
-			if ( report[i].boss > -1 ) {
-				fprintf ( fp, "\t%i", report[i].boss_id );
-					fprintf ( fp, "\t%s", report[i].boss_name );
-				} else {
-				fprintf ( fp, "\t0" );
-				fprintf (
 fp, "\t0.0" );
-				fprintf ( fp, "\t0.0" );
-			} else {
-				fprintf ( fp, "\t%i", report[i].id );
-				} else {
-				fprintf ( fp, "\t%li", report[i].out_count );
-				fprintf ( fp, "\t%.3f", report[i].percentage );
-				fprintf ( fp, "\t%.3f", report[i].area );
-				fprintf ( fp, "\t%.3f", report[i].max_cost );
-				if (( report[i].aggressor > 0 ) && ( report[i].boss < 0 )) {
-					fprintf ( fp, "\t%li", report[i].aggressor);
-					fprintf ( fp, "\t%.3f", report[i].aggressor_p );
-				} else {
-				if (( report[i].competitor > -1 ) && ( report[report[i].competitor].boss != i ) && ( report[i].boss < 0 )) {
-					fprintf ( fp, "\t%i", report[i].competitor_id);
-					fprintf ( fp, "\t%s", labels[repor
 t[i].competitor]);
-					fprintf ( fp, "\t%.3f", report[i].competitor_p );
-				} else {
-					fprintf ( fp, "\t%.3f", report[i].err_avg );
-					fprintf ( fp, "\t%.3f", report[i].err_var );
-					fprintf ( fp, "\t%.3f", report[i].err_std );
-				} else {
-			fprintf ( fp, "\n" ) ;
-		} else {
-			/* this is regular report format: one paragraph per center */
-			/* write records to report file */
-			fprintf ( fp, "(center %i of %i)\n", i + 1, num_centers );
-			fprintf ( fp, "id:\t\t%i\n", report[i].id );
-				fprintf ( fp, "name:\t\t%s\n", repo
 rt[i].name );
-			} else {
-				fprintf ( fp, "name:\t\tn.a.\n" );
-			if ( report[i].num_subjects > 0 ) {
-				fprintf ( fp, "dominates:\t" );
-				for ( j=0; j<report[i].num_subjects; j ++ ) {
-						fprintf ( fp, "%i (%s)", report[i].subject_id[j], report[i].subject_name[j] );
-					} else {
-						fprintf ( fp, "%i", report[i].subject_id[j] );
-					if ( j < (report[i].num_subjects-1) ) {
-						fprintf ( fp, ", " );
-				fprintf ( fp, "\n");
-			} else {
-				fprintf ( fp, "dominates:\tn.a.\n" );
-					fprintf ( fp, "dominated by:\t%i, %s\n", report[i].boss_id, report[i].boss_name );
-				} else {
-					fprintf ( fp, "dominated by:\t%i\n", report[i].boss_id );
-			} else {
-				fprintf ( fp, "dominated by:\tn.a.\n" );
-				fprintf ( fp, "cells:\t\t%li (%.3f%%)\n", report[i].out_count, report[i].percentage );
 if ( report[i].area > -1.0 ) {
-					fprintf ( fp, "area:\t\t%.3f sqkm\n", report[i].area );
-				if ( DISTANCE == COST ) {
-					fprintf ( fp, "reach cost:\t%.3f cells\n", report[i].max_cost );
-				} else {
-					fprintf ( fp, "reach dist:\t%.3f km\n", report[i].max_cost / 1000 );
-					fprintf ( fp,"aggressor:\t%li (%.3f%%)\n", report[i].aggressor, report[i].aggressor_p );
-				} else {
-					fprintf ( fp,"aggressor:\tn.a.\n" );
-					fprintf ( fp,"competitor:\t%i, %s (%.3f%%)\n", report[i].competitor_id, labels[report[i].competitor], report[i].competitor_p );
-				} else {
-					fprintf ( fp,"competitor:\tn.a.\n" );
-					fprintf ( fp, "strength avg:\t%.3f\n", report[i].err_avg );
-					fprintf ( fp, "strength var:\t%.3f\n", report[i].err_var );
-					fprintf ( fp, "strength std:\t%.3f\n", report[i].err_std );
-				} else {
-					fprintf ( fp, "strength avg:\tn.a.\n" );
-					fprintf ( fp, "strength var:\tn.a.\n" );
-					fprintf ( fp, "strength std:\tn.a.\n" );
-			fprintf ( fp, "\n\n" );
-			if ( PROGRESS ) {
-				G_percent ( i, num_centers-1, 1 );
-		/* write a nice footer */
-		/* write processing time to logfile */
-		proctime = clock ();
-		timeused = (unsigned long) proctime / CLOCKS_PER_SEC;
-		days = timeused / 86400;
-		hours = (timeused - (days * 86400)) / 3600;
-		mins = (timeused - (days * 86400) - (hours * 3600)) / 60;
-		secs = (timeused - (days * 86400) - (hours * 3600) - (mins * 60));
-		fprintf ( fp, "==="
-		fprintf ( fp, "\n\nCalculation finished %s",ctime(&systime));
-		fprintf ( fp, "Processing time: %id, %ih, %im, %is\n",
-				days, hours, mins, secs );
-		fflush ( fp );
-	fclose ( fp );
-	/* TODO: also release invidual members of the report struct */
-	G_free ( report );
-	/* close output map(s) */
-	G_close_cell ( fd_output );
-		G_close_cell ( fd_second );
-		G_close_cell ( fd_errors );
-				MAIN
-int main (int argc, char *argv[]) {
-	int i,j;
-	char tmp[5000];
-	int row, col;
-	int nrows, ncols;
-	double east, north;
-	int fd, fd_temp, fd_error;
-	int fd_second;
-	int fd_boundaries;
-	double x, y;
-	double max_d;
-	double max_c;
-	double C_total;
 	/* for raster map categories, labels and colours */
-	int *cats;
-	char **labels;
-	struct Categories pcats;
-	char **rgb;
-	int r,g,b;
-	/* map history */
-	struct History hist;
-	/* color map rules */
-	struct Colors *colors;
-	DCELL *v1, *v2;
-	int error;
-	double diff;
-	double max_diff;
-	double dist;
-	int valid_I;	/* this var is set to "1", if at least one cell was found to belong to the territory of any
-					   any center in the input map. Its purpose is to guard against cases, where strict mode
-					   is used (-s) and the model parameters are set badly, so that the user is presented
-					   with an all NULL output map
-	int matched;
-	int boss;
-	define_opts ( argc, argv );
-	check_params ();
-	GVT_init ();
-	pmap = GVT_new_map ( );
-	GVT_open_map ( parm.centers->answer, GV_POINT , pmap );
-	a = atof ( parm.a->answer );
 k = atof ( parm.k->answer );
-	C = G_malloc ( sizeof (double) * pmap->num_records );
-	/* init file descriptors */
-	fd_temp = -1;
-	fd_second = -1;
-	fd_boundaries = -1;
-	if ( parm.c->answer != NULL ) {
-		/* check if C attribute exists */
-		if ( GVT_any_exists ( parm.c->answer, pmap) == FALSE ) {
-				G_fatal_error (_("Error reading C attribute: '%s' does not exist in input vector map '%s'.\n"),
-						parm.c->answer, parm.centers->answer );
-		if ( GVT_numeric_exists ( parm.c->answer, pmap) == FALSE ) {
-						G_fatal_error (_("Error reading C attribute: '%s' is not of type double or integer in input vector map '%s'.\n"),
-		i = 0;
-		C_total = 0;
-			C[i] = GVT_get_numeric ( parm.c->answer, pmap );
-			if ( DEBUG > 1 ) {
-				G_message (_( " %i: C=%.f\n"), i, C[i]);
-			C_total = C_total + C[i];
-			i ++;
-		num_centers = i;
-		/* normalize C attributes */
-		C_norm = G_malloc ( sizeof (double) * num_centers );
-		for ( i = 0; i < num_centers; i ++ ) {
-			C_norm [i] = (double) C[i] / (double) C_total;
-	} else {
-		/* we still need to know at least the number of centers (sites) in the input map! */
-		num_centers = 0;
-			num_centers ++;
-	/* if no attribute for C given: set it to 1.0 for each center */
-	if (parm.c->answer == NULL ) {
-		G_warning (_("No C attribute specified. Assuming constant C=1.0.\n"));
-		for ( i=0; i<pmap->num_records; i++) {
-			C[i] = 1.0;
-	cats = NULL;
-	/* no categories attribute specified? create a new index starting at 1! */
-	if ( parm.cats->answer == NULL ) {
-		cats = G_malloc ( sizeof (int) * num_centers );
-			cats[i] = i + 1;
-	/* check if cats attribute exists and is of type integer */
-	if ( parm.cats->
 answer != NULL ) {
-		if ( GVT_any_exists ( parm.cats->answer, pmap) == FALSE ) {
-			G_warning (_("Error reading categories attribute: '%s' does not exist in input vector map '%s'.\n"),
-					parm.cats->answer, parm.centers->answer );
-				cats[i] = i + 1;
-		} else {
-		if ( GVT_int_exists ( parm.cats->answer, pmap) == FALSE ) {
-				G_warning (_("Error reading categories attribute: '%s' is not of integer type in input vector map '%s'.\n"),
-					cats[i] = i + 1;
-		if ( GVT_int_exists ( parm.cats->answer, pmap) == TRUE ) {
-			/* categories label is cool, so let's read in all category values in input vector map */
-			i = 0;
-				cats[i] = GVT_get_int ( parm.cats->answer, pmap);
-				i ++;
-	labels = NULL;
-	/* labeling attribute? */
-	if ( parm.labels->answer != NULL ) {
-		if ( GVT_any_exists ( parm.labels->answer, pmap) == FALSE ) {
-				G_fatal_error (_("Error reading label attribute: '%s' does not exist in input vector map '%s'.\n"),
-						parm.labels->answer, parm.centers->answer );
-		if ( GVT_string_exists ( parm.labels->answer, pmap) == FALSE ) {
-				G_fatal_error (_("Error reading label attribute: '%s' is not of text type in input vector map '%s'.\n"),
-	colors = NULL;
-	/* colouring attribute? */
-	make_colors = 0;
-	if ( parm.rgbcol->answer ) {
-		if ( GVT_any_exists ( parm.rgbcol->answer, pmap) == FALSE ) {
-				if ( strcmp ( parm.rgbcol->answer, "GRASSRGB" ) ) {
-					G_warning (_("Colors attribute: '%s' does not exist in input vector map '%s'. Using default co
 lors.\n"),
-						parm.rgbcol->answer, parm.centers->answer );
-		} else {
-			if ( GVT_string_exists ( parm.rgbcol->answer, pmap) == FALSE ) {
-					G_warning (_("Colors attribute: '%s' is not of text type in input vector map '%s'. Using default colors.\n"),
-		if ( GVT_string_exists ( parm.rgbcol->answer, pmap) == TRUE ) {
-		  /* colouring attribute is cool, so read in colours */
-			rgb = G_malloc ( sizeof (char*) * num_centers );
-			i = 0;
-				rgb[i] = GVT_get_string ( parm.rgbcol->answer, pmap);
-				i ++;
-			make_colors = 1;
-	/* allocate an array of center reaches (max cost/dist from a center to claim a cell) */
-	reach = G_malloc ( sizeof (double) * pmap->num_records );
-	for ( i=0; i < num_centers; i ++ ) {
-		reach[i] = -1.0; /* set all centers to unconstrained reach by default */
-	/* maximum cos
 t/distance attribute specified ? */
-	if ( parm.maxdist->answer ) {
-		/* check for valid attribute */
-		if ( GVT_any_exists ( parm.maxdist->answer, pmap) == FALSE ) {
-				G_fatal_error (_("Error reading max reach attribute: '%s' does not exist in input vector map '%s'.\n"),
-								parm.maxdist->answer, parm.centers->answer );
-		if ( GVT_double_exists ( parm.maxdist->answer, pmap) == FALSE ) {
-				G_fatal_error (_("Error reading max reach attribute: '%s' exists in input vector map '%s' but is not of type double.\n"),
-		/* read in all reach values */
-		i = 0;
-			reach[i] = GVT_get_double ( parm.maxdist->answer, pmap );
-			i ++;
-	/* allocate an array of ruler pointers */
-	ruler = G_malloc ( sizeof (int) * pmap->num_records );
-		ruler[i] = i; /* set all centers to be their own rulers by default *
-	/* ruler attribute specified ? */
-	if ( parm.ruler->answer ) {
-		if ( GVT_any_exists ( parm.ruler->answer, pmap) == FALSE ) {
-				G_fatal_error (_("Error reading ruler attribute: '%s' does not exist in input vector map '%s'.\n"),
-								parm.ruler->answer, parm.centers->answer );
-		if ( GVT_int_exists ( parm.ruler->answer, pmap) == FALSE ) {
-				G_fatal_error (_("Error reading ruler attribute: '%s' exists in input vector map '%s' but is not of type integer.\n"),
-		i = 0;
-			ruler[i] = GVT_get_int ( parm.ruler->answer, pmap );
-			i ++;
-		/* now translate the category IDs to the sequential IDs in pmap */
-		for ( i=0; i <= num_centers; i ++ ) {
-			matched = 0;
-			for ( j=0; j <= num_centers; j ++ ) {
-				if ( cats[j] == ruler[i] ) {
-					ruler[i] = j;
-					mat
 ched = 1;
-			if ( matched == 0 ) {
-				G_fatal_error (_("Ruler ID '%i' in record no. %i in input map '%s' points to a non-existing record.\n"),
-									ruler[i], i, parm.output->answer );
-	/* register an AT EXIT function that will make sure temp maps
-	 * get deleted
-	atexit ( clean_tmpfiles );
-	/* cost surface mode? check for valid maps or create them ad hoc !!! */
-		make_pseudo = 0;
-		if ( COSTMODE == ATTNAME ) { /* User has specified an attribute name for cost surfaces */
-			/* check if map name attribute exists */
-			if ( GVT_any_exists ( parm.costs_att->answer, pmap) == FALSE ) {
-					G_fatal_error (_("Error reading map name attribute: '%s' does not exist in input vector map '%s'.\n"),
-									parm.costs_att->answer, parm.centers->answer );
-			if ( GVT_string_exists ( parm.costs_att->answer, pmap) == FALSE ) {
 '%s' is not of string type in input vector map '%s'.\n"),
-			/* allocate mem for pointers to cost maps and open all maps */
-			costf = G_calloc ( (unsigned) num_centers, sizeof (int));
-			i = 0;
-				cmapname = GVT_get_string ( parm.costs_att->answer, pmap );
-				costf[i] = G_open_cell_old ( cmapname, G_find_cell ( cmapname, "" ) );
-				if ( costf[i] < 0 ) {
-					G_fatal_error (_("Error opening cost surface raster '%s').\n"),cmapname);
-				i ++;
-				G_free ( cmapname );
-			/* allocate mem for raster map buffers to read data from cost maps */
-			costdcell = G_calloc ( (unsigned) num_centers, sizeof (DCELL*) );
-			for ( i = 0; i < num_centers; i++ ) {
-				costdcell[i] = G_allocate_d_raster_buf();
-			/* allocate an array of doubles for storing cost values */
-			costs = G_calloc ( (unsigned) num_centers, sizeof (double))
-	 * CALCULATE XTENT MODEL
-	if ( PROGRESS )
-		G_message (_("Calculating Xtent model for %i centers:\n"), num_centers);
-	valid_I = 0;
-	/* this globally tracks the maximum distance to each center from within
-	 * any cell in its territory. We may need this for report writing later
-	max_cost = G_malloc ( num_centers * sizeof ( double ) );
-		max_cost[i] = -1.0;
-	cell = G_allocate_c_raster_buf();
-	fd = G_open_cell_new ( parm.output->answer );
-	if ( fd < 0 ) {
-		G_fatal_error (_("Could not open output map %s for writing.\n"), parm.output->answer);
-	/* also output a map of "second best" centers?*/
-	if ( parm.second->answer != NULL ) {
-		cell_second = G_allocate_c_raster_buf();
-		fd_second = G_open_cell_new ( parm.second->answer );
-		if ( fd_second < 0 ) {
-			G_fatal_error (_("Could not open 'second highest I' map %s for writing.\n"), parm.second->answer);
 * also output a map of error probability ? */
-	if ( parm.errors->answer != NULL ) {
-		/* for now, we'll just create a temporary map to store the
-		 * unnormalized error
-		temapname = mktmpmap ( "XTENTtmp" );
-		dcell = G_allocate_d_raster_buf();
-		G_set_fp_type(DCELL_TYPE);
-		fd_temp = G_open_fp_cell_new ( temapname );
-		if ( fd_temp < 0 ) {
-			G_fatal_error (_("Could not open temporary error map %s for writing.\n"), temapname );
-		make_error = 1;
-	max_c = 1;
-	max_d = 1;
-	/* write a raster map with an I value for each cell */
-	if ( PROGRESS )
-		G_message (_(" Calculating I values for all cells in region:\n"));
-		G_set_c_null_value ( cell, ncols );
-			G_set_d_null_value ( dcell, ncols );
-			/* if we have cost surfaces, we need to read one row from each map */
  ( costf[i], costdcell[i], row );
-		y = G_row_to_northing ( (double) row, &window );
-				/* if we have cost surfaces, we need to read the cost value for each center in this column */
-					costs[i] = (double) costdcell[i][col];
-			x = G_col_to_easting ( (double) col, &window );
-			/* calculate XTENT value I at current coordinates */
-				I = get_center_xtent_original ( x, y, C_norm, a, k, costs, reach, ruler, pmap );
-			} else {
-				I = get_center_xtent_original ( x, y, C, a, k, costs, reach, ruler, pmap );
-			/* update max cost value for this center if necessary */
-			if ( I >= 0 ) {
-					if ( max_cost[I] < costs[I] ) {
-						if ( !G_is_d_null_value ( (DCELL*) &costs[I] ) ) {
-							max_cost[I] = costs[I];
 if ( DISTANCE == STRAIGHT ) {
-					dist = GVT_get_2D_point_distance ( x, y, pmap );
-					if ( dist > max_cost[I] ) {
-						max_cost[I] = dist;
-			if ( I < 0 ) {
-				/* this can only happen if there is an error calculating I or strict mode is turned on */
-				/* otherwise, the return value of I will be the INDEX of the dominant center ! */
-				G_set_c_null_value ( &cell[col], 1 );
-			} else {
-				cell[col] = (CELL) cats[I];
-			/* this signals that the model has managed to produce at least one center index ;) */
-			if ( (!G_is_c_null_value ( &cell[col] )) && ( I >= 0 ) ) {
-				valid_I = 1;
-			/* if one of the cost surfaces has a NULL value here, we will copy it thru, as well! */
-					if ( G_is_d_null_value (&costdcell[i][col])) {
-		G_put_map_row ( fd, cell );
-		if ( PROGRESS ) {
-			G_percent (row, (nrows-1), 2);
-	/* close basic output map for now */
-	G_close_cell ( fd );
-	/* Now we make a second pass to find the strongest competitor for each cell.
-	 * This code is full of redundant terminology. The following are all
-	 * basically the same: second I, second biggest I, competitor
-	 * The competitor is the center which would have claimed a cell if another,
-	 * more dominant center had not taken it. The difference between the influences
-	 * of the dominant center and the competitor is stored in the 'errors' map.
-	 * It can be interpreted both as the strength of competition and the likelihood
-	 * of making an error when claiming that a specific cell is in the territory of
-	 * center A rather then B.
-	 * The error (= competition strength) measure is normalized in another pass after this loop.
-	 max_diff = 0;
-		/* re-open basic output map */
 fd = G_open_cell_old ( parm.output->answer, G_find_cell ( parm.output->answer, "" ) );
-		if ( PROGRESS )
-			G_message ( " Finding competitors for all cells in region:\n");
-		/* If center A is dominated by center B, then it can no longer be a competitor of center B !
-	 	* So we need to first identify all such situations and update the 'ruler' array accordingly.
-		i = 0;
-			G_get_c_raster_row ( fd, cell, (int) north );
-						ruler[i] = j;
-			i++;
-			/* initialize error map
 to be all NULL cells */
-					G_get_d_raster_row ( costf[i], costdcell[i], row );
-				/* get second highest I */
-						I_second = get_center_xtent_second ( x, y, C_norm, a, k, &diff, costs, ruler, pmap );
-					} else {
 tent_second ( x, y, C, a, k, &diff, costs, ruler, pmap );
-					if ( diff > max_diff ) {
-						max_diff = diff;
-				if ( G_is_c_null_value ( &cell[col] ) ) {
-					/* if I map has a NULL val here, we need to copy it through */
-					/* because by definition: if I is invalid, then so is 'second I' (competitor) */
-					G_set_c_null_value ( &cell_second[col], 1 );
-						G_set_d_null_value ( &dcell[col], 1 );
-				} else {
-					/* if not, we set the current cell to the second biggest I (=ID of competitor) */
-					cell_second[col] = (CELL) cats[I_second];
-						/* at this point: just store the unnormalized strength of competition
-						 * We will make a second pass later of the 'errors' map to normalize this measure
-						dcell[col] = diff;
-				/* a competitor and competitor's strength (error) can only be cal
 culated where at least
-				 * two territories overlap!
-				if ( I_second < 0 ) {
-					/* this can only happen if there is an error calculating second I or strict mode is turned on */
-					/* otherwise, the return value of I will be the ID of the second most dominant center
-					 * as set above */
-								/* also: copy thru to error map! */
-			G_put_map_row ( fd_second, cell_second );
-				G_put_d_raster_row ( fd_temp, dcell );
-			if ( PROGRESS ) {
-	/* Normalize values in error output map ! */
-		/* we need to make a second pass and normalize the error
-		 * measuere over the whole error map
-		/* close and re-open the (temporary ) error map */
-		G_close_cell ( fd_temp );
-		fd_temp = G_open_cell_old ( temapname, G_find_cell ( temapname, "" ) );
-			G_fatal_error (_("Could not open temporary error map %s for reading.\n"), temapname );
-		/* create the new final (normalized) error map for writing */
-		fd_error = G_open_fp_cell_new ( parm.errors->answer );
-		if ( fd_error < 0 ) {
-			G_fatal_error (_("Could not open error map %s for writing.\n"), parm.errors->answer );
-		if ( max_diff == 0 ) { /* protect against extreme cases and divisio by zero */
-			G_warning (_("The maximum difference between I and second highest I in your map is 0.\n"));
-			if ( PROGRESS )
-				G_message (_( " Setting all error measures to 1.0:\n"));
-				G_get_d_raster_row ( fd_temp, dcell, row );
-					if ( !G_is_d_null_value ( &dcell[col]) ) {
-							dcell[col] = 1.0;
-				G_put_d_raster_row ( fd_error, dcell );
-				if ( PROGRESS ) {
-					G_percent (row, (nrows-1), 2);				}
-		} else {
-			if ( PROGRESS )
-				G_message ( " Normalizing error measures:\n");
-							/* this is the normalized error measure:
-							 * the closer to "1", the higher the risk of error
 -							dcell[col] = 1 - dcell[col] / max_diff;
-				if ( PROGRESS ) {
-		/* close raster maps */
-		G_close_cell ( fd_error );
-		/* make a nice gray-shade color table for output map */
-		colors = G_malloc ( sizeof (struct Colors));
-		G_init_colors ( colors );
-		v1 = (DCELL*) G_malloc (sizeof (DCELL));
-		v2 = (DCELL*) G_malloc (sizeof (DCELL));
-		*v1 = 1.0; *v2 = 0.0;
-		G_add_d_raster_color_rule ( v1,0,0,0,v2,255,255,255, colors );
-		G_write_colors ( parm.errors->answer, G_mapset (), colors );
-		G_init_cats ( num_centers, "Name of dominant center", &pcats );
-		/* write map labels */
-		labels = G_malloc ( num_centers * sizeof (char* ) );
-		GVT_rewind ( pmap ); i = 0;
-			labels[i] = GVT_get_string ( parm.labels->answer, pmap );
-			i ++;
-		/* add labels to output map categories */
-		error = 0;
-			error = G_set_cat ( cats[i], labels[i], &pcats );
-			if ( error == -1 ) {
-				G_warning (_("Error writing category label '%s': too many categories.\n"), labels[i] );
-					G_warning (_("Error writing category label '%s': got NULL category.\n"), labels[i] );
-		if ( error == 1 ) {
-			error = G_write_cats ( parm.output->answer, &pcats );
-			if ( error != 1 ) {
-				G_warning (_("Error writing categories for output map '%s'.\n"), parm.output->answer );
-				error = G_write_cats ( parm.second->answer, &pcats );
-					G_warning (_("Error writing categories for 'second highest I' map '%s'.\n"), parm.second->answer );
-		G_free_cats ( &pcats );
-	/* write raster map history */
-	G_short_history ( parm.output->answer, "raster", &hist
-	sprintf ( hist.title, "XTENT: ID of center with highest local I" );
-	error = G_write_history (parm.output->answer, &hist);
-		G_warning (_("Could not write history file for output raster map '%s'.\n"), parm.output->answer );
-		G_short_history ( parm.second->answer, "raster", &hist );
-		G_command_history ( &hist );
-		sprintf ( hist.title, "XTENT: ID of center with second highest local I" );
-		error = G_write_history (parm.second->answer, &hist);
-			G_warning (_("Could not write history file for 'competitor ID' raster map '%s'.\n"), parm.second->answer );
-		G_short_history ( parm.errors->answer, "raster", &hist );
-		sprintf ( hist.title, "XTENT: competition strength" );
-		error = G_write_history (parm.errors->answer, &hist);
-			G_warning (_("Could not write history file for 'err
 ors' raster map '%s'.\n"), parm.errors->answer );
-	/* make colour map for output maps if RGB attribute given */
-	if ( make_colors ) {
-		if ( parm.errors->answer == NULL ) {
-			/* we don't have a color table yet, because there is no error map */
-		i = 0;
-			if ( sscanf ( GVT_get_string ( parm.rgbcol->answer, pmap),"%i:%i:%i", &r, &g, &b ) != 3 ) {
-				G_warning ( "Malformed RGB attribute string in record no. %i.\n", i + 1 );
-			} else {
-				G_set_color ( (CELL) cats[i], r, g, b, colors );
-			i ++;
-		G_write_colors ( parm.output->answer, G_mapset (), colors );
-			G_write_colors ( parm.second->answer, G_mapset (), colors );
-	/* if user requested a report file to be written: do so now! */
-	if ( parm.report->answer ) {
-		write_report ( cats, labels, argc, ar
 gv );
-	/* warn, if model output is entirely empty! */
-	if ( flag.strict->answer ) {
-		if ( valid_I == 0 ) {
-			G_warning ("All cells in output map are NULL. You need to adjust your model parameters (C,a,k) or do not run in 'strict' mode.\n");
-	/* TODO: free colors struct */
-	/* free cell handles */
-	G_free ( cell );
-		G_free ( cell_second );
-		G_free ( dcell );
-	/* free other arrays */
-	G_free ( cats );
-	/* close input vector map 'centers' */
-	GVT_close_map ( pmap );
-	GVT_free_map ( pmap );
-	/* THAT'S IT, FOLKS! */
-	if ( PROGRESS ) {
-		G_message ("\nJOB DONE.\n");
-	return (0);
+/* r.xtent */
+	TODO Version 1.0
+	BUGS:
+		- Win32:
+		  Complains about not being able to remove fcell element for tmapnames[i]. But there is no
+		  fcell element for those maps, anyway !!! Maybe this is just a bug in current CVS
+  	DBF TROUBLES:
+    		- column names are limited to 10 chars
+	TEST:
+		- what happens, if some attribute values are bad in the input centers map?
+		- does this work with CENTROIDS instead of POINTS, as well ?
+		- do line breaks work for the protocol on Win32 (both regular and tabular)?
+		- NULL cells in input cost surfaces
+	General coding
+		- VALGRIND
+		- replace all G_system() with G_spawn(). G_spawn returns -1 on error, so this can be checked!
+        	   -> adjust tools.c run_cmd() to use G_spawn() instead of G_system()
+		- improve HTML documentation: math typesetting, better formatting. Pictures. Cross references.
+		- make status display work on Win32. [currently impossible?]
+		- ATTRIBUTE TYPE CHECKING: SOME COULD BE DOUBLE OR INT, BUT SHOULD ALWAYS BE HANDLED AS DOUBLE
+			-> use functions GVT_numeric_exists and GVT_get_numeric (), that always returns a double !!!
+			- Currently, only C attribute supports double and int, all other do strict type-checking. Should this
+			be relaxed?
+		- replace Posix funcs like strcpy with GRASS funcs, where available
+		- make sure that memory is dealloc'd properly for things like cats, labels, colors ...
+	Program functionality
+	  - a switch to output areal calculations in ha
+	  - let user define sqkm per cell for areal calculations in non-world systems
+	Documentation updates:
+	  - C gets normalized automatically!
+	  - territorial partitioning will always be complete, unless 'strict' flag given or reach
+	    constraint set
+	  - paragraph breaks between figures
+	  - add more examples, with strict mode and reach constraints
+    	  - reach constraint together with unrestricted formula is the recommended way of defining
+      	    territorial reach, as it is easier to control than the original I>=0 contraint!
+	TODO VERSION 2.X
+		A version 1.x should be done if there is enough user demand
+		Political attributes:
+			- Model constraints
+				* find a way to store for each site:
+					- allies: cannot claim each other's territory: if second highest I is an ally: do not touch it!
+			- if any constraints are given, then there should be a check for validity
+					to see if they hold in the model result (?!)
+		Misc.:
+			- user should be able to provide a map for spatially variable k (?)
+			- in very complex situations, the model may produce fragmented territories. E.g.:
+			r.xtent cent=sites output=test comp_id=comp comp_str=strength elev=dem -g --o
+			(Oaxaca dataset, with region set to extents of 'dem' and res=0:00:59)
+				-> Should this be catered for? If so, if a center gets captured, then all of
+				its cells in the output map (basic I) should be reclassified to the ID of
+				the new "boss" (this will automatically be taken care of in cases where
+				there is an a priori boss for that center, specified in the ruler= attribute).
+			- latex, html, rtf output style for protocols
+REVISON 0.99, OCT 2007
+FIX BUGS:
+UPDATE DOCUMENTATION!
+geom.c: in function get_distance():
+	delete line distance measure in case where a cost map is used to derive
+	distance: only take the cost value (costs[i]) and return that! [DONE]
+xent.c: the debugging output for "I=..." should be set to %.10f to allow floating
+	point values in much smaller ranges [DONE]
+Improvements for the next version of r.xtent:
+1. Normalize center weights, so that largest center's weight=1.0
+	-> Divide all weights by largest weight. This won't do
+	any harm to data that is already normalized, as it just
+	divides everything by "1"! This is also what R and L did
+	in their original study. [DONE]
+2. Use standard weight of "k=0.0001" for regions that use projected
+meter systems. This is the same as R and L did (although they used km as
+their unit of distance measurements which meant "k=0.1").
+Use standard weight of "k=0.000001?" for cost surface maps generated with
+r.walk. [DONE]
+3. Provide different functions for distance decay:
+a. Linear (already DONE)
+b. Exponential
+c. Sigmoid-function: P(t)=(1)/(1+e^t)
+	--> see Wikipedia entry on Sigmoid
+	For our purposes : P(t)=( 1- (1)/(1+e^t) )
+*** Open questions:
+a) How to model the hierarchical relations of sites that form alliances?
+b) How to choose "k" for regions that use lat-long and plain x/y systems?
+c) what to do with "residual territories", i.e. territories still claimed by a site A that has been
+taken over by another site B? Maybe allocate all territory that once belonged to A to B in a
+second "clean-up" pass?
+#define LOCAL
+#include <stdlib.h>
+#include <stdio.h>
+#include <errno.h>
+#include <string.h>
+#include <time.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "globals.h"
+#include "at_exit_funcs.h"
+#include "gt_vector.h"
+#include "xtent.h"
+#include "tools.h"
+/* variables global in main.c */
+GVT_map_s *pmap;
+double b_weight; /* weight for boundaries */
+double p_weight; /* weight for pathways */
+int *costf;
+CELL *cell;
+CELL *cell_second;
+DCELL *dcell;
+DCELL *dcell_boundaries;
+DCELL **costdcell;
+double *costs;
+double *reach;
+int *ruler;
+double *max_cost;
+char *boundaries_map;
+char *pathways_map;
+/* temporary map name strings */
+char *cmapname; /* name of a cost map */
+char *pseudomap; /* a pseudo friction map (all costs set to 1), used when only boundaries or pathways are supplied */
+/* DEFINE FLAGS AND OPTIONS */
+void define_opts ( int argc, char *argv[] ) {
+	module = G_define_module ();
+	module->description = "Calculate variations or original version of Renfrew and Level's Xtent model for territorial modeling.";
+	module->label = "r.xtent: territorial modelling with boundaries and movement costs";
+	module->keywords = _("raster,Xtent,territories,territorial analysis");
+	/* vector map with centers (sites only or network) */
+	parm.centers = G_define_standard_option (G_OPT_V_INPUT);
+	parm.centers->key = "centers";
+	parm.centers->type = TYPE_STRING;
+	parm.centers->required = YES;
+	parm.centers->description = _("Input map with vector points representing centers");
+	parm.centers->guisection = _("Basic");
+	/* Output map name */
+	parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
+	parm.output->key = "territories";
+	parm.output->description = _("Output raster map showing territories");
+	parm.output->guisection = _("Basic");
+	/* attribute that stores C for each center */
+	parm.c = G_define_option ();
+	parm.c->key = "c";
+	parm.c->type = TYPE_STRING;
+	parm.c->required = NO;
+	parm.c->description = _("Double or integer attribute in 'centers' map with individual 'C' values");
+	parm.c->guisection = _("Basic");
+	/* global a */
+	parm.a = G_define_option ();
+	parm.a->key = "a";
+	parm.a->type = TYPE_DOUBLE;
+	parm.a->required = YES;
+	parm.a->answer = "0.5";
+	parm.a->description = _("Global setting for 'a'");
+	parm.a->guisection = _("Basic");
+	/* global k */
+	parm.k = G_define_option ();
+	parm.k->key = "k";
+	parm.k->type = TYPE_DOUBLE;
+	parm.k->required = NO;
+	parm.k->description = _("Global setting for 'k'");
+	parm.k->guisection = _("Basic");
+	/* cost surface attribute */
+	parm.costs_att = G_define_option ();
+	parm.costs_att->key = "costs_att";
+	parm.costs_att->type = TYPE_STRING;
+	parm.costs_att->required = NO;
+	parm.costs_att->description = _("Text attribute in 'centers' map that stores names of raster cost maps");
+	parm.costs_att->guisection = _("Basic");
+	/* write ASCII report file? */
+	parm.report = G_define_standard_option (G_OPT_F_OUTPUT);
+	parm.report->key = "report";
+	parm.report->type = TYPE_STRING;
+	parm.report->required = NO;
+	parm.report->description = _("Name of ASCII file to write report to");
+	parm.report->guisection = _("Basic");
+	/* impose I >= 0 restriction? */
+	flag.strict = G_define_flag ();
+	flag.strict->key = 's';
+	flag.strict->description = _("Impose original restriction I >= 0");
+	flag.strict->guisection = _("Basic");
+	/* tabular format report file? */
+	flag.tabular = G_define_flag ();
+	flag.tabular->key = 't';
+	flag.tabular->description = _("Tabular output format for report file");
+	flag.tabular->guisection = _("Basic");
+	parm.second = G_define_standard_option(G_OPT_R_OUTPUT);
+	parm.second->key = "comp_id";
+	parm.second->type = TYPE_STRING;
+	parm.second->required = NO;
+	parm.second->description = _("New raster map to store ID of strongest competitor");
+	parm.second->guisection = _("Enhancements");
+	/* Error map/attribute name */
+	parm.errors = G_define_standard_option(G_OPT_R_OUTPUT);
+	parm.errors->key = "comp_strength";
+	parm.errors->type = TYPE_STRING;
+	parm.errors->required = NO;
+	parm.errors->description = _("New raster map to store strength of competitor");
+	parm.errors->guisection = _("Enhancements");
+	parm.maxdist = G_define_option ();
+	parm.maxdist->key = "reach";
+	parm.maxdist->type = TYPE_STRING;
+	parm.maxdist->required = NO;
+	parm.maxdist->description = _("Double attribute in 'centers' map for maximum distance/cost reach");
+	parm.maxdist->guisection = _("Enhancements");
+	parm.ruler = G_define_option ();
+	parm.ruler->key = "ruler";
+	parm.ruler->type = TYPE_STRING;
+	parm.ruler->required = NO;
+	parm.ruler->description = _("Integer attribute in 'centers' map that points to ID of ruling center");
+	parm.ruler->guisection = _("Enhancements");
+	#ifdef EXPERIMENTAL
+	parm.ally = G_define_option ();
+	parm.ally->key = "ally";
+	parm.ally->type = TYPE_STRING;
+	parm.ally->required = NO;
+	parm.ally->description = _("Text attribute in 'centers' map with comma-separated list of ally IDs");
+	parm.ally->guisection = _("Enhancements");
+	#endif
+	/* indexing attribute */
+	parm.cats = G_define_option ();
+	parm.cats->key = "categories";
+	parm.cats->type = TYPE_STRING;
+	parm.cats->required = NO;
+	parm.cats->answer = "cat";
+	parm.cats->description = _("Integer attribute in 'centers' map to use as output raster map categories");
+	parm.cats->guisection = _("Mapping");
+	/* can be used to label raster categories (mode 'areas') or add a labeling attribute in mode 'sites'*/
+	parm.labels = G_define_option ();
+	parm.labels->key = "labels";
+	parm.labels->type = TYPE_STRING;
+	parm.labels->required = NO;
+	parm.labels->description = _("Text attribute in 'centers' map for labeling output raster map categories");
+	parm.labels->guisection = _("Mapping");
+	/* RGB colouring attribute */
+	parm.rgbcol = G_define_option ();
+	parm.rgbcol->key = "rgb_column";
+	parm.rgbcol->type = TYPE_STRING;
+	parm.rgbcol->required = NO;
+	parm.rgbcol->answer = "GRASSRGB";
+	parm.rgbcol->description = _("String attribute (RRR:GGG:BBB) in 'centers' map for category colors");
+	parm.rgbcol->guisection = _("Mapping");
+	/* setup some basic GIS stuff */
+	G_gisinit (argv[0]);
+	if (G_parser(argc, argv))
+        	exit(-1);
+	/* do not pause after a warning message was displayed */
+	G_sleep_on_error (0);
+/* check for valid combinations of parameters/options */
+/* check for valid map and attribute names and types */
+void check_params ( void ) {
+	int num_specs;
+	double k_val;
+	/* enable verbosity, overwrite, progess display? */
+	VERBOSE = 0;
+	OVERWRITE = 0;
+	PROGRESS = 1;
+	if ( module->verbose ) {
+		VERBOSE = 1;
+	if ( module->overwrite ) {
+		OVERWRITE = 1;
+	/* stuff relating to report file writing */
+	if ( flag.tabular->answer ) {
+		if ( parm.report->answer == NULL ) {
+			G_warning (_("-t flag only makes sense if option 'report=' is specified. Ignoring.\n"));
+	/* 1. FORMULA PROPERTIES */
+	if ( (parm.errors->answer) && (parm.second->answer==NULL) ) {
+		G_fatal_error (_("Mapping strength of competition requires providing a name for the 'competitor ID' map.\n"));
+	/* set appropriate value for k, if user did not provide one! */
+	if ( parm.k->answer == NULL ) {
+		G_warning (_("No value for k given. Will set a default value."));
+		parm.k->answer = G_malloc ( sizeof (char) * 255 );
+		k_val = 0.0001;
+		/* lat-long system */
+		if ( G_projection () == 3 ) {
+			G_warning (_("You are working in a lat-long location. Appropriate value for 'k' depends on latitude."));
+		} else {
+			/* we assume a system based on meters */
+			G_warning (_("Assuming meter-based coordinate system."));
+		if ( parm.costs_att->answer != NULL ) {
+			G_warning (_("Using cost maps. Appropriate value for k depends on cost units."));
+		sprintf ( parm.k->answer, "%f", k_val);
+		G_warning (_("Guessing k = %f. No guarantee this will work"), k_val);
+	/* 3. DISTANCE MODE */
+	DISTANCE = STRAIGHT; /* default is to use a straight-line distance measure */
+	COSTMODE = NONE;
+	/* check if user specified more than one way of naming cost maps */
+		num_specs ++;
+		COSTMODE = ATTNAME;
+		DISTANCE = COST;
+/* write a report to an ASCII file on disk */
+void write_report ( int *cats, char **labels, int argc, char *argv[] ) {
+	struct report_struct *report;
+	FILE *fp;
+	int error;
+	int i,j;
+	int fd_output, fd_second, fd_errors;
+	long int total_cells;
+	long int *competitor;
+	long int max;
+	char tmp [5000];
+	time_t systime;
+	clock_t proctime;
+	unsigned long timeused;
+	unsigned int days, hours, mins, secs;
+	double sqdiff;
+	struct Cell_head window;
+	int row, col;
+	int nrows, ncols;
+	double east, north;
+	int boss;
+	G_get_window (&window);
+	nrows = G_window_rows ();
+	ncols = G_window_cols ();
+	fp = fopen ( parm.report->answer, "w+" );
+	if ( fp == NULL ) {
+		G_fatal_error ("Failed to open file '%s' for report writing.\n", parm.report->answer );
+	report = G_malloc ( num_centers * sizeof ( struct report_struct ) );
+	fd_output = G_open_cell_old ( parm.output->answer, G_find_cell ( parm.output->answer, "" ) );
+	fd_second = -1;
+	if ( parm.second->answer ) {
+		fd_second = G_open_cell_old ( parm.second->answer, G_find_cell ( parm.second->answer, "" ) );
+	fd_errors = -1;
+	if ( parm.errors->answer ) {
+		fd_errors = G_open_cell_old ( parm.errors->answer, G_find_cell ( parm.errors->answer, "" ) );
+	if ( PROGRESS )
+		G_message (_( "Writing report file to '%s':\n"), parm.report->answer);
+	/* alloc some counter arrays */
+	competitor = G_malloc ( sizeof ( long int) * num_centers );
+	/* make room for storing subjects */
+	for ( i=0; i < num_centers; i ++ ) {
+		report[i].num_subjects = 0;
+		report[i].subject = G_malloc ( sizeof (int) * num_centers );
+		report[i].subject_id = G_malloc ( sizeof (int) * num_centers );
+		report[i].subject_name = G_malloc ( sizeof (char*) * num_centers );
+	/* init area calculations */
+	error = G_begin_cell_area_calculations ();
+	/* get map statistics */
+	if ( PROGRESS )
+		G_message (_("  Getting map statistics:\n" ));
+	GVT_rewind ( pmap );
+	i = 0;
+	while ( GVT_next ( pmap ) ) {
+		if ( error == 0 ) {
+			/* area cannot be calculated in x/y locations */
+			report[i].area = -1.0;
+		} else {
+			report[i].area = 0.0;
+		report[i].id = cats[i];
+		if ( parm.labels->answer ) {
+			report[i].name = strdup ( labels[i] );
+		/* get basic raster stats */
+		report[i].out_count = 0;
+		total_cells = 0;
+		for (row=0; row < nrows; row ++) {
+			G_get_c_raster_row ( fd_output, cell, row );
+			for (col=0; col < ncols; col ++) {
+				if ( !G_is_c_null_value ( &cell[col]) ) {
+					if ( cell[col] == cats[i] ) {
+							report[i].out_count ++;
+							if ( error > 0 ) {
+								/* update area stats */
+								report[i].area = report[i].area + G_area_of_cell_at_row ( row );
+					total_cells ++;
+		/* calculate area (km^2), percentage and maximum reach of this center's territory */
+		report[i].area = report[i].area / 1000000;
+		report[i].percentage =  ( ( (double) report[i].out_count / (double) total_cells) * 100.0 );
+		report[i].max_cost = max_cost[i];
+		/* get error stats */
+			report[i].err_count = 0;
+			report[i].err_sum = 0.0;
+				G_get_d_raster_row ( fd_errors, dcell, row );
+								report[i].err_count ++;
+								report[i].err_sum = report[i].err_sum + (double) dcell[col];
+			report[i].err_avg = ((double) report[i].err_sum / report[i].err_count);
+			/* now get error var and std */
+			report[i].err_var = 0;
+			report[i].err_std = 0.0;
+			sqdiff = 0.0;
+							sqdiff = sqdiff + pow ( ((double) dcell[col] - (double) report[i].err_avg), 2.0 );
+			report[i].err_var = (1.0 / (double) report[i].err_count) * sqdiff;
+			report[i].err_std = sqrt ( report[i].err_var );
+		/* get information about competitors (second highest I) */
+			/* initialize counters */
+			for ( j=0; j < num_centers; j ++ ) {
+				competitor[j] = 0;
+			report[i].aggressor = 0;
+				G_get_c_raster_row ( fd_second, cell_second, row );
+							/* we have a cell that belongs to the current center */
+							/* which on is the most frequent competitor in current center's territory?
+							 * count frequencies for all centers in array of i counters
+							 * we'll find the index of the largest counter when the raster map loop is done.
+							 for (j=0; j < num_centers; j++) {
+							 	if ( cats[j] == cell_second[col] ) {
+							 		competitor [j] ++;
+						} else {
+							/* we have a cell that is outside the current center's territory */
+							/* how frequent is the current center second highest I in the territory of another?  */
+							if ( cell_second[col] == cats[i] ) {
+								/* just sum up and also calculate percentage (against number of cells in foreing territories) */
+								report[i].aggressor ++;
+			/* find most frequent competitor */
+			max = -1;
+			report[i].competitor = 0;
+			report[i].competitor_id = cats[0];
+			for ( j=1; j< num_centers; j ++ ) {
+				if ( (competitor[j] > 0) && ( competitor[j] > max ) ) {
+					max = competitor[j];
+					report[i].competitor = j;
+					report[i].competitor_id = cats[j];
+			/* no competitor found! */
+			if ( max == -1 ) {
+				report[i].competitor = -1;
+			} else {
+				/* get percentage */
+				report[i].competitor_p = ((double) max / (double) report[i].out_count) * 100.0;
+			report[i].aggressor_p =  ( (double)report[i].aggressor / ((double)total_cells - (double)report[i].out_count) )  * 100.0;
+		if ( PROGRESS ) {
+			G_percent (i, num_centers-1, 1);		}
+		i ++;
+	/* now check for boss and/or subjects! */
+	/* check the cell under each center. If it's not owned by the center, then that
+	 * center is dominated by another and we need to store its ID.
+	i = 0;
+		report[i].boss = -1;
+		east = G_easting_to_col ( GVT_get_point_x ( pmap ), &window );
+		north = G_northing_to_row ( GVT_get_point_y ( pmap ), &window );
+		G_get_c_raster_row ( fd_output, cell, (int) north );
+		boss = (CELL) cell[(int) east];
+		if ( boss != cats[i] ) {
+			/* this center is dominated by another center! Store that center's ID */
+				if ( cats[j] == boss ) {
+					report[i].boss = j;
+					report[i].boss_id = boss;
+						report[i].boss_name = strdup ( labels[j] );
+					/* also: append ID and name of this center to the bosse's list */
+					report[j].subject[report[j].num_subjects] = i;
+					report[j].subject_id[report[j].num_subjects] = cats[i];
+						report[j].subject_name[report[j].num_subjects] = strdup ( labels[i] );
+					report[j].num_subjects ++;
+		i++;
+	/* write records to ASCII file */
+	if ( PROGRESS )
+		G_message (_( "  Writing individual records:\n" ));
+		/* header line for tabular report output */
+		fprintf ( fp, "id\tname\trulerid\trname\tcells\tcellsp\tarea\treach" );
+			fprintf ( fp, "\taggressor\taggperc\tcompid\tcompname\tcompperc" );
+			fprintf ( fp, "\tstravg\tstrvar\tstrdev" );
+		fprintf ( fp, "\n" );
+	if ( !flag.tabular->answer ) {
+		/* make a nice header */
+		fprintf ( fp, "This is %s version %.2f\n", argv[0], PROGVERSION);
+		systime = time (NULL);
+		fprintf ( fp, "Calculation started on %s", ctime ( &systime ) );
+		fprintf ( fp, "\tlocation   = %s\n", G_location() );
+		fprintf ( fp, "\tmapset     = %s\n", G_mapset() );
+		sprintf ( tmp, "%s ", argv[0]);
+		for ( j=1; j < argc; j ++ ) {
+			strcat ( tmp, argv[j] );
+			if ( j < (argc - 1) ) {
+				strcat ( tmp, " " );
+		fprintf ( fp, "\tcommand    = %s\n\n", tmp );
+		fprintf ( fp, "===\n\n" );
+	for ( i=0; i < num_centers; i++ ) {
+			/* tabular output: one line per center and always with complete fields */
+			fprintf ( fp, "%i", report[i].id );
+				fprintf ( fp, "\t%s", report[i].name );
+			} else {
+				fprintf ( fp, "\tn.a." );
+			if ( report[i].boss > -1 ) {
+				fprintf ( fp, "\t%i", report[i].boss_id );
+					fprintf ( fp, "\t%s", report[i].boss_name );
+				} else {
+				fprintf ( fp, "\t0" );
+				fprintf ( fp, "\t0.0" );
+			} else {
+				fprintf ( fp, "\t%i", report[i].id );
+				} else {
+				fprintf ( fp, "\t%li", report[i].out_count );
+				fprintf ( fp, "\t%.3f", report[i].percentage );
+				fprintf ( fp, "\t%.3f", report[i].area );
+				fprintf ( fp, "\t%.3f", report[i].max_cost );
+				if (( report[i].aggressor > 0 ) && ( report[i].boss < 0 )) {
+					fprintf ( fp, "\t%li", report[i].aggressor);
+					fprintf ( fp, "\t%.3f", report[i].aggressor_p );
+				} else {
+				if (( report[i].competitor > -1 ) && ( report[report[i].competitor].boss != i ) && ( report[i].boss < 0 )) {
+					fprintf ( fp, "\t%i", report[i].competitor_id);
+					fprintf ( fp, "\t%s", labels[report[i].competitor]);
+					fprintf ( fp, "\t%.3f", report[i].competitor_p );
+				} else {
+					fprintf ( fp, "\t%.3f", report[i].err_avg );
+					fprintf ( fp, "\t%.3f", report[i].err_var );
+					fprintf ( fp, "\t%.3f", report[i].err_std );
+				} else {
+			fprintf ( fp, "\n" ) ;
+		} else {
+			/* this is regular report format: one paragraph per center */
+			/* write records to report file */
+			fprintf ( fp, "(center %i of %i)\n", i + 1, num_centers );
+			fprintf ( fp, "id:\t\t%i\n", report[i].id );
+				fprintf ( fp, "name:\t\t%s\n", report[i].name );
+			} else {
+				fprintf ( fp, "name:\t\tn.a.\n" );
+			if ( report[i].num_subjects > 0 ) {
+				fprintf ( fp, "dominates:\t" );
+				for ( j=0; j<report[i].num_subjects; j ++ ) {
+						fprintf ( fp, "%i (%s)", report[i].subject_id[j], report[i].subject_name[j] );
+					} else {
+						fprintf ( fp, "%i", report[i].subject_id[j] );
+					if ( j < (report[i].num_subjects-1) ) {
+						fprintf ( fp, ", " );
+				fprintf ( fp, "\n");
+			} else {
+				fprintf ( fp, "dominates:\tn.a.\n" );
+					fprintf ( fp, "dominated by:\t%i, %s\n", report[i].boss_id, report[i].boss_name );
+				} else {
+					fprintf ( fp, "dominated by:\t%i\n", report[i].boss_id );
+			} else {
+				fprintf ( fp, "dominated by:\tn.a.\n" );
+				fprintf ( fp, "cells:\t\t%li (%.3f%%)\n", report[i].out_count, report[i].percentage );
+				if ( report[i].area > -1.0 ) {
+					fprintf ( fp, "area:\t\t%.3f sqkm\n", report[i].area );
+				if ( DISTANCE == COST ) {
+					fprintf ( fp, "reach cost:\t%.3f cells\n", report[i].max_cost );
+				} else {
+					fprintf ( fp, "reach dist:\t%.3f km\n", report[i].max_cost / 1000 );
+					fprintf ( fp,"aggressor:\t%li (%.3f%%)\n", report[i].aggressor, report[i].aggressor_p );
+				} else {
+					fprintf ( fp,"aggressor:\tn.a.\n" );
+					fprintf ( fp,"competitor:\t%i, %s (%.3f%%)\n", report[i].competitor_id, labels[report[i].competitor], report[i].competitor_p );
+				} else {
+					fprintf ( fp,"competitor:\tn.a.\n" );
+					fprintf ( fp, "strength avg:\t%.3f\n", report[i].err_avg );
+					fprintf ( fp, "strength var:\t%.3f\n", report[i].err_var );
+					fprintf ( fp, "strength std:\t%.3f\n", report[i].err_std );
+				} else {
+					fprintf ( fp, "strength avg:\tn.a.\n" );
+					fprintf ( fp, "strength var:\tn.a.\n" );
+					fprintf ( fp, "strength std:\tn.a.\n" );
+			fprintf ( fp, "\n\n" );
+			if ( PROGRESS ) {
+				G_percent ( i, num_centers-1, 1 );
+		/* write a nice footer */
+		/* write processing time to logfile */
+		proctime = clock ();
+		timeused = (unsigned long) proctime / CLOCKS_PER_SEC;
+		days = timeused / 86400;
+		hours = (timeused - (days * 86400)) / 3600;
+		mins = (timeused - (days * 86400) - (hours * 3600)) / 60;
+		secs = (timeused - (days * 86400) - (hours * 3600) - (mins * 60));
+		fprintf ( fp, "===" );
+		fprintf ( fp, "\n\nCalculation finished %s",ctime(&systime));
+		fprintf ( fp, "Processing time: %id, %ih, %im, %is\n",
+				days, hours, mins, secs );
+		fflush ( fp );
+	fclose ( fp );
+	/* TODO: also release invidual members of the report struct */
+	G_free ( report );
+	/* close output map(s) */
+	G_close_cell ( fd_output );
+		G_close_cell ( fd_second );
+		G_close_cell ( fd_errors );
+				MAIN
+int main (int argc, char *argv[]) {
+	int i,j;
+	char tmp[5000];
+	int row, col;
+	int nrows, ncols;
+	int fd, fd_temp, fd_error;
+	int fd_second;
+	int fd_boundaries;
+	double x, y;
+	double max_d;
+	double max_c;
+	double C_total;
+	/* for raster map categories, labels and colours */
+	int *cats;
+	char **labels;
+	struct Categories pcats;
+	char **rgb;
+	int r,g,b;
+	/* map history */
+	struct History hist;
+	/* color map rules */
+	struct Colors *colors;
+	DCELL *v1, *v2;
+	int error;
+	double diff;
+	double max_diff;
+	double dist;
+	int valid_I;	/* this var is set to "1", if at least one cell was found to belong to the territory of any
+					   any center in the input map. Its purpose is to guard against cases, where strict mode
+					   is used (-s) and the model parameters are set badly, so that the user is presented
+					   with an all NULL output map
+	int matched;
+	int boss;
+	define_opts ( argc, argv );
+	check_params ();
+	GVT_init ();
+	pmap = GVT_new_map ( );
+	GVT_open_map ( parm.centers->answer, GV_POINT , pmap );
+	a = atof ( parm.a->answer );
+	k = atof ( parm.k->answer );
+	C = G_malloc ( sizeof (double) * pmap->num_records );
+	/* init file descriptors */
+	fd_temp = -1;
+	fd_second = -1;
+	fd_boundaries = -1;
+	if ( parm.c->answer != NULL ) {
+		/* check if C attribute exists */
+		if ( GVT_any_exists ( parm.c->answer, pmap) == FALSE ) {
+				G_fatal_error (_("Error reading C attribute: '%s' does not exist in input vector map '%s'.\n"),
+						parm.c->answer, parm.centers->answer );
+		if ( GVT_numeric_exists ( parm.c->answer, pmap) == FALSE ) {
+						G_fatal_error (_("Error reading C attribute: '%s' is not of type double or integer in input vector map '%s'.\n"),
+		i = 0;
+		C_total = 0;
+			C[i] = GVT_get_numeric ( parm.c->answer, pmap );
+			if ( DEBUG > 1 ) {
+				G_message (_( " %i: C=%.f\n"), i, C[i]);
+			C_total = C_total + C[i];
+			i ++;
+		num_centers = i;
+		/* normalize C attributes */
+		C_norm = G_malloc ( sizeof (double) * num_centers );
+		for ( i = 0; i < num_centers; i ++ ) {
+			C_norm [i] = (double) C[i] / (double) C_total;
+	} else {
+		/* we still need to know at least the number of centers (sites) in the input map! */
+		num_centers = 0;
+			num_centers ++;
+	/* if no attribute for C given: set it to 1.0 for each center */
+	if (parm.c->answer == NULL ) {
+		G_warning (_("No C attribute specified. Assuming constant C=1.0.\n"));
+		for ( i=0; i<pmap->num_records; i++) {
+			C[i] = 1.0;
+	cats = NULL;
+	/* no categories attribute specified? create a new index starting at 1! */
+	if ( parm.cats->answer == NULL ) {
+		cats = G_malloc ( sizeof (int) * num_centers );
+			cats[i] = i + 1;
+	/* check if cats attribute exists and is of type integer */
+	if ( parm.cats->answer != NULL ) {
+		if ( GVT_any_exists ( parm.cats->answer, pmap) == FALSE ) {
+			G_warning (_("Error reading categories attribute: '%s' does not exist in input vector map '%s'.\n"),
+					parm.cats->answer, parm.centers->answer );
+				cats[i] = i + 1;
+		} else {
+		if ( GVT_int_exists ( parm.cats->answer, pmap) == FALSE ) {
+				G_warning (_("Error reading categories attribute: '%s' is not of integer type in input vector map '%s'.\n"),
+					cats[i] = i + 1;
+		if ( GVT_int_exists ( parm.cats->answer, pmap) == TRUE ) {
+			/* categories label is cool, so let's read in all category values in input vector map */
+			i = 0;
+				cats[i] = GVT_get_int ( parm.cats->answer, pmap);
+				i ++;
+	labels = NULL;
+	/* labeling attribute? */
+	if ( parm.labels->answer != NULL ) {
+		if ( GVT_any_exists ( parm.labels->answer, pmap) == FALSE ) {
+				G_fatal_error (_("Error reading label attribute: '%s' does not exist in input vector map '%s'.\n"),
+						parm.labels->answer, parm.centers->answer );
+		if ( GVT_string_exists ( parm.labels->answer, pmap) == FALSE ) {
+				G_fatal_error (_("Error reading label attribute: '%s' is not of text type in input vector map '%s'.\n"),
+	colors = NULL;
+	/* colouring attribute? */
+	make_colors = 0;
+	if ( parm.rgbcol->answer ) {
+		if ( GVT_any_exists ( parm.rgbcol->answer, pmap) == FALSE ) {
+				if ( strcmp ( parm.rgbcol->answer, "GRASSRGB" ) ) {
+					G_warning (_("Colors attribute: '%s' does not exist in input vector map '%s'. Using default colors.\n"),
+						parm.rgbcol->answer, parm.centers->answer );
+		} else {
+			if ( GVT_string_exists ( parm.rgbcol->answer, pmap) == FALSE ) {
+					G_warning (_("Colors attribute: '%s' is not of text type in input vector map '%s'. Using default colors.\n"),
+		if ( GVT_string_exists ( parm.rgbcol->answer, pmap) == TRUE ) {
+		  /* colouring attribute is cool, so read in colours */
+			rgb = G_malloc ( sizeof (char*) * num_centers );
+			i = 0;
+				rgb[i] = GVT_get_string ( parm.rgbcol->answer, pmap);
+				i ++;
+			make_colors = 1;
+	/* allocate an array of center reaches (max cost/dist from a center to claim a cell) */
+	reach = G_malloc ( sizeof (double) * pmap->num_records );
+		reach[i] = -1.0; /* set all centers to unconstrained reach by default */
+	/* maximum cost/distance attribute specified ? */
+	if ( parm.maxdist->answer ) {
+		/* check for valid attribute */
+		if ( GVT_any_exists ( parm.maxdist->answer, pmap) == FALSE ) {
+				G_fatal_error (_("Error reading max reach attribute: '%s' does not exist in input vector map '%s'.\n"),
+								parm.maxdist->answer, parm.centers->answer );
+		if ( GVT_double_exists ( parm.maxdist->answer, pmap) == FALSE ) {
+				G_fatal_error (_("Error reading max reach attribute: '%s' exists in input vector map '%s' but is not of type double.\n"),
+		/* read in all reach values */
+		i = 0;
+			reach[i] = GVT_get_double ( parm.maxdist->answer, pmap );
+			i ++;
+	/* allocate an array of ruler pointers */
+	ruler = G_malloc ( sizeof (int) * pmap->num_records );
+		ruler[i] = i; /* set all centers to be their own rulers by default */
+	/* ruler attribute specified ? */
+	if ( parm.ruler->answer ) {
+		if ( GVT_any_exists ( parm.ruler->answer, pmap) == FALSE ) {
+				G_fatal_error (_("Error reading ruler attribute: '%s' does not exist in input vector map '%s'.\n"),
+								parm.ruler->answer, parm.centers->answer );
+		if ( GVT_int_exists ( parm.ruler->answer, pmap) == FALSE ) {
+				G_fatal_error (_("Error reading ruler attribute: '%s' exists in input vector map '%s' but is not of type integer.\n"),
+		i = 0;
+			ruler[i] = GVT_get_int ( parm.ruler->answer, pmap );
+			i ++;
+		/* now translate the category IDs to the sequential IDs in pmap */
+		for ( i=0; i <= num_centers; i ++ ) {
+			matched = 0;
+			for ( j=0; j <= num_centers; j ++ ) {
+				if ( cats[j] == ruler[i] ) {
+					ruler[i] = j;
+					matched = 1;
+			if ( matched == 0 ) {
+				G_fatal_error (_("Ruler ID '%i' in record no. %i in input map '%s' points to a non-existing record.\n"),
+									ruler[i], i, parm.output->answer );
+	/* register an AT EXIT function that will make sure temp maps
+	 * get deleted
+	atexit ( clean_tmpfiles );
+	/* cost surface mode? check for valid maps or create them ad hoc !!! */
+		make_pseudo = 0;
+		if ( COSTMODE == ATTNAME ) { /* User has specified an attribute name for cost surfaces */
+			/* check if map name attribute exists */
+			if ( GVT_any_exists ( parm.costs_att->answer, pmap) == FALSE ) {
+					G_fatal_error (_("Error reading map name attribute: '%s' does not exist in input vector map '%s'.\n"),
+									parm.costs_att->answer, parm.centers->answer );
+			if ( GVT_string_exists ( parm.costs_att->answer, pmap) == FALSE ) {
+					G_fatal_error (_("Error reading map name attribute: '%s' is not of string type in input vector map '%s'.\n"),
+			/* allocate mem for pointers to cost maps and open all maps */
+			costf = G_calloc ( (unsigned) num_centers, sizeof (int));
+			i = 0;
+				cmapname = GVT_get_string ( parm.costs_att->answer, pmap );
+				costf[i] = G_open_cell_old ( cmapname, G_find_cell ( cmapname, "" ) );
+				if ( costf[i] < 0 ) {
+					G_fatal_error (_("Error opening cost surface raster '%s').\n"),cmapname);
+				i ++;
+				G_free ( cmapname );
+			/* allocate mem for raster map buffers to read data from cost maps */
+			costdcell = G_calloc ( (unsigned) num_centers, sizeof (DCELL*) );
+			for ( i = 0; i < num_centers; i++ ) {
+				costdcell[i] = G_allocate_d_raster_buf();
+			/* allocate an array of doubles for storing cost values */
+			costs = G_calloc ( (unsigned) num_centers, sizeof (double));
+	 * CALCULATE XTENT MODEL
+	if ( PROGRESS )
+		G_message (_("Calculating Xtent model for %i centers:\n"), num_centers);
+	valid_I = 0;
+	/* this globally tracks the maximum distance to each center from within
+	 * any cell in its territory. We may need this for report writing later
+	max_cost = G_malloc ( num_centers * sizeof ( double ) );
+		max_cost[i] = -1.0;
+	cell = G_allocate_c_raster_buf();
+	fd = G_open_cell_new ( parm.output->answer );
+	if ( fd < 0 ) {
+		G_fatal_error (_("Could not open output map %s for writing.\n"), parm.output->answer);
+	/* also output a map of "second best" centers?*/
+	if ( parm.second->answer != NULL ) {
+		cell_second = G_allocate_c_raster_buf();
+		fd_second = G_open_cell_new ( parm.second->answer );
+		if ( fd_second < 0 ) {
+			G_fatal_error (_("Could not open 'second highest I' map %s for writing.\n"), parm.second->answer);
+	/* also output a map of error probability ? */
+	if ( parm.errors->answer != NULL ) {
+		/* for now, we'll just create a temporary map to store the
+		 * unnormalized error
+		temapname = mktmpmap ( "XTENTtmp" );
+		dcell = G_allocate_d_raster_buf();
+		G_set_fp_type(DCELL_TYPE);
+		fd_temp = G_open_fp_cell_new ( temapname );
+		if ( fd_temp < 0 ) {
+			G_fatal_error (_("Could not open temporary error map %s for writing.\n"), temapname );
+		make_error = 1;
+	max_c = 1;
+	max_d = 1;
+	/* write a raster map with an I value for each cell */
+	if ( PROGRESS )
+		G_message (_(" Calculating I values for all cells in region:\n"));
+		G_set_c_null_value ( cell, ncols );
+			G_set_d_null_value ( dcell, ncols );
+			/* if we have cost surfaces, we need to read one row from each map */
+				G_get_d_raster_row ( costf[i], costdcell[i], row );
+		y = G_row_to_northing ( (double) row, &window );
+				/* if we have cost surfaces, we need to read the cost value for each center in this column */
+					costs[i] = (double) costdcell[i][col];
+			x = G_col_to_easting ( (double) col, &window );
+			/* calculate XTENT value I at current coordinates */
+				I = get_center_xtent_original ( x, y, C_norm, a, k, costs, reach, ruler, pmap );
+			} else {
+				I = get_center_xtent_original ( x, y, C, a, k, costs, reach, ruler, pmap );
+			/* update max cost value for this center if necessary */
+			if ( I >= 0 ) {
+					if ( max_cost[I] < costs[I] ) {
+						if ( !G_is_d_null_value ( (DCELL*) &costs[I] ) ) {
+							max_cost[I] = costs[I];
+				if ( DISTANCE == STRAIGHT ) {
+					dist = GVT_get_2D_point_distance ( x, y, pmap );
+					if ( dist > max_cost[I] ) {
+						max_cost[I] = dist;
+			if ( I < 0 ) {
+				/* this can only happen if there is an error calculating I or strict mode is turned on */
+				/* otherwise, the return value of I will be the INDEX of the dominant center ! */
+				G_set_c_null_value ( &cell[col], 1 );
+			} else {
+				cell[col] = (CELL) cats[I];
+			/* this signals that the model has managed to produce at least one center index ;) */
+			if ( (!G_is_c_null_value ( &cell[col] )) && ( I >= 0 ) ) {
+				valid_I = 1;
+			/* if one of the cost surfaces has a NULL value here, we will copy it thru, as well! */
+					if ( G_is_d_null_value (&costdcell[i][col])) {
+		G_put_map_row ( fd, cell );
+		if ( PROGRESS ) {
+			G_percent (row, (nrows-1), 2);
+	/* close basic output map for now */
+	G_close_cell ( fd );
+	/* Now we make a second pass to find the strongest competitor for each cell.
+	 * This code is full of redundant terminology. The following are all
+	 * basically the same: second I, second biggest I, competitor
+	 * The competitor is the center which would have claimed a cell if another,
+	 * more dominant center had not taken it. The difference between the influences
+	 * of the dominant center and the competitor is stored in the 'errors' map.
+	 * It can be interpreted both as the strength of competition and the likelihood
+	 * of making an error when claiming that a specific cell is in the territory of
+	 * center A rather then B.
+	 * The error (= competition strength) measure is normalized in another pass after this loop.
+	 max_diff = 0;
+		/* re-open basic output map */
+		fd = G_open_cell_old ( parm.output->answer, G_find_cell ( parm.output->answer, "" ) );
+		if ( PROGRESS )
+			G_message ( " Finding competitors for all cells in region:\n");
+		/* If center A is dominated by center B, then it can no longer be a competitor of center B !
+	 	* So we need to first identify all such situations and update the 'ruler' array accordingly.
+		i = 0;
+			G_get_c_raster_row ( fd, cell, (int) north );
+						ruler[i] = j;
+			i++;
+			/* initialize error map to be all NULL cells */
+				/* get second highest I */
+						I_second = get_center_xtent_second ( x, y, C_norm, a, k, &diff, costs, ruler, pmap );
+					} else {
+						I_second = get_center_xtent_second ( x, y, C, a, k, &diff, costs, ruler, pmap );
+					if ( diff > max_diff ) {
+						max_diff = diff;
+				if ( G_is_c_null_value ( &cell[col] ) ) {
+					/* if I map has a NULL val here, we need to copy it through */
+					/* because by definition: if I is invalid, then so is 'second I' (competitor) */
+					G_set_c_null_value ( &cell_second[col], 1 );
+						G_set_d_null_value ( &dcell[col], 1 );
+				} else {
+					/* if not, we set the current cell to the second biggest I (=ID of competitor) */
+					cell_second[col] = (CELL) cats[I_second];
+						/* at this point: just store the unnormalized strength of competition
+						 * We will make a second pass later of the 'errors' map to normalize this measure
+						dcell[col] = diff;
+				/* a competitor and competitor's strength (error) can only be calculated where at least
+				 * two territories overlap!
+				if ( I_second < 0 ) {
+					/* this can only happen if there is an error calculating second I or strict mode is turned on */
+					/* otherwise, the return value of I will be the ID of the second most dominant center
+					 * as set above */
+								/* also: copy thru to error map! */
+			G_put_map_row ( fd_second, cell_second );
+				G_put_d_raster_row ( fd_temp, dcell );
+			if ( PROGRESS ) {
+	/* Normalize values in error output map ! */
+		/* we need to make a second pass and normalize the error
+		 * measuere over the whole error map
+		/* close and re-open the (temporary ) error map */
+		G_close_cell ( fd_temp );
+		fd_temp = G_open_cell_old ( temapname, G_find_cell ( temapname, "" ) );
+			G_fatal_error (_("Could not open temporary error map %s for reading.\n"), temapname );
+		/* create the new final (normalized) error map for writing */
+		fd_error = G_open_fp_cell_new ( parm.errors->answer );
+		if ( fd_error < 0 ) {
+			G_fatal_error (_("Could not open error map %s for writing.\n"), parm.errors->answer );
+		if ( max_diff == 0 ) { /* protect against extreme cases and divisio by zero */
+			G_warning (_("The maximum difference between I and second highest I in your map is 0.\n"));
+			if ( PROGRESS )
+				G_message (_( " Setting all error measures to 1.0:\n"));
+				G_get_d_raster_row ( fd_temp, dcell, row );
+					if ( !G_is_d_null_value ( &dcell[col]) ) {
+							dcell[col] = 1.0;
+				G_put_d_raster_row ( fd_error, dcell );
+				if ( PROGRESS ) {
+					G_percent (row, (nrows-1), 2);				}
+		} else {
+			if ( PROGRESS )
+				G_message ( " Normalizing error measures:\n");
+							/* this is the normalized error measure:
+							 * the closer to "1", the higher the risk of error
+							dcell[col] = 1 - dcell[col] / max_diff;
+				if ( PROGRESS ) {
+		/* close raster maps */
+		G_close_cell ( fd_error );
+		/* make a nice gray-shade color table for output map */
+		colors = G_malloc ( sizeof (struct Colors));
+		G_init_colors ( colors );
+		v1 = (DCELL*) G_malloc (sizeof (DCELL));
+		v2 = (DCELL*) G_malloc (sizeof (DCELL));
+		*v1 = 1.0; *v2 = 0.0;
+		G_add_d_raster_color_rule ( v1,0,0,0,v2,255,255,255, colors );
+		G_write_colors ( parm.errors->answer, G_mapset (), colors );
+		G_init_cats ( num_centers, "Name of dominant center", &pcats );
+		/* write map labels */
+		labels = G_malloc ( num_centers * sizeof (char* ) );
+		GVT_rewind ( pmap ); i = 0;
+			labels[i] = GVT_get_string ( parm.labels->answer, pmap );
+			i ++;
+		/* add labels to output map categories */
+		error = 0;
+			error = G_set_cat ( cats[i], labels[i], &pcats );
+			if ( error == -1 ) {
+				G_warning (_("Error writing category label '%s': too many categories.\n"), labels[i] );
+					G_warning (_("Error writing category label '%s': got NULL category.\n"), labels[i] );
+		if ( error == 1 ) {
+			error = G_write_cats ( parm.output->answer, &pcats );
+			if ( error != 1 ) {
+				G_warning (_("Error writing categories for output map '%s'.\n"), parm.output->answer );
+				error = G_write_cats ( parm.second->answer, &pcats );
+					G_warning (_("Error writing categories for 'second highest I' map '%s'.\n"), parm.second->answer );
+		G_free_cats ( &pcats );
+	/* write raster map history */
+	G_short_history ( parm.output->answer, "raster", &hist );
+	sprintf ( hist.title, "XTENT: ID of center with highest local I" );
+	error = G_write_history (parm.output->answer, &hist);
+		G_warning (_("Could not write history file for output raster map '%s'.\n"), parm.output->answer );
+		G_short_history ( parm.second->answer, "raster", &hist );
+		G_command_history ( &hist );
+		sprintf ( hist.title, "XTENT: ID of center with second highest local I" );
+		error = G_write_history (parm.second->answer, &hist);
+			G_warning (_("Could not write history file for 'competitor ID' raster map '%s'.\n"), parm.second->answer );
+		G_short_history ( parm.errors->answer, "raster", &hist );
+		sprintf ( hist.title, "XTENT: competition strength" );
+		error = G_write_history (parm.errors->answer, &hist);
+			G_warning (_("Could not write history file for 'errors' raster map '%s'.\n"), parm.errors->answer );
+	/* make colour map for output maps if RGB attribute given */
+	if ( make_colors ) {
+		if ( parm.errors->answer == NULL ) {
+			/* we don't have a color table yet, because there is no error map */
+		i = 0;
+			if ( sscanf ( GVT_get_string ( parm.rgbcol->answer, pmap),"%i:%i:%i", &r, &g, &b ) != 3 ) {
+				G_warning ( "Malformed RGB attribute string in record no. %i.\n", i + 1 );
+			} else {
+				G_set_color ( (CELL) cats[i], r, g, b, colors );
+			i ++;
+		G_write_colors ( parm.output->answer, G_mapset (), colors );
+			G_write_colors ( parm.second->answer, G_mapset (), colors );
+	/* if user requested a report file to be written: do so now! */
+	if ( parm.report->answer ) {
+		write_report ( cats, labels, argc, argv );
+	/* warn, if model output is entirely empty! */
+	if ( flag.strict->answer ) {
+		if ( valid_I == 0 ) {
+			G_warning ("All cells in output map are NULL. You need to adjust your model parameters (C,a,k) or do not run in 'strict' mode.\n");
+	/* TODO: free colors struct */
+	/* free cell handles */
+	G_free ( cell );
+		G_free ( cell_second );
+		G_free ( dcell );
+	/* free other arrays */
+	G_free ( cats );
+	/* close input vector map 'centers' */
+	GVT_close_map ( pmap );
+	GVT_free_map ( pmap );
+	/* THAT'S IT, FOLKS! */
+	if ( PROGRESS ) {
+		G_message ("\nJOB DONE.\n");
+	return (0);
Property changes on: grass-addons/grass6/raster/r.xtent/main.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/r.xtent.001.png
Modified: svn:mime-type
   - application/octet-stream
   + image/png
Property changes on: grass-addons/grass6/raster/r.xtent/r.xtent.002.png
   + image/png
Property changes on: grass-addons/grass6/raster/r.xtent/r.xtent.003.png
   + image/png
Property changes on: grass-addons/grass6/raster/r.xtent/r.xtent.004.png
   + image/png
Property changes on: grass-addons/grass6/raster/r.xtent/r.xtent.005.png
   + image/png
Property changes on: grass-addons/grass6/raster/r.xtent/r.xtent.006.png
   + image/png
Property changes on: grass-addons/grass6/raster/r.xtent/r.xtent.007.png
   + image/png
Property changes on: grass-addons/grass6/raster/r.xtent/tools.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/tools.h
   + text/x-chdr
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/xtent.c
   + text/x-csrc
   + native
Property changes on: grass-addons/grass6/raster/r.xtent/xtent.h
   + text/x-chdr
   + native
