[GRASS-SVN] r52307 - in grass/trunk: include/defs lib/gis lib/vector/Vlib vector/v.external
Thu Jul 5 04:26:21 PDT 2012
Author: martinl
Date: 2012-07-05 04:26:21 -0700 (Thu, 05 Jul 2012)
New Revision: 52307
   grass/trunk/include/defs/vector.h
   grass/trunk/lib/gis/parser.c
   grass/trunk/lib/vector/Vlib/close.c
   grass/trunk/lib/vector/Vlib/close_ogr.c
   grass/trunk/lib/vector/Vlib/close_pg.c
   grass/trunk/lib/vector/Vlib/header.c
   grass/trunk/lib/vector/Vlib/hist.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/open_nat.c
   grass/trunk/lib/vector/Vlib/open_pg.c
   grass/trunk/lib/vector/Vlib/pg_local_proto.h
   grass/trunk/vector/v.external/list.c
vlib: when writing to external formats (defined by v.external.out) vector library creates link automatically when closing the map (no need to run v.external explicitly)
gislib: remove extra check for PG/OGR files
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/include/defs/vector.h	2012-07-05 11:26:21 UTC (rev 52307)
@@ -467,6 +467,7 @@
 int Vect_open_fidx(struct Map_info *, struct Format_info_offset *);
 int Vect_save_fidx(struct Map_info *, struct Format_info_offset *);
 int Vect_fidx_dump(const struct Map_info *, FILE *);
+int Vect_save_frmt(struct Map_info *);
 int Vect__write_head(const struct Map_info *);
 int Vect__read_head(struct Map_info *);
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/gis/parser.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -1325,11 +1325,6 @@
 			found = TRUE;
-		    if (found && strcmp(element, "vector") == 0 &&
-			(G_find_file("", "OGR", G_mapset()) ||
-			 G_find_file("", "PG", G_mapset())))
-			found = FALSE;
 		    if (found) {	/* found */
 			if (!st->overwrite && !over) {
                             if (G_verbose() > -1) {
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/vector/Vlib/close.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -5,7 +5,7 @@
    Higher level functions for reading/writing/manipulating vectors.
-   (C) 2001-2009, 2011 by the GRASS Development Team
+   (C) 2001-2009, 2011-2012 by the GRASS Development Team
    This program is free software under the GNU General Public License
    (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -135,12 +135,10 @@
-    if (Map->format == GV_FORMAT_NATIVE) {
-	G_debug(1, "close history file");
-	if (Map->hist_fp != NULL)
-	    fclose(Map->hist_fp);
+    G_debug(1, "close history file");
+    if (Map->hist_fp)
+        fclose(Map->hist_fp);
     /* close level 1 files / data sources if not head_only */
     if (!Map->head_only) {
 	if (((*Close_array[Map->format][1]) (Map)) != 0) {
@@ -160,6 +158,61 @@
     return 0;
+   \brief Save format definition file for vector map
+   \param Map pointer to Map_info structure
+   \return 1 on success
+   \return 0 on error
+int Vect_save_frmt(struct Map_info *Map)
+    FILE *fd;
+    char buf[GPATH_MAX];
+    if (Map->format != GV_FORMAT_OGR &&
+        Map->format != GV_FORMAT_POSTGIS) {
+        G_warning(_("Invalid request for writing frmt file - map format is %d"), Map->format);
+        return 0;
+    /* create frmt file */
+    sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
+    fd = G_fopen_new(buf, GV_FRMT_ELEMENT);
+    if (fd == NULL) {
+        G_fatal_error("Unable to create file '%s'", buf);
+    if (Map->format == GV_FORMAT_POSTGIS) {
+#ifdef HAVE_POSTGRES
+        fprintf(fd, "FORMAT: postgis\n");
+        fprintf(fd, "CONNINFO: %s\n", Map->fInfo.pg.conninfo);
+        fprintf(fd, "SCHEMA: %s\n",   Map->fInfo.pg.schema_name);
+        fprintf(fd, "TABLE: %s\n",    Map->fInfo.pg.table_name);
+#else
+        G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
+        return 0;
+#endif
+    } else if (Map->format == GV_FORMAT_OGR) {
+#ifdef HAVE_OGR
+        fprintf(fd, "FORMAT: ogr\n");
+        fprintf(fd, "DSN: %s\n",   Map->fInfo.ogr.dsn);
+        fprintf(fd, "LAYER: %s\n", Map->fInfo.ogr.layer_name);
+#else
+        G_fatal_error(_("GRASS is not compiled with OGR support"));
+        return 0;
+#endif
+    G_verbose_message(_("Link to vector map <%s> created"), Map->name);
+    /* close frmt file */
+    fclose(fd);
+    return 1;
 void unlink_file(const struct Map_info *Map, const char *name)
Modified: grass/trunk/lib/vector/Vlib/close_ogr.c
--- grass/trunk/lib/vector/Vlib/close_ogr.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/vector/Vlib/close_ogr.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -44,8 +44,14 @@
     ogr_info = &(Map->fInfo.ogr);
     if (Map->format != GV_FORMAT_OGR_DIRECT &&
-	(Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW))
-	Vect__write_head(Map);
+        (Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW)) {
+        /* write header */
+        Vect__write_head(Map);
+        if (G_find_file2("", "OGR", G_mapset())) {
+            /* write frmt file for created PG-link */
+            Vect_save_frmt(Map);
     if (ogr_info->feature_cache)
 	OGR_F_Destroy(ogr_info->feature_cache);
Modified: grass/trunk/lib/vector/Vlib/close_pg.c
--- grass/trunk/lib/vector/Vlib/close_pg.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/vector/Vlib/close_pg.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -43,8 +43,14 @@
         return -1;
     pg_info = &(Map->fInfo.pg);
-    if (Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW)
+    if (Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW) {
+        if (G_find_file2("", "PG", G_mapset())) {
     /* close connection */
     if (pg_info->res) {
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/vector/Vlib/header.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -84,7 +84,7 @@
     head_fp = G_fopen_new(buf, GV_HEAD_ELEMENT);
     if (head_fp == NULL) {
-	G_warning(_("Unable to open header file of vector <%s>"),
+	G_warning(_("Unable to create header file for vector map <%s>"),
 		  Vect_get_full_name(Map));
 	return -1;
@@ -102,7 +102,8 @@
     fprintf(head_fp, "MAP THRESH:   %f\n", Vect_get_thresh(Map));
     fclose(head_fp);
-    return (0);
+    return 0;
Modified: grass/trunk/lib/vector/Vlib/hist.c
--- grass/trunk/lib/vector/Vlib/hist.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/vector/Vlib/hist.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -51,8 +51,6 @@
    \brief Write string to history file
-   Only native format supported.
    \param str string to write
@@ -69,7 +67,7 @@
 	fflush(Map->hist_fp);
-    return (ret);
+    return ret;
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/vector/Vlib/open.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -25,9 +25,9 @@
 #include <grass/vector.h>
 #include <grass/glocale.h>
-/* PG-related defines */
-#define FID_COLUMN "fid"
-#define GEOMETRY_COLUMN "geom"
+#include "pg_local_proto.h"
+#endif
   \brief Number of levels
@@ -108,6 +108,7 @@
 static int open_old(struct Map_info *, const char *, const char *,
                     const char *, int, int);
+static int map_format(struct Map_info *);
   \brief Predetermine level at which a vector map will be opened for
@@ -700,8 +701,7 @@
 int Vect_open_new(struct Map_info *Map, const char *name, int with_z)
     int ret;
-    char buf[500];
-    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+    char xname[GNAME_MAX], xmapset[GMAPSET_MAX], buf[GPATH_MAX];
     G_debug(2, "Vect_open_new(): name = %s", name);
@@ -725,104 +725,21 @@
         return -1;
-    /* determine output format native or ogr */
-    Map->format = GV_FORMAT_NATIVE;
-    if (strcmp(G_program_name(), "v.external") != 0) {
-        if (G_find_file2("", "OGR", G_mapset())) {
-            /* OGR */
-            FILE *fp;
-            const char *p;
-            struct Key_Value *key_val;
-            struct Format_info_ogr *ogr_info;
-            G_debug(2, " using OGR format");
-            Map->format = GV_FORMAT_OGR_DIRECT;
-            fp = G_fopen_old("", "OGR", G_mapset());
-            if (!fp) {
-                G_fatal_error(_("Unable to open OGR file"));
-            key_val = G_fread_key_value(fp);
-            fclose(fp);
-            ogr_info = &(Map->fInfo.ogr);
-            /* format */
-            p = G_find_key_value("format", key_val);
-            if (p)
-                ogr_info->driver_name = G_store(p);
-            /* dsn */
-            p = G_find_key_value("dsn", key_val);
-            if (p)
-                ogr_info->dsn = G_store(p);
-            /* options */
-            p = G_find_key_value("options", key_val);
-            if (p)
-                ogr_info->layer_options = G_tokenize(p, ",");
-            ogr_info->layer_name = G_store(name);
-        if (G_find_file2("", "PG", G_mapset())) {
-            /* PostGIS */
-            if (Map->fInfo.ogr.driver_name) {
-                G_warning(_("OGR output also detected, using OGR"));
-            else {
-                FILE *fp;
-                const char *p;
-                struct Format_info_pg *pg_info;
-                G_debug(2, " using PostGIS format");
-                Map->format = GV_FORMAT_POSTGIS;
-                fp = G_fopen_old("", "PG", G_mapset());
-                if (!fp) {
-                    G_fatal_error(_("Unable to open PG file"));
-                fclose(fp);
-                pg_info = &(Map->fInfo.pg);
-                /* conninfo */
-                p = G_find_key_value("conninfo", key_val);
-                if (p) {
-                    pg_info->conninfo = G_store(p);
-                    G_debug(1, "PG: conninfo = '%s'", pg_info->conninfo);
-                /* schema (default: public) */
-                p = G_find_key_value("schema", key_val);
-                if (p)
-                    pg_info->schema_name = G_store(p);
-                else
-                    pg_info->schema_name = G_store("public");
-                G_debug(1, "PG: schema_name = '%s'", pg_info->schema_name);
-                /* fid column (default: ogc_fid) */
-                p = G_find_key_value("fid", key_val);
-                if (p)
-                    pg_info->fid_column = G_store(p);
-                else
-                    pg_info->fid_column = G_store(FID_COLUMN);
-                G_debug(1, "PG: fid_column = '%s'", pg_info->fid_column);
-                /* geometry column (default: wkb_geometry) */
-                p = G_find_key_value("geometry_name", key_val);
-                if (p)
-                    pg_info->geom_column = G_store(p);
-                else
-                    pg_info->geom_column = G_store(GEOMETRY_COLUMN);
-                G_debug(1, "PG: geom_column = '%s'", pg_info->geom_column);
-                /* table name */
-                Map->fInfo.pg.table_name = G_store(name);
-        /* native */
-        G_debug(2, " using native format");
+    /* store basic info (map at mapset) */
+    Map->name = G_store(name);
+    Map->mapset = G_store(G_mapset());
+    Map->location = G_store(G_location());
+    Map->gisdbase = G_store(G_gisdbase());
+    /* determine output format */
+    if (strcmp(G_program_name(), "v.external") != 0)
+        Map->format = map_format(Map);
+    else
+        Map->format = GV_FORMAT_NATIVE;
+    if (Map->format != GV_FORMAT_OGR_DIRECT) {
+        G_debug(2, " using non-direct format");
         /* check if map already exists */
         if (G_find_vector2(name, G_mapset()) != NULL) {
             G_warning(_("Vector map <%s> already exists and will be overwritten"),
@@ -834,13 +751,27 @@
                 return -1;
+        /* write header file
+           note: header & history file is also written for external
+           formats since vector library create links automatically
+           when closing the map
+        Map->head.size = 0;
+        Map->head.head_size = GV_COOR_HEAD_SIZE + 4;
+        /* create history file */
+        Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
+        if (Map->hist_fp == NULL) {
+            G_warning(_("Unable to open history file of vector map <%s>"),
+                      name);
+            return -1;
-    Map->name     = G_store(name);
-    Map->mapset   = G_store(G_mapset());
-    Map->location = G_store(G_location());
-    Map->gisdbase = G_store(G_gisdbase());
     /* set 2D/3D */
     Map->plus.spidx_with_z = Map->plus.with_z = Map->head.with_z = (with_z != 0);
@@ -850,17 +781,6 @@
         return -1;
-        /* Open history file */
-        sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
-        Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
-        if (Map->hist_fp == NULL) {
-            G_warning(_("Unable to open history file of vector map <%s>"),
-                      name);
-            return -1;
     Open_level = 0;
     /* initialize topo */
@@ -1184,3 +1104,104 @@
     return 0;
+/* check for external formats definition */
+int map_format(struct Map_info *Map)
+        /* OGR */
+        FILE *fp;
+        const char *p;
+        struct Key_Value *key_val;
+        struct Format_info_ogr *ogr_info;
+        G_debug(2, " using OGR format");
+        Map->format = GV_FORMAT_OGR;
+        fp = G_fopen_old("", "OGR", G_mapset());
+        if (!fp) {
+            G_fatal_error(_("Unable to open OGR file"));
+        key_val = G_fread_key_value(fp);
+        fclose(fp);
+        ogr_info = &(Map->fInfo.ogr);
+        /* format */
+        p = G_find_key_value("format", key_val);
+        if (p)
+            ogr_info->driver_name = G_store(p);
+        /* dsn */
+        p = G_find_key_value("dsn", key_val);
+        if (p)
+            ogr_info->dsn = G_store(p);
+        /* options */
+        p = G_find_key_value("options", key_val);
+        if (p)
+            ogr_info->layer_options = G_tokenize(p, ",");
+        ogr_info->layer_name = G_store(Map->name);
+        /* PostGIS */
+        if (Map->fInfo.ogr.driver_name) {
+            G_warning(_("OGR output also detected, using OGR"));
+        else {
+            FILE *fp;
+            const char *p;
+            struct Format_info_pg *pg_info;
+            G_debug(2, " using PostGIS format");
+            Map->format = GV_FORMAT_POSTGIS;
+            fp = G_fopen_old("", "PG", G_mapset());
+            if (!fp) {
+                G_fatal_error(_("Unable to open PG file"));
+            fclose(fp);
+            pg_info = &(Map->fInfo.pg);
+            /* conninfo */
+            p = G_find_key_value("conninfo", key_val);
+            if (p) {
+                pg_info->conninfo = G_store(p);
+                G_debug(1, "PG: conninfo = '%s'", pg_info->conninfo);
+            /* schema (default: public) */
+            p = G_find_key_value("schema", key_val);
+            if (p)
+                pg_info->schema_name = G_store(p);
+            else
+                pg_info->schema_name = G_store("public");
+            G_debug(1, "PG: schema_name = '%s'", pg_info->schema_name);
+            /* fid column (default: fid) */
+            p = G_find_key_value("fid", key_val);
+            if (p)
+                pg_info->fid_column = G_store(p);
+            else
+                pg_info->fid_column = G_store(FID_COLUMN);
+#endif
+            G_debug(1, "PG: fid_column = '%s'", pg_info->fid_column);
+            /* geometry column (default: geom) */
+            p = G_find_key_value("geometry_name", key_val);
+            if (p)
+                pg_info->geom_column = G_store(p);
+            else
+                pg_info->geom_column = G_store(GEOMETRY_COLUMN);
+#endif
+            G_debug(1, "PG: geom_column = '%s'", pg_info->geom_column);
+            /* table name */
+            pg_info->table_name = G_store(Map->name);
+    return Map->format;
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/vector/Vlib/open_nat.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -90,7 +90,7 @@
 int V1_open_new_nat(struct Map_info *Map, const char *name, int with_z)
-    char buf[1000];
     G_debug(1, "V1_open_new_nat(): name = %s", name);
@@ -123,10 +123,6 @@
     G_file_name(name_buf, buf, GV_COOR_ELEMENT, G_mapset());
-    Map->head.size = 0;
-    Map->head.head_size = GV_COOR_HEAD_SIZE + 4;
     /* set conversion matrices */
     dig_init_portable(&(Map->head.port), dig__byte_order_out());
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -240,12 +240,12 @@
     /* if fid_column not defined, use 'ogc_fid' */
     if (!pg_info->fid_column) {
-        pg_info->fid_column = G_store("ogc_fid");
     /* if geom_column not defined, use 'wkb_geometry' */
     if (!pg_info->geom_column) {
-        pg_info->geom_column = G_store("wkb_geometry");
     /* check if feature table already exists */
Modified: grass/trunk/lib/vector/Vlib/pg_local_proto.h
--- grass/trunk/lib/vector/Vlib/pg_local_proto.h	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/lib/vector/Vlib/pg_local_proto.h	2012-07-05 11:26:21 UTC (rev 52307)
@@ -8,6 +8,9 @@
 #define CURSOR_PAGE 500
+#define FID_COLUMN       "fid"
+#define GEOMETRY_COLUMN "geom"
 #define SWAP32(x) \
         ((unsigned int)( \
             (((unsigned int)(x) & (unsigned int)0x000000ffUL) << 24) | \
Modified: grass/trunk/vector/v.external/list.c
--- grass/trunk/vector/v.external/list.c	2012-07-05 08:20:28 UTC (rev 52306)
+++ grass/trunk/vector/v.external/list.c	2012-07-05 11:26:21 UTC (rev 52307)
@@ -211,7 +211,8 @@
 		    fprintf(fd, "%s\n", value_table);
-	if (table_name && strcmp(value_table, table_name) == 0) {
+	if ((!schema_name || strcmp(value_schema, schema_name) == 0) &&
+            table_name && strcmp(value_table, table_name) == 0) {
 	    ret = row;
 	    *is3D = WITHOUT_Z;
