[GRASS-SVN] r50592 - grass/branches/develbranch_6/gui/wxpython/xml
Tue Jan 31 16:29:09 EST 2012
Author: neteler
Date: 2012-01-31 13:29:09 -0800 (Tue, 31 Jan 2012)
New Revision: 50592
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
menu organization cleanup (joint work with mmetz)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2012-01-31 21:28:53 UTC (rev 50591)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2012-01-31 21:29:09 UTC (rev 50592)
@@ -92,7 +92,7 @@
 	  <label>Import raster data</label>
 	  <items>
 	    <menuitem>
-	      <label>Common import formats</label>
+	      <label>Common formats import</label>
 	      <help>Import raster data into a GRASS map layer using GDAL.</help>
 	      <keywords>raster,import</keywords>
 	      <handler>OnImportGdalLayers</handler>
@@ -1069,6 +1069,32 @@
         </menuitem>
 	  </items>
 	</menu>
+	<menu>
+	  <label>Map type conversions</label>
+	  <items>
+	    <menuitem>
+	      <label>Raster to vector</label>
+	      <help>Converts a raster map into a vector map layer.</help>
+	      <keywords>raster,conversion,vectorization</keywords>
+	      <handler>OnMenuCmd</handler>
+	      <command>r.to.vect</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Raster series to volume</label>
+	      <help>Converts 2D raster map slices to one 3D raster volume map.</help>
+	      <keywords>raster,volume,conversion</keywords>
+	      <command>r.to.rast3</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Raster 2.5D to volume</label>
+	      <help>Creates a 3D volume map based on 2D elevation and value raster maps.</help>
+	      <keywords>raster,raster3d,voxel,conversion</keywords>
+	      <command>r.to.rast3elev</command>
+	    </menuitem>
+	  </items>
+	</menu>
 	<separator />
 	<menuitem>
 	  <label>Buffer rasters</label>
@@ -1078,6 +1104,13 @@
 	  <command>r.buffer</command>
 	</menuitem>
 	<menuitem>
+	  <label>Concentric circles</label>
+	  <help>Creates a raster map containing concentric rings around a given point.</help>
+	  <keywords>raster,geometry</keywords>
+	  <command>r.circle</command>
+	</menuitem>
+	<menuitem>
 	  <label>Closest points</label>
 	  <help>Locates the closest points between objects in two raster maps.</help>
 	  <keywords>raster,distance</keywords>
@@ -1174,11 +1207,11 @@
 	  <label>Terrain analysis</label>
 	  <items>
 	    <menuitem>
-	      <label>Cumulative movement costs</label>
-	      <help>Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost.</help>
-	      <keywords>raster,cost surface,cumulative costs</keywords>
+	      <label>Generate contour lines</label>
+	      <help>Produces a vector map of specified contours from a raster map.</help>
+	      <keywords>raster,DEM,contours,vector</keywords>
-	      <command>r.walk</command>
+	      <command>r.contour</command>
 	    </menuitem>
 	    <menuitem>
 	      <label>Cost surface</label>
@@ -1188,6 +1221,13 @@
 	      <command>r.cost</command>
 	    </menuitem>
 	    <menuitem>
+	      <label>Cumulative movement costs</label>
+	      <help>Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost.</help>
+	      <keywords>raster,cost surface,cumulative costs</keywords>
+	      <command>r.walk</command>
+	    </menuitem>
+	    <menuitem>
 	      <label>Least cost route or flow</label>
 	      <help>Traces a flow through an elevation model on a raster map.</help>
 	      <keywords>raster,hydrology</keywords>
@@ -1315,8 +1355,37 @@
 	      <command>r.flow</command>
 	    </menuitem>
+	    <menuitem>
+	      <label>Watershed analysis</label>
+	      <help>Watershed basin analysis program.</help>
+	      <keywords>raster,hydrology</keywords>
+	      <command>r.watershed</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Watershed subbasins</label>
+	      <help>Generates watershed subbasins raster map.</help>
+	      <command>r.basins.fill</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Watershed basin creation</label>
+	      <help>Watershed basin creation program.</help>
+	      <command>r.water.outlet</command>
+	    </menuitem>
 	    <separator />
 	    <menuitem>
+	      <label>Groundwater modeling</label>
+	      <help>Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions.</help>
+	      <command>r.gwflow</command>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
 	      <label>SIMWE Overland flow modeling</label>
 	      <help>Overland flow hydrologic simulation using path sampling method (SIMWE).</help>
 	      <keywords>raster,flow,hydrology</keywords>
@@ -1345,37 +1414,8 @@
 	      <command>r.topmodel</command>
 	    </menuitem>
-	    <separator />
-	    <menuitem>
-	      <label>Watershed subbasins</label>
-	      <help>Generates watershed subbasins raster map.</help>
-	      <keywords>raster,hydrology</keywords>
-	      <handler>OnMenuCmd</handler>
-	      <command>r.basins.fill</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Watershed analysis</label>
-	      <help>Watershed basin analysis program</help>
-	      <command>r.watershed</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Watershed basin creation</label>
-	      <help>Creates watershed basins.</help>
-	      <command>r.water.outlet</command>
-	    </menuitem>
 	  </items>
 	</menu>
-    <menuitem>
-      <label>Groundwater modeling</label>
-      <help>Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions.</help>
-      <keywords>raster</keywords>
-      <command>r.gwflow</command>
-    </menuitem>
 	<menu>
 	  <label>Landscape structure modeling</label>
 	  <items>
@@ -1595,13 +1635,6 @@
 	  </items>
 	</menu>
 	<separator />
-	<menuitem>
-	  <label>Concentric circles</label>
-	  <help>Creates a raster map containing concentric rings around a given point.</help>
-	  <keywords>raster,geometry</keywords>
-	  <command>r.circle</command>
-	</menuitem>
 	<menu>
 	  <label>Generate random cells</label>
 	  <items>
@@ -1671,13 +1704,6 @@
 	    </menuitem>
 	  </items>
 	</menu>
-	<menuitem>
-	  <label>Generate contour lines</label>
-	  <help>Produces a vector map of specified contours from a raster map.</help>
-	  <keywords>raster,DEM,contours,vector</keywords>
-	  <command>r.contour</command>
-	</menuitem>
 	<menu>
 	  <label>Interpolate surfaces</label>
 	  <items>
@@ -1893,35 +1919,6 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
-	      <label>Create or rebuild topology</label>
-	      <help>Creates topology for GRASS vector map.</help>
-	      <keywords>vector,topology</keywords>
-	      <command>v.build</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Rebuild topology on all vector maps</label>
-	      <help>Rebuilds topology on all vector maps in the current mapset.</help>
-	      <keywords>vector</keywords>
-	      <command>v.build.all</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Clean vector map</label>
-	      <help>Toolset for cleaning topology of vector map.</help>
-	      <handler>OnVectorCleaning</handler>
-	      <command>v.clean</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Smooth or simplify</label>
-	      <help>Vector based generalization.</help>
-	      <keywords>vector,generalization,simplification,smoothing,displacement,network generalization</keywords>
-	      <command>v.generalize</command>
-	    </menuitem>
-	    <separator />
-	    <menuitem>
 	      <label>Convert object types</label>
 	      <help>Change the type of geometry elements.</help>
 	      <keywords>vector,geometry</keywords>
@@ -1930,35 +1927,6 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
-	      <label>Add centroids</label>
-	      <help>Adds missing centroids to closed boundaries.</help>
-	      <keywords>vector,centroid,area</keywords>
-	      <command>v.centroids</command>
-	    </menuitem>
-	    <separator />
-	    <menuitem>
-	      <label>Build polylines</label>
-	      <help>Builds polylines from lines or boundaries.</help>
-	      <keywords>vector,geometry,topology</keywords>
-	      <command>v.build.polylines</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Split lines</label>
-	      <help>Split lines to shorter segments.</help>
-	      <keywords>vector,geometry</keywords>
-	      <command>v.split</command>
-	    </menuitem>
-	    <menuitem>
-	      <label>Split polylines</label>
-	      <help>Creates points/segments from input vector lines and positions.</help>
-	      <command>v.segment</command>
-	    </menuitem>
-	    <menuitem>
 	      <label>Parallel lines</label>
 	      <help>Create parallel line to input lines</help>
@@ -2029,6 +1997,69 @@
 	  </items>
 	</menu>
 	<menu>
+	  <label>Topology maintenance</label>
+	  <items>
+	    <menuitem>
+	      <label>Create or rebuild topology</label>
+	      <help>Creates topology for GRASS vector map.</help>
+	      <keywords>vector,topology</keywords>
+	      <command>v.build</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Rebuild topology on all vector maps</label>
+	      <help>Rebuilds topology on all vector maps in the current mapset.</help>
+	      <keywords>vector</keywords>
+	      <command>v.build.all</command>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
+	      <label>Build polylines</label>
+	      <help>Builds polylines from lines or boundaries.</help>
+	      <keywords>vector,geometry,topology</keywords>
+	      <command>v.build.polylines</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Split lines</label>
+	      <help>Split lines to shorter segments.</help>
+	      <keywords>vector,geometry</keywords>
+	      <command>v.split</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Split polylines</label>
+	      <help>Creates points/segments from input vector lines and positions.</help>
+	      <command>v.segment</command>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
+	      <label>Clean vector map</label>
+	      <help>Toolset for cleaning topology of vector map.</help>
+	      <handler>OnVectorCleaning</handler>
+	      <command>v.clean</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Smooth or simplify</label>
+	      <help>Vector based generalization.</help>
+	      <keywords>vector,generalization,simplification,smoothing,displacement,network generalization</keywords>
+	      <command>v.generalize</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Add centroids</label>
+	      <help>Adds missing centroids to closed boundaries.</help>
+	      <keywords>vector,centroid,area</keywords>
+	      <command>v.centroids</command>
+	    </menuitem>
+	  </items>
+	</menu>
+	<menu>
 	  <label>Manage colors</label>
 	  <items>
 	    <menuitem>
@@ -2047,23 +2078,79 @@
 	    </menuitem>
 	  </items>
 	</menu>
+	<menu>
+	  <label>Query vector map</label>
+	  <items>
+	    <menuitem>
+	      <label>Query with coordinate(s)</label>
+	      <help>Queries a vector map layer at given locations.</help>
+	      <keywords>vector,querying</keywords>
+	      <command>v.what</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Query vector attribute data</label>
+	      <help>Prints vector map attributes.</help>
+	      <keywords>vector,database,attribute table</keywords>
+	      <command>v.db.select</command>
+	    </menuitem>
+	  </items>
+	</menu>
+	<menu>
+	  <label>Feature selection</label>
+	  <items>
+	    <menuitem>
+	      <label>Attribute query</label>
+	      <help>Selects vector objects from an existing vector map and creates a new map containing only the selected objects.</help>
+	      <keywords>vector,extract</keywords>
+	      <command>v.extract</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Spatial query</label>
+	      <help>Selects features from vector map (A) by features from other vector map (B).</help>
+	      <keywords>vector,spatial query</keywords>
+	      <command>v.select</command>
+	    </menuitem>
+	  </items>
+	 </menu>
+	 <menu>
+	  <items>
+	    <menuitem>
+	      <label>Vector to raster</label>
+	      <help>Converts (rasterize) a vector map into a raster map.</help>
+	      <keywords>vector,raster,conversion</keywords>
+	      <command>v.to.rast</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Vector to volume</label>
+	      <help>Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer.</help>
+	      <keywords>vector,volume,conversion</keywords>
+	      <command>v.to.rast3</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>2D vector to 3D vector</label>
+	      <help>Performs transformation of 2D vector features to 3D.</help>
+	      <keywords>vector,transformation,3D</keywords>
+	      <command>v.to.3d</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Sites to vector</label>
+	      <help>Converts a GRASS site_lists file into a vector map.</help>
+	      <keywords>vector,import,sites</keywords>
+	      <command>v.in.sites</command>
+	    </menuitem>
+	  </items>
+	</menu>
 	<separator />
 	<menuitem>
-	  <label>Attribute query</label>
-	  <help>Selects vector objects from an existing vector map and creates a new map containing only the selected objects.</help>
-	  <keywords>vector,extract</keywords>
-	  <command>v.extract</command>
-	</menuitem>
-	<menuitem>
-	  <label>Spatial query</label>
-	  <help>Selects features from vector map (A) by features from other vector map (B).</help>
-	  <keywords>vector,spatial query</keywords>
-	  <command>v.select</command>
-	</menuitem>
-	<separator />
-	<menuitem>
 	  <label>Buffer vectors</label>
 	  <help>Creates a buffer around features of given type (areas must contain centroid).</help>
 	  <keywords>vector,buffer</keywords>
@@ -2582,35 +2669,36 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
+	      <label>Input for supervised MLC</label>
+	      <help>Generates statistics for i.maxlik from raster map.</help>
+	      <keywords>imagery,classification,supervised,MLC</keywords>
+	      <command>i.gensig</command>
+	    </menuitem>
+	    <menuitem>
+	      <label>Maximum likelihood classification (MLC)</label>
+	      <help>Classifies the cell spectral reflectances in imagery data.</help>
+	      <keywords>imagery,classification,MLC</keywords>
+	      <command>i.maxlik</command>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
 	      <label>Interactive input for supervised classification (requires Xterm)</label>
 	      <help>Generates spectral signatures for an image by allowing the user to outline regions of interest.</help>
 	      <keywords>imagery,classification</keywords>
 	      <handler>OnXTerm</handler>
 	      <command>i.class</command>
 	    </menuitem>
+	    <separator />
 	    <menuitem>
-	      <label>Input for supervised MLC</label>
-	      <help>Generates statistics for i.maxlik from raster map.</help>
-	      <keywords>imagery,classification,supervised,MLC</keywords>
-	      <command>i.gensig</command>
-	    </menuitem>
-	    <menuitem>
 	      <label>Input for supervised SMAP</label>
 	      <help>Generates statistics for i.smap from raster map.</help>
 	      <keywords>imagery,classification,supervised,SMAP</keywords>
 	      <command>i.gensigset</command>
 	    </menuitem>
-	    <separator />
 	    <menuitem>
-	      <label>Maximum likelihood classification (MLC)</label>
-	      <help>Classifies the cell spectral reflectances in imagery data.</help>
-	      <keywords>imagery,classification,MLC</keywords>
-	      <command>i.maxlik</command>
-	    </menuitem>
-	    <menuitem>
 	      <label>Sequential maximum a posteriori classification (SMAP)</label>
 	      <help>Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation.</help>
@@ -2777,6 +2865,18 @@
 	    </menuitem>
 	  </items>
 	</menu>
+	<menu>
+	  <items>
+	    <menuitem>
+	      <label>Volume to raster series</label>
+	      <help>Converts 3D raster maps to 2D raster maps</help>
+	      <keywords>raster3d,voxel</keywords>
+	      <command>r3.to.rast</command>
+	    </menuitem>
+	  </items>
+	</menu>
 	<separator />
 	<menuitem>
 	  <label>3D Mask</label>
